  4. "vis-google-fonts" benötigt?
vis-google-fonts
56 Beiträge 9 Kommentatoren 7.4k Aufrufe 6 Beobachtet
  • S
    S
    Supermicha
    @liv-in-sky
    Möglich, aber der Fehler lief schon ne zeitlang im Log auf... das wäre doch auch jemand anders aufgefallen....
    @Homoran
    welchen Fehler meist du genau?
    Siehst du was im Log? oder meinst du jetzt das allgemeine Problem?
    • S Supermicha
      @liv-in-sky
      @Homoran
      @Supermicha sagte in "vis-google-fonts" benötigt?:
      natürlich!
      not found on this host
      • S Supermicha
        @liv-in-sky
        @Homoran
        @Supermicha Bitte Adapter googlefonts löschen - rebooten - neu installieren
        • S
          S
          Supermicha
          schrieb am zuletzt editiert von Supermicha
          micha@ioBroker:/opt/iobroker$ iobroker del vis-google-fonts
          Delete adapter "vis-google-fonts"
          host.ioBroker Counted 1 meta of vis-google-fonts
          host.ioBroker Counted 1 adapter for vis-google-fonts
          host.ioBroker Counted 2 states (system.adapter.vis-google-fonts.*) from states
          host.ioBroker file vis-google-fonts.admin deleted
          host.ioBroker object vis-google-fonts.admin deleted
          host.ioBroker Deleting 2 object(s).
          host.ioBroker Deleting 2 state(s).
          npm uninstall iobroker.vis-google-fonts --error --prefix "/opt/iobroker" (System call)
          npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@^1.0.7 (node_modules/iobroker.info/node_modules/osx-temperature-sensor):
          npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.7: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
          npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.1.2 (node_modules/chokidar/node_modules/fsevents):
          npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.3: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
          npm WARN babel-eslint@10.1.0 requires a peer of eslint@>= 4.12.1 but none is installed. You must install peer dependencies yourself.
          npm WARN bl@0.7.0 requires a peer of stream-browserify@* but none is installed. You must install peer dependencies yourself.
          Adapter "system.adapter.vis.0" restarted.
          ich starte jetz neu
          • S Supermicha
            ich starte jetz neu
            Thomas BraunT
            Thomas BraunT
            Most Active Developer
            @Supermicha
            Da scheint mir aber ich noch anderes schief zu sein. Die peer dependencies sollten mMn auch installiert sein/werden.
            • S
              S
              Supermicha
              @Thomas-Braun kein Plan...
              hier jetzt der neuinstall
              micha@ioBroker:~$ iobroker install vis-google-fonts
              NPM version: 6.14.8
              npm install iobroker.vis-google-fonts@0.1.0 --loglevel error --prefix "/opt/iobroker" (System call)
              host.ioBroker install adapter vis-google-fonts
              upload [1] vis-google-fonts.admin /opt/iobroker/node_modules/iobroker.vis-google-fonts/admin/vis-google-fonts.png vis-google-fonts.png image/png
              upload [0] vis-google-fonts.admin /opt/iobroker/node_modules/iobroker.vis-google-fonts/admin/index.html index.html text/html
              host.ioBroker object system.adapter.vis-google-fonts created/updated
              • S Supermicha
                ich starte jetz neu
                ich starte jetz neu
                da stimmt bei deiner gogglefonts Installation (oder gar noch tiefer) etwas gar nicht.
                Da können dependencies nicht aufgelöst werden, dann konnten die auch nicht installiert werden
                • S
                  S
                  Supermicha
                  Installfixer mal drüberlaufen lassen?
                  • S Supermicha
                    schadet nie, repariert aber dein deps nicht.
                    aber klappt es denn immer noch nicht?
                    • S
                      S
                      Supermicha
                      nein, es kommt noch die gleiche Fehlermeldung
                      • S
                        S
                        Supermicha
                        Nachtrag:
                        Installfixer laufen lassen, wie du erwartet hast, keine Änderung.
                        • S Supermicha
                          Thomas BraunT
                          Thomas BraunT
                          @Supermicha
                          Ich hab zwar keinen Plan von vis, aber muss man die entsprechenden Fonts nicht separat erstmal auf das System holen?
                          Ich kann mir nicht vorstellen, dass der Adapter das tut.
                            @Supermicha
                            @Thomas-Braun sagte in "vis-google-fonts" benötigt?:
                            doch! Das soll er
                            • S
                              S
                              Supermicha
                              hatte es auch schon mal mit
                              npm install vis-google-fonts
                              versucht, brachte aber auch nix
                              • S Supermicha
                                hoffentlich vorher in /opt/iobroker gewechselt
                                • S
                                  S
                                  Supermicha
                                  @Homoran
                                  ja selbstverständlich
                                  Leute, ich bin mal off und muss zu nem Geburtstag.
                                  Hätte nicht gedacht, das hier Montag Mittag so viele Experten online sind.... :)
                                  Ich bin späterer Nachmittag wieder da...
                                  Schon mal danke bis hierher.
                                  • S Supermicha
                                    @liv-in-sky
                                    hätte ich auch gedacht, aber scheinbar bin ich der einzige mit dem Problem?
                                    GarganoG
                                    GarganoG
                                    Gargano
                                    schrieb am zuletzt editiert von Gargano
                                    @Supermicha hätte ich auch gedacht, aber scheinbar bin ich der einzige mit dem Problem?
                                    Bist Du nicht, bei mir kann ich Material Design Widgets nicht über die Website updaten.
                                    Beim Update Icon kommt 'Keine Versionsinfo für vis-google-fonts'. Nach Installieren von vis-google-fonts ging es dann über die Website upzudaten.
                                    • GarganoG Gargano
                                      @Gargano sagte in "vis-google-fonts" benötigt?:
                                      leider hat @Supermicha die googlefonts installiert
                                        S
                                        S
                                        Speedy012
                                        Ich hatte die Fehlermeldung auch, nach installation von "vis-google-fonts" scheint diese weg zu sein.
                                        • S Supermicha
                                          @liv-in-sky
                                          ScroungerS
                                          ScroungerS
                                          Scrounger
                                          @Supermicha @Gargano
                                          Bin dran den Fehler zu finden. Bitte postet im folgendem Ticket
                                          https://github.com/Scrounger/ioBroker.vis-materialdesign/issues/135
                                          welche Admin Version ihr installiert habt.
                                          84.1k
