  • simatecS simatec
    @fortune95 Also ich habe deine Situation noch einmal mit convert und ohne Convert nachgestellt und kann keinen Fehler feststellen
    Rolladen fährt bei offenen Fenster runter:
    shuttercontrol.013905	2021-12-07 15:25:30.227	debug	shutterDownChildren #1 Test old height: 0% new height: 100%
    shuttercontrol.013905	2021-12-07 15:25:30.226	debug	last automatic Action for Test: Down_ChildrenTime
    shuttercontrol.013905	2021-12-07 15:25:30.142	info	Children down #26 Set ID: Test value: 100%
    Fenster wird geschlossen:
    shuttercontrol.013905	2021-12-07 15:26:05.031	debug	save back trigger action: down for device Test
    shuttercontrol.013905	2021-12-07 15:26:05.030	debug	#1 shutter trigger released Test already in place: 100%
    shuttercontrol.013905	2021-12-07 15:26:04.948	debug	Test - shutter trigger Change is:upDown
    shuttercontrol.013905	2021-12-07 15:26:04.947	debug	Test - shutter trigger Action is:down
    shuttercontrol.013905	2021-12-07 15:26:04.947	debug	Test - shutter trigger Height is:100
    shuttercontrol.013905	2021-12-07 15:26:04.946	debug	Test - shutter current Height is:100
    shuttercontrol.013905	2021-12-07 15:26:04.945	debug	Test - shutter current state.val is:100
    Hier noch die Config des Test-Rolllades:
            "enabled": true,
            "shutterName": "Test",
            "name": "javascript.0.Rolladen.Test.rollo.LEVEL",
            "triggerID": "javascript.0.Rolladen.Test.rollo.fensterkontakt",
            "typeUp": "children",
            "typeDown": "children",
            "type": "in- & outside temperature",
            "heightDownSun": "20",
            "direction": "290",
            "directionRange": "15",
            "tempInside": "23",
            "tempSensor": "javascript.0.Rolladen.Test.rollo.innentemp",
            "outsideTempSensor": "javascript.0.Rolladen.Test.rollo.aussentemp",
            "tempOutside": "23",
            "lightSensor": "javascript.0.Rolladen.Test.rollo.lichtsensor",
            "valueLight": "",
            "heightUp": "0",
            "heightDown": "100",
            "triggerState": "false",
            "triggerStateTilted": "none",
            "triggerDrive": "35",
            "triggerDriveTildet": "35",
            "triggerChange": "upDown",
            "elevation": "1.5",
            "autoDrive": "upDown",
            "hysteresisOutside": "5",
            "hysteresisInside": "10",
            "hysteresisLight": "",
            "currentAction": "up",
            "currentHeight": "0",
            "oldHeight": "0",
            "firstCompleteUp": "",
            "triggerHeight": "0",
            "LateDown": false,
            "inSummerNotDown": false,
            "KeepSunProtect": false,
            "triggerAction": "0",
            "driveAfterClose": false,
            "useXmasLevel": false,
            "XmasLevel": "",
            "betweenPosition": false,
            "betweenPositionLevel": "30",
            "trigDelyUp": "",
            "trigDelyDown": "",
            "sunProtectEndDely": "",
            "sunProtectEndtimerid": "",
            "enableAlarmWind1": false,
            "enableAlarmWind2": false,
            "enableAlarmRain": false,
            "enableAlarmFrost": false,
            "enableAlarmFire": false,
            "alarmTriggerAction": "",
            "alarmTriggerLevel": "",
            "lastAutoAction": ""
    Fortune95
    #4067
    @simatec sagte in Test Adapter shuttercontrol v1.4.x:
            "enabled": true,
            "direction": "290",
            "tempInside": "23",
            "valueLight": "",
            "heightUp": "0",
            "elevation": "1.5",
            "oldHeight": "0",
            "LateDown": false,
            "XmasLevel": "",
            "trigDelyUp": "",
            "trigDelyDown": "",
    Rollladen fährt Runter:
    2021-12-07 16:29:00.025 - info: shuttercontrol.0 (1090698) Sleep down #26 Set ID: Schlafzimmer Rechts value: 0%
    2021-12-07 16:29:00.036 - debug: shuttercontrol.0 (1090698) last automatic Action for Schlafzimmer Rechts: Down_SleepTime
    2021-12-07 16:29:00.036 - debug: shuttercontrol.0 (1090698) shutterDownSleep #1 Schlafzimmer Rechts old height: 100% new height: 0%
    2021-12-07 16:37:03.104 - debug: shuttercontrol.0 (1090698) TriggerID changed: alias.0.Schlafzimmer.Fensterkontakt_Schlafzimmer_rechts.ACTUAL Value: 0
    2021-12-07 16:37:03.106 - debug: shuttercontrol.0 (1090698) Schlafzimmer Rechts - shutter conversion is:false
    2021-12-07 16:37:03.112 - debug: shuttercontrol.0 (1090698) Schlafzimmer Rechts - shutter current Height is:0
    2021-12-07 16:37:03.112 - debug: shuttercontrol.0 (1090698) Schlafzimmer Rechts - shutter trigger Height is:100
    2021-12-07 16:37:03.112 - debug: shuttercontrol.0 (1090698) Schlafzimmer Rechts - shutter trigger Action is:up
    2021-12-07 16:37:03.113 - debug: shuttercontrol.0 (1090698) Schlafzimmer Rechts - shutter trigger Change is:upDown
    2021-12-07 16:37:03.116 - info: shuttercontrol.0 (1090698) Window is still closed -> drive to last height: Set ID: Schlafzimmer Rechts value: 100%
    Config des Rollladen:
            "enabled": true,
            "shutterName": "Schlafzimmer Rechts",
            "name": "alias.0.Schlafzimmer.Rolladen_Schlafzimmer_Rechts.SET",
            "triggerID": "alias.0.Schlafzimmer.Fensterkontakt_Schlafzimmer_rechts.ACTUAL",
            "typeUp": "sleep",
            "typeDown": "sleep",
            "type": "off",
            "heightDownSun": "30",
            "direction": "120",
            "directionRange": "50",
            "tempInside": "23",
            "tempSensor": "",
            "outsideTempSensor": "",
            "lightSensor": "",
            "valueLight": "15",
            "heightUp": "100",
            "heightDown": "0",
            "triggerState": "0",
            "triggerDrive": "30",
            "triggerDriveTildet": "30",
            "elevation": "8",
            "hysteresisInside": "5",
            "hysteresisLight": "5",
            "currentAction": "",
            "currentHeight": "",
            "oldHeight": "",
            "triggerHeight": "",
            "LateDown": false,
            "triggerAction": "",
            "XmasLevel": "0",
            "betweenPositionLevel": "50",
            "trigDelyUp": "",
            "trigDelyDown": "",
    • simatecS simatec
      @simatec Wie hast du 1.4.3 installiert? Über Github?
      Wenn du es über Github installiert hast, musst du noch einen Upload machen.
      Fortune95
      #4068
      Nein, ganz normal aktualisiert. :man-shrugging:
      • Jens16J Offline
        Jens16J Offline
        Jens16
        #4069
        besteht die Möglichkeit bei [Einstellungen Helligkeitssensor] auch wie bei zum Beispiel [Einstellungen für den Wohnbereich] frühste / späteste Zeit für das hoch und runderfahren ein zu stellen?
        mfg Jens
        simatecS SchmakusS 2 Antworten Letzte Antwort
        • simatecS simatec
          @nightfly1983 Zeige mal bitte die errors im Log ... Im Debug sieht man da nichts
          Nightfly1983N Offline
          Nightfly1983
          #4070
          @simatec Im Log bei Errors steht nix zu shuttercontrol
          • Jens16J Jens16
            mfg Jens
            simatecS Offline
            simatecS Offline
            simatec
            #4071
            @jens16 sagte in Test Adapter shuttercontrol v1.4.x:
            stellen
            Nein die Möglichkeit besteht nicht ... Hier wird komplett nach den Lux-Werten gefahren
            • Besuche meine Github Seite
            • HowTo Restore ioBroker
            • F Fortune95
              simatecS Offline
              simatecS Offline
              simatec
              #4072
              @fortune95 Denke ich hab den Fehler gefunden ... Im Schlafbereich wurde der Reset des Trigger noch nicht umgesetzt ... Hatte ich wohl vergessen.
              Kannst du bitte mal die DEV-Version über den Githublink installieren und testen?
              https://github.com/simatec/ioBroker.shuttercontrol/tarball/dev
              F 1 Antwort Letzte Antwort
              • Nightfly1983N Nightfly1983
                simatecS Offline
                simatecS Offline
                simatec
                #4073
                @nightfly1983 Trage mal bei der Höhe fürs kippen bitte Werte ein und teste nochmal
                Nightfly1983N 1 Antwort Letzte Antwort
                • simatecS simatec
                  @tom-haase Bitte teste mal die 1.4.3 ... dein Problem sollte gefixt sein.
                  Tom Haase
                  #4074
                  Leider keine Veränderung. Die Weihnachtseinstellung wird komplett ignoriert. Vielleicht finde ich am WE Zeit für Logs....
                  Nightfly1983N simatecS 2 Antworten Letzte Antwort
                  • simatecS simatec
                    Fortune95
                    #4075
                    👍 👍 👍 Super! :-) DANKE!!!
                    2021-12-07 17:49:36.946 - debug: shuttercontrol.0 (1107019) TriggerID changed: alias.0.Schlafzimmer.Fensterkontakt_Schlafzimmer_rechts.ACTUAL Value: 0
                    2021-12-07 17:49:36.954 - debug: shuttercontrol.0 (1107019) Schlafzimmer Rechts - shutter conversion is:false
                    2021-12-07 17:49:36.969 - debug: shuttercontrol.0 (1107019) Schlafzimmer Rechts - shutter current Height is:0
                    2021-12-07 17:49:36.970 - debug: shuttercontrol.0 (1107019) Schlafzimmer Rechts - shutter trigger Height is:0
                    2021-12-07 17:49:36.971 - debug: shuttercontrol.0 (1107019) Schlafzimmer Rechts - shutter trigger Action is:down
                    2021-12-07 17:49:36.972 - debug: shuttercontrol.0 (1107019) Schlafzimmer Rechts - shutter trigger Change is:upDown
                    2021-12-07 17:49:36.991 - debug: shuttercontrol.0 (1107019) #1 shutter trigger released Schlafzimmer Rechts already in place: 0%
                    2021-12-07 17:49:36.993 - debug: shuttercontrol.0 (1107019) save back trigger action: down for device Schlafzimmer Rechts
                    könnte man auch den eingestellten Wert bei geöffneten Fenster direkt anfahren?
                    • F Fortune95
                      simatecS Offline
                      simatecS Offline
                      simatec
                      #4076
                      @fortune95 Bein dafür kippt es die Option drive after close
                      • simatecS simatec
                        Fortune95
                        #4077
                        @simatec
                        Dann bleibt es aber bis zum schließen, komplett auf, oder?
                        Ich möchte es ja, wie in der "Nacht" beim öffnen auf Lüftungsstellung haben. Das war so mein Gedanke...🤔
                        • simatecS simatec
                          @funbug sagte in Test Adapter shuttercontrol v1.4.x:
                          (bestimmter Wert, nicht boolen)
                          das ist sicher mit shuttercontrol und 1-2 Skripten machbar.
                          Aber da benötige ich mehr Infos ... Was für Werte bekommst du genau, und was kannst du ansteuern?
                          Funbug
                          #4078
                          Hier mal ein Printscreen von allen Objekten, welches ein Gerät liefert.
                          Beim Objekt targetPostion trage ich den Wert ein, wohin das Fenster oder der Rollladen fahren soll.
                          CurrentPosition gibt dann die erreichte Position an. State geht während dem Fahren auf "Execution" sobald fertig auf "Done" und runState geht während dem Fahren auf "ExecutionActive" sobald fertig auf "ExecutionCompleted".
                          Möchte ich zum Beispiel ein Fenster öffnen, muss zuerst geprüft werden, dass der Rollladen aktuell nicht am fahren ist und dass die aktuelle Position "CurrentPosition" kleiner "40" ist.
                          Möchte ich hingegen mit dem Rollladen hoch oder runter fahren, so muss zuvor geprüft werden, dass dasjenige Fenster aktuell nicht fährt und die "CurrentPosition" kleiner "10" ist.
                          Schön währe, wenn die Bedingung nicht erfüllt ist, der Befehl dennoch ausgeführt wird, jedoch zuvor die Bedingung dafür erstellt wird.
                          Ich hab gelesen, dass der Adapter eine Fenster Position prüfen kann, den Befehl je nach Setting dann erst ausführt, wenn die Fenster Position dies zulässt.
                          • simatecS simatec
                            Hallo IoBroker Gemeinde,
                            da ich hier im Forum immer mal wieder gelesen habe, dass es Fragen nach einer Lösung für die automatische Rollladensteuerung gab, habe ich mich mal bei gemacht und einen Adapter dafür geschrieben.
                            An dieser Stelle ein riesengroßes Dankeschön an alle Dev's für die Unterstützung bei einigen Fragen dazu.
                            Aktuell befindet sich der Adapter in der latest Repro und kann ganz einfach über den Tab "Adapter" in eurem iobroker installiert werden.
                            Die aktuelle Dokumentation findet ihr unter folgenden Links:
                            Deutsche Beschreibung
                            English Description
                            Hier der Link zum Github-Projekt:
                            https://github.com/simatec/ioBroker.shuttercontrol.git
                            Shuttercontrol ist ein Adapter zur automatischen Steuerung von Rollläden und Markisen.
                            Changelog
                            2.0.0 (2025-03-23)
                            • (simatec) Dependencies updated
                            • (simatec) jsonTab added
                            Viel Spaß beim testen ...
                            2afs2 Offline
                            2afs2 Offline
                            2afs
                            #4079
                            Hallo @simatec ,
                            ich setzte derzeit die stable shuttercontrol v1.2.1 im IOBROKER ein.
                            Jetzt wo es schon recht Weihnachtlich wird habe ich die Weihnachtseinstellungen konfiguriert und bekomme die Positionsverstellung nicht hin.
                            Zu den definierten Zeiten wenn der Rollladen herunter bis zur Weihnachtseinstellung (50%) fahren soll bekommt ein 100% geöffneter Rolladen noch einmal den Befehl Position 100%. Er bewegt sich also nicht. Es ist nur zu sehen (letzte Änderung im VIS) das die Position 100% noch einmal gesetzt wurde.
                            Spätes Schliessen funktioniert dann wieder richtig und die Rollläden schliessen. Gibt es hierzu einen fix oder workaround?
                            Danke und Gruß
                            • da_WoodyD Online
                              da_WoodyD Online
                              #4080
                              @2afs ich denk mal das das in den latest gefixt ist. 1.4.3 ist die latest im moment. da hat sich seite deiner version verdammt viel getan.
                              mach einen npm install und dann mal schauen.
                              • T Tom Haase
                                Nightfly1983
                                #4081
                                @tom-haase Da schließe ich mich an, die Weihnachtsposition wurde angefahren, aber das später schließen hat leider nicht geklappt, alle Rollläden waren heute Morgen noch in der Weihnachtsstellung 😕
                                • simatecS simatec
                                  Nightfly1983
                                  #4082
                                  @simatec Probiere ich heute Nachmittag direkt, danke für den Hinweis. Aber bei Sensor für das Kippen trage ich weiterhin nicht vorhanden ein und bei der Höhe einfach das gleiche wie beim öffnen?!
                                    simatecS Offline
                                    simatecS Offline
                                    simatec
                                    #4083
                                    @nightfly1983
                                    Ja genau
                                    • T Tom Haase
                                      simatecS Offline
                                      simatecS Offline
                                      simatec
                                      #4084
                                      @tom-haase Ich habe das jetzt noch einmal getestet ... Bei mir fahren die Rollläden alle in die Weihnachtseinstellung.
                                      Zeige doch mal deinen Debuglog und die Config als json
                                      • BanditFGB Offline
                                        BanditFGB Offline
                                        BanditFG
                                        #4085
                                        @simatec
                                        hallo,
                                        ich habe gestern die v1.4.3 installiert, die Weihnachtsposition wurde richtig angefahren und auch beim später schliessen wurde die Frostschutzposition angefahren.. hab erstmal eins von 5 Fenstern getestet.. alle anderen Rollos funktionieren nochmal, 30min nach Sonnenuntergang sie die jetzt immer 3 sec Zeitversetz in die Frostschutzposition gefahren...
                                        Wenn das Versetzt fahren noch für die Rollos umgesetzt wird welche Später (22:00) runterfahren sollen, bin ich glücklich.
                                          simatecS Offline
                                          simatecS Offline
                                          simatec
                                          #4086
                                          @nightfly1983 Konnte ich nicht nachstellen ... Bei mir fahren alle Testrollläden
