  4. Test Adaper Tado v0.1.x
tadoadaptertesting team
868 Beiträge 62 Kommentatoren 316.3k Aufrufe 59 Beobachtet
  • H HGlab
    @andy_68
    The API only delivers these four:
    Andy_68
    #826
    @hglab said in Test Adaper Tado v0.1.x:
    Is that new?
    in the past there was a datapoint in the folder Rooms
    tado.0.xxxxxx.Rooms.3.openWindowDetected
    H 1 Antwort Letzte Antwort
    • A Andy_68
      Is that new?
      HGlab
      #827
      @andy_68
      I cannot tell you. I just looked at the API and there was no additional info
      • H HGlab
        @andy_68
        Andy_68
        #828
        @hglab
        thks. but allow me one question:
        in this adapter https://github.com/DrozmotiX/ioBroker.tado i found the following entry for V 0.1.3.
        0.1.3 Several fixes for reported error's
        (DutchmanNL) boilerId / onDemandLogRetrievalEnabled / openWindowDetected / onDemandLogRetrievalEnabled
        (DutchmanNL) Open Window detection implemented, only by device not by room
        Did the API change in the last weeks (it works until last week)
        • A Andy_68
          @hglab
          HGlab
          #829
          @andy_68
          I can only tell you what the API is currently providing. I am not monitoring the API and maybe in some cases the API delivers the state.
          I only can ensure that the API content is proper handled.
          • J Offline
            JohnnyBahama
            #830
            Hi, ich habe nach dem gesamt update auf Node 12.x den Adapter auch auf latest Version aktualisiert aufgrund der ganzen Meldungen. Leider kommen jetzt keine Werte/Geofencing mehr rein , außer Name und Id je mobilem Gerät. Gab es schonmal ein Feedback dazu?
            • J JohnnyBahama
              #831
              @johnnybahama Hier funktioniert Geofencing.
              V 0.3.0-4
                V 0.3.0-4
                JohnnyBahama
                schrieb am zuletzt editiert von JohnnyBahama
                #832
                @thomas-braun die Version ist installiert, trotzdem leer
                Hier auch der Log. Der schmeist auch keine Fehler aus.
                tado.0	2021-06-09 23:17:30.945	info	(2555) Initialisation finished, connected to Tado cloud service refreshing every 30 seconds
                tado.0	2021-06-09 23:17:20.641	info	(2555) Connected to Tado cloud, initialyzing ...
                tado.0	2021-06-09 23:17:19.952	info	(2555) Started with JSON-Explorer version 0.1.0
                tado.0	2021-06-09 23:17:19.886	info	(2555) starting. Version 0.3.0-4 in /opt/iobroker/node_modules/iobroker.tado, node: v12.22.1, js-controller: 3.3.12
                tado.0	2021-06-09 23:17:19.840	info	(2555) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
                Edit: Nur die mobile devices bekommen keine Werte/Geofencing rein. Die Hardware Thermostate DP zeigen alles an
                Edit2: Nach dem löschen der Objekte und Neustart des Adapters sind diese wieder zu sehen. Jetzt sehe ich momentan nur die Raumtemperatur pro Gerät nicht. Mal sehen, ob sich da noch was tut.
                • J JohnnyBahama
                  HGlab
                  #833
                  @johnnybahama
                  wenn das Raumthermostat OFF ist, schickt die Tado-App keine Temperatur, Dann wird auch kein Datenpubnkt angelegt
                  Die Aktualisierung von "Home" und "MobileDevices" findet ab 0.3.x stündlich statt um nicht unnötig viele Datenpinkte in kurzen Intervallen zu schreiben. Beim Neustart des Adapters werden die Datenpunkte natürlöich geschrieben bzw. aktualisiert.
                  C 1 Antwort Letzte Antwort
                  • H HGlab
                    @johnnybahama
                    cortana
                    schrieb am zuletzt editiert von cortana
                    #834
                    @hglab
                    entschuldige, dass ich so dazwischen platze.
                    Du schreibst, dass in V. 0.3.x die Aktualisierung der Devices nur noch stündlich geschieht.
                    Stehe ich grad auf dem Schlauch. Was genau bedeutet das für die Steuerung genau? Ich öffne das Fenster, der Sensor merkst das aber die Steuerung regelt erst, im ungünstigsten Fall, die Heizung nach eine Stunde herunter?
                    Oder habe ich da was falsch verstanden?
                    LG Jens
                    • C cortana
                      @hglab
                      LG Jens
                      HGlab
                      schrieb am zuletzt editiert von HGlab
                      #835
                      @cortana
                      Du hast das Wort MOBILE überlesen bei MobileDevices.
                      Soll heißen, das gilt nur für die Datenpunkte
                      tado.0.xxxxx.Mobile_Devices.*
                      Die Arbeitshypothese dahinter ist, dass man das Handy nicht mehrfach pro Stunde wechselt bzw. die Eigenschaften des Handys sich nicht ändern
                      Thomas BraunT C 2 Antworten Letzte Antwort
                      • H HGlab
                        @cortana
                        #836
                        @hglab Ich 'missbrauche' allerdings das geofence für Abwesenheitslogik. Das wäre doof wenn das mit bis zu einer Stunde Verzögerung die Anwesenheit meldet.
                        H C 2 Antworten Letzte Antwort
                          HGlab
                          #837
                          das hab ich mir schon gedacht und du bist wohl nicht der einzige. Da werde ich wohl diese Performance-Optimierung rausnehmen
                          • H HGlab
                            @cortana
                            cortana
                            #838
                            @hglab
                            lieben Dank für die Klärung. Hatte schon Schweißperlen auf der Stirn 😂
                            Nun aber noch einmal was zu der "geofence"Geschichte. Das dürfte für die Zukunft wohl so einige außer @Thomas-Braun interessieren.
                            Ich hatte hier Kontakt zum tado Techniker Team da diese einen Support zu meiner Konfig brauchten. Dabei hat sich herausgestellt, dass tado in der Planung hat, eine Abfragebegrenzung / Ratenbegrenzung einzuführen.
                            Das bedeutet, dass alle Abfragen über die Api nur alle 5 Minuten zugelassen werden bzw. darunter abgelehnt werden.
                            Insofern wird damit das geofencing über tado schon fast uninteressant.
                            Leider ist hier auch meine Fenster offen Erkennung von betroffen.
                            • C cortana
                              @hglab
                              TDCroPower
                              #839
                              @cortana oh das wäre wirklich ein Ko für den tado Adapter.
                              Dann brauchen wir dringend eine alternative Datenabfrage.
                              • T TDCroPower
                                cortana
                                #840
                                @tdcropower
                                die hatte ich bereits angefangen zu testen. Nennt sich "iogo".
                                Hier gibt es einen Adapter und eine App. Und hier scheint das geofencing tatsächlich relativ gut zu funktionieren.
                                Ist zwar auch eine Abo geschichte aber bezahlbar und wenn es gut läuft dann passt das
                                Kannst dir ja mal ansehen
                                ioGo
                                Thomas BraunT T 2 Antworten Letzte Antwort
                                • C cortana
                                  @tdcropower
                                  ioGo
                                  #841
                                  @cortana @HGlab
                                  In meinem konkreten Fall könnte ich mit 5 Minuten sogar leben.
                                  Hab nur als Logik drin: 'Wenn bei Sonnenuntergang zuhause, dann Lichter einschalten'
                                  Das dürfte auch mit 5 Minuten hinhauen. Eine Stunde wäre aber dann doch zu groß.
                                  • C cortana
                                    @tdcropower
                                    ioGo
                                    TDCroPower
                                    #842
                                    @cortana das geofancing von tado benötige ich im ioBroker nicht.
                                    Dafür habe ich den unifi Adapter der anhand meiner Wlan Clients meine Anwesenheit trakt.
                                      @cortana @HGlab
                                      cortana
                                      #843
                                      ja dann passt das ja.
                                      Ich denke notfalls könnte ich mit meiner Fenstersteuerung auch leben. im schlimmsten Fall heizt die Heizung eben 5 Minuten weiter bei offenem Fenster.
                                      @TDCroPower
                                      welche Abfrage ist denn für dich das Problem bei 5 Minuten?
                                      • C cortana
                                        @TDCroPower
                                        TDCroPower
                                        #844
                                        @cortana ebenfalls die Fenster Offen, wobei ich die eigentlich extern (Xiaomi Sensor) abgreife und nur die Thermostate dann auf off/on stelle.
                                        Aber auch hier könnte ich nur noch alle 5 Minuten einen Impuls senden… würde weiter funktionieren aber mit Einschränkungen, wenn mal mehrere Sachen parallel was abgreifen z.B. Fenster im Wohnzimmer und kurz danach Fenster im Schlafzimmer öffnen.
                                        Dazu noch den Offset Datenpunkt aber den checke/schreibe ich sowieso aktuell nur alle 30 Minuten, also alles gut.
                                        Aber vielleicht findet dadurch jemand eine Möglichkeit die Geräte in Zukunft doch lokal abzugreifen und nicht alles über die cloud zu schicken.
                                        Wäre mir persönlich sowieso lieber!
                                        • T TDCroPower
                                          cortana
                                          #845
                                          @tdcropower
                                          Ja das ist genau wie bei mir. Ich habe auch Aqara Sensoren für die Fenster offen Erkennung. Im Grunde wär das alles nicht wirklich dramatisch wenn tado endlich mal selbst Sensoren herstellen würde.
                                          So wie ich das verstehe, limitiert tado nur die Api und nicht ihr eigenes System.
