  4. npm raspi-i2c modul ladefehler
moduleraspi-i2ci2c
41 Beiträge 6 Kommentatoren 5.4k Aufrufe 5 Beobachtet
  • G grooovie
    @UncleSam
    ich habe versucht den i2c adapter zu benutzen, aber der bricht immer mit fehler ab:
    host.PoststrasseZentralheizung	2020-10-09 16:45:02.561	info	iobroker exit 25
    host.PoststrasseZentralheizung	2020-10-09 16:45:01.529	error	iobroker host.PoststrasseZentralheizung Cannot install iobroker.i2c@0.0.6: 1
    host.PoststrasseZentralheizung	2020-10-09 16:45:01.500	info	iobroker npm ERR! A complete log of this run can be found in:npm ERR! /home/iobroker/.npm/_logs/2020-10-09T14_45_01_465Z-debug.log
    host.PoststrasseZentralheizung	2020-10-09 16:45:01.453	info	iobroker npm ERR! i2c-bus@1.2.5 install: `node-gyp rebuild`npm ERR! Exit status 1npm ERR! npm ERR! Failed at the i2c-bus@1.2.5 install script.npm ERR! This is probably not a problem with npm. There i
    host.PoststrasseZentralheizung	2020-10-09 16:45:01.434	info	iobroker npm ERR! code ELIFECYCLEnpm ERR! errno 1
    host.PoststrasseZentralheizung	2020-10-09 16:45:00.110	info	iobroker gyp ERR! System Linux 5.4.51-v7+gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"gyp ERR! cwd /opt/iobroker/node_modules/i2c-busgyp
    host.PoststrasseZentralheizung	2020-10-09 16:45:00.107	info	iobroker gyp ERR! stack Error: `make` failed with exit code: 2gyp ERR! stack at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:194:23)gyp ERR! stack at Chil
    host.PoststrasseZentralheizung	2020-10-09 16:45:00.103	info	iobroker ERR! build error
    host.PoststrasseZentralheizung	2020-10-09 16:45:00.100	info	iobroker gyp
    host.PoststrasseZentralheizung	2020-10-09 16:45:00.094	info	iobroker make: *** [i2c.target.mk:111: Release/obj.target/i2c/src/i2c.o] Error 1
    host.PoststrasseZentralheizung	2020-10-09 16:44:58.063	info	iobroker In file included from ../src/i2c.cc:107:../src/./writequick.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE WriteQuickSync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./writequick.cc:60:32: error: no ma
    host.PoststrasseZentralheizung	2020-10-09 16:44:58.061	info	iobroker In file included from /home/iobroker/.cache/node-gyp/12.19.0/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.19.0/include/node/v8.h:2709:40: no
    host.PoststrasseZentralheizung	2020-10-09 16:44:58.058	info	iobroker In file included from ../src/i2c.cc:107:../src/./writequick.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE WriteQuickAsync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./writequick.cc:47:32: error: no m
    host.PoststrasseZentralheizung	2020-10-09 16:44:58.052	info	iobroker In file included from ../src/i2c.cc:106:../src/./writei2cblock.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE WriteI2cBlockSync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./writei2cblock.cc:108:32: er
    host.PoststrasseZentralheizung	2020-10-09 16:44:58.048	info	iobroker In file included from /home/iobroker/.cache/node-gyp/12.19.0/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.19.0/include/node/v8.h:2709:40: no
    host.PoststrasseZentralheizung	2020-10-09 16:44:58.045	info	iobroker In file included from ../src/i2c.cc:106:../src/./writei2cblock.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE WriteI2cBlockAsync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./writei2cblock.cc:68:32: er
    host.PoststrasseZentralheizung	2020-10-09 16:44:58.039	info	iobroker In file included from ../src/i2c.cc:105:../src/./writeblock.cc:112:39: error: no matching function for call to ‘v8::Value::Uint32Value()’ __u32 length = info[2]->Uint32Value();
    host.PoststrasseZentralheizung	2020-10-09 16:44:58.036	info	iobroker In file included from ../src/i2c.cc:105:../src/./writeblock.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE WriteBlockSync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./writeblock.cc:110:32: error: no m
    host.PoststrasseZentralheizung	2020-10-09 16:44:58.033	info	iobroker In file included from /home/iobroker/.cache/node-gyp/12.19.0/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.19.0/include/node/v8.h:2709:40: no
    host.PoststrasseZentralheizung	2020-10-09 16:44:58.030	info	iobroker In file included from ../src/i2c.cc:105:../src/./writeblock.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE WriteBlockAsync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./writeblock.cc:70:32: error: no m
    host.PoststrasseZentralheizung	2020-10-09 16:44:58.023	info	iobroker In file included from ../src/i2c.cc:104:../src/./writeword.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE WriteWordSync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./writeword.cc:64:32: error: no match
    host.PoststrasseZentralheizung	2020-10-09 16:44:58.020	info	iobroker In file included from /home/iobroker/.cache/node-gyp/12.19.0/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.19.0/include/node/v8.h:2709:40: no
    host.PoststrasseZentralheizung	2020-10-09 16:44:58.017	info	iobroker In file included from ../src/i2c.cc:104:../src/./writeword.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE WriteWordAsync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./writeword.cc:49:32: error: no matc
    host.PoststrasseZentralheizung	2020-10-09 16:44:58.013	info	iobroker In file included from ../src/i2c.cc:103:../src/./writebyte.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE WriteByteSync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./writebyte.cc:63:32: error: no match
    host.PoststrasseZentralheizung	2020-10-09 16:44:58.010	info	iobroker In file included from /home/iobroker/.cache/node-gyp/12.19.0/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.19.0/include/node/v8.h:2709:40: no
    host.PoststrasseZentralheizung	2020-10-09 16:44:58.006	info	iobroker In file included from ../src/i2c.cc:103:../src/./writebyte.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE WriteByteAsync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./writebyte.cc:49:32: error: no matc
    host.PoststrasseZentralheizung	2020-10-09 16:44:58.002	info	iobroker In file included from ../src/i2c.cc:102:../src/./setaddr.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE SetAddrSync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./setaddr.cc:61:32: error: no matching fu
    host.PoststrasseZentralheizung	2020-10-09 16:44:57.999	info	iobroker /home/iobroker/.cache/node-gyp/12.19.0/include/node/v8.h:2699:8: note: candidate expects 1 argument, 0 providedIn file included from /home/iobroker/.cache/node-gyp/12.19.0/include/node/v8-
    @grooovie sagte in npm raspi-i2c modul ladefehler:
    writequick.cc
    Hast du das Paket libi2c-dev installiert?
    sudo apt update
    sudo apt install libi2c-dev build-essential
    G 2 Antworten Letzte Antwort
      writequick.cc
      sudo apt update
      grooovie
      @Thomas-Braun ```
      @PoststrasseZentralheizung:~ $ sudo apt update
      Hit:1 http://archive.raspberrypi.org/debian buster InRelease
      Get:2 http://raspbian.raspberrypi.org/raspbian buster InRelease [15.0 kB]
      Hit:3 https://deb.nodesource.com/node_12.x buster InRelease
      Fetched 15.0 kB in 2s (9,911 B/s)
      Reading package lists... Done
      Building dependency tree
      All packages are up to date.
      pi@PoststrasseZentralheizung:~ $ sudo apt install libi2c-dev build-essential
      build-essential is already the newest version (12.6).
      libi2c-dev is already the newest version (4.1-1).
      0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
      pi@PoststrasseZentralheizung:~ $ sudo reboot
        writequick.cc
        sudo apt update
        grooovie
        @Thomas-Braun
        das script besteht nur aus einer zeile:
        const I2C = require('raspi-i2c').I2C;
        G 1 Antwort Letzte Antwort
        • G grooovie
          @Thomas-Braun
          grooovie
          nach dem starten des scripts bekomme ich das:
          17:24:25.123	info	javascript.2 (531) Start javascript script.js.Mein_Haus.Poststrasse.Heizung
          17:24:25.143	error	javascript.2 (531) script.js.Mein_Haus.Poststrasse.Heizung: Error: Cannot find module '/opt/iobroker/node_modules/iobroker.javascript/lib/../../raspi-i2c'
          17:24:25.146	error	javascript.2 (531) at script.js.Mein_Haus.Poststrasse.Heizung:3:13
          17:24:25.151	error	javascript.2 (531) script.js.Mein_Haus.Poststrasse.Heizung: script.js.Mein_Haus.Poststrasse.Heizung:3
          17:24:25.155	error	javascript.2 (531) at script.js.Mein_Haus.Poststrasse.Heizung:3:33
          17:24:26.060	info	javascript.2 (531) Stop script script.js.Mein_Haus.Poststrasse.Heizung
          • G grooovie
            grooovie
            installiert habe ich alles wie von Alcalzone am 13.7. vorgeschlagen. leider ohne erfolg
            • G grooovie
              AlCalzoneA Offline
              AlCalzoneA Offline
              AlCalzone
              @grooovie Es ist vollkommen egal, wie viele Zeilen das Skript hat. Es lädt eine Abhängigkeit, die nicht vollständig installiert ist und dann ist Schicht im Schacht.
              Was ist die vollständige Ausgabe dieser Installation?
              • G grooovie
                es ist bisher immer noch nicht möglich das modul zu laden.
                ich habe jetzt einen raspi 3b+ in das multihostsystem eingebunden, eine weitere JAVASCCRIPT instanz 4.6.17 installiert
                doch es ist nicht möglich das modul zu nutzen, er findet es nicht, genau wie oben beschrieben.
                gibt es denn kein vernünftige möglichkeit? bin ich der einzigste der i2c auf einem raspi in iobroker nutzt?
                GlasfaserG Offline
                GlasfaserG Offline
                @AlCalzone
                Kenne mich mit dem Modul nicht aus ... muß das bei einem neuen PI nicht erst in der Rasp Config freigeschaltet werden , oder hat das damit nichts zu tun wegen der Fehlermeldung .
                AlCalzoneA G 2 Antworten Letzte Antwort
                • GlasfaserG Glasfaser
                  @AlCalzone
                  AlCalzoneA Offline
                  AlCalzoneA Offline
                  AlCalzone
                  @Glasfaser glaube das will das Modul selbst machen - was die Installationsprobleme erst verursacht.
                    @AlCalzone
                    grooovie
                    @Glasfaser
                    mit raspi config habe ich den i2c bus feigeschaltet falls ihr das meint
                    die Hardware funktioniert meiner meinung nach
                    pi@PoststrasseZentralheizung:~ $ i2cdetect -y 1
                         0  1  2  3  4  5  6  7  8  9  a  b  c  d  e  f
                    00:          -- -- -- -- -- -- -- -- -- -- -- -- --
                    10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
                    20: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
                    30: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
                    40: -- -- -- -- -- -- -- -- 48 -- -- -- -- -- -- --
                    50: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
                    60: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
                    70: -- -- -- -- -- -- -- --
                    • G grooovie
                      @UncleSam
                      UncleSamU Offline
                      UncleSamU Offline
                      UncleSam
                      @grooovie Sorry ich bin mit dem Handy unterwegs. Was hast du denn für eine Node Version?
                      Kannst du mal in irgend ein leeres Verzeichnis auf dem Raspi gehen (z.B. ~/mein-test/) und dort npm install i2c-bus machen? Geht das? Hast du die gesamte Anleitung auf der Modul-Seite befolgt? https://www.npmjs.com/package/i2c-bus#installation
                      Wenn du übrigens meinen Adapter installieren willst, nimm bitte die Version von Github (nicht von npm, die ist veraltet).
                      Bitte bei Problemen mit meinen Adaptern, Issue auf GitHub erfassen: Loxone | I2C | Luxtronik2
                      ♡-lichen Dank an meine Sponsoren
                      • G grooovie
                        Guten Abend.
                        Seit Tagen versuche ich den Raspi-I2C in JS zu nutzen.
                        gefunden habe ich den hier: https://www.npmjs.com/package/raspi-i2c
                        Ich habe IO Broker auf einem Nuke und ein Slave auf einem Raspi 4
                        auf beiden maschinen sind folgende versionen
                        am raspi habe ich einen i2c extender angeschlossen, adresse 3e, der bus ist in der config configuriert
                        mit i2cdetect - y 1
                        erhalte ich das
                        ich schliesse daraus dass die verbindung i2c modul - raspberry funktioniert
                        nun wollte ich das in java script auch ansprechen und habe JS auf dem Pi installiert
                        aber ich erhalte immer eine fehlermeldung
                        ich komme hier einfach nicht weiter, habe alles nochmal "sauber" installiert aber selber effekt
                        UncleSamU Offline
                        UncleSamU Offline
                        UncleSam
                        @grooovie Ich sehe gerade, dass du raspi-i2c verwendest. Gibt es einen Grund, weshalb du das und nicht i2c-bus benutzt? Ich kenne ersteres nicht und es wurde auch schon ein Jahr nicht mehr aktualisiert. Mit i2c-bus hatte ich bis jetzt noch nie Probleme (ausser mit veralteten Versionen - deshalb bitte Github Version meines Adapters verwenden).
                        • AlCalzoneA AlCalzone
                          AlCalzoneA Offline
                          AlCalzoneA Offline
                          AlCalzone
                          @grooovie Ich versuchs nochmal... Ohne dass du die benötigten Infos lieferst, kann man dir nicht helfen:
                          @AlCalzone sagte in npm raspi-i2c modul ladefehler:
                          • UncleSamU UncleSam
                            grooovie
                            @UncleSam das klappt gut mit der installation
                            also der von npm ist veraltet und kann nicht installiert werden.
                            von github funktioniert die installation deines adapters exit code 0
                            das nächste problem, er wird bei den instanzen nicht angezeigt. auch wollte ich ihn auf einen bestimmten host im multihost system installieren. ichhabe aber nicht gefunden wo man das auswählt. da benötige ich noch ein bischen hilfe bitte
                            gedrückt hatte ich "adapter" dann installieren aus eigener url
                            dann die tab "von github" dann i2c eingegeben, i2c(unclesamswiss) ausgewählt und "installieren" gedrückt.
                            dann ist die installation abeglaufen mit exit code 0
                            G UncleSamU 2 Antworten Letzte Antwort
                              grooovie
                              schrieb am zuletzt editiert von grooovie
                              @AlCalzone ich habe herausgefunden das die installation funktioniert wie von dir am 13.7. vorgeschlagen, allerdings muss man vorher noch die rechte freigeben, das habe ich dann so gemacht
                              sudo chmod 777 /opt/iobroker/node_modules/iobroker.javascript/lib
                              aber wie gesagt, ein JS update hatte damals alles zunichte gemacht, die neue 4.9 habe ich noch nicht probiert da das vom juli erst mal läuft...never touch a running system. mit der 4.6.17 funktioniert es tadellos.
                              für mein neues projekt wäre es prima einfach den i2c adapter zu installieren, das versuche ich gerade hier im selben thread mit unclesam zu erledigen
                              • G grooovie
                                grooovie
                                nach der installation, wenn ich oben den host auswähle wird der i2c adapter als installiert angezeigt, bei all anderen hosts nur die verfügbare version
                                bei den instanzen finde ich nichts, auch nicht bei den anderen hosts
                                • G grooovie
                                  GlasfaserG Offline
                                  GlasfaserG Offline
                                  @grooovie
                                  du hast auch keine Instanz vom Adapter anlegelegt , denn unter installierten Version 0.0.8 würde dann noch installierte Instanz 1 stehen !
                                  • G grooovie
                                    UncleSamU Offline
                                    UncleSamU Offline
                                    UncleSam
                                    Oben im blauen Streifen auf der Adapter Ansicht hat es ein Drop-down wo man den Host auswählen kann. Sorry bin auf dem Handy und kann dir keinen Screenshot anhängen. Der Adapter wird dann auf dem ausgewählten Host installiert.
                                      grooovie
                                      @UncleSam ja, das hatte ich gemacht. aber wo ist dann die instanz zu sehen?
                                      auch obekte sind keine vorhanden...
                                      • G grooovie
                                        grooovie
                                        ok, hab einfach noch eine weitere instanz hinzugefügt. jetzt ist er da :-)
