  4. "vis-google-fonts" benötigt?
    6.6k
vis-google-fonts
56 Beiträge 9 Kommentatoren 6.4k Aufrufe 6 Beobachtet
  • S Supermicha
    micha@ioBroker:/opt/iobroker$ iobroker del vis-google-fonts
    Delete adapter "vis-google-fonts"
    host.ioBroker Counted 1 meta of vis-google-fonts
    host.ioBroker Counted 1 adapter for vis-google-fonts
    host.ioBroker Counted 2 states (system.adapter.vis-google-fonts.*) from states
    host.ioBroker file vis-google-fonts.admin deleted
    host.ioBroker object vis-google-fonts.admin deleted
    host.ioBroker Deleting 2 object(s).
    host.ioBroker Deleting 2 state(s).
    npm uninstall iobroker.vis-google-fonts --error --prefix "/opt/iobroker" (System call)
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@^1.0.7 (node_modules/iobroker.info/node_modules/osx-temperature-sensor):
    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.7: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.1.2 (node_modules/chokidar/node_modules/fsevents):
    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.3: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
    npm WARN babel-eslint@10.1.0 requires a peer of eslint@>= 4.12.1 but none is installed. You must install peer dependencies yourself.
    npm WARN bl@0.7.0 requires a peer of stream-browserify@* but none is installed. You must install peer dependencies yourself.
    Adapter "system.adapter.vis.0" restarted.
    ich starte jetz neu
    HomoranH Offline
    HomoranH Offline
    @Supermicha sagte in "vis-google-fonts" benötigt?:
    ich starte jetz neu
    da stimmt bei deiner gogglefonts Installation (oder gar noch tiefer) etwas gar nicht.
    Da können dependencies nicht aufgelöst werden, dann konnten die auch nicht installiert werden
      Supermicha
      Installfixer mal drüberlaufen lassen?
      • S Supermicha
        HomoranH Offline
        HomoranH Offline
        schadet nie, repariert aber dein deps nicht.
        aber klappt es denn immer noch nicht?
          Supermicha
          nein, es kommt noch die gleiche Fehlermeldung
            Supermicha
            Nachtrag:
            Installfixer laufen lassen, wie du erwartet hast, keine Änderung.
            • S Supermicha
              @Supermicha
              Ich hab zwar keinen Plan von vis, aber muss man die entsprechenden Fonts nicht separat erstmal auf das System holen?
              Ich kann mir nicht vorstellen, dass der Adapter das tut.
                @Supermicha
                HomoranH Offline
                HomoranH Offline
                @Thomas-Braun sagte in "vis-google-fonts" benötigt?:
                doch! Das soll er
                  Supermicha
                  hatte es auch schon mal mit
                  npm install vis-google-fonts
                  versucht, brachte aber auch nix
                  • S Supermicha
                    HomoranH Offline
                    HomoranH Offline
                    hoffentlich vorher in /opt/iobroker gewechselt
                      Supermicha
                      @Homoran
                      ja selbstverständlich
                      Leute, ich bin mal off und muss zu nem Geburtstag.
                      Hätte nicht gedacht, das hier Montag Mittag so viele Experten online sind.... :)
                      Ich bin späterer Nachmittag wieder da...
                      Schon mal danke bis hierher.
                      • S Supermicha
                        @liv-in-sky
                        hätte ich auch gedacht, aber scheinbar bin ich der einzige mit dem Problem?
                        GarganoG Offline
                        GarganoG Offline
                        Gargano
                        schrieb am zuletzt editiert von Gargano
                        @Supermicha hätte ich auch gedacht, aber scheinbar bin ich der einzige mit dem Problem?
                        Bist Du nicht, bei mir kann ich Material Design Widgets nicht über die Website updaten.
                        Beim Update Icon kommt 'Keine Versionsinfo für vis-google-fonts'. Nach Installieren von vis-google-fonts ging es dann über die Website upzudaten.
                        • GarganoG Gargano
                          HomoranH Offline
                          HomoranH Offline
                          @Gargano sagte in "vis-google-fonts" benötigt?:
                          leider hat @Supermicha die googlefonts installiert
                            Speedy012
                            Ich hatte die Fehlermeldung auch, nach installation von "vis-google-fonts" scheint diese weg zu sein.
                            • S Supermicha
                              @liv-in-sky
                              ScroungerS Offline
                              ScroungerS Offline
                              Scrounger
                              @Supermicha @Gargano
                              Bin dran den Fehler zu finden. Bitte postet im folgendem Ticket
                              https://github.com/Scrounger/ioBroker.vis-materialdesign/issues/135
                              welche Admin Version ihr installiert habt.
                                Supermicha
                                Erledigt.
                                (Admin Version ist 4.1.12)
                                • liv-in-skyL Offline
                                  liv-in-skyL Offline
                                  na super - habe mir gedacht ich mach mal auch das update des adapters - auch bei mir nun der selbe fehler
                                  dann wartn wir mal auf das update
                                  F 1 Antwort Letzte Antwort
                                  • liv-in-skyL liv-in-sky
                                    F Online
                                    F Online
                                    fastfoot
                                    @liv-in-sky sagte in "vis-google-fonts" benötigt?:
                                    du kannst die vis-google-fonts auch aus dem Adapter-Tab installieren, dann klappts
                                    • F fastfoot
                                      liv-in-skyL Offline
                                      liv-in-skyL Offline
                                      @fastfoot
                                      ok - danke hat er gemacht - werd aber erst morgen versuchen den mat. des. widget adapter upzudaten - ich muss dann das "menu app widget" neu konfigurieren - das wird heut nix mehr
                                        Supermicha
                                        @Scrounger
                                        mit der 0.4.2 hats geklappt 👍 👍 👍
                                        • ScroungerS Scrounger
                                          liv-in-skyL Offline
                                          liv-in-skyL Offline
                                          @Scrounger
                                          update hat bei mir auch geklappt - menu app widget umgestellt - danke
                                          und guten rutsch - bis nächstes jahr
