  4. vis-inventwo v.2.x.x
inventwotestwidgetcss
443 Beiträge 63 Kommentatoren 150.6k Aufrufe 66 Beobachtet
  • BananaJoeB BananaJoe
    @holger-etzel sagte in vis-inventwo v.2.x.x:
    @bananajoe
    hallo, kannst du dein Widget für die Waschmaschine zur Verfügung stellen.
    Bin auch gerade am Rätseln um das Widget zu verstehen, komme da auch nicht richtig weiter.
    mfg
    Holger
    Moin,
    öhm, eigentlich kannst du es dir 1:1 aus der Schritt-für-Schritt-Anleitung nachbauen ...
    Trotzdem hier einmal als Widget Export:
    [{"tpl":"i-vis-multi","data":{"g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","iUniversalWidgetType":"State","iValueType":"boolean","iStateResponseTime":"0","iStateResetValueTime":"0","iNavWait":"94","iUniversalValueCount":"4","iValueComparison1":"equal","iButtonActiveM1":"#333333","iShadowColorActiveM1":"#111111","iShadowInnerColorActiveM1":"#111111","iBorderColorActiveM1":"#666666","iImgBlinkTrue1":"0","iImgColorTrue1":"#eeece1","iButtonCol":"#333333","iButtonColHover":"","iOpacityBack":"0.8","iCornerRadiusUL":"12","iCornerRadiusUR":"0","iCornerRadiusLR":"12","iCornerRadiusLL":"0","iContentFlexDirection":"vertical","iContentVertAlign":"iSpace-between","iContentOrder":"orderImgText","iOpacityCtn":"1","iTextColor":"#eeece1","iTextSize":"23","iTextAlign":"iCenter","iTextSpaceTop":"4","iTextSpaceBottom":"0","iTextSpaceLeft":"0","iTextSpaceRight":"0","iIconSize":"60","iImgAlign":"iCenter","iImgRotation":"0","iImgSpaceTop":"5","iImgSpaceBottom":"0","iImgSpaceLeft":"0","iImgSpaceRight":"0","iImgBlinkFalse":"0","iImgColorFalse":"#eeece1","iShadowXOffset":"4","iShadowYOffset":"4","iShadowBlur":"4","iShadowSpread":"1","iShadowColor":"#111111","iShadowInnerXOffset":"0","iShadowInnerYOffset":"0","iShadowInnerBlur":"0","iShadowInnerSpread":"0","iShadowInnerColor":"#111111","iBorderSize":"2","iBorderStyle":"outset","iBorderColor":"#666666","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"iValueComparison2":"equal","iButtonActiveM2":"#ffd233","iShadowColorActiveM2":"#111111","iShadowInnerColorActiveM2":"#111111","iBorderColorActiveM2":"#666666","iImgBlinkTrue2":"0","iImgColorTrue2":"#000000","iValueComparison3":"equal","iButtonActiveM3":"#92D050","iShadowColorActiveM3":"#111111","iShadowInnerColorActiveM3":"#111111","iBorderColorActiveM3":"#66AA66","iImgBlinkTrue3":"2000","iImgColorTrue3":"#000000","iValueComparison4":"equal","iButtonActiveM4":"#ff0000","iShadowColorActiveM4":"#111111","iShadowInnerColorActiveM4":"#111111","iBorderColorActiveM4":"#666666","iImgBlinkTrue4":"2000","iImgColorTrue4":"#ffd233","oid":"mqtt.0.zabbix.BlitzWolf168-Waschmaschine.waschmaschine","value":"","iTextFalse":"Waschm.<br>\nunbekannt","oid1":"mqtt.0.zabbix.BlitzWolf168-Waschmaschine.waschmaschine","iValue1":"0","iTextTrue1":"Waschm.<br>\naus","iImageTrue1":"/vis-icontwo/Devices/washer.png","iImageFalse":"/vis-icontwo/Devices/washer.png","oid2":"mqtt.0.zabbix.BlitzWolf168-Waschmaschine.waschmaschine","iValue2":"1","iTextTrue2":"Waschm.<br>\nStandby","iImageTrue2":"/vis-icontwo/Devices/washer.png","iImageTrue3":"/vis-icontwo/Devices/washer.png","iImageTrue4":"/vis-icontwo/Devices/washer.png","oid3":"mqtt.0.zabbix.BlitzWolf168-Waschmaschine.waschmaschine","iValue3":"2","iTextTrue3":"Waschm.<br>\nfertig!","oid4":"mqtt.0.zabbix.BlitzWolf168-Waschmaschine.waschmaschine","iValue4":"3","iTextTrue4":"Waschm.<br>\narbeitet","iPopUpBackground":"#666666","iPopUpPreventClickOutside":"","iPopUpShowTitle":"true","iPopUpTitle":"","iPopUpTitleColor":"#ffffff","iPopUpWidth":"800px","iPopUpHeight":"500px","iPopUpPosition":"center","iPopUpCornerRadiusUL":"12","iPopUpCornerRadiusUR":"0","iPopUpCornerRadiusLR":"12","iPopUpCornerRadiusLL":"0","iPopUpShadowXOffset":"2","iPopUpShadowYOffset":"2","iPopUpShadowBlur":"2","iPopUpShadowSpread":"1","iPopUpShadowColor":"#111111","iPopUpCloseBtnColor":"#dc2e2e"},"style":{"left":"579px","top":"359px","font-family":"Verdana, Geneva, sans-serif","text-shadow":"2px 2px 0 #000000, 2px -2px 0 #000000, -2px 2px 0 #000000, -2px -2px 0 #000000, 2px 0px 0 #000000, 0px 2px 0 #000000, -2px 0px 0 #000000, 0px -2px 0 #000000, 2px 2px 4px #000000","width":"150px","height":"150px","z-index":"57"},"widgetSet":"vis-inventwo"}]
    Ich habe extra eine normale Schriftart eingestellt. Für das Icon muss der Adapter inventwo Icon Set installiert sein.
    Die 5 eingestellten (ist immer der gleiche) Datenpunkte stimmen natürlich nicht, da musst du deine eigenen einsetzen.
    Holger EtzelH Offline
    Holger Etzel
    #233
    @bananajoe
    danke, werde es gleich mal analysieren.
    • L legro
      Hier einmal eine Zusammenfassung meiner Erkenntnisse hinsichtlich der MultiWidgets ..
      • Ein MultiWidget funktioniert zunächst einmal genau so wie auch ein normales UnversalWidget.
      • Besitzt das UniversalWidget je einen Datensatz an Einstellungen für die Werte bei falsch und bei wahr, so kommt das MultiWidget gleich mit beliebig vielen möglichen Datensätzen (hier Zustände genannt) bei den Einstellungen für bei wahr daher.
      • Werte schreiben können diese Widgets nur in den ersten Datenpunkt. Das geschieht ganz so, wie auch beim normalen UnversalWidget (siehe state, switch)
      • Der wesentliche Unterschied besteht darin, dass es für die Werte bei wahr mehrere sog. Zustände geben kann, die das Aussehen des Widgets bestimmen. Einen Zustand explizit für wahr gibt es nicht mehr.
      • Die Datenpunkte, welche den Zuständen zugeordnet werden, können nur gelesen und zur Anzeige/Darstellung des Widgets ausgewertet werden.
      Eigentlich ganz einfach, wenn man's mal verstanden hat.🙂
      In dieser Abbildung wird ein MultiWidget zur Steuerung einer dimmbaren LED genutzt. Der erste Datenpunkt schaltet die LED unter Verwendung von true/false ein oder aus.
      Der hier einzige Zustand [0] verwendet den Datenpunkt des Helligkeitsreglers. Wenn dieser einen Wert größer 0 besitzt, wird das Widget als aktiviert dargestellt.
      BananaJoeB Offline
      BananaJoeB Offline
      BananaJoe
      #234
      @legro sagte in vis-inventwo v.2.x.x:
      Stimmt, in meinem Beispiel welches den Multiswitch nur für eine Darstellung nutzt könnte man den Eintrag bei Objekt ID ganz weglassen (aber bei den Zuständen muss er gesetzt sein)
      L 1 Antwort Letzte Antwort
        legro
        schrieb am zuletzt editiert von legro
        #235
        @bananajoe said in vis-inventwo v.2.x.x:
        Stimmt, ..
        Schade, dass @jkvarel und @skvarel die Anleitungen (WIKI) nicht so gut pflegen wie ihre hervorragenden Widgets. Neben der großen Zeitersparnis bei den Anwendern würde sich die Akzeptanz dieses tollen Projektes gewiss mit einer ausführlichen Dokumentation ganz wesentlich steigern.
        Nun gehe ich bei meinen Arbeiten bei der Erstellung einer Visualisierung grundsätzlich nach folgendem Prinzip vor: Zuerst werden die Widget-Vorlagen erstellt, dann erstelle ich aus diesen die Views.
        Wenn ich meinen Basis-Satz an Widgets (DimmerWidget, RollladenWidget, GaragentorWidget, ..) erstellt habe, werde ich dazu einmal eine Dokumentation hier einstellen.
        Raspberry Pi 5 mit 8GB + 120GB SSD + Coordinator COD-m + ioBroker ..
        • skvarelS Online
          skvarelS Online
          skvarel
          #236
          @legro .. ja, ich weiss :( Ich hänge mit der WIKI hinterher. Im Moment habe ich einfach zu viel um die Ohren.
          Der Widget Adapter ist @jkvarel sein Ding, ich kümmere mich um den Icon Adapter und um die WIKI. Ich habe nun ein paar Tage Urlaub und hoffe, ich kann wieder etwas aufholen.
          #TeamInventwo
          Unsere Adapter:
            @legro
            Also das Color Slider Widget kann 3 Dinge:
            Ich nutze HEX wo dann die Schreibweise
            #AABBCC
            erwartet wird, also mit dem # davor. Da ich mich per Skript selbst um die Übersetzung zwischen Tasmota und VIS kümmere habe ich mir einen Datenpunkt ohne (Color) und einen mit # (Color2) gebaut.
            Ich habe da heute nach drüber gegrübelt wie ich das per Skript lösen kann.
            Der Color Slide - so meine laienhafte Vermutung - arbeitet dem Hue Prinzip in welchem die Farbe zwischen 0 und 359 angegeben wird:
            Also müsste ich die Farbe als HUE Wert zur Verfügung stellen und auswerten.
            Der Color Slider kann ansonsten ja noch RGB - wo ich unterstellt habe das er die RGB Werte dann schlicht als 3 Einzelwerte haben will und bei CIE als 2 Zahlen mit Komma getrennt, 0.15,0.27 zum Beispiel
            Mal schauen wie man das alles umrechnen kann
            P Online
            P Online
            pd_mueller
            #237
            @bananajoe Hey, die Auswahl des Farbmodells ist genau das was ich suche, um das LIDL LED-Band anzusteuern. Da ich die Testversion nicht verwenden möchte: Weisst du, wann die Funktion in die Release-Version kommt? Wenn es nicht mehr so lange dauert, kann ich mir die Arbeit sparen, das mühselig selber über zu bauen ...
            • P pd_mueller
              BananaJoeB Offline
              BananaJoeB Offline
              BananaJoe
              #238
              @pd_mueller sagte in vis-inventwo v.2.x.x:
              Öhm, Bahnhof? Mein Post zur Beta ging um die Popup-Funktion. Farbmodell? Ich habe mir das ein Skript zu gebaut, passend zu meinen Tasmota-LED-Streifen per MQTT. Das bietet nun Datenpunkte die zu den Reglern passen bzw. zum Beispiel einen der immer die Farbe, aber mit voller Helligkeit anzeigt.
              • skvarelS skvarel
                legro
                #239
                @skvarel said in vis-inventwo v.2.x.x:
                @legro .. ja, ich weiss :( Ich hänge mit der WIKI hinterher. ..
                Nachdem ich endlich die Sache mit den MultiWidgets verstanden habe, geht‘s mit meiner Visualisierung richtig gut voran.🙂 Oben habe ich einmal eine Kurzfassung zu den Eigenschaften und deren Verwendung des MultiWidget zusammengetragen. Solche oder ähnliche Beschreibungen solltest du unbedingt in die Beschreibung aufnehmen, damit wir schneller mit euren tollen Widget umzugehen vermögen.
                • L legro
                  legro
                  #240
                  @skvarel
                  In diesem Thread habe ich zwei Widgets für einen Dimmer und eine Garagentor aus euren Widgets erstellt. In eurem WIKI wären solche Anwendungen zur Erläuterung gewiss hilfreich.
                  • L legro
                    @skvarel
                    legro
                    #241
                    @skvarel
                    Mittlerweile bin ich mir nach all den vielen Tests (recht) sicher: Die Widgets funktionieren im iPad und iPhone sehr unzuverlässig.🙁
                    Wie in der Abbildung zu sehen, bewirkt ein Klick auf ein Widget (hier: Beleuchtung) oft nur, dass die Darstellung für Hover aktiviert wird; die eigentliche Aktion - das Ein-/Ausschalten - wird nicht ausgelöst.
                    Führe ich diese Aktionen parallel auf dem MacBook durch, so funktionieren die Widgets tadellos. Auch Überprüfungen unter Verwendung anderer (z.B. von HQ, jqui, ..) Widgets zeigen kein solches Fehlverhalten.
                    Ergänzungen ..
                    Mein Eindruck ist, dass diese Ausfälle sich mit dem stetigen Ausbau unserer Visualisierung beständig steigerten.
                    • BananaJoeB Offline
                      BananaJoeB Offline
                      BananaJoe
                      #242
                      @skvarel Wenn ich auf Version 2.9.0 Update aktualisieren sich meine Switch Schalter nicht mehr.
                      Also Zustand des True/False Datenpunktes wird zwar umgeschaltet, er aktualisiert es aber nicht in der VIS.
                      Meine View-Schalter funktionieren normal weiter.
                      Zurück auf 2.8.3 und Neustart ioBroker und es geht wieder.
                      Noch jemand das Problem?
                      Hab noch mal Korrigiert: 2.9.0, nicht 2.9.1
                      BananaJoeB L 2 Antworten Letzte Antwort
                        BananaJoeB Offline
                        BananaJoeB Offline
                        BananaJoe
                        #243
                        @bananajoe sagte in vis-inventwo v.2.x.x:
                        @jkvarel hat gerade auf GitHub auf meinen Issue geantwortet, der Fehler soll in der 2.9.1 behoben sein.
                          legro
                          #244
                          Deine hier geschilderten Erfahrungen deuten ebenfalls daraufhin, dass irgendetwas mit Widgets im Argen liegen mag. Auch bei uns lösen die Widgets mal aus, mal aber auch wieder nicht, dabei bleibt die Darstellung der Widgets auf „Hover“.
                          • L legro
                            legro
                            #245
                            Irgendwie kann ich mir einfach keinen Reim darauf machen, wie diese Art Widget funktioniert.
                            Meine Versuche, als Datenpunkt etwa einen HTML-Text einzufügen, der eine Wetteranzeige erzeugt, scheiterten kläglich.
                            Kann bitte jemand Licht ins Dunkel bringen?
                            L skvarelS 2 Antworten Letzte Antwort
                            • L legro
                              legro
                              #246
                              @legro said in vis-inventwo v.2.x.x:
                              Dann muss ich das offenbar selbst tun.😞
                              Für genauso unwissende Leute wie unsereiner hier die Lösung:
                              Die Option View in PopUp vermag eine View, die im Feld View zum Navigieren eingetragen ist, als Popup-Fenster aufzurufen.
                              Der Sinn der übrigen Datenpunkte vermag ich mir leider noch immer nicht zu erschließen. Da kann ich nur vermuten und wünschen: Je nach Wert in den referenzierten Datenpunkte könnte eine andere View angezeigt werden.
                              • L legro
                                skvarelS Online
                                skvarelS Online
                                skvarel
                                #247
                                @legro .. was hast Du genau vor?
                                Die Widgets können in der Beschreibung HTML und Bindings. Wenn mit den Widgest nichst geprüft wird, dann den Text immer unter 'Beschriftung falsch' eintragen.
                                Hast Du mal einen Screenshot von den Einstellungen mit dem HTML?
                                #TeamInventwo
                                Unsere Adapter:
                                skvarelS L 2 Antworten Letzte Antwort
                                • skvarelS skvarel
                                  skvarelS Online
                                  skvarelS Online
                                  skvarel
                                  schrieb am zuletzt editiert von skvarel
                                  #248
                                  Beispiel:
                                  #TeamInventwo
                                  Unsere Adapter:
                                  skvarelS 1 Antwort Letzte Antwort
                                  • skvarelS skvarel
                                    Beispiel:
                                    skvarelS Online
                                    skvarelS Online
                                    skvarel
                                    #249
                                    .. oder:
                                    #TeamInventwo
                                    Unsere Adapter:
                                    T TG70T 2 Antworten Letzte Antwort
                                    • skvarelS skvarel
                                      legro
                                      #250
                                      Was ich damit vorhabe, kann ich erst beschreiben, wenn ich weiß, was ich damit anfangen kann.😊
                                      Mit deinen Erläuterungen, so denke ich, komme ich ein gutes Stück voran, mir das Ganze zunutze zu machen.
                                      Vielen Dank.
                                      Derzeit bearbeite ich gleich zwei Baustellen: Ich arbeite mich in die Programmierung mit JacaScript ein und versuche mich daran, in einem nunmehr schon dritten Anlauf, eine mich zufriedenstellende Visualisierung auf die Beine zu stellen.😥 😵
                                      Bei meiner Visualisierung setze ich voll und ganz auf eure Widgets.👍 🙂
                                      • L legro
                                        Vielen Dank.
                                        sigi234S Online
                                        sigi234S Online
                                        #251
                                        Ich auch, Projekt ist bald fertig. (fertig ist eine Vis eigentlich nie)
                                        Screenshot (3628).png Screenshot (3627).png Screenshot (3626).png Screenshot (3625).png Screenshot (3624).png Screenshot (3623).png Screenshot (3622).pngScreenshot (3658).png
                                        L NashraN 3 Antworten Letzte Antwort
                                        • sigi234S sigi234
                                          legro
                                          #252
                                          @sigi234 said in vis-inventwo v.2.x.x:
                                          .. Ich auch, Projekt ist bald fertig. (fertig ist eine Vis eigentlich nie) ..
                                          .. wie wahr! .. 🙂
                                          Meine erste Visualisierung war eine kunterbunte Mischung aus allen möglichen Quellen. Da mir dies alles zu bunt wurde - und vor allem meinen Lieben, die sich von wegen alles wird einfacher, veräppelt fühlten - habe ich uns in einer zweiten Phase richtig verAPPLEt: Alle alltäglichen Dinge habe ich mittels YAHKA im HomeKit von Apple verfügbar gemacht. Damit kann unsere über 90-igjährige (Ur)Oma sogar in Teilen umgehen.🤗
                                          Als ich dann auf das Inventwo-Projekt stieß, war der Entschluss schnell gefasst: Eine dritte Visualisierung muss her!🙂 Endlich die Möglichkeit eine harmonische, schön anzusehende, in sich geschlossene Visualisierung.
