  4. [gelöst] backup Adapter 1.7.0 Fehlermeldung
backup fehlermeldung
29 Beiträge 3 Kommentatoren 3.1k Aufrufe 3 Beobachtet
  • RaspiUserR Offline
    RaspiUserR Offline
    RaspiUser
    schrieb am zuletzt editiert von RaspiUser
    o.g. Adapter hat mit CIFS Einstellung einwandfrei auf einem NAS QNAP 231 die Backups geschrieben.
    Dann gab es einen Stromausfall und nun kommt diese Fehlermeldung und es klappt nicht mehr ...
    Ich habe die NAS neu gestartet und den ioBroker upgedatet (sudo apt-get update).
    ***Gestartet...
    [DEBUG] [mount] - first mount attempt with smb option failed. try next mount attempt without smb option ...
    [ERROR] [mount] - [undefined Error: Command failed: sudo mount -t cifs -o username=admin,password='xxxxxxxx',rw,file_mode=0777,dir_mode=0777 //192.168.178.25/Multimedia/backupDir/ioBroker /opt/iobroker/backups
    mount error(2): No such file or directory
    Refer to the mount.cifs(8) manual page (e.g. man mount.cifs)
    [ERROR] [mount] - [IGNORED] Error: Command failed: sudo mount -t cifs -o username=admin,password='xxxxxxxx',rw,file_mode=0777,dir_mode=0777 //192.168.178.25/Multimedia/backupDir/ioBroker /opt/iobroker/backups
    [DEBUG] [iobroker] - host.ioBroker-Raspi 3752 states saved
    [DEBUG] [iobroker] - host.ioBroker-Raspi 4734 objects saved
    [DEBUG] [iobroker] - Backup created: /opt/iobroker/backups/iobroker_2021_01_25-07_44_56_backupiobroker.tar.gz
    [DEBUG] [iobroker] - done
    [DEBUG] [zigbee] - found zigbee database: zigbee.0
    [DEBUG] [zigbee] - done
    [DEBUG] [cifs] - done
    [ERROR] [clean] - Backup files not deleted from /opt/iobroker/backups because some errors.
    [DEBUG] [clean] - done
    [DEBUG] [history] - backitup.0.history.html
    [DEBUG] [history] - backitup.0.history.json
    [EXIT] 0
    [DEBUG] [telegram] - done
    [EXIT] 0***
    Ich hoffe, jemand kann mir helfen ....
    Thomas BraunT F 2 Antworten Letzte Antwort
    • RaspiUserR RaspiUser
      ***Gestartet...
      [EXIT] 0
      [EXIT] 0***
      @raspiuser Bitte Konsolentext in CodeTags setzen.
      RaspiUserR 1 Antwort Letzte Antwort
        ***Gestartet...
        [EXIT] 0
        [EXIT] 0***
        F Online
        F Online
        fastfoot
        @raspiuser sagte in backup Adapter 1.7.0 Fehlermeldung:
        Probiere mal ob du vom PC auf das Share(//192.168.178.25/Multimedia/backupDir/ioBroker) kommst. Evtl lief da durch den Stromausfall was schief...
        iobroker läuft unter Docker auf QNAP TS-451+
        SkriptRecovery: https://forum.iobroker.net/post/930558
          RaspiUserR Offline
          RaspiUserR Offline
          RaspiUser
          Gestartet...
          [ERROR] [mount] - [undefined Error: Command failed: sudo mount -t cifs -o username=admin,password='xxxxxxxxx',rw,file_mode=0777,dir_mode=0777 //192.168.178.25/Multimedia/backupDir/ioBroker /opt/iobroker/backups
          [ERROR] [mount] - [IGNORED] Error: Command failed: sudo mount -t cifs -o username=admin,password='xxxxxxxxx',rw,file_mode=0777,dir_mode=0777 //192.168.178.25/Multimedia/backupDir/ioBroker /opt/iobroker/backups
          [EXIT] 0
          [EXIT] 0
          OK ... sieht jetzt übersichtlicher aus ...
          • F fastfoot
            RaspiUserR Offline
            RaspiUserR Offline
            RaspiUser
            @fastfoot
            ... aber im Explorer kann ich ohne Probleme auf den Ordner zugreifen ... 🙄
            EDIT: Wenn ich auf die NAS zugreifen will muss ich (natürlich) "admin" und das "Passwort" eingeben. Dann kann o.g. Eingabe auch nicht funktionieren, richtig ?
              @fastfoot
              @raspiuser
              Ich würde sagen da fehlen die Rechte an der Freigabe.
                @raspiuser
                RaspiUserR Offline
                RaspiUserR Offline
                RaspiUser
                @thomas-braun said in backup Adapter 1.7.0 Fehlermeldung:
                @raspiuser
                ... und die können sich durch einen Stromausfall ändern ? D.h. ich gebe die Daten in der Backup Instanz einfach neu in den Einstellungen ein ?!
                  @raspiuser
                  @raspiuser
                  Vermutlich eher auf dem Backup-Server.
                  Da nochmal neuanlegen.
                    @fastfoot
                    F Online
                    F Online
                    fastfoot
                    @fastfoot
                    Im BackitUp Adapter mount as root eingestellt?
                    • F fastfoot
                      @fastfoot
                      RaspiUserR Offline
                      RaspiUserR Offline
                      RaspiUser
                      @fastfoot
                      ... jo
                      "Never change a running system" ist bei mir sehr wichtig, wie beschrieben: Nur der Strom war weg ... (NAS und Raspberry ioBroker auf derselben Sicherung)
                        @fastfoot
                        ... jo
                        @raspiuser
                        Schau mal per
                        dmesg | grep -i ext4
                        über das (Datei)-System.
                          @raspiuser
                          RaspiUserR Offline
                          RaspiUserR Offline
                          RaspiUser
                          ... jetzt mal für "Blinde":
                          Ich habe vor einem 1/2 Jahr den Adapter installiert, in der Instanz die Daten eingegeben und alles hat funktioniert. In einem "Backup-Server" habe ich nix eingestellt ... (zumindest kann ich mich daran nicht erinnern ...)
                            @raspiuser
                            Ich meine die Kiste (also dein NAS) von der aus du die Freigabe in den iobroker mountest.
                              @fastfoot
                              ... jo
                              F Online
                              F Online
                              fastfoot
                              die QNAP mag einen Stromausfall aber gar nicht, wurdest du danach aufgefordert das Dateisystem zu prüfen? EVTL auch SAMBA neu starten
                              Thomas BraunT RaspiUserR 2 Antworten Letzte Antwort
                              • F fastfoot
                                @fastfoot @RaspiUser
                                Wenn NFS angeboten wird würde ich das auch dem CIFS/SMB vorziehen auf einem Linux.
                                • F fastfoot
                                  RaspiUserR Offline
                                  RaspiUserR Offline
                                  RaspiUser
                                  @fastfoot said in backup Adapter 1.7.0 Fehlermeldung:
                                  ja, dem Vorgang hatte ich auch zugestimmt, danach die NAS neu gestartet.
                                  ... der Haken war so gesetzt ...
                                  F 1 Antwort Letzte Antwort
                                    @raspiuser
                                    RaspiUserR Offline
                                    RaspiUserR Offline
                                    RaspiUser
                                    ... aha ... aber da mußte ich nix einstellen ...
                                      @raspiuser
                                      Schau mal per
                                      RaspiUserR Offline
                                      RaspiUserR Offline
                                      RaspiUser
                                      ... sieht so aus:
                                        F Online
                                        F Online
                                        fastfoot
                                        weghaken.... Übernehmen... anhaken... Übernehmen(=Neustart). Mir fällt dazu wenig ein, aber wenn der Adaper den Ordner nicht findet bzw im Browser Forbidden kommt, dann stimmt da was mit den Rechten nicht(mehr)
                                          ... sieht so aus:
                                          @raspiuser Dateisystem in den Binsen.
                                          Konsolentext bitte nicht als Screenshot sondern als Text in CodeTags.
                                          82.9k
