  4. Test Adapter pegelalarm v0.0.1-x
pegelalarmadapterhochwasserhochwasser adaptergewässerfluss
95 Beiträge 10 Kommentatoren 16.8k Aufrufe 9 Beobachtet
  • simatecS simatec
    @sigi234 @Negalein
    Stellt den Log mal bitte auch auf debug und beobachtet, ob alle Request richtig durchlaufen.
    Debug gibt da einige Infos raus.
    sigi234S Online
    sigi234S Online
    #86
    @simatec
    pegelalarm.0	2021-04-02 15:18:13.280	info	(2420) Terminated (NO_ERROR): Without reason
    pegelalarm.0	2021-04-02 15:18:13.277	debug	(2420) cleaned everything up...
    pegelalarm.0	2021-04-02 15:17:53.261	debug	(2420) Check for deleting old objects is started
    pegelalarm.0	2021-04-02 15:17:48.249	debug	(2420) Pegelalarm Request is completed
    pegelalarm.0	2021-04-02 15:17:48.249	debug	(2420) Pegelalarm request for measuring station 5 is finish ...
    pegelalarm.0	2021-04-02 15:17:48.249	debug	(2420) Pegelalarm request done
    pegelalarm.0	2021-04-02 15:17:48.135	debug	(2420) Pegelalarm API is available ... Status: 200
    pegelalarm.0	2021-04-02 15:17:48.031	debug	(2420) https://api.pegelalarm.at/api/station/1.0/list?countryCode=AT&qRegion=Ober%C3%B6sterreich&qWater=Krems&qStationName=Kematen%20An%20Der%20Krems
    pegelalarm.0	2021-04-02 15:17:48.031	debug	(2420) Pegelalarm request for measuring station 5 is started ...
    pegelalarm.0	2021-04-02 15:17:47.023	debug	(2420) Pegelalarm request for measuring station 4 is finish ...
    pegelalarm.0	2021-04-02 15:17:47.023	debug	(2420) Pegelalarm request done
    pegelalarm.0	2021-04-02 15:17:30.363	debug	(2420) Pegelalarm API is available ... Status: 200
    pegelalarm.0	2021-04-02 15:17:30.254	debug	(2420) https://api.pegelalarm.at/api/station/1.0/list?countryCode=AT&qRegion=Ober%C3%B6sterreich&qWater=Traun
    pegelalarm.0	2021-04-02 15:17:30.254	debug	(2420) Pegelalarm request for measuring station 4 is started ...
    pegelalarm.0	2021-04-02 15:17:29.244	debug	(2420) Pegelalarm request for measuring station 3 is finish ...
    pegelalarm.0	2021-04-02 15:17:29.244	debug	(2420) Pegelalarm request done
    pegelalarm.0	2021-04-02 15:17:18.896	debug	(2420) Pegelalarm API is available ... Status: 200
    pegelalarm.0	2021-04-02 15:17:18.781	debug	(2420) https://api.pegelalarm.at/api/station/1.0/list?countryCode=AT&qRegion=Ober%C3%B6sterreich&qWater=Steyr
    pegelalarm.0	2021-04-02 15:17:18.780	debug	(2420) Pegelalarm request for measuring station 3 is started ...
    pegelalarm.0	2021-04-02 15:17:17.774	debug	(2420) Pegelalarm request for measuring station 2 is finish ...
    pegelalarm.0	2021-04-02 15:17:17.774	debug	(2420) Pegelalarm request done
    pegelalarm.0	2021-04-02 15:17:05.406	debug	(2420) Pegelalarm API is available ... Status: 200
    pegelalarm.0	2021-04-02 15:17:05.283	debug	(2420) https://api.pegelalarm.at/api/station/1.0/list?countryCode=AT&qRegion=Ober%C3%B6sterreich&qWater=Donau
    pegelalarm.0	2021-04-02 15:17:05.282	debug	(2420) Pegelalarm request for measuring station 2 is started ...
    pegelalarm.0	2021-04-02 15:17:04.266	debug	(2420) Pegelalarm request for measuring station 1 is finish ...
    pegelalarm.0	2021-04-02 15:17:04.266	debug	(2420) Pegelalarm request done
    pegelalarm.0	2021-04-02 15:16:57.927	debug	(2420) Pegelalarm API is available ... Status: 200
    pegelalarm.0	2021-04-02 15:16:57.765	debug	(2420) https://api.pegelalarm.at/api/station/1.0/list?countryCode=AT&qRegion=Ober%C3%B6sterreich&qWater=Krems
    pegelalarm.0	2021-04-02 15:16:57.764	debug	(2420) Pegelalarm request for measuring station 1 is started ...
    pegelalarm.0	2021-04-02 15:16:57.757	info	(2420) starting. Version 1.1.4 in C:/Program Files/iobroker/Home/node_modules/iobroker.pegelalarm, node: v12.21.0, js-controller: 3.2.16
    • sigi234S sigi234
      @simatec
      simatecS Offline
      simatecS Offline
      simatec
      #87
      @sigi234 @Negalein
      Sieht gut aus ...
      @Negalein
      Ich würde die Instanzen etwas zeitversetzt fahren, damit es nicht zu eventuellen Request Fehlern kommt.
      • Besuche meine Github Seite
      • HowTo Restore ioBroker
      • simatecS simatec
        @sigi234 @Negalein
        Sieht gut aus ...
        @Negalein
        NegaleinN Offline
        NegaleinN Offline
        Negalein
        #88
        @simatec sagte in Test Adapter pegelalarm v0.0.1-x:
        mach ich bereits seit Anfang an :)
        ° Fixer ---> iob fix
        • sigi234S Online
          sigi234S Online
          #89
          Ich denke man brauch die API nicht alle 15 Min. abrufen, eigentlich nur wenn eine Warnung gibt. Was denk Ihr?
          simatecS NegaleinN 2 Antworten Letzte Antwort
          • sigi234S sigi234
            simatecS Offline
            simatecS Offline
            simatec
            #90
            @sigi234
            Ich denke auch, dass einmal die Stunde reichen sollte
            • sigi234S sigi234
              NegaleinN Offline
              NegaleinN Offline
              Negalein
              #91
              @sigi234 sagte in Test Adapter pegelalarm v0.0.1-x:
              Was denk Ihr?
              Ja, das würde sicher reichen.
              Cool wäre es, wenn der Adapter erkennt das eine Warnung da ist und dann selbsständig den Cron auf zB 15 Min. verändert. Wenn Warnung wieder weg, dann Cron wieder auf 60 Min.!
              Aber ob das vom Adapter möglich ist?
              • simatecS Offline
                simatecS Offline
                simatec
                #92
                Hier die Version 1.1.5 zum testen auf Github
                Github: https://github.com/simatec/ioBroker.pegelalarm.git
                Changelog
                1.1.5 (2021-04-07)
                • (simatec) fetch added
                • (simatec) sentry added
                LatziL NegaleinN 2 Antworten Letzte Antwort
                • simatecS simatec
                  Changelog
                  1.1.5 (2021-04-07)
                  LatziL Online
                  LatziL Online
                  Latzi
                  #93
                  @simatec
                  👍 läuft!
                  • simatecS simatec
                    Changelog
                    1.1.5 (2021-04-07)
                    NegaleinN Offline
                    NegaleinN Offline
                    Negalein
                    #94
                    • simatecS Offline
                      simatecS Offline
                      simatec
                      #95
                      So die Version 1.1.7 ist nun im latest ..
                      Hier gehts weiter ;-)
