  4. Zwave 0.4
    apollon77A
Zwave 0.4
142 Beiträge 16 Kommentatoren 35.5k Aufrufe
  • AlCalzoneA
    AlCalzoneA
    AlCalzone
    #105
    Du willst also die zwave-Geräte, die mit Raspi A ("Gateway") verbunden sind, in den zwave-Adapter von Raspi B einbinden?
    • BluefoxB
      #106
      @Patrick:
      @Bluefox:
      @Patrick: `
      npm cache clean
      npm install node-gyp -g --force
      Und das alles als Admin. `
      habe jetzt noch mal das alte Backup aufgespielt und alles wie beschrieben gemacht
      jetzt kommt ein anderes Fehler
      ! C:\Users\rickfl>cd "C:\Program Files\IO BROKER\ioBroker"
      ! C:\Program Files\IO BROKER\ioBroker>npm install https://github.com/ioBroker/ioBroker.zw … all/master --production --unsafe-perm --build-from-source
      ! > iobroker.zwave@0.4.3 preinstall C:\Program Files\IO BROKER\ioBroker\node_modules\iobroker.zwave
      ! > node lib/preinstall.js
      ! > openzwave-shared@1.2.0 preinstall C:\Program Files\IO BROKER\ioBroker\node_modules\iobroker.zwave\node_modules\openzwave-shared
      ! > node lib/install-ozw.js
      ! Installing Open Z-Wave
      ! Installing dependencies to C:\Users\rickfl\AppData\Local\Temp\ozwinstall-yeew830izfr
      ! npm WARN deprecated wrench@1.5.9: wrench.js is deprecated! You should check out fs-extra (https://github.com/jprichardson/node-fs-extra) for any operations you were using wrench for. Thanks for all the usage over the years.
      ! module.js:327
      ! throw err;
      ! Error: Cannot find module 'C:\Users\rickfl\AppData\Local\Temp\ozwinstall-yeew830izfr/node_modules/request'
      ! at Function.Module._resolveFilename (module.js:325:15)
      ! at Function.Module._load (module.js:276:25)
      ! at Module.require (module.js:353:17)
      ! at require (internal/module.js:12:17)
      ! at Module.module.exports (C:\Program Files\IO BROKER\ioBroker\node_modules\iobroker.zwave\node_modules\openzwave-shared\lib\install-ozw.js:165:13)
      ! at Object. <anonymous>(C:\Program Files\IO BROKER\ioBroker\node_modules\iobroker.zwave\node_modules\openzwave-shared\lib\install-ozw.js:220:12)
      ! at Module._compile (module.js:409:26)
      ! at Object.Module._extensions..js (module.js:416:10)
      ! at Module.load (module.js:343:32)
      ! at Function.Module._load (module.js:300:12)
      ! npm ERR! Windows_NT 10.0.10586
      ! npm ERR! argv "C:\Program Files\nodejs\node.exe" "C:\Program Files\nodejs\node_modules\npm\bin\npm-cli.js" "install" "https://github.com/ioBroker/ioBroker.zw ... all/master" "--production" "--unsafe-perm" "--build-from-source"
      ! npm ERR! node v4.6.1
      ! npm ERR! npm v2.15.9
      ! npm ERR! code ELIFECYCLE
      ! npm ERR! openzwave-shared@1.2.0 preinstall: node lib/install-ozw.js
      ! npm ERR! Exit status 1
      ! npm ERR!
      ! npm ERR! Failed at the openzwave-shared@1.2.0 preinstall script 'node lib/install-ozw.js'.
      ! npm ERR! This is most likely a problem with the openzwave-shared package,
      ! npm ERR! not with npm itself.
      ! npm ERR! Tell the author that this fails on your system:
      ! npm ERR! node lib/install-ozw.js
      ! npm ERR! You can get information on how to open an issue for this project with:
      ! npm ERR! npm bugs openzwave-shared
      ! npm ERR! Or if that isn't available, you can get their info via:
      ! npm ERR!
      ! npm ERR! npm owner ls openzwave-shared
      ! npm ERR! There is likely additional logging output above.
      ! npm ERR! Please include the following file with any support request:
      ! npm ERR! C:\Program Files\IO BROKER\ioBroker\npm-debug.log
      ! C:\Program Files\IO BROKER\ioBroker></anonymous> `
      Also es gibt tatsächlich das Problem mit Windows.
      Die Leute arbeiten dran, aber es gibt immer noch keine Lösung:
      https://github.com/felixrieseberg/windo … s/issues/9
      Workaround: Install Visual C++ projects support to Visual Studio 2015 (requires 3GB space).(C++ option aktivieren)
      • PatrickP
        PatrickP
        Patrick
        #107
        @Bluefox:
        @Patrick:
        @Bluefox:
        npm cache clean
        ! module.js:327
        ! throw err;
        ! npm ERR!
        ! npm ERR!
        Workaround: Install Visual C++ projects support to Visual Studio 2015 (requires 3GB space).(C++ option aktivieren) `
        dann warte ich mal ab
        • BluefoxB
          #108
          Wie ist die Lage?
          Läuft zWave?
          Ist zWave Funktionalität vergleichbar mit Domoticz/OpenHAB?
          Ist zWave Stabil?
          • Lenny.CBL
            Lenny.CBL
            Lenny.CB
            #109
            @Bluefox:
            Wie ist die Lage?
            Läuft zWave?
            Ist zWave Stabil? `
            bei mir is es soweit stabil.
            Hin und wieder wird ein Status nicht aktualisiert wenn ich Rollos per Hand am Schalter bewege.
            Cool wäre noch wenn man im Admin Namen vergeben könnte. Zumindest geht das bei mir nicht.
            Sonst, sehr gute Arbeit!
            • BluefoxB
              #110
              @Lenny.CB:
              @Bluefox:
              Wie ist die Lage?
              Läuft zWave?
              Ist zWave Stabil? `
              Sonst, sehr gute Arbeit! `
              Die Idee ist, dass du Objekt Lasche dafür benutztst. Da kann man sehr schnell die Namen setzen.
              • Lenny.CBL
                Lenny.CBL
                Lenny.CB
                #111
                @Bluefox:
                Die Idee ist, dass du Objekt Lasche dafür benutztst. Da kann man sehr schnell die Namen setzen. `
                ja so mache ich das auch. Hätte nur gedacht, das es in der Admin-Maske übersichtlicher wird.
                  #112
                  @Bluefox:
                  Wie ist die Lage?
                  Läuft zWave?
                  Ist zWave Stabil? `
                  Bei mir stabil. Kann auch die Konfig-Parameter setzen.
                  Habe allerdings nur zwei Geräte
                  • FIBARO System FGMS001 Motion Sensor
                  • FIBARO System FGWPE Wall Plug
                  Der Wall Plug misst auch den Verbrauch, geht alles.
                  Prima Arbeit.
                  P.S. Nix gegen die Jungs aus Leer, aber wenn man mal das Design des FIBARO Wall Plug mit dem des Funk-Schaltaktor 1fach mit Leistungsmessung, Zwischenstecker für Smart Home / Hausautomation vergleicht, dann ist bei eq3 noch gewaltig Luft nach oben.
                  • AlCalzoneA
                    AlCalzoneA
                    AlCalzone
                    #113
                    Kleines Update von meiner Seite. Habe jetzt dieses Gerät zum Testen: http://www.devolo.de/article/devolo-hom … hermostat/
                    Das funktioniert:
                    • Thermostat SetPoint
                    • Temperaturmessung
                    • Datum/Uhrzeit einstellen
                    • Batteriestatus auslesen
                    Das nicht:
                    • WakeUp-Intervalle
                    • Bediensperre (Protection)
                    • Lenny.CBL
                      Lenny.CBL
                      Lenny.CB
                      #114
                      hallo zusammen,
                      habe heut wieder etwas zum Testen bekommen. Diesmal ein "Power Plug" von "NEO Coolcam"
                      http://www.szneo.com/en/products/index.php?id=41
                      Spezifikationen: 983_smart-plug_user_guide_v2.pdf Ein paar Sachen gehen, ein paar nicht.
                      Was geht:
                      • Schalten
                      • Anzeige der Spannung
                      Was geht nicht:
                      • Anzeige: Strom (A), Energie (kWh), Power (W)
                      • Schalten über Timer
                      Ich vermute, dass in der config-Datei was fehlt:
                      config/shenzen_neo/ –> nas-wr01z.xml
                      Beim Inkludieren wird Folgendes unter CONFIGURATION angelegt:
                      zwave.0.NODE12.CONFIGURATION.Button_On/Off
                      zwave.0.NODE12.CONFIGURATION.Configure_Plug_Time_switch_Function
                      zwave.0.NODE12.CONFIGURATION.Configure_maximum_over-load_current
                      zwave.0.NODE12.CONFIGURATION.Led_Display
                      zwave.0.NODE12.CONFIGURATION.Meter_Report_Interval
                      zwave.0.NODE12.CONFIGURATION.Remember_Relay_ON/OFF_status
                      zwave.0.NODE12.CONFIGURATION.Send_Meter_Report
                      lt. Gerätespezifikation sollte es aber so ausschauen:
                      zwave.0.NODE12.CONFIGURATION.Button_On/Off_Enable
                      zwave.0.NODE12.CONFIGURATION.Configure_Time_switch_Period			(-->NEU)
                      zwave.0.NODE12.CONFIGURATION.Configure_maximum_Alarm_current		(-->NEU)
                      zwave.0.NODE12.CONFIGURATION.Led_Display_Enable
                      zwave.0.NODE12.CONFIGURATION.Configure_report_by_Current_Changed	(-->NEU)
                      zwave.0.NODE12.CONFIGURATION.Send_Meter_Report_Enable
                      Configure_report_by_Current_Changed Diese Einstellung gibt es bei meinem AEOTEC-Energy-Meter… """reporte wenn Wert um einen pestimmten Prozentsatz vom Vorwert abweicht""".
                      m.E. wenn der Wert nicht da ist bringt der Wall-Plug auch keine W- und kWh-Werte.
                      Zumindest meine ich die Sache so verstanden zu haben.
                      Kann ich einfach in der Datei config/shenzen_neo/nas-wr01z.xml ohne Weiteres "rumpfuschen" oder muss das dann immer, wie bei einer Neuinstallation, neu kompiliert werden?
                        #115
                        @Lenny.CB:
                        hallo zusammen,
                        Spezifikationen: filename="Smart-Plug User Guide V2.pdf" index="0">~~Ein paar Sachen gehen, ein paar nicht.
                        Was geht:
                        • Schalten
                        Was geht nicht:
                        Kann ich einfach in der Datei config/shenzen_neo/nas-wr01z.xml ohne Weiteres "rumpfuschen" oder muss das dann immer, wie bei einer Neuinstallation, neu kompiliert werden? `
                        Du kannst ändern, wenn es danach funktioniert, würde ich einen Change Request in git machen. Ich hatte einen für Fibaro multisensor gemacht. War im nächsten Release drin.
                        Ansonsten wird deine lokale bei jedem Update überschrieben.
                        Gesendet von meinem ONEPLUS A3003 mit Tapatalk
                        • Lenny.CBL
                          Lenny.CBL
                          Lenny.CB
                          #116
                          @OstfrieseUnterwegs:
                          Ansonsten wird deine lokale bei jedem Update überschrieben. ` muss, nachdem die Datei geändert ist, make und make install im Ordner open-zwave-master gemacht werden?
                            #117
                            @Lenny.CB:
                            muss, nachdem die Datei geändert ist, make und make install im Ordner open-zwave-master gemacht werden? `
                            Nein, aber möglicherweise muss das Gerät neu angelernt werden.
                            • T
                              T
                              TomF
                              #118
                              Hallo zusammen, bin hier ziemlich neu, und auch im Bereich Hausautomation recht neu.
                              Habe ein Rademacher Homepilot im Einsatz und spiele mit einem Rasberry Pi und dem Razberry Modul mit ein paar Fibaro Kompenenten rum…
                              Bin auf der Suche nach etwas übergeordnetem auf ioBroker gestoßen und das hat mir auf Anhieb gefallen.
                              Habe dann direkt ein neues Image mit ioBroker für den Rasberry erzeugt.
                              Meine Frage nun:
                              Muss ich für den Ansatz ioBroker zWaveAdapter und Razberry Modul vorab irgendwas installieren, oder bringt ioBroker Adater alles mit?
                              In der Doku steht irgendwas von Zitat:
                              First of all, Implementation is tested only on ARM Linux (e.g. Raspberry Pi (2)). You need a fully Development Environment (gcc, make,...)
                              On some systems the additional package is required:
                              apt-get install pkg-config libudev-dev build-essential curl unzip
                              das sagt mir so recht nichts,
                              also gibt es irgendwo noch eine step by step Anleitung, oder kann mir jemand in kurzen Worten erkläten was ich zu tuen habe...
                              Danke im Voraus
                              Tom
                                #119
                                @TomF:
                                Meine Frage nun:
                                Danke im Voraus
                                Tom `
                                Normalerweise braucht man keine Entwicklungsumgebung für ioBroker. Der zwave Adapter ist eine Ausnahme. Er benutzt 'fremde' npm Pakete und die müssen jeweils auf dem Zielgerät (also hier der ioBroker Server) übersetzt werden.
                                Du musst dich dazu auf dem Raspberry anmelden (idealerweise als root user) und dann den Befehl:
                                ````eingeben. Wenn du nicht root bist, dann musst du
                                sudo apt-get install pkg-config libudev-dev build-essential curl unzip
                                Den Rest macht der Installer des zwave Adapters für Dich. Den kannst du normal über das Admin Interface anstoßen. Nicht nervös werden, der braucht sehr lange! 25 Minuten sind da nix, eher mehr.
                                EDIT: das muss __sudo__ statt __su__ sein
                                • T
                                  T
                                  TomF
                                  #120
                                  habe nun Z wave deinstalliert, adnn die Treiber installiert, dann Z Wave neu installiert.
                                  der Logger sagt nun er kann ZWave nicht Starten…
                                  zwave.0	2017-01-22 15:15:02.652	error	failed to start driver
                                  zwave.0	2017-01-22 15:15:02.643	info	connected: homeid = 1.4.0
                                  zwave.0	2017-01-22 15:15:02.450	info	starting. Version 0.4.4 in /opt/iobroker/node_modules/iobroker.zwave, node: v4.7.2
                                  zwave.0	2017-01-22 15:08:37.789	error	failed to start driver
                                  zwave.0	2017-01-22 15:08:37.781	info	connected: homeid = 1.4.0
                                  zwave.0	2017-01-22 15:08:37.696	info	starting. Version 0.4.4 in /opt/iobroker/node_modules/iobroker.zwave, node: v4.7.2
                                  Hat jemand noch eine Idee?
                                  Tom
                                  geändert: Code in Code-Tags; Homoran (Mod)
                                  • T
                                    T
                                    TomF
                                    #121
                                    open Z wave will bei mir immer noch nicht laufen :x
                                    Habe nun die 0.5er Version installiert und bekomme immer noch die Meldung:
                                    Die Frage an die Experten, ich benutze eine Raspberry 3 mit dem neuen Razberry Modul, kann das der Grund sein?
                                    bzw. wo kann ich noch suchen um den Fehler weiter einzukreisen?
                                    Danke Tom
                                      #122
                                      @TomF:
                                      Danke Tom `
                                      Ich habe einen Pi 1 und einen ZME USB Stick.
                                      Mal nachgeschaut, ich hatte das damals so installiert
                                      npm install https://github.com/ioBroker/ioBroker.zwave/tarball/master --production --unsave-perm --build-from-source
                                      Aber das sollte eigentlich keinen Unterschied machen.
                                      Du kannst doch im Adapter noch ein extra Logging einschalten, kommt da was brauchbares?
                                      • T
                                        T
                                        TomF
                                        #123
                                        Problem erstmal gelöst, beim Razberry Modul muss wohl auch die Software von Razberry Seite auf dem Raspi installiert sein.
                                        Ich bin davon ausgegangen das dies nicht notwendig ist…
                                        Tom
                                        • S
                                          S
                                          Schnutexxl
                                          #124
                                          Hallo Zusammen,
                                          ich wollte heute versuchen den zwave Adapter zu installieren, scheitere aber bereits bei:
                                          Hier kommt dann folgende Fehlermeldung:
                                          ` > root@ioBroker:/opt/open-zwave-master# apt-get install pkg-config libudev-dev build-essential curl unzip
                                          build-essential ist schon die neueste Version.
                                          curl ist schon die neueste Version.
                                          pkg-config ist schon die neueste Version.
                                          unzip ist schon die neueste Version.
                                          Die folgenden NEUEN Pakete werden installiert:
                                          libudev-dev
                                          0 aktualisiert, 1 neu installiert, 0 zu entfernen und 0 nicht aktualisiert.
                                          Es müssen 23,2 kB an Archiven heruntergeladen werden.
                                          Nach dieser Operation werden 261 kB Plattenplatz zusätzlich benutzt.
                                          Möchten Sie fortfahren? [J/n] J
                                          Fehl http://mirrordirector.raspbian.org/raspbian/ jessie/main libudev-dev armhf 215-17+deb8u4
                                          404 Not Found [IP: 93.93.128.193 80]
                                          E: Fehlschlag beim Holen von http://mirrordirector.raspbian.org/rasp … _armhf.deb 404 Not Found [IP: 93.93.128.193 80]
                                          E: Einige Archive konnten nicht heruntergeladen werden; vielleicht »apt-get update« ausführen oder mit »–fix-missing« probieren? `
                                          Gibt es hier eine andere Möglichkeit dieses zu installieren?
                                          Danke und Gruß
                                          84.0k
