  4. Test Adapter Plex v0.8.x
plex
312 Beiträge 14 Kommentatoren 66.4k Aufrufe 13 Beobachtet
  • sigi234S sigi234
    @Zefau
    Hallo, seit einen Update auf Admin 4.0.5, Web 3.0.1 und socketio 3.0.1 geht der Adapter nicht mehr:
    plex.0	2020-02-24 15:14:34.546	info	(14916) Terminated (NO_ERROR): Without reason
    plex.0	2020-02-24 15:14:34.545	info	(14916) terminating
    plex.0	2020-02-24 15:14:34.544	info	(14916) Adapter stopped und unloaded.
    plex.0	2020-02-24 15:14:34.543	error	(14916) TypeError: Cannot read property 'val' of null at adapter.getStates (C:\Program Files\iobroker\Test\node_modules\iobroker.plex\plex.js:166:41) at states.getStates (C:\Program Files\iobr
    plex.0	2020-02-24 15:14:34.543	error	(14916) uncaught exception: Cannot read property 'val' of null
    plex.0	2020-02-24 15:14:34.501	info	(14916) Establishing insecure connection to Plex Media Server...
    plex.0	2020-02-24 15:14:34.490	info	(14916) starting. Version 0.8.10 in C:/Program Files/iobroker/Test/node_modules/iobroker.plex, node: v10.16.3
    plex.0	2020-02-24 15:14:02.715	info	(15232) Terminated (NO_ERROR): Without reason
    plex.0	2020-02-24 15:14:02.715	info	(15232) terminating
    plex.0	2020-02-24 15:14:02.713	info	(15232) Adapter stopped und unloaded.
    plex.0	2020-02-24 15:14:02.712	error	at process._tickCallback (internal/process/next_tick.js:68:7)
    plex.0	2020-02-24 15:14:02.712	error	at promise.then (C:\Program Files\iobroker\Test\node_modules\standard-as-callback\built\index.js:19:49)
    plex.0	2020-02-24 15:14:02.712	error	at tryCatcher (C:\Program Files\iobroker\Test\node_modules\standard-as-callback\built\utils.js:11:23)
    plex.0	2020-02-24 15:14:02.712	error	at client.mget (C:\Program Files\iobroker\Test\node_modules\iobroker.js-controller\lib\states\statesInRedis.js:619:13)
    plex.0	2020-02-24 15:14:02.712	error	at states.getStates (C:\Program Files\iobroker\Test\node_modules\iobroker.js-controller\lib\adapter.js:5922:17)
    plex.0	2020-02-24 15:14:02.712	error	at adapter.getStates (C:\Program Files\iobroker\Test\node_modules\iobroker.plex\plex.js:166:41)
    plex.0	2020-02-24 15:14:02.712	error	(15232) TypeError: Cannot read property 'val' of null
    plex.0	2020-02-24 15:14:02.712	error	(15232) uncaught exception: Cannot read property 'val' of null
    plex.0	2020-02-24 15:14:02.610	info	(15232) Establishing insecure connection to Plex Media Server...
    ZefauZ Offline
    ZefauZ Offline
    Zefau
    #148
    @sigi234 sagte in Test Adapter Plex v0.8.x:
    Probier mal bitte v0.8.11 von Github.
    • ZefauZ Zefau
      sigi234S Online
      sigi234S Online
      #149
      @Zefau sagte in Test Adapter Plex v0.8.x:
      Jupp geht, teste weiter. 👍
        Megabeit
        #150
        Hi, ich habe eher ein kleines Problem.
        Habe den Plex Adapter (Version 0.9.0) bei mir installiert. Adapter ist auch grün und liefert zuverlässig Werte vom richtigen Plexserver. Es ist jedoch die falsche IP Adresse des Plexserver im ioBroker hinterlegt, also sowohl in der Übersicht als auch in der Adapterliste, wo man per Button direkt auf den Plexserver springen kann. Genau genommen wird in der Übersicht die gleiche IP-Adresse/Port angezeigt, wie bei der VIS !?!?
        In der Konfig des Adapters ist die korrekte IP hinterlegt. Irgendeine Idee, wie/wo ich das korrigieren kann?
        • M Megabeit
          ZefauZ Offline
          ZefauZ Offline
          Zefau
          #151
          @Megabeit Wo genau in ioBroker steht die falsche IP? In der Übersicht mit den Kacheln ist ein Interface verlinkt, welches die letzten Aktivitäten zeigt. Das Interface läuft auf ioBroker, daher ist dort auch die ioBroker IP zu sehen. Der Link soll nicht zum Plex Server führen, sondern zu folgendem Interface:
          • ZefauZ Zefau
            Megabeit
            #152
            @Zefau
            Ja, genau. Ich meinte die Kachel in der Übersicht. Okay, das war mir nicht klar.
            Bei mir zeigt das Interface aber keine Daten an. Muss ich da in Plex oder Tautulli noch was aktivieren?
            • M Megabeit
              @Zefau
              ZefauZ Offline
              ZefauZ Offline
              Zefau
              #153
              @Megabeit entweder Plex Pass den Webhook konfigurieren oder in Tautulli den Webhook konfigurieren. Steht alles auf Github: https://github.com/Zefau/ioBroker.plex#22-advanced-setup-plex-pass-or-tautulli
              WinniW 1 Antwort Letzte Antwort
              • ZefauZ Zefau
                WinniW Offline
                WinniW Offline
                Winni
                schrieb am zuletzt editiert von Winni
                #154
                Hallo, ich versuche den Adapter bei mir zum laufen zu bringen. Ich scheitere aber bei der Übernahme des Authentifizierungs-Token. Ich gebe auf der Seite http://www.plex.tv/pin den Pin ein und bekomme die Meldung "Account Linked Your account has been successfully linked, please revisit your app to continue" Aber das war es dann auch, ich kann nirgends einen Authentifizierungs-Token entdecken und der Adapter bleibt gelb. Wo ist mein Fehler 😖
                Nach mehreren Versuchen hats doch funktioniert..
                • ZefauZ Zefau
                  Aktuelle Test Version 0.8.x
                  Veröffentlichungsdatum v0.8.0 29.10.2019
                  Veröffentlichungsdatum v0.8.1 02.11.2019
                  Github Link https://github.com/Zefau/ioBroker.plex
                  Roadmap https://github.com/Zefau/ioBroker.plex/projects/1
                  Über Tester der aktuellen Version würde ich mich sehr freuen.
                  Plex Notifications
                  Die v0.8.x unterstützt nun zuverlässig Plex Notifications (siehe offizielle Ankündigung https://www.plex.tv/blog/plex-knows-notifications/). Das Feature muss im Plex Media Server aktiviert werden (siehe https://support.plex.tv/articles/push-notifications/).
                  Die Events werden in den Objekten unter events gespeichert. Das Adapter Web-Interface zeigt diese dann an:
                  Bild Text
                  Die Texte für die Benachrichtigungen können in den Adapter-Einstellungen customized werden:
                  Garbage Collector
                  Alte States werden nun zuverlässig bereinigt, wenn beispielsweise nach einem Film eine Serie abgespielt wird. Die States unter _playing werden entsprechend bereinigt.
                  Du-BassD Offline
                  Du-BassD Offline
                  Du-Bass
                  #155
                  @Zefau
                  Good day!
                  I installed this adapter. Filled in ip and tried to get PIN, but couldn't get it... What did i do wrong?
                  Du-BassD 1 Antwort Letzte Antwort
                  • Du-BassD Du-Bass
                    @Zefau
                    Good day!
                    Du-BassD Offline
                    Du-BassD Offline
                    Du-Bass
                    #156
                    @Du-Bass said in Test Adapter Plex v0.8.x:
                    @Zefau
                    Good day!
                    Solved this question.
                    I have to change instance to debug, and at log check th PIN. I think it will great to add to readme for this adapter
                    • NegaleinN Offline
                      NegaleinN Offline
                      Negalein
                      #157
                      @Zefau
                      hab heute deinen Adapter installiert.
                      Mir füllt es das Log extrem an.
                      Hab den Adapter schon auf warn gestellt. Wird aber nicht unterdrückt.
                      plex.0 2022-01-05 23:15:03.914	warn	Object of state "plex.0.libraries.4-horror" is missing the required property "common.type"
                      plex.0 2022-01-05 23:15:03.914	warn	Object of state "plex.0.libraries.10-filme" is missing the required property "common.type"
                      plex.0 2022-01-05 23:15:03.914	warn	Object of state "plex.0.libraries" is missing the required property "common.type"
                      plex.0 2022-01-05 23:15:03.913	warn	Object of state "plex.0.settings.other" is missing the required property "common.type"
                      ° Fixer ---> iob fix
                      • sigi234S sigi234
                        @el_malto sagte in Test Adapter Plex v0.8.x:
                        @sigi234
                        Du kannst doch /?X-Plex-Token=xxxxxxxxxxx hinter deinen %Metadata.thumb% Platzhalter schreiben.
                        %Metadata.thumb%/?X-Plex-Token=xxxxxxxxxxx Dann müsste das doch unter den Datenpunkt "thumb" generiert werden.
                        Um das ohne Plex Token zu machen, musst du glaube ich in den Plex Server Einstellungen unter Netzwerk die IPs von deinen Geräten rein schreiben.
                        SUPER!
                        Arbeite schon an einer Vis:
                        NegaleinN Offline
                        NegaleinN Offline
                        Negalein
                        #158
                        Servus Sigi!
                        Verwendest du noch Plex und gibt es deinen View noch?
                        • T Nicht stören
                          T Nicht stören
                          ticaki
                          #159
                          wow ist das Problem schon alt.
                          ich hab die common.type Warnung gefixt bitte testen
                          https://github.com/ticaki/ioBroker.plex
                          Dann mache ich eine PR draus.
                          Spenden
                          • T ticaki
                            liv-in-skyL Offline
                            liv-in-skyL Offline
                            #160
                            @ticaki
                            die common.type sind nicht gekommen - aber evtl möchtest du das noch ansehen - beim starten eines videos
                            plex.0
                            2023-08-12 15:24:50.482	info	State value to set for "plex.0._playing._recent-player.playing" has to be type "string" but received type "boolean"
                            plex.0
                            2023-08-12 15:24:50.479	info	State value to set for "plex.0._playing._recent-player.Metadata.parentRatingKey" has to be type "number" but received type "string"
                            plex.0
                            2023-08-12 15:24:50.479	info	State value to set for "plex.0._playing._recent-player.Metadata.grandparentRatingKey" has to be type "number" but received type "string"
                            • T ticaki
                              liv-in-skyL Offline
                              liv-in-skyL Offline
                              #161
                              @ticaki und nochmals danke - wäre schade um den adapter
                              • liv-in-skyL liv-in-sky
                                @ticaki
                                plex.0
                                plex.0
                                plex.0
                                T Nicht stören
                                T Nicht stören
                                ticaki
                                #162
                                @liv-in-sky
                                kannst du dieses Addon(Tautulli) testen? Das ist seit 2021 archiviert und ich wollte sowas altes nicht installieren. Oder gibts da was gepflegtes für?
                                Ich gucke auch mal nach diesen typen
                                Spenden
                                • T ticaki
                                  @liv-in-sky
                                  liv-in-skyL Offline
                                  liv-in-skyL Offline
                                  #163
                                  @ticaki sagte in Test Adapter Plex v0.8.x:
                                  habe ich angesehen (tautulli) - es wurde sofort das laufende video übertragen und in tautulli sichtbar - hat mir erstmal gereicht - brauchst du ws besonderes
                                    T Nicht stören
                                    T Nicht stören
                                    ticaki
                                    #164
                                    @liv-in-sky
                                    Nein danke, muß nur den Code besser verstehen. Also ist das Tautulli noch ok? Kann ich das ohne furcht installieren? 😂
                                    Spenden
                                    • T ticaki
                                      @liv-in-sky
                                      liv-in-skyL Offline
                                      liv-in-skyL Offline
                                      #165
                                      @ticaki bei mir läuft es noch - habe aber nicht die neuste plex version - hatte mal ein problem , das ich meine mediathek daten nicht mehr über die apps aktualisieren konnte - daher blieb ich bei der älteren version
                                      1.25.3.5409
                                        1.25.3.5409
                                        T Nicht stören
                                        T Nicht stören
                                        ticaki
                                        #166
                                        @liv-in-sky
                                        Ich kann alles überall aktualisieren das nur nebenher:
                                        https://github.com/ticaki/ioBroker.plex/tree/testing
                                        das wirft bei mir keine Warnungen oder unnötigen Infos mehr raus. Da haben in der alten Version über 10 Datenpunkte gefehlt und 2 scheinen sich geändert zu haben.
                                        Den plex.0 Objektdatenbaum zu löschen scheint auch kein Problem zu sein, der wird bei jedem Start neu erstellt nur unter _playing werden die Geräte erst bei Benutzung eingetragen.
                                        Wegen der geänderten Datenpunkte ist entweder löschen oder per Hand ändern angeraten :)
                                        "playing.metadata.ratingkey": {"description": "The unique identifier for the movie, episode, or track.", "role": "value", "type": "string"},
                                        "playing.metadata.year": {"description": "The release year for the item", "role": "text", "type": "number"},
                                        ach und wenn no clue irgendwo steht bedeutet das genau das - bin für erleuchtung dankbar :)
                                        Spenden
                                        • T ticaki
                                          @liv-in-sky
                                          liv-in-skyL Offline
                                          liv-in-skyL Offline
                                          #167
                                          habe das jetzt installiert - dann:
