Test Adapter bluelink - Hyundai (Bluelink) oder KIA (UVO)
@fichte_112 möglicherweise hab ich da was ungebaut. Bräuchte mal die debug Ausgabe
@newan said in Adapter Hyundai (Bluelink) oder KIA (UVO):
2021-10-14 07:52:35.281 - info: host.debian stopInstance system.adapter.bluelink.0 (force=false, process=true) 2021-10-14 07:52:35.298 - info: bluelink.0 (110216) Got terminate signal TERMINATE_YOURSELF 2021-10-14 07:52:35.299 - info: bluelink.0 (110216) Adapter bluelink cleaned up everything... 2021-10-14 07:52:35.300 - info: bluelink.0 (110216) terminating 2021-10-14 07:52:35.302 - info: bluelink.0 (110216) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason 2021-10-14 07:52:35.321 - info: host.debian stopInstance system.adapter.bluelink.0 send kill signal 2021-10-14 07:52:35.874 - info: host.debian instance system.adapter.bluelink.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION) 2021-10-14 07:52:38.431 - info: host.debian instance system.adapter.bluelink.0 started with pid 112864 2021-10-14 07:52:41.087 - info: bluelink.0 (112864) starting. Version 1.1.0 in /opt/iobroker/node_modules/iobroker.bluelink, node: v12.22.6, js-controller: 3.3.18 2021-10-14 07:52:41.210 - info: bluelink.0 (112864) Login to api 2021-10-14 07:52:46.311 - info: bluelink.0 (112864) Vehicles found 2021-10-14 07:52:46.386 - info: bluelink.0 (112864) Read new status from api 2021-10-14 07:53:03.714 - info: bluelink.0 (112864) Set new status 2021-10-14 07:53:03.781 - info: bluelink.0 (112864) State value to set for "bluelink.0.vehicleStatus.battery.plugin" has to be type "boolean" but received type "number" -
2021-10-14 07:52:35.281 - info: host.debian stopInstance system.adapter.bluelink.0 (force=false, process=true) 2021-10-14 07:52:35.298 - info: bluelink.0 (110216) Got terminate signal TERMINATE_YOURSELF 2021-10-14 07:52:35.299 - info: bluelink.0 (110216) Adapter bluelink cleaned up everything... 2021-10-14 07:52:35.300 - info: bluelink.0 (110216) terminating 2021-10-14 07:52:35.302 - info: bluelink.0 (110216) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason 2021-10-14 07:52:35.321 - info: host.debian stopInstance system.adapter.bluelink.0 send kill signal 2021-10-14 07:52:35.874 - info: host.debian instance system.adapter.bluelink.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION) 2021-10-14 07:52:38.431 - info: host.debian instance system.adapter.bluelink.0 started with pid 112864 2021-10-14 07:52:41.087 - info: bluelink.0 (112864) starting. Version 1.1.0 in /opt/iobroker/node_modules/iobroker.bluelink, node: v12.22.6, js-controller: 3.3.18 2021-10-14 07:52:41.210 - info: bluelink.0 (112864) Login to api 2021-10-14 07:52:46.311 - info: bluelink.0 (112864) Vehicles found 2021-10-14 07:52:46.386 - info: bluelink.0 (112864) Read new status from api 2021-10-14 07:53:03.714 - info: bluelink.0 (112864) Set new status 2021-10-14 07:53:03.781 - info: bluelink.0 (112864) State value to set for "bluelink.0.vehicleStatus.battery.plugin" has to be type "boolean" but received type "number"@fichte_112 das ist nur Info, stell mal auf debug um aber entferne deine Persönlichen Daten!
@newan sagte in Adapter Hyundai (Bluelink) oder KIA (UVO):
2021-10-14 08:33:11.423 - info: host.debian stopInstance system.adapter.bluelink.0 (force=false, process=true) 2021-10-14 08:33:11.450 - info: bluelink.0 (114905) Got terminate signal TERMINATE_YOURSELF 2021-10-14 08:33:11.452 - info: bluelink.0 (114905) Adapter bluelink cleaned up everything... 2021-10-14 08:33:11.453 - info: bluelink.0 (114905) terminating 2021-10-14 08:33:11.456 - info: bluelink.0 (114905) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason 2021-10-14 08:33:11.459 - info: host.debian stopInstance system.adapter.bluelink.0 send kill signal 2021-10-14 08:33:12.038 - info: host.debian instance system.adapter.bluelink.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION) 2021-10-14 08:33:14.514 - info: host.debian instance system.adapter.bluelink.0 started with pid 114944 2021-10-14 08:33:16.353 - debug: bluelink.0 (114944) Redis Objects: Use Redis connection: 127.0.0.1:9001 2021-10-14 08:33:16.389 - debug: bluelink.0 (114944) Objects client ready ... initialize now 2021-10-14 08:33:16.392 - debug: bluelink.0 (114944) Objects create System PubSub Client 2021-10-14 08:33:16.393 - debug: bluelink.0 (114944) Objects create User PubSub Client 2021-10-14 08:33:16.395 - debug: bluelink.0 (114944) Objects client initialize lua scripts 2021-10-14 08:33:16.640 - debug: bluelink.0 (114944) Objects connected to redis: 127.0.0.1:9001 2021-10-14 08:33:16.656 - debug: bluelink.0 (114944) objectDB connected 2021-10-14 08:33:16.659 - debug: bluelink.0 (114944) Redis States: Use Redis connection: 127.0.0.1:9000 2021-10-14 08:33:16.672 - debug: bluelink.0 (114944) States create System PubSub Client 2021-10-14 08:33:16.674 - debug: bluelink.0 (114944) States create User PubSub Client 2021-10-14 08:33:16.687 - debug: bluelink.0 (114944) States connected to redis: 127.0.0.1:9000 2021-10-14 08:33:16.689 - debug: bluelink.0 (114944) statesDB connected 2021-10-14 08:33:17.015 - info: bluelink.0 (114944) starting. Version 1.1.0 in /opt/iobroker/node_modules/iobroker.bluelink, node: v12.22.6, js-controller: 3.3.18 2021-10-14 08:33:17.125 - debug: bluelink.0 (114944) Schedule restart: */60 * * * * 2021-10-14 08:33:17.155 - info: bluelink.0 (114944) Login to api 2021-10-14 08:33:17.157 - debug: bluelink.0 (114944) xxx 2021-10-14 08:33:17.157 - debug: bluelink.0 (114944) {"username":"xxx","password":"xxx","pin":"xxx","brand":"kia","vin":"xxx","region":"EU"} 2021-10-14 08:33:21.091 - info: bluelink.0 (114944) Vehicles found 2021-10-14 08:33:21.130 - info: bluelink.0 (114944) Read new status from api 2021-10-14 08:33:32.424 - info: bluelink.0 (114944) Set new status 2021-10-14 08:33:32.425 - debug: bluelink.0 (114944) {"vehicleLocation":{"coord":{"lat":51.379586,"lon":12.404494,"alt":2,"type":0},"head":70,"speed":{"value":0,"unit":0},"accuracy":{"hdop":10,"pdop":10},"time":"20211014043331"},"vehicleStatus":{"airCtrlOn":false,"engine":false,"doorLock":true,"doorOpen":{"frontLeft":0,"frontRight":0,"backLeft":0,"backRight":0},"trunkOpen":false,"airTemp":{"value":"01H","unit":0,"hvacTempType":1},"defrost":false,"lowFuelLight":false,"acc":false,"evStatus":{"batteryCharge":false,"batteryStatus":100,"batteryPlugin":2,"remainTime2":{"etc2":{"value":0,"unit":1},"etc3":{"value":0,"unit":1},"atc":{"value":0,"unit":1}},"drvDistance":[{"rangeByFuel":{"gasModeRange":{"value":351,"unit":1},"evModeRange":{"value":4,"unit":1},"totalAvailableRange":{"value":355,"unit":1}},"type":2}],"reservChargeInfos":{"reservChargeInfo":{"reservChargeInfoDetail":{"reservInfo":{"day":[9],"time":{"time":"1200","timeSection":0}},"reservChargeSet":false}},"offpeakPowerInfo":{"offPeakPowerTime1":{"starttime":{"time":"1200","timeSection":0},"endtime":{"time":"1200","timeSection":0}},"offPeakPowerFlag":0},"reserveChargeInfo2":{"reservChargeInfoDetail":{"reservInfo":{"day":[9],"time":{"time":"1200","timeSection":0}},"reservChargeSet":false}},"reservFlag":0,"ect":{"start":{"day":9,"time":{"time":"1200","timeSection":0}},"end":{"day":9,"time":{"time":"1200","timeSection":0}}}}},"ign3":true,"hoodOpen":false,"transCond":true,"steerWheelHeat":0,"sideBackWindowHeat":0,"tirePressureLamp":{"tirePressureLampAll":0,"tirePressureLampFL":0,"tirePressureLampFR":0,"tirePressureLampRL":0,"tirePressureLampRR":0},"battery":{"batSoc":28,"batState":0},"time":"20211014043329","remoteWaitingTimeAlert":{"remoteControlAvailable":1},"systemCutOffAlert":0},"odometer":{"value":2379.6,"unit":1}} 2021-10-14 08:33:32.505 - debug: bluelink.0 (114944) Folgende Ladezeiten Moeglichkeiten wurden gefunden: 2021-10-14 08:33:32.506 - debug: bluelink.0 (114944) {"etc2":{"value":0,"unit":1},"etc3":{"value":0,"unit":1},"atc":{"value":0,"unit":1}} -
2021-10-14 08:33:11.423 - info: host.debian stopInstance system.adapter.bluelink.0 (force=false, process=true) 2021-10-14 08:33:11.450 - info: bluelink.0 (114905) Got terminate signal TERMINATE_YOURSELF 2021-10-14 08:33:11.452 - info: bluelink.0 (114905) Adapter bluelink cleaned up everything... 2021-10-14 08:33:11.453 - info: bluelink.0 (114905) terminating 2021-10-14 08:33:11.456 - info: bluelink.0 (114905) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason 2021-10-14 08:33:11.459 - info: host.debian stopInstance system.adapter.bluelink.0 send kill signal 2021-10-14 08:33:12.038 - info: host.debian instance system.adapter.bluelink.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION) 2021-10-14 08:33:14.514 - info: host.debian instance system.adapter.bluelink.0 started with pid 114944 2021-10-14 08:33:16.353 - debug: bluelink.0 (114944) Redis Objects: Use Redis connection: 127.0.0.1:9001 2021-10-14 08:33:16.389 - debug: bluelink.0 (114944) Objects client ready ... initialize now 2021-10-14 08:33:16.392 - debug: bluelink.0 (114944) Objects create System PubSub Client 2021-10-14 08:33:16.393 - debug: bluelink.0 (114944) Objects create User PubSub Client 2021-10-14 08:33:16.395 - debug: bluelink.0 (114944) Objects client initialize lua scripts 2021-10-14 08:33:16.640 - debug: bluelink.0 (114944) Objects connected to redis: 127.0.0.1:9001 2021-10-14 08:33:16.656 - debug: bluelink.0 (114944) objectDB connected 2021-10-14 08:33:16.659 - debug: bluelink.0 (114944) Redis States: Use Redis connection: 127.0.0.1:9000 2021-10-14 08:33:16.672 - debug: bluelink.0 (114944) States create System PubSub Client 2021-10-14 08:33:16.674 - debug: bluelink.0 (114944) States create User PubSub Client 2021-10-14 08:33:16.687 - debug: bluelink.0 (114944) States connected to redis: 127.0.0.1:9000 2021-10-14 08:33:16.689 - debug: bluelink.0 (114944) statesDB connected 2021-10-14 08:33:17.015 - info: bluelink.0 (114944) starting. Version 1.1.0 in /opt/iobroker/node_modules/iobroker.bluelink, node: v12.22.6, js-controller: 3.3.18 2021-10-14 08:33:17.125 - debug: bluelink.0 (114944) Schedule restart: */60 * * * * 2021-10-14 08:33:17.155 - info: bluelink.0 (114944) Login to api 2021-10-14 08:33:17.157 - debug: bluelink.0 (114944) xxx 2021-10-14 08:33:17.157 - debug: bluelink.0 (114944) {"username":"xxx","password":"xxx","pin":"xxx","brand":"kia","vin":"xxx","region":"EU"} 2021-10-14 08:33:21.091 - info: bluelink.0 (114944) Vehicles found 2021-10-14 08:33:21.130 - info: bluelink.0 (114944) Read new status from api 2021-10-14 08:33:32.424 - info: bluelink.0 (114944) Set new status 2021-10-14 08:33:32.425 - debug: bluelink.0 (114944) {"vehicleLocation":{"coord":{"lat":51.379586,"lon":12.404494,"alt":2,"type":0},"head":70,"speed":{"value":0,"unit":0},"accuracy":{"hdop":10,"pdop":10},"time":"20211014043331"},"vehicleStatus":{"airCtrlOn":false,"engine":false,"doorLock":true,"doorOpen":{"frontLeft":0,"frontRight":0,"backLeft":0,"backRight":0},"trunkOpen":false,"airTemp":{"value":"01H","unit":0,"hvacTempType":1},"defrost":false,"lowFuelLight":false,"acc":false,"evStatus":{"batteryCharge":false,"batteryStatus":100,"batteryPlugin":2,"remainTime2":{"etc2":{"value":0,"unit":1},"etc3":{"value":0,"unit":1},"atc":{"value":0,"unit":1}},"drvDistance":[{"rangeByFuel":{"gasModeRange":{"value":351,"unit":1},"evModeRange":{"value":4,"unit":1},"totalAvailableRange":{"value":355,"unit":1}},"type":2}],"reservChargeInfos":{"reservChargeInfo":{"reservChargeInfoDetail":{"reservInfo":{"day":[9],"time":{"time":"1200","timeSection":0}},"reservChargeSet":false}},"offpeakPowerInfo":{"offPeakPowerTime1":{"starttime":{"time":"1200","timeSection":0},"endtime":{"time":"1200","timeSection":0}},"offPeakPowerFlag":0},"reserveChargeInfo2":{"reservChargeInfoDetail":{"reservInfo":{"day":[9],"time":{"time":"1200","timeSection":0}},"reservChargeSet":false}},"reservFlag":0,"ect":{"start":{"day":9,"time":{"time":"1200","timeSection":0}},"end":{"day":9,"time":{"time":"1200","timeSection":0}}}}},"ign3":true,"hoodOpen":false,"transCond":true,"steerWheelHeat":0,"sideBackWindowHeat":0,"tirePressureLamp":{"tirePressureLampAll":0,"tirePressureLampFL":0,"tirePressureLampFR":0,"tirePressureLampRL":0,"tirePressureLampRR":0},"battery":{"batSoc":28,"batState":0},"time":"20211014043329","remoteWaitingTimeAlert":{"remoteControlAvailable":1},"systemCutOffAlert":0},"odometer":{"value":2379.6,"unit":1}} 2021-10-14 08:33:32.505 - debug: bluelink.0 (114944) Folgende Ladezeiten Moeglichkeiten wurden gefunden: 2021-10-14 08:33:32.506 - debug: bluelink.0 (114944) {"etc2":{"value":0,"unit":1},"etc3":{"value":0,"unit":1},"atc":{"value":0,"unit":1}}@fichte_112 ok da sind die coord drin. Wenn die nicht aktualisieren muss ich den Adapter nochmal prüfen
@newan Ja, man kann die Koordinaten auswählen. Es sind aber die, die vor dem Update gestimmt haben. Sie werden nicht aktualisiert.
@newan Hi, ja, der Fehler mit den Koordinaten ist bei mir auch vorhanden. Gerade getestet. ( Hyundai ).
@newan Issue aufgemacht, du hast gefixt, und ich hab Issue wieder zu gemacht. :-)
Vielen Dank! Super! -
Funktioniert wieder. Vielen Dank
Ich möchte meinen e-Niro über diesen Adapter überwachen, bekomme aber keine Verbindung.
Im log steht:
bluelink.0 2021-10-14 17:43:01.958 error ManagedBluelinkyError: @EuropeController.login: [400] Bad Request on [POST] https://prd.eu-ccapi.kia.com:8080/api/v1/user/signin - {"errId":"e2253e03-ae98-41bd-9360-e1d1cc0e7236","errCode":"4003","errMsg":"Invalid values"}Ich bin sicher, dass ich die richtige VIN eingefügt habe.
Kann es daran liegen, dass das Passwort keine Sonderzeichen enthalten darf?
Von meinem Prinzip der Groß- und Kleinschreibung, Ziffern und Sonderzeichen (insgesamt 12 Zeichen) möchte ich nicht abweichen.Mit der Android-App funktioniert die Verbindung tadellos.
Im log steht:
@meister-mopper wir speichern das Passwort verschlüsselt ab. Ob es da Probleme mit Sonderzeichen gibt kannst du testen indem du schaust ob es korrekt im debuglog ausgegeben wird.
@newan Die Daten stimmen so wie ich sie beim Einrichten gespeichert habe.
bluelink.0 2021-10-16 15:56:22.859 error ManagedBluelinkyError: @EuropeController.login: [400] Bad Request on [POST] https://prd.eu-ccapi.kia.com:8080/api/v1/user/signin - {"errId":"2b258692-e947-4d2d-82d9-3293b0c0fc7e","errCode":"4003","errMsg":"Invalid values"} bluelink.0 2021-10-16 15:56:22.859 debug Error on Api login bluelink.0 2021-10-16 15:56:21.621 debug {"username":"xx.xx@xx.de","password":"xxxxxxxxxxxx","pin":"xxx","brand":"kia","vin":"xxxxxxxxxxxxxxxxx","region":"EU"}Aber da sind noch immer
Invalid values -
Invalid values@meister-mopper teste mal debug locally von der lib
https://github.com/Hacksore/bluelinky -
https://github.com/Hacksore/bluelinky@newan Den Adapter bluelinky kann ich nicht installieren:
@meister-mopper bluelinky ist kein iobroker adapter..
https://github.com/Hacksore/bluelinky@newan sagte in Adapter Hyundai (Bluelink) oder KIA (UVO):
Okay, dann fehlt mir das Verständnis. Was meinst Du?
edit:
Okay, ich versuch malnpm install bluelinky
Sorry, mit
npm install bluelinkyaus dem Verzeichnis '/opt/iobroker' komme ich nicht zum Ziel. Wie muss ich bitte vorgehen? -
Sorry, mit
npm install bluelinkyaus dem Verzeichnis '/opt/iobroker' komme ich nicht zum Ziel. Wie muss ich bitte vorgehen?ich kenn mich damit auch nicht aus, aber hab gerade die Anleitung gelesen, ich würd bluelinky als addon in den javascript adapter eintragen, und dann eins von den Beispielscripten die in der Doc stehen, verwenden..
@ilovegym
hallöle, der Adapter schaut ja echt gut aus , danke dafür, leider Scheiter ich daran dass ich im log nach dem start folgende Meldung bekomme....eventuell hast Du ja ne Idee?
ManagedBluelinkyError: @EuropeController.login: [400] Bad Request on [POST] https://prd.eu-ccapi.hyundai.com:8080/api/v1/user/signin - {"errId":"7ed8e8d6-8255-428f-b85e-0427c7b7e029","errCode":"4003","errMsg":"Invalid values"}
