  4. Test Adapter fb-checkpresence v1.1.x
avmfb-checkpresencefritzboxtr-064
948 Beiträge 89 Kommentatoren 397.7k Aufrufe 78 Beobachtet
  • sigi234S sigi234
    @afuerhoff sagte in Test Adapter fb-checkpresence v1.1.x:
    @afuerhoff
    Hab noch ein weiteres Update hochgeladen.
    fb-checkpresence.0	2021-04-02 12:51:29.145	warn	(14768) loop: getExtIp: GetInfo WANConnection Cannot get external ip address ""
    fb-checkpresence.0	2021-04-02 12:50:51.336	info	(14768) loop successfully started
    fb-checkpresence.0	2021-04-02 12:50:51.335	info	(14768) states successfully subscribed
    fb-checkpresence.0	2021-04-02 12:50:51.334	info	(14768) createFbDeviceObjects finished successfully
    fb-checkpresence.0	2021-04-02 12:50:49.316	info	(14768) createMemberObjects finished successfully
    fb-checkpresence.0	2021-04-02 12:50:49.065	info	(14768) createGlobalObjects finished successfully
    fb-checkpresence.0	2021-04-02 12:50:48.886	warn	(14768) The state "devices" will not longer exist in a future version. Please use "fb-devices.count" instead!
    fb-checkpresence.0	2021-04-02 12:50:48.886	warn	(14768) The state "activeDevices" will not longer exist in a future version. Please use "fb-devices.active" instead!
    fb-checkpresence.0	2021-04-02 12:50:48.885	warn	(14768) The state "blacklist" will not longer exist in a future version. Please use "blacklist.presence" instead!
    fb-checkpresence.0	2021-04-02 12:50:48.885	warn	(14768) The state "guest" will not longer exist in a future version. Please use "guest.presence" instead!
    Info jetzt alle auf true
    FB Devices keine Daten
    Bl+WHList keine Daten
    afuerhoffA Offline
    afuerhoffA Offline
    afuerhoff
    #430
    @sigi234 sagte in Test Adapter fb-checkpresence v1.1.x:
    Hallo, neues Update ist hochgeladen.
    sigi234S 2 Antworten Letzte Antwort
    • afuerhoffA afuerhoff
      sigi234S Online
      sigi234S Online
      #431
      Sieht viel Besser aus 👍
      fb-checkpresence.0	2021-04-02 15:01:52.499	warn	(832) getExtIp
      fb-checkpresence.0	2021-04-02 14:57:26.985	warn	(832) getExtIp
      fb-checkpresence.0	2021-04-02 14:57:05.599	info	(832) loop successfully started
      fb-checkpresence.0	2021-04-02 14:57:05.598	info	(832) states successfully subscribed
      fb-checkpresence.0	2021-04-02 14:57:05.597	info	(832) createFbDeviceObjects finished successfully
      fb-checkpresence.0	2021-04-02 14:57:03.701	info	(832) createMemberObjects finished successfully
      fb-checkpresence.0	2021-04-02 14:57:03.419	info	(832) createGlobalObjects finished successfully
      fb-checkpresence.0	2021-04-02 14:57:02.381	warn	(832) The state "devices" will not longer exist in a future version. Please use "fb-devices.count" instead!
      fb-checkpresence.0	2021-04-02 14:57:02.380	warn	(832) The state "activeDevices" will not longer exist in a future version. Please use "fb-devices.active" instead!
      fb-checkpresence.0	2021-04-02 14:57:02.380	warn	(832) The state "blacklist" will not longer exist in a future version. Please use "blacklist.presence" instead!
      fb-checkpresence.0	2021-04-02 14:57:02.380	warn	(832) The state "guest" will not longer exist in a future version. Please use "guest.presence" instead!
      fb-checkpresence.0	2021-04-02 14:57:01.883	info	(832) LANConfigSecurity1-X_AVM-DE_GetCurrentUser is supported
      fb-checkpresence.0	2021-04-02 14:57:01.883	info	(832) WANPPPConnection1-ForceTermination is supported
      fb-checkpresence.0	2021-04-02 14:57:01.882	info	(832) DeviceConfig1-Reboot is supported
      fb-checkpresence.0	2021-04-02 14:57:01.882	info	(832) X_AVM-DE_HostFilter-GetWANAccessByIP is supported
      fb-checkpresence.0	2021-04-02 14:57:01.882	info	(832) X_AVM-DE_HostFilter-DisallowWANAccessByIP is supported
      fb-checkpresence.0	2021-04-02 14:57:01.882	info	(832) DeviceInfo1-GetInfo is supported
      fb-checkpresence.0	2021-04-02 14:57:01.882	info	(832) WLANConfiguration3-GetSecurityKeys is supported
      fb-checkpresence.0	2021-04-02 14:57:01.881	info	(832) WLANConfiguration3-GetInfo is supported
      fb-checkpresence.0	2021-04-02 14:57:01.881	info	(832) WLANConfiguration3-SetEnable is supported
      fb-checkpresence.0	2021-04-02 14:57:01.881	info	(832) WANIPConnection1-GetInfo is supported
      fb-checkpresence.0	2021-04-02 14:57:01.881	info	(832) WANPPPConnection1-GetInfo is supported
      fb-checkpresence.0	2021-04-02 14:57:01.881	info	(832) WANCommonInterfaceConfig1-GetCommonLinkProperties is supported
      fb-checkpresence.0	2021-04-02 14:57:01.880	info	(832) DeviceInfo1-GetSecurityPort is supported
      fb-checkpresence.0	2021-04-02 14:57:01.880	info	(832) Hosts1-X_AVM-DE_GetSpecificHostEntryByIP is supported
      fb-checkpresence.0	2021-04-02 14:57:01.880	info	(832) Hosts1-GetSpecificHostEntry is supported
      fb-checkpresence.0	2021-04-02 14:57:01.880	info	(832) Hosts1-X_AVM-DE_GetMeshListPath is supported
      fb-checkpresence.0	2021-04-02 14:57:01.880	info	(832) Hosts1-X_AVM-DE_GetHostListPath is supported
      fb-checkpresence.0	2021-04-02 14:57:01.878	info	(832) start fb-checkpresence.0: FRITZ!Box 6590 Cable version: 148.07.20 ip-address: "192.168.178.1" - interval devices: 2 min. - interval members: 15 s
      fb-checkpresence.0	2021-04-02 14:57:01.542	info	(832) starting. Version 1.1.3 in C:/Program Files/iobroker/Home/node_modules/iobroker.fb-checkpresence, node: v12.21.0, js-controller: 3.2.16
        sigi234S Online
        sigi234S Online
        #432
        @afuerhoff
        Hallo, die History Json wird nicht befüllt, kommt erst nach Mitteernach habe ich mal gelesen?
        extip ist ein value?
        afuerhoffA 2 Antworten Letzte Antwort
        • sigi234S sigi234
          @afuerhoff
          afuerhoffA Offline
          afuerhoffA Offline
          afuerhoff
          #433
          @sigi234
          In extip sollte die externe IP-Adresse der Fritzbox angezeigt werden. Das scheint bei der Cable Fritzbox nicht so zu funktionieren wie ich es implementiert habe. Ich muss mir das nochmal anschauen.
          In der history json werden die History Werte eigentlich sofort angezeigt, wenn welche vorhanden sind. Schauen ich mir auch nochmal an. Könnte mit dem Kompatibilitätsmodus zusammenhängen.
          • sigi234S sigi234
            @afuerhoff
            afuerhoffA Offline
            afuerhoffA Offline
            afuerhoff
            #434
            Ich hab gerade noch ein Update eingespielt. Die Historydaten sollten jetzt wieder geschrieben werden. Schau mal, ob jetzt die extip gesetzt wird.
              sigi234S Online
              sigi234S Online
              #435
              Alles da! 👍
                sigi234S Online
                sigi234S Online
                #436
                @afuerhoff
                Kann man die DP "fb-checkpresence.0.familyMembers.Home.xxxx.comming" vom Datum anders formatieren?
                Komme: 02.04.21 - 17:29 Uhr
                Derzeit kommt: Fri Apr 02 2021 13:58:38 GMT+0200 (Mitteleuropäische Sommerzeit)
                • sigi234S sigi234
                  @afuerhoff
                  afuerhoffA Offline
                  afuerhoffA Offline
                  afuerhoff
                  #437
                  @sigi234
                  Das kannst Du doch mit dem basic - TimesValue hinbekommen.
                  Stephan SchleichS 1 Antwort Letzte Antwort
                    @sigi234
                    Stephan SchleichS Offline
                    Stephan Schleich
                    #438
                    @afuerhoff fände eine extra Option fürs datum im Adapter auch gut, da immer mehr Leute von der vis weggehen.
                    afuerhoffA Stephan SchleichS 2 Antworten Letzte Antwort
                    • Stephan SchleichS Stephan Schleich
                      afuerhoffA Offline
                      afuerhoffA Offline
                      afuerhoff
                      #439
                      @stephan-schleich
                      Die States sind ja extra so universell angelegt, dass der Anwender das in vis entsprechen formatieren kann. Wo mit visualisierst du denn die Daten?
                      Gibt es dort die Format Möglichkeit nicht.
                      I 1 Antwort Letzte Antwort
                        @stephan-schleich
                        I Online
                        I Online
                        intruder7
                        #440
                        @afuerhoff
                        Moin, hab jetzt auch mal die Testversion (letzte Git Version) installiert. Bei mir zeigt er die ext IP nicht an und auch nicht den QR Code für das Gäste WLAN
                        Der Rest scheint erstmal zu passen
                        • I intruder7
                          @afuerhoff
                          afuerhoffA Offline
                          afuerhoffA Offline
                          afuerhoff
                          schrieb am zuletzt editiert von afuerhoff
                          #441
                          @intruder7
                          Was hast du für eine Fritzbox?
                          Die Optionen sind aber angehakt.
                            @intruder7
                            I Online
                            I Online
                            intruder7
                            #442
                            @afuerhoff
                            hab die 7490 an Glasfaser.
                            was meinst du mit Optionen? Hatte ja nur die Version aktualisiert. Davor ging ja alles.
                            Achso, du meinst QR-Code in den Einstellungen des Adapters? Ja dies ist gesetzt.
                              Stephan Schleich
                              schrieb am zuletzt editiert von Stephan Schleich
                              #443
                              @afuerhoff meine vis ist jarvis
                              • I intruder7
                                @afuerhoff
                                afuerhoffA Offline
                                afuerhoffA Offline
                                afuerhoff
                                #444
                                @intruder7 sagte in Test Adapter fb-checkpresence v1.1.x:
                                Ich baue noch etwas ein. Update kommt demnächst.
                                • I intruder7
                                  @afuerhoff
                                  afuerhoffA Offline
                                  afuerhoffA Offline
                                  afuerhoff
                                  #445
                                  @intruder7
                                  Hallo, update habe ich hochgeladen. Die externe IP sollte jetzt hoffentlich angezeigt werden.
                                    @intruder7
                                    I Online
                                    I Online
                                    intruder7
                                    #446
                                    @afuerhoff
                                    top, ext ip funktioniert. nur qr code geht noch nicht
                                    • I intruder7
                                      @afuerhoff
                                      afuerhoffA Offline
                                      afuerhoffA Offline
                                      afuerhoff
                                      #447
                                      @intruder7
                                      Hast du da besondere Einstellungen im WLAN?
                                      Wird der Datenpunkt gar nicht befüllt?
                                      Kommt eine Fehlermeldung im Log?
                                        @intruder7
                                        I Online
                                        I Online
                                        intruder7
                                        #448
                                        @afuerhoff
                                        wie schon gesagt.. am gesamtsetup habe ich nichts verändert nur auf die aktuelle GIT Version aktualisiert. Der Datenpunkt wlanQR ist leer. Fehler im LOG hab ich keine. Hab es im DEBUG gestartet. Dort ist auch kein Eintrag bzgl QR zu sehen
                                        • I intruder7
                                          @afuerhoff
                                          afuerhoffA Offline
                                          afuerhoffA Offline
                                          afuerhoff
                                          #449
                                          @intruder7
                                          Neues Update habe ich hochgeladen. Jetzt müsste der QR-Code funktionieren.
