  4. Admin v5 jetzt im STABLE!
    6.4k
563 Beiträge 83 Kommentatoren 207.6k Aufrufe 70 Beobachtet
  • smarthomegirlS smarthomegirl
    @crunchip
    ja habe ich gemacht, startet erstmal, aber javaskript instanz bleibt rot, obwohl v5.2.8 installiert ist.
    Web Server würde ich jetzt nochmal updaten.
    Edit:
    Web Server installiert - auch wieder rot. Mache jetzt den Fix.
    Weboberfläche ist gestartet, aber javaskript und web bleiben rot.
    smarthomegirlS Offline
    smarthomegirl
    #245
    @smarthomegirl
    WARNUNGEN:
    host.Server-ioBroker-Master
    2021-08-12 13:51:20.437	error	startInstance system.adapter.web.0: required adapter "admin" has wrong version. Installed "4.2.2", required ">=5.1.0"!
    2021-08-12 13:49:41.090	error	startInstance system.adapter.javascript.0: required adapter "admin" has wrong version. Installed "4.2.2", required ">=5.1.9"!
    2021-08-12 13:49:17.200	error	startInstance system.adapter.web.0: required adapter "admin" has wrong version. Installed "4.2.2", required ">=5.1.0"!
    simple-api.0
    2021-08-12 13:49:00.295	error	Please specify the email address and domains to use Let's Encrypt certificates! We reuse old certificates
    fullybrowser.0
    2021-08-12 13:48:42.068	warn	updateDeviceERROR 192.168.178.122
    fullybrowser.0
    2021-08-12 13:48:40.933	warn	Generate State problem 192_168_178_122 {"message":"timeout of 2000ms exceeded","name":"Error","stack":"Error: timeout of 2000ms exceeded\n at createError (/opt/iobroker/node_modules/axios/lib/core/createError.js:16:15)\n at RedirectableRequest.handleRequestTimeout (/opt/iobroker/node_modules/axios/lib/adapters/http.js:280:16)\n at Object.onceWrapper (events.js:420:28)\n at RedirectableRequest.emit (events.js:314:20)\n at Timeout._onTimeout (/opt/iobroker/node_modules/axios/node_modules/follow-redirects/index.js:166:13)\n at listOnTimeout (internal/timers.js:554:17)\n at processTimers (internal/timers.js:497:7)","config":{"url":"http://192.168.178.122:2323/?cmd=deviceInfo&type=json&password=Aileen-30","method":"get","headers":{"Accept":"application/json, text/plain, */*","User-Agent":"axios/0.21.1"},"transformRequest":[null],"transformResponse":[null],"timeout":2000,"xsrfCookieName":"XSRF-TOKEN","xsrfHeaderName":"X-XSRF-TOKEN","maxContentLength":-1,"maxBodyLength":-1},"code":"ECONNABORTED"}
    👍 Ich danke Euch im Voraus. 👍
    smarthomegirlS 1 Antwort Letzte Antwort
      @smarthomegirl
      WARNUNGEN:
      simple-api.0
      fullybrowser.0
      fullybrowser.0
      smarthomegirl
      #246
      Log kann ich leider nicht senden, System meldet nur 10000 Zeichen.
      FEHLER:
      simple-api.0
      Thomas BraunT smarthomegirlS 2 Antworten Letzte Antwort
        FEHLER:
        simple-api.0
        #247
        @smarthomegirl
        Master/Slave-System?
        Reihenfolge beim Update beachtet?
        iobroker update
        iobroker upgrade
          FEHLER:
          simple-api.0
          smarthomegirl
          #248
          @smarthomegirl
          LOG nach Adapterneustart:
          2021-08-12 14:02:09.712 - info: enigma2.0 (7235) State value to set for "enigma2.0.enigma2.MESSAGE_ANSWER" has to be type "integer" but received type "string"
          2021-08-12 14:02:09.744 - info: enigma2.0 (7235) State value to set for "enigma2.0.enigma2.EVENTDURATION" has to be type "number" but received type "string"
          2021-08-12 14:02:09.749 - info: enigma2.0 (7235) State value to set for "enigma2.0.enigma2.EVENTREMAINING" has to be type "number" but received type "string"
          2021-08-12 14:02:14.715 - info: enigma2.0 (7235) State value to set for "enigma2.0.enigma2.MESSAGE_ANSWER" has to be type "integer" but received type "string"
          2021-08-12 14:02:14.751 - info: enigma2.0 (7235) State value to set for "enigma2.0.enigma2.EVENTDURATION" has to be type "number" but received type "string"
          2021-08-12 14:02:14.753 - info: enigma2.0 (7235) State value to set for "enigma2.0.enigma2.EVENTREMAINING" has to be type "number" but received type "string"
          2021-08-12 14:02:19.720 - info: enigma2.0 (7235) State value to set for "enigma2.0.enigma2.MESSAGE_ANSWER" has to be type "integer" but received type "string"
          2021-08-12 14:02:19.748 - info: enigma2.0 (7235) State value to set for "enigma2.0.enigma2.EVENTDURATION" has to be type "number" but received type "string"
          2021-08-12 14:02:19.749 - info: enigma2.0 (7235) State value to set for "enigma2.0.enigma2.EVENTREMAINING" has to be type "number" but received type "string"
          2021-08-12 14:02:24.815 - info: enigma2.0 (7235) State value to set for "enigma2.0.enigma2.MESSAGE_ANSWER" has to be type "integer" but received type "string"
          2021-08-12 14:02:24.846 - info: enigma2.0 (7235) State value to set for "enigma2.0.enigma2.EVENTDURATION" has to be type "number" but received type "string"
          2021-08-12 14:02:24.847 - info: enigma2.0 (7235) State value to set for "enigma2.0.enigma2.EVENTREMAINING" has to be type "number" but received type "string"
          2021-08-12 14:02:29.708 - info: enigma2.0 (7235) State value to set for "enigma2.0.enigma2.MESSAGE_ANSWER" has to be type "integer" but received type "string"
          2021-08-12 14:02:29.726 - info: enigma2.0 (7235) State value to set for "enigma2.0.enigma2.EVENTDURATION" has to be type "number" but received type "string"
          2021-08-12 14:02:29.727 - info: enigma2.0 (7235) State value to set for "enigma2.0.enigma2.EVENTREMAINING" has to be type "number" but received type "string"
          2021-08-12 14:02:31.928 - info: host.Server-ioBroker-Master "system.adapter.javascript.0" disabled
          2021-08-12 14:02:34.801 - info: enigma2.0 (7235) State value to set for "enigma2.0.enigma2.MESSAGE_ANSWER" has to be type "integer" but received type "string"
          2021-08-12 14:02:34.805 - info: host.Server-ioBroker-Master "system.adapter.javascript.0" enabled
          2021-08-12 14:02:34.814 - info: enigma2.0 (7235) State value to set for "enigma2.0.enigma2.EVENTDURATION" has to be type "number" but received type "string"
          2021-08-12 14:02:34.814 - info: enigma2.0 (7235) State value to set for "enigma2.0.enigma2.EVENTREMAINING" has to be type "number" but received type "string"
          2021-08-12 14:02:34.946 - error: host.Server-ioBroker-Master startInstance system.adapter.javascript.0: required adapter "admin" has wrong version. Installed "4.2.2", required ">=5.1.9"!
          2021-08-12 14:02:38.480 - info: host.Server-ioBroker-Master "system.adapter.web.0" disabled
          2021-08-12 14:02:39.655 - info: enigma2.0 (7235) State value to set for "enigma2.0.enigma2.MESSAGE_ANSWER" has to be type "integer" but received type "string"
          2021-08-12 14:02:39.678 - info: enigma2.0 (7235) State value to set for "enigma2.0.enigma2.EVENTDURATION" has to be type "number" but received type "string"
          2021-08-12 14:02:39.683 - info: enigma2.0 (7235) State value to set for "enigma2.0.enigma2.EVENTREMAINING" has to be type "number" but received type "string"
          2021-08-12 14:02:40.734 - info: host.Server-ioBroker-Master "system.adapter.web.0" enabled
          2021-08-12 14:02:40.838 - error: host.Server-ioBroker-Master startInstance system.adapter.web.0: required adapter "admin" has wrong version. Installed "4.2.2", required ">=5.1.0"!
          2021-08-12 14:02:44.718 - info: enigma2.0 (7235) State value to set for "enigma2.0.enigma2.MESSAGE_ANSWER" has to be type "integer" but received type "string"
          2021-08-12 14:02:44.733 - info: enigma2.0 (7235) State value to set for "enigma2.0.enigma2.EVENTDURATION" has to be type "number" but received type "string"
          2021-08-12 14:02:44.739 - info: enigma2.0 (7235) State value to set for "enigma2.0.enigma2.EVENTREMAINING" has to be type "number" but received type "string"
          2021-08-12 14:02:49.655 - info: enigma2.0 (7235) State value to set for "enigma2.0.enigma2.MESSAGE_ANSWER" has to be type "integer" but received type "string"
          2021-08-12 14:02:49.675 - info: enigma2.0 (7235) State value to set for "enigma2.0.enigma2.EVENTDURATION" has to be type "number" but received type "string"
          2021-08-12 14:02:49.677 - info: enigma2.0 (7235) State value to set for "enigma2.0.enigma2.EVENTREMAINING" has to be type "number" but received type "string"
          Mod-Edit: Code in </> Code-Tag gepackt!
            @smarthomegirl
            iobroker update
            iobroker upgrade
            smarthomegirl
            #249
            Ja, habe Multihost.
            Reihenfolge habe ich auch beachtet.
              Ja, habe Multihost.
              smarthomegirl
              #250
              @smarthomegirl
              Ich frage mich, wieso kommt die Fehlermeldung, dass admin v 4 installiert wäre, obwohl admin v5 installiert ist (siehe Foto)
                @smarthomegirl
                #251
                @smarthomegirl
                Das fragen sich mehrere Leute.
                Und warten auf die Antworten auf z. B.
                iobroker update
                iobroker upgrade
                iobroker upload all
                Jeweils auf dem Primären und Sekundären System.
                crunchipC smarthomegirlS 2 Antworten Letzte Antwort
                  @smarthomegirl
                  iobroker update
                  iobroker upgrade
                  iobroker upload all
                  crunchipC Offline
                  crunchipC Offline
                  #252
                  @thomas-braun vor allem war von Multihost nie die Rede
                  • bahnuhrB Online
                    bahnuhrB Online
                    bahnuhr
                    #253
                    Ich habe auch multihost und die Reihenfolge beachtet.
                    Also zuerst Master und dann slave.
                    Läuft so wie es sein soll.
                    Keine Probleme im log.
                    Danke.
                      @smarthomegirl
                      iobroker update
                      iobroker upgrade
                      iobroker upload all
                      smarthomegirl
                      #254
                      okay super, das hat funktioniert. Beide Adapter sind jetzt grün.
                        #255
                        @smarthomegirl sagte in Admin v5 jetzt im STABLE!:
                        was?
                        die Ausgaben der Befehle?
                        Warum zeigst du sie dann nicht?
                          was?
                          smarthomegirl
                          #256
                          Ja, das wars doch wieder.
                          Musste den raspberry neu starten und siehe da, die Weboberfläche ist nicht erreichbar. War ja fast zu erwarten. Fix hilft auch nicht.
                            #257
                            Natürlich!
                            wel alle Antworten nur stochern im Nebel sein können, bevor wir von dir keine belastbaren Fakten bekommen
                            • smarteuleS Offline
                              smarteuleS Offline
                              smarteule
                              #258
                              Ja, das Ganze kann ich nur bestätigen. Geht mir auch so.
                              Habe gerade einen theoretisch funktionierenden ioBroker mit admin -v 5.1.23 neu starten müssen (Stromausfall), komme auch nicht mehr auf die Weboberfläche.
                              • smarteuleS smarteule
                                #259
                                @smarteule sagte in Admin v5 jetzt im STABLE!:
                                (Stromausfall)
                                ...gähn...
                                  @ice987 sagte in Admin v5 jetzt im STABLE!:
                                  im Info-Adapter wurde dieser geprüft und je nach dem Farblich markiert:
                                  tut es doch noch immer
                                  ice987I Offline
                                  ice987I Offline
                                  ice987
                                  #260
                                  @crunchip sagte in Admin v5 jetzt im STABLE!:
                                  Im Info-Adapter ja; da dieser aber nicht mehr standartmässig installiert wird, bleibt „nur noch“ der Admin. Und da gibt‘s keine solche Prüfung.
                                  husqvarna-automower, meteoblue, wiserbyfeller, spritmonitor
                                  • I Offline
                                    I Offline
                                    IOBaer
                                    #261
                                    Ist das normal / gewollt, dass Min/Max-Werte nicht beachtet werden, d.h. dass Eingaben, die außerhalb der Vorgaben liegen, nicht abgelehnt werden?
                                      "common": {
                                        "name": "Lueftung_Hysterese",
                                        "desc": "Manuell erzeugt",
                                        "role": "state",
                                        "type": "number",
                                        "read": true,
                                        "write": true,
                                        "def": 1,
                                        "min": 0,
                                        "max": 3,
                                        "unit": "°C"
                                      "type": "state",
                                      "_id": "0_userdata.0.DP.HLK.AWP.Lueftung_Hysterese",
                                      "user": "system.user.admin",
                                      "ts": 1628786273409
                                    HomoranH apollon77A 2 Antworten Letzte Antwort
                                    • I IOBaer
                                        "common": {
                                          "role": "state",
                                          "type": "number",
                                          "read": true,
                                          "write": true,
                                          "def": 1,
                                          "min": 0,
                                          "max": 3,
                                          "unit": "°C"
                                        "type": "state",
                                        "ts": 1628786273409
                                      #262
                                      @iobaer sagte in Admin v5 jetzt im STABLE!:
                                      inwiefern "beachtet"?
                                      was genau passiert?
                                      nein, sie werden auf min oder max begrenzt
                                      I 1 Antwort Letzte Antwort
                                        was genau passiert?
                                        I Offline
                                        I Offline
                                        IOBaer
                                        schrieb am zuletzt editiert von IOBaer
                                        #263
                                        @homoran Ich kann in obigem Beispiel z.B. auch eine 7 eingeben und es erscheint keine Fehlermeldung - das meinte ich. Ich habe es testweise mit der alten Oberfläche versucht und da ist das Verhalten genauso. Habe ich da einen Fehler gemacht? In obigem Beispiel möchte ich, dass nur Ziffern zwischen 0 und 3 eingegeben werden können.
                                        Edit: unter der alten Admin-Oberfläche gab es ja noch eine Art Vorlage für solche Min-/Max-Werte. Ich habe dort mal einen neuen Datenpunkt angelegt und kann dort z.B. problemlos 70 eingeben, obwohl dies ja außerhalb des Wertebereichs liegt:
                                          "from": "system.adapter.admin.1",
                                          "ts": 1628788057222,
                                          "common": {
                                            "name": "test",
                                            "role": "",
                                            "type": "number",
                                            "unit": "%",
                                            "min": 0,
                                            "max": 50,
                                            "def": 0,
                                            "read": true,
                                            "write": true
                                          "native": {},
                                          "acl": {
                                            "object": 1638,
                                            "owner": "system.user.admin",
                                            "state": 1638
                                          "_id": "0_userdata.0.DP.HLK.AWP.test",
                                          "type": "state"
                                        Edit 2: Nur im Logfile steht:
                                        (82511) State value to set for "0_userdata.0.DP.HLK.AWP.test" has value "70" greater than max "50"
                                        • I IOBaer
                                            "common": {
                                              "name": "test",
                                              "role": "",
                                              "type": "number",
                                              "unit": "%",
                                              "min": 0,
                                              "max": 50,
                                              "def": 0,
                                              "read": true,
                                              "write": true
                                            "native": {},
                                            "acl": {
                                              "object": 1638,
                                              "state": 1638
                                            "type": "state"
                                          #264
                                          das Eingeben kannst du so nicht verhindern, aber in den Objects wird nur ein Wert innerhalb der range eingetragen.
                                          Natürlich! War ja schon immer so.
