  4. Test Adapter enigma2 v1.2.x
    6.5k
adapterenigma2
640 Beiträge 71 Kommentatoren 219.7k Aufrufe 60 Beobachtet
  • Matten MattenM Matten Matten
    @negalein sagte in Test Adapter enigma2 v1.2.x:
    @matten-matten sagte in Test Adapter enigma2 v1.2.x:
    Bitte den Adapter neu installieren.
    Das wars.
    Nun kommt aber was neues.
    enigma2.0 2021-07-08 16:58:08.319	warn	State "enigma2.0.enigma2.HDD_FREE" has no existing object, this might lead to an error in future versions
    enigma2.0 2021-07-08 16:58:08.319	warn	State "enigma2.0.enigma2.HDD_CAPACITY" has no existing object, this might lead to an error in future versions
    enigma2.0 2021-07-08 16:57:47.334	warn	State "enigma2.0.enigma2.MOVIE_LIST" has no existing object, this might lead to an error in future versions
    enigma2.0 2021-07-08 16:57:43.350	info	enigma2 Verbunden!
    enigma2.0 2021-07-08 16:57:38.304	warn	State "enigma2.0.enigma2-CONNECTION" has no existing object, this might lead to an error in future versions
    enigma2.0 2021-07-08 16:57:38.303	warn	State "enigma2.0.Message.Timeout" has no existing object, this might lead to an error in future versions
    enigma2.0 2021-07-08 16:57:38.303	warn	State "enigma2.0.Message.Type" has no existing object, this might lead to an error in future versions
    enigma2.0 2021-07-08 16:57:38.284	info	starting Polling every 5000 ms
    enigma2.0 2021-07-08 16:57:38.261	info	starting. Version 1.3.3 in /opt/iobroker/node_modules/iobroker.enigma2, node: v14.17.1, js-controller: 3.3.14
    Hast du die Instanzen vorher einmal gelöscht. Dann den Adapter neu installieren dann am besten ein Upload und die Instanzen neu anlegen.
    Gruß.
    oberfraggerO Offline
    oberfragger
    #450
    @matten-matten said in Test Adapter enigma2 v1.2.x:
    Moin,
    ich habe das so gemacht wie beschrieben. Vor der Neuinstallation der Instanzen noch die Objekte gelöscht. Leider bekomme ich noch folgendes:
    enigma2.0
    2021-08-10 22:20:22.561	warn	State "enigma2.0.enigma2.MOVIE_LIST" has no existing object, this might lead to an error in future versions
    enigma2.0
    2021-08-10 22:20:15.151	warn	State "enigma2.0.enigma2-CONNECTION" has no existing object, this might lead to an error in future versions
    enigma2.0
    2021-08-10 22:20:15.150	warn	State "enigma2.0.Message.Timeout" has no existing object, this might lead to an error in future versions
    enigma2.0
    2021-08-10 22:20:15.150	warn	State "enigma2.0.Message.Type" has no existing object, this might lead to an error in future versions
      #451
      Hat sich eigentlich inzwischen ein Maintainer für den enigma2 Adapter gefunden?
      Für admin 5 müsste da was angepasst werden
        TiDO
        #452
        bekomme aktuell folgende Fehler:
        enigma2.0
        	2021-09-02 21:52:58.817	info	State value to set for "enigma2.0.enigma2.MESSAGE_ANSWER" has to be type "integer" but received type "string"
        enigma2.0
        	2021-09-02 21:52:53.832	info	State value to set for "enigma2.0.enigma2.EVENTREMAINING" has to be type "number" but received type "string"
        enigma2.0
        	2021-09-02 21:52:53.829	info	State value to set for "enigma2.0.enigma2.EVENTDURATION" has to be type "number" but received type "string"
        enigma2.0
        	2021-09-02 21:52:53.813	info	State value to set for "enigma2.0.enigma2.MESSAGE_ANSWER" has to be type "integer" but received type "string"
        jemand eine Idee?
        liegt das am js-controller 3.3.15?
        • T TiDO
          enigma2.0
          enigma2.0
          enigma2.0
          enigma2.0
          jemand eine Idee?
          GlasfaserG Offline
          GlasfaserG Offline
          #453
          @tido
          Alle Datenpunkte vom enigma löschen und den Adapter neu installieren
          https://forum.iobroker.net/topic/25112/test-adapter-enigma2-v1-2-x/441
          • GlasfaserG Glasfaser
            @tido
            biker1602
            #454
            Ich habe mich jetzt auch mal, mit dem Adapter beschäftigt um mit einem Blockly zu arbeiten.
            Ich habe eine VU+Duo2 mit Open ATV Image, und es wird mir unter Objekte alles angezeigt, aber mein Problem ist, zum einen, dass ich die Box zwar in den DeepStandby versetzen kann, aber nicht wieder eingeschaltet bekomme. Es stehen ja auch nur die Werte true und false zur Verfügung, die sich automatisch auch nicht ändern.
            Das macht mich irgendwie stutzig. Kann mir da jemand helfen?
            E B SBorgS 3 Antworten Letzte Antwort
            • B biker1602
              el_malto
              #455
              @biker1602 beim DeepStandby wird der Receiver komplett heruntergefahren. Sprich, es ist auch kein Netzwerk mehr verfügbar und somit kannst du den Receiver darüber nicht aus dem DeppStandby holen. Das geht dann nur noch mit der Fernbedienung. Wenn du den Receiver immer über ioBroker steuern willst, musst du den nur in den normalen Standby schicken.
              Als abhilfe könnte hier vielleicht so eine Logitech Harmony sein? Weiß nicht ob man die quasi als "Brücke" nehmen kann.
              • B biker1602
                B Online
                B Online
                bombaman
                #456
                @biker1602 Du kannst über eine schaltbare Steckdose den Strom wegnehmen. Wenn du die dann wieder einschaltest dann startet der Receiver.
                • B biker1602
                  SBorgS Offline
                  SBorgS Offline
                  SBorg
                  #457
                  Hat die VU+Duo2 nicht WoL (was noch immer selbst bei der aktuellen DreamBox fehlt... :( ) ?
                  @biker1602
                  Hast du irgendwo was im Menü mit "Wake on LAN" (sorry, DreamBox-Nutzer ;) ) ? Dann kannst du sie darüber aufwecken (bspw. "Magic Paket" per Blockly oä.).
                  LG SBorg ( SBorg auf GitHub)
                  AtifanA 1 Antwort Letzte Antwort
                  • SBorgS SBorg
                    @biker1602
                    AtifanA Offline
                    AtifanA Offline
                    Atifan
                    #458
                    Duo2 weiß ich nicht, ich hab ne UNO 4K SE, die hat kein WOL.
                    Man kann den Receiver entweder wie schon geschrieben über ne schaltbare Steckdose Wecken über Strom aus/an, oder über HDMI-CEC wenn man das TV ansteuern kann und das angeht, dass dann der Receiver angeschaltet wird. Oder über nen IR-Sender.
                    • AtifanA Atifan
                      SBorgS Offline
                      SBorgS Offline
                      SBorg
                      #459
                      @atifan ...und ich dachte schon nur die "Dreamer" schauen da in die Röhre... ;)
                      Hier ist aber sogar eine Anleitung zur Einrichtung.
                        biker1602
                        #460
                        @sborg Danke das werde ich mal testen
                        • SBorgS SBorg
                          biker1602
                          #461
                          @sborg Ich habe es mal getestet es in der Vu+Duo2 Box zu aktivieren und es hat auch funktioniert in der Fritzbox bin ich auf WoL aktivieren gegangen und dann auf starten und die Box ist hochgefahren. Leider finde ich im iobroker bei dem Adapter fb-checkpresence oder Fritzbox keinen Datenpunkt für WoL den ich für ein Script zum Aufwecken nehmen kann.
                          Hast du da eine Idee?
                          ? SBorgS 2 Antworten Letzte Antwort
                          • B biker1602
                            #462
                            @biker1602
                            Hi, da gibts mehrere Moeglichkeiten vom iobroker aus, schau mal hier nach:
                            https://forum.iobroker.net/topic/8018/gelöst-wol-als-magicpaket-an-nas-per-blockly-script/3?_=1637058135404
                            • B biker1602
                              SBorgS Offline
                              SBorgS Offline
                              SBorg
                              #463
                              @biker1602 siehe @ilovegym oder einfach runter gebrochen ein minimales JavaSkript.
                              Du legst dir einen Datenpunkt an wie bspw. "0_userdata.0.VU_einschalten".
                              Dann noch ein JS (xx:...:xx MAC-Adresse der VU):
                              let wol = require('wake_on_lan');
                              on({id: "0_userdata.0.VU_einschalten", val: true}, function (obj) {
                              	wol.wake("xx:xx:xx:xx:xx:xx");
                                      setState("0_userdata.0.VU_einschalten", false, true);
                              Wenn du nun "0_userdata.0.VU_einschalten" auf true setzt sollte sie eigentlich hochfahren.
                              ? B 2 Antworten Letzte Antwort
                              • SBorgS SBorg
                                #464
                                @sborg @biker1602
                                nicht vergessen, wake_on_lan im javascript Adapter zu hinterlegen, und wenn du es ganz praktisch machst, dann deklarierst du den Datenpunkt 0_userdata.0.VU_einschalten noch als button...
                                • SBorgS SBorg
                                  biker1602
                                  #465
                                  @sborg
                                  Ich habe mich vielleicht etwas verkehrt ausgedrückt aber ich arbeite nur mit Blockly unter Scripte und nicht mit Java Skript da ich mich da zu wenig auskenne. Ich mache alles nur über Blockly. Bin ehrlich ich habe mich da noch nicht richtig herangetraut.
                                    biker1602
                                    #466
                                    @ilovegym @SBorg
                                    Ich habe es hinbekommen wie auch immer
                                    • B biker1602
                                      @ilovegym @SBorg
                                      SBorgS Offline
                                      SBorgS Offline
                                      SBorg
                                      #467
                                      @biker1602 Dein "Glück" denn ich bin nicht der Blockly-Held 😂
                                      Wenn du den Datenpunkt wie von @ilovegym vorgeschlagen direkt als "Button" anlegst/angelegt hast, kannst du Zeile #5 dann auch weglassen.
                                      Ich nehme meist einen "normalen" Datenpunkt mit true/false, da nicht unbedingt jedes Widget korrekt mit einem Boolean-Button umgeht/umgehen kann.
                                      • SBorgS SBorg
                                        biker1602
                                        #468
                                        @sborg
                                        Ich bin ehrlich ich habe dein Script so wie du es im Post geschrieben hast kopiert eingefügt und den richtigen Namen und die Mac Adresse eingetragen.
                                        Aber ich habe keine Ahnung wo der auf einmal das WOL her hat. Aber ich habe ein Blockly mit dem Datenpunkt gemacht und der Receiver geht zu der bestimmten Zeit mit WOL an.
                                        • B biker1602
                                          @sborg
                                          SBorgS Offline
                                          SBorgS Offline
                                          SBorg
                                          #469
                                          @biker1602 Hauptsache läuft, also ✔ dran...
                                          Das WOL bezieht er aus Zeile #1. Lapidar: benutze Werkzeugkiste "wol" (da sind nun allerlei Werkzeuge drin)
                                          ...und in Zeile #4 gebe ich dann eine Anweisung: nimm nun aus Werkzeugkiste "wol" die Säge und schneide 10cm vom Brett ab : wol.wake("xx:xx:xx:xx:xx:xx")
                                          wol=Werkzeugkiste
                                          wake=welches Werkzeug
                                          xx:...:xx=quasi die auszuführende Tätigkeit
                                          ...und jetzt bin ich erst mal neidisch, dass deine VU WoL hat/kann...😂
                                          B J 2 Antworten Letzte Antwort
