  4. Test Adapter Linux Control v1.x.x
adaptercontrolhardwarelinuxsteuern
718 Beiträge 74 Kommentatoren 255.8k Aufrufe 67 Beobachtet
  • B bishop
    @wendy2702
    @Scrounger
    danke hat funktioniert.
    Ist etwas Offtopic aber ich wollte jetzt ein Js Controller update machen auf dem Raspberry pi2 und bekomme nun:
    pi@raspberrypi:~ $ iobroker upgrade self
    Update js-controller from @3.1.6 to @3.2.16
    NPM version: 6.14.11
    npm install iobroker.js-controller@3.2.16 --loglevel error --unsafe-perm --prefix "/opt/iobroker" (System call)
    /opt/iobroker/node_modules/at-least-node/index.js:5
        location?: LocationCode;
    SyntaxError: Unexpected token :
        at Module._compile (internal/modules/cjs/loader.js:723:23)
        at Object.Module._extensions..js (internal/modules/cjs/loader.js:789:10)
        at Module.load (internal/modules/cjs/loader.js:653:32)
        at tryModuleLoad (internal/modules/cjs/loader.js:593:12)
        at Function.Module._load (internal/modules/cjs/loader.js:585:3)
        at Module.require (internal/modules/cjs/loader.js:692:17)
        at require (internal/modules/cjs/helpers.js:25:18)
        at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/fs-extra/lib/mkdirs/make-dir.js:9:21)
        at Module._compile (internal/modules/cjs/loader.js:778:30)
    npm ERR! code ELIFECYCLE
    npm ERR! errno 1
    npm ERR! iobroker.js-controller@3.2.16 install: `node iobroker.js setup first`
    npm ERR! Exit status 1
    npm ERR!
    npm ERR! Failed at the iobroker.js-controller@3.2.16 install script.
    npm ERR!     /home/iobroker/.npm/_logs/2021-03-05T06_55_14_822Z-debug.log
    host.raspberrypi Cannot install iobroker.js-controller@3.2.16: 1
    pi@raspberrypi:~ $ npm -v
    6.14.11
    vorher habe ich eine apt-get update und upgrade gemacht.
    #283
    @bishop
    which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
    • FredFF FredF
      @bishop
      iobroker stop
      iobroker update
      iobroker start
      bishop
      #284
      @fredf sagte in Test Adapter Linux Control v1.x.x:
      @bishop
      iobroker stop
      iobroker update
      iobroker start
      Das habe ich getan!
      @thomas-braun sagte in Test Adapter Linux Control v1.x.x:
      @bishop
      pi@raspberrypi:~ $ which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
      /usr/bin/nodejs
      v10.24.0
      /usr/bin/node
      v10.24.0
      /usr/bin/npm
      6.14.11
      nodejs:
        Installed: 10.24.0-1nodesource1
        Candidate: 10.24.0-1nodesource1
        Version table:
       *** 10.24.0-1nodesource1 500
              500 https://deb.nodesource.com/node_10.x buster/main armhf Packages
           10.24.0~dfsg-1~deb10u1 500
      pi@raspberrypi:~ $
      • B bishop
        @bishop
        iobroker stop
        iobroker update
        iobroker start
        Das habe ich getan!
        @bishop
        /usr/bin/nodejs
        v10.24.0
        /usr/bin/node
        v10.24.0
        /usr/bin/npm
        6.14.11
        nodejs:
          Version table:
        pi@raspberrypi:~ $
        #285
        @bishop
        sudo apt update
        sudo apt dist-upgrade
        sudo reboot
          @bishop
          sudo apt update
          sudo reboot
          bishop
          #286
          @bishop
          sudo apt update
          sudo reboot
          pi@raspberrypi:~ $ sudo apt update
          Hit:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
          Hit:2 http://archive.raspberrypi.org/debian buster InRelease
          Hit:3 http://packages.microsoft.com/repos/code stable InRelease
          Hit:4 https://www.pivccu.de/piVCCU stable InRelease
          Hit:5 https://deb.nodesource.com/node_10.x buster InRelease
          Reading package lists... Done
          Building dependency tree
          All packages are up to date.
          pi@raspberrypi:~ $ sudo apt dist-upgrade
          Calculating upgrade... Done
          0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
          pi@raspberrypi:~ $
          • B bishop
            @bishop
            sudo apt update
            sudo reboot
            pi@raspberrypi:~ $
            bishop
            schrieb am zuletzt editiert von bishop
            #287
            @Scrounger
            ist es möglich auch die synology nas zu integrieren?
            Habe sie mal mit im Adapter konfiguriert aber leider bleibt nur ein INFO Datenpunkt mit der Ip und das sie Offline ist, ist aber natürlich online SSH ist dort auch konfiguriert ich bekomme eine Verbindung mit Putty hin.
            Kann das sein weil es keine richtige Distribution ist?
            linux-control.0	2021-03-13 21:27:33.633	error	at processTimers (internal/timers.js:497:7)
            linux-control.0	2021-03-13 21:27:33.633	error	at listOnTimeout (internal/timers.js:554:17)
            linux-control.0	2021-03-13 21:27:33.633	error	at Timeout._onTimeout (/opt/iobroker/node_modules/ssh2/lib/client.js:695:19)
            linux-control.0	2021-03-13 21:27:33.633	error	(26597) [getConnection] error: Timed out while waiting for handshake, stack: Error: Timed out while waiting for handshake
            linux-control.0	2021-03-13 21:27:33.631	error	(26597) [getConnection] Could not establish a connection to 'Diskstation218' (192.168.1.4:22)!
            linux-control.0	2021-03-13 21:27:28.341	error	at processTimers (internal/timers.js:497:7)
            linux-control.0	2021-03-13 21:27:28.341	error	at listOnTimeout (internal/timers.js:554:17)
            linux-control.0	2021-03-13 21:27:28.341	error	at Timeout._onTimeout (/opt/iobroker/node_modules/ssh2/lib/client.js:695:19)
            linux-control.0	2021-03-13 21:27:28.341	error	(26597) [getConnection] error: Timed out while waiting for handshake, stack: Error: Timed out while waiting for handshake
            linux-control.0	2021-03-13 21:27:28.275	error	(26597) [getConnection] Could not establish a connection to 'Diskstation212' (192.168.1.104:22)!
            ScroungerS 1 Antwort Letzte Antwort
            • da_WoodyD Online
              da_WoodyD Online
              #288
              @bishop hmm, hab gerade meine 2 DS reingehängt, da kommt wirklich nicht viel rum. ausser bei der grossen mehr...
              wenn du mehr infos brauchst, dann nimm den synology adapter...
              • da_WoodyD da_Woody
                bishop
                #289
                @da_woody
                ja das habe ich auch schon probiert, wollte das ohne synology adapter versuchen :)
                werde das ganze mit nem rsa schlüssel versuchen vielleicht geht es damit besser!
                • B bishop
                  @da_woody
                  da_WoodyD Online
                  da_WoodyD Online
                  #290
                  @bishop tjo, schuss in den ofen... :) komisch ja auch, daß bei der 218+ nichtmal control kommt...
                    bishop
                    #291
                    @da_woody
                    liegt glaube ich am handshake.
                    • B bishop
                      @Scrounger
                      ScroungerS Offline
                      ScroungerS Offline
                      Scrounger
                      #292
                      @bishop sagte in Test Adapter Linux Control v1.x.x:
                      Hast du den timeout mal erhöht?
                      • ScroungerS Scrounger
                        bishop
                        #293
                        @scrounger
                        ja habe ich
                        linux-control.0	2021-03-14 13:25:03.940	error	at LinuxControl.onReady (/opt/iobroker/node_modules/iobroker.linux-control/main.js:54:5)
                        linux-control.0	2021-03-14 13:25:03.940	error	at LinuxControl.refreshHost (/opt/iobroker/node_modules/iobroker.linux-control/main.js:82:5)
                        linux-control.0	2021-03-14 13:25:03.940	error	at LinuxControl.servicesInfo (/opt/iobroker/node_modules/iobroker.linux-control/main.js:485:21)
                        linux-control.0	2021-03-14 13:25:03.940	error	at processTicksAndRejections (internal/process/task_queues.js:97:5)
                        linux-control.0	2021-03-14 13:25:03.940	error	at runMicrotasks (<anonymous>)
                        linux-control.0	2021-03-14 13:25:03.940	error	at LinuxControl.sendCommand (/opt/iobroker/node_modules/iobroker.linux-control/main.js:874:26)
                        linux-control.0	2021-03-14 13:25:03.940	error	(23028) [servicesInfo] Diskstation218 (192.168.1.4:22): response error: sh: systemctl: command not found, stack: ResponseError: [servicesInfo] Diskstation218 (192.168.1.4:22): sh: systemctl: command
                        linux-control.0	2021-03-14 13:25:03.551	error	at LinuxControl.onReady (/opt/iobroker/node_modules/iobroker.linux-control/main.js:54:5)
                        linux-control.0	2021-03-14 13:25:03.551	error	at LinuxControl.refreshHost (/opt/iobroker/node_modules/iobroker.linux-control/main.js:81:5)
                        linux-control.0	2021-03-14 13:25:03.551	error	at LinuxControl.updateInfos (/opt/iobroker/node_modules/iobroker.linux-control/main.js:609:5)
                        linux-control.0	2021-03-14 13:25:03.551	error	at LinuxControl.cmdAptUpdate (/opt/iobroker/node_modules/iobroker.linux-control/main.js:706:21)
                        linux-control.0	2021-03-14 13:25:03.551	error	at processTicksAndRejections (internal/process/task_queues.js:97:5)
                        linux-control.0	2021-03-14 13:25:03.551	error	at runMicrotasks (<anonymous>)
                        linux-control.0	2021-03-14 13:25:03.551	error	at LinuxControl.sendCommand (/opt/iobroker/node_modules/iobroker.linux-control/main.js:874:26)
                        linux-control.0	2021-03-14 13:25:03.551	error	(23028) [cmdAptUpdate] Diskstation218 (192.168.1.4:22): response error: sh: apt-get: command not found, stack: ResponseError: [cmdAptUpdate] Diskstation218 (192.168.1.4:22): sh: apt-get: command not
                        linux-control.0	2021-03-14 13:25:03.533	error	at LinuxControl.onReady (/opt/iobroker/node_modules/iobroker.linux-control/main.js:54:5)
                        linux-control.0	2021-03-14 13:25:03.533	error	at LinuxControl.refreshHost (/opt/iobroker/node_modules/iobroker.linux-control/main.js:80:5)
                        linux-control.0	2021-03-14 13:25:03.533	error	at LinuxControl.distributionInfo (/opt/iobroker/node_modules/iobroker.linux-control/main.js:553:21)
                        linux-control.0	2021-03-14 13:25:03.533	error	at processTicksAndRejections (internal/process/task_queues.js:97:5)
                        linux-control.0	2021-03-14 13:25:03.533	error	at runMicrotasks (<anonymous>)
                        linux-control.0	2021-03-14 13:25:03.533	error	at LinuxControl.sendCommand (/opt/iobroker/node_modules/iobroker.linux-control/main.js:874:26)
                        linux-control.0	2021-03-14 13:25:03.533	error	(23028) [distributionInfo] Diskstation218 (192.168.1.4:22): response error: cat: /etc/os-release: No such file or directory, stack: ResponseError: [distributionInfo] Diskstation218 (192.168.1.4:22):
                        host.iobroker	2021-03-14 13:24:27.723	info	instance system.adapter.linux-control.0 started with pid 23028
                        Der Synology Adapter ist im Prinzip möglich nur der stresst meine Nas ziemlich, wenn der Adapter läuft habe ich mindestens 30% mehr CPU auslastung!
                        ? ScroungerS 2 Antworten Letzte Antwort
                        • B bishop
                          @scrounger
                          ja habe ich
                          #294
                          @bishop dann stimmt was nicht mit der config oder system, der Synology Adapter braucht nicht viel Ressourcen.
                          Welche Version hast du denn installiert?
                          • B bishop
                            @scrounger
                            ja habe ich
                            ScroungerS Offline
                            ScroungerS Offline
                            Scrounger
                            schrieb am zuletzt editiert von Scrounger
                            #295
                            @bishop
                            Jetzt klappt doch die Verbindung.
                            Musst halt alle Datenpunkte wo er nix findet (Fehlemeldung im Log) auf die Blacklist schieben.
                            Meine Befehle solltest du dann nutzen können.
                              @bishop
                              bishop
                              #296
                              @scrounger
                              Ok teste ich danke.
                              @ilovegym
                              Nicht das iobroker System sondern die Nas!
                              • B bishop
                                @scrounger
                                Ok teste ich danke.
                                @ilovegym
                                da_WoodyD Online
                                da_WoodyD Online
                                #297
                                @bishop hmm, mein privat-NAS dümpelt bei 6% rum, die grosse mit dem ftp-server, trotz 3 leutz aktiv drauf, bei 40%.
                                wie sollte der adapter das NAS beanspruchen?
                                  bishop
                                  #298
                                  @da_woody
                                  hm..
                                  hier mal ein Auszug aus meiner Ds218+ CPU Auslastung, Ram sind 8GB zusätzlich verbaut also insgesamt 10GB.
                                  IoBroker läuft im Docker.
                                  kein Plan warum das so eine Auswirkung auf meine DS hat... einfach zu schwach auf der Brust???
                                  • B bishop
                                    @da_woody
                                    hm..
                                    da_WoodyD Online
                                    da_WoodyD Online
                                    #299
                                    @bishop die 218+ sollte das eigentlich schaffen. is ja meine private auch. wie sieht denn die benutzerauslastung aus, wenn adapter aus? die 67%...
                                    aber ok, bei mir lööpt da kein ioBroker oder sonstige Docker dingens...
                                      Master-Rudi
                                      #300
                                      Kann ich mit dem Adapter denn auch die GPIOs eines anderen Raspberry steuern?
                                      Ich habe an meinem Octoprint Raspberry ein Relais für das Licht, das würde ich gerne in meiner VIS ein und ausschalten wollen.
                                      Danke!
                                      • M Master-Rudi
                                        Danke!
                                        FredFF Online
                                        FredFF Online
                                        FredF
                                        Most Active Forum Testing
                                        #301
                                        @master-rudi sagte in Test Adapter Linux Control v1.x.x:
                                        Nein, dafür gibt es den RPI Adapter
                                        • FredFF FredF
                                          Master-Rudi
                                          schrieb am zuletzt editiert von Master-Rudi
                                          #302
                                          @fredf
                                          Aber ich möchte die GPIOs von einem anderem Raspberry steuern auf dem kein ioBroker ist. Also ich habe einen Raspi mit iobroker als Zentrale und einen mit octoprint für den Drucker. Und ich würde gerne das Licht über die VIS einschalten.
                                          Ich habe den octoprint nicht als Slave im Multihost, weil da eben nur octoprint drauf ist.
                                          Wie kann ich denn mit dem RPI Adapter die Werte eines anderen Raspi auslesen bzw. dessen GPIOs steuern?? Seh da nur den auf den mein iobroker ist.
                                          da_WoodyD FredFF 2 Antworten Letzte Antwort
