  4. Test Adapter doorio v2.1.2
door intercomdoorpitürsprechstelle
590 Beiträge 36 Kommentatoren 209.9k Aufrufe 39 Beobachtet
  • R Offline
    Renegade 0
    #399
    Moin,
    habe ein Problem mit baresip als service.
    Die baresip.service ist eingerichtet wie hier im thread. Allerdings habe ich das Problem, kein Ton. Wenn ich den service beende und über baresip -v starte, geht es.
    pi@TestPI:~$ sudo systemctl status baresip.service
    ● baresip.service - baresip
       Loaded: loaded (/etc/systemd/system/baresip.service; enabled; vendor preset:
       Active: active (running) since Sat 2021-02-27 14:02:11 CET; 12min ago
     Main PID: 661 (baresip)
        Tasks: 1 (limit: 4915)
       CGroup: /system.slice/baresip.service
               └─661 /usr/bin/baresip -f /home/pi/.baresip
    Feb 27 14:02:11 TestPI baresip[661]: Populated 2 audio codecs
    Feb 27 14:02:11 TestPI baresip[661]: Populated 1 audio filter
    Feb 27 14:02:11 TestPI baresip[661]: Populated 0 video codecs
    Feb 27 14:02:11 TestPI baresip[661]: Populated 0 video filters
    Feb 27 14:02:11 TestPI baresip[661]: baresip is ready.
    Feb 27 14:02:11 TestPI baresip[661]: IP-DoorPI@192.168.33.70: {0/UDP/v4} 200 OK
    Feb 27 14:06:41 TestPI baresip[661]: reg: sip:IP-DoorPI@192.168.33.70: 401 Unaut
    Feb 27 14:07:23 TestPI baresip[661]: IP-DoorPI@192.168.33.70: {0/UDP/v4} 200 OK
    Feb 27 14:11:53 TestPI baresip[661]: reg: sip:IP-DoorPI@192.168.33.70: 401 Unaut
    Feb 27 14:12:26 TestPI baresip[661]: IP-DoorPI@192.168.33.70: {0/UDP/v4} 200 OK
    und das steht nach dem call drinnen
       Loaded: loaded (/etc/systemd/system/baresip.service; enabled; vendor preset: enabled)
       Active: active (running) since Sat 2021-02-27 14:02:11 CET; 13min ago
    Feb 27 14:15:41 TestPI baresip[661]: alsa: could not open ausrc device 'default' (Connection refused)
    Feb 27 14:15:41 TestPI baresip[661]: audio: start_source failed (alsa.default): Unknown error -111
    Feb 27 14:15:41 TestPI baresip[661]: stream: incoming rtp for 'audio' established, receiving from 192.168.33.70:7082
    Feb 27 14:15:50 TestPI baresip[661]: [3.0K blob data]
    Feb 27 14:15:50 TestPI baresip[661]: alsa: could not open auplay device 'default' (Connection refused)
    Feb 27 14:15:50 TestPI baresip[661]: audio: start_player failed (alsa.default): Unknown error -111
    Feb 27 14:15:50 TestPI baresip[661]: ALSA lib pulse.c:243:(pulse_connect) PulseAudio: Unable to connect: Connection refused
    Feb 27 14:15:50 TestPI baresip[661]: alsa: could not open ausrc device 'default' (Connection refused)
    Feb 27 14:15:50 TestPI baresip[661]: audio: start_source failed (alsa.default): Unknown error -111
    Feb 27 14:15:50 TestPI baresip[661]: sip:**610@192.168.33.70: session closed: Unknown error -111
    Was läuft da falsch?
    WalW 1 Antwort Letzte Antwort
    • R Renegade 0
      Moin,
      WalW Offline
      WalW Offline
      Wal
      #400
      @renegade-0 ,
      es sieht so aus als ob du mit dem baresip-alsa-modul arbeitest. Schau mal deine Baresipkonfig durch.
      In meinem log sehe ich nichts von alsa.
      call: update media
      stream: update 'audio'
      stream: audio: starting RTCP with remote 192.168.1.2:7079
      audio: Set audio decoder: G722 16000Hz 1ch
      audio: start
      audio: create recv buffer [20 - 160 ms] [640 - 5120 bytes]
      pulse: opening player (16000 Hz, 1 channels, device 'noecho.sound_out')
      pulse: playback started
      audio: player started with sample format S16LE
      audio: Set audio encoder: G722 16000Hz 1ch
      audio: start
      pulse: opening recorder (16000 Hz, 1 channels, device 'noecho.mic_in')
      pulse: recording started
      audio: source started with sample format S16LE
      audio tx pipeline:       pulse ---> G722
      audio rx pipeline:       pulse <--- G722
      stream: incoming rtp for 'audio' established, receiving from 192.168.1.2:7078
      call: got SDP answer (211 bytes)
      call: update media
      call: stream start (active=1)
      audio: start
      Walter
      DoorIO-Adapter
      • WalW Wal
        @renegade-0 ,
        ich werde demnächst auch meine Anlage auf das 2N IP Audio-Kit umstellen, das Set ist schon bestellt.
        Da ich Ü50 bin muß ich mittlerweile auch an meine Nachkommen denken und werde alles auf vorhandene Technik umstellen. Der Adapter wird weiterhin gepflegt, er muß ja auch nur angepasst werden falls sich im ioBroker was ändert da er ja funktioniert.
        Für das 2N IP Audiokit werde ich sehr wahrscheinlich auch einen Adapter in Angriff nehmen. Die API läuft über Http Post/Get.
        KnallochseK Offline
        KnallochseK Offline
        Knallochse
        schrieb am zuletzt editiert von Knallochse
        #401
        @wal sagte in Test Adapter doorio v1.1.x:
        Gehe ich recht in der Annahme, dass mit dem Marktplatz-Angebot auch die Adapter-Entwicklung eingestellt wurde?
        • KnallochseK Knallochse
          WalW Offline
          WalW Offline
          Wal
          #402
          @knallochse,
          ich hatte das Teil getestet und man kann das Kit direkt ansprechen und auch an die ioBroker-Api den Status senden lassen, deshalb ist ein Adapter völlig überflüssig. Da ich an meiner Sprechstelle für das Nextion-Display trotzdem noch ein RPI brauche und ich sonst keine Vorteile sehe, habe ich das Teil wieder abgegeben. Für einen der wenig basteln möchte, ist das Kit hervorragend geeignet.
          Walter
          DoorIO-Adapter
          R 1 Antwort Letzte Antwort
          • WalW Wal
            @knallochse,
            Renegade 0
            schrieb am zuletzt editiert von Renegade 0
            #403
            @wal
            Ja ich hab mir meinen mal selbst aufgesetzt zum spielen und verstehen. Ich habe halt Alsa gelassen und nicht das pulseaudio nachinstalliert.
            wenn ich über baresip -v manuell starte läuft es auch einwandfrei. Nur als Service nicht.
            Warum hast du eigentlich das pulse nachinstalliert?
            Da ich
            • Buster-Lite
            • Baresip-core
            • Mosquitto
            • mjpeg_streamer
            • xserver und chromium
            verwende, ist mein Aufbau ja sehr ähnlich. Habe halt xserver für die Anzeige der vis drauf aber ansonsten nutze ich ja eigentlich das gleiche wie du. Nur eben also statt pulseaudio oder?
            edit: Bei deinem Image ist der mjpg_streamer aber nicht drauf? Wie hast du den implementiert?
            • WalW Wal
              Bild Text
              **Aktuelle Version 2.1.3
              Der Adapter ist für eine "Selfmade Türstation". Github Installationsadresse
              Es können z.Z. bis zu 4 Klingeleingänge und 4 DTMF-Codes für das steuern von Ausgängen konfiguriert werden. Ich hatte DoorPi im Einsatz, da es aber nicht mehr weiterentwickelt wird, musste was Neues her. Auf der Türstationshardware muss zwingend Baresip laufen, ein modularer SIP User-Agent. Es bietet sich ein RPI3 als Hardware an "siehe DoorPi", ist aber kein muss.
              In der Baresip-Konfig wird das Modul "ctrl_tcp.so" aktiviert, da über TCP Socket mit dem ioBroker kommuniziert wird.
              Baresip sollte erst mal ohne Fehler laufen, bevor man den Adapter nutzt.
              Baresip installieren
              Verbindung zu Barsip.
              Objekte allgemein steuern bei Ruf aktiv, Ruf verbunden und Ruf beendet. (z.B. Licht einschalten oder Sprechstelle mute/unmute)
              Klingelevent und Rufnummer einstellen.
              Objekte steuern mit DTMF Code bei Verbindung mit der Sprechstelle. (z.B. Türöffner für 2sec. betätigen)
              Fertiges Image für den RPI3 und RPI4, Benutzer "pi" Passwort "raspberry".
              Passwort zum runterladen lautet "iobroker" :
              Selfmade-DoorIntercom
              Neues RPI4 Bullseye64 Image
              1. Image flashen
              2. RPI hochfahren und mit "sudo raspi-config" in Advanced Options Expanded Filesystem anstossen.
              3. "sudo passwd" Passwort für root erstellen.
              4. Baresip, config.yaml und pulseaudio der eigenen Hardware/Software anpassen.
              Daten für AEC von pulseaudio herausfinden:
              "pactl list" eingeben und nach Quelle und Ziel suchen.
              Ziel #0
                      Status: SUSPENDED
                      Beschreibung: Jabra SPEAK 410 USB Analog Stereo
              Quelle #1
                      Status: IDLE
                      Beschreibung: Jabra SPEAK 410 USB Analog Mono
              sink_master und source_master der eigenen Quelle und Ziel anpassen.
              /etc/pulse/system.pa
              load-module module-echo-cancel aec_method=webrtc format=s16le rate=16000 channels=1 source_name="noecho.mic_in" sink_name="noecho.sound_out" sink_master="alsa_output.usb-0b0e_Jabra_SPEAK_410_USB_501AA5A30536010C00-00.analog-stereo" source_master="alsa_input.usb-0b0e_Jabra_SPEAK_410_USB_501AA5A30536010C00-00.analog-mono"
              set-default-sink noecho.sound_out
              set-default-source noecho.mic_in
              weiter
              Achtung !!!
              Falls mit dem aktuellen Raspberry Pi OS Lite gearbeitet wird und nicht mit dem RPI-Image:
              sudo apt install pulseaudio
              sudo apt install baresip-core
              sudo apt install baresip-x11
              sudo reboot
              Soundkarte finden und default.pa anpassen:
              alsamixer
              pacmd list-sources | grep 'name:.*input'
              pacmd list-sinks | grep 'name:.*output'
              baresip -vvv
              Ctrl-c zum beenden von Baresip. Baresip hat jetzt ein Verzeichnis ".baresip"erzeugt mit den Konfigdateien.
              nano /home/pi/.baresip/config
              Das ändern:
              audio_player		pulse,noecho.sound_out
              audio_source		pulse,noecho.mic_in
              audio_alert		pulse,noecho.sound_out
              module                   pulse.so
              module_app		ctrl_tcp.so
              Sipdaten anpassen:
              nano /home/pi/.baresip/accounts
              Bei Fritzbox z.B:
              <sip:door2iobroker@fritz.box>;auth_pass=PASSWORD
              Jetzt nicht mehr die "etc/pulse/system.pa" ändern, sondern die "etc/pulse/default.pa" siehe oben.
              sudo nano /etc/pulse/default.pa
              Sonst ist alles beim alten.
              danach wieder Baresip starten:
              baresip -vvv
              Autostart als User einrichten:
              sudo loginctl enable-linger pi
              mkdir -p ~/.config/systemd/user/
              nano ~/.config/systemd/user/baresip.service
              das einfügen:
              [Unit]
              Description=baresip
              [Service]
              ExecStart=/usr/local/bin/baresip -4 -f /home/pi/.baresip
              [Install]
              WantedBy=default.target
              aktivieren und reboot:
              systemctl --user daemon-reload
              systemctl --user enable baresip.service
              sudo reboot
              Bei Fehlern bitte kompletten Log von Baresip und Ausgabe von "pactl list" mit angeben.
              koli.d
              #404
              @wal
              seit einiger Zeit benutze ich diesen Adapter und ich finde den einfach super. Ich habe aber leider ein kleines aber ziemlich nerviges Problem.
              Wenn jemand klingelt und ich sehe denjenigen durch das Fenster, dann mache ich die Türen über eine Taste auf meinem Wand Tablet auf (VIS), statt über das Telefon.
              Das Telefon Klingelt dann aber weiter bis der Timeout (bei mir ziemlich Lang) um ist. Gibt es eine Möglichkeit in solchem Fall den Anruf früher abzubrechen, also direkt mit dem Öffnen der Pforte/Statusänderung abzubrechen/zu Beenden?
              WalW 2 Antworten Letzte Antwort
              • R Renegade 0
                @wal
                Da ich
                • Buster-Lite
                • Baresip-core
                • Mosquitto
                • mjpeg_streamer
                WalW Offline
                WalW Offline
                Wal
                schrieb am zuletzt editiert von Wal
                #405
                @renegade-0 ,
                ich nutze das pulseaudio AEC.
                Den MJPG-Server habe ich über Github installiert.
                Walter
                DoorIO-Adapter
                • K koli.d
                  @wal
                  WalW Offline
                  WalW Offline
                  Wal
                  #406
                  @koli-d ,
                  muss ich mir mal anschauen, evtl. kann ich ein Objekt zum auflegen einfügen, ich weiß nur nicht ob das funzt da ja nicht abgehoben wird.
                  Walter
                  DoorIO-Adapter
                  • K koli.d
                    @wal
                    WalW Offline
                    WalW Offline
                    Wal
                    #407
                    @koli-d ,
                    installiere den Adapter mal über Github, es müsste ein neues Objekt "hangup" sichtbar sein.
                    Schreibe mal was rein und das Telefon müsste aufhören zu klingeln. Ich habe aber nichts getestet, sag einfach bescheid.
                    Walter
                    DoorIO-Adapter
                    R K 2 Antworten Letzte Antwort
                    • WalW Wal
                      @koli-d ,
                      Renegade 0
                      #408
                      @wal
                      Und warum das pulseaudio AEC und nicht standard Alsa?
                      Welchen MJPG nutzt du Liamjackson, rpi?
                      Also wenn du statt annehmen auf der Gegenseite ein hangup schickst, legt er auf.
                      • R Renegade 0
                        @wal
                        WalW Offline
                        WalW Offline
                        Wal
                        #409
                        @renegade-0 ,
                        wüsste jetzt nicht das alsa AEC kann.
                        Ja,Liamjackson.
                        Walter
                        DoorIO-Adapter
                        • WalW Wal
                          @koli-d ,
                          koli.d
                          #410
                          @wal
                          Moin,
                          habe die Änderung getestet. Funktioniert einwandfrei. Klasse. Vielen Dank für deinen super schnellen Support. Beide Daumen hoch.
                          Lieben Gruß
                          • R Offline
                            Renegade 0
                            #411
                            @Wal
                            Moin,
                            Was ist eigentlich der Grund, dass du beim Client pulse und nicht alsa verwendest?
                            • R Renegade 0
                              @Wal
                              Moin,
                              WalW Offline
                              WalW Offline
                              Wal
                              #412
                              @renegade-0 ,
                              habe ich doch oben geschrieben.
                              Wüsste nicht das alsa AEC kann.
                              Walter
                              DoorIO-Adapter
                              R 2 Antworten Letzte Antwort
                              • WalW Wal
                                @renegade-0 ,
                                Renegade 0
                                #413
                                @wal
                                Ah ok, habe ich wohl überlesen. Dann muss ich mich wohl doch nochmal damit rumärgern, wie man pulseaudio in Lite installiert. Bei mir gibts nämlich seltsamste Aktionen, wenn ich von einem baresip auf einen anderen anrufe. Doppelter Anruf, incomming call kommt über die Boxen, aber dann kein Ton mehr beim Gespräch,... Baresip auf DECT geht aber einwandfrei.
                                • WalW Wal
                                  @renegade-0 ,
                                  Renegade 0
                                  #414
                                  @wal
                                  Hast du vielleicht eine gute Anleitung, wie du pulseaudio installierst? Ich hab nur eine für Jessie und eine andere, aber bei keiner gibt es eine config.yml
                                  • R Renegade 0
                                    @wal
                                    WalW Offline
                                    WalW Offline
                                    Wal
                                    #415
                                    @renegade-0 ,
                                    die config.yml ist für die In/Out auf MQTT. Die Config für pulseaudio wie auf Seite 1 beschrieben system.pa.
                                    Das Problem bei dir wird der XServer sein, der kapert den Audioserver. Bei den meisten Oberflächen ist pulseaudio schon dabei, siehe hier.
                                    edit: ich kann dir auch sagen, das ich Tage damit verbracht habe pulseaudio und AEC zum laufen zu bringen. ;-)
                                    Walter
                                    DoorIO-Adapter
                                    • WalW Wal
                                      @renegade-0 ,
                                      Renegade 0
                                      #416
                                      @wal
                                      Ach ja stimmt. die war das ja mit diesen ellenlangen input und output Texten. :)
                                      Lustigerweise das Gerät mit dem XServer läuft. Die andere Seite ist das Problem. Da sollte pivccu3(Image) mit iobroker drauf sein. Aktuell setze ich einen blanken Buster Lite auf nur mit pulse und baresip. Und von dem aus werde ich dann weiter bauen.
                                      Ja pulse ist echt eine Mistmatz, wie man hier im sonnigen Süden zu sagen pflegt. Und einfach keine vernünftige Anleitung zu finden. Deine war noch die beste, aber halt leider nur Konfiguration. Irgendwie wollen die immer mpd oder sonst was mit installieren.
                                      • WalW Wal
                                        @renegade-0 ,
                                        Renegade 0
                                        #417
                                        @wal
                                        hab mal zum Spaß auf deinem image systemctl status pulseaudio gemacht.
                                        Mär 05 08:06:23 TestPi pulseaudio[311]: Für eine Erklärung, warum der Systemmodus eine schlechte Idee ist, lesen Sie bitte http://www.freedesktop.org/wiki/Software/PulseAudio/Documentation/User/WhatIsWrongWithSystemWide/.
                                        Mär 05 08:06:24 TestPi pulseaudio[311]: Failed to open cookie file '/var/run/pulse/.config/pulse/cookie': Datei oder Verzeichnis nicht gefunden
                                        Mär 05 08:06:24 TestPi pulseaudio[311]: Failed to load authentication key '/var/run/pulse/.config/pulse/cookie': Datei oder Verzeichnis nicht gefunden
                                        Mär 05 08:06:24 TestPi pulseaudio[311]: Failed to open cookie file '/var/run/pulse/.pulse-cookie': Datei oder Verzeichnis nicht gefunden
                                        Mär 05 08:06:24 TestPi pulseaudio[311]: Failed to load authentication key '/var/run/pulse/.pulse-cookie': Datei oder Verzeichnis nicht gefunden
                                        Mär 05 08:06:26 TestPi pulseaudio[311]: Master source not found
                                        Mär 05 08:06:26 TestPi pulseaudio[311]: Failed to load module "module-echo-cancel" (argument: "aec_method=webrtc format=s16le rate=16000 channels=1 source_name="noecho.mic_in" sink_name="noecho.sound_out" sink_master="alsa_output.usb-C-Media_Electronics_Inc._USB_Audio_Device-00.
                                        Mär 05 08:06:26 TestPi pulseaudio[311]: Sink noecho.sound_out does not exist.
                                        Mär 05 08:06:26 TestPi pulseaudio[311]: Source noecho.mic_in does not exist.
                                        Mär 05 08:06:26 TestPi systemd[1]: Started PulseAudio Sound System.
                                        Wie mir scheint läuft da was nicht korrekt.
                                        • R Renegade 0
                                          @wal
                                          WalW Offline
                                          WalW Offline
                                          Wal
                                          #418
                                          @renegade-0 ,
                                          hast du die Einstellungen wie im ersten Thread beschrieben für deine Soundkarte gemacht ?
                                          Wenn ja deine Ausgabe von "pactl list" bitte.
                                          Walter
                                          DoorIO-Adapter
