  4. [gelöst] - VIS Intance Id - automatisiert ermitteln
126 Beiträge 13 Kommentatoren 28.0k Aufrufe 12 Beobachtet
  • bahnuhrB bahnuhr
    @bananajoe
    natürlich das Script von @Jey-Cee
    und weitere aus dem Netz:
        window.RTCPeerConnection = window.RTCPeerConnection || window.mozRTCPeerConnection || window.webkitRTCPeerConnection;   //compatibility for firefox and chrome
        var pc = new RTCPeerConnection({iceServers:[]}), noop = function(){};
        pc.createDataChannel("");    //create a bogus data channel
        pc.createOffer(pc.setLocalDescription.bind(pc), noop);    // create offer and set local description
        pc.onicecandidate = function(ice){  //listen for candidate events
            if(!ice || !ice.candidate || !ice.candidate.candidate)  return;
            var myIP = /([0-9]{1,3}(\.[0-9]{1,3}){3}|[a-f0-9]{1,4}(:[a-f0-9]{1,4}){7})/.exec(ice.candidate.candidate)[1];
            console.log('my IP: ', myIP);
            pc.onicecandidate = noop;
    // cleaned, 363b
    const ip = await new Promise((resolve, reject) => {
      const conn = new RTCPeerConnection()
      conn.createDataChannel('')
      conn.createOffer(offer => conn.setLocalDescription(offer), reject)
      conn.onicecandidate = ice => {
        if (ice && ice.candidate && ice.candidate.candidate) {
          resolve(i.candidate.candidate.split(' ')[4])
          conn.close()
     * Get the user IP throught the webkitRTCPeerConnection
     * @param onNewIP {Function} listener function to expose the IP locally
     * @return undefined
    function getUserIP(onNewIP) { //  onNewIp - your listener function for new IPs
        var myPeerConnection = window.RTCPeerConnection || window.mozRTCPeerConnection || window.webkitRTCPeerConnection;
        var pc = new myPeerConnection({
            iceServers: []
        noop = function() {},
        localIPs = {},
        ipRegex = /([0-9]{1,3}(\.[0-9]{1,3}){3}|[a-f0-9]{1,4}(:[a-f0-9]{1,4}){7})/g,
        key;
        function iterateIP(ip) {
            if (!localIPs[ip]) onNewIP(ip);
            localIPs[ip] = true;
        pc.createOffer().then(function(sdp) {
            sdp.sdp.split('\n').forEach(function(line) {
                if (line.indexOf('candidate') < 0) return;
                line.match(ipRegex).forEach(iterateIP);
            pc.setLocalDescription(sdp, noop, noop);
        }).catch(function(reason) {
            // An error occurred, so handle the failure to connect
        pc.onicecandidate = function(ice) {
            if (!ice || !ice.candidate || !ice.candidate.candidate || !ice.candidate.candidate.match(ipRegex)) return;
            ice.candidate.candidate.match(ipRegex).forEach(iterateIP);
    // Usage
    getUserIP(function(ip){
        alert("Got IP! :" + ip);
    Aber wie gesagt, ich glaube das übersteigt meine Kenntnisse.
    liv-in-skyL Offline
    liv-in-skyL Offline
    @bahnuhr
    zur not mach dir eine tabelle mit instance und ip`s dazu - dann kannst du je instance id auch die ip ausgeben
    muss halt gepflegt werden
    • liv-in-skyL liv-in-sky
      @bahnuhr
      bahnuhrB Online
      bahnuhrB Online
      bahnuhr
      @liv-in-sky sagte in VIS Intance Id - automatisiert ermitteln:
      @bahnuhr
      genau das geht eben nicht.
      Hintergrund:
      Ich wollte auf dem Tablet im Wohnzimmer (win10) edge im kiosk mode einrichten.
      Nur da wird die Instanz nur erzeugt wenn man klickt. Und diese ändert sich dann ständig.
      Die IP ist aber immer gleich.
      Ich müsste also wissen, welche IP die instanz sendet um dann zu beurteilen welcher PC / Laptop neu die VIS aufgebaut hat.
      Danke.
      • bahnuhrB bahnuhr
        @bahnuhr
        Hintergrund:
        liv-in-skyL Offline
        liv-in-skyL Offline
        @bahnuhr
        hast du mal den vis-editor im kioskmode mit dem pc aufgemacht - ich glaube, so bekommt man eine feste instance id - kann mich aber auch täuschen - da gab es doch Browser ID erzeugen als menu punkt im editor
          @bahnuhr
          BananaJoeB Offline
          BananaJoeB Offline
          BananaJoe
          #66
          @liv-in-sky Es geht halt darum zuverlässig zu erkennen welcher Client da kommt. Wenn ich auf meinen PC 3 verschiedene Browser nutze kommen da auch 3 verschiedene Instance ID.
          Beim Fully Kiosk muss man aufpassen wenn er den Cache löscht / was er löscht.
          Die Idee hier hinter ist ja das einfach ein paar Datenpunkte hat in denen man nachsehen kann welche ID das Tablet im Wohnzimmer gerade hat. Und das das Tablet die aktualisiert falls di sich ändert :-)
          • BananaJoeB BananaJoe
            liv-in-skyL Offline
            liv-in-skyL Offline
            #67
            @bananajoe
            das habe ich verstanden
            ein pc , zwei browser - einmal chrome, einmal edge und die id dazu
            hier ausgewählt
            sind auch nach neustart noch da
            • bahnuhrB bahnuhr
              @bananajoe
              // cleaned, 363b
                    conn.close()
               * @return undefined
                      iceServers: []
                  localIPs = {},
                  key;
              // Usage
              BananaJoeB Offline
              BananaJoeB Offline
              BananaJoe
              #68
              @bahnuhr ja, die Beispiele habe ich alle durch.
              Was ich zum funktionieren bekomme habe, ist z.B. per
              $.getJSON('http://internerserver/meineip.php', function(data) {
                          console.log(JSON.stringify(data, null, 2));
                          alert(data.ipAddress);
              Die Adresse zu bekommen. Der Webserver muss dafür als Text
              { "ipAddress":"192.168.1.99" }
              zurückgeben was mit einem .php Skript ginge:
              <?php
              echo '{ "ipAddress":"'.$_SERVER['REMOTE_ADDR'].'"}';
              Aber wie gesagt suche ich nach einer "ich hab nur den ioBroker Server und will nicht extra einen Webserver aufsetzen" Lösung
                @bananajoe
                hier ausgewählt
                BananaJoeB Offline
                BananaJoeB Offline
                BananaJoe
                #69
                @liv-in-sky jepp. Bis man den Cache löscht. Was Fully meine ich sogar default macht beim Neuladen
                  liv-in-skyL Offline
                  liv-in-skyL Offline
                  #70
                  @bananajoe
                  probiert doch das mal aus - evtl gibt das eine feste id pro gerät zurück -
                  import widget - im widget die widget id noch angleichen !
                  [{"tpl":"tplHtml","data":{"g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":true,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","refreshInterval":"0","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"html":"<script>\nuuid=function(){\nvar u = 'xxxxxxxx-xxxx-4xxx-yxxx-xxxxxxxxxxxx'.replace(/[xy]/g,\nfunction(c) {\nvar r = Math.random() * 16 | 0,\nv = c == 'x' ? r : (r & 0x3 | 0x8);\nreturn v.toString(16);\n});\nreturn u;\n}\n\n\ngetDeviceId = function(){\nvar current = window.localStorage.getItem(\"_DEVICEID_\")\nif (current) return current;\nvar id = uuid();\nwindow.localStorage.setItem(\"_DEVICEID_\",id);   \nreturn id;\n}\n\nconsole.log(getDeviceId())\n $( \"#w00006\" ).text( getDeviceId());\n\n\n</script>\n"},"style":{"left":"838px","top":"180px","color":"#f4e643","background-color":"#b7aeae"},"widgetSet":"basic"}]
                  • BananaJoeB Offline
                    BananaJoeB Offline
                    BananaJoe
                    #71
                    @liv-in-sky nope, pro Browser und inPrivate Sitzung eine eigene
                    JavaScript kann das nicht ... und das ist Absicht
                      liv-in-skyL Offline
                      liv-in-skyL Offline
                      #72
                      @bananajoe
                      also ich bekomme damit einen eindeutigen , nicht vom cache-löschbaren code zurück - getestet mit fully , chrome und edge
                      ich dachte, dass sucht ihr
                        liv-in-skyL Offline
                        liv-in-skyL Offline
                        #73
                        @bananajoe und wer macht die vis im private mode auf - oder warum sollte man das
                        bahnuhrB BananaJoeB 2 Antworten Letzte Antwort
                          bahnuhrB Online
                          bahnuhrB Online
                          bahnuhr
                          #74
                          private mode
                          Ich wollte im Wohnzimmer ein tablet das im Vollbild öffnet und dass man nicht so einfach mit esc oder f11 raus kommt.
                          Und das ging halt mit edge kiosk.
                          Danke.
                          BananaJoeB liv-in-skyL 2 Antworten Letzte Antwort
                            BananaJoeB Offline
                            BananaJoeB Offline
                            BananaJoe
                            #75
                            @liv-in-sky Ich, zum simulieren verschiedener Geräte :-)
                            Dein Skript erstellt eine zufällige ID und speichert diese, richtig? Also nichts anderes als die Instanz-ID und wird somit auch kein löschen der Caches überleben.
                            • bahnuhrB bahnuhr
                              private mode
                              BananaJoeB Offline
                              BananaJoeB Offline
                              BananaJoe
                              #76
                              @bahnuhr ich wäre ja schon am Ziel da ich pro Gerät eine eigene VIS habe. Aber ich suche noch.
                              • bahnuhrB bahnuhr
                                private mode
                                liv-in-skyL Offline
                                liv-in-skyL Offline
                                #77
                                @bahnuhr
                                ok - aber dann ist es trotzdem eine eindeutige nummer
                                  @bahnuhr
                                  bahnuhrB Online
                                  bahnuhrB Online
                                  bahnuhr
                                  #78
                                  @bahnuhr
                                  Nein, eben nicht.
                                  Weil edge die Nr. nicht speichert und jedes mal eine neue erzeugt (bzw. durch klick erzeugt werden muss)
                                  Danke.
                                    liv-in-skyL Offline
                                    liv-in-skyL Offline
                                    #79
                                    @bananajoe sagte in VIS Intance Id - automatisiert ermitteln:
                                    hast du es ausprobiert oder schätzt du nur
                                      liv-in-skyL Offline
                                      liv-in-skyL Offline
                                      #80
                                      @bananajoe
                                      @bahnuhr
                                      ok - ihr habt recht - es überlebt den cache nicht - hatte falsch gelöscht - nutze ein tool, was falsch eingestellt war
                                        @bahnuhr
                                        BananaJoeB Offline
                                        BananaJoeB Offline
                                        BananaJoe
                                        #81
                                        @liv-in-sky die hätte wir ja schon mit der Instanz ID. Gesucht wird ein Weg immer das gleiche Gerät eindeutig der Instanz-ID zu zuordnen. Die IP-Adresse wäre da einer. Oder der Gerätename. Das sind aber alles dinge an die man wohl aus Absicht nicht aus JavaScript heraus rankommt. Denn damit könnte man ja einen Benutzer eindeutig identifizieren.
                                        Und ausprobiert. 4 Browser = 4 verschiedene IDs, im InPrivate dann noch mal 4 verschiedene. und das ist ja auch ok, sonst hätte der InPrivate Modus ja gar keinen Sinn, geht ja darum das der Benutzer nicht eindeutig zu identifizieren ist oder man Informationen aus seinem Netzwerk auslesen kann
                                          @bananajoe
                                          @bahnuhr
                                          bahnuhrB Online
                                          bahnuhrB Online
                                          bahnuhr
                                          #82
                                          @liv-in-sky
                                          Warst aber ganz schön hartnäckig ;-)
                                          Danke.
