  4. [gelöst] backup Adapter 1.7.0 Fehlermeldung
backup fehlermeldung
29 Beiträge 3 Kommentatoren 3.5k Aufrufe 3 Beobachtet
    @raspiuser Bitte Konsolentext in CodeTags setzen.
    RaspiUserR Offline
    RaspiUserR Offline
    RaspiUser
    schrieb am zuletzt editiert von RaspiUser
    Gestartet...
    [DEBUG] [mount] - first mount attempt with smb option failed. try next mount attempt without smb option ...
    [ERROR] [mount] - [undefined Error: Command failed: sudo mount -t cifs -o username=admin,password='xxxxxxxxx',rw,file_mode=0777,dir_mode=0777 //192.168.178.25/Multimedia/backupDir/ioBroker /opt/iobroker/backups
    mount error(2): No such file or directory
    Refer to the mount.cifs(8) manual page (e.g. man mount.cifs)
    [ERROR] [mount] - [IGNORED] Error: Command failed: sudo mount -t cifs -o username=admin,password='xxxxxxxxx',rw,file_mode=0777,dir_mode=0777 //192.168.178.25/Multimedia/backupDir/ioBroker /opt/iobroker/backups
    [DEBUG] [iobroker] - host.ioBroker-Raspi 3752 states saved
    [DEBUG] [iobroker] - host.ioBroker-Raspi 4734 objects saved
    [DEBUG] [iobroker] - Backup created: /opt/iobroker/backups/iobroker_2021_01_25-07_44_56_backupiobroker.tar.gz
    [DEBUG] [iobroker] - done
    [DEBUG] [zigbee] - found zigbee database: zigbee.0
    [DEBUG] [zigbee] - done
    [DEBUG] [cifs] - done
    [ERROR] [clean] - Backup files not deleted from /opt/iobroker/backups because some errors.
    [DEBUG] [clean] - done
    [DEBUG] [history] - backitup.0.history.html
    [DEBUG] [history] - backitup.0.history.json
    [EXIT] 0
    [DEBUG] [telegram] - done
    [EXIT] 0
    OK ... sieht jetzt übersichtlicher aus ...
    • F fastfoot
      @raspiuser sagte in backup Adapter 1.7.0 Fehlermeldung:
      Probiere mal ob du vom PC auf das Share(//192.168.178.25/Multimedia/backupDir/ioBroker) kommst. Evtl lief da durch den Stromausfall was schief...
      RaspiUserR Offline
      RaspiUserR Offline
      RaspiUser
      @fastfoot
      ... aber im Explorer kann ich ohne Probleme auf den Ordner zugreifen ... 🙄
      EDIT: Wenn ich auf die NAS zugreifen will muss ich (natürlich) "admin" und das "Passwort" eingeben. Dann kann o.g. Eingabe auch nicht funktionieren, richtig ?
      Thomas BraunT F 2 Antworten Letzte Antwort
      • RaspiUserR RaspiUser
        @fastfoot
        @raspiuser
        Ich würde sagen da fehlen die Rechte an der Freigabe.
        RaspiUserR 1 Antwort Letzte Antwort
          @raspiuser
          RaspiUserR Offline
          RaspiUserR Offline
          RaspiUser
          @thomas-braun said in backup Adapter 1.7.0 Fehlermeldung:
          @raspiuser
          ... und die können sich durch einen Stromausfall ändern ? D.h. ich gebe die Daten in der Backup Instanz einfach neu in den Einstellungen ein ?!
            @raspiuser
            @raspiuser
            Vermutlich eher auf dem Backup-Server.
            Da nochmal neuanlegen.
              @fastfoot
              fastfoot
              @fastfoot
              Im BackitUp Adapter mount as root eingestellt?
              • F fastfoot
                @fastfoot
                RaspiUserR Offline
                RaspiUserR Offline
                RaspiUser
                @fastfoot
                ... jo
                "Never change a running system" ist bei mir sehr wichtig, wie beschrieben: Nur der Strom war weg ... (NAS und Raspberry ioBroker auf derselben Sicherung)
                  @fastfoot
                  ... jo
                  @raspiuser
                  Schau mal per
                  dmesg | grep -i ext4
                  über das (Datei)-System.
                    @raspiuser
                    RaspiUserR Offline
                    RaspiUserR Offline
                    RaspiUser
                    ... jetzt mal für "Blinde":
                    Ich habe vor einem 1/2 Jahr den Adapter installiert, in der Instanz die Daten eingegeben und alles hat funktioniert. In einem "Backup-Server" habe ich nix eingestellt ... (zumindest kann ich mich daran nicht erinnern ...)
                      @raspiuser
                      Ich meine die Kiste (also dein NAS) von der aus du die Freigabe in den iobroker mountest.
                        @fastfoot
                        ... jo
                        fastfoot
                        die QNAP mag einen Stromausfall aber gar nicht, wurdest du danach aufgefordert das Dateisystem zu prüfen? EVTL auch SAMBA neu starten
                        Thomas BraunT RaspiUserR 2 Antworten Letzte Antwort
                        • F fastfoot
                          @fastfoot @RaspiUser
                          Wenn NFS angeboten wird würde ich das auch dem CIFS/SMB vorziehen auf einem Linux.
                          • F fastfoot
                            RaspiUserR Offline
                            RaspiUserR Offline
                            RaspiUser
                            @fastfoot said in backup Adapter 1.7.0 Fehlermeldung:
                            ja, dem Vorgang hatte ich auch zugestimmt, danach die NAS neu gestartet.
                            ... der Haken war so gesetzt ...
                            F 1 Antwort Letzte Antwort
                              @raspiuser
                              RaspiUserR Offline
                              RaspiUserR Offline
                              RaspiUser
                              ... aha ... aber da mußte ich nix einstellen ...
                                @raspiuser
                                Schau mal per
                                RaspiUserR Offline
                                RaspiUserR Offline
                                RaspiUser
                                ... sieht so aus:
                                  fastfoot
                                  weghaken.... Übernehmen... anhaken... Übernehmen(=Neustart). Mir fällt dazu wenig ein, aber wenn der Adaper den Ordner nicht findet bzw im Browser Forbidden kommt, dann stimmt da was mit den Rechten nicht(mehr)
                                    ... sieht so aus:
                                    @raspiuser Dateisystem in den Binsen.
                                    Konsolentext bitte nicht als Screenshot sondern als Text in CodeTags.
                                      RaspiUserR Offline
                                      RaspiUserR Offline
                                      RaspiUser
                                      Klingt nicht gut, Was tun ?
                                      pi@ioBroker-Raspi:~ $ dmesg | grep -i ext4
                                      [    0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835                    .enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=DC:A6:32:12:B4                    :C8 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200                     console=tty1 root=PARTUUID=3c382316-02 rootfstype=ext4 elevator=deadline fsck.re                    pair=yes rootwait
                                      [    1.391418] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesyst                    em
                                      [    1.391455] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
                                      [    1.643498] EXT4-fs (mmcblk0p2): orphan cleanup on readonly fs
                                      [    1.643687] EXT4-fs (mmcblk0p2): 1 orphan inode deleted
                                      [    1.643717] EXT4-fs (mmcblk0p2): recovery complete
                                      [    1.655384] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. O                    pts: (null)
                                      [    1.655491] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                                      [    3.536977] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
                                      sorry ...
                                      • F fastfoot
                                        RaspiUserR Offline
                                        RaspiUserR Offline
                                        RaspiUser
                                        @fastfoot
                                        ... läuft gerade ... ich greife nach jedem Srohhalm ...
                                        • F fastfoot
                                          RaspiUserR Offline
                                          RaspiUserR Offline
                                          RaspiUser
                                          .... läuft gerade ....
