  4. js-controller 3.3 jetzt im STABLE!
344 Beiträge 61 Kommentatoren 138.1k Aufrufe 46 Beobachtet
  • P peterfido
    @apollon77
    Das Update ist durchgeführt. Vorher musste ich noch einen
    iobroker fix
    durchführen.
    Die Ausgabe des Updates:
    peter@proxbroker:/opt/iobroker$ iobroker upgrade self
    Update js-controller from @3.2.16 to @3.3.15
    NPM version: 6.14.14
    npm install iobroker.js-controller@3.3.15 --loglevel error --unsafe-perm --prefix "/opt/iobroker" (System call)
    /bin/sh: 1: cmake: not found
    make: *** [config_deps.target.mk:13: /opt/iobroker/node_modules/cpu-features/deps/cpu_features/build/Makefile] Fehler 127
    gyp ERR! build error
    gyp ERR! stack Error: `make` failed with exit code: 2
    gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:194:23)
    gyp ERR! stack     at ChildProcess.emit (events.js:314:20)
    gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:276:12)
    gyp ERR! System Linux 4.19.0-17-amd64
    gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
    gyp ERR! cwd /opt/iobroker/node_modules/cpu-features
    gyp ERR! node -v v12.22.5
    gyp ERR! node-gyp -v v5.1.0
    gyp ERR! not ok
    In file included from ../src/binding.cc:6:
    /home/iobroker/.cache/node-gyp/12.22.5/include/node/node.h:736:43: warning: cast between incompatible function types from ‘void (*)(Nan::ADDON_REGISTER_FUNCTION_ARGS_TYPE)’ {aka ‘void (*)(v8::Local<v8::Object>)’} to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type]
           (node::addon_register_func) (regfunc),                          \
    /home/iobroker/.cache/node-gyp/12.22.5/include/node/node.h:770:3: note: in expansion of macro ‘NODE_MODULE_X’
       NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_usage)
    ../src/binding.cc:2013:1: note: in expansion of macro ‘NODE_MODULE’
     NODE_MODULE(sshcrypto, init)
    Starting node restart.js
    Kann ich die Fehler ignorieren?
    Thomas BraunT
    Thomas BraunT
    #159
    @peterfido
    cmake würde ich mal nachinstallieren.
    apt policy cmake
    bringt?
    P 1 Antwort Letzte Antwort
      @peterfido
      apt policy cmake
      bringt?
      P
      P
      peterfido
      schrieb am zuletzt editiert von peterfido
      #160
      Danke.
      OK, habe ich installiert.
      cmake:
        Installiert:           (keine)
        Installationskandidat: 3.13.4-1
        Versionstabelle:
           3.13.4-1 500
              500 http://deb.debian.org/debian buster/main amd64 Packages
              500 http://ftp.de.debian.org/debian buster/main amd64 Packages
      peter@proxbroker:~$ sudo apt install cmake
      Die folgenden zusätzlichen Pakete werden installiert:
        cmake-data libjsoncpp1 librhash0
      Vorgeschlagene Pakete:
        cmake-doc ninja-build
      Die folgenden NEUEN Pakete werden installiert:
        cmake cmake-data libjsoncpp1 librhash0
      0 aktualisiert, 4 neu installiert, 0 zu entfernen und 0 nicht aktualisiert.
      Es müssen 5.155 kB an Archiven heruntergeladen werden.
      Nach dieser Operation werden 25,8 MB Plattenplatz zusätzlich benutzt.
      Möchten Sie fortfahren? [J/n]
      Holen:1 http://deb.debian.org/debian buster/main amd64 cmake-data all 3.13.4-1 [1.476 kB]
      Holen:2 http://deb.debian.org/debian buster/main amd64 libjsoncpp1 amd64 1.7.4-3 [75,6 kB]
      Holen:3 http://deb.debian.org/debian buster/main amd64 librhash0 amd64 1.3.8-1 [122 kB]
      Holen:4 http://deb.debian.org/debian buster/main amd64 cmake amd64 3.13.4-1 [3.480 kB]
      Es wurden 5.155 kB in 0 s geholt (19,2 MB/s).
      Vormals nicht ausgewähltes Paket cmake-data wird gewählt.
      (Lese Datenbank ... 123005 Dateien und Verzeichnisse sind derzeit installiert.)
      Vorbereitung zum Entpacken von .../cmake-data_3.13.4-1_all.deb ...
      Entpacken von cmake-data (3.13.4-1) ...
      Vormals nicht ausgewähltes Paket libjsoncpp1:amd64 wird gewählt.
      Vorbereitung zum Entpacken von .../libjsoncpp1_1.7.4-3_amd64.deb ...
      Entpacken von libjsoncpp1:amd64 (1.7.4-3) ...
      Vormals nicht ausgewähltes Paket librhash0:amd64 wird gewählt.
      Vorbereitung zum Entpacken von .../librhash0_1.3.8-1_amd64.deb ...
      Entpacken von librhash0:amd64 (1.3.8-1) ...
      Vormals nicht ausgewähltes Paket cmake wird gewählt.
      Vorbereitung zum Entpacken von .../cmake_3.13.4-1_amd64.deb ...
      Entpacken von cmake (3.13.4-1) ...
      librhash0:amd64 (1.3.8-1) wird eingerichtet ...
      cmake-data (3.13.4-1) wird eingerichtet ...
      libjsoncpp1:amd64 (1.7.4-3) wird eingerichtet ...
      cmake (3.13.4-1) wird eingerichtet ...
      Trigger für man-db (2.8.5-2) werden verarbeitet ...
      Trigger für libc-bin (2.28-10) werden verarbeitet ...
      peter@proxbroker:~$
      Sollte ich nochmal iobroker upgraden? << Also erst zurück zum Snapshot und dann nochmal mit cmake
      Peterfido
      • P peterfido
        Danke.
        cmake:
          Versionstabelle:
             3.13.4-1 500
        peter@proxbroker:~$
        Thomas BraunT
        Thomas BraunT
        #161
        @peterfido
        Dann versuch jetzt nochmal dein Glück.
          @peterfido
          P
          P
          peterfido
          #162
          Habe ich. Ein paar Warnungen kommen noch.
          In file included from ../src/binding.cc:1:
          ../src/binding.cc:153:1: note: in expansion of macro ‘NODE_MODULE’
           NODE_MODULE(cpufeatures, init)
          Peterfido
          • P peterfido
            Thomas BraunT
            Thomas BraunT
            #163
            @peterfido
            Lösch den npm cache Mal
            cd /opt/iobroker
            npm cache clear --force
              @peterfido
              cd /opt/iobroker
              P
              P
              peterfido
              #164
              @thomas-braun sagte in js-controller 3.3 jetzt im STABLE!:
              Leider keine Änderung.
              peter@proxbroker:/opt/iobroker$ npm cache clear --force
              npm WARN using --force I sure hope you know what you are doing.
              Ich lasse es jetzt so.
              Peterfido
              • P peterfido
                Thomas BraunT
                Thomas BraunT
                #165
                @peterfido
                Versuchs so:
                cd /opt/iobroker
                sudo -H -u iobroker npm install iobroker.js-controller
                  @peterfido
                  Versuchs so:
                  cd /opt/iobroker
                  P
                  P
                  peterfido
                  #166
                  Das Ergebnis:
                  peter@proxbroker:/opt/iobroker$ iobroker stop
                  peter@proxbroker:/opt/iobroker$ sudo -H -u iobroker npm install iobroker.js-controller
                  > iobroker.js-controller@3.3.15 preinstall /opt/iobroker/node_modules/iobroker.js-controller
                  > node lib/preinstallCheck.js
                  > iobroker.js-controller@3.3.15 install /opt/iobroker/node_modules/iobroker.js-controller
                  > node iobroker.js setup first
                  object _design/custom updated
                  object _design/system updated
                  npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.3.2 (node_modules/chokidar/node_modules/fsevents):
                  npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
                  npm WARN typedoc@0.20.28 requires a peer of typescript@3.9.x || 4.0.x || 4.1.x but none is installed. You must install peer dependencies yourself.
                  npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/fsevents):
                  npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules/zigbee-herdsman/node_modules/fsevents):
                  npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules/zigbee-herdsman-converters/node_modules/fsevents):
                  + iobroker.js-controller@3.3.15
                  removed 88 packages and updated 1 package in 34.258s
                  peter@proxbroker:/opt/iobroker$ iobroker start
                  Peterfido
                  • P peterfido
                    Das Ergebnis:
                    Thomas BraunT
                    Thomas BraunT
                    #167
                    @peterfido Dann sollte es ja jetzt passen.
                    iobroker version
                      iobroker version
                      P
                      P
                      peterfido
                      #168
                      Danke.
                      Die Version war nach dem Update um 12:14 auch schon die 3.3.15. Es traten halt die Warnungen während des Updates auf.
                      Mein erster Versuch ohne
                      iobroker fix
                      hatte die ioBroker "zerschossen". Er konnte ein paar Links nicht löschen. Danach lief kein Update mehr durch. Also im Snapshot zurück und erst den fix laufen lassen und nochmal aktualisieren.
                      Danach war die Version zwar aktuell, jedoch war ich mir wegen der Fehlermeldung mit dem cmake unsicher und habe daher hier angefragt.
                      Die (letzte) "manuelle" Installation hatte den positiven Nebeneffekt, dass ein paar Gigabyte freigeschaufelt wurden. 😊
                      Peterfido
                      • P peterfido
                        Danke.
                        iobroker fix
                        Thomas BraunT
                        Thomas BraunT
                        #169
                        @peterfido
                        Jetzt kann ich dem auch nicht entnehmen ob das wieder senkrecht läuft...
                        iobroker version
                        iobroker update
                        iobroker upgrade
                          @peterfido
                          iobroker version
                          iobroker update
                          iobroker upgrade
                          P
                          P
                          peterfido
                          #170
                          peter@proxbroker:/opt/iobroker$ iobroker version
                          3.3.15
                          peter@proxbroker:/opt/iobroker$ iobroker update
                          Used repository: stable
                          hash unchanged, use cached sources
                          update done
                          Adapter    "admin"         : 5.1.23   , installed 5.1.23
                          Adapter    "alexa2"        : 3.9.3    , installed 3.9.3
                          Adapter    "asterisk"      : 1.0.6    , installed 1.0.6
                          Adapter    "backitup"      : 2.1.13   , installed 2.1.13
                          Adapter    "chromecast"    : 2.3.1    , installed 2.3.1
                          Adapter    "cloud"         : 4.1.0    , installed 4.1.0
                          Adapter    "daswetter"     : 3.0.7    , installed 3.0.7
                          Adapter    "discovery"     : 2.7.0    , installed 2.7.0
                          Adapter    "doorio"        : 2.0.1    , installed 2.0.1
                          Adapter    "dwd"           : 2.7.7    , installed 2.7.7
                          Adapter    "email"         : 1.0.10   , installed 1.0.10
                          Adapter    "feiertage"     : 1.0.17   , installed 1.0.17
                          Adapter    "flot"          : 1.10.6   , installed 1.10.6
                          Adapter    "fullcalendar"  : 1.1.0    , installed 1.1.0
                          Adapter    "fullybrowser"  : 2.0.8    , installed 2.0.8
                          Adapter    "habpanel"      : 0.4.3    , installed 0.4.3
                          Adapter    "harmony"       : 1.2.2    , installed 1.2.2
                          Adapter    "history"       : 1.9.13   , installed 1.9.13
                          Adapter    "hm-rega"       : 3.0.29   , installed 3.0.29
                          Adapter    "hm-rpc"        : 1.14.43  , installed 1.14.43
                          Adapter    "hue"           : 3.5.19   , installed 3.5.19
                          Adapter    "hue-extended"  : 2.0.0    , installed 2.0.0
                          Adapter    "ical"          : 1.11.2   , installed 1.11.2
                          Adapter    "icons-addictive-flavour-png": 0.1.0   , installed 0.1.0
                          Adapter    "icons-icons8"  : 0.0.1    , installed 0.0.1
                          Adapter    "icons-material-png": 0.1.0   , installed 0.1.0
                          Adapter    "icons-mfd-png" : 1.0.2    , installed 1.0.2
                          Adapter    "icons-mfd-svg" : 1.0.2    , installed 1.0.2
                          Adapter    "icons-open-icon-library-png": 0.1.2   , installed 0.1.2
                          Adapter    "icons-ultimate-png": 1.0.1   , installed 1.0.1
                          Adapter    "influxdb"      : 1.9.5    , installed 1.9.5
                          Adapter    "info"          : 1.9.8    , installed 1.9.8
                          Adapter    "iot"           : 1.8.22   , installed 1.8.22
                          Adapter    "javascript"    : 5.2.8    , installed 5.2.8
                          Controller "js-controller" : 3.3.15   , installed 3.3.15
                          Adapter    "logparser"     : 1.1.0    , installed 1.1.0
                          Adapter    "lovelace"      : 2.0.4    , installed 2.0.4
                          Adapter    "material"      : 1.0.4    , installed 1.0.4
                          Adapter    "mobile"        : 1.0.1    , installed 1.0.1
                          Adapter    "modbus"        : 3.4.11   , installed 3.4.11
                          Adapter    "mqtt"          : 2.4.0    , installed 2.4.0
                          Adapter    "node-red"      : 2.4.0    , installed 2.4.0
                          Adapter    "nut"           : 1.5.0    , installed 1.5.0
                          Adapter    "onkyo"         : 2.1.0    , installed 2.1.0
                          Adapter    "openweathermap": 0.1.0    , installed 0.1.0
                          Adapter    "parser"        : 1.0.7    , installed 1.0.7
                          Adapter    "ping"          : 1.5.0    , installed 1.5.0
                          Adapter    "proxmox"       : 1.3.3    , installed 1.3.3
                          Adapter    "pushover"      : 2.0.5    , installed 2.0.5
                          Adapter    "rickshaw"      : 1.0.0    , installed 1.0.0
                          Adapter    "s7"            : 1.3.6    , installed 1.3.6
                          Adapter    "sayit"         : 1.12.3   , installed 1.12.3
                          Adapter    "scenes"        : 2.3.6    , installed 2.3.6
                          Adapter    "shelly"        : 4.0.7    , installed 4.0.7
                          Adapter    "simple-api"    : 2.6.1    , installed 2.6.1
                          Adapter    "snmp"          : 0.5.0    , installed 0.5.0
                          Adapter    "socketio"      : 3.1.4    , installed 3.1.4
                          Adapter    "sonoff"        : 2.4.5    , installed 2.4.5
                          Adapter    "sql"           : 1.15.7   , installed 1.15.7
                          Adapter    "statistics"    : 1.0.9    , installed 1.0.9
                          Adapter    "systeminfo"    : 0.3.1    , installed 0.3.1
                          Adapter    "tankerkoenig"  : 2.1.1    , installed 2.1.1
                          Adapter    "telegram"      : 1.10.0   , installed 1.10.0
                          Adapter    "text2command"  : 2.1.1    , installed 2.1.1
                          Adapter    "trashschedule" : 1.2.0    , installed 1.2.0
                          Adapter    "unifi"         : 0.5.10   , installed 0.5.10
                          Adapter    "vis"           : 1.4.3    , installed 1.4.3
                          Adapter    "vis-bars"      : 0.1.4    , installed 0.1.4
                          Adapter    "vis-fancyswitch": 1.1.0   , installed 1.1.0
                          Adapter    "vis-google-fonts": 0.1.0   , installed 0.1.0
                          Adapter    "vis-history"   : 1.0.0    , installed 1.0.0
                          Adapter    "vis-hqwidgets" : 1.1.7    , installed 1.1.7
                          Adapter    "vis-icontwo"   : 0.75.0   , installed 0.75.0
                          Adapter    "vis-inventwo"  : 3.0.11   , installed 3.0.11
                          Adapter    "vis-keyboard"  : 0.0.2    , installed 0.0.2
                          Adapter    "vis-material-advanced": 1.7.0   , installed 1.7.0
                          Adapter    "vis-metro"     : 1.1.2    , installed 1.1.2
                          Adapter    "vis-rgraph"    : 0.0.2    , installed 0.0.2
                          Adapter    "vis-timeandweather": 1.1.7   , installed 1.1.7
                          Adapter    "web"           : 3.4.7    , installed 3.4.7
                          Adapter    "zigbee"        : 1.5.6    , installed 1.5.6
                          All adapters are up to date
                          Peterfido
                          • P peterfido
                            3.3.15
                            update done
                            Thomas BraunT
                            Thomas BraunT
                            #171
                            @peterfido
                            Sollte jetzt passen.
                            Pedder007P 1 Antwort Letzte Antwort
                              @peterfido
                              Pedder007P
                              Pedder007P
                              Pedder007
                              schrieb am zuletzt editiert von Pedder007
                              #172
                              @die Beteiligten, wollte an der Stelle einfach einmal Danke sagen!
                              Nach einigem lesen hier im Forum und der ein oder anderen beantworteten Frage habe ich am letzten Sonntag alles ge-updated.
                              Also js-controller, javascript und zum Schluss noch Admin. Davor noch 3-4 andere Adapter inkl. deCONZ.
                              ... und was soll ich sagen, komplett unspektakulär, keinerlei Probleme, geradezu laaangweilig 😂 👍 👍 👍
                              Alles lüppt geschmeidig weiter 🤗
                              Einen klasse Job habt ihr da alle gemacht, danke!
                              PS.
                              Hatte extra 2 SD-Card Clone + Backitup + Kopie des iobroker-data Verzeichnisses angelegt.
                              Alles völlig umsonst ;-)
                              Pedder
                              All @Proxmox/Trixie auf HP Elitedesk 800 G4; Zigbee: ZigStar (LAN), ~110Devices
                              Unifi, Motioneye/3Reolinks, PiHole, Bosch CS7800i via BBQKees/EMS-ESP, Fronius/BYD 11kWp via Modbus
                              Under construction: Smart-WoMo auf Raspi4
                              F 1 Antwort Letzte Antwort
                              • Pedder007P Pedder007
                                PS.
                                F
                                F
                                fastfoot
                                #173
                                @pedder007 sagte in js-controller 3.3 jetzt im STABLE!:
                                Backups sind nie!!! umsonst :-)
                                • C
                                  C
                                  chhe
                                  #174
                                  @apollon77 said in js-controller 3.3 jetzt im STABLE!:
                                  Windows
                                  Ausa der Community kommt von @sigi234 eine Anleitung für ein Windows Update Update_Windows_ioBroker.pdf
                                  die Anleitung ist ja sehr ausführlich und auch hilfreich. Wie soll mal mit dem Windows installer aber updaten wenn die letzte zur Verfügung stehende Version vom 23.11.2019 ist?
                                  https://www.iobroker.net/#de/download
                                  • C chhe
                                    Windows
                                    sigi234S
                                    sigi234S
                                    #175
                                    @chhe sagte in js-controller 3.3 jetzt im STABLE!:
                                    Windows
                                    Na darum ist die Anleitung ja da, bis es eine neue Version vom Installer gibt.
                                    C 1 Antwort Letzte Antwort
                                    • sigi234S sigi234
                                      Windows
                                      C
                                      C
                                      chhe
                                      #176
                                      @sigi234
                                      Die Anleitung gibt aber vor, eine Frische Installation mit dem Installer durchzuführen. Das erscheint mir aber ohne die neue Version des Installers nicht möglich.
                                      Mein Problem ist eigtl. folgendes:
                                      Die bei mir installierten Versionen sind mittlerweile veraltet.
                                      Node.js ist 10.17.0
                                      js-controller ist 3.2.16
                                      Admin ist 4.0.10
                                      Ich möchte nun updaten, da ich auch nun den ersten Adapter habe der mit der Adminversion nicht mehr kompatibel ist. Wie soll ich nun vorgehen?
                                      1. Backup machen
                                      2. iobroker stop
                                        npm i iobroker.js-controller@stable --ignore-scripts
                                        iobroker start
                                      3. js-controller updaten (wie in der verlinkten Anleitung beschrieben)
                                      4. Node.js updaten (wie in der verlinkten Anleitung beschrieben)
                                      Ich bin davon ausgegangen, dass ich mit dem Installer und der frischen Installation den Admin update. An welcher Stelle soll ich das nun machen?
                                      • C chhe
                                        @sigi234
                                        Node.js ist 10.17.0
                                        Admin ist 4.0.10
                                        1. Backup machen
                                        2. iobroker stop
                                          iobroker start
                                        sigi234S
                                        sigi234S
                                        #177
                                        Nein
                                        1.Schritt
                                        In der GUI die Updates machen - falls nötig
                                        Dabei (falls Update) den zuvor gesicherten data-Ordner durch den Installer
                                        einlesen.
                                        Migration kann Stunden dauern!
                                        Dann weiter mit Schritt 2+3
                                        • crunchipC
                                          crunchipC
                                          Developer Global Moderator Most Active Forum Testing
                                          #178
                                          @apollon77
                                          v3.3.15
                                          habe gerade meine Proxmox VM gestoppt und anschliessend neu gestartet, im log findet man zu sämtlichen Adaptern
                                          terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                                          des weiteren kam diese Meldung
                                          host.IoBroker
                                          	2021-08-19 21:43:41.306	error	Caught by controller[0]: at processTicksAndRejections (internal/process/task_queues.js:95:5)
                                          host.IoBroker
                                          	2021-08-19 21:43:41.306	error	Caught by controller[0]: at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:352:25)
                                          host.IoBroker
                                          	2021-08-19 21:43:41.305	error	Caught by controller[0]: at process.exit (internal/process/per_thread.js:169:15)
                                          host.IoBroker
                                          	2021-08-19 21:43:41.305	error	Caught by controller[0]: at processEmit [as emit] (/opt/iobroker/node_modules/signal-exit/index.js:149:35)
                                          host.IoBroker
                                          	2021-08-19 21:43:41.304	error	Caught by controller[0]: at process.emit (events.js:400:28)
                                          host.IoBroker
                                          	2021-08-19 21:43:41.304	error	Caught by controller[0]: at Object.onceWrapper (events.js:520:26)
                                          host.IoBroker
                                          	2021-08-19 21:43:41.303	error	Caught by controller[0]: at process.stop (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:8747:22)
                                          host.IoBroker
                                          	2021-08-19 21:43:41.303	error	Caught by controller[0]: at Adapter.emit (events.js:400:28)
                                          host.IoBroker
                                          	2021-08-19 21:43:41.302	error	Caught by controller[0]: at Adapter.unload (/opt/iobroker/node_modules/iobroker.chromecast/main.js:79:19)
                                          host.IoBroker
                                          	2021-08-19 21:43:41.300	error	Caught by controller[0]: TypeError: Cannot read property 'info' of undefined
                                          83.8k
