  4. Test Adapter ioBroker.backitup v3.1.x
backitupbackitup backupccuhistorymysqlredisrestorerestore backup
2.8k Beiträge 170 Kommentatoren 3.0m Aufrufe 113 Beobachtet
  • simatecS simatec
    @altersrentner
    Hast du denn in deiner neuen Installation von Grafana die gleichen Benutzerdaten und auch dort einen ApiKey angelegt
    Laut Log stimmen bei deinem Restore weder Username und Passwort als auch ApiKey nicht.
    Konfiguriere Backitup mit den Benutzerdaten aus grafana (inkl. ApiKey) und führe im Anschluss den restore durch
    A
    A
    Altersrentner
    #1096
    @simatec
    Wieder das selbe Ergebnis:
    Started restore ...
    [DEBUG] [grafana] - Start Grafana Restore ...
    [DEBUG] [grafana] - filename for restore: /opt/iobroker/backups/grafana_2021_03_08-02_18_32_backupiobroker.tar.gz
    [DEBUG] [grafana] - Grafana tmp directory created: /opt/iobroker/backups/grafana_tmp
    [DEBUG] [grafana] - start decompress
    [DEBUG] [grafana] - Grafana request started
    [DEBUG] [grafana] - Grafana is available ... Status: 200
    [DEBUG] [grafana] - Try to Restore: /opt/iobroker/backups/grafana_tmp/datasource/InfluxDB-1.json
    [DEBUG] [grafana] - Try to Restore: /opt/iobroker/backups/grafana_tmp/datasource/InfluxDB.json
    [DEBUG] [grafana] - cannot restore datasource "InfluxDB": "data source with the same name already exists"
    [DEBUG] [grafana] - cannot restore datasource "InfluxDB-1": "data source with the same name already exists"
    [DEBUG] [grafana] - Try to Restore: /opt/iobroker/backups/grafana_tmp/dashboards/n1-aussen-wz.json
    [DEBUG] [grafana] - cannot restore dashboard "n1-aussen-wz": {"message":"invalid API key"}
    [DEBUG] [grafana] - Grafana request ended
    [DEBUG] [grafana] - Try deleting the Grafana tmp directory
    [DEBUG] [grafana] - Grafana tmp directory was successfully deleted
    [DEBUG] [grafana] - Grafana Restore completed successfully
    [EXIT] Grafana restore done
    Das ist der Key, oberste Zeile
    eyJrIjoiUkNLdUFsa0JReUppazAwS3RUN0tYWjAwbGtGbFVDMFAiLCJuIjoiaW9Ccm9rZXIiLCJpZCI6MX0=
    curl -H "Authorization: Bearer eyJrIjoiUkNLdUFsa0JReUppazAwS3RUN0tYWjAwbGtGbFVDMFAiLCJuIjoiaW9Ccm9rZXIiLCJpZCI6MX0=" http://192.168.178.41:3000/api/dashboards/home
    • A Altersrentner
      @simatec
      Started restore ...
      simatecS
      simatecS
      simatec
      #1097
      @altersrentner sagte in Test Adapter Backitup v2.0.x:
      Hast du den Key mit Adminrechten angelegt?
      • Besuche meine Github Seite
      • HowTo Restore ioBroker
      • simatecS simatec
        A
        A
        Altersrentner
        #1098
        @simatec
        Werde ich sofort in der alten HDD überprüfen.
        Danke für den Hinweis
        MfG Michael
        • A Altersrentner
          @simatec
          MfG Michael
          simatecS
          simatecS
          simatec
          #1099
          @altersrentner
          Denke aber bitte daran, dass du in deiner neuen Umgebung auch einen neuen ApiKey benötigst, der natürlich dann auch in Backitup aktualisiert werden muss
          A 2 Antworten Letzte Antwort
          • simatecS simatec
            @altersrentner
            A
            A
            Altersrentner
            #1100
            @simatec
            Bin jetzt auf de alten HDD
            werde einen neuen API Key als admin generieren
            Dann ein Backup erstellen
            Platte tauschen
            Auf der SSD unter Backitup den neuen Key, Login un Passwort eintragen
            Und Restore machen
            Ist das so OK
            MfG Michael
            • A Altersrentner
              @simatec
              Platte tauschen
              Und Restore machen
              Ist das so OK
              MfG Michael
              simatecS
              simatecS
              simatec
              #1101
              @altersrentner Login und ApiKey müssen mit den Grafana System auf deiner SDD passen.
              Also lege den ApiKey dort an.
              Der alte ApiKey von dem HDD System ist für den restore nicht relevant
              • simatecS simatec
                @altersrentner
                A
                A
                Altersrentner
                #1102
                @simatec sagte in Test Adapter Backitup v2.0.x:
                Auch oder den neu generierten Key? der alten Platte
                • A Altersrentner
                  simatecS
                  simatecS
                  simatec
                  #1103
                  @altersrentner Nein den auf deinem neuen System generierten Key
                  • simatecS simatec
                    A
                    A
                    Altersrentner
                    #1104
                    @simatec Hallo,
                    Ich bedanke mich für die Unterstützung.
                    Jetzt ist wieder alles online.
                    Problem war vermutlich,
                    dass ich den API Key nicht als admin angelegt hatte.
                    Mit freundlichen grüßen
                    Michael
                    • simatecS
                      simatecS
                      simatec
                      #1105
                      @altersrentner Gerne ... Kein Problem ;-)
                      • simatecS
                        simatecS
                        simatec
                        #1106
                        Ab sofort steht die Version 2.0.4 auf Github und in Kürze auch im latest zur Verfügung.
                        Changelog
                        2.0.4 (10.03.2021)
                        • (simatec) Bugfix history json
                        • (simatec) BugFix Redis backup
                        • (simatec) chmod for backup directory added
                        • (simatec) error handling for Grafana backup added
                        • simatecS
                          simatecS
                          simatec
                          #1107
                          Ab sofort steht die Version 2.0.5 auf Github und in Kürze auch im latest zur Verfügung.
                          Changelog
                          2.0.5 (14.03.2021)
                          • (simatec) error handling for redis backup added
                          • (simatec) error handling for history backup added
                          • (simatec) BugFix Grafana backup
                          O crunchipC R 3 Antworten Letzte Antwort
                          • simatecS simatec
                            Changelog
                            2.0.5 (14.03.2021)
                            O
                            O
                            Oli
                            #1108
                            @simatec
                            erstmal danke für den genialen Adapter, hat mir schon etliche mal das arbeiten mit ioBroker erleichtert.
                            Da ich leider versehentlich ein Script gelöscht hatte, suchte ich nach einer einfachen Methode nur die Scripte aus dem letzten Backup wieder herzustellen, habe dazu aber leider nichts einfaches im Forum oder im Internet gefunden. Daher die Frage, wäre es möglich so eine Möglichkeit in deinen Adapter zu integrieren?
                            Oliver
                            • O Oli
                              @simatec
                              Thomas BraunT
                              Thomas BraunT
                              Most Active Developer
                              #1109
                              @oli Gibt es doch schon.
                              O 1 Antwort Letzte Antwort
                                O
                                O
                                Oli
                                #1110
                                wo finde ich das im Adapter, habe alles durchsucht und nicht gefunden
                                Oliver
                                • O Oli
                                  Thomas BraunT
                                  Thomas BraunT
                                  #1111
                                  @oli Welche Version?
                                  In 2.0.4 findet sich das in den Einstellungen. Nennt sich Javascript dort.
                                    O
                                    O
                                    Oli
                                    #1112
                                    @thomas-braun, @simatec
                                    sorry, wer lesen kann ist klar im Vorteil, bin auf stable Version unterwegs
                                    Oliver
                                    • simatecS simatec
                                      Changelog
                                      2.0.5 (14.03.2021)
                                      crunchipC
                                      crunchipC
                                      Developer Global Moderator Most Active Forum Testing
                                      #1113
                                      @simatec habe gerade versucht zu installieren, von 2.0.4 auf 2.0.5, siehe screen
                                      js-controller 3.2.16
                                      2021-03-15 23:40:29.194 - info: host.IoBroker iobroker upgrade backitup
                                      2021-03-15 23:40:32.840 - error: host.IoBroker iobroker /opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:2674 res.forEach(aliveState => { ^TypeError: Cannot read property 'forEach' of undefined at Immediate. (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:2674:21) at processImmediate (internal/timers.js:463:21)
                                      2021-03-15 23:40:32.855 - info: host.IoBroker iobroker exit 1
                                        simatecS
                                        simatecS
                                        simatec
                                        #1114
                                        @crunchip
                                        Du hast doch zu dem gleichen Fehler bereits ein Thread offen. Es ist doch eindeutig, dass es der gleiche Fehler wie in deiner letzten Anfrage ist und dementsprechend nicht Adapter spezifisch
                                        https://forum.iobroker.net/topic/38377/tr-064-adapter-kann-icht-installiert-werden/30?_=1615875479116
                                        • simatecS simatec
                                          @crunchip
                                          crunchipC
                                          crunchipC
                                          #1115
                                          @simatec aaaaahhhh, danke👍👍👍 hatte ich total vergessen, dann werd ich dort mal nachhaken
                                          33.2k
                                          84.3k
