  4. Test Adapter enigma2 v1.2.x
adapterenigma2
640 Beiträge 71 Kommentatoren 246.5k Aufrufe 60 Beobachtet
  • hg6806H hg6806
    Seit 1 Woche habe ich nun eine Dreambox One, jedoch bleibt der Adapter immer rot.
    Weiß jemand ob und was da anders ist? Port 80?
    Hier ein Log:
    enigma2.0	2020-12-16 13:16:53.305	error	(30964) TypeError: Cannot read property 'e2currentserviceinformation' of undefined at evaluateCommandResponse (/opt/iobroker/node_modules/iobroker.enigma2/enigma2.js:436:10) at /opt/iobroker/n
    enigma2.0	2020-12-16 13:16:53.305	error	(30964) uncaught exception: Cannot read property 'e2currentserviceinformation' of undefined
    enigma2.0	2020-12-16 13:16:53.301	error	(30964) TypeError: Cannot read property 'e2volume' of undefined at evaluateCommandResponse (/opt/iobroker/node_modules/iobroker.enigma2/enigma2.js:416:13) at /opt/iobroker/node_modules/iobroke
    enigma2.0	2020-12-16 13:16:53.300	error	(30964) uncaught exception: Cannot read property 'e2volume' of undefined
    enigma2.0	2020-12-16 13:16:53.296	error	(30964) TypeError: Cannot read property 'e2abouts' of undefined at evaluateCommandResponse (/opt/iobroker/node_modules/iobroker.enigma2/enigma2.js:547:51) at /opt/iobroker/node_modules/iobroke
    enigma2.0	2020-12-16 13:16:53.295	error	(30964) uncaught exception: Cannot read property 'e2abouts' of undefined
    enigma2.0	2020-12-16 13:16:53.291	error	(30964) TypeError: Cannot read property 'e2simplexmlresult' of undefined at evaluateCommandResponse (/opt/iobroker/node_modules/iobroker.enigma2/enigma2.js:382:46) at /opt/iobroker/node_module
    enigma2.0	2020-12-16 13:16:53.291	error	(30964) uncaught exception: Cannot read property 'e2simplexmlresult' of undefined
    enigma2.0	2020-12-16 13:16:53.281	error	(30964) TypeError: Cannot read property 'e2powerstate' of undefined at evaluateCommandResponse (/opt/iobroker/node_modules/iobroker.enigma2/enigma2.js:403:63) at /opt/iobroker/node_modules/iob
    enigma2.0	2020-12-16 13:16:53.280	error	(30964) uncaught exception: Cannot read property 'e2powerstate' of undefined
    Irgendwie scheint die Box keine Verbindung zu bekommen. IP, Benutzer und PW stimmen aber.
    Meister MopperM
    Meister MopperM
    Meister Mopper
    #366
    @hg6806 Wie ist das webinterface eingestellt: http oder https?
    Proxmox und HA ...
    • hg6806H hg6806
      Hier ein Log:
      E
      E
      el_malto
      #367
      @hg6806 wenn du das originale DreamOS drauf hast, benutzt dieses nicht das OpenWebIF sonder das Webinterface. Du musst in den Adaptereinstellungen unter "Webinterface Version" das "Dream Webinterface" auswählen.
      Ansonsten kann du auch das OpenWebTF nachinstallieren. Müsstest halt höchstens die Ports anpassen und dann kann der Adapter über das OpenWebIF laufen.
      hg6806H 1 Antwort Letzte Antwort
      • E el_malto
        hg6806H
        hg6806H
        hg6806
        #368
        @el_malto
        Wo finde ich denn die Adaptereinstellungen?
        In der Adapterkonfiguration ist nichts.
        • hg6806H hg6806
          @el_malto
          dslraserD
          dslraserD
          dslraser
          #369
          @hg6806 sagte in Test Adapter enigma2 v1.2.x:
          @el_malto
          • dslraserD dslraser
            @el_malto
            hg6806H
            hg6806H
            hg6806
            #370
            @dslraser
            Ähhh, und genau das fehlt mir
            J haselchenH 2 Antworten Letzte Antwort
            • hg6806H hg6806
              @dslraser
              J
              J
              Jan1
              #371
              @hg6806
              welche Adapter Version läuft denn bei Dir?
              • hg6806H hg6806
                @dslraser
                haselchenH
                haselchenH
                haselchen
                #372
                @hg6806
                Von den Screenshots her habt ihr beide verschiedene Adapter Versionen.
                • haselchenH haselchen
                  @hg6806
                  hg6806H
                  hg6806H
                  hg6806
                  #373
                  V1.2.3, was neueres wird mir nicht angeboten
                  dslraserD J 2 Antworten Letzte Antwort
                  • hg6806H hg6806
                    dslraserD
                    dslraserD
                    dslraser
                    #374
                    • hg6806H hg6806
                      J
                      J
                      Jan1
                      #375
                      @hg6806
                      normal endet hier die Hilfe, wenn einer nicht in der Lage ist den ersten und meist wichtigsten Post eines Adapter Thread zu lesen.
                      • hg6806H
                        hg6806H
                        hg6806
                        #376
                        Sorry, hatte übersehen dass es auf Git neuere Versionen gibt.
                        Habe Dream Webinterface eingestellt, geht aber leider immer noch nicht.
                        Muss ich auf der Box noch was einstellen?
                        • hg6806H hg6806
                          J
                          J
                          Jan1
                          #377
                          @hg6806
                          Schalt mal in den Einstellungen der Box das ganze Firewall Zeug aus.
                          • J Jan1
                            @hg6806
                            hg6806H
                            hg6806H
                            hg6806
                            #378
                            @Jan1
                            Klappt. Tausend Dank!
                            • hg6806H hg6806
                              @Jan1
                              J
                              J
                              Jan1
                              #379
                              @hg6806
                              Dann kannst das mal wieder eins nach dem anderen anschalten uns schauen welche Einstellung den Adapter blockiert.
                              • J Jan1
                                @hg6806
                                hg6806H
                                hg6806H
                                hg6806
                                #380
                                @Jan1 ok
                                • S
                                  S
                                  Sekretär
                                  #381
                                  Hallo, ich hatte heute mal wieder etwas Zeit zum spielen. Habe im Enigma2 Adapter den vorhandenen Punkt enigma2.0./command REMOTE-CONTROL "enigma2 send remote control command as number" über Alexa eingebunden. Das funktioniert aber die Zahl stimmt nicht. Ich sage "schalte Fernseher 3" und es wird auf Kanal 2 geschalten. Ich weiß nicht wo die Zahlen im Adapter hinterlegt sind und an meiner Dreambox kann ich keinen Kanal "0" anlegen. Sonst würde es ja vielleicht funktionieren.
                                  Kann da jemand helfen?
                                  • S Sekretär
                                    NegaleinN
                                    NegaleinN
                                    Negalein
                                    #382
                                    @Sekretär sagte in Test Adapter enigma2 v1.2.x:
                                    3=2
                                    4=3
                                    usw.
                                    116 Key "Power"
                                    2   Key "1"
                                    3   Key "2"
                                    4   Key "3"
                                    5   Key "4"
                                    6   Key "5"
                                    7   Key "6"
                                    8   Key "7"
                                    9   Key "8"
                                    10  Key "1"
                                    11  Key "0"
                                    412 Key "previous"
                                    407 Key "next
                                    115 Key "volume up"
                                    113 Key "mute"
                                    402 Key "bouquet up"
                                    114 Key "volume down"
                                    174 Key "lame"
                                    403 Key "bouquet down"
                                    358 Key "info"
                                    103 Key "up"
                                    139 Key "menu"
                                    105 Key "left"
                                    352 Key "OK"
                                    106 Key "right"
                                    392 Key "audio"
                                    108 Key "down"
                                    393 Key "video"
                                    398 Key "red"
                                    399 Key "green"
                                    400 Key "yellow"
                                    401 Key "blue"
                                    377 Key "tv"
                                    385 Key "radio"
                                    388 Key "text"
                                    138 Key "help"
                                    ° Fixer ---> iob fix
                                    • S
                                      S
                                      Sekretär
                                      #383
                                      Das ist gut aber ich habe noch gar keine Zahlen vergeben. Irgendwo muss die Zahl ja herkommen? Ich habe einfach im iot.0
                                      den Punkt:
                                      Fernseher
                                      angelegt, der wird von Alexa erkannt und es wird umgeschaltet. Wo kommt dann die Zahl her?
                                      • S Sekretär
                                        den Punkt:
                                        Fernseher
                                        NegaleinN
                                        NegaleinN
                                        Negalein
                                        #384
                                        Und wenn du sagst "schalte Fernseher 2", schaltet er vermutlich auf Kanal 1.
                                        Besser ist, du schaltest mit der ServiceReference die Sender um.
                                        Such hier im Thread die Beiträge von DSLraser.
                                        Er hat ein sehr gutes Blockly dafür.
                                        • NegaleinN Negalein
                                          dslraserD
                                          dslraserD
                                          dslraser
                                          #385
                                          @Negalein @Sekretär
                                          hier ging es auch gerade um das Thema Sender schalten. Da habe ich gerade beschrieben wie ich es mache.
                                          https://forum.iobroker.net/post/542926
                                          83.9k
