  4. Test Adapter enigma2 v1.2.x
adapterenigma2
640 Beiträge 71 Kommentatoren 285.8k Aufrufe 60 Beobachtet
  • Matten MattenM Matten Matten
    @negalein sagte in Test Adapter enigma2 v1.2.x:
    Ich bekomm seit JS-Controller 3.3.14 laufend solche Meldungen.
    enigma2.0 | 2021-07-08 16:04:56.849 | info | State value to set for "enigma2.0.enigma2.EVENTREMAINING" has to be type "number" but received type "string"
    enigma2.0 | 2021-07-08 16:04:56.848 | info | State value to set for "enigma2.0.enigma2.EVENTDURATION" has to be type "number" but received type "string"
    enigma2.0 | 2021-07-08 16:04:56.844 | info | State value to set for "enigma2.0.enigma2.MESSAGE_ANSWER" has to be type "integer" but received type "string"
    Bitte den Adapter neu installieren.
    NegaleinN
    NegaleinN
    Negalein
    #443
    @matten-matten sagte in Test Adapter enigma2 v1.2.x:
    Das wars.
    Nun kommt aber was neues.
    enigma2.0 2021-07-08 16:58:08.319	warn	State "enigma2.0.enigma2.HDD_FREE" has no existing object, this might lead to an error in future versions
    enigma2.0 2021-07-08 16:58:08.319	warn	State "enigma2.0.enigma2.HDD_CAPACITY" has no existing object, this might lead to an error in future versions
    enigma2.0 2021-07-08 16:57:47.334	warn	State "enigma2.0.enigma2.MOVIE_LIST" has no existing object, this might lead to an error in future versions
    enigma2.0 2021-07-08 16:57:43.350	info	enigma2 Verbunden!
    enigma2.0 2021-07-08 16:57:38.304	warn	State "enigma2.0.enigma2-CONNECTION" has no existing object, this might lead to an error in future versions
    enigma2.0 2021-07-08 16:57:38.303	warn	State "enigma2.0.Message.Timeout" has no existing object, this might lead to an error in future versions
    enigma2.0 2021-07-08 16:57:38.303	warn	State "enigma2.0.Message.Type" has no existing object, this might lead to an error in future versions
    enigma2.0 2021-07-08 16:57:38.284	info	starting Polling every 5000 ms
    enigma2.0 2021-07-08 16:57:38.261	info	starting. Version 1.3.3 in /opt/iobroker/node_modules/iobroker.enigma2, node: v14.17.1, js-controller: 3.3.14
    ° Fixer ---> iob fix
    Matten MattenM J 2 Antworten Letzte Antwort
    • NegaleinN Negalein
      Das wars.
      Matten MattenM
      Matten MattenM
      Matten Matten
      #444
      Das wars.
      Hast du die Instanzen vorher einmal gelöscht. Dann den Adapter neu installieren dann am besten ein Upload und die Instanzen neu anlegen.
      Gruß.
      ioBroker auf Beelink mit WIN10 home|CCU3 (Raspberrymatic)|Neato BotVac D3|HYPERION Ambilight auf RPI3 und RPI ZeroW|HA-Bridge|Milight LED|Nodered&Redmatic|VU Duo2 & Solo se V2
      NegaleinN oberfraggerO 2 Antworten Letzte Antwort
        Das wars.
        J
        J
        Jan1
        #445
        @negalein
        Greif mal auf die HDD zu, wenn die schläft bekommt der Adapter keine Daten ;)
          Das wars.
          Gruß.
          NegaleinN
          NegaleinN
          Negalein
          #446
          Nein.
          Hab den Adapter gelöscht, installiert und Instanz erzeugt.
          Hab nochmal einen Upload gemacht. Funktioniert! :)
          Wo kommt der leere Admin Ordner her? Ist der eventuell noch von vorher?
          Kann ich den löschen oder hat er eine Funktion?
            Nein.
            J
            J
            Jan1
            #447
            @negalein
            Einen leeren Admin Ordner habe ich bei jedem Adapter in den Objekten.
            • J Jan1
              @negalein
              NegaleinN
              NegaleinN
              Negalein
              #448
              @jan1 sagte in Test Adapter enigma2 v1.2.x:
              stimmt. Hab gerade nachgeschaut.
              Wird wohl mit Admin 5 zusammenhängen.
                J
                J
                Jan1
                #449
                @negalein
                Seit dem Umstieg sind die zumindest mal da. Was das soll frage ich mich aber auch. Da es nicht wirklich stört, wird es aber auch ein Sinn haben.
                Hatte übrigens die selben Meldungen wie Du im Log wegen der HDD und erst nach dem ich die aus dem Sleep geholt hatte und der Adapter die Werte lesen konnte war Ruhe.
                  Das wars.
                  Gruß.
                  oberfraggerO
                  oberfraggerO
                  oberfragger
                  #450
                  @matten-matten said in Test Adapter enigma2 v1.2.x:
                  Moin,
                  ich habe das so gemacht wie beschrieben. Vor der Neuinstallation der Instanzen noch die Objekte gelöscht. Leider bekomme ich noch folgendes:
                  enigma2.0
                  2021-08-10 22:20:22.561	warn	State "enigma2.0.enigma2.MOVIE_LIST" has no existing object, this might lead to an error in future versions
                  enigma2.0
                  2021-08-10 22:20:15.151	warn	State "enigma2.0.enigma2-CONNECTION" has no existing object, this might lead to an error in future versions
                  enigma2.0
                  2021-08-10 22:20:15.150	warn	State "enigma2.0.Message.Timeout" has no existing object, this might lead to an error in future versions
                  enigma2.0
                  2021-08-10 22:20:15.150	warn	State "enigma2.0.Message.Type" has no existing object, this might lead to an error in future versions
                  • HomoranH
                    #451
                    Hat sich eigentlich inzwischen ein Maintainer für den enigma2 Adapter gefunden?
                    Für admin 5 müsste da was angepasst werden
                      T
                      T
                      TiDO
                      #452
                      bekomme aktuell folgende Fehler:
                      enigma2.0
                      	2021-09-02 21:52:58.817	info	State value to set for "enigma2.0.enigma2.MESSAGE_ANSWER" has to be type "integer" but received type "string"
                      enigma2.0
                      	2021-09-02 21:52:53.832	info	State value to set for "enigma2.0.enigma2.EVENTREMAINING" has to be type "number" but received type "string"
                      enigma2.0
                      	2021-09-02 21:52:53.829	info	State value to set for "enigma2.0.enigma2.EVENTDURATION" has to be type "number" but received type "string"
                      enigma2.0
                      	2021-09-02 21:52:53.813	info	State value to set for "enigma2.0.enigma2.MESSAGE_ANSWER" has to be type "integer" but received type "string"
                      jemand eine Idee?
                      liegt das am js-controller 3.3.15?
                      • T TiDO
                        enigma2.0
                        enigma2.0
                        enigma2.0
                        enigma2.0
                        jemand eine Idee?
                        GlasfaserG
                        GlasfaserG
                        #453
                        @tido
                        Alle Datenpunkte vom enigma löschen und den Adapter neu installieren
                        https://forum.iobroker.net/topic/25112/test-adapter-enigma2-v1-2-x/441
                        • GlasfaserG Glasfaser
                          @tido
                          B
                          B
                          biker1602
                          #454
                          Ich habe mich jetzt auch mal, mit dem Adapter beschäftigt um mit einem Blockly zu arbeiten.
                          Ich habe eine VU+Duo2 mit Open ATV Image, und es wird mir unter Objekte alles angezeigt, aber mein Problem ist, zum einen, dass ich die Box zwar in den DeepStandby versetzen kann, aber nicht wieder eingeschaltet bekomme. Es stehen ja auch nur die Werte true und false zur Verfügung, die sich automatisch auch nicht ändern.
                          Das macht mich irgendwie stutzig. Kann mir da jemand helfen?
                          E B SBorgS 3 Antworten Letzte Antwort
                          • B biker1602
                            E
                            E
                            el_malto
                            #455
                            @biker1602 beim DeepStandby wird der Receiver komplett heruntergefahren. Sprich, es ist auch kein Netzwerk mehr verfügbar und somit kannst du den Receiver darüber nicht aus dem DeppStandby holen. Das geht dann nur noch mit der Fernbedienung. Wenn du den Receiver immer über ioBroker steuern willst, musst du den nur in den normalen Standby schicken.
                            Als abhilfe könnte hier vielleicht so eine Logitech Harmony sein? Weiß nicht ob man die quasi als "Brücke" nehmen kann.
                            • B biker1602
                              B
                              B
                              bombaman
                              #456
                              @biker1602 Du kannst über eine schaltbare Steckdose den Strom wegnehmen. Wenn du die dann wieder einschaltest dann startet der Receiver.
                              • B biker1602
                                SBorgS
                                SBorgS
                                SBorg
                                #457
                                Hat die VU+Duo2 nicht WoL (was noch immer selbst bei der aktuellen DreamBox fehlt... :( ) ?
                                @biker1602
                                Hast du irgendwo was im Menü mit "Wake on LAN" (sorry, DreamBox-Nutzer ;) ) ? Dann kannst du sie darüber aufwecken (bspw. "Magic Paket" per Blockly oä.).
                                LG SBorg ( SBorg auf GitHub)
                                AtifanA 1 Antwort Letzte Antwort
                                • SBorgS SBorg
                                  @biker1602
                                  AtifanA
                                  AtifanA
                                  Atifan
                                  #458
                                  Duo2 weiß ich nicht, ich hab ne UNO 4K SE, die hat kein WOL.
                                  Man kann den Receiver entweder wie schon geschrieben über ne schaltbare Steckdose Wecken über Strom aus/an, oder über HDMI-CEC wenn man das TV ansteuern kann und das angeht, dass dann der Receiver angeschaltet wird. Oder über nen IR-Sender.
                                  • AtifanA Atifan
                                    SBorgS
                                    SBorgS
                                    SBorg
                                    #459
                                    @atifan ...und ich dachte schon nur die "Dreamer" schauen da in die Röhre... ;)
                                    Hier ist aber sogar eine Anleitung zur Einrichtung.
                                    • B
                                      B
                                      biker1602
                                      #460
                                      @sborg Danke das werde ich mal testen
                                      • SBorgS SBorg
                                        B
                                        B
                                        biker1602
                                        #461
                                        @sborg Ich habe es mal getestet es in der Vu+Duo2 Box zu aktivieren und es hat auch funktioniert in der Fritzbox bin ich auf WoL aktivieren gegangen und dann auf starten und die Box ist hochgefahren. Leider finde ich im iobroker bei dem Adapter fb-checkpresence oder Fritzbox keinen Datenpunkt für WoL den ich für ein Script zum Aufwecken nehmen kann.
                                        Hast du da eine Idee?
                                        ? SBorgS 2 Antworten Letzte Antwort
                                        • B biker1602
                                          #462
                                          @biker1602
                                          Hi, da gibts mehrere Moeglichkeiten vom iobroker aus, schau mal hier nach:
                                          https://forum.iobroker.net/topic/8018/gelöst-wol-als-magicpaket-an-nas-per-blockly-script/3?_=1637058135404
                                          33.2k
                                          84.3k
