  4. js-controller 3.3 jetzt im STABLE!
    apollon77A
344 Beiträge 61 Kommentatoren 142.2k Aufrufe 46 Beobachtet
    @peterfido
    Lösch den npm cache Mal
    cd /opt/iobroker
    npm cache clear --force
    P
    P
    peterfido
    #164
    @thomas-braun sagte in js-controller 3.3 jetzt im STABLE!:
    Leider keine Änderung.
    cmake (3.13.4-1) wird eingerichtet ...
    Trigger für man-db (2.8.5-2) werden verarbeitet ...
    Trigger für libc-bin (2.28-10) werden verarbeitet ...
    peter@proxbroker:/opt/iobroker$ npm cache clear --force
    npm WARN using --force I sure hope you know what you are doing.
    peter@proxbroker:/opt/iobroker$ iobroker upgrade self
    Update js-controller from @3.2.16 to @3.3.15
    NPM version: 6.14.14
    npm install iobroker.js-controller@3.3.15 --loglevel error --unsafe-perm --prefix "/opt/iobroker" (System call)
    In file included from ../src/binding.cc:1:
    /home/iobroker/.cache/node-gyp/12.22.5/include/node/node.h:736:43: warning: cast between incompatible function types from ‘void (*)(Nan::ADDON_REGISTER_FUNCTION_ARGS_TYPE)’ {aka ‘void (*)(v8::Local<v8::Object>)’} to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type]
           (node::addon_register_func) (regfunc),                          \
    /home/iobroker/.cache/node-gyp/12.22.5/include/node/node.h:770:3: note: in expansion of macro ‘NODE_MODULE_X’
       NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_usage)
    ../src/binding.cc:153:1: note: in expansion of macro ‘NODE_MODULE’
     NODE_MODULE(cpufeatures, init)
    In file included from ../src/binding.cc:6:
    ../src/binding.cc:2013:1: note: in expansion of macro ‘NODE_MODULE’
     NODE_MODULE(sshcrypto, init)
    Starting node restart.js
    Ich lasse es jetzt so.
    Peterfido
    • P peterfido
      Thomas BraunT
      Thomas BraunT
      #165
      @peterfido
      Versuchs so:
      cd /opt/iobroker
      sudo -H -u iobroker npm install iobroker.js-controller
      P 1 Antwort Letzte Antwort
        @peterfido
        Versuchs so:
        cd /opt/iobroker
        P
        P
        peterfido
        #166
        Das Ergebnis:
        peter@proxbroker:/opt/iobroker$ iobroker stop
        peter@proxbroker:/opt/iobroker$ sudo -H -u iobroker npm install iobroker.js-controller
        > iobroker.js-controller@3.3.15 preinstall /opt/iobroker/node_modules/iobroker.js-controller
        > node lib/preinstallCheck.js
        > iobroker.js-controller@3.3.15 install /opt/iobroker/node_modules/iobroker.js-controller
        > node iobroker.js setup first
        object _design/custom updated
        object _design/system updated
        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.3.2 (node_modules/chokidar/node_modules/fsevents):
        npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
        npm WARN typedoc@0.20.28 requires a peer of typescript@3.9.x || 4.0.x || 4.1.x but none is installed. You must install peer dependencies yourself.
        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/fsevents):
        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules/zigbee-herdsman/node_modules/fsevents):
        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules/zigbee-herdsman-converters/node_modules/fsevents):
        + iobroker.js-controller@3.3.15
        removed 88 packages and updated 1 package in 34.258s
        peter@proxbroker:/opt/iobroker$ iobroker start
        Peterfido
        • P peterfido
          Das Ergebnis:
          Thomas BraunT
          Thomas BraunT
          #167
          @peterfido Dann sollte es ja jetzt passen.
          iobroker version
            iobroker version
            P
            P
            peterfido
            #168
            Danke.
            Die Version war nach dem Update um 12:14 auch schon die 3.3.15. Es traten halt die Warnungen während des Updates auf.
            Mein erster Versuch ohne
            iobroker fix
            hatte die ioBroker "zerschossen". Er konnte ein paar Links nicht löschen. Danach lief kein Update mehr durch. Also im Snapshot zurück und erst den fix laufen lassen und nochmal aktualisieren.
            Danach war die Version zwar aktuell, jedoch war ich mir wegen der Fehlermeldung mit dem cmake unsicher und habe daher hier angefragt.
            Die (letzte) "manuelle" Installation hatte den positiven Nebeneffekt, dass ein paar Gigabyte freigeschaufelt wurden. 😊
            Peterfido
            • P peterfido
              Danke.
              iobroker fix
              Thomas BraunT
              Thomas BraunT
              #169
              @peterfido
              Jetzt kann ich dem auch nicht entnehmen ob das wieder senkrecht läuft...
              iobroker version
              iobroker update
              iobroker upgrade
                @peterfido
                iobroker version
                iobroker update
                iobroker upgrade
                P
                P
                peterfido
                #170
                peter@proxbroker:/opt/iobroker$ iobroker version
                3.3.15
                peter@proxbroker:/opt/iobroker$ iobroker update
                Used repository: stable
                hash unchanged, use cached sources
                update done
                Adapter    "admin"         : 5.1.23   , installed 5.1.23
                Adapter    "alexa2"        : 3.9.3    , installed 3.9.3
                Adapter    "asterisk"      : 1.0.6    , installed 1.0.6
                Adapter    "backitup"      : 2.1.13   , installed 2.1.13
                Adapter    "chromecast"    : 2.3.1    , installed 2.3.1
                Adapter    "cloud"         : 4.1.0    , installed 4.1.0
                Adapter    "daswetter"     : 3.0.7    , installed 3.0.7
                Adapter    "discovery"     : 2.7.0    , installed 2.7.0
                Adapter    "doorio"        : 2.0.1    , installed 2.0.1
                Adapter    "dwd"           : 2.7.7    , installed 2.7.7
                Adapter    "email"         : 1.0.10   , installed 1.0.10
                Adapter    "feiertage"     : 1.0.17   , installed 1.0.17
                Adapter    "flot"          : 1.10.6   , installed 1.10.6
                Adapter    "fullcalendar"  : 1.1.0    , installed 1.1.0
                Adapter    "fullybrowser"  : 2.0.8    , installed 2.0.8
                Adapter    "habpanel"      : 0.4.3    , installed 0.4.3
                Adapter    "harmony"       : 1.2.2    , installed 1.2.2
                Adapter    "history"       : 1.9.13   , installed 1.9.13
                Adapter    "hm-rega"       : 3.0.29   , installed 3.0.29
                Adapter    "hm-rpc"        : 1.14.43  , installed 1.14.43
                Adapter    "hue"           : 3.5.19   , installed 3.5.19
                Adapter    "hue-extended"  : 2.0.0    , installed 2.0.0
                Adapter    "ical"          : 1.11.2   , installed 1.11.2
                Adapter    "icons-addictive-flavour-png": 0.1.0   , installed 0.1.0
                Adapter    "icons-icons8"  : 0.0.1    , installed 0.0.1
                Adapter    "icons-material-png": 0.1.0   , installed 0.1.0
                Adapter    "icons-mfd-png" : 1.0.2    , installed 1.0.2
                Adapter    "icons-mfd-svg" : 1.0.2    , installed 1.0.2
                Adapter    "icons-open-icon-library-png": 0.1.2   , installed 0.1.2
                Adapter    "icons-ultimate-png": 1.0.1   , installed 1.0.1
                Adapter    "influxdb"      : 1.9.5    , installed 1.9.5
                Adapter    "info"          : 1.9.8    , installed 1.9.8
                Adapter    "iot"           : 1.8.22   , installed 1.8.22
                Adapter    "javascript"    : 5.2.8    , installed 5.2.8
                Controller "js-controller" : 3.3.15   , installed 3.3.15
                Adapter    "logparser"     : 1.1.0    , installed 1.1.0
                Adapter    "lovelace"      : 2.0.4    , installed 2.0.4
                Adapter    "material"      : 1.0.4    , installed 1.0.4
                Adapter    "mobile"        : 1.0.1    , installed 1.0.1
                Adapter    "modbus"        : 3.4.11   , installed 3.4.11
                Adapter    "mqtt"          : 2.4.0    , installed 2.4.0
                Adapter    "node-red"      : 2.4.0    , installed 2.4.0
                Adapter    "nut"           : 1.5.0    , installed 1.5.0
                Adapter    "onkyo"         : 2.1.0    , installed 2.1.0
                Adapter    "openweathermap": 0.1.0    , installed 0.1.0
                Adapter    "parser"        : 1.0.7    , installed 1.0.7
                Adapter    "ping"          : 1.5.0    , installed 1.5.0
                Adapter    "proxmox"       : 1.3.3    , installed 1.3.3
                Adapter    "pushover"      : 2.0.5    , installed 2.0.5
                Adapter    "rickshaw"      : 1.0.0    , installed 1.0.0
                Adapter    "s7"            : 1.3.6    , installed 1.3.6
                Adapter    "sayit"         : 1.12.3   , installed 1.12.3
                Adapter    "scenes"        : 2.3.6    , installed 2.3.6
                Adapter    "shelly"        : 4.0.7    , installed 4.0.7
                Adapter    "simple-api"    : 2.6.1    , installed 2.6.1
                Adapter    "snmp"          : 0.5.0    , installed 0.5.0
                Adapter    "socketio"      : 3.1.4    , installed 3.1.4
                Adapter    "sonoff"        : 2.4.5    , installed 2.4.5
                Adapter    "sql"           : 1.15.7   , installed 1.15.7
                Adapter    "statistics"    : 1.0.9    , installed 1.0.9
                Adapter    "systeminfo"    : 0.3.1    , installed 0.3.1
                Adapter    "tankerkoenig"  : 2.1.1    , installed 2.1.1
                Adapter    "telegram"      : 1.10.0   , installed 1.10.0
                Adapter    "text2command"  : 2.1.1    , installed 2.1.1
                Adapter    "trashschedule" : 1.2.0    , installed 1.2.0
                Adapter    "unifi"         : 0.5.10   , installed 0.5.10
                Adapter    "vis"           : 1.4.3    , installed 1.4.3
                Adapter    "vis-bars"      : 0.1.4    , installed 0.1.4
                Adapter    "vis-fancyswitch": 1.1.0   , installed 1.1.0
                Adapter    "vis-google-fonts": 0.1.0   , installed 0.1.0
                Adapter    "vis-history"   : 1.0.0    , installed 1.0.0
                Adapter    "vis-hqwidgets" : 1.1.7    , installed 1.1.7
                Adapter    "vis-icontwo"   : 0.75.0   , installed 0.75.0
                Adapter    "vis-inventwo"  : 3.0.11   , installed 3.0.11
                Adapter    "vis-keyboard"  : 0.0.2    , installed 0.0.2
                Adapter    "vis-material-advanced": 1.7.0   , installed 1.7.0
                Adapter    "vis-metro"     : 1.1.2    , installed 1.1.2
                Adapter    "vis-rgraph"    : 0.0.2    , installed 0.0.2
                Adapter    "vis-timeandweather": 1.1.7   , installed 1.1.7
                Adapter    "web"           : 3.4.7    , installed 3.4.7
                Adapter    "zigbee"        : 1.5.6    , installed 1.5.6
                All adapters are up to date
                Peterfido
                • P peterfido
                  3.3.15
                  update done
                  Thomas BraunT
                  Thomas BraunT
                  #171
                  @peterfido
                  Sollte jetzt passen.
                  Pedder007P 1 Antwort Letzte Antwort
                    @peterfido
                    Pedder007P
                    Pedder007P
                    Pedder007
                    schrieb am zuletzt editiert von Pedder007
                    #172
                    @die Beteiligten, wollte an der Stelle einfach einmal Danke sagen!
                    Nach einigem lesen hier im Forum und der ein oder anderen beantworteten Frage habe ich am letzten Sonntag alles ge-updated.
                    Also js-controller, javascript und zum Schluss noch Admin. Davor noch 3-4 andere Adapter inkl. deCONZ.
                    ... und was soll ich sagen, komplett unspektakulär, keinerlei Probleme, geradezu laaangweilig 😂 👍 👍 👍
                    Alles lüppt geschmeidig weiter 🤗
                    Einen klasse Job habt ihr da alle gemacht, danke!
                    PS.
                    Hatte extra 2 SD-Card Clone + Backitup + Kopie des iobroker-data Verzeichnisses angelegt.
                    Alles völlig umsonst ;-)
                    Pedder
                    All @Proxmox/Trixie auf HP Elitedesk 800 G4; Zigbee: ZigStar (LAN), ~110Devices
                    Unifi, Motioneye/3Reolinks, PiHole, Bosch CS7800i via BBQKees/EMS-ESP, Fronius/BYD 11kWp via Modbus
                    Under construction: Smart-WoMo auf Raspi4
                    F 1 Antwort Letzte Antwort
                    • Pedder007P Pedder007
                      PS.
                      F
                      F
                      fastfoot
                      #173
                      @pedder007 sagte in js-controller 3.3 jetzt im STABLE!:
                      Backups sind nie!!! umsonst :-)
                      • C
                        C
                        chhe
                        #174
                        @apollon77 said in js-controller 3.3 jetzt im STABLE!:
                        Windows
                        Ausa der Community kommt von @sigi234 eine Anleitung für ein Windows Update Update_Windows_ioBroker.pdf
                        die Anleitung ist ja sehr ausführlich und auch hilfreich. Wie soll mal mit dem Windows installer aber updaten wenn die letzte zur Verfügung stehende Version vom 23.11.2019 ist?
                        https://www.iobroker.net/#de/download
                        • C chhe
                          Windows
                          sigi234S
                          sigi234S
                          #175
                          @chhe sagte in js-controller 3.3 jetzt im STABLE!:
                          Windows
                          Na darum ist die Anleitung ja da, bis es eine neue Version vom Installer gibt.
                          C 1 Antwort Letzte Antwort
                          • sigi234S sigi234
                            Windows
                            C
                            C
                            chhe
                            #176
                            @sigi234
                            Die Anleitung gibt aber vor, eine Frische Installation mit dem Installer durchzuführen. Das erscheint mir aber ohne die neue Version des Installers nicht möglich.
                            Mein Problem ist eigtl. folgendes:
                            Die bei mir installierten Versionen sind mittlerweile veraltet.
                            Node.js ist 10.17.0
                            js-controller ist 3.2.16
                            Admin ist 4.0.10
                            Ich möchte nun updaten, da ich auch nun den ersten Adapter habe der mit der Adminversion nicht mehr kompatibel ist. Wie soll ich nun vorgehen?
                            1. Backup machen
                            2. iobroker stop
                              npm i iobroker.js-controller@stable --ignore-scripts
                              iobroker start
                            3. js-controller updaten (wie in der verlinkten Anleitung beschrieben)
                            4. Node.js updaten (wie in der verlinkten Anleitung beschrieben)
                            Ich bin davon ausgegangen, dass ich mit dem Installer und der frischen Installation den Admin update. An welcher Stelle soll ich das nun machen?
                            • C chhe
                              @sigi234
                              Node.js ist 10.17.0
                              Admin ist 4.0.10
                              1. Backup machen
                              2. iobroker stop
                                iobroker start
                              sigi234S
                              sigi234S
                              #177
                              Nein
                              1.Schritt
                              In der GUI die Updates machen - falls nötig
                              Dabei (falls Update) den zuvor gesicherten data-Ordner durch den Installer
                              einlesen.
                              Migration kann Stunden dauern!
                              Dann weiter mit Schritt 2+3
                              • crunchipC
                                crunchipC
                                Developer Global Moderator Most Active Forum Testing
                                #178
                                @apollon77
                                v3.3.15
                                habe gerade meine Proxmox VM gestoppt und anschliessend neu gestartet, im log findet man zu sämtlichen Adaptern
                                terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                                des weiteren kam diese Meldung
                                host.IoBroker
                                	2021-08-19 21:43:41.306	error	Caught by controller[0]: at processTicksAndRejections (internal/process/task_queues.js:95:5)
                                host.IoBroker
                                	2021-08-19 21:43:41.306	error	Caught by controller[0]: at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:352:25)
                                host.IoBroker
                                	2021-08-19 21:43:41.305	error	Caught by controller[0]: at process.exit (internal/process/per_thread.js:169:15)
                                host.IoBroker
                                	2021-08-19 21:43:41.305	error	Caught by controller[0]: at processEmit [as emit] (/opt/iobroker/node_modules/signal-exit/index.js:149:35)
                                host.IoBroker
                                	2021-08-19 21:43:41.304	error	Caught by controller[0]: at process.emit (events.js:400:28)
                                host.IoBroker
                                	2021-08-19 21:43:41.304	error	Caught by controller[0]: at Object.onceWrapper (events.js:520:26)
                                host.IoBroker
                                	2021-08-19 21:43:41.303	error	Caught by controller[0]: at process.stop (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:8747:22)
                                host.IoBroker
                                	2021-08-19 21:43:41.303	error	Caught by controller[0]: at Adapter.emit (events.js:400:28)
                                host.IoBroker
                                	2021-08-19 21:43:41.302	error	Caught by controller[0]: at Adapter.unload (/opt/iobroker/node_modules/iobroker.chromecast/main.js:79:19)
                                host.IoBroker
                                	2021-08-19 21:43:41.300	error	Caught by controller[0]: TypeError: Cannot read property 'info' of undefined
                                  @apollon77
                                  v3.3.15
                                  host.IoBroker
                                  host.IoBroker
                                  host.IoBroker
                                  host.IoBroker
                                  host.IoBroker
                                  host.IoBroker
                                  host.IoBroker
                                  host.IoBroker
                                  host.IoBroker
                                  host.IoBroker
                                  apollon77A
                                  apollon77A
                                  #179
                                  @crunchip Hm ... Was heisst denn "gestoppt"? Hart ohne iobroker sauber zu beenden?
                                  Dann wären die "Already Running" Meldungen erstmal ok weil der Controller denkt das noch die alte Instanz-Prozesse laufen ... er sendet ihr dann nen Kill Befehl aber ist ja schon weg von daher egal ... und er startet dann einen neuen Prozess. Herauszufinden ob eine "andere" prozess-ID noch läuft ist nicht ganz so simpel.
                                  Immer Systeme sauber runterfahren :-)
                                  Für den Chromecast Fehler würde ich da mal ein Issue anlegen. Interessant wäre noch zu wissen WANN das log kam?
                                  • apollon77A apollon77
                                    crunchipC
                                    crunchipC
                                    #180
                                    @apollon77 sagte in js-controller 3.3 jetzt im STABLE!:
                                    jep, VM direkt gestoppt, nicht dran gedacht, weil das gerade alles so nervt...die Fehlersuche
                                    jetzt, ist mir das nächste aufgefallen, nachdem ich das log durch gesehen habe
                                    zwei Browserfenster, ich verstehe das nicht, log Größe unterschiedlich und unterschiedliche Meldungen
                                    c00a8347-d3e1-455d-a167-8103cfe649cd-grafik.png b86c0e1f-2733-4805-9725-2903cd9964c7-grafik.png
                                    irgendwann mittendrin, nachdem schon ein paar Instanzen gestartet sind
                                    2021-08-19 21:42:51.416 - info: admin.0 (866) starting. Version 5.1.25 in /opt/iobroker/node_modules/iobroker.admin, node: v14.17.4, js-controller: 3.3.15
                                    2021-08-19 21:43:41.300 - error: host.IoBroker Caught by controller[0]: TypeError: Cannot read property 'info' of undefined
                                      apollon77A
                                      apollon77A
                                      #181
                                      @crunchip ich verstehe nicht was ich da sehe ... sorry. Aber ehrlich ... mach nen sauberen "iobroker stop" und "iobroker start" dann sollte alles ok sein wieder
                                      • M
                                        M
                                        Mechy
                                        #182
                                        Hallo zusammen!
                                        Ich hab nun mal was abgewaret bevor ich der Anleitung folge. Nun hatte ich alles aktualisiert und mein IOBroker startet nicht mehr.
                                        pi@PI:~ $ iob start
                                        pi@PI:~ $ iobroker start
                                        pi@PI:~ $ cd /opt/iobroker
                                        pi@PI:/opt/iobroker $ iob start
                                        pi@PI:/opt/iobroker $ node -v
                                        v12.22.5
                                        pi@PI:/opt/iobroker $ npm -v
                                        6.14.14
                                        pi@PI:/opt/iobroker $ iobroker fix
                                        library: loaded
                                        Library version=2021-04-07
                                        ioBroker is not installed in /opt/iobroker! Cannot fix anything...
                                        Was mich nun wundert das er sagt er sei nicht installiert obwohl ich ja im Verzeichnis bin, wie gehe ich nun am besten vor?
                                        Danke im Voraus!
                                        • M Mechy
                                          Hallo zusammen!
                                          pi@PI:~ $ iob start
                                          v12.22.5
                                          6.14.14
                                          library: loaded
                                          Danke im Voraus!
                                          Thomas BraunT
                                          Thomas BraunT
                                          #183
                                          @mechy
                                          Bitte CodeTags verwenden.
                                          iobroker status
                                          sagt?
                                          84.0k
