  4. Adapter "smartmeter"
    apollon77A
3.6k Beiträge 281 Kommentatoren 3.5m Aufrufe 162 Beobachtet
  • A AndieKiste
    Ok, hab die Einstellungen wieder auf Default gestellt.
    2022-01-08 17:29:11.277 - warn: smartmeter.0 (1659) No or too long answer from Serial Device after last request.
    2022-01-08 17:32:13.052 - info: smartmeter.0 (1659) List of port: [{"path":"/dev/ttyUSB0"},{"path":"/dev/ttyUSB1"},{"path":"/dev/ttyS0"},{"path":"/dev/ttyS1"},{"path":"/dev/ttyS10"},{"path":"/dev/ttyS11"},{"path":"/dev/ttyS12"},{"path":"/dev/ttyS13"},{"path":"/dev/ttyS14"},{"path":"/dev/ttyS15"},{"path":"/dev/ttyS16"},{"path":"/dev/ttyS17"},{"path":"/dev/ttyS18"},{"path":"/dev/ttyS19"},{"path":"/dev/ttyS2"},{"path":"/dev/ttyS20"},{"path":"/dev/ttyS21"},{"path":"/dev/ttyS22"},{"path":"/dev/ttyS23"},{"path":"/dev/ttyS24"},{"path":"/dev/ttyS25"},{"path":"/dev/ttyS26"},{"path":"/dev/ttyS27"},{"path":"/dev/ttyS28"},{"path":"/dev/ttyS29"},{"path":"/dev/ttyS3"},{"path":"/dev/ttyS30"},{"path":"/dev/ttyS31"},{"path":"/dev/ttyS4"},{"path":"/dev/ttyS5"},{"path":"/dev/ttyS6"},{"path":"/dev/ttyS7"},{"path":"/dev/ttyS8"},{"path":"/dev/ttyS9"}]
    2022-01-08 17:32:27.805 - info: host.iobroker stopInstance system.adapter.smartmeter.0 (force=false, process=true)
    2022-01-08 17:32:27.810 - info: smartmeter.0 (1659) Got terminate signal TERMINATE_YOURSELF
    2022-01-08 17:32:27.811 - info: host.iobroker stopInstance system.adapter.smartmeter.0 send kill signal
    2022-01-08 17:32:27.811 - info: smartmeter.0 (1659) terminating
    2022-01-08 17:32:27.811 - info: smartmeter.0 (1659) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2022-01-08 17:32:28.373 - info: host.iobroker instance system.adapter.smartmeter.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2022-01-08 17:32:30.857 - info: host.iobroker instance system.adapter.smartmeter.0 started with pid 1678
    2022-01-08 17:32:32.060 - info: smartmeter.0 (1678) starting. Version 3.2.1 in /opt/iobroker/node_modules/iobroker.smartmeter, node: v12.22.8, js-controller: 3.3.22
    2022-01-08 17:34:32.103 - info: smartmeter.0 (1678) Error: No or too long answer from Serial Device after last request.
    2022-01-08 17:34:32.105 - warn: smartmeter.0 (1678) No or too long answer from Serial Device after last request.
    Thomas BraunT
    Thomas BraunT
    Most Active Developer
    #2407
    @andiekiste
    Kannst du das auf /dev/serial/by-id umstellen?
    Zeig mal:
    ls -la /der/serial/by-id
    sudo -u iobroker groups
    groups
    • HomoranH
      #2408
      @andiekiste sagte in Adapter "smartmeter":
      ISKRA MT681
      in der Zwischenzeit habe ich für dich die Suche gequält und den folgenden Beitrag gefunden:
      https://forum.iobroker.net/topic/14292/hilfe-smartmeter-adapter/20?_=1641659814990
      mit diesen Einstellungen:
      https://forum.iobroker.net/assets/uploads/files/1604917824845-iobroker_zähler.png
      Dort ist der Lesekopf über USB erkannt worden.
      Das vermisse ich bei dir
      • loboL lobo
        Ich hab einen Wärmemengenzähler Siemens Uh 50 bzw. baugleich mit Landis+Gyr ULTRAHEAT T550 und bekomme ihn einfach nicht ausgelesen. Kann mir jemand helfen?
        Ich kenne zum Thema diese beiden Infoquellen.
        http://www.sedelmaier.at/node/112
        http://www.sedelmaier.at/content/siemens-uh50-landisgyr-ultraheat-t550-mit-openhab
        https://gathering-tweakers-net.translate.goog/forum/list_messages/1535019?_x_tr_sl=nl&_x_tr_tl=de&_x_tr_hl=de
        Anscheinend muss man den Zähler mit 40 NUL erst aufwecken. Aber meine x hundert unterschiedlichen Versuche blieben bisher erfolglos. Ich bekomme einfach keine Antwort.
        smartmeter.1	2021-12-26 21:35:09.786	debug	SCHEDULE NEXT RUN IN 60000s
        smartmeter.1	2021-12-26 21:35:09.786	debug	DELETE rest of data (0) because new Message start with a new Request Message
        smartmeter.1	2021-12-26 21:35:09.786	debug	CURRENT SIGNON MESSAGE COUNTER 1 OF 1
        smartmeter.1	2021-12-26 21:35:09.785	debug	SERIALPORT REMOVE LISTENERS
        smartmeter.1	2021-12-26 21:35:09.785	debug	SERIALPORT CLOSE
        smartmeter.1	2021-12-26 21:35:09.782	debug	CLEAR MESSAGE TIMEOUT TIMER
        smartmeter.1	2021-12-26 21:35:09.781	debug	STOP
        smartmeter.1	2021-12-26 21:35:09.781	debug	Transport Reset!! Restart = true
        smartmeter.1	2021-12-26 21:35:09.781	debug	Error: No or too long answer from Serial Device after last request.
        smartmeter.1	2021-12-26 21:35:09.781	warn	No or too long answer from Serial Device after last request.
        smartmeter.1	2021-12-26 21:35:09.780	debug	MESSAGE TIMEOUT TRIGGERED
        smartmeter.1	2021-12-26 21:34:54.780	debug	SET MESSAGE TIMEOUT TIMER2: 15000
        smartmeter.1	2021-12-26 21:34:54.780	debug	DONE SEND 0
        smartmeter.1	2021-12-26 21:34:54.529	debug	DONE SEND 1
        smartmeter.1	2021-12-26 21:34:54.050	debug	TO SEND 1: /?!\x0D\x0A!
        smartmeter.1	2021-12-26 21:34:54.050	debug	CURRENT PROCESS STEP 1 IN GETNEXTMESSAGE
        smartmeter.1	2021-12-26 21:34:53.798	debug	DONE SEND 2
        smartmeter.1	2021-12-26 21:34:52.368	debug	TO SEND 2:
        smartmeter.1	2021-12-26 21:34:52.368	debug	CURRENT PROCESS STEP 0 IN GETNEXTMESSAGE
        smartmeter.1	2021-12-26 21:34:52.368	debug	INITIAL MESSAGES TO SEND: 2
        smartmeter.1	2021-12-26 21:34:52.368	debug	SERIALPORT RESET BAUDRATE TO 300
        smartmeter.1	2021-12-26 21:34:52.367	debug	SERIALPORT OPEN
        smartmeter.1	2021-12-26 21:34:52.365	debug	CREATE SERIALPORT: 300 7 2 even
        smartmeter.1	2021-12-26 21:33:52.364	debug	SCHEDULE NEXT RUN IN 60000s
        smartmeter.1	2021-12-26 21:33:52.364	debug	DELETE rest of data (0) because new Message start with a new Request Message
        smartmeter.1	2021-12-26 21:33:52.364	debug	CURRENT SIGNON MESSAGE COUNTER 1 OF 1
        smartmeter.1	2021-12-26 21:33:52.363	debug	SERIALPORT REMOVE LISTENERS
        smartmeter.1	2021-12-26 21:33:52.363	debug	SERIALPORT CLOSE
        smartmeter.1	2021-12-26 21:33:52.359	debug	CLEAR MESSAGE TIMEOUT TIMER
        smartmeter.1	2021-12-26 21:33:52.358	debug	STOP
        smartmeter.1	2021-12-26 21:33:52.358	debug	Transport Reset!! Restart = true
        smartmeter.1	2021-12-26 21:33:52.358	debug	Error: No or too long answer from Serial Device after last request.
        smartmeter.1	2021-12-26 21:33:52.358	warn	No or too long answer from Serial Device after last request.
        smartmeter.1	2021-12-26 21:33:52.357	debug	Error: No or too long answer from Serial Device after last request.
        smartmeter.1	2021-12-26 21:33:52.357	debug	MESSAGE TIMEOUT TRIGGERED
        smartmeter.1	2021-12-26 21:33:37.356	debug	SET MESSAGE TIMEOUT TIMER2: 15000
        smartmeter.1	2021-12-26 21:33:37.355	debug	DONE SEND 0
        smartmeter.1	2021-12-26 21:33:37.105	debug	DONE SEND 1
        smartmeter.1	2021-12-26 21:33:36.628	debug	TO SEND 1: /?!\x0D\x0A!
        smartmeter.1	2021-12-26 21:33:36.628	debug	CURRENT PROCESS STEP 1 IN GETNEXTMESSAGE
        smartmeter.1	2021-12-26 21:33:36.377	debug	DONE SEND 2
        smartmeter.1	2021-12-26 21:33:34.945	debug	TO SEND 2:
        smartmeter.1	2021-12-26 21:33:34.945	debug	CURRENT PROCESS STEP 0 IN GETNEXTMESSAGE
        smartmeter.1	2021-12-26 21:33:34.945	debug	INITIAL MESSAGES TO SEND: 2
        smartmeter.1	2021-12-26 21:33:34.945	debug	SERIALPORT RESET BAUDRATE TO 300
        smartmeter.1	2021-12-26 21:33:34.944	debug	SERIALPORT OPEN
        smartmeter.1	2021-12-26 21:33:34.941	debug	CREATE SERIALPORT: 300 7 2 even
        Meine zuletzt versuchten Einstellungen:
        @apollon77 @rossi73 Ich glaube ihr habt beide ähliche Zähler, aber nie eure Konfig hier gepostet?!
        R
        R
        rossi73
        #2409
        @lobo
        Hallo, auf die Seiten von sedelmaier.at bin ich auch gestoßen. Hat mir aber auch nichts gebracht. Ich konnte meinen Landis+Gyr T330 Ultraheat leider nicht zum kommunizieren überreden. Wobei ich nicht mal weiß ob die optische Schnittstelle bei meinem aktiviert ist...
        M T 2 Antworten Letzte Antwort
        • R rossi73
          @lobo
          M
          M
          martinschm
          #2410
          mal ausnahmsweise keine Problem. Heute kam mein zweiter IR Lesekopf an, diesmal einer von Hichi. Ich runter zu meinem SlavePi, den Lesekopf per USB verbunden und auf den Stromzähler gesetzt.
          Hoch an den Rechner, eine zweite Instanz des Adapters hinzugefügt, Lesekopf ausgewählt und Baudrate hinterlegt und schon waren die Daten da. In weniger als 10 min war alles erledigt.
          So macht Smart Home richtig Spaß. Danke @apollon77 für den coolen Adapter.
          apollon77A T 2 Antworten Letzte Antwort
          • M martinschm
            apollon77A
            apollon77A
            #2411
            @martinschm gern doch ;-))
            • M martinschm
              T
              T
              Tomte
              #2412
              @martinschm
              Ist toll dass es so gut klappt. Aber für 2 serielle Schnittstellen einen Raspi mit OS und Slave ioBroker ist für mich etwas "Overengineering". Das kann auch ein ESP8266 mit 70mA für ein paar Euro - ohne Wartung/Updates usw.
              Natürlich kann es jeder machen wie er will, versteht mich nicht falsch.
              bahnuhrB K M 3 Antworten Letzte Antwort
              • R rossi73
                @lobo
                T
                T
                Tomte
                #2413
                @rossi73 said in Adapter "smartmeter":
                Landis+Gyr T330
                Ich habe mir mal die Doku angeschaut. Der optische Ausgang scheint ein Impulsausgang zu sein. Keine Datenschnittstelle. Ist denn mit einem Handy/Digicam ein blinken zu sehen?
                • T Tomte
                  @martinschm
                  bahnuhrB
                  bahnuhrB
                  bahnuhr
                  #2414
                  @tomte sagte in Adapter "smartmeter":
                  Bitte mal schreiben wie du dies realisiert hast.
                  Danke.
                  • T Tomte
                    @martinschm
                    K
                    K
                    klassisch
                    #2415
                    @tomte Ich nutze einen halben USR-TCP232 E2 und habe eine kabelgebundene Lösung mit diesem Adapter. Stromsparend, bequem und rocksolid
                    • K klassisch
                      bahnuhrB
                      bahnuhrB
                      bahnuhr
                      #2416
                      @klassisch sagte in Adapter "smartmeter":
                      auch dies würde mich interessieren.
                      Danke.
                      • T Tomte
                        @martinschm
                        M
                        M
                        martinschm
                        #2417
                        @tomte said in Adapter "smartmeter":
                        @martinschm
                        Hi, du hast vermutlich Recht. Damals war es aber für mich einfacher mal eben iobroker auf den Raspi zu spielen und die Adapter zu installieren. Hab jetzt halt auch zwei Leseköpfe mit USB.
                        Wenn man sich besser und tiefer auskennt geht es meistens einfacher. Die, die sich nicht auskennen nehmen verfügbare Möglichkeiten und zahlen oft ein wenig mehr. Komme oft erst spät abends zu meinen Smart Home Sachen, da bin ich dann oft zu müde um mich tief in mir fremde Materie einzuarbeiten. Da bleibe ich dann bei den Dingen die ich kenn und kann. Hauptsache der Strom wird ausgelesen und der Spaßfaktor stimmt.
                        • bahnuhrB bahnuhr
                          K
                          K
                          klassisch
                          #2418
                          @bahnuhr sagte in Adapter "smartmeter":
                          Eine der vielen Möglichkeiten, die ich im Guide für die Moderne Meßeinrichtung beschrieben habe.
                          Mittlerweile scheint man ähnliche Module (transparente TCP Server) auch in D von Fa. Waveshare bei Welectron. zu bekommen. Wobei ich die noch nicht getestet habe.
                          • bahnuhrB bahnuhr
                            T
                            T
                            Tomte
                            #2419
                            @bahnuhr
                            Ich habe das hier schon mal im Thead erwähnt.
                            Für D0 und SML Reader geht das ganz gut mit ESP-Link oder Tasmota.
                            Für SML Push Zähler geht das super mit SMLReader über MQTT, super mit ioBroker.
                            Habe ich schon im Einsatz mit folgenden Zählern:
                            EMH (ED300L, EHZ-K, EHZ-P, EHZ-I, mMe4.0, eBZ DD3 (Typ SM),  ISKRA (MT681, MT175, MT631),  Hager (EHZ 162, 163, 361, 362, 363),   EFR SGM-C4, Easymeter Q3A, Itron Openway 3.HZ, Landis & Gyr E220, DZG DxS74 (z.B. DVS7412.1,  DWS7412.2.G2), Apator Norax 3D, KAIFA MB310H4BDE,
                            Das geht auch mit mehreren Köpfen an einem ESP. 3 Habe ich schon getestet.
                            Alle diese Programm gibt es auf Github. Bei SMLReader wird auch der Hardwareaufbau (eigentlich Standard) beschrieben.
                            Nur so als Anregung. Man gibt seine Wlan-Daten und MQTT-Serveradresse ein und rennt.
                            Viele Grüße, Tomte
                            R 1 Antwort Letzte Antwort
                            • T Tomte
                              @bahnuhr
                              Viele Grüße, Tomte
                              R
                              R
                              reptilezz
                              #2420
                              @tomte
                              Die Lösung mit Tasmota habe ich auch gewählt.
                              Habe hier allerdings einen Zweirichtungszähler vom EMH und zwar den
                              eHZ-PW...
                              Leider fehlt mir das erforderliche SML Script für Tasmota.
                              Hast du das und wenn ja, könntest du es mir zur Verfügung stellen?
                              • R reptilezz
                                @tomte
                                eHZ-PW...
                                T
                                T
                                Tomte
                                #2421
                                @reptilezz
                                Das ist gleich der Hauptnachteil von Tasmota bei SML und der Vorteil von SMLReader: Die Konfiguration der Datensätze.
                                SMLReader überträgt einfach alles, was er bekommt. Bei Tasmota muss ich in der Doku erstmal prüfen was kommt.
                                (Bei esp-link übernimmt das der Smart Meter Adapter von ioBroker, das ist sozusagen der kabellose USR-TCP232 E2)
                                Welche Datensätze möchtest Du denn lesen? Eine Doku von EHZ-P habe ich spontan gefunden.
                                Ein schönes Beispiel zur Konfiguration findest Du https://ottelo.jimdofree.com/iskra-stromz%C3%A4hler-und-ha/ (nicht von mir).
                                Wenn Du mir sagst, an welchem Pin dein Kopf sitzt (ich hoffe mal er geht, schon geprüft mit Gesamtverbrauch?), dann kann ich Dir auch ein passendes Binary von SMLReader anbieten. (ohne Backdoor, versprochen)
                                Viele Grüße, Tomte
                                K R 2 Antworten Letzte Antwort
                                • T Tomte
                                  @reptilezz
                                  Viele Grüße, Tomte
                                  K
                                  K
                                  klassisch
                                  #2422
                                  Das wäre eigentlich der USR-WIFI232-A2. Unwesentlich teurer als ein ESP - aber normalerweise halt nicht in der Schublade vorrätig.
                                  Hatte ich auch testweise in Betrieb. Lief auch, aber ich wollte eine solide Kabelanbindung und mein Zählerkasten ist aus Stahl.
                                  • K klassisch
                                    T
                                    T
                                    Tomte
                                    #2423
                                    @klassisch
                                    Die meisten Zählerkasten sind aus Stahl.
                                    Daher führe ich den esp mit einem Klingeldraht raus (Türe läßt sich schließen) und befestige ihn mit einem Magneten am Schrank.
                                    Ein Lesekopf mit aufgesetztem Wlan Modul macht bei einem Stahlschrank imho wenig Sinn.
                                    (Wird aber verkauft)
                                    Mit dem Netzwerk-Teil kenne ich mich nicht aus. Danke für den Hinweis
                                    • T Tomte
                                      @reptilezz
                                      Viele Grüße, Tomte
                                      R
                                      R
                                      reptilezz
                                      schrieb am zuletzt editiert von reptilezz
                                      #2424
                                      @tomte
                                      Sehe jetzt endlich Gesamtverbrauchsdaten mit folgenden Script
                                      D
                                      B
                                      ->sensor53 r
                                      M 1
                                      +1,3,s,0,9600,Strom
                                      1,77070100100700FF@1,Leistung,W,Power_curr,0
                                      1,77070100010800FF@1000,Verbrauch,kWh,Tariflos,2
                                      Jetzt muss ich auf meinen Pin warten...
                                      Datensätze würde ich gerne HT und NT lesen wollen
                                      Ein schönes Beispiel zur Konfiguration findest Du https://ottelo.jimdofree.com/iskra-stromzähler-und-ha/ (nicht von mir).
                                      Das passte leider nicht zu meinem Zähler.
                                      Bin aber hier fündig geworden
                                      https://www.photovoltaikforum.com/thread/163927-emh-mme-40-auslesen-startschwierigkeiten/
                                      • T Tomte
                                        @klassisch
                                        K
                                        K
                                        klassisch
                                        #2425
                                        Habe zwar billigste Leseköpfe aus "IR Flame detector" prototypisch gebaut und getestst. Aber ich wollte kein Gebastel im Zählerschrank und habe deshalb einen industriellen EHZ-Kopf verwendet, der damals rel. günstig war. Der hat einen 6-Pin Western Stecker. Den stecke ich in so einen Eth-Flachleiter zur Fensterdurchführung und gehe damit durch den Türspalt des Zählerkastens.
                                        • K klassisch
                                          T
                                          T
                                          Tomte
                                          #2426
                                          @klassisch
                                          Verstehe ich. Mit diesem Aufbau hat man letztendlich jedoch nur ein Bauteil, 3,3v und max. 10mA im Schrank. Weniger Risiko geht kaum.
                                          M K 2 Antworten Letzte Antwort
                                          84.0k
