  4. "vis-google-fonts" benötigt?
    6.6k
vis-google-fonts
56 Beiträge 9 Kommentatoren 6.4k Aufrufe 6 Beobachtet
  • S Supermicha
    @liv-in-sky
    Möglich, aber der Fehler lief schon ne zeitlang im Log auf... das wäre doch auch jemand anders aufgefallen....
    @Homoran
    welchen Fehler meist du genau?
    Siehst du was im Log? oder meinst du jetzt das allgemeine Problem?
    @Supermicha sagte in "vis-google-fonts" benötigt?:
    natürlich!
    not found on this host
    • S Supermicha
      @liv-in-sky
      @Homoran
      @Supermicha Bitte Adapter googlefonts löschen - rebooten - neu installieren
        Supermicha
        schrieb am zuletzt editiert von Supermicha
        micha@ioBroker:/opt/iobroker$ iobroker del vis-google-fonts
        Delete adapter "vis-google-fonts"
        host.ioBroker Counted 1 meta of vis-google-fonts
        host.ioBroker Counted 1 adapter for vis-google-fonts
        host.ioBroker Counted 2 states (system.adapter.vis-google-fonts.*) from states
        host.ioBroker file vis-google-fonts.admin deleted
        host.ioBroker object vis-google-fonts.admin deleted
        host.ioBroker Deleting 2 object(s).
        host.ioBroker Deleting 2 state(s).
        npm uninstall iobroker.vis-google-fonts --error --prefix "/opt/iobroker" (System call)
        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@^1.0.7 (node_modules/iobroker.info/node_modules/osx-temperature-sensor):
        npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.7: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.1.2 (node_modules/chokidar/node_modules/fsevents):
        npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.3: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
        npm WARN babel-eslint@10.1.0 requires a peer of eslint@>= 4.12.1 but none is installed. You must install peer dependencies yourself.
        npm WARN bl@0.7.0 requires a peer of stream-browserify@* but none is installed. You must install peer dependencies yourself.
        Adapter "system.adapter.vis.0" restarted.
        ich starte jetz neu
        • S Supermicha
          ich starte jetz neu
          @Supermicha
          Da scheint mir aber ich noch anderes schief zu sein. Die peer dependencies sollten mMn auch installiert sein/werden.
            Supermicha
            @Thomas-Braun kein Plan...
            hier jetzt der neuinstall
            micha@ioBroker:~$ iobroker install vis-google-fonts
            NPM version: 6.14.8
            npm install iobroker.vis-google-fonts@0.1.0 --loglevel error --prefix "/opt/iobroker" (System call)
            host.ioBroker install adapter vis-google-fonts
            upload [1] vis-google-fonts.admin /opt/iobroker/node_modules/iobroker.vis-google-fonts/admin/vis-google-fonts.png vis-google-fonts.png image/png
            upload [0] vis-google-fonts.admin /opt/iobroker/node_modules/iobroker.vis-google-fonts/admin/index.html index.html text/html
            host.ioBroker object system.adapter.vis-google-fonts created/updated
            • S Supermicha
              ich starte jetz neu
              ich starte jetz neu
              da stimmt bei deiner gogglefonts Installation (oder gar noch tiefer) etwas gar nicht.
              Da können dependencies nicht aufgelöst werden, dann konnten die auch nicht installiert werden
                Supermicha
                Installfixer mal drüberlaufen lassen?
                • S Supermicha
                  schadet nie, repariert aber dein deps nicht.
                  aber klappt es denn immer noch nicht?
                    Supermicha
                    nein, es kommt noch die gleiche Fehlermeldung
                      Supermicha
                      Nachtrag:
                      Installfixer laufen lassen, wie du erwartet hast, keine Änderung.
                      • S Supermicha
                        @Supermicha
                        Ich hab zwar keinen Plan von vis, aber muss man die entsprechenden Fonts nicht separat erstmal auf das System holen?
                        Ich kann mir nicht vorstellen, dass der Adapter das tut.
                          @Supermicha
                          @Thomas-Braun sagte in "vis-google-fonts" benötigt?:
                          doch! Das soll er
                            Supermicha
                            hatte es auch schon mal mit
                            npm install vis-google-fonts
                            versucht, brachte aber auch nix
                            • S Supermicha
                              hoffentlich vorher in /opt/iobroker gewechselt
                                Supermicha
                                @Homoran
                                ja selbstverständlich
                                Leute, ich bin mal off und muss zu nem Geburtstag.
                                Hätte nicht gedacht, das hier Montag Mittag so viele Experten online sind.... :)
                                Ich bin späterer Nachmittag wieder da...
                                Schon mal danke bis hierher.
                                • S Supermicha
                                  @liv-in-sky
                                  hätte ich auch gedacht, aber scheinbar bin ich der einzige mit dem Problem?
                                  GarganoG Offline
                                  GarganoG Offline
                                  Gargano
                                  schrieb am zuletzt editiert von Gargano
                                  @Supermicha hätte ich auch gedacht, aber scheinbar bin ich der einzige mit dem Problem?
                                  Bist Du nicht, bei mir kann ich Material Design Widgets nicht über die Website updaten.
                                  Beim Update Icon kommt 'Keine Versionsinfo für vis-google-fonts'. Nach Installieren von vis-google-fonts ging es dann über die Website upzudaten.
                                  • GarganoG Gargano
                                    @Gargano sagte in "vis-google-fonts" benötigt?:
                                    leider hat @Supermicha die googlefonts installiert
                                      Speedy012
                                      Ich hatte die Fehlermeldung auch, nach installation von "vis-google-fonts" scheint diese weg zu sein.
                                      • S Supermicha
                                        @liv-in-sky
                                        ScroungerS Offline
                                        ScroungerS Offline
                                        Scrounger
                                        @Supermicha @Gargano
                                        Bin dran den Fehler zu finden. Bitte postet im folgendem Ticket
                                        https://github.com/Scrounger/ioBroker.vis-materialdesign/issues/135
                                        welche Admin Version ihr installiert habt.
                                          Supermicha
                                          Erledigt.
                                          (Admin Version ist 4.1.12)
