  4. "vis-google-fonts" benötigt?
    6.6k
vis-google-fonts
56 Beiträge 9 Kommentatoren 6.4k Aufrufe 6 Beobachtet
    Supermicha
    @Thomas-Braun kein Plan...
    hier jetzt der neuinstall
    micha@ioBroker:~$ iobroker install vis-google-fonts
    NPM version: 6.14.8
    npm install iobroker.vis-google-fonts@0.1.0 --loglevel error --prefix "/opt/iobroker" (System call)
    host.ioBroker install adapter vis-google-fonts
    upload [1] vis-google-fonts.admin /opt/iobroker/node_modules/iobroker.vis-google-fonts/admin/vis-google-fonts.png vis-google-fonts.png image/png
    upload [0] vis-google-fonts.admin /opt/iobroker/node_modules/iobroker.vis-google-fonts/admin/index.html index.html text/html
    Adapter "system.adapter.vis.0" restarted.
    host.ioBroker object system.adapter.vis-google-fonts created/updated
    • S Supermicha
      micha@ioBroker:/opt/iobroker$ iobroker del vis-google-fonts
      Delete adapter "vis-google-fonts"
      host.ioBroker Counted 1 meta of vis-google-fonts
      host.ioBroker Counted 1 adapter for vis-google-fonts
      host.ioBroker Counted 2 states (system.adapter.vis-google-fonts.*) from states
      host.ioBroker file vis-google-fonts.admin deleted
      host.ioBroker object vis-google-fonts.admin deleted
      host.ioBroker Deleting 2 object(s).
      host.ioBroker Deleting 2 state(s).
      npm uninstall iobroker.vis-google-fonts --error --prefix "/opt/iobroker" (System call)
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@^1.0.7 (node_modules/iobroker.info/node_modules/osx-temperature-sensor):
      npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.7: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.1.2 (node_modules/chokidar/node_modules/fsevents):
      npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.3: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
      npm WARN babel-eslint@10.1.0 requires a peer of eslint@>= 4.12.1 but none is installed. You must install peer dependencies yourself.
      npm WARN bl@0.7.0 requires a peer of stream-browserify@* but none is installed. You must install peer dependencies yourself.
      ich starte jetz neu
      HomoranH Offline
      HomoranH Offline
      @Supermicha sagte in "vis-google-fonts" benötigt?:
      ich starte jetz neu
      da stimmt bei deiner gogglefonts Installation (oder gar noch tiefer) etwas gar nicht.
      Da können dependencies nicht aufgelöst werden, dann konnten die auch nicht installiert werden
        Supermicha
        Installfixer mal drüberlaufen lassen?
        • S Supermicha
          HomoranH Offline
          HomoranH Offline
          schadet nie, repariert aber dein deps nicht.
          aber klappt es denn immer noch nicht?
            Supermicha
            nein, es kommt noch die gleiche Fehlermeldung
              Supermicha
              Nachtrag:
              Installfixer laufen lassen, wie du erwartet hast, keine Änderung.
              • S Supermicha
                @Supermicha
                Ich hab zwar keinen Plan von vis, aber muss man die entsprechenden Fonts nicht separat erstmal auf das System holen?
                Ich kann mir nicht vorstellen, dass der Adapter das tut.
                  @Supermicha
                  HomoranH Offline
                  HomoranH Offline
                  @Thomas-Braun sagte in "vis-google-fonts" benötigt?:
                  doch! Das soll er
                    Supermicha
                    hatte es auch schon mal mit
                    npm install vis-google-fonts
                    versucht, brachte aber auch nix
                    • S Supermicha
                      HomoranH Offline
                      HomoranH Offline
                      hoffentlich vorher in /opt/iobroker gewechselt
                        Supermicha
                        @Homoran
                        ja selbstverständlich
                        Leute, ich bin mal off und muss zu nem Geburtstag.
                        Hätte nicht gedacht, das hier Montag Mittag so viele Experten online sind.... :)
                        Ich bin späterer Nachmittag wieder da...
                        Schon mal danke bis hierher.
                        • S Supermicha
                          @liv-in-sky
                          hätte ich auch gedacht, aber scheinbar bin ich der einzige mit dem Problem?
                          GarganoG Offline
                          GarganoG Offline
                          Gargano
                          schrieb am zuletzt editiert von Gargano
                          @Supermicha hätte ich auch gedacht, aber scheinbar bin ich der einzige mit dem Problem?
                          Bist Du nicht, bei mir kann ich Material Design Widgets nicht über die Website updaten.
                          Beim Update Icon kommt 'Keine Versionsinfo für vis-google-fonts'. Nach Installieren von vis-google-fonts ging es dann über die Website upzudaten.
                          • GarganoG Gargano
                            HomoranH Offline
                            HomoranH Offline
                            @Gargano sagte in "vis-google-fonts" benötigt?:
                            leider hat @Supermicha die googlefonts installiert
                              Speedy012
                              Ich hatte die Fehlermeldung auch, nach installation von "vis-google-fonts" scheint diese weg zu sein.
                              • S Supermicha
                                @liv-in-sky
                                ScroungerS Offline
                                ScroungerS Offline
                                Scrounger
                                @Supermicha @Gargano
                                Bin dran den Fehler zu finden. Bitte postet im folgendem Ticket
                                https://github.com/Scrounger/ioBroker.vis-materialdesign/issues/135
                                welche Admin Version ihr installiert habt.
                                  Supermicha
                                  Erledigt.
                                  (Admin Version ist 4.1.12)
                                  • liv-in-skyL Offline
                                    liv-in-skyL Offline
                                    na super - habe mir gedacht ich mach mal auch das update des adapters - auch bei mir nun der selbe fehler
                                    dann wartn wir mal auf das update
                                    F 1 Antwort Letzte Antwort
                                    • liv-in-skyL liv-in-sky
                                      F Online
                                      F Online
                                      fastfoot
                                      @liv-in-sky sagte in "vis-google-fonts" benötigt?:
                                      du kannst die vis-google-fonts auch aus dem Adapter-Tab installieren, dann klappts
                                      • F fastfoot
                                        liv-in-skyL Offline
                                        liv-in-skyL Offline
                                        @fastfoot
                                        ok - danke hat er gemacht - werd aber erst morgen versuchen den mat. des. widget adapter upzudaten - ich muss dann das "menu app widget" neu konfigurieren - das wird heut nix mehr
                                          Supermicha
                                          @Scrounger
                                          mit der 0.4.2 hats geklappt 👍 👍 👍
