  4. Material Design Widgets: Line History Chart Widget
vis
202 Beiträge 61 Kommentatoren 54.4k Aufrufe 62 Beobachtet
  • M MaikB85
    Also ... Die Warnings hab ich soweit weg. War noch wegen dem ganzen Umbauen auf die MDWs.
    Hab mal den Debug Mode aktiviert für das Chart. Allerdings ist da glaube ich nicht viel zu sehen:
    [Warning] ApplicationCache is deprecated. Please use ServiceWorkers instead. (index.html, line 2)
    [Log] Version Info-Adapter-Widget: 0.0.9 (info.js, line 21)
    [Log] Version justgage: 1.0.2 (justgage.js, line 115)
    [Error] Failed to load resource: the server responded with a status of 404 (Not Found) (socket.io.js.map, line 0)
    [Error] Failed to load resource: the server responded with a status of 404 (Not Found) (materialdesignicons.css.map, line 0)
    [Log] 2020-07-16T09:08:10.111Z Connected => authenticate (conn.js, line 273)
    [Info] Download the Vue Devtools extension for a better development experience: (lib.min.js, line 22)
    https://github.com/vuejs/vue-devtools
    [Info] You are running Vue in development mode. (lib.min.js, line 22)
    Make sure to turn on production mode when deploying for production.
    See more tips at https://vuejs.org/guide/deployment.html
    [Log] 2020-07-16T09:08:10.235Z Authenticated: true (conn.js, line 293)
    [Log] Version vis-materialdesign: 0.3.14 (materialdesign.js, line 33)
    [Debug] Request 0 states. (bundle.min.js, line 2)
    [Log] Create inner vis object s7.0.DBs.DB4.Perlschlauch_hinten_Mode (bundle.min.js, line 2)
    [Log] Create inner vis object s7.0.DBs.DB4.Perlschlauch_hinten_wettermode (bundle.min.js, line 2)
    [Log] Create inner vis object mqtt.0.Garten.Rasen_vorne.Startzeit_Stunde (bundle.min.js, line 2)
    [Log] Create inner vis object mqtt.0.Garten.Rasen_vorne.Startzeit_Minute (bundle.min.js, line 2)
    [Log] Create inner vis object s7.0.DBs.DB4.Perlschlauch_hinten_interval (bundle.min.js, line 2)
    [Log] Create inner vis object s7.0.DBs.DB4.Perlschlauch_hinten_Dauer (bundle.min.js, line 2)
    [Log] Create inner vis object s7.0.DBs.DB4.Perlschlauch_hinten_aussetzen (bundle.min.js, line 2)
    [Log] Create inner vis object s7.0.DBs.DB4.Perlschlauch_hinten_manuell_Start (bundle.min.js, line 2)
    [Log] Create inner vis object s7.0.DBs.DB4.Perlschlauch_hinten_Restlaufzeit (bundle.min.js, line 2)
    [Log] Create inner vis object s7.0.DBs.DB4.Perlschlauch_vorne_Mode (bundle.min.js, line 2)
    [Log] Create inner vis object s7.0.DBs.DB4.Perlschlauch_vorne_wettermode (bundle.min.js, line 2)
    [Log] Create inner vis object s7.0.DBs.DB4.Perlschlauch_vorne_interval (bundle.min.js, line 2)
    [Log] Create inner vis object s7.0.DBs.DB4.Perlschlauch_vorne_Dauer (bundle.min.js, line 2)
    [Log] Create inner vis object s7.0.DBs.DB4.Perlschlauch_vorne_aussetzen (bundle.min.js, line 2)
    [Log] Create inner vis object s7.0.DBs.DB4.Perlschlauch_vorne_manuell_Start (bundle.min.js, line 2)
    [Log] Create inner vis object s7.0.DBs.DB4.Perlschlauch_vorne_Restlaufzeit (bundle.min.js, line 2)
    [Log] Create inner vis object s7.0.DBs.DB4.Rasen_hinten_Mode (bundle.min.js, line 2)
    [Log] Create inner vis object s7.0.DBs.DB4.Rasen_vorne_Mode (bundle.min.js, line 2)
    [Log] Create inner vis object s7.0.DBs.DB4.Rasen_hinten_wettermode (bundle.min.js, line 2)
    [Log] Create inner vis object s7.0.DBs.DB4.Rasen_hinten_interval (bundle.min.js, line 2)
    [Log] Create inner vis object s7.0.DBs.DB4.Rasen_hinten_Dauer (bundle.min.js, line 2)
    [Log] Create inner vis object s7.0.DBs.DB4.Rasen_hinten_aussetzen (bundle.min.js, line 2)
    [Log] Create inner vis object s7.0.DBs.DB4.Rasen_hinten_manuell_Start (bundle.min.js, line 2)
    [Log] Create inner vis object s7.0.DBs.DB4.Rasen_hinten_Restlaufzeit (bundle.min.js, line 2)
    [Log] Create inner vis object s7.0.DBs.DB4.Rasen_vorne_wettermode (bundle.min.js, line 2)
    [Log] Create inner vis object s7.0.DBs.DB4.Rasen_vorne_interval (bundle.min.js, line 2)
    [Log] Create inner vis object s7.0.DBs.DB4.Rasen_vorne_Dauer (bundle.min.js, line 2)
    [Log] Create inner vis object s7.0.DBs.DB4.Rasen_vorne_aussetzen (bundle.min.js, line 2)
    [Log] Create inner vis object s7.0.DBs.DB4.Rasen_vorne_manuell_Start (bundle.min.js, line 2)
    [Log] Create inner vis object s7.0.DBs.DB4.Rasen_vorne_Restlaufzeit (bundle.min.js, line 2)
    [Log] Create inner vis object s7.0.DBs.DB4.Brunnenpumpe_Ein (bundle.min.js, line 2)
    [Log] Create inner vis object s7.0.DBs.DB4.Druck_Brunnenwasser (bundle.min.js, line 2)
    [Log] Create inner vis object s7.0.DBs.DB4.Durchfluss_Brunnenwasser (bundle.min.js, line 2)
    [Log] Create inner vis object maxcube.0.devices.contact_1595e8.error (bundle.min.js, line 2)
    [Log] Create inner vis object maxcube.0.devices.contact_1595e8.battery_low (bundle.min.js, line 2)
    [Log] Create inner vis object maxcube.0.devices.contact_1595e8.link_error (bundle.min.js, line 2)
    [Log] Create inner vis object maxcube.0.devices.contact_1595e8.opened (bundle.min.js, line 2)
    [Log] Create inner vis object maxcube.0.devices.contact_1b3239.error (bundle.min.js, line 2)
    [Log] Create inner vis object maxcube.0.devices.contact_1b3239.battery_low (bundle.min.js, line 2)
    [Log] Create inner vis object maxcube.0.devices.contact_1b3239.link_error (bundle.min.js, line 2)
    [Log] Create inner vis object maxcube.0.devices.contact_1b3239.opened (bundle.min.js, line 2)
    [Log] Create inner vis object maxcube.0.devices.contact_1b3193.error (bundle.min.js, line 2)
    [Log] Create inner vis object maxcube.0.devices.contact_1b3193.battery_low (bundle.min.js, line 2)
    [Log] Create inner vis object maxcube.0.devices.contact_1b3193.link_error (bundle.min.js, line 2)
    [Log] Create inner vis object maxcube.0.devices.contact_1b3193.opened (bundle.min.js, line 2)
    [Log] Create inner vis object maxcube.0.devices.contact_1b31e1.error (bundle.min.js, line 2)
    [Log] Create inner vis object maxcube.0.devices.contact_1b31e1.battery_low (bundle.min.js, line 2)
    [Log] Create inner vis object maxcube.0.devices.contact_1b31e1.link_error (bundle.min.js, line 2)
    [Log] Create inner vis object maxcube.0.devices.contact_1b31e1.opened (bundle.min.js, line 2)
    [Log] Create inner vis object maxcube.0.devices.contact_1b34bc.error (bundle.min.js, line 2)
    [Log] Create inner vis object maxcube.0.devices.contact_1b34bc.battery_low (bundle.min.js, line 2)
    [Log] Create inner vis object maxcube.0.devices.contact_1b34bc.link_error (bundle.min.js, line 2)
    [Log] Create inner vis object maxcube.0.devices.contact_1b34bc.opened (bundle.min.js, line 2)
    [Log] Create inner vis object maxcube.0.devices.contact_1b3179.error (bundle.min.js, line 2)
    [Log] Create inner vis object maxcube.0.devices.contact_1b3179.battery_low (bundle.min.js, line 2)
    [Log] Create inner vis object maxcube.0.devices.contact_1b3179.link_error (bundle.min.js, line 2)
    [Log] Create inner vis object maxcube.0.devices.contact_1b3179.opened (bundle.min.js, line 2)
    [Log] Create inner vis object maxcube.0.devices.contact_159811.error (bundle.min.js, line 2)
    [Log] Create inner vis object maxcube.0.devices.contact_159811.battery_low (bundle.min.js, line 2)
    [Log] Create inner vis object maxcube.0.devices.contact_159811.link_error (bundle.min.js, line 2)
    [Log] Create inner vis object maxcube.0.devices.contact_159811.opened (bundle.min.js, line 2)
    [Log] Create inner vis object maxcube.0.devices.contact_15951a.error (bundle.min.js, line 2)
    [Log] Create inner vis object maxcube.0.devices.contact_15951a.battery_low (bundle.min.js, line 2)
    [Log] Create inner vis object maxcube.0.devices.contact_15951a.link_error (bundle.min.js, line 2)
    [Log] Create inner vis object maxcube.0.devices.contact_15951a.opened (bundle.min.js, line 2)
    [Log] Create inner vis object maxcube.0.devices.contact_1b3203.error (bundle.min.js, line 2)
    [Log] Create inner vis object maxcube.0.devices.contact_1b3203.battery_low (bundle.min.js, line 2)
    [Log] Create inner vis object maxcube.0.devices.contact_1b3203.link_error (bundle.min.js, line 2)
    [Log] Create inner vis object maxcube.0.devices.contact_1b3203.opened (bundle.min.js, line 2)
    [Log] Create inner vis object maxcube.0.devices.contact_1b3183.error (bundle.min.js, line 2)
    [Log] Create inner vis object maxcube.0.devices.contact_1b3183.battery_low (bundle.min.js, line 2)
    [Log] Create inner vis object maxcube.0.devices.contact_1b3183.link_error (bundle.min.js, line 2)
    [Log] Create inner vis object maxcube.0.devices.contact_1b3183.opened (bundle.min.js, line 2)
    [Log] Create inner vis object maxcube.0.devices.contact_1593e1.error (bundle.min.js, line 2)
    [Log] Create inner vis object maxcube.0.devices.contact_1593e1.battery_low (bundle.min.js, line 2)
    [Log] Create inner vis object maxcube.0.devices.contact_1593e1.link_error (bundle.min.js, line 2)
    [Log] Create inner vis object maxcube.0.devices.contact_1593e1.opened (bundle.min.js, line 2)
    [Log] Create inner vis object maxcube.0.devices.contact_1593be.error (bundle.min.js, line 2)
    [Log] Create inner vis object maxcube.0.devices.contact_1593be.battery_low (bundle.min.js, line 2)
    [Log] Create inner vis object maxcube.0.devices.contact_1593be.link_error (bundle.min.js, line 2)
    [Log] Create inner vis object maxcube.0.devices.contact_1593be.opened (bundle.min.js, line 2)
    [Log] Create inner vis object maxcube.0.devices.contact_17871e.error (bundle.min.js, line 2)
    [Log] Create inner vis object maxcube.0.devices.contact_17871e.battery_low (bundle.min.js, line 2)
    [Log] Create inner vis object maxcube.0.devices.contact_17871e.link_error (bundle.min.js, line 2)
    [Log] Create inner vis object maxcube.0.devices.contact_17871e.opened (bundle.min.js, line 2)
    [Log] Create inner vis object s7.0.DBs.DB9.Mode (bundle.min.js, line 2)
    [Log] Create inner vis object s7.0.DBs.DB9.Bandantrieb_Ein (bundle.min.js, line 2)
    [Log] Create inner vis object s7.0.DBs.DB9.Magnetventil_Ein (bundle.min.js, line 2)
    [Log] Create inner vis object s7.0.DBs.DB9.Status_Bandantrieb (bundle.min.js, line 2)
    [Log] Create inner vis object s7.0.DBs.DB9.Status_Magnetventil (bundle.min.js, line 2)
    [Log] Create inner vis object s7.0.DBs.DB9.Abreinigungszeit (bundle.min.js, line 2)
    [Log] Create inner vis object s7.0.DBs.DB9.Verzoegerung_Ventil (bundle.min.js, line 2)
    [Log] Create inner vis object 0_userdata.0.Charts.KlimaWohnzimmer (bundle.min.js, line 2)
    [Log] Create inner vis object maxcube.0.devices.thermostat_155528.setpoint (bundle.min.js, line 2)
    [Log] Create inner vis object maxcube.0.devices.thermostat_155528.error (bundle.min.js, line 2)
    [Log] Create inner vis object maxcube.0.devices.thermostat_155528.battery_low (bundle.min.js, line 2)
    [Log] Create inner vis object maxcube.0.devices.thermostat_155528.link_error (bundle.min.js, line 2)
    [Log] Create inner vis object maxcube.0.devices.thermostat_155528.mode (bundle.min.js, line 2)
    [Log] Create inner vis object maxcube.0.devices.thermostat_178cc3.setpoint (bundle.min.js, line 2)
    [Log] Create inner vis object maxcube.0.devices.thermostat_178cc3.error (bundle.min.js, line 2)
    [Log] Create inner vis object maxcube.0.devices.thermostat_178cc3.battery_low (bundle.min.js, line 2)
    [Log] Create inner vis object maxcube.0.devices.thermostat_178cc3.link_error (bundle.min.js, line 2)
    [Log] Create inner vis object maxcube.0.devices.thermostat_178cc3.mode (bundle.min.js, line 2)
    [Log] Create inner vis object maxcube.0.devices.thermostat_178cd2.setpoint (bundle.min.js, line 2)
    [Log] Create inner vis object maxcube.0.devices.thermostat_178cd2.error (bundle.min.js, line 2)
    [Log] Create inner vis object maxcube.0.devices.thermostat_178cd2.battery_low (bundle.min.js, line 2)
    [Log] Create inner vis object maxcube.0.devices.thermostat_178cd2.link_error (bundle.min.js, line 2)
    [Log] Create inner vis object maxcube.0.devices.thermostat_178cd2.mode (bundle.min.js, line 2)
    [Log] Create inner vis object maxcube.0.devices.thermostat_178cec.setpoint (bundle.min.js, line 2)
    [Log] Create inner vis object maxcube.0.devices.thermostat_178cec.error (bundle.min.js, line 2)
    [Log] Create inner vis object maxcube.0.devices.thermostat_178cec.battery_low (bundle.min.js, line 2)
    [Log] Create inner vis object maxcube.0.devices.thermostat_178cec.link_error (bundle.min.js, line 2)
    [Log] Create inner vis object maxcube.0.devices.thermostat_178cec.mode (bundle.min.js, line 2)
    [Log] Create inner vis object maxcube.0.devices.thermostat_15555b.setpoint (bundle.min.js, line 2)
    [Log] Create inner vis object maxcube.0.devices.thermostat_15555b.error (bundle.min.js, line 2)
    [Log] Create inner vis object maxcube.0.devices.thermostat_15555b.battery_low (bundle.min.js, line 2)
    [Log] Create inner vis object maxcube.0.devices.thermostat_15555b.link_error (bundle.min.js, line 2)
    [Log] Create inner vis object maxcube.0.devices.thermostat_15555b.mode (bundle.min.js, line 2)
    [Log] Create inner vis object maxcube.0.devices.thermostat_166422.setpoint (bundle.min.js, line 2)
    [Log] Create inner vis object maxcube.0.devices.thermostat_166422.error (bundle.min.js, line 2)
    [Log] Create inner vis object maxcube.0.devices.thermostat_166422.battery_low (bundle.min.js, line 2)
    [Log] Create inner vis object maxcube.0.devices.thermostat_166422.link_error (bundle.min.js, line 2)
    [Log] Create inner vis object maxcube.0.devices.thermostat_166422.mode (bundle.min.js, line 2)
    [Log] Create inner vis object maxcube.0.devices.thermostat_178ce1.setpoint (bundle.min.js, line 2)
    [Log] Create inner vis object maxcube.0.devices.thermostat_178ce1.error (bundle.min.js, line 2)
    [Log] Create inner vis object maxcube.0.devices.thermostat_178ce1.battery_low (bundle.min.js, line 2)
    [Log] Create inner vis object maxcube.0.devices.thermostat_178ce1.link_error (bundle.min.js, line 2)
    [Log] Create inner vis object maxcube.0.devices.thermostat_178ce1.mode (bundle.min.js, line 2)
    [Log] Create inner vis object maxcube.0.devices.thermostat_16641c.setpoint (bundle.min.js, line 2)
    [Log] Create inner vis object maxcube.0.devices.thermostat_16641c.error (bundle.min.js, line 2)
    [Log] Create inner vis object maxcube.0.devices.thermostat_16641c.battery_low (bundle.min.js, line 2)
    [Log] Create inner vis object maxcube.0.devices.thermostat_16641c.link_error (bundle.min.js, line 2)
    [Log] Create inner vis object maxcube.0.devices.thermostat_16641c.mode (bundle.min.js, line 2)
    [Log] Create inner vis object maxcube.0.devices.thermostat_155101.setpoint (bundle.min.js, line 2)
    [Log] Create inner vis object maxcube.0.devices.thermostat_155101.error (bundle.min.js, line 2)
    [Log] Create inner vis object maxcube.0.devices.thermostat_155101.battery_low (bundle.min.js, line 2)
    [Log] Create inner vis object maxcube.0.devices.thermostat_155101.link_error (bundle.min.js, line 2)
    [Log] Create inner vis object maxcube.0.devices.thermostat_155101.mode (bundle.min.js, line 2)
    [Log] Create inner vis object mqtt.0.Wohnzimmer.Temperatur (bundle.min.js, line 2)
    [Log] Create inner vis object mqtt.0.Wohnzimmer.Luftfeuchtigkeit (bundle.min.js, line 2)
    [Log] Create inner vis object javascript.0.Wohnzimmer.Luftfeuchte (bundle.min.js, line 2)
    [Log] Create inner vis object mqtt.0.Wohnzimmer.TVOC (bundle.min.js, line 2)
    [Log] Create inner vis object javascript.0.Wohnzimmer.Luftquali_Wert (bundle.min.js, line 2)
    [Log] Create inner vis object javascript.0.Wohnzimmer.Luftquali (bundle.min.js, line 2)
    [Log] Create inner vis object 0_userdata.0.Luftbewertung.Luft_Wohnzimmer (bundle.min.js, line 2)
    [Log] Create inner vis object mqtt.0.Wohnzimmer.Luftdruck (bundle.min.js, line 2)
    [Log] Create inner vis object 0_userdata.0.Charts.KlimaEsszimmer (bundle.min.js, line 2)
    [Log] Create inner vis object 0_userdata.0.Charts.KlimaKinderzimmer2 (bundle.min.js, line 2)
    [Log] Create inner vis object 0_userdata.0.Charts.KlimaKinderzimmer1 (bundle.min.js, line 2)
    [Log] Create inner vis object s7.0.DBs.DB3.Schalter_Licht_Kinderzimmer1 (bundle.min.js, line 2)
    [Log] Create inner vis object s7.0.DBs.DB6.Schalter_Licht_Esszimmer (bundle.min.js, line 2)
    [Log] Create inner vis object s7.0.DBs.DB6.Schalter_Licht_Flur_Treppe (bundle.min.js, line 2)
    [Log] Create inner vis object s7.0.DBs.DB6.Schalter_Licht_Flur_EG_2 (bundle.min.js, line 2)
    [Log] Create inner vis object s7.0.DBs.DB6.Schalter_Licht_Flur_EG (bundle.min.js, line 2)
    [Log] Create inner vis object s7.0.DBs.DB6.Schalter_Licht_Wohnzimmer (bundle.min.js, line 2)
    [Log] Create inner vis object s7.0.DBs.DB6.Steckdose_Wohnzimmer_2 (bundle.min.js, line 2)
    [Log] Create inner vis object s7.0.DBs.DB6.Steckdose_Wohnzimmer_3 (bundle.min.js, line 2)
    [Log] Create inner vis object s7.0.DBs.DB6.Sollwert_Rollladen_Wohnzimmer (bundle.min.js, line 2)
    [Log] Create inner vis object s7.0.DBs.DB6.Istwert_Rollladen_Esszimmer_Fenster (bundle.min.js, line 2)
    [Log] Create inner vis object s7.0.DBs.DB6.Sollwert_Rollladen_Esszimmer_Fenster (bundle.min.js, line 2)
    [Log] Create inner vis object s7.0.DBs.DB6.Istwert_Rollladen_Esszimmer_Tür (bundle.min.js, line 2)
    [Log] Create inner vis object s7.0.DBs.DB6.Sollwert_Rollladen_Esszimmer_Tür (bundle.min.js, line 2)
    [Log] Create inner vis object s7.0.DBs.DB3.Istwert_Rollladen_Kinderzimmer1 (bundle.min.js, line 2)
    [Log] Create inner vis object s7.0.DBs.DB3.Sollwert_Rollladen_Kinderzimmer1 (bundle.min.js, line 2)
    [Log] Create inner vis object s7.0.DBs.DB3.Istwert_Rollladen_Kinderzimmer2 (bundle.min.js, line 2)
    [Log] Create inner vis object s7.0.DBs.DB3.Sollwert_Rollladen_Kinderzimmer2 (bundle.min.js, line 2)
    [Log] Create inner vis object s7.0.DBs.DB6.Istwert_Rollladen_Wohnzimmer (bundle.min.js, line 2)
    [Log] Create inner vis object backitup.0.history.html (bundle.min.js, line 2)
    [Log] Create inner vis object s7.0.DBs.DB6.Steckdosen_Esszimmer_1 (bundle.min.js, line 2)
    [Log] Create inner vis object s7.0.DBs.DB6.Steckdosen_Esszimmer_2 (bundle.min.js, line 2)
    [Log] Create inner vis object s7.0.DBs.DB6.Steckdosen_Esszimmer_3 (bundle.min.js, line 2)
    [Log] Create inner vis object s7.0.DBs.DB6.Steckdosen_Esszimmer_4 (bundle.min.js, line 2)
    [Log] Create inner vis object s7.0.DBs.DB6.Steckdose_Wohnzimmer_1 (bundle.min.js, line 2)
    [Log] Create inner vis object s7.0.DBs.DB6.Steckdose_Wohnzimmer_4 (bundle.min.js, line 2)
    [Log] Create inner vis object s7.0.DBs.DB6.Steckdose_Wohnzimmer_5 (bundle.min.js, line 2)
    [Log] Create inner vis object s7.0.DBs.DB9.Teichpumpe_Ein (bundle.min.js, line 2)
    [Log] Create inner vis object s7.0.DBs.DB9.Temperatur_Oben (bundle.min.js, line 2)
    [Log] Create inner vis object s7.0.DBs.DB9.Temperatur_Unten (bundle.min.js, line 2)
    [Log] Create inner vis object 0_userdata.0.Charts.TempTeich (bundle.min.js, line 2)
    [Log] Create inner vis object mqtt.0.Teich.Temperatur_Oben (bundle.min.js, line 2)
    [Log] Create inner vis object mqtt.0.Teich.Temperatur_Unten (bundle.min.js, line 2)
    [Log] Create inner vis object mqtt.0.Teich.Temperatur_Filtergraben (bundle.min.js, line 2)
    [Log] Create inner vis object s7.0.DBs.DB3.Schalter_Licht_Kinderzimmer1_deaktivieren (bundle.min.js, line 2)
    [Log] Create inner vis object s7.0.DBs.DB3.Taster_Rollladen_Kinderzimmer1_deaktivieren (bundle.min.js, line 2)
    [Log] Create inner vis object s7.0.DBs.DB3.Schalter_Licht_Kinderzimmer2_deaktivieren (bundle.min.js, line 2)
    [Log] Create inner vis object s7.0.DBs.DB3.Taster_Rollladen_Kinderzimmer2_deaktivieren (bundle.min.js, line 2)
    [Log] Create inner vis object 0 (bundle.min.js, line 2)
    [Log] Create inner vis object 40 (bundle.min.js, line 2)
    [Log] Create inner vis object 20 (bundle.min.js, line 2)
    [Log] Create inner vis object mqtt.0.Gäste_WC.Temperatur (bundle.min.js, line 2)
    [Log] Create inner vis object 100 (bundle.min.js, line 2)
    [Log] Create inner vis object 50 (bundle.min.js, line 2)
    [Log] Create inner vis object mqtt.0.Gäste_WC.Luftfeuchtigkeit (bundle.min.js, line 2)
    [Log] Create inner vis object 125 (bundle.min.js, line 2)
    [Log] Create inner vis object 2000 (bundle.min.js, line 2)
    [Log] Create inner vis object 600 (bundle.min.js, line 2)
    [Log] Create inner vis object mqtt.0.Gäste_WC.TVOC (bundle.min.js, line 2)
    [Log] Create inner vis object 0_userdata.0.topappbar (bundle.min.js, line 2)
    [Debug] [1594890490471] Request 1 states. (bundle.min.js, line 2)
    [Debug] [1594890490509] Request 3 states. (bundle.min.js, line 2)
    [Debug] [1594890490553] Request 2 states. (bundle.min.js, line 2)
    [Debug] [1594890490576] Request 5 states. (bundle.min.js, line 2)
    [Debug] [1594890490604] Request 4 states. (bundle.min.js, line 2)
    [Debug] [1594890490627] Request 3 states. (bundle.min.js, line 2)
    [Debug] [1594890490652] Request 6 states. (bundle.min.js, line 2)
    [Debug] [1594890490724] Request 2 states. (bundle.min.js, line 2)
    [Log] [Line History Chart w00503] widget setting: {"_data":{"wid":"w00503","g_fixed":false,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","dataCount":"3","aggregate":"average","timeIntervalToShow":"1 month","refreshMethod":"timeInterval","refreshTimeInterval":"30 seconds","chartTimeout":"3","pointStyle":"circle","showLegend":"true","legendPosition":"bottom","legendPointStyle":"true","showTooltip":"true","tooltipTimeFormats":"{\"millisecond\":\"lll:ss\",\"second\":\"lll:ss\",\"minute\":\"lll\",\"hour\":\"lll\",\"day\":\"lll\",\"week\":\"lll\",\"month\":\"lll\",\"quarter\":\"lll\",\"year\":\"lll\"}","tooltipShowColorBox":"true","lineSpanGaps0":"true","lineSpanGaps1":"true","xAxisPosition":"bottom","xAxisBounds":"dataSet","xAxisTimeFormats":"{\"millisecond\":\"H:mm:ss.SSS\",\"second\":\"H:mm:ss\",\"minute\":\"H:mm\",\"hour\":\"H\",\"day\":\"ddd DD.\",\"week\":\"ll\",\"month\":\"MMM YYYY\",\"quarter\":\"[Q]Q - YYYY\",\"year\":\"YYYY\"}","xAxisValueDistanceToAxis":"8","xAxisShowAxis":true,"xAxisShowAxisLabels":true,"xAxisShowGridLines":true,"xAxisShowTicks":true,"xAxisMinRotation":"0","xAxisMaxRotation":"0","yAxisValueDistanceToAxis":"","showYAxis0":true,"yAxisPosition0":"left","yAxisShowGridLines0":false,"yAxisShowTicks0":false,"yAxisShowAxisBorder0":false,"showYAxis1":true,"yAxisPosition1":"left","yAxisShowGridLines1":false,"yAxisShowTicks1":false,"yAxisShowAxisBorder1":false,"showValues0":"showValuesOff","valuesPositionAnchor0":"end","valuesPositionAlign0":"top","valuesTextAlign0":"center","showValues1":"showValuesOff","valuesPositionAnchor1":"end","valuesPositionAlign1":"top","valuesTextAlign1":"center","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"historyAdapterInstance":"sql.1","lineSpanGaps2":"true","lineSpanGaps3":"true","showYAxis2":true,"yAxisPosition2":"right","yAxisShowGridLines2":"true","yAxisShowTicks2":"true","yAxisShowAxisBorder2":"true","showYAxis3":true,"yAxisPosition3":"right","yAxisShowGridLines3":false,"yAxisShowTicks3":false,"yAxisShowAxisBorder3":false,"showValues2":"showValuesOff","valuesPositionAnchor2":"end","valuesPositionAlign2":"top","valuesTextAlign2":"start","showValues3":"showValuesOff","valuesPositionAnchor3":"end","valuesPositionAlign3":"top","valuesTextAlign3":"center","maxDataPoints":"","colorScheme":"","legendFontColor":"#e7e7e7","xAxisValueLabelColor":"#e7e7e7","yAxisValueLabelColor":"#e7e7e7","yAxisTitleColor":"","yAxisValueColor0":"#e75f79","xAxisZeroLineColor":"#787878","xAxisGridLinesColor":"#e7e7e7","xAxisZeroLineWidth":"1","xAxisTickLength":"","xAxisGridLinesWitdh":"","xAxisTitleColor":"#e7e7e7","yAxisGridLinesColor0":"#e75f79","yAxisGridLinesColor1":"#dbd029","yAxisGridLinesColor2":"#35aede","yAxisGridLinesColor3":"#43df69","oid0":"mqtt.0.Wohnzimmer.Temperatur","oid1":"mqtt.0.Wohnzimmer.Luftdruck","oid2":"mqtt.0.Wohnzimmer.TVOC","legendText0":"Temperatur","legendText2":"TVOCs","legendText3":"Luftfeuchtigkeit","legendText1":"Luftdruck","globalColor":"","xAxisValueFontSize":"10","xAxisOffsetGridLines":false,"yAxisValueFontSize":"10","valuesMinDecimals2":"0","valuesMaxDecimals2":"0","valuesMinDecimals1":"0","valuesMaxDecimals1":"0","valuesMinDecimals0":"1","valuesMaxDecimals0":"1","yAxisValueMinDigits2":"0","yAxisValueMaxDigits2":"0","yAxisValueMaxDigits1":"0","yAxisValueMinDigits1":"0","yAxisValueMinDigits0":"1","yAxisValueMaxDigits0":"1","yAxisMinValue0":"","yAxisMaxValue0":"","xAxisMaxLabel":"10","time_interval_oid":"0_userdata.0.Charts.KlimaWohnzimmer","legendBoxWidth":"","pointSize":"1","pointSizeHover":"4","dataColor1":"#dbd029","dataColor2":"#35aede","dataColor0":"#e75f79","fillColor0":"","pointHoverColor0":"","fillColor1":"","pointHoverColor1":"","useFillColor1":true,"useFillColor0":true,"fillColor2":"","pointHoverColor2":"","useFillColor2":true,"oid3":"mqtt.0.Wohnzimmer.Luftfeuchtigkeit","dataColor3":"#43df69","fillColor3":"","pointHoverColor3":"","legendFontSize":"10","tooltipValueMaxDecimals":"1","tooltipValueMinDecimals":"0","valuesAppendText0":"°C","valuesAppendText1":"mbar","valuesAppendText2":"ppm","valuesAppendText3":"%","yAxisValueMinDigits3":"1","yAxisValueMaxDigits3":"1","yAxisMaxLabel3":"3","yAxisMaxLabel0":"5","yAxisZeroLineColor0":"#e7e7e7","yAxisZeroLineWidth0":"","yAxisValueColor1":"#dbd029","yAxisZeroLineColor1":"#e7e7e7","yAxisMaxLabel1":"3","yAxisValueColor2":"#35aede","yAxisValueColor3":"#43df69","yAxisMinValue2":"","yAxisMaxValue2":"","yAxisMaxLabel2":"5","yAxisZeroLineColor2":"#e7e7e7","yAxisZeroLineColor3":"#e7e7e7","lineSpanGaps4":"true","showYAxis4":"true","yAxisPosition4":"left","yAxisShowGridLines4":"true","yAxisShowTicks4":"true","yAxisShowAxisBorder4":"true","showValues4":"showValuesOn","valuesPositionAnchor4":"end","valuesPositionAlign4":"top","valuesTextAlign4":"center","chartPaddingLeft":"","steppedLine0":false,"lineTension0":"","manualRefreshTrigger":"","useFillColor3":true,"mdwDebug":true},"_cid":".map746","_computedAttrs":{},"wid":"w00503","g_fixed":false,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","dataCount":"3","aggregate":"average","timeIntervalToShow":"1 month","refreshMethod":"timeInterval","refreshTimeInterval":"30 seconds","chartTimeout":"3","pointStyle":"circle","showLegend":"true","legendPosition":"bottom","legendPointStyle":"true","showTooltip":"true","tooltipTimeFormats":"{\"millisecond\":\"lll:ss\",\"second\":\"lll:ss\",\"minute\":\"lll\",\"hour\":\"lll\",\"day\":\"lll\",\"week\":\"lll\",\"month\":\"lll\",\"quarter\":\"lll\",\"year\":\"lll\"}","tooltipShowColorBox":"true","lineSpanGaps0":"true","lineSpanGaps1":"true","xAxisPosition":"bottom","xAxisBounds":"dataSet","xAxisTimeFormats":"{\"millisecond\":\"H:mm:ss.SSS\",\"second\":\"H:mm:ss\",\"minute\":\"H:mm\",\"hour\":\"H\",\"day\":\"ddd DD.\",\"week\":\"ll\",\"month\":\"MMM YYYY\",\"quarter\":\"[Q]Q - YYYY\",\"year\":\"YYYY\"}","xAxisValueDistanceToAxis":"8","xAxisShowAxis":true,"xAxisShowAxisLabels":true,"xAxisShowGridLines":true,"xAxisShowTicks":true,"xAxisMinRotation":"0","xAxisMaxRotation":"0","yAxisValueDistanceToAxis":"","showYAxis0":true,"yAxisPosition0":"left","yAxisShowGridLines0":false,"yAxisShowTicks0":false,"yAxisShowAxisBorder0":false,"showYAxis1":true,"yAxisPosition1":"left","yAxisShowGridLines1":false,"yAxisShowTicks1":false,"yAxisShowAxisBorder1":false,"showValues0":"showValuesOff","valuesPositionAnchor0":"end","valuesPositionAlign0":"top","valuesTextAlign0":"center","showValues1":"showValuesOff","valuesPositionAnchor1":"end","valuesPositionAlign1":"top","valuesTextAlign1":"center","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"historyAdapterInstance":"sql.1","lineSpanGaps2":"true","lineSpanGaps3":"true","showYAxis2":true,"yAxisPosition2":"right","yAxisShowGridLines2":"true","yAxisShowTicks2":"true","yAxisShowAxisBorder2":"true","showYAxis3":true,"yAxisPosition3":"right","yAxisShowGridLines3":false,"yAxisShowTicks3":false,"yAxisShowAxisBorder3":false,"showValues2":"showValuesOff","valuesPositionAnchor2":"end","valuesPositionAlign2":"top","valuesTextAlign2":"start","showValues3":"showValuesOff","valuesPositionAnchor3":"end","valuesPositionAlign3":"top","valuesTextAlign3":"center","maxDataPoints":"","colorScheme":"","legendFontColor":"#e7e7e7","xAxisValueLabelColor":"#e7e7e7","yAxisValueLabelColor":"#e7e7e7","yAxisTitleColor":"","yAxisValueColor0":"#e75f79","xAxisZeroLineColor":"#787878","xAxisGridLinesColor":"#e7e7e7","xAxisZeroLineWidth":"1","xAxisTickLength":"","xAxisGridLinesWitdh":"","xAxisTitleColor":"#e7e7e7","yAxisGridLinesColor0":"#e75f79","yAxisGridLinesColor1":"#dbd029","yAxisGridLinesColor2":"#35aede","yAxisGridLinesColor3":"#43df69","oid0":"mqtt.0.Wohnzimmer.Temperatur","oid1":"mqtt.0.Wohnzimmer.Luftdruck","oid2":"mqtt.0.Wohnzimmer.TVOC","legendText0":"Temperatur","legendText2":"TVOCs","legendText3":"Luftfeuchtigkeit","legendText1":"Luftdruck","globalColor":"","xAxisValueFontSize":"10","xAxisOffsetGridLines":false,"yAxisValueFontSize":"10","valuesMinDecimals2":"0","valuesMaxDecimals2":"0","valuesMinDecimals1":"0","valuesMaxDecimals1":"0","valuesMinDecimals0":"1","valuesMaxDecimals0":"1","yAxisValueMinDigits2":"0","yAxisValueMaxDigits2":"0","yAxisValueMaxDigits1":"0","yAxisValueMinDigits1":"0","yAxisValueMinDigits0":"1","yAxisValueMaxDigits0":"1","yAxisMinValue0":"","yAxisMaxValue0":"","xAxisMaxLabel":"10","time_interval_oid":"0_userdata.0.Charts.KlimaWohnzimmer","legendBoxWidth":"","pointSize":"1","pointSizeHover":"4","dataColor1":"#dbd029","dataColor2":"#35aede","dataColor0":"#e75f79","fillColor0":"","pointHoverColor0":"","fillColor1":"","pointHoverColor1":"","useFillColor1":true,"useFillColor0":true,"fillColor2":"","pointHoverColor2":"","useFillColor2":true,"oid3":"mqtt.0.Wohnzimmer.Luftfeuchtigkeit","dataColor3":"#43df69","fillColor3":"","pointHoverColor3":"","legendFontSize":"10","tooltipValueMaxDecimals":"1","tooltipValueMinDecimals":"0","valuesAppendText0":"°C","valuesAppendText1":"mbar","valuesAppendText2":"ppm","valuesAppendText3":"%","yAxisValueMinDigits3":"1","yAxisValueMaxDigits3":"1","yAxisMaxLabel3":"3","yAxisMaxLabel0":"5","yAxisZeroLineColor0":"#e7e7e7","yAxisZeroLineWidth0":"","yAxisValueColor1":"#dbd029","yAxisZeroLineColor1":"#e7e7e7","yAxisMaxLabel1":"3","yAxisValueColor2":"#35aede","yAxisValueColor3":"#43df69","yAxisMinValue2":"","yAxisMaxValue2":"","yAxisMaxLabel2":"5","yAxisZeroLineColor2":"#e7e7e7","yAxisZeroLineColor3":"#e7e7e7","lineSpanGaps4":"true","showYAxis4":"true","yAxisPosition4":"left","yAxisShowGridLines4":"true","yAxisShowTicks4":"true","yAxisShowAxisBorder4":"true","showValues4":"showValuesOn","valuesPositionAnchor4":"end","valuesPositionAlign4":"top","valuesTextAlign4":"center","chartPaddingLeft":"","steppedLine0":false,"lineTension0":"","manualRefreshTrigger":"","useFillColor3":true,"mdwDebug":true,"_bubbleBindings":{},"__bindEvents":{"class":[{"name":"class"}],"backgroundColor":[{"name":"backgroundColor"}],"wid":[{"name":"wid"}]},"_bindings":3} (bundle.min.js, line 2)
    [Log] [getTaskForHistoryData w00503] history options for 'mqtt.0.Wohnzimmer.Temperatur': {"instance":"sql.1","count":100,"aggregate":"average","start":1594886890754,"end":1594890490754,"timeout":3000} (bundle.min.js, line 2)
    [Log] [getTaskForHistoryData w00503] history options for 'mqtt.0.Wohnzimmer.Luftdruck': {"instance":"sql.1","count":100,"aggregate":"average","start":1594886890754,"end":1594890490755,"timeout":3000} (bundle.min.js, line 2)
    [Log] [getTaskForHistoryData w00503] history options for 'mqtt.0.Wohnzimmer.TVOC': {"instance":"sql.1","count":100,"aggregate":"average","start":1594886890754,"end":1594890490755,"timeout":3000} (bundle.min.js, line 2)
    [Log] [getTaskForHistoryData w00503] history options for 'mqtt.0.Wohnzimmer.Luftfeuchtigkeit': {"instance":"sql.1","count":100,"aggregate":"average","start":1594886890754,"end":1594890490755,"timeout":3000} (bundle.min.js, line 2)
    [Log] [getTaskForHistoryData w00503] history data result 'mqtt.0.Wohnzimmer.Temperatur' length: 101 (bundle.min.js, line 2)
    [Log] [getTaskForHistoryData w00503] history data result 'mqtt.0.Wohnzimmer.Temperatur': [{"ts":1594886890754,"val":26.225},{"ts":1594886908754,"val":26.2},{"ts":1594886944754,"val":26.21},{"ts":1594886980754,"val":26.21},{"ts":1594887016754,"val":26.22},{"ts":1594887052754,"val":26.21},{"ts":1594887088754,"val":26.2},{"ts":1594887124754,"val":26.21},{"ts":1594887160754,"val":26.22},{"ts":1594887196754,"val":26.23},{"ts":1594887232754,"val":26.27},{"ts":1594887268754,"val":26.25},{"ts":1594887304754,"val":26.25},{"ts":1594887340754,"val":26.28},{"ts":1594887376754,"val":26.25},{"ts":1594887412754,"val":26.25},{"ts":1594887448754,"val":26.21},{"ts":1594887484754,"val":26.21},{"ts":1594887520754,"val":26.22},{"ts":1594887556754,"val":26.23},{"ts":1594887592754,"val":26.25},{"ts":1594887628754,"val":26.25},{"ts":1594887664754,"val":26.22},{"ts":1594887700754,"val":26.23},{"ts":1594887736754,"val":26.27},{"ts":1594887772754,"val":26.3},{"ts":1594887808754,"val":26.29},{"ts":1594887844754,"val":26.3},{"ts":1594887880754,"val":26.27},{"ts":1594887916754,"val":26.28},{"ts":1594887952754,"val":26.29},{"ts":1594887988754,"val":26.29},{"ts":1594888024754,"val":26.3},{"ts":1594888060754,"val":26.32},{"ts":1594888096754,"val":26.35},{"ts":1594888132754,"val":26.32},{"ts":1594888168754,"val":26.33},{"ts":1594888204754,"val":26.36},{"ts":1594888240754,"val":26.42},{"ts":1594888276754,"val":26.4},{"ts":1594888312754,"val":26.38},{"ts":1594888348754,"val":26.43},{"ts":1594888384754,"val":26.36},{"ts":1594888420754,"val":26.43},{"ts":1594888456754,"val":26.42},{"ts":1594888492754,"val":26.42},{"ts":1594888528754,"val":26.43},{"ts":1594888564754,"val":26.42},{"ts":1594888600754,"val":26.38},{"ts":1594888636754,"val":26.4},{"ts":1594888672754,"val":26.43},{"ts":1594888708754,"val":26.4},{"ts":1594888744754,"val":26.4},{"ts":1594888780754,"val":26.38},{"ts":1594888816754,"val":26.42},{"ts":1594888852754,"val":26.43},{"ts":1594888888754,"val":26.42},{"ts":1594888924754,"val":26.4},{"ts":1594888960754,"val":26.44},{"ts":1594888996754,"val":26.42},{"ts":1594889032754,"val":26.4},{"ts":1594889068754,"val":26.4},{"ts":1594889104754,"val":26.35},{"ts":1594889140754,"val":26.36},{"ts":1594889176754,"val":26.4},{"ts":1594889212754,"val":26.38},{"ts":1594889248754,"val":26.38},{"ts":1594889284754,"val":26.35},{"ts":1594889320754,"val":26.36},{"ts":1594889356754,"val":26.33},{"ts":1594889392754,"val":26.38},{"ts":1594889428754,"val":26.38},{"ts":1594889464754,"val":26.4},{"ts":1594889500754,"val":26.42},{"ts":1594889536754,"val":26.4},{"ts":1594889572754,"val":26.36},{"ts":1594889608754,"val":26.35},{"ts":1594889644754,"val":26.34},{"ts":1594889680754,"val":26.35},{"ts":1594889716754,"val":26.34},{"ts":1594889752754,"val":26.36},{"ts":1594889788754,"val":26.33},{"ts":1594889824754,"val":26.34},{"ts":1594889860754,"val":26.35},{"ts":1594889896754,"val":26.34},{"ts":1594889932754,"val":26.38},{"ts":1594889968754,"val":26.33},{"ts":1594890004754,"val":26.38},{"ts":1594890040754,"val":26.3},{"ts":1594890076754,"val":26.34},{"ts":1594890112754,"val":26.3},{"ts":1594890148754,"val":26.32},{"ts":1594890184754,"val":26.29},{"ts":1594890220754,"val":26.33},{"ts":1594890256754,"val":26.29},{"ts":1594890292754,"val":26.28},{"ts":1594890328754,"val":26.29},{"ts":1594890364754,"val":26.3},{"ts":1594890400754,"val":26.29},{"ts":1594890436754,"val":26.29},{"ts":1594890472754,"val":26.3}] (bundle.min.js, line 2)
    [Log] [getTaskForHistoryData w00503] history data result 'mqtt.0.Wohnzimmer.Luftdruck' length: 102 (bundle.min.js, line 2)
    [Log] [getTaskForHistoryData w00503] history data result 'mqtt.0.Wohnzimmer.Luftdruck': [{"ts":1594886890754,"val":1010.83},{"ts":1594886908754,"val":1010.83},{"ts":1594886944754,"val":1010.84},{"ts":1594886980754,"val":1010.84},{"ts":1594887016754,"val":1010.84},{"ts":1594887052754,"val":1010.86},{"ts":1594887088754,"val":1010.87},{"ts":1594887124754,"val":1010.86},{"ts":1594887160754,"val":1010.86},{"ts":1594887196754,"val":1010.88},{"ts":1594887232754,"val":1010.88},{"ts":1594887268754,"val":1010.88},{"ts":1594887304754,"val":1010.9},{"ts":1594887340754,"val":1010.9},{"ts":1594887376754,"val":1010.92},{"ts":1594887412754,"val":1010.91},{"ts":1594887448754,"val":1010.89},{"ts":1594887484754,"val":1010.92},{"ts":1594887520754,"val":1010.91},{"ts":1594887556754,"val":1010.91},{"ts":1594887592754,"val":1010.9},{"ts":1594887628754,"val":1010.89},{"ts":1594887664754,"val":1010.89},{"ts":1594887700754,"val":1010.9},{"ts":1594887736754,"val":1010.88},{"ts":1594887772754,"val":1010.9},{"ts":1594887808754,"val":1010.88},{"ts":1594887844754,"val":1010.92},{"ts":1594887880754,"val":1010.93},{"ts":1594887916754,"val":1010.94},{"ts":1594887952754,"val":1010.93},{"ts":1594887988754,"val":1010.93},{"ts":1594888024754,"val":1010.95},{"ts":1594888060754,"val":1010.93},{"ts":1594888096754,"val":1010.92},{"ts":1594888132754,"val":1010.92},{"ts":1594888168754,"val":1010.93},{"ts":1594888204754,"val":1010.95},{"ts":1594888240754,"val":1010.97},{"ts":1594888276754,"val":1010.96},{"ts":1594888312754,"val":1010.97},{"ts":1594888348754,"val":1010.97},{"ts":1594888384754,"val":1010.97},{"ts":1594888420754,"val":1010.98},{"ts":1594888456754,"val":1010.98},{"ts":1594888492754,"val":1010.98},{"ts":1594888528754,"val":1011},{"ts":1594888564754,"val":1010.99},{"ts":1594888600754,"val":1011},{"ts":1594888636754,"val":1010.99},{"ts":1594888672754,"val":1010.99},{"ts":1594888708755,"val":1010.97},{"ts":1594888744755,"val":1010.98},{"ts":1594888780755,"val":1010.99},{"ts":1594888816755,"val":1010.98},{"ts":1594888852755,"val":1010.98},{"ts":1594888888755,"val":1010.98},{"ts":1594888924755,"val":1010.98},{"ts":1594888960755,"val":1010.97},{"ts":1594888996755,"val":1010.96},{"ts":1594889032755,"val":1010.98},{"ts":1594889068755,"val":1010.97},{"ts":1594889104755,"val":1010.98},{"ts":1594889140755,"val":1010.98},{"ts":1594889176755,"val":1011},{"ts":1594889212755,"val":1010.98},{"ts":1594889248755,"val":1010.99},{"ts":1594889284755,"val":1010.98},{"ts":1594889320755,"val":1010.99},{"ts":1594889356755,"val":1010.99},{"ts":1594889392755,"val":1010.94},{"ts":1594889428755,"val":1010.96},{"ts":1594889464755,"val":1010.97},{"ts":1594889500755,"val":1010.94},{"ts":1594889536755,"val":1010.94},{"ts":1594889572755,"val":1010.93},{"ts":1594889608755,"val":1010.95},{"ts":1594889644755,"val":1010.93},{"ts":1594889680755,"val":1010.95},{"ts":1594889716755,"val":1010.94},{"ts":1594889752755,"val":1010.94},{"ts":1594889788755,"val":1010.95},{"ts":1594889824755,"val":1010.95},{"ts":1594889860755,"val":1010.97},{"ts":1594889896755,"val":1010.98},{"ts":1594889932755,"val":1010.97},{"ts":1594889968755,"val":1011},{"ts":1594890004755,"val":1010.98},{"ts":1594890040755,"val":1010.99},{"ts":1594890076755,"val":1010.98},{"ts":1594890112755,"val":1010.98},{"ts":1594890148755,"val":1010.99},{"ts":1594890184755,"val":1010.99},{"ts":1594890220755,"val":1011.01},{"ts":1594890256755,"val":1010.99},{"ts":1594890292755,"val":1010.99},{"ts":1594890328755,"val":1011},{"ts":1594890364755,"val":1010.99},{"ts":1594890400755,"val":1010.99},{"ts":1594890436755,"val":1010.99},{"ts":1594890472755,"val":1011},{"ts":1594890490755,"val":1011}] (bundle.min.js, line 2)
    [Log] [getTaskForHistoryData w00503] history data result 'mqtt.0.Wohnzimmer.TVOC' length: 101 (bundle.min.js, line 2)
    [Log] [getTaskForHistoryData w00503] history data result 'mqtt.0.Wohnzimmer.TVOC': [{"ts":1594886890754,"val":133.6},{"ts":1594886908754,"val":134.2},{"ts":1594886944754,"val":141.5},{"ts":1594886980754,"val":141.17},{"ts":1594887016754,"val":146},{"ts":1594887052754,"val":149.67},{"ts":1594887088754,"val":149.2},{"ts":1594887124754,"val":153.67},{"ts":1594887160754,"val":166.2},{"ts":1594887196754,"val":165.33},{"ts":1594887232754,"val":156.17},{"ts":1594887268754,"val":156.6},{"ts":1594887304754,"val":155.67},{"ts":1594887340754,"val":155.2},{"ts":1594887376754,"val":152.17},{"ts":1594887412754,"val":153.2},{"ts":1594887448754,"val":153.83},{"ts":1594887484754,"val":154},{"ts":1594887520754,"val":152.2},{"ts":1594887556754,"val":154.17},{"ts":1594887592754,"val":151.6},{"ts":1594887628754,"val":152.83},{"ts":1594887664754,"val":154.2},{"ts":1594887700754,"val":155.5},{"ts":1594887736754,"val":153.5},{"ts":1594887772754,"val":150.8},{"ts":1594887808754,"val":149.33},{"ts":1594887844754,"val":149.6},{"ts":1594887880754,"val":148.67},{"ts":1594887916754,"val":150.6},{"ts":1594887952754,"val":149.17},{"ts":1594887988754,"val":152.33},{"ts":1594888024754,"val":149.6},{"ts":1594888060754,"val":149.17},{"ts":1594888096754,"val":148},{"ts":1594888132754,"val":148.67},{"ts":1594888168754,"val":148.67},{"ts":1594888204754,"val":149.4},{"ts":1594888240754,"val":150.83},{"ts":1594888276754,"val":150.4},{"ts":1594888312754,"val":148.33},{"ts":1594888348754,"val":147},{"ts":1594888384754,"val":149.5},{"ts":1594888420754,"val":148},{"ts":1594888456754,"val":150.2},{"ts":1594888492754,"val":149.83},{"ts":1594888528754,"val":147.2},{"ts":1594888564754,"val":147.33},{"ts":1594888600754,"val":147.8},{"ts":1594888636754,"val":148.5},{"ts":1594888672754,"val":149},{"ts":1594888708755,"val":148.6},{"ts":1594888744755,"val":149.5},{"ts":1594888780755,"val":149},{"ts":1594888816755,"val":146.33},{"ts":1594888852755,"val":146.2},{"ts":1594888888755,"val":145.83},{"ts":1594888924755,"val":145.17},{"ts":1594888960755,"val":145},{"ts":1594888996755,"val":147.67},{"ts":1594889032755,"val":150.2},{"ts":1594889068755,"val":149.17},{"ts":1594889104755,"val":148.2},{"ts":1594889140755,"val":150.67},{"ts":1594889176755,"val":152},{"ts":1594889212755,"val":147.8},{"ts":1594889248755,"val":148},{"ts":1594889284755,"val":147.4},{"ts":1594889320755,"val":147},{"ts":1594889356755,"val":146.6},{"ts":1594889392755,"val":143.5},{"ts":1594889428755,"val":144.67},{"ts":1594889464755,"val":145.8},{"ts":1594889500755,"val":144.33},{"ts":1594889536755,"val":140.8},{"ts":1594889572755,"val":141.33},{"ts":1594889608755,"val":144},{"ts":1594889644755,"val":144.83},{"ts":1594889680755,"val":144.67},{"ts":1594889716755,"val":143},{"ts":1594889752755,"val":142.17},{"ts":1594889788755,"val":140.4},{"ts":1594889824755,"val":140.5},{"ts":1594889860755,"val":143.2},{"ts":1594889896755,"val":140},{"ts":1594889932755,"val":140.67},{"ts":1594889968755,"val":141},{"ts":1594890004755,"val":141.33},{"ts":1594890040755,"val":140.2},{"ts":1594890076755,"val":142},{"ts":1594890112755,"val":140.2},{"ts":1594890148755,"val":139.33},{"ts":1594890184755,"val":139.67},{"ts":1594890220755,"val":140.6},{"ts":1594890256755,"val":143},{"ts":1594890292755,"val":142.4},{"ts":1594890328755,"val":142},{"ts":1594890364755,"val":141.6},{"ts":1594890400755,"val":141.33},{"ts":1594890436755,"val":141},{"ts":1594890472755,"val":139.4}] (bundle.min.js, line 2)
    [Log] [getTaskForHistoryData w00503] history data result 'mqtt.0.Wohnzimmer.Luftfeuchtigkeit' length: 101 (bundle.min.js, line 2)
    [Log] [getTaskForHistoryData w00503] history data result 'mqtt.0.Wohnzimmer.Luftfeuchtigkeit': [{"ts":1594886890754,"val":40.815},{"ts":1594886908754,"val":40.87},{"ts":1594886944754,"val":41.22},{"ts":1594886980754,"val":41.26},{"ts":1594887016754,"val":41.19},{"ts":1594887052754,"val":41.18},{"ts":1594887088754,"val":41.16},{"ts":1594887124754,"val":40.98},{"ts":1594887160754,"val":40.58},{"ts":1594887196754,"val":41.03},{"ts":1594887232754,"val":40.89},{"ts":1594887268754,"val":41.2},{"ts":1594887304754,"val":41.11},{"ts":1594887340754,"val":40.9},{"ts":1594887376754,"val":40.83},{"ts":1594887412754,"val":41.05},{"ts":1594887448754,"val":41.11},{"ts":1594887484754,"val":41.15},{"ts":1594887520754,"val":41.23},{"ts":1594887556754,"val":41.33},{"ts":1594887592754,"val":41.41},{"ts":1594887628754,"val":41.49},{"ts":1594887664754,"val":41.19},{"ts":1594887700754,"val":41.28},{"ts":1594887736754,"val":41.3},{"ts":1594887772754,"val":41.27},{"ts":1594887808754,"val":41.22},{"ts":1594887844754,"val":41.19},{"ts":1594887880754,"val":41.18},{"ts":1594887916754,"val":41.11},{"ts":1594887952754,"val":41.06},{"ts":1594887988754,"val":41},{"ts":1594888024754,"val":41.05},{"ts":1594888060754,"val":41.05},{"ts":1594888096754,"val":40.98},{"ts":1594888132754,"val":40.95},{"ts":1594888168754,"val":40.96},{"ts":1594888204754,"val":40.95},{"ts":1594888240754,"val":40.93},{"ts":1594888276754,"val":40.93},{"ts":1594888312754,"val":40.93},{"ts":1594888348754,"val":40.97},{"ts":1594888384754,"val":40.95},{"ts":1594888420754,"val":40.99},{"ts":1594888456754,"val":40.92},{"ts":1594888492754,"val":40.95},{"ts":1594888528754,"val":41.01},{"ts":1594888564754,"val":40.96},{"ts":1594888600754,"val":40.95},{"ts":1594888636754,"val":40.98},{"ts":1594888672754,"val":40.93},{"ts":1594888708755,"val":40.94},{"ts":1594888744755,"val":40.97},{"ts":1594888780755,"val":40.99},{"ts":1594888816755,"val":41},{"ts":1594888852755,"val":41},{"ts":1594888888755,"val":41.04},{"ts":1594888924755,"val":41.06},{"ts":1594888960755,"val":40.96},{"ts":1594888996755,"val":40.96},{"ts":1594889032755,"val":41},{"ts":1594889068755,"val":40.95},{"ts":1594889104755,"val":40.95},{"ts":1594889140755,"val":40.83},{"ts":1594889176755,"val":40.9},{"ts":1594889212755,"val":40.94},{"ts":1594889248755,"val":40.78},{"ts":1594889284755,"val":40.78},{"ts":1594889320755,"val":40.96},{"ts":1594889356755,"val":41.01},{"ts":1594889392755,"val":41.02},{"ts":1594889428755,"val":41.03},{"ts":1594889464755,"val":41.05},{"ts":1594889500755,"val":41.07},{"ts":1594889536755,"val":41.06},{"ts":1594889572755,"val":41.03},{"ts":1594889608755,"val":41.02},{"ts":1594889644755,"val":41.06},{"ts":1594889680755,"val":41.05},{"ts":1594889716755,"val":41.05},{"ts":1594889752755,"val":41.05},{"ts":1594889788755,"val":41.1},{"ts":1594889824755,"val":41.03},{"ts":1594889860755,"val":41.09},{"ts":1594889896755,"val":41.08},{"ts":1594889932755,"val":41.08},{"ts":1594889968755,"val":41.09},{"ts":1594890004755,"val":41.08},{"ts":1594890040755,"val":40.97},{"ts":1594890076755,"val":41.05},{"ts":1594890112755,"val":41.07},{"ts":1594890148755,"val":41.06},{"ts":1594890184755,"val":41.06},{"ts":1594890220755,"val":41},{"ts":1594890256755,"val":40.95},{"ts":1594890292755,"val":40.96},{"ts":1594890328755,"val":40.91},{"ts":1594890364755,"val":40.97},{"ts":1594890400755,"val":40.93},{"ts":1594890436755,"val":40.9},{"ts":1594890472755,"val":40.88}] (bundle.min.js, line 2)
    [Log] [Line History Chart w00503] promise all datasets - count: 4 (bundle.min.js, line 2)
    [Log] [getPreparedData w00503] prepare data for 'mqtt.0.Wohnzimmer.Temperatur' length: 101 (bundle.min.js, line 2)
    [Log] [Line History Chart w00503] prepare dataset for 'mqtt.0.Wohnzimmer.Temperatur' (bundle.min.js, line 2)
    [Log] [Line History Chart w00503] prepare yAxis for 'mqtt.0.Wohnzimmer.Temperatur' (bundle.min.js, line 2)
    [Log] [getPreparedData w00503] prepare data for 'mqtt.0.Wohnzimmer.Luftdruck' length: 102 (bundle.min.js, line 2)
    [Log] [Line History Chart w00503] prepare dataset for 'mqtt.0.Wohnzimmer.Luftdruck' (bundle.min.js, line 2)
    [Log] [Line History Chart w00503] prepare yAxis for 'mqtt.0.Wohnzimmer.Luftdruck' (bundle.min.js, line 2)
    [Log] [getPreparedData w00503] prepare data for 'mqtt.0.Wohnzimmer.TVOC' length: 101 (bundle.min.js, line 2)
    [Log] [Line History Chart w00503] prepare dataset for 'mqtt.0.Wohnzimmer.TVOC' (bundle.min.js, line 2)
    [Log] [Line History Chart w00503] prepare yAxis for 'mqtt.0.Wohnzimmer.TVOC' (bundle.min.js, line 2)
    [Log] [getPreparedData w00503] prepare data for 'mqtt.0.Wohnzimmer.Luftfeuchtigkeit' length: 101 (bundle.min.js, line 2)
    [Log] [Line History Chart w00503] prepare dataset for 'mqtt.0.Wohnzimmer.Luftfeuchtigkeit' (bundle.min.js, line 2)
    [Log] [Line History Chart w00503] prepare yAxis for 'mqtt.0.Wohnzimmer.Luftfeuchtigkeit' (bundle.min.js, line 2)
    [Log] [Line History Chart - w00503] prepare chart options (bundle.min.js, line 2)
    [Log] [Line History Chart w00503] chart creating... (bundle.min.js, line 2)
    [Log] [Line History Chart w00503] chart successful created (bundle.min.js, line 2)
    [Log] [Line History Chart w00503] ************************************************************** onChange - TimeInterval by Editor ************************************************************** (bundle.min.js, line 2)
    [Log] [getTaskForHistoryData w00503] history options for 'mqtt.0.Wohnzimmer.Temperatur': {"instance":"sql.1","count":100,"aggregate":"average","start":1594886920755,"end":1594890520755,"timeout":3000} (bundle.min.js, line 2)
    [Log] [getTaskForHistoryData w00503] history options for 'mqtt.0.Wohnzimmer.Luftdruck': {"instance":"sql.1","count":100,"aggregate":"average","start":1594886920755,"end":1594890520755,"timeout":3000} (bundle.min.js, line 2)
    [Log] [getTaskForHistoryData w00503] history options for 'mqtt.0.Wohnzimmer.TVOC': {"instance":"sql.1","count":100,"aggregate":"average","start":1594886920755,"end":1594890520755,"timeout":3000} (bundle.min.js, line 2)
    [Log] [getTaskForHistoryData w00503] history options for 'mqtt.0.Wohnzimmer.Luftfeuchtigkeit': {"instance":"sql.1","count":100,"aggregate":"average","start":1594886920755,"end":1594890520755,"timeout":3000} (bundle.min.js, line 2)
    [Log] [getTaskForHistoryData w00503] history data result 'mqtt.0.Wohnzimmer.Temperatur': [{"ts":1594886920755,"val":26.23},{"ts":1594886938755,"val":26.21},{"ts":1594886974755,"val":26.21},{"ts":1594887010755,"val":26.2},{"ts":1594887046755,"val":26.21},{"ts":1594887082755,"val":26.2},{"ts":1594887118755,"val":26.21},{"ts":1594887154755,"val":26.25},{"ts":1594887190755,"val":26.23},{"ts":1594887226755,"val":26.25},{"ts":1594887262755,"val":26.25},{"ts":1594887298755,"val":26.25},{"ts":1594887334755,"val":26.28},{"ts":1594887370755,"val":26.25},{"ts":1594887406755,"val":26.28},{"ts":1594887442755,"val":26.21},{"ts":1594887478755,"val":26.21},{"ts":1594887514755,"val":26.2},{"ts":1594887550755,"val":26.23},{"ts":1594887586755,"val":26.22},{"ts":1594887622755,"val":26.27},{"ts":1594887658755,"val":26.25},{"ts":1594887694755,"val":26.23},{"ts":1594887730755,"val":26.25},{"ts":1594887766755,"val":26.3},{"ts":1594887802755,"val":26.29},{"ts":1594887838755,"val":26.28},{"ts":1594887874755,"val":26.27},{"ts":1594887910755,"val":26.3},{"ts":1594887946755,"val":26.29},{"ts":1594887982755,"val":26.29},{"ts":1594888018755,"val":26.3},{"ts":1594888054755,"val":26.32},{"ts":1594888090755,"val":26.33},{"ts":1594888126755,"val":26.32},{"ts":1594888162755,"val":26.33},{"ts":1594888198755,"val":26.36},{"ts":1594888234755,"val":26.4},{"ts":1594888270755,"val":26.43},{"ts":1594888306755,"val":26.38},{"ts":1594888342755,"val":26.43},{"ts":1594888378755,"val":26.36},{"ts":1594888414755,"val":26.42},{"ts":1594888450755,"val":26.4},{"ts":1594888486755,"val":26.42},{"ts":1594888522755,"val":26.43},{"ts":1594888558755,"val":26.42},{"ts":1594888594755,"val":26.4},{"ts":1594888630755,"val":26.4},{"ts":1594888666755,"val":26.42},{"ts":1594888702755,"val":26.4},{"ts":1594888738755,"val":26.4},{"ts":1594888774755,"val":26.38},{"ts":1594888810755,"val":26.42},{"ts":1594888846755,"val":26.4},{"ts":1594888882755,"val":26.42},{"ts":1594888918755,"val":26.42},{"ts":1594888954755,"val":26.43},{"ts":1594888990755,"val":26.42},{"ts":1594889026755,"val":26.43},{"ts":1594889062755,"val":26.4},{"ts":1594889098755,"val":26.38},{"ts":1594889134755,"val":26.36},{"ts":1594889170755,"val":26.38},{"ts":1594889206755,"val":26.38},{"ts":1594889242755,"val":26.38},{"ts":1594889278755,"val":26.35},{"ts":1594889314755,"val":26.36},{"ts":1594889350755,"val":26.33},{"ts":1594889386755,"val":26.38},{"ts":1594889422755,"val":26.38},{"ts":1594889458755,"val":26.4},{"ts":1594889494755,"val":26.42},{"ts":1594889530755,"val":26.4},{"ts":1594889566755,"val":26.36},{"ts":1594889602755,"val":26.35},{"ts":1594889638755,"val":26.34},{"ts":1594889674755,"val":26.36},{"ts":1594889710755,"val":26.33},{"ts":1594889746755,"val":26.36},{"ts":1594889782755,"val":26.35},{"ts":1594889818755,"val":26.34},{"ts":1594889854755,"val":26.33},{"ts":1594889890755,"val":26.34},{"ts":1594889926755,"val":26.38},{"ts":1594889962755,"val":26.33},{"ts":1594889998755,"val":26.38},{"ts":1594890034755,"val":26.33},{"ts":1594890070755,"val":26.34},{"ts":1594890106755,"val":26.3},{"ts":1594890142755,"val":26.32},{"ts":1594890178755,"val":26.29},{"ts":1594890214755,"val":26.3},{"ts":1594890250755,"val":26.29},{"ts":1594890286755,"val":26.3},{"ts":1594890322755,"val":26.29},{"ts":1594890358755,"val":26.3},{"ts":1594890394755,"val":26.29},{"ts":1594890430755,"val":26.29},{"ts":1594890466755,"val":26.28},{"ts":1594890502755,"val":26.32}] (bundle.min.js, line 2)
    [Log] [getTaskForHistoryData w00503] history data result 'mqtt.0.Wohnzimmer.Luftdruck' length: 101 (bundle.min.js, line 2)
    [Log] [getTaskForHistoryData w00503] history data result 'mqtt.0.Wohnzimmer.Luftdruck': [{"ts":1594886920755,"val":1010.83},{"ts":1594886938755,"val":1010.83},{"ts":1594886974755,"val":1010.84},{"ts":1594887010755,"val":1010.84},{"ts":1594887046755,"val":1010.87},{"ts":1594887082755,"val":1010.87},{"ts":1594887118755,"val":1010.86},{"ts":1594887154755,"val":1010.85},{"ts":1594887190755,"val":1010.88},{"ts":1594887226755,"val":1010.88},{"ts":1594887262755,"val":1010.89},{"ts":1594887298755,"val":1010.9},{"ts":1594887334755,"val":1010.9},{"ts":1594887370755,"val":1010.91},{"ts":1594887406755,"val":1010.91},{"ts":1594887442755,"val":1010.89},{"ts":1594887478755,"val":1010.92},{"ts":1594887514755,"val":1010.91},{"ts":1594887550755,"val":1010.92},{"ts":1594887586755,"val":1010.9},{"ts":1594887622755,"val":1010.89},{"ts":1594887658755,"val":1010.9},{"ts":1594887694755,"val":1010.9},{"ts":1594887730755,"val":1010.88},{"ts":1594887766755,"val":1010.89},{"ts":1594887802755,"val":1010.89},{"ts":1594887838755,"val":1010.92},{"ts":1594887874755,"val":1010.93},{"ts":1594887910755,"val":1010.94},{"ts":1594887946755,"val":1010.93},{"ts":1594887982755,"val":1010.93},{"ts":1594888018755,"val":1010.94},{"ts":1594888054755,"val":1010.93},{"ts":1594888090755,"val":1010.92},{"ts":1594888126755,"val":1010.92},{"ts":1594888162755,"val":1010.93},{"ts":1594888198755,"val":1010.95},{"ts":1594888234755,"val":1010.97},{"ts":1594888270755,"val":1010.96},{"ts":1594888306755,"val":1010.97},{"ts":1594888342755,"val":1010.98},{"ts":1594888378755,"val":1010.96},{"ts":1594888414755,"val":1010.98},{"ts":1594888450755,"val":1010.99},{"ts":1594888486755,"val":1010.97},{"ts":1594888522755,"val":1010.99},{"ts":1594888558755,"val":1011},{"ts":1594888594755,"val":1011},{"ts":1594888630755,"val":1010.99},{"ts":1594888666755,"val":1010.99},{"ts":1594888702755,"val":1010.97},{"ts":1594888738755,"val":1010.98},{"ts":1594888774755,"val":1010.99},{"ts":1594888810755,"val":1010.99},{"ts":1594888846755,"val":1010.97},{"ts":1594888882755,"val":1010.98},{"ts":1594888918755,"val":1010.98},{"ts":1594888954755,"val":1010.97},{"ts":1594888990755,"val":1010.97},{"ts":1594889026755,"val":1010.97},{"ts":1594889062755,"val":1010.97},{"ts":1594889098755,"val":1010.98},{"ts":1594889134755,"val":1010.98},{"ts":1594889170755,"val":1010.99},{"ts":1594889206755,"val":1010.98},{"ts":1594889242755,"val":1010.99},{"ts":1594889278755,"val":1010.98},{"ts":1594889314755,"val":1010.99},{"ts":1594889350755,"val":1010.99},{"ts":1594889386755,"val":1010.94},{"ts":1594889422755,"val":1010.95},{"ts":1594889458755,"val":1010.97},{"ts":1594889494755,"val":1010.94},{"ts":1594889530755,"val":1010.94},{"ts":1594889566755,"val":1010.93},{"ts":1594889602755,"val":1010.95},{"ts":1594889638755,"val":1010.93},{"ts":1594889674755,"val":1010.95},{"ts":1594889710755,"val":1010.94},{"ts":1594889746755,"val":1010.94},{"ts":1594889782755,"val":1010.95},{"ts":1594889818755,"val":1010.94},{"ts":1594889854755,"val":1010.97},{"ts":1594889890755,"val":1010.98},{"ts":1594889926755,"val":1010.97},{"ts":1594889962755,"val":1011},{"ts":1594889998755,"val":1010.98},{"ts":1594890034755,"val":1010.99},{"ts":1594890070755,"val":1010.98},{"ts":1594890106755,"val":1010.98},{"ts":1594890142755,"val":1010.98},{"ts":1594890178755,"val":1010.99},{"ts":1594890214755,"val":1011.01},{"ts":1594890250755,"val":1010.99},{"ts":1594890286755,"val":1010.98},{"ts":1594890322755,"val":1011},{"ts":1594890358755,"val":1010.99},{"ts":1594890394755,"val":1010.99},{"ts":1594890430755,"val":1010.99},{"ts":1594890466755,"val":1011},{"ts":1594890502755,"val":1010.99}] (bundle.min.js, line 2)
    [Log] [getTaskForHistoryData w00503] history data result 'mqtt.0.Wohnzimmer.TVOC': [{"ts":1594886920755,"val":138.6},{"ts":1594886938755,"val":141.2},{"ts":1594886974755,"val":141.83},{"ts":1594887010755,"val":143.8},{"ts":1594887046755,"val":150},{"ts":1594887082755,"val":149},{"ts":1594887118755,"val":152},{"ts":1594887154755,"val":165},{"ts":1594887190755,"val":166},{"ts":1594887226755,"val":157},{"ts":1594887262755,"val":157.2},{"ts":1594887298755,"val":155.17},{"ts":1594887334755,"val":155.6},{"ts":1594887370755,"val":152.5},{"ts":1594887406755,"val":153.17},{"ts":1594887442755,"val":153.6},{"ts":1594887478755,"val":154.5},{"ts":1594887514755,"val":152},{"ts":1594887550755,"val":154.17},{"ts":1594887586755,"val":151.6},{"ts":1594887622755,"val":152.67},{"ts":1594887658755,"val":154.17},{"ts":1594887694755,"val":155.6},{"ts":1594887730755,"val":154.33},{"ts":1594887766755,"val":151},{"ts":1594887802755,"val":149.5},{"ts":1594887838755,"val":149.4},{"ts":1594887874755,"val":148.33},{"ts":1594887910755,"val":150.67},{"ts":1594887946755,"val":148.8},{"ts":1594887982755,"val":152.33},{"ts":1594888018755,"val":150},{"ts":1594888054755,"val":149.67},{"ts":1594888090755,"val":147.2},{"ts":1594888126755,"val":148.83},{"ts":1594888162755,"val":148.67},{"ts":1594888198755,"val":149},{"ts":1594888234755,"val":151.17},{"ts":1594888270755,"val":149.8},{"ts":1594888306755,"val":149.5},{"ts":1594888342755,"val":146.4},{"ts":1594888378755,"val":149.17},{"ts":1594888414755,"val":148.5},{"ts":1594888450755,"val":149.2},{"ts":1594888486755,"val":150.17},{"ts":1594888522755,"val":147.8},{"ts":1594888558755,"val":147.33},{"ts":1594888594755,"val":147.4},{"ts":1594888630755,"val":148.67},{"ts":1594888666755,"val":148.5},{"ts":1594888702755,"val":149},{"ts":1594888738755,"val":149},{"ts":1594888774755,"val":150.2},{"ts":1594888810755,"val":146},{"ts":1594888846755,"val":147},{"ts":1594888882755,"val":145.5},{"ts":1594888918755,"val":145.33},{"ts":1594888954755,"val":144.8},{"ts":1594888990755,"val":146.83},{"ts":1594889026755,"val":150.6},{"ts":1594889062755,"val":149.33},{"ts":1594889098755,"val":148},{"ts":1594889134755,"val":149.83},{"ts":1594889170755,"val":152.5},{"ts":1594889206755,"val":148.6},{"ts":1594889242755,"val":148},{"ts":1594889278755,"val":147.2},{"ts":1594889314755,"val":147.17},{"ts":1594889350755,"val":146.8},{"ts":1594889386755,"val":143.83},{"ts":1594889422755,"val":144.33},{"ts":1594889458755,"val":146},{"ts":1594889494755,"val":144.67},{"ts":1594889530755,"val":141.4},{"ts":1594889566755,"val":140.67},{"ts":1594889602755,"val":144},{"ts":1594889638755,"val":144.33},{"ts":1594889674755,"val":145.17},{"ts":1594889710755,"val":143.2},{"ts":1594889746755,"val":142.33},{"ts":1594889782755,"val":141},{"ts":1594889818755,"val":139.83},{"ts":1594889854755,"val":143.17},{"ts":1594889890755,"val":140},{"ts":1594889926755,"val":140.67},{"ts":1594889962755,"val":140.6},{"ts":1594889998755,"val":141.5},{"ts":1594890034755,"val":139.8},{"ts":1594890070755,"val":142.17},{"ts":1594890106755,"val":140.5},{"ts":1594890142755,"val":139},{"ts":1594890178755,"val":139.67},{"ts":1594890214755,"val":140.6},{"ts":1594890250755,"val":142.5},{"ts":1594890286755,"val":143},{"ts":1594890322755,"val":141.83},{"ts":1594890358755,"val":141.67},{"ts":1594890394755,"val":141.2},{"ts":1594890430755,"val":141.33},{"ts":1594890466755,"val":140},{"ts":1594890502755,"val":140.5}] (bundle.min.js, line 2)
    [Log] [getTaskForHistoryData w00503] history data result 'mqtt.0.Wohnzimmer.Luftfeuchtigkeit': [{"ts":1594886920755,"val":41.075},{"ts":1594886938755,"val":41.19},{"ts":1594886974755,"val":41.28},{"ts":1594887010755,"val":41.18},{"ts":1594887046755,"val":41.22},{"ts":1594887082755,"val":41.14},{"ts":1594887118755,"val":41.11},{"ts":1594887154755,"val":40.51},{"ts":1594887190755,"val":41.07},{"ts":1594887226755,"val":40.83},{"ts":1594887262755,"val":41.16},{"ts":1594887298755,"val":41.22},{"ts":1594887334755,"val":40.89},{"ts":1594887370755,"val":40.81},{"ts":1594887406755,"val":41.04},{"ts":1594887442755,"val":41.1},{"ts":1594887478755,"val":41.17},{"ts":1594887514755,"val":41.18},{"ts":1594887550755,"val":41.38},{"ts":1594887586755,"val":41.32},{"ts":1594887622755,"val":41.57},{"ts":1594887658755,"val":41.18},{"ts":1594887694755,"val":41.27},{"ts":1594887730755,"val":41.3},{"ts":1594887766755,"val":41.28},{"ts":1594887802755,"val":41.24},{"ts":1594887838755,"val":41.19},{"ts":1594887874755,"val":41.19},{"ts":1594887910755,"val":41.12},{"ts":1594887946755,"val":41.07},{"ts":1594887982755,"val":40.99},{"ts":1594888018755,"val":41.04},{"ts":1594888054755,"val":41.06},{"ts":1594888090755,"val":40.99},{"ts":1594888126755,"val":40.95},{"ts":1594888162755,"val":40.96},{"ts":1594888198755,"val":40.95},{"ts":1594888234755,"val":40.92},{"ts":1594888270755,"val":40.92},{"ts":1594888306755,"val":40.93},{"ts":1594888342755,"val":40.97},{"ts":1594888378755,"val":40.96},{"ts":1594888414755,"val":40.98},{"ts":1594888450755,"val":40.93},{"ts":1594888486755,"val":40.95},{"ts":1594888522755,"val":41},{"ts":1594888558755,"val":40.97},{"ts":1594888594755,"val":40.96},{"ts":1594888630755,"val":40.97},{"ts":1594888666755,"val":40.94},{"ts":1594888702755,"val":40.94},{"ts":1594888738755,"val":40.97},{"ts":1594888774755,"val":40.99},{"ts":1594888810755,"val":41},{"ts":1594888846755,"val":40.99},{"ts":1594888882755,"val":41.03},{"ts":1594888918755,"val":41.06},{"ts":1594888954755,"val":40.98},{"ts":1594888990755,"val":40.96},{"ts":1594889026755,"val":40.99},{"ts":1594889062755,"val":40.96},{"ts":1594889098755,"val":40.96},{"ts":1594889134755,"val":40.84},{"ts":1594889170755,"val":40.88},{"ts":1594889206755,"val":40.94},{"ts":1594889242755,"val":40.9},{"ts":1594889278755,"val":40.69},{"ts":1594889314755,"val":40.93},{"ts":1594889350755,"val":41.01},{"ts":1594889386755,"val":41.01},{"ts":1594889422755,"val":41.03},{"ts":1594889458755,"val":41.05},{"ts":1594889494755,"val":41.05},{"ts":1594889530755,"val":41.07},{"ts":1594889566755,"val":41.05},{"ts":1594889602755,"val":41.01},{"ts":1594889638755,"val":41.06},{"ts":1594889674755,"val":41.05},{"ts":1594889710755,"val":41.05},{"ts":1594889746755,"val":41.04},{"ts":1594889782755,"val":41.09},{"ts":1594889818755,"val":41.04},{"ts":1594889854755,"val":41.09},{"ts":1594889890755,"val":41.08},{"ts":1594889926755,"val":41.08},{"ts":1594889962755,"val":41.08},{"ts":1594889998755,"val":41.09},{"ts":1594890034755,"val":40.98},{"ts":1594890070755,"val":41.04},{"ts":1594890106755,"val":41.07},{"ts":1594890142755,"val":41.06},{"ts":1594890178755,"val":41.06},{"ts":1594890214755,"val":41.03},{"ts":1594890250755,"val":40.93},{"ts":1594890286755,"val":40.97},{"ts":1594890322755,"val":40.9},{"ts":1594890358755,"val":40.96},{"ts":1594890394755,"val":40.93},{"ts":1594890430755,"val":40.89},{"ts":1594890466755,"val":40.9},{"ts":1594890502755,"val":40.82}] (bundle.min.js, line 2)
    [Log] [getPreparedData w00503] prepare data for 'mqtt.0.Wohnzimmer.Luftdruck' length: 101 (bundle.min.js, line 2)
    [Log] [Line History Chart w00503] chart updating... (bundle.min.js, line 2)
    [Log] [Line History Chart w00503] chart successful updated (bundle.min.js, line 2)
    [Log] [getTaskForHistoryData w00503] history options for 'mqtt.0.Wohnzimmer.Temperatur': {"instance":"sql.1","count":100,"aggregate":"average","start":1594886950755,"end":1594890550755,"timeout":3000} (bundle.min.js, line 2)
    [Log] [getTaskForHistoryData w00503] history options for 'mqtt.0.Wohnzimmer.Luftdruck': {"instance":"sql.1","count":100,"aggregate":"average","start":1594886950755,"end":1594890550755,"timeout":3000} (bundle.min.js, line 2)
    [Log] [getTaskForHistoryData w00503] history options for 'mqtt.0.Wohnzimmer.TVOC': {"instance":"sql.1","count":100,"aggregate":"average","start":1594886950755,"end":1594890550755,"timeout":3000} (bundle.min.js, line 2)
    [Log] [getTaskForHistoryData w00503] history options for 'mqtt.0.Wohnzimmer.Luftfeuchtigkeit': {"instance":"sql.1","count":100,"aggregate":"average","start":1594886950755,"end":1594890550756,"timeout":3000} (bundle.min.js, line 2)
    [Log] [getTaskForHistoryData w00503] history data result 'mqtt.0.Wohnzimmer.Temperatur': [{"ts":1594886950755,"val":26.23},{"ts":1594886968755,"val":26.21},{"ts":1594887004755,"val":26.2},{"ts":1594887040755,"val":26.21},{"ts":1594887076755,"val":26.22},{"ts":1594887112755,"val":26.21},{"ts":1594887148755,"val":26.23},{"ts":1594887184755,"val":26.2},{"ts":1594887220755,"val":26.27},{"ts":1594887256755,"val":26.25},{"ts":1594887292755,"val":26.25},{"ts":1594887328755,"val":26.28},{"ts":1594887364755,"val":26.25},{"ts":1594887400755,"val":26.27},{"ts":1594887436755,"val":26.2},{"ts":1594887472755,"val":26.21},{"ts":1594887508755,"val":26.2},{"ts":1594887544755,"val":26.23},{"ts":1594887580755,"val":26.25},{"ts":1594887616755,"val":26.25},{"ts":1594887652755,"val":26.25},{"ts":1594887688755,"val":26.22},{"ts":1594887724755,"val":26.25},{"ts":1594887760755,"val":26.3},{"ts":1594887796755,"val":26.27},{"ts":1594887832755,"val":26.3},{"ts":1594887868755,"val":26.27},{"ts":1594887904755,"val":26.29},{"ts":1594887940755,"val":26.3},{"ts":1594887976755,"val":26.29},{"ts":1594888012755,"val":26.28},{"ts":1594888048755,"val":26.32},{"ts":1594888084755,"val":26.33},{"ts":1594888120755,"val":26.32},{"ts":1594888156755,"val":26.34},{"ts":1594888192755,"val":26.35},{"ts":1594888228755,"val":26.4},{"ts":1594888264755,"val":26.43},{"ts":1594888300755,"val":26.38},{"ts":1594888336755,"val":26.4},{"ts":1594888372755,"val":26.38},{"ts":1594888408755,"val":26.4},{"ts":1594888444755,"val":26.43},{"ts":1594888480755,"val":26.42},{"ts":1594888516755,"val":26.43},{"ts":1594888552755,"val":26.42},{"ts":1594888588755,"val":26.4},{"ts":1594888624755,"val":26.4},{"ts":1594888660755,"val":26.42},{"ts":1594888696755,"val":26.4},{"ts":1594888732755,"val":26.4},{"ts":1594888768755,"val":26.35},{"ts":1594888804755,"val":26.42},{"ts":1594888840755,"val":26.43},{"ts":1594888876755,"val":26.42},{"ts":1594888912755,"val":26.42},{"ts":1594888948755,"val":26.43},{"ts":1594888984755,"val":26.42},{"ts":1594889020755,"val":26.43},{"ts":1594889056755,"val":26.4},{"ts":1594889092755,"val":26.38},{"ts":1594889128755,"val":26.36},{"ts":1594889164755,"val":26.38},{"ts":1594889200755,"val":26.38},{"ts":1594889236755,"val":26.38},{"ts":1594889272755,"val":26.35},{"ts":1594889308755,"val":26.36},{"ts":1594889344755,"val":26.35},{"ts":1594889380755,"val":26.36},{"ts":1594889416755,"val":26.38},{"ts":1594889452755,"val":26.4},{"ts":1594889488755,"val":26.42},{"ts":1594889524755,"val":26.38},{"ts":1594889560755,"val":26.38},{"ts":1594889596755,"val":26.35},{"ts":1594889632755,"val":26.34},{"ts":1594889668755,"val":26.36},{"ts":1594889704755,"val":26.35},{"ts":1594889740755,"val":26.36},{"ts":1594889776755,"val":26.33},{"ts":1594889812755,"val":26.34},{"ts":1594889848755,"val":26.34},{"ts":1594889884755,"val":26.33},{"ts":1594889920755,"val":26.38},{"ts":1594889956755,"val":26.35},{"ts":1594889992755,"val":26.36},{"ts":1594890028755,"val":26.35},{"ts":1594890064755,"val":26.32},{"ts":1594890100755,"val":26.32},{"ts":1594890136755,"val":26.3},{"ts":1594890172755,"val":26.29},{"ts":1594890208755,"val":26.33},{"ts":1594890244755,"val":26.29},{"ts":1594890280755,"val":26.3},{"ts":1594890316755,"val":26.29},{"ts":1594890352755,"val":26.29},{"ts":1594890388755,"val":26.28},{"ts":1594890424755,"val":26.29},{"ts":1594890460755,"val":26.3},{"ts":1594890496755,"val":26.32},{"ts":1594890532755,"val":26.28}] (bundle.min.js, line 2)
    [Log] [getTaskForHistoryData w00503] history data result 'mqtt.0.Wohnzimmer.Luftdruck': [{"ts":1594886950755,"val":1010.84},{"ts":1594886968755,"val":1010.84},{"ts":1594887004755,"val":1010.84},{"ts":1594887040755,"val":1010.86},{"ts":1594887076755,"val":1010.87},{"ts":1594887112755,"val":1010.86},{"ts":1594887148755,"val":1010.85},{"ts":1594887184755,"val":1010.87},{"ts":1594887220755,"val":1010.88},{"ts":1594887256755,"val":1010.89},{"ts":1594887292755,"val":1010.9},{"ts":1594887328755,"val":1010.9},{"ts":1594887364755,"val":1010.91},{"ts":1594887400755,"val":1010.91},{"ts":1594887436755,"val":1010.9},{"ts":1594887472755,"val":1010.91},{"ts":1594887508755,"val":1010.91},{"ts":1594887544755,"val":1010.92},{"ts":1594887580755,"val":1010.9},{"ts":1594887616755,"val":1010.89},{"ts":1594887652755,"val":1010.9},{"ts":1594887688755,"val":1010.9},{"ts":1594887724755,"val":1010.88},{"ts":1594887760755,"val":1010.89},{"ts":1594887796755,"val":1010.9},{"ts":1594887832755,"val":1010.91},{"ts":1594887868755,"val":1010.93},{"ts":1594887904755,"val":1010.94},{"ts":1594887940755,"val":1010.94},{"ts":1594887976755,"val":1010.93},{"ts":1594888012755,"val":1010.94},{"ts":1594888048755,"val":1010.93},{"ts":1594888084755,"val":1010.93},{"ts":1594888120755,"val":1010.92},{"ts":1594888156755,"val":1010.93},{"ts":1594888192755,"val":1010.94},{"ts":1594888228755,"val":1010.96},{"ts":1594888264755,"val":1010.97},{"ts":1594888300755,"val":1010.97},{"ts":1594888336755,"val":1010.97},{"ts":1594888372755,"val":1010.96},{"ts":1594888408755,"val":1010.99},{"ts":1594888444755,"val":1010.98},{"ts":1594888480755,"val":1010.98},{"ts":1594888516755,"val":1010.99},{"ts":1594888552755,"val":1010.99},{"ts":1594888588755,"val":1011},{"ts":1594888624755,"val":1010.99},{"ts":1594888660755,"val":1010.99},{"ts":1594888696755,"val":1010.98},{"ts":1594888732755,"val":1010.98},{"ts":1594888768755,"val":1010.99},{"ts":1594888804755,"val":1010.99},{"ts":1594888840755,"val":1010.97},{"ts":1594888876755,"val":1010.99},{"ts":1594888912755,"val":1010.98},{"ts":1594888948755,"val":1010.97},{"ts":1594888984755,"val":1010.97},{"ts":1594889020755,"val":1010.96},{"ts":1594889056755,"val":1010.97},{"ts":1594889092755,"val":1010.98},{"ts":1594889128755,"val":1010.98},{"ts":1594889164755,"val":1010.99},{"ts":1594889200755,"val":1010.99},{"ts":1594889236755,"val":1010.98},{"ts":1594889272755,"val":1010.99},{"ts":1594889308755,"val":1010.98},{"ts":1594889344755,"val":1010.99},{"ts":1594889380755,"val":1010.95},{"ts":1594889416755,"val":1010.95},{"ts":1594889452755,"val":1010.97},{"ts":1594889488755,"val":1010.95},{"ts":1594889524755,"val":1010.94},{"ts":1594889560755,"val":1010.94},{"ts":1594889596755,"val":1010.94},{"ts":1594889632755,"val":1010.93},{"ts":1594889668755,"val":1010.94},{"ts":1594889704755,"val":1010.94},{"ts":1594889740755,"val":1010.94},{"ts":1594889776755,"val":1010.95},{"ts":1594889812755,"val":1010.94},{"ts":1594889848755,"val":1010.96},{"ts":1594889884755,"val":1010.98},{"ts":1594889920755,"val":1010.98},{"ts":1594889956755,"val":1010.99},{"ts":1594889992755,"val":1010.98},{"ts":1594890028755,"val":1010.99},{"ts":1594890064755,"val":1010.98},{"ts":1594890100755,"val":1010.98},{"ts":1594890136755,"val":1010.98},{"ts":1594890172755,"val":1010.99},{"ts":1594890208755,"val":1011.01},{"ts":1594890244755,"val":1011},{"ts":1594890280755,"val":1010.98},{"ts":1594890316755,"val":1011},{"ts":1594890352755,"val":1011},{"ts":1594890388755,"val":1010.98},{"ts":1594890424755,"val":1010.99},{"ts":1594890460755,"val":1011},{"ts":1594890496755,"val":1010.99},{"ts":1594890532755,"val":1011.01}] (bundle.min.js, line 2)
    [Log] [getTaskForHistoryData w00503] history data result 'mqtt.0.Wohnzimmer.TVOC': [{"ts":1594886950755,"val":142.66500000000002},{"ts":1594886968755,"val":142.33},{"ts":1594887004755,"val":142.4},{"ts":1594887040755,"val":149.83},{"ts":1594887076755,"val":148.8},{"ts":1594887112755,"val":151},{"ts":1594887148755,"val":163},{"ts":1594887184755,"val":167},{"ts":1594887220755,"val":158.33},{"ts":1594887256755,"val":156.8},{"ts":1594887292755,"val":155.5},{"ts":1594887328755,"val":155.6},{"ts":1594887364755,"val":152.83},{"ts":1594887400755,"val":153},{"ts":1594887436755,"val":153.4},{"ts":1594887472755,"val":155},{"ts":1594887508755,"val":151.8},{"ts":1594887544755,"val":154},{"ts":1594887580755,"val":152.2},{"ts":1594887616755,"val":152.33},{"ts":1594887652755,"val":153.83},{"ts":1594887688755,"val":155.2},{"ts":1594887724755,"val":155.33},{"ts":1594887760755,"val":151.2},{"ts":1594887796755,"val":149.83},{"ts":1594887832755,"val":149.4},{"ts":1594887868755,"val":148},{"ts":1594887904755,"val":150.67},{"ts":1594887940755,"val":148.8},{"ts":1594887976755,"val":152},{"ts":1594888012755,"val":150.6},{"ts":1594888048755,"val":149.67},{"ts":1594888084755,"val":147.4},{"ts":1594888120755,"val":149},{"ts":1594888156755,"val":148.67},{"ts":1594888192755,"val":148.4},{"ts":1594888228755,"val":151},{"ts":1594888264755,"val":149.8},{"ts":1594888300755,"val":150.17},{"ts":1594888336755,"val":146.5},{"ts":1594888372755,"val":149},{"ts":1594888408755,"val":149},{"ts":1594888444755,"val":148.4},{"ts":1594888480755,"val":150.67},{"ts":1594888516755,"val":148.4},{"ts":1594888552755,"val":146.67},{"ts":1594888588755,"val":147.67},{"ts":1594888624755,"val":149},{"ts":1594888660755,"val":148.17},{"ts":1594888696755,"val":149.2},{"ts":1594888732755,"val":148.67},{"ts":1594888768755,"val":150.6},{"ts":1594888804755,"val":146.17},{"ts":1594888840755,"val":147},{"ts":1594888876755,"val":145.6},{"ts":1594888912755,"val":145.17},{"ts":1594888948755,"val":144.8},{"ts":1594888984755,"val":146.33},{"ts":1594889020755,"val":150.6},{"ts":1594889056755,"val":149.17},{"ts":1594889092755,"val":148.33},{"ts":1594889128755,"val":149.4},{"ts":1594889164755,"val":152.5},{"ts":1594889200755,"val":149.6},{"ts":1594889236755,"val":148},{"ts":1594889272755,"val":146.8},{"ts":1594889308755,"val":147.67},{"ts":1594889344755,"val":146.67},{"ts":1594889380755,"val":144},{"ts":1594889416755,"val":143.83},{"ts":1594889452755,"val":146.2},{"ts":1594889488755,"val":145},{"ts":1594889524755,"val":142},{"ts":1594889560755,"val":140.17},{"ts":1594889596755,"val":143.83},{"ts":1594889632755,"val":144.4},{"ts":1594889668755,"val":144.83},{"ts":1594889704755,"val":143.8},{"ts":1594889740755,"val":142.67},{"ts":1594889776755,"val":141.2},{"ts":1594889812755,"val":139.33},{"ts":1594889848755,"val":143.33},{"ts":1594889884755,"val":140.2},{"ts":1594889920755,"val":140.67},{"ts":1594889956755,"val":140.4},{"ts":1594889992755,"val":141.67},{"ts":1594890028755,"val":139.8},{"ts":1594890064755,"val":142.17},{"ts":1594890100755,"val":140.17},{"ts":1594890136755,"val":140},{"ts":1594890172755,"val":139.5},{"ts":1594890208755,"val":140.4},{"ts":1594890244755,"val":142},{"ts":1594890280755,"val":143.2},{"ts":1594890316755,"val":141.83},{"ts":1594890352755,"val":142},{"ts":1594890388755,"val":140.8},{"ts":1594890424755,"val":141.5},{"ts":1594890460755,"val":140.4},{"ts":1594890496755,"val":140},{"ts":1594890532755,"val":140.6}] (bundle.min.js, line 2)
    [Log] [getTaskForHistoryData w00503] history data result 'mqtt.0.Wohnzimmer.Luftfeuchtigkeit': [{"ts":1594886950755,"val":41.29},{"ts":1594886968755,"val":41.28},{"ts":1594887004755,"val":41.18},{"ts":1594887040755,"val":41.24},{"ts":1594887076755,"val":41.14},{"ts":1594887112755,"val":41.22},{"ts":1594887148755,"val":40.46},{"ts":1594887184755,"val":41.05},{"ts":1594887220755,"val":40.79},{"ts":1594887256755,"val":41.13},{"ts":1594887292755,"val":41.23},{"ts":1594887328755,"val":40.99},{"ts":1594887364755,"val":40.75},{"ts":1594887400755,"val":41.01},{"ts":1594887436755,"val":41.1},{"ts":1594887472755,"val":41.18},{"ts":1594887508755,"val":41.15},{"ts":1594887544755,"val":41.35},{"ts":1594887580755,"val":41.29},{"ts":1594887616755,"val":41.58},{"ts":1594887652755,"val":41.22},{"ts":1594887688755,"val":41.26},{"ts":1594887724755,"val":41.3},{"ts":1594887760755,"val":41.29},{"ts":1594887796755,"val":41.24},{"ts":1594887832755,"val":41.2},{"ts":1594887868755,"val":41.19},{"ts":1594887904755,"val":41.14},{"ts":1594887940755,"val":41.08},{"ts":1594887976755,"val":40.99},{"ts":1594888012755,"val":41.04},{"ts":1594888048755,"val":41.06},{"ts":1594888084755,"val":41.01},{"ts":1594888120755,"val":40.95},{"ts":1594888156755,"val":40.96},{"ts":1594888192755,"val":40.95},{"ts":1594888228755,"val":40.92},{"ts":1594888264755,"val":40.92},{"ts":1594888300755,"val":40.93},{"ts":1594888336755,"val":40.97},{"ts":1594888372755,"val":40.95},{"ts":1594888408755,"val":40.98},{"ts":1594888444755,"val":40.93},{"ts":1594888480755,"val":40.96},{"ts":1594888516755,"val":40.99},{"ts":1594888552755,"val":40.97},{"ts":1594888588755,"val":40.97},{"ts":1594888624755,"val":40.95},{"ts":1594888660755,"val":40.96},{"ts":1594888696755,"val":40.93},{"ts":1594888732755,"val":40.97},{"ts":1594888768756,"val":40.98},{"ts":1594888804756,"val":41.01},{"ts":1594888840756,"val":40.99},{"ts":1594888876756,"val":41.02},{"ts":1594888912756,"val":41.05},{"ts":1594888948756,"val":41.01},{"ts":1594888984756,"val":40.94},{"ts":1594889020756,"val":40.99},{"ts":1594889056756,"val":40.98},{"ts":1594889092756,"val":40.96},{"ts":1594889128756,"val":40.85},{"ts":1594889164756,"val":40.88},{"ts":1594889200756,"val":40.93},{"ts":1594889236756,"val":40.93},{"ts":1594889272756,"val":40.67},{"ts":1594889308756,"val":40.92},{"ts":1594889344756,"val":41},{"ts":1594889380756,"val":41.01},{"ts":1594889416756,"val":41.03},{"ts":1594889452756,"val":41.05},{"ts":1594889488756,"val":41.05},{"ts":1594889524756,"val":41.07},{"ts":1594889560756,"val":41.06},{"ts":1594889596756,"val":41.01},{"ts":1594889632756,"val":41.05},{"ts":1594889668756,"val":41.05},{"ts":1594889704756,"val":41.05},{"ts":1594889740756,"val":41.05},{"ts":1594889776756,"val":41.08},{"ts":1594889812756,"val":41.05},{"ts":1594889848756,"val":41.08},{"ts":1594889884756,"val":41.09},{"ts":1594889920756,"val":41.08},{"ts":1594889956756,"val":41.08},{"ts":1594889992756,"val":41.09},{"ts":1594890028756,"val":40.99},{"ts":1594890064756,"val":41.03},{"ts":1594890100756,"val":41.07},{"ts":1594890136756,"val":41.06},{"ts":1594890172756,"val":41.05},{"ts":1594890208756,"val":41.05},{"ts":1594890244756,"val":40.92},{"ts":1594890280756,"val":40.97},{"ts":1594890316756,"val":40.92},{"ts":1594890352756,"val":40.95},{"ts":1594890388756,"val":40.94},{"ts":1594890424756,"val":40.9},{"ts":1594890460756,"val":40.91},{"ts":1594890496756,"val":40.82},{"ts":1594890532756,"val":40.84}] (bundle.min.js, line 2)
    Ich kann da halt nicht wirklich was anklicken. Das verhält sich, als wäre es nur ein Bild. Wenn ich allerdings aus dem Editor heraus nur die eine Card starte funktioniert das auch mit der Bedienung. Nur auf der Seite mit dem Masonry View, wo die Card drin eingebunden ist, kann ich das nicht bedienen. Als wäre das verdeckt.
    EDIT: Es wäre noch anzumerken, dass es scheinbar nur im Safari unter macOS Catalina so ist. Vielleicht macht es nicht wirklich sinn, da jetzt was zu suchen.
    macOS Catalina - Safari: nicht bedienbar
    macOS Catalina - Chrome: funktioniert einwandfrei
    iOS 13.5.1 - Safari (iPhone): funktioniert auch
    MaikB85
    #119
    @MaikB85 sagte in Material Design Widgets: Line History Chart Widget:
    Also ... Die Warnings hab ich soweit weg. War noch wegen dem ganzen Umbauen auf die MDWs.
    Hab mal den Debug Mode aktiviert für das Chart. Allerdings ist da glaube ich nicht viel zu sehen:
    [Warning] ApplicationCache is deprecated. Please use ServiceWorkers instead. (index.html, line 2)
    [Log] Version Info-Adapter-Widget: 0.0.9 (info.js, line 21)
    [Log] Version justgage: 1.0.2 (justgage.js, line 115)
    [Error] Failed to load resource: the server responded with a status of 404 (Not Found) (socket.io.js.map, line 0)
    [Error] Failed to load resource: the server responded with a status of 404 (Not Found) (materialdesignicons.css.map, line 0)
    [Log] 2020-07-16T09:08:10.111Z Connected => authenticate (conn.js, line 273)
    [Info] Download the Vue Devtools extension for a better development experience: (lib.min.js, line 22)
    https://github.com/vuejs/vue-devtools
    [Info] You are running Vue in development mode. (lib.min.js, line 22)
    Make sure to turn on production mode when deploying for production.
    See more tips at https://vuejs.org/guide/deployment.html
    [Log] 2020-07-16T09:08:10.235Z Authenticated: true (conn.js, line 293)
    [Log] Version vis-materialdesign: 0.3.14 (materialdesign.js, line 33)
    [Debug] Request 0 states. (bundle.min.js, line 2)
    [Log] Create inner vis object s7.0.DBs.DB4.Perlschlauch_hinten_Mode (bundle.min.js, line 2)
    [Log] Create inner vis object s7.0.DBs.DB4.Perlschlauch_hinten_wettermode (bundle.min.js, line 2)
    [Log] Create inner vis object mqtt.0.Garten.Rasen_vorne.Startzeit_Stunde (bundle.min.js, line 2)
    [Log] Create inner vis object mqtt.0.Garten.Rasen_vorne.Startzeit_Minute (bundle.min.js, line 2)
    [Log] Create inner vis object s7.0.DBs.DB4.Perlschlauch_hinten_interval (bundle.min.js, line 2)
    [Log] Create inner vis object s7.0.DBs.DB4.Perlschlauch_hinten_Dauer (bundle.min.js, line 2)
    [Log] Create inner vis object s7.0.DBs.DB4.Perlschlauch_hinten_aussetzen (bundle.min.js, line 2)
    [Log] Create inner vis object s7.0.DBs.DB4.Perlschlauch_hinten_manuell_Start (bundle.min.js, line 2)
    [Log] Create inner vis object s7.0.DBs.DB4.Perlschlauch_hinten_Restlaufzeit (bundle.min.js, line 2)
    [Log] Create inner vis object s7.0.DBs.DB4.Perlschlauch_vorne_Mode (bundle.min.js, line 2)
    [Log] Create inner vis object s7.0.DBs.DB4.Perlschlauch_vorne_wettermode (bundle.min.js, line 2)
    [Log] Create inner vis object s7.0.DBs.DB4.Perlschlauch_vorne_interval (bundle.min.js, line 2)
    [Log] Create inner vis object s7.0.DBs.DB4.Perlschlauch_vorne_Dauer (bundle.min.js, line 2)
    [Log] Create inner vis object s7.0.DBs.DB4.Perlschlauch_vorne_aussetzen (bundle.min.js, line 2)
    [Log] Create inner vis object s7.0.DBs.DB4.Perlschlauch_vorne_manuell_Start (bundle.min.js, line 2)
    [Log] Create inner vis object s7.0.DBs.DB4.Perlschlauch_vorne_Restlaufzeit (bundle.min.js, line 2)
    [Log] Create inner vis object s7.0.DBs.DB4.Rasen_hinten_Mode (bundle.min.js, line 2)
    [Log] Create inner vis object s7.0.DBs.DB4.Rasen_vorne_Mode (bundle.min.js, line 2)
    [Log] Create inner vis object s7.0.DBs.DB4.Rasen_hinten_wettermode (bundle.min.js, line 2)
    [Log] Create inner vis object s7.0.DBs.DB4.Rasen_hinten_interval (bundle.min.js, line 2)
    [Log] Create inner vis object s7.0.DBs.DB4.Rasen_hinten_Dauer (bundle.min.js, line 2)
    [Log] Create inner vis object s7.0.DBs.DB4.Rasen_hinten_aussetzen (bundle.min.js, line 2)
    [Log] Create inner vis object s7.0.DBs.DB4.Rasen_hinten_manuell_Start (bundle.min.js, line 2)
    [Log] Create inner vis object s7.0.DBs.DB4.Rasen_hinten_Restlaufzeit (bundle.min.js, line 2)
    [Log] Create inner vis object s7.0.DBs.DB4.Rasen_vorne_wettermode (bundle.min.js, line 2)
    [Log] Create inner vis object s7.0.DBs.DB4.Rasen_vorne_interval (bundle.min.js, line 2)
    [Log] Create inner vis object s7.0.DBs.DB4.Rasen_vorne_Dauer (bundle.min.js, line 2)
    [Log] Create inner vis object s7.0.DBs.DB4.Rasen_vorne_aussetzen (bundle.min.js, line 2)
    [Log] Create inner vis object s7.0.DBs.DB4.Rasen_vorne_manuell_Start (bundle.min.js, line 2)
    [Log] Create inner vis object s7.0.DBs.DB4.Rasen_vorne_Restlaufzeit (bundle.min.js, line 2)
    [Log] Create inner vis object s7.0.DBs.DB4.Brunnenpumpe_Ein (bundle.min.js, line 2)
    [Log] Create inner vis object s7.0.DBs.DB4.Druck_Brunnenwasser (bundle.min.js, line 2)
    [Log] Create inner vis object s7.0.DBs.DB4.Durchfluss_Brunnenwasser (bundle.min.js, line 2)
    [Log] Create inner vis object maxcube.0.devices.contact_1595e8.error (bundle.min.js, line 2)
    [Log] Create inner vis object maxcube.0.devices.contact_1595e8.battery_low (bundle.min.js, line 2)
    [Log] Create inner vis object maxcube.0.devices.contact_1595e8.link_error (bundle.min.js, line 2)
    [Log] Create inner vis object maxcube.0.devices.contact_1595e8.opened (bundle.min.js, line 2)
    [Log] Create inner vis object maxcube.0.devices.contact_1b3239.error (bundle.min.js, line 2)
    [Log] Create inner vis object maxcube.0.devices.contact_1b3239.battery_low (bundle.min.js, line 2)
    [Log] Create inner vis object maxcube.0.devices.contact_1b3239.link_error (bundle.min.js, line 2)
    [Log] Create inner vis object maxcube.0.devices.contact_1b3239.opened (bundle.min.js, line 2)
    [Log] Create inner vis object maxcube.0.devices.contact_1b3193.error (bundle.min.js, line 2)
    [Log] Create inner vis object maxcube.0.devices.contact_1b3193.battery_low (bundle.min.js, line 2)
    [Log] Create inner vis object maxcube.0.devices.contact_1b3193.link_error (bundle.min.js, line 2)
    [Log] Create inner vis object maxcube.0.devices.contact_1b3193.opened (bundle.min.js, line 2)
    [Log] Create inner vis object maxcube.0.devices.contact_1b31e1.error (bundle.min.js, line 2)
    [Log] Create inner vis object maxcube.0.devices.contact_1b31e1.battery_low (bundle.min.js, line 2)
    [Log] Create inner vis object maxcube.0.devices.contact_1b31e1.link_error (bundle.min.js, line 2)
    [Log] Create inner vis object maxcube.0.devices.contact_1b31e1.opened (bundle.min.js, line 2)
    [Log] Create inner vis object maxcube.0.devices.contact_1b34bc.error (bundle.min.js, line 2)
    [Log] Create inner vis object maxcube.0.devices.contact_1b34bc.battery_low (bundle.min.js, line 2)
    [Log] Create inner vis object maxcube.0.devices.contact_1b34bc.link_error (bundle.min.js, line 2)
    [Log] Create inner vis object maxcube.0.devices.contact_1b34bc.opened (bundle.min.js, line 2)
    [Log] Create inner vis object maxcube.0.devices.contact_1b3179.error (bundle.min.js, line 2)
    [Log] Create inner vis object maxcube.0.devices.contact_1b3179.battery_low (bundle.min.js, line 2)
    [Log] Create inner vis object maxcube.0.devices.contact_1b3179.link_error (bundle.min.js, line 2)
    [Log] Create inner vis object maxcube.0.devices.contact_1b3179.opened (bundle.min.js, line 2)
    [Log] Create inner vis object maxcube.0.devices.contact_159811.error (bundle.min.js, line 2)
    [Log] Create inner vis object maxcube.0.devices.contact_159811.battery_low (bundle.min.js, line 2)
    [Log] Create inner vis object maxcube.0.devices.contact_159811.link_error (bundle.min.js, line 2)
    [Log] Create inner vis object maxcube.0.devices.contact_159811.opened (bundle.min.js, line 2)
    [Log] Create inner vis object maxcube.0.devices.contact_15951a.error (bundle.min.js, line 2)
    [Log] Create inner vis object maxcube.0.devices.contact_15951a.battery_low (bundle.min.js, line 2)
    [Log] Create inner vis object maxcube.0.devices.contact_15951a.link_error (bundle.min.js, line 2)
    [Log] Create inner vis object maxcube.0.devices.contact_15951a.opened (bundle.min.js, line 2)
    [Log] Create inner vis object maxcube.0.devices.contact_1b3203.error (bundle.min.js, line 2)
    [Log] Create inner vis object maxcube.0.devices.contact_1b3203.battery_low (bundle.min.js, line 2)
    [Log] Create inner vis object maxcube.0.devices.contact_1b3203.link_error (bundle.min.js, line 2)
    [Log] Create inner vis object maxcube.0.devices.contact_1b3203.opened (bundle.min.js, line 2)
    [Log] Create inner vis object maxcube.0.devices.contact_1b3183.error (bundle.min.js, line 2)
    [Log] Create inner vis object maxcube.0.devices.contact_1b3183.battery_low (bundle.min.js, line 2)
    [Log] Create inner vis object maxcube.0.devices.contact_1b3183.link_error (bundle.min.js, line 2)
    [Log] Create inner vis object maxcube.0.devices.contact_1b3183.opened (bundle.min.js, line 2)
    [Log] Create inner vis object maxcube.0.devices.contact_1593e1.error (bundle.min.js, line 2)
    [Log] Create inner vis object maxcube.0.devices.contact_1593e1.battery_low (bundle.min.js, line 2)
    [Log] Create inner vis object maxcube.0.devices.contact_1593e1.link_error (bundle.min.js, line 2)
    [Log] Create inner vis object maxcube.0.devices.contact_1593e1.opened (bundle.min.js, line 2)
    [Log] Create inner vis object maxcube.0.devices.contact_1593be.error (bundle.min.js, line 2)
    [Log] Create inner vis object maxcube.0.devices.contact_1593be.battery_low (bundle.min.js, line 2)
    [Log] Create inner vis object maxcube.0.devices.contact_1593be.link_error (bundle.min.js, line 2)
    [Log] Create inner vis object maxcube.0.devices.contact_1593be.opened (bundle.min.js, line 2)
    [Log] Create inner vis object maxcube.0.devices.contact_17871e.error (bundle.min.js, line 2)
    [Log] Create inner vis object maxcube.0.devices.contact_17871e.battery_low (bundle.min.js, line 2)
    [Log] Create inner vis object maxcube.0.devices.contact_17871e.link_error (bundle.min.js, line 2)
    [Log] Create inner vis object maxcube.0.devices.contact_17871e.opened (bundle.min.js, line 2)
    [Log] Create inner vis object s7.0.DBs.DB9.Mode (bundle.min.js, line 2)
    [Log] Create inner vis object s7.0.DBs.DB9.Bandantrieb_Ein (bundle.min.js, line 2)
    [Log] Create inner vis object s7.0.DBs.DB9.Magnetventil_Ein (bundle.min.js, line 2)
    [Log] Create inner vis object s7.0.DBs.DB9.Status_Bandantrieb (bundle.min.js, line 2)
    [Log] Create inner vis object s7.0.DBs.DB9.Status_Magnetventil (bundle.min.js, line 2)
    [Log] Create inner vis object s7.0.DBs.DB9.Abreinigungszeit (bundle.min.js, line 2)
    [Log] Create inner vis object s7.0.DBs.DB9.Verzoegerung_Ventil (bundle.min.js, line 2)
    [Log] Create inner vis object 0_userdata.0.Charts.KlimaWohnzimmer (bundle.min.js, line 2)
    [Log] Create inner vis object maxcube.0.devices.thermostat_155528.setpoint (bundle.min.js, line 2)
    [Log] Create inner vis object maxcube.0.devices.thermostat_155528.error (bundle.min.js, line 2)
    [Log] Create inner vis object maxcube.0.devices.thermostat_155528.battery_low (bundle.min.js, line 2)
    [Log] Create inner vis object maxcube.0.devices.thermostat_155528.link_error (bundle.min.js, line 2)
    [Log] Create inner vis object maxcube.0.devices.thermostat_155528.mode (bundle.min.js, line 2)
    [Log] Create inner vis object maxcube.0.devices.thermostat_178cc3.setpoint (bundle.min.js, line 2)
    [Log] Create inner vis object maxcube.0.devices.thermostat_178cc3.error (bundle.min.js, line 2)
    [Log] Create inner vis object maxcube.0.devices.thermostat_178cc3.battery_low (bundle.min.js, line 2)
    [Log] Create inner vis object maxcube.0.devices.thermostat_178cc3.link_error (bundle.min.js, line 2)
    [Log] Create inner vis object maxcube.0.devices.thermostat_178cc3.mode (bundle.min.js, line 2)
    [Log] Create inner vis object maxcube.0.devices.thermostat_178cd2.setpoint (bundle.min.js, line 2)
    [Log] Create inner vis object maxcube.0.devices.thermostat_178cd2.error (bundle.min.js, line 2)
    [Log] Create inner vis object maxcube.0.devices.thermostat_178cd2.battery_low (bundle.min.js, line 2)
    [Log] Create inner vis object maxcube.0.devices.thermostat_178cd2.link_error (bundle.min.js, line 2)
    [Log] Create inner vis object maxcube.0.devices.thermostat_178cd2.mode (bundle.min.js, line 2)
    [Log] Create inner vis object maxcube.0.devices.thermostat_178cec.setpoint (bundle.min.js, line 2)
    [Log] Create inner vis object maxcube.0.devices.thermostat_178cec.error (bundle.min.js, line 2)
    [Log] Create inner vis object maxcube.0.devices.thermostat_178cec.battery_low (bundle.min.js, line 2)
    [Log] Create inner vis object maxcube.0.devices.thermostat_178cec.link_error (bundle.min.js, line 2)
    [Log] Create inner vis object maxcube.0.devices.thermostat_178cec.mode (bundle.min.js, line 2)
    [Log] Create inner vis object maxcube.0.devices.thermostat_15555b.setpoint (bundle.min.js, line 2)
    [Log] Create inner vis object maxcube.0.devices.thermostat_15555b.error (bundle.min.js, line 2)
    [Log] Create inner vis object maxcube.0.devices.thermostat_15555b.battery_low (bundle.min.js, line 2)
    [Log] Create inner vis object maxcube.0.devices.thermostat_15555b.link_error (bundle.min.js, line 2)
    [Log] Create inner vis object maxcube.0.devices.thermostat_15555b.mode (bundle.min.js, line 2)
    [Log] Create inner vis object maxcube.0.devices.thermostat_166422.setpoint (bundle.min.js, line 2)
    [Log] Create inner vis object maxcube.0.devices.thermostat_166422.error (bundle.min.js, line 2)
    [Log] Create inner vis object maxcube.0.devices.thermostat_166422.battery_low (bundle.min.js, line 2)
    [Log] Create inner vis object maxcube.0.devices.thermostat_166422.link_error (bundle.min.js, line 2)
    [Log] Create inner vis object maxcube.0.devices.thermostat_166422.mode (bundle.min.js, line 2)
    [Log] Create inner vis object maxcube.0.devices.thermostat_178ce1.setpoint (bundle.min.js, line 2)
    [Log] Create inner vis object maxcube.0.devices.thermostat_178ce1.error (bundle.min.js, line 2)
    [Log] Create inner vis object maxcube.0.devices.thermostat_178ce1.battery_low (bundle.min.js, line 2)
    [Log] Create inner vis object maxcube.0.devices.thermostat_178ce1.link_error (bundle.min.js, line 2)
    [Log] Create inner vis object maxcube.0.devices.thermostat_178ce1.mode (bundle.min.js, line 2)
    [Log] Create inner vis object maxcube.0.devices.thermostat_16641c.setpoint (bundle.min.js, line 2)
    [Log] Create inner vis object maxcube.0.devices.thermostat_16641c.error (bundle.min.js, line 2)
    [Log] Create inner vis object maxcube.0.devices.thermostat_16641c.battery_low (bundle.min.js, line 2)
    [Log] Create inner vis object maxcube.0.devices.thermostat_16641c.link_error (bundle.min.js, line 2)
    [Log] Create inner vis object maxcube.0.devices.thermostat_16641c.mode (bundle.min.js, line 2)
    [Log] Create inner vis object maxcube.0.devices.thermostat_155101.setpoint (bundle.min.js, line 2)
    [Log] Create inner vis object maxcube.0.devices.thermostat_155101.error (bundle.min.js, line 2)
    [Log] Create inner vis object maxcube.0.devices.thermostat_155101.battery_low (bundle.min.js, line 2)
    [Log] Create inner vis object maxcube.0.devices.thermostat_155101.link_error (bundle.min.js, line 2)
    [Log] Create inner vis object maxcube.0.devices.thermostat_155101.mode (bundle.min.js, line 2)
    [Log] Create inner vis object mqtt.0.Wohnzimmer.Temperatur (bundle.min.js, line 2)
    [Log] Create inner vis object mqtt.0.Wohnzimmer.Luftfeuchtigkeit (bundle.min.js, line 2)
    [Log] Create inner vis object javascript.0.Wohnzimmer.Luftfeuchte (bundle.min.js, line 2)
    [Log] Create inner vis object mqtt.0.Wohnzimmer.TVOC (bundle.min.js, line 2)
    [Log] Create inner vis object javascript.0.Wohnzimmer.Luftquali_Wert (bundle.min.js, line 2)
    [Log] Create inner vis object javascript.0.Wohnzimmer.Luftquali (bundle.min.js, line 2)
    [Log] Create inner vis object 0_userdata.0.Luftbewertung.Luft_Wohnzimmer (bundle.min.js, line 2)
    [Log] Create inner vis object mqtt.0.Wohnzimmer.Luftdruck (bundle.min.js, line 2)
    [Log] Create inner vis object 0_userdata.0.Charts.KlimaEsszimmer (bundle.min.js, line 2)
    [Log] Create inner vis object 0_userdata.0.Charts.KlimaKinderzimmer2 (bundle.min.js, line 2)
    [Log] Create inner vis object 0_userdata.0.Charts.KlimaKinderzimmer1 (bundle.min.js, line 2)
    [Log] Create inner vis object s7.0.DBs.DB3.Schalter_Licht_Kinderzimmer1 (bundle.min.js, line 2)
    [Log] Create inner vis object s7.0.DBs.DB6.Schalter_Licht_Esszimmer (bundle.min.js, line 2)
    [Log] Create inner vis object s7.0.DBs.DB6.Schalter_Licht_Flur_Treppe (bundle.min.js, line 2)
    [Log] Create inner vis object s7.0.DBs.DB6.Schalter_Licht_Flur_EG_2 (bundle.min.js, line 2)
    [Log] Create inner vis object s7.0.DBs.DB6.Schalter_Licht_Flur_EG (bundle.min.js, line 2)
    [Log] Create inner vis object s7.0.DBs.DB6.Schalter_Licht_Wohnzimmer (bundle.min.js, line 2)
    [Log] Create inner vis object s7.0.DBs.DB6.Steckdose_Wohnzimmer_2 (bundle.min.js, line 2)
    [Log] Create inner vis object s7.0.DBs.DB6.Steckdose_Wohnzimmer_3 (bundle.min.js, line 2)
    [Log] Create inner vis object s7.0.DBs.DB6.Sollwert_Rollladen_Wohnzimmer (bundle.min.js, line 2)
    [Log] Create inner vis object s7.0.DBs.DB6.Istwert_Rollladen_Esszimmer_Fenster (bundle.min.js, line 2)
    [Log] Create inner vis object s7.0.DBs.DB6.Sollwert_Rollladen_Esszimmer_Fenster (bundle.min.js, line 2)
    [Log] Create inner vis object s7.0.DBs.DB6.Istwert_Rollladen_Esszimmer_Tür (bundle.min.js, line 2)
    [Log] Create inner vis object s7.0.DBs.DB6.Sollwert_Rollladen_Esszimmer_Tür (bundle.min.js, line 2)
    [Log] Create inner vis object s7.0.DBs.DB3.Istwert_Rollladen_Kinderzimmer1 (bundle.min.js, line 2)
    [Log] Create inner vis object s7.0.DBs.DB3.Sollwert_Rollladen_Kinderzimmer1 (bundle.min.js, line 2)
    [Log] Create inner vis object s7.0.DBs.DB3.Istwert_Rollladen_Kinderzimmer2 (bundle.min.js, line 2)
    [Log] Create inner vis object s7.0.DBs.DB3.Sollwert_Rollladen_Kinderzimmer2 (bundle.min.js, line 2)
    [Log] Create inner vis object s7.0.DBs.DB6.Istwert_Rollladen_Wohnzimmer (bundle.min.js, line 2)
    [Log] Create inner vis object backitup.0.history.html (bundle.min.js, line 2)
    [Log] Create inner vis object s7.0.DBs.DB6.Steckdosen_Esszimmer_1 (bundle.min.js, line 2)
    [Log] Create inner vis object s7.0.DBs.DB6.Steckdosen_Esszimmer_2 (bundle.min.js, line 2)
    [Log] Create inner vis object s7.0.DBs.DB6.Steckdosen_Esszimmer_3 (bundle.min.js, line 2)
    [Log] Create inner vis object s7.0.DBs.DB6.Steckdosen_Esszimmer_4 (bundle.min.js, line 2)
    [Log] Create inner vis object s7.0.DBs.DB6.Steckdose_Wohnzimmer_1 (bundle.min.js, line 2)
    [Log] Create inner vis object s7.0.DBs.DB6.Steckdose_Wohnzimmer_4 (bundle.min.js, line 2)
    [Log] Create inner vis object s7.0.DBs.DB6.Steckdose_Wohnzimmer_5 (bundle.min.js, line 2)
    [Log] Create inner vis object s7.0.DBs.DB9.Teichpumpe_Ein (bundle.min.js, line 2)
    [Log] Create inner vis object s7.0.DBs.DB9.Temperatur_Oben (bundle.min.js, line 2)
    [Log] Create inner vis object s7.0.DBs.DB9.Temperatur_Unten (bundle.min.js, line 2)
    [Log] Create inner vis object 0_userdata.0.Charts.TempTeich (bundle.min.js, line 2)
    [Log] Create inner vis object mqtt.0.Teich.Temperatur_Oben (bundle.min.js, line 2)
    [Log] Create inner vis object mqtt.0.Teich.Temperatur_Unten (bundle.min.js, line 2)
    [Log] Create inner vis object mqtt.0.Teich.Temperatur_Filtergraben (bundle.min.js, line 2)
    [Log] Create inner vis object s7.0.DBs.DB3.Schalter_Licht_Kinderzimmer1_deaktivieren (bundle.min.js, line 2)
    [Log] Create inner vis object s7.0.DBs.DB3.Taster_Rollladen_Kinderzimmer1_deaktivieren (bundle.min.js, line 2)
    [Log] Create inner vis object s7.0.DBs.DB3.Schalter_Licht_Kinderzimmer2_deaktivieren (bundle.min.js, line 2)
    [Log] Create inner vis object s7.0.DBs.DB3.Taster_Rollladen_Kinderzimmer2_deaktivieren (bundle.min.js, line 2)
    [Log] Create inner vis object 0 (bundle.min.js, line 2)
    [Log] Create inner vis object 40 (bundle.min.js, line 2)
    [Log] Create inner vis object 20 (bundle.min.js, line 2)
    [Log] Create inner vis object mqtt.0.Gäste_WC.Temperatur (bundle.min.js, line 2)
    [Log] Create inner vis object 100 (bundle.min.js, line 2)
    [Log] Create inner vis object 50 (bundle.min.js, line 2)
    [Log] Create inner vis object mqtt.0.Gäste_WC.Luftfeuchtigkeit (bundle.min.js, line 2)
    [Log] Create inner vis object 125 (bundle.min.js, line 2)
    [Log] Create inner vis object 2000 (bundle.min.js, line 2)
    [Log] Create inner vis object 600 (bundle.min.js, line 2)
    [Log] Create inner vis object mqtt.0.Gäste_WC.TVOC (bundle.min.js, line 2)
    [Log] Create inner vis object 0_userdata.0.topappbar (bundle.min.js, line 2)
    [Debug] [1594890490471] Request 1 states. (bundle.min.js, line 2)
    [Debug] [1594890490509] Request 3 states. (bundle.min.js, line 2)
    [Debug] [1594890490553] Request 2 states. (bundle.min.js, line 2)
    [Debug] [1594890490576] Request 5 states. (bundle.min.js, line 2)
    [Debug] [1594890490604] Request 4 states. (bundle.min.js, line 2)
    [Debug] [1594890490627] Request 3 states. (bundle.min.js, line 2)
    [Debug] [1594890490652] Request 6 states. (bundle.min.js, line 2)
    [Debug] [1594890490724] Request 2 states. (bundle.min.js, line 2)
    [Log] [Line History Chart w00503] widget setting: {"_data":{"wid":"w00503","g_fixed":false,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","dataCount":"3","aggregate":"average","timeIntervalToShow":"1 month","refreshMethod":"timeInterval","refreshTimeInterval":"30 seconds","chartTimeout":"3","pointStyle":"circle","showLegend":"true","legendPosition":"bottom","legendPointStyle":"true","showTooltip":"true","tooltipTimeFormats":"{\"millisecond\":\"lll:ss\",\"second\":\"lll:ss\",\"minute\":\"lll\",\"hour\":\"lll\",\"day\":\"lll\",\"week\":\"lll\",\"month\":\"lll\",\"quarter\":\"lll\",\"year\":\"lll\"}","tooltipShowColorBox":"true","lineSpanGaps0":"true","lineSpanGaps1":"true","xAxisPosition":"bottom","xAxisBounds":"dataSet","xAxisTimeFormats":"{\"millisecond\":\"H:mm:ss.SSS\",\"second\":\"H:mm:ss\",\"minute\":\"H:mm\",\"hour\":\"H\",\"day\":\"ddd DD.\",\"week\":\"ll\",\"month\":\"MMM YYYY\",\"quarter\":\"[Q]Q - YYYY\",\"year\":\"YYYY\"}","xAxisValueDistanceToAxis":"8","xAxisShowAxis":true,"xAxisShowAxisLabels":true,"xAxisShowGridLines":true,"xAxisShowTicks":true,"xAxisMinRotation":"0","xAxisMaxRotation":"0","yAxisValueDistanceToAxis":"","showYAxis0":true,"yAxisPosition0":"left","yAxisShowGridLines0":false,"yAxisShowTicks0":false,"yAxisShowAxisBorder0":false,"showYAxis1":true,"yAxisPosition1":"left","yAxisShowGridLines1":false,"yAxisShowTicks1":false,"yAxisShowAxisBorder1":false,"showValues0":"showValuesOff","valuesPositionAnchor0":"end","valuesPositionAlign0":"top","valuesTextAlign0":"center","showValues1":"showValuesOff","valuesPositionAnchor1":"end","valuesPositionAlign1":"top","valuesTextAlign1":"center","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"historyAdapterInstance":"sql.1","lineSpanGaps2":"true","lineSpanGaps3":"true","showYAxis2":true,"yAxisPosition2":"right","yAxisShowGridLines2":"true","yAxisShowTicks2":"true","yAxisShowAxisBorder2":"true","showYAxis3":true,"yAxisPosition3":"right","yAxisShowGridLines3":false,"yAxisShowTicks3":false,"yAxisShowAxisBorder3":false,"showValues2":"showValuesOff","valuesPositionAnchor2":"end","valuesPositionAlign2":"top","valuesTextAlign2":"start","showValues3":"showValuesOff","valuesPositionAnchor3":"end","valuesPositionAlign3":"top","valuesTextAlign3":"center","maxDataPoints":"","colorScheme":"","legendFontColor":"#e7e7e7","xAxisValueLabelColor":"#e7e7e7","yAxisValueLabelColor":"#e7e7e7","yAxisTitleColor":"","yAxisValueColor0":"#e75f79","xAxisZeroLineColor":"#787878","xAxisGridLinesColor":"#e7e7e7","xAxisZeroLineWidth":"1","xAxisTickLength":"","xAxisGridLinesWitdh":"","xAxisTitleColor":"#e7e7e7","yAxisGridLinesColor0":"#e75f79","yAxisGridLinesColor1":"#dbd029","yAxisGridLinesColor2":"#35aede","yAxisGridLinesColor3":"#43df69","oid0":"mqtt.0.Wohnzimmer.Temperatur","oid1":"mqtt.0.Wohnzimmer.Luftdruck","oid2":"mqtt.0.Wohnzimmer.TVOC","legendText0":"Temperatur","legendText2":"TVOCs","legendText3":"Luftfeuchtigkeit","legendText1":"Luftdruck","globalColor":"","xAxisValueFontSize":"10","xAxisOffsetGridLines":false,"yAxisValueFontSize":"10","valuesMinDecimals2":"0","valuesMaxDecimals2":"0","valuesMinDecimals1":"0","valuesMaxDecimals1":"0","valuesMinDecimals0":"1","valuesMaxDecimals0":"1","yAxisValueMinDigits2":"0","yAxisValueMaxDigits2":"0","yAxisValueMaxDigits1":"0","yAxisValueMinDigits1":"0","yAxisValueMinDigits0":"1","yAxisValueMaxDigits0":"1","yAxisMinValue0":"","yAxisMaxValue0":"","xAxisMaxLabel":"10","time_interval_oid":"0_userdata.0.Charts.KlimaWohnzimmer","legendBoxWidth":"","pointSize":"1","pointSizeHover":"4","dataColor1":"#dbd029","dataColor2":"#35aede","dataColor0":"#e75f79","fillColor0":"","pointHoverColor0":"","fillColor1":"","pointHoverColor1":"","useFillColor1":true,"useFillColor0":true,"fillColor2":"","pointHoverColor2":"","useFillColor2":true,"oid3":"mqtt.0.Wohnzimmer.Luftfeuchtigkeit","dataColor3":"#43df69","fillColor3":"","pointHoverColor3":"","legendFontSize":"10","tooltipValueMaxDecimals":"1","tooltipValueMinDecimals":"0","valuesAppendText0":"°C","valuesAppendText1":"mbar","valuesAppendText2":"ppm","valuesAppendText3":"%","yAxisValueMinDigits3":"1","yAxisValueMaxDigits3":"1","yAxisMaxLabel3":"3","yAxisMaxLabel0":"5","yAxisZeroLineColor0":"#e7e7e7","yAxisZeroLineWidth0":"","yAxisValueColor1":"#dbd029","yAxisZeroLineColor1":"#e7e7e7","yAxisMaxLabel1":"3","yAxisValueColor2":"#35aede","yAxisValueColor3":"#43df69","yAxisMinValue2":"","yAxisMaxValue2":"","yAxisMaxLabel2":"5","yAxisZeroLineColor2":"#e7e7e7","yAxisZeroLineColor3":"#e7e7e7","lineSpanGaps4":"true","showYAxis4":"true","yAxisPosition4":"left","yAxisShowGridLines4":"true","yAxisShowTicks4":"true","yAxisShowAxisBorder4":"true","showValues4":"showValuesOn","valuesPositionAnchor4":"end","valuesPositionAlign4":"top","valuesTextAlign4":"center","chartPaddingLeft":"","steppedLine0":false,"lineTension0":"","manualRefreshTrigger":"","useFillColor3":true,"mdwDebug":true},"_cid":".map746","_computedAttrs":{},"wid":"w00503","g_fixed":false,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","dataCount":"3","aggregate":"average","timeIntervalToShow":"1 month","refreshMethod":"timeInterval","refreshTimeInterval":"30 seconds","chartTimeout":"3","pointStyle":"circle","showLegend":"true","legendPosition":"bottom","legendPointStyle":"true","showTooltip":"true","tooltipTimeFormats":"{\"millisecond\":\"lll:ss\",\"second\":\"lll:ss\",\"minute\":\"lll\",\"hour\":\"lll\",\"day\":\"lll\",\"week\":\"lll\",\"month\":\"lll\",\"quarter\":\"lll\",\"year\":\"lll\"}","tooltipShowColorBox":"true","lineSpanGaps0":"true","lineSpanGaps1":"true","xAxisPosition":"bottom","xAxisBounds":"dataSet","xAxisTimeFormats":"{\"millisecond\":\"H:mm:ss.SSS\",\"second\":\"H:mm:ss\",\"minute\":\"H:mm\",\"hour\":\"H\",\"day\":\"ddd DD.\",\"week\":\"ll\",\"month\":\"MMM YYYY\",\"quarter\":\"[Q]Q - YYYY\",\"year\":\"YYYY\"}","xAxisValueDistanceToAxis":"8","xAxisShowAxis":true,"xAxisShowAxisLabels":true,"xAxisShowGridLines":true,"xAxisShowTicks":true,"xAxisMinRotation":"0","xAxisMaxRotation":"0","yAxisValueDistanceToAxis":"","showYAxis0":true,"yAxisPosition0":"left","yAxisShowGridLines0":false,"yAxisShowTicks0":false,"yAxisShowAxisBorder0":false,"showYAxis1":true,"yAxisPosition1":"left","yAxisShowGridLines1":false,"yAxisShowTicks1":false,"yAxisShowAxisBorder1":false,"showValues0":"showValuesOff","valuesPositionAnchor0":"end","valuesPositionAlign0":"top","valuesTextAlign0":"center","showValues1":"showValuesOff","valuesPositionAnchor1":"end","valuesPositionAlign1":"top","valuesTextAlign1":"center","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"historyAdapterInstance":"sql.1","lineSpanGaps2":"true","lineSpanGaps3":"true","showYAxis2":true,"yAxisPosition2":"right","yAxisShowGridLines2":"true","yAxisShowTicks2":"true","yAxisShowAxisBorder2":"true","showYAxis3":true,"yAxisPosition3":"right","yAxisShowGridLines3":false,"yAxisShowTicks3":false,"yAxisShowAxisBorder3":false,"showValues2":"showValuesOff","valuesPositionAnchor2":"end","valuesPositionAlign2":"top","valuesTextAlign2":"start","showValues3":"showValuesOff","valuesPositionAnchor3":"end","valuesPositionAlign3":"top","valuesTextAlign3":"center","maxDataPoints":"","colorScheme":"","legendFontColor":"#e7e7e7","xAxisValueLabelColor":"#e7e7e7","yAxisValueLabelColor":"#e7e7e7","yAxisTitleColor":"","yAxisValueColor0":"#e75f79","xAxisZeroLineColor":"#787878","xAxisGridLinesColor":"#e7e7e7","xAxisZeroLineWidth":"1","xAxisTickLength":"","xAxisGridLinesWitdh":"","xAxisTitleColor":"#e7e7e7","yAxisGridLinesColor0":"#e75f79","yAxisGridLinesColor1":"#dbd029","yAxisGridLinesColor2":"#35aede","yAxisGridLinesColor3":"#43df69","oid0":"mqtt.0.Wohnzimmer.Temperatur","oid1":"mqtt.0.Wohnzimmer.Luftdruck","oid2":"mqtt.0.Wohnzimmer.TVOC","legendText0":"Temperatur","legendText2":"TVOCs","legendText3":"Luftfeuchtigkeit","legendText1":"Luftdruck","globalColor":"","xAxisValueFontSize":"10","xAxisOffsetGridLines":false,"yAxisValueFontSize":"10","valuesMinDecimals2":"0","valuesMaxDecimals2":"0","valuesMinDecimals1":"0","valuesMaxDecimals1":"0","valuesMinDecimals0":"1","valuesMaxDecimals0":"1","yAxisValueMinDigits2":"0","yAxisValueMaxDigits2":"0","yAxisValueMaxDigits1":"0","yAxisValueMinDigits1":"0","yAxisValueMinDigits0":"1","yAxisValueMaxDigits0":"1","yAxisMinValue0":"","yAxisMaxValue0":"","xAxisMaxLabel":"10","time_interval_oid":"0_userdata.0.Charts.KlimaWohnzimmer","legendBoxWidth":"","pointSize":"1","pointSizeHover":"4","dataColor1":"#dbd029","dataColor2":"#35aede","dataColor0":"#e75f79","fillColor0":"","pointHoverColor0":"","fillColor1":"","pointHoverColor1":"","useFillColor1":true,"useFillColor0":true,"fillColor2":"","pointHoverColor2":"","useFillColor2":true,"oid3":"mqtt.0.Wohnzimmer.Luftfeuchtigkeit","dataColor3":"#43df69","fillColor3":"","pointHoverColor3":"","legendFontSize":"10","tooltipValueMaxDecimals":"1","tooltipValueMinDecimals":"0","valuesAppendText0":"°C","valuesAppendText1":"mbar","valuesAppendText2":"ppm","valuesAppendText3":"%","yAxisValueMinDigits3":"1","yAxisValueMaxDigits3":"1","yAxisMaxLabel3":"3","yAxisMaxLabel0":"5","yAxisZeroLineColor0":"#e7e7e7","yAxisZeroLineWidth0":"","yAxisValueColor1":"#dbd029","yAxisZeroLineColor1":"#e7e7e7","yAxisMaxLabel1":"3","yAxisValueColor2":"#35aede","yAxisValueColor3":"#43df69","yAxisMinValue2":"","yAxisMaxValue2":"","yAxisMaxLabel2":"5","yAxisZeroLineColor2":"#e7e7e7","yAxisZeroLineColor3":"#e7e7e7","lineSpanGaps4":"true","showYAxis4":"true","yAxisPosition4":"left","yAxisShowGridLines4":"true","yAxisShowTicks4":"true","yAxisShowAxisBorder4":"true","showValues4":"showValuesOn","valuesPositionAnchor4":"end","valuesPositionAlign4":"top","valuesTextAlign4":"center","chartPaddingLeft":"","steppedLine0":false,"lineTension0":"","manualRefreshTrigger":"","useFillColor3":true,"mdwDebug":true,"_bubbleBindings":{},"__bindEvents":{"class":[{"name":"class"}],"backgroundColor":[{"name":"backgroundColor"}],"wid":[{"name":"wid"}]},"_bindings":3} (bundle.min.js, line 2)
    [Log] [getTaskForHistoryData w00503] history options for 'mqtt.0.Wohnzimmer.Temperatur': {"instance":"sql.1","count":100,"aggregate":"average","start":1594886890754,"end":1594890490754,"timeout":3000} (bundle.min.js, line 2)
    [Log] [getTaskForHistoryData w00503] history options for 'mqtt.0.Wohnzimmer.Luftdruck': {"instance":"sql.1","count":100,"aggregate":"average","start":1594886890754,"end":1594890490755,"timeout":3000} (bundle.min.js, line 2)
    [Log] [getTaskForHistoryData w00503] history options for 'mqtt.0.Wohnzimmer.TVOC': {"instance":"sql.1","count":100,"aggregate":"average","start":1594886890754,"end":1594890490755,"timeout":3000} (bundle.min.js, line 2)
    [Log] [getTaskForHistoryData w00503] history options for 'mqtt.0.Wohnzimmer.Luftfeuchtigkeit': {"instance":"sql.1","count":100,"aggregate":"average","start":1594886890754,"end":1594890490755,"timeout":3000} (bundle.min.js, line 2)
    [Log] [getTaskForHistoryData w00503] history data result 'mqtt.0.Wohnzimmer.Temperatur' length: 101 (bundle.min.js, line 2)
    [Log] [getTaskForHistoryData w00503] history data result 'mqtt.0.Wohnzimmer.Temperatur': [{"ts":1594886890754,"val":26.225},{"ts":1594886908754,"val":26.2},{"ts":1594886944754,"val":26.21},{"ts":1594886980754,"val":26.21},{"ts":1594887016754,"val":26.22},{"ts":1594887052754,"val":26.21},{"ts":1594887088754,"val":26.2},{"ts":1594887124754,"val":26.21},{"ts":1594887160754,"val":26.22},{"ts":1594887196754,"val":26.23},{"ts":1594887232754,"val":26.27},{"ts":1594887268754,"val":26.25},{"ts":1594887304754,"val":26.25},{"ts":1594887340754,"val":26.28},{"ts":1594887376754,"val":26.25},{"ts":1594887412754,"val":26.25},{"ts":1594887448754,"val":26.21},{"ts":1594887484754,"val":26.21},{"ts":1594887520754,"val":26.22},{"ts":1594887556754,"val":26.23},{"ts":1594887592754,"val":26.25},{"ts":1594887628754,"val":26.25},{"ts":1594887664754,"val":26.22},{"ts":1594887700754,"val":26.23},{"ts":1594887736754,"val":26.27},{"ts":1594887772754,"val":26.3},{"ts":1594887808754,"val":26.29},{"ts":1594887844754,"val":26.3},{"ts":1594887880754,"val":26.27},{"ts":1594887916754,"val":26.28},{"ts":1594887952754,"val":26.29},{"ts":1594887988754,"val":26.29},{"ts":1594888024754,"val":26.3},{"ts":1594888060754,"val":26.32},{"ts":1594888096754,"val":26.35},{"ts":1594888132754,"val":26.32},{"ts":1594888168754,"val":26.33},{"ts":1594888204754,"val":26.36},{"ts":1594888240754,"val":26.42},{"ts":1594888276754,"val":26.4},{"ts":1594888312754,"val":26.38},{"ts":1594888348754,"val":26.43},{"ts":1594888384754,"val":26.36},{"ts":1594888420754,"val":26.43},{"ts":1594888456754,"val":26.42},{"ts":1594888492754,"val":26.42},{"ts":1594888528754,"val":26.43},{"ts":1594888564754,"val":26.42},{"ts":1594888600754,"val":26.38},{"ts":1594888636754,"val":26.4},{"ts":1594888672754,"val":26.43},{"ts":1594888708754,"val":26.4},{"ts":1594888744754,"val":26.4},{"ts":1594888780754,"val":26.38},{"ts":1594888816754,"val":26.42},{"ts":1594888852754,"val":26.43},{"ts":1594888888754,"val":26.42},{"ts":1594888924754,"val":26.4},{"ts":1594888960754,"val":26.44},{"ts":1594888996754,"val":26.42},{"ts":1594889032754,"val":26.4},{"ts":1594889068754,"val":26.4},{"ts":1594889104754,"val":26.35},{"ts":1594889140754,"val":26.36},{"ts":1594889176754,"val":26.4},{"ts":1594889212754,"val":26.38},{"ts":1594889248754,"val":26.38},{"ts":1594889284754,"val":26.35},{"ts":1594889320754,"val":26.36},{"ts":1594889356754,"val":26.33},{"ts":1594889392754,"val":26.38},{"ts":1594889428754,"val":26.38},{"ts":1594889464754,"val":26.4},{"ts":1594889500754,"val":26.42},{"ts":1594889536754,"val":26.4},{"ts":1594889572754,"val":26.36},{"ts":1594889608754,"val":26.35},{"ts":1594889644754,"val":26.34},{"ts":1594889680754,"val":26.35},{"ts":1594889716754,"val":26.34},{"ts":1594889752754,"val":26.36},{"ts":1594889788754,"val":26.33},{"ts":1594889824754,"val":26.34},{"ts":1594889860754,"val":26.35},{"ts":1594889896754,"val":26.34},{"ts":1594889932754,"val":26.38},{"ts":1594889968754,"val":26.33},{"ts":1594890004754,"val":26.38},{"ts":1594890040754,"val":26.3},{"ts":1594890076754,"val":26.34},{"ts":1594890112754,"val":26.3},{"ts":1594890148754,"val":26.32},{"ts":1594890184754,"val":26.29},{"ts":1594890220754,"val":26.33},{"ts":1594890256754,"val":26.29},{"ts":1594890292754,"val":26.28},{"ts":1594890328754,"val":26.29},{"ts":1594890364754,"val":26.3},{"ts":1594890400754,"val":26.29},{"ts":1594890436754,"val":26.29},{"ts":1594890472754,"val":26.3}] (bundle.min.js, line 2)
    [Log] [getTaskForHistoryData w00503] history data result 'mqtt.0.Wohnzimmer.Luftdruck' length: 102 (bundle.min.js, line 2)
    [Log] [getTaskForHistoryData w00503] history data result 'mqtt.0.Wohnzimmer.Luftdruck': [{"ts":1594886890754,"val":1010.83},{"ts":1594886908754,"val":1010.83},{"ts":1594886944754,"val":1010.84},{"ts":1594886980754,"val":1010.84},{"ts":1594887016754,"val":1010.84},{"ts":1594887052754,"val":1010.86},{"ts":1594887088754,"val":1010.87},{"ts":1594887124754,"val":1010.86},{"ts":1594887160754,"val":1010.86},{"ts":1594887196754,"val":1010.88},{"ts":1594887232754,"val":1010.88},{"ts":1594887268754,"val":1010.88},{"ts":1594887304754,"val":1010.9},{"ts":1594887340754,"val":1010.9},{"ts":1594887376754,"val":1010.92},{"ts":1594887412754,"val":1010.91},{"ts":1594887448754,"val":1010.89},{"ts":1594887484754,"val":1010.92},{"ts":1594887520754,"val":1010.91},{"ts":1594887556754,"val":1010.91},{"ts":1594887592754,"val":1010.9},{"ts":1594887628754,"val":1010.89},{"ts":1594887664754,"val":1010.89},{"ts":1594887700754,"val":1010.9},{"ts":1594887736754,"val":1010.88},{"ts":1594887772754,"val":1010.9},{"ts":1594887808754,"val":1010.88},{"ts":1594887844754,"val":1010.92},{"ts":1594887880754,"val":1010.93},{"ts":1594887916754,"val":1010.94},{"ts":1594887952754,"val":1010.93},{"ts":1594887988754,"val":1010.93},{"ts":1594888024754,"val":1010.95},{"ts":1594888060754,"val":1010.93},{"ts":1594888096754,"val":1010.92},{"ts":1594888132754,"val":1010.92},{"ts":1594888168754,"val":1010.93},{"ts":1594888204754,"val":1010.95},{"ts":1594888240754,"val":1010.97},{"ts":1594888276754,"val":1010.96},{"ts":1594888312754,"val":1010.97},{"ts":1594888348754,"val":1010.97},{"ts":1594888384754,"val":1010.97},{"ts":1594888420754,"val":1010.98},{"ts":1594888456754,"val":1010.98},{"ts":1594888492754,"val":1010.98},{"ts":1594888528754,"val":1011},{"ts":1594888564754,"val":1010.99},{"ts":1594888600754,"val":1011},{"ts":1594888636754,"val":1010.99},{"ts":1594888672754,"val":1010.99},{"ts":1594888708755,"val":1010.97},{"ts":1594888744755,"val":1010.98},{"ts":1594888780755,"val":1010.99},{"ts":1594888816755,"val":1010.98},{"ts":1594888852755,"val":1010.98},{"ts":1594888888755,"val":1010.98},{"ts":1594888924755,"val":1010.98},{"ts":1594888960755,"val":1010.97},{"ts":1594888996755,"val":1010.96},{"ts":1594889032755,"val":1010.98},{"ts":1594889068755,"val":1010.97},{"ts":1594889104755,"val":1010.98},{"ts":1594889140755,"val":1010.98},{"ts":1594889176755,"val":1011},{"ts":1594889212755,"val":1010.98},{"ts":1594889248755,"val":1010.99},{"ts":1594889284755,"val":1010.98},{"ts":1594889320755,"val":1010.99},{"ts":1594889356755,"val":1010.99},{"ts":1594889392755,"val":1010.94},{"ts":1594889428755,"val":1010.96},{"ts":1594889464755,"val":1010.97},{"ts":1594889500755,"val":1010.94},{"ts":1594889536755,"val":1010.94},{"ts":1594889572755,"val":1010.93},{"ts":1594889608755,"val":1010.95},{"ts":1594889644755,"val":1010.93},{"ts":1594889680755,"val":1010.95},{"ts":1594889716755,"val":1010.94},{"ts":1594889752755,"val":1010.94},{"ts":1594889788755,"val":1010.95},{"ts":1594889824755,"val":1010.95},{"ts":1594889860755,"val":1010.97},{"ts":1594889896755,"val":1010.98},{"ts":1594889932755,"val":1010.97},{"ts":1594889968755,"val":1011},{"ts":1594890004755,"val":1010.98},{"ts":1594890040755,"val":1010.99},{"ts":1594890076755,"val":1010.98},{"ts":1594890112755,"val":1010.98},{"ts":1594890148755,"val":1010.99},{"ts":1594890184755,"val":1010.99},{"ts":1594890220755,"val":1011.01},{"ts":1594890256755,"val":1010.99},{"ts":1594890292755,"val":1010.99},{"ts":1594890328755,"val":1011},{"ts":1594890364755,"val":1010.99},{"ts":1594890400755,"val":1010.99},{"ts":1594890436755,"val":1010.99},{"ts":1594890472755,"val":1011},{"ts":1594890490755,"val":1011}] (bundle.min.js, line 2)
    [Log] [getTaskForHistoryData w00503] history data result 'mqtt.0.Wohnzimmer.TVOC' length: 101 (bundle.min.js, line 2)
    [Log] [getTaskForHistoryData w00503] history data result 'mqtt.0.Wohnzimmer.TVOC': [{"ts":1594886890754,"val":133.6},{"ts":1594886908754,"val":134.2},{"ts":1594886944754,"val":141.5},{"ts":1594886980754,"val":141.17},{"ts":1594887016754,"val":146},{"ts":1594887052754,"val":149.67},{"ts":1594887088754,"val":149.2},{"ts":1594887124754,"val":153.67},{"ts":1594887160754,"val":166.2},{"ts":1594887196754,"val":165.33},{"ts":1594887232754,"val":156.17},{"ts":1594887268754,"val":156.6},{"ts":1594887304754,"val":155.67},{"ts":1594887340754,"val":155.2},{"ts":1594887376754,"val":152.17},{"ts":1594887412754,"val":153.2},{"ts":1594887448754,"val":153.83},{"ts":1594887484754,"val":154},{"ts":1594887520754,"val":152.2},{"ts":1594887556754,"val":154.17},{"ts":1594887592754,"val":151.6},{"ts":1594887628754,"val":152.83},{"ts":1594887664754,"val":154.2},{"ts":1594887700754,"val":155.5},{"ts":1594887736754,"val":153.5},{"ts":1594887772754,"val":150.8},{"ts":1594887808754,"val":149.33},{"ts":1594887844754,"val":149.6},{"ts":1594887880754,"val":148.67},{"ts":1594887916754,"val":150.6},{"ts":1594887952754,"val":149.17},{"ts":1594887988754,"val":152.33},{"ts":1594888024754,"val":149.6},{"ts":1594888060754,"val":149.17},{"ts":1594888096754,"val":148},{"ts":1594888132754,"val":148.67},{"ts":1594888168754,"val":148.67},{"ts":1594888204754,"val":149.4},{"ts":1594888240754,"val":150.83},{"ts":1594888276754,"val":150.4},{"ts":1594888312754,"val":148.33},{"ts":1594888348754,"val":147},{"ts":1594888384754,"val":149.5},{"ts":1594888420754,"val":148},{"ts":1594888456754,"val":150.2},{"ts":1594888492754,"val":149.83},{"ts":1594888528754,"val":147.2},{"ts":1594888564754,"val":147.33},{"ts":1594888600754,"val":147.8},{"ts":1594888636754,"val":148.5},{"ts":1594888672754,"val":149},{"ts":1594888708755,"val":148.6},{"ts":1594888744755,"val":149.5},{"ts":1594888780755,"val":149},{"ts":1594888816755,"val":146.33},{"ts":1594888852755,"val":146.2},{"ts":1594888888755,"val":145.83},{"ts":1594888924755,"val":145.17},{"ts":1594888960755,"val":145},{"ts":1594888996755,"val":147.67},{"ts":1594889032755,"val":150.2},{"ts":1594889068755,"val":149.17},{"ts":1594889104755,"val":148.2},{"ts":1594889140755,"val":150.67},{"ts":1594889176755,"val":152},{"ts":1594889212755,"val":147.8},{"ts":1594889248755,"val":148},{"ts":1594889284755,"val":147.4},{"ts":1594889320755,"val":147},{"ts":1594889356755,"val":146.6},{"ts":1594889392755,"val":143.5},{"ts":1594889428755,"val":144.67},{"ts":1594889464755,"val":145.8},{"ts":1594889500755,"val":144.33},{"ts":1594889536755,"val":140.8},{"ts":1594889572755,"val":141.33},{"ts":1594889608755,"val":144},{"ts":1594889644755,"val":144.83},{"ts":1594889680755,"val":144.67},{"ts":1594889716755,"val":143},{"ts":1594889752755,"val":142.17},{"ts":1594889788755,"val":140.4},{"ts":1594889824755,"val":140.5},{"ts":1594889860755,"val":143.2},{"ts":1594889896755,"val":140},{"ts":1594889932755,"val":140.67},{"ts":1594889968755,"val":141},{"ts":1594890004755,"val":141.33},{"ts":1594890040755,"val":140.2},{"ts":1594890076755,"val":142},{"ts":1594890112755,"val":140.2},{"ts":1594890148755,"val":139.33},{"ts":1594890184755,"val":139.67},{"ts":1594890220755,"val":140.6},{"ts":1594890256755,"val":143},{"ts":1594890292755,"val":142.4},{"ts":1594890328755,"val":142},{"ts":1594890364755,"val":141.6},{"ts":1594890400755,"val":141.33},{"ts":1594890436755,"val":141},{"ts":1594890472755,"val":139.4}] (bundle.min.js, line 2)
    [Log] [getTaskForHistoryData w00503] history data result 'mqtt.0.Wohnzimmer.Luftfeuchtigkeit' length: 101 (bundle.min.js, line 2)
    [Log] [getTaskForHistoryData w00503] history data result 'mqtt.0.Wohnzimmer.Luftfeuchtigkeit': [{"ts":1594886890754,"val":40.815},{"ts":1594886908754,"val":40.87},{"ts":1594886944754,"val":41.22},{"ts":1594886980754,"val":41.26},{"ts":1594887016754,"val":41.19},{"ts":1594887052754,"val":41.18},{"ts":1594887088754,"val":41.16},{"ts":1594887124754,"val":40.98},{"ts":1594887160754,"val":40.58},{"ts":1594887196754,"val":41.03},{"ts":1594887232754,"val":40.89},{"ts":1594887268754,"val":41.2},{"ts":1594887304754,"val":41.11},{"ts":1594887340754,"val":40.9},{"ts":1594887376754,"val":40.83},{"ts":1594887412754,"val":41.05},{"ts":1594887448754,"val":41.11},{"ts":1594887484754,"val":41.15},{"ts":1594887520754,"val":41.23},{"ts":1594887556754,"val":41.33},{"ts":1594887592754,"val":41.41},{"ts":1594887628754,"val":41.49},{"ts":1594887664754,"val":41.19},{"ts":1594887700754,"val":41.28},{"ts":1594887736754,"val":41.3},{"ts":1594887772754,"val":41.27},{"ts":1594887808754,"val":41.22},{"ts":1594887844754,"val":41.19},{"ts":1594887880754,"val":41.18},{"ts":1594887916754,"val":41.11},{"ts":1594887952754,"val":41.06},{"ts":1594887988754,"val":41},{"ts":1594888024754,"val":41.05},{"ts":1594888060754,"val":41.05},{"ts":1594888096754,"val":40.98},{"ts":1594888132754,"val":40.95},{"ts":1594888168754,"val":40.96},{"ts":1594888204754,"val":40.95},{"ts":1594888240754,"val":40.93},{"ts":1594888276754,"val":40.93},{"ts":1594888312754,"val":40.93},{"ts":1594888348754,"val":40.97},{"ts":1594888384754,"val":40.95},{"ts":1594888420754,"val":40.99},{"ts":1594888456754,"val":40.92},{"ts":1594888492754,"val":40.95},{"ts":1594888528754,"val":41.01},{"ts":1594888564754,"val":40.96},{"ts":1594888600754,"val":40.95},{"ts":1594888636754,"val":40.98},{"ts":1594888672754,"val":40.93},{"ts":1594888708755,"val":40.94},{"ts":1594888744755,"val":40.97},{"ts":1594888780755,"val":40.99},{"ts":1594888816755,"val":41},{"ts":1594888852755,"val":41},{"ts":1594888888755,"val":41.04},{"ts":1594888924755,"val":41.06},{"ts":1594888960755,"val":40.96},{"ts":1594888996755,"val":40.96},{"ts":1594889032755,"val":41},{"ts":1594889068755,"val":40.95},{"ts":1594889104755,"val":40.95},{"ts":1594889140755,"val":40.83},{"ts":1594889176755,"val":40.9},{"ts":1594889212755,"val":40.94},{"ts":1594889248755,"val":40.78},{"ts":1594889284755,"val":40.78},{"ts":1594889320755,"val":40.96},{"ts":1594889356755,"val":41.01},{"ts":1594889392755,"val":41.02},{"ts":1594889428755,"val":41.03},{"ts":1594889464755,"val":41.05},{"ts":1594889500755,"val":41.07},{"ts":1594889536755,"val":41.06},{"ts":1594889572755,"val":41.03},{"ts":1594889608755,"val":41.02},{"ts":1594889644755,"val":41.06},{"ts":1594889680755,"val":41.05},{"ts":1594889716755,"val":41.05},{"ts":1594889752755,"val":41.05},{"ts":1594889788755,"val":41.1},{"ts":1594889824755,"val":41.03},{"ts":1594889860755,"val":41.09},{"ts":1594889896755,"val":41.08},{"ts":1594889932755,"val":41.08},{"ts":1594889968755,"val":41.09},{"ts":1594890004755,"val":41.08},{"ts":1594890040755,"val":40.97},{"ts":1594890076755,"val":41.05},{"ts":1594890112755,"val":41.07},{"ts":1594890148755,"val":41.06},{"ts":1594890184755,"val":41.06},{"ts":1594890220755,"val":41},{"ts":1594890256755,"val":40.95},{"ts":1594890292755,"val":40.96},{"ts":1594890328755,"val":40.91},{"ts":1594890364755,"val":40.97},{"ts":1594890400755,"val":40.93},{"ts":1594890436755,"val":40.9},{"ts":1594890472755,"val":40.88}] (bundle.min.js, line 2)
    [Log] [Line History Chart w00503] promise all datasets - count: 4 (bundle.min.js, line 2)
    [Log] [getPreparedData w00503] prepare data for 'mqtt.0.Wohnzimmer.Temperatur' length: 101 (bundle.min.js, line 2)
    [Log] [Line History Chart w00503] prepare dataset for 'mqtt.0.Wohnzimmer.Temperatur' (bundle.min.js, line 2)
    [Log] [Line History Chart w00503] prepare yAxis for 'mqtt.0.Wohnzimmer.Temperatur' (bundle.min.js, line 2)
    [Log] [getPreparedData w00503] prepare data for 'mqtt.0.Wohnzimmer.Luftdruck' length: 102 (bundle.min.js, line 2)
    [Log] [Line History Chart w00503] prepare dataset for 'mqtt.0.Wohnzimmer.Luftdruck' (bundle.min.js, line 2)
    [Log] [Line History Chart w00503] prepare yAxis for 'mqtt.0.Wohnzimmer.Luftdruck' (bundle.min.js, line 2)
    [Log] [getPreparedData w00503] prepare data for 'mqtt.0.Wohnzimmer.TVOC' length: 101 (bundle.min.js, line 2)
    [Log] [Line History Chart w00503] prepare dataset for 'mqtt.0.Wohnzimmer.TVOC' (bundle.min.js, line 2)
    [Log] [Line History Chart w00503] prepare yAxis for 'mqtt.0.Wohnzimmer.TVOC' (bundle.min.js, line 2)
    [Log] [getPreparedData w00503] prepare data for 'mqtt.0.Wohnzimmer.Luftfeuchtigkeit' length: 101 (bundle.min.js, line 2)
    [Log] [Line History Chart w00503] prepare dataset for 'mqtt.0.Wohnzimmer.Luftfeuchtigkeit' (bundle.min.js, line 2)
    [Log] [Line History Chart w00503] prepare yAxis for 'mqtt.0.Wohnzimmer.Luftfeuchtigkeit' (bundle.min.js, line 2)
    [Log] [Line History Chart - w00503] prepare chart options (bundle.min.js, line 2)
    [Log] [Line History Chart w00503] chart creating... (bundle.min.js, line 2)
    [Log] [Line History Chart w00503] chart successful created (bundle.min.js, line 2)
    [Log] [Line History Chart w00503] ************************************************************** onChange - TimeInterval by Editor ************************************************************** (bundle.min.js, line 2)
    [Log] [getTaskForHistoryData w00503] history options for 'mqtt.0.Wohnzimmer.Temperatur': {"instance":"sql.1","count":100,"aggregate":"average","start":1594886920755,"end":1594890520755,"timeout":3000} (bundle.min.js, line 2)
    [Log] [getTaskForHistoryData w00503] history options for 'mqtt.0.Wohnzimmer.Luftdruck': {"instance":"sql.1","count":100,"aggregate":"average","start":1594886920755,"end":1594890520755,"timeout":3000} (bundle.min.js, line 2)
    [Log] [getTaskForHistoryData w00503] history options for 'mqtt.0.Wohnzimmer.TVOC': {"instance":"sql.1","count":100,"aggregate":"average","start":1594886920755,"end":1594890520755,"timeout":3000} (bundle.min.js, line 2)
    [Log] [getTaskForHistoryData w00503] history options for 'mqtt.0.Wohnzimmer.Luftfeuchtigkeit': {"instance":"sql.1","count":100,"aggregate":"average","start":1594886920755,"end":1594890520755,"timeout":3000} (bundle.min.js, line 2)
    [Log] [getTaskForHistoryData w00503] history data result 'mqtt.0.Wohnzimmer.Temperatur': [{"ts":1594886920755,"val":26.23},{"ts":1594886938755,"val":26.21},{"ts":1594886974755,"val":26.21},{"ts":1594887010755,"val":26.2},{"ts":1594887046755,"val":26.21},{"ts":1594887082755,"val":26.2},{"ts":1594887118755,"val":26.21},{"ts":1594887154755,"val":26.25},{"ts":1594887190755,"val":26.23},{"ts":1594887226755,"val":26.25},{"ts":1594887262755,"val":26.25},{"ts":1594887298755,"val":26.25},{"ts":1594887334755,"val":26.28},{"ts":1594887370755,"val":26.25},{"ts":1594887406755,"val":26.28},{"ts":1594887442755,"val":26.21},{"ts":1594887478755,"val":26.21},{"ts":1594887514755,"val":26.2},{"ts":1594887550755,"val":26.23},{"ts":1594887586755,"val":26.22},{"ts":1594887622755,"val":26.27},{"ts":1594887658755,"val":26.25},{"ts":1594887694755,"val":26.23},{"ts":1594887730755,"val":26.25},{"ts":1594887766755,"val":26.3},{"ts":1594887802755,"val":26.29},{"ts":1594887838755,"val":26.28},{"ts":1594887874755,"val":26.27},{"ts":1594887910755,"val":26.3},{"ts":1594887946755,"val":26.29},{"ts":1594887982755,"val":26.29},{"ts":1594888018755,"val":26.3},{"ts":1594888054755,"val":26.32},{"ts":1594888090755,"val":26.33},{"ts":1594888126755,"val":26.32},{"ts":1594888162755,"val":26.33},{"ts":1594888198755,"val":26.36},{"ts":1594888234755,"val":26.4},{"ts":1594888270755,"val":26.43},{"ts":1594888306755,"val":26.38},{"ts":1594888342755,"val":26.43},{"ts":1594888378755,"val":26.36},{"ts":1594888414755,"val":26.42},{"ts":1594888450755,"val":26.4},{"ts":1594888486755,"val":26.42},{"ts":1594888522755,"val":26.43},{"ts":1594888558755,"val":26.42},{"ts":1594888594755,"val":26.4},{"ts":1594888630755,"val":26.4},{"ts":1594888666755,"val":26.42},{"ts":1594888702755,"val":26.4},{"ts":1594888738755,"val":26.4},{"ts":1594888774755,"val":26.38},{"ts":1594888810755,"val":26.42},{"ts":1594888846755,"val":26.4},{"ts":1594888882755,"val":26.42},{"ts":1594888918755,"val":26.42},{"ts":1594888954755,"val":26.43},{"ts":1594888990755,"val":26.42},{"ts":1594889026755,"val":26.43},{"ts":1594889062755,"val":26.4},{"ts":1594889098755,"val":26.38},{"ts":1594889134755,"val":26.36},{"ts":1594889170755,"val":26.38},{"ts":1594889206755,"val":26.38},{"ts":1594889242755,"val":26.38},{"ts":1594889278755,"val":26.35},{"ts":1594889314755,"val":26.36},{"ts":1594889350755,"val":26.33},{"ts":1594889386755,"val":26.38},{"ts":1594889422755,"val":26.38},{"ts":1594889458755,"val":26.4},{"ts":1594889494755,"val":26.42},{"ts":1594889530755,"val":26.4},{"ts":1594889566755,"val":26.36},{"ts":1594889602755,"val":26.35},{"ts":1594889638755,"val":26.34},{"ts":1594889674755,"val":26.36},{"ts":1594889710755,"val":26.33},{"ts":1594889746755,"val":26.36},{"ts":1594889782755,"val":26.35},{"ts":1594889818755,"val":26.34},{"ts":1594889854755,"val":26.33},{"ts":1594889890755,"val":26.34},{"ts":1594889926755,"val":26.38},{"ts":1594889962755,"val":26.33},{"ts":1594889998755,"val":26.38},{"ts":1594890034755,"val":26.33},{"ts":1594890070755,"val":26.34},{"ts":1594890106755,"val":26.3},{"ts":1594890142755,"val":26.32},{"ts":1594890178755,"val":26.29},{"ts":1594890214755,"val":26.3},{"ts":1594890250755,"val":26.29},{"ts":1594890286755,"val":26.3},{"ts":1594890322755,"val":26.29},{"ts":1594890358755,"val":26.3},{"ts":1594890394755,"val":26.29},{"ts":1594890430755,"val":26.29},{"ts":1594890466755,"val":26.28},{"ts":1594890502755,"val":26.32}] (bundle.min.js, line 2)
    [Log] [getTaskForHistoryData w00503] history data result 'mqtt.0.Wohnzimmer.Luftdruck' length: 101 (bundle.min.js, line 2)
    [Log] [getTaskForHistoryData w00503] history data result 'mqtt.0.Wohnzimmer.Luftdruck': [{"ts":1594886920755,"val":1010.83},{"ts":1594886938755,"val":1010.83},{"ts":1594886974755,"val":1010.84},{"ts":1594887010755,"val":1010.84},{"ts":1594887046755,"val":1010.87},{"ts":1594887082755,"val":1010.87},{"ts":1594887118755,"val":1010.86},{"ts":1594887154755,"val":1010.85},{"ts":1594887190755,"val":1010.88},{"ts":1594887226755,"val":1010.88},{"ts":1594887262755,"val":1010.89},{"ts":1594887298755,"val":1010.9},{"ts":1594887334755,"val":1010.9},{"ts":1594887370755,"val":1010.91},{"ts":1594887406755,"val":1010.91},{"ts":1594887442755,"val":1010.89},{"ts":1594887478755,"val":1010.92},{"ts":1594887514755,"val":1010.91},{"ts":1594887550755,"val":1010.92},{"ts":1594887586755,"val":1010.9},{"ts":1594887622755,"val":1010.89},{"ts":1594887658755,"val":1010.9},{"ts":1594887694755,"val":1010.9},{"ts":1594887730755,"val":1010.88},{"ts":1594887766755,"val":1010.89},{"ts":1594887802755,"val":1010.89},{"ts":1594887838755,"val":1010.92},{"ts":1594887874755,"val":1010.93},{"ts":1594887910755,"val":1010.94},{"ts":1594887946755,"val":1010.93},{"ts":1594887982755,"val":1010.93},{"ts":1594888018755,"val":1010.94},{"ts":1594888054755,"val":1010.93},{"ts":1594888090755,"val":1010.92},{"ts":1594888126755,"val":1010.92},{"ts":1594888162755,"val":1010.93},{"ts":1594888198755,"val":1010.95},{"ts":1594888234755,"val":1010.97},{"ts":1594888270755,"val":1010.96},{"ts":1594888306755,"val":1010.97},{"ts":1594888342755,"val":1010.98},{"ts":1594888378755,"val":1010.96},{"ts":1594888414755,"val":1010.98},{"ts":1594888450755,"val":1010.99},{"ts":1594888486755,"val":1010.97},{"ts":1594888522755,"val":1010.99},{"ts":1594888558755,"val":1011},{"ts":1594888594755,"val":1011},{"ts":1594888630755,"val":1010.99},{"ts":1594888666755,"val":1010.99},{"ts":1594888702755,"val":1010.97},{"ts":1594888738755,"val":1010.98},{"ts":1594888774755,"val":1010.99},{"ts":1594888810755,"val":1010.99},{"ts":1594888846755,"val":1010.97},{"ts":1594888882755,"val":1010.98},{"ts":1594888918755,"val":1010.98},{"ts":1594888954755,"val":1010.97},{"ts":1594888990755,"val":1010.97},{"ts":1594889026755,"val":1010.97},{"ts":1594889062755,"val":1010.97},{"ts":1594889098755,"val":1010.98},{"ts":1594889134755,"val":1010.98},{"ts":1594889170755,"val":1010.99},{"ts":1594889206755,"val":1010.98},{"ts":1594889242755,"val":1010.99},{"ts":1594889278755,"val":1010.98},{"ts":1594889314755,"val":1010.99},{"ts":1594889350755,"val":1010.99},{"ts":1594889386755,"val":1010.94},{"ts":1594889422755,"val":1010.95},{"ts":1594889458755,"val":1010.97},{"ts":1594889494755,"val":1010.94},{"ts":1594889530755,"val":1010.94},{"ts":1594889566755,"val":1010.93},{"ts":1594889602755,"val":1010.95},{"ts":1594889638755,"val":1010.93},{"ts":1594889674755,"val":1010.95},{"ts":1594889710755,"val":1010.94},{"ts":1594889746755,"val":1010.94},{"ts":1594889782755,"val":1010.95},{"ts":1594889818755,"val":1010.94},{"ts":1594889854755,"val":1010.97},{"ts":1594889890755,"val":1010.98},{"ts":1594889926755,"val":1010.97},{"ts":1594889962755,"val":1011},{"ts":1594889998755,"val":1010.98},{"ts":1594890034755,"val":1010.99},{"ts":1594890070755,"val":1010.98},{"ts":1594890106755,"val":1010.98},{"ts":1594890142755,"val":1010.98},{"ts":1594890178755,"val":1010.99},{"ts":1594890214755,"val":1011.01},{"ts":1594890250755,"val":1010.99},{"ts":1594890286755,"val":1010.98},{"ts":1594890322755,"val":1011},{"ts":1594890358755,"val":1010.99},{"ts":1594890394755,"val":1010.99},{"ts":1594890430755,"val":1010.99},{"ts":1594890466755,"val":1011},{"ts":1594890502755,"val":1010.99}] (bundle.min.js, line 2)
    [Log] [getTaskForHistoryData w00503] history data result 'mqtt.0.Wohnzimmer.TVOC': [{"ts":1594886920755,"val":138.6},{"ts":1594886938755,"val":141.2},{"ts":1594886974755,"val":141.83},{"ts":1594887010755,"val":143.8},{"ts":1594887046755,"val":150},{"ts":1594887082755,"val":149},{"ts":1594887118755,"val":152},{"ts":1594887154755,"val":165},{"ts":1594887190755,"val":166},{"ts":1594887226755,"val":157},{"ts":1594887262755,"val":157.2},{"ts":1594887298755,"val":155.17},{"ts":1594887334755,"val":155.6},{"ts":1594887370755,"val":152.5},{"ts":1594887406755,"val":153.17},{"ts":1594887442755,"val":153.6},{"ts":1594887478755,"val":154.5},{"ts":1594887514755,"val":152},{"ts":1594887550755,"val":154.17},{"ts":1594887586755,"val":151.6},{"ts":1594887622755,"val":152.67},{"ts":1594887658755,"val":154.17},{"ts":1594887694755,"val":155.6},{"ts":1594887730755,"val":154.33},{"ts":1594887766755,"val":151},{"ts":1594887802755,"val":149.5},{"ts":1594887838755,"val":149.4},{"ts":1594887874755,"val":148.33},{"ts":1594887910755,"val":150.67},{"ts":1594887946755,"val":148.8},{"ts":1594887982755,"val":152.33},{"ts":1594888018755,"val":150},{"ts":1594888054755,"val":149.67},{"ts":1594888090755,"val":147.2},{"ts":1594888126755,"val":148.83},{"ts":1594888162755,"val":148.67},{"ts":1594888198755,"val":149},{"ts":1594888234755,"val":151.17},{"ts":1594888270755,"val":149.8},{"ts":1594888306755,"val":149.5},{"ts":1594888342755,"val":146.4},{"ts":1594888378755,"val":149.17},{"ts":1594888414755,"val":148.5},{"ts":1594888450755,"val":149.2},{"ts":1594888486755,"val":150.17},{"ts":1594888522755,"val":147.8},{"ts":1594888558755,"val":147.33},{"ts":1594888594755,"val":147.4},{"ts":1594888630755,"val":148.67},{"ts":1594888666755,"val":148.5},{"ts":1594888702755,"val":149},{"ts":1594888738755,"val":149},{"ts":1594888774755,"val":150.2},{"ts":1594888810755,"val":146},{"ts":1594888846755,"val":147},{"ts":1594888882755,"val":145.5},{"ts":1594888918755,"val":145.33},{"ts":1594888954755,"val":144.8},{"ts":1594888990755,"val":146.83},{"ts":1594889026755,"val":150.6},{"ts":1594889062755,"val":149.33},{"ts":1594889098755,"val":148},{"ts":1594889134755,"val":149.83},{"ts":1594889170755,"val":152.5},{"ts":1594889206755,"val":148.6},{"ts":1594889242755,"val":148},{"ts":1594889278755,"val":147.2},{"ts":1594889314755,"val":147.17},{"ts":1594889350755,"val":146.8},{"ts":1594889386755,"val":143.83},{"ts":1594889422755,"val":144.33},{"ts":1594889458755,"val":146},{"ts":1594889494755,"val":144.67},{"ts":1594889530755,"val":141.4},{"ts":1594889566755,"val":140.67},{"ts":1594889602755,"val":144},{"ts":1594889638755,"val":144.33},{"ts":1594889674755,"val":145.17},{"ts":1594889710755,"val":143.2},{"ts":1594889746755,"val":142.33},{"ts":1594889782755,"val":141},{"ts":1594889818755,"val":139.83},{"ts":1594889854755,"val":143.17},{"ts":1594889890755,"val":140},{"ts":1594889926755,"val":140.67},{"ts":1594889962755,"val":140.6},{"ts":1594889998755,"val":141.5},{"ts":1594890034755,"val":139.8},{"ts":1594890070755,"val":142.17},{"ts":1594890106755,"val":140.5},{"ts":1594890142755,"val":139},{"ts":1594890178755,"val":139.67},{"ts":1594890214755,"val":140.6},{"ts":1594890250755,"val":142.5},{"ts":1594890286755,"val":143},{"ts":1594890322755,"val":141.83},{"ts":1594890358755,"val":141.67},{"ts":1594890394755,"val":141.2},{"ts":1594890430755,"val":141.33},{"ts":1594890466755,"val":140},{"ts":1594890502755,"val":140.5}] (bundle.min.js, line 2)
    [Log] [getTaskForHistoryData w00503] history data result 'mqtt.0.Wohnzimmer.Luftfeuchtigkeit': [{"ts":1594886920755,"val":41.075},{"ts":1594886938755,"val":41.19},{"ts":1594886974755,"val":41.28},{"ts":1594887010755,"val":41.18},{"ts":1594887046755,"val":41.22},{"ts":1594887082755,"val":41.14},{"ts":1594887118755,"val":41.11},{"ts":1594887154755,"val":40.51},{"ts":1594887190755,"val":41.07},{"ts":1594887226755,"val":40.83},{"ts":1594887262755,"val":41.16},{"ts":1594887298755,"val":41.22},{"ts":1594887334755,"val":40.89},{"ts":1594887370755,"val":40.81},{"ts":1594887406755,"val":41.04},{"ts":1594887442755,"val":41.1},{"ts":1594887478755,"val":41.17},{"ts":1594887514755,"val":41.18},{"ts":1594887550755,"val":41.38},{"ts":1594887586755,"val":41.32},{"ts":1594887622755,"val":41.57},{"ts":1594887658755,"val":41.18},{"ts":1594887694755,"val":41.27},{"ts":1594887730755,"val":41.3},{"ts":1594887766755,"val":41.28},{"ts":1594887802755,"val":41.24},{"ts":1594887838755,"val":41.19},{"ts":1594887874755,"val":41.19},{"ts":1594887910755,"val":41.12},{"ts":1594887946755,"val":41.07},{"ts":1594887982755,"val":40.99},{"ts":1594888018755,"val":41.04},{"ts":1594888054755,"val":41.06},{"ts":1594888090755,"val":40.99},{"ts":1594888126755,"val":40.95},{"ts":1594888162755,"val":40.96},{"ts":1594888198755,"val":40.95},{"ts":1594888234755,"val":40.92},{"ts":1594888270755,"val":40.92},{"ts":1594888306755,"val":40.93},{"ts":1594888342755,"val":40.97},{"ts":1594888378755,"val":40.96},{"ts":1594888414755,"val":40.98},{"ts":1594888450755,"val":40.93},{"ts":1594888486755,"val":40.95},{"ts":1594888522755,"val":41},{"ts":1594888558755,"val":40.97},{"ts":1594888594755,"val":40.96},{"ts":1594888630755,"val":40.97},{"ts":1594888666755,"val":40.94},{"ts":1594888702755,"val":40.94},{"ts":1594888738755,"val":40.97},{"ts":1594888774755,"val":40.99},{"ts":1594888810755,"val":41},{"ts":1594888846755,"val":40.99},{"ts":1594888882755,"val":41.03},{"ts":1594888918755,"val":41.06},{"ts":1594888954755,"val":40.98},{"ts":1594888990755,"val":40.96},{"ts":1594889026755,"val":40.99},{"ts":1594889062755,"val":40.96},{"ts":1594889098755,"val":40.96},{"ts":1594889134755,"val":40.84},{"ts":1594889170755,"val":40.88},{"ts":1594889206755,"val":40.94},{"ts":1594889242755,"val":40.9},{"ts":1594889278755,"val":40.69},{"ts":1594889314755,"val":40.93},{"ts":1594889350755,"val":41.01},{"ts":1594889386755,"val":41.01},{"ts":1594889422755,"val":41.03},{"ts":1594889458755,"val":41.05},{"ts":1594889494755,"val":41.05},{"ts":1594889530755,"val":41.07},{"ts":1594889566755,"val":41.05},{"ts":1594889602755,"val":41.01},{"ts":1594889638755,"val":41.06},{"ts":1594889674755,"val":41.05},{"ts":1594889710755,"val":41.05},{"ts":1594889746755,"val":41.04},{"ts":1594889782755,"val":41.09},{"ts":1594889818755,"val":41.04},{"ts":1594889854755,"val":41.09},{"ts":1594889890755,"val":41.08},{"ts":1594889926755,"val":41.08},{"ts":1594889962755,"val":41.08},{"ts":1594889998755,"val":41.09},{"ts":1594890034755,"val":40.98},{"ts":1594890070755,"val":41.04},{"ts":1594890106755,"val":41.07},{"ts":1594890142755,"val":41.06},{"ts":1594890178755,"val":41.06},{"ts":1594890214755,"val":41.03},{"ts":1594890250755,"val":40.93},{"ts":1594890286755,"val":40.97},{"ts":1594890322755,"val":40.9},{"ts":1594890358755,"val":40.96},{"ts":1594890394755,"val":40.93},{"ts":1594890430755,"val":40.89},{"ts":1594890466755,"val":40.9},{"ts":1594890502755,"val":40.82}] (bundle.min.js, line 2)
    [Log] [getPreparedData w00503] prepare data for 'mqtt.0.Wohnzimmer.Luftdruck' length: 101 (bundle.min.js, line 2)
    [Log] [Line History Chart w00503] chart updating... (bundle.min.js, line 2)
    [Log] [Line History Chart w00503] chart successful updated (bundle.min.js, line 2)
    [Log] [getTaskForHistoryData w00503] history options for 'mqtt.0.Wohnzimmer.Temperatur': {"instance":"sql.1","count":100,"aggregate":"average","start":1594886950755,"end":1594890550755,"timeout":3000} (bundle.min.js, line 2)
    [Log] [getTaskForHistoryData w00503] history options for 'mqtt.0.Wohnzimmer.Luftdruck': {"instance":"sql.1","count":100,"aggregate":"average","start":1594886950755,"end":1594890550755,"timeout":3000} (bundle.min.js, line 2)
    [Log] [getTaskForHistoryData w00503] history options for 'mqtt.0.Wohnzimmer.TVOC': {"instance":"sql.1","count":100,"aggregate":"average","start":1594886950755,"end":1594890550755,"timeout":3000} (bundle.min.js, line 2)
    [Log] [getTaskForHistoryData w00503] history options for 'mqtt.0.Wohnzimmer.Luftfeuchtigkeit': {"instance":"sql.1","count":100,"aggregate":"average","start":1594886950755,"end":1594890550756,"timeout":3000} (bundle.min.js, line 2)
    [Log] [getTaskForHistoryData w00503] history data result 'mqtt.0.Wohnzimmer.Temperatur': [{"ts":1594886950755,"val":26.23},{"ts":1594886968755,"val":26.21},{"ts":1594887004755,"val":26.2},{"ts":1594887040755,"val":26.21},{"ts":1594887076755,"val":26.22},{"ts":1594887112755,"val":26.21},{"ts":1594887148755,"val":26.23},{"ts":1594887184755,"val":26.2},{"ts":1594887220755,"val":26.27},{"ts":1594887256755,"val":26.25},{"ts":1594887292755,"val":26.25},{"ts":1594887328755,"val":26.28},{"ts":1594887364755,"val":26.25},{"ts":1594887400755,"val":26.27},{"ts":1594887436755,"val":26.2},{"ts":1594887472755,"val":26.21},{"ts":1594887508755,"val":26.2},{"ts":1594887544755,"val":26.23},{"ts":1594887580755,"val":26.25},{"ts":1594887616755,"val":26.25},{"ts":1594887652755,"val":26.25},{"ts":1594887688755,"val":26.22},{"ts":1594887724755,"val":26.25},{"ts":1594887760755,"val":26.3},{"ts":1594887796755,"val":26.27},{"ts":1594887832755,"val":26.3},{"ts":1594887868755,"val":26.27},{"ts":1594887904755,"val":26.29},{"ts":1594887940755,"val":26.3},{"ts":1594887976755,"val":26.29},{"ts":1594888012755,"val":26.28},{"ts":1594888048755,"val":26.32},{"ts":1594888084755,"val":26.33},{"ts":1594888120755,"val":26.32},{"ts":1594888156755,"val":26.34},{"ts":1594888192755,"val":26.35},{"ts":1594888228755,"val":26.4},{"ts":1594888264755,"val":26.43},{"ts":1594888300755,"val":26.38},{"ts":1594888336755,"val":26.4},{"ts":1594888372755,"val":26.38},{"ts":1594888408755,"val":26.4},{"ts":1594888444755,"val":26.43},{"ts":1594888480755,"val":26.42},{"ts":1594888516755,"val":26.43},{"ts":1594888552755,"val":26.42},{"ts":1594888588755,"val":26.4},{"ts":1594888624755,"val":26.4},{"ts":1594888660755,"val":26.42},{"ts":1594888696755,"val":26.4},{"ts":1594888732755,"val":26.4},{"ts":1594888768755,"val":26.35},{"ts":1594888804755,"val":26.42},{"ts":1594888840755,"val":26.43},{"ts":1594888876755,"val":26.42},{"ts":1594888912755,"val":26.42},{"ts":1594888948755,"val":26.43},{"ts":1594888984755,"val":26.42},{"ts":1594889020755,"val":26.43},{"ts":1594889056755,"val":26.4},{"ts":1594889092755,"val":26.38},{"ts":1594889128755,"val":26.36},{"ts":1594889164755,"val":26.38},{"ts":1594889200755,"val":26.38},{"ts":1594889236755,"val":26.38},{"ts":1594889272755,"val":26.35},{"ts":1594889308755,"val":26.36},{"ts":1594889344755,"val":26.35},{"ts":1594889380755,"val":26.36},{"ts":1594889416755,"val":26.38},{"ts":1594889452755,"val":26.4},{"ts":1594889488755,"val":26.42},{"ts":1594889524755,"val":26.38},{"ts":1594889560755,"val":26.38},{"ts":1594889596755,"val":26.35},{"ts":1594889632755,"val":26.34},{"ts":1594889668755,"val":26.36},{"ts":1594889704755,"val":26.35},{"ts":1594889740755,"val":26.36},{"ts":1594889776755,"val":26.33},{"ts":1594889812755,"val":26.34},{"ts":1594889848755,"val":26.34},{"ts":1594889884755,"val":26.33},{"ts":1594889920755,"val":26.38},{"ts":1594889956755,"val":26.35},{"ts":1594889992755,"val":26.36},{"ts":1594890028755,"val":26.35},{"ts":1594890064755,"val":26.32},{"ts":1594890100755,"val":26.32},{"ts":1594890136755,"val":26.3},{"ts":1594890172755,"val":26.29},{"ts":1594890208755,"val":26.33},{"ts":1594890244755,"val":26.29},{"ts":1594890280755,"val":26.3},{"ts":1594890316755,"val":26.29},{"ts":1594890352755,"val":26.29},{"ts":1594890388755,"val":26.28},{"ts":1594890424755,"val":26.29},{"ts":1594890460755,"val":26.3},{"ts":1594890496755,"val":26.32},{"ts":1594890532755,"val":26.28}] (bundle.min.js, line 2)
    [Log] [getTaskForHistoryData w00503] history data result 'mqtt.0.Wohnzimmer.Luftdruck': [{"ts":1594886950755,"val":1010.84},{"ts":1594886968755,"val":1010.84},{"ts":1594887004755,"val":1010.84},{"ts":1594887040755,"val":1010.86},{"ts":1594887076755,"val":1010.87},{"ts":1594887112755,"val":1010.86},{"ts":1594887148755,"val":1010.85},{"ts":1594887184755,"val":1010.87},{"ts":1594887220755,"val":1010.88},{"ts":1594887256755,"val":1010.89},{"ts":1594887292755,"val":1010.9},{"ts":1594887328755,"val":1010.9},{"ts":1594887364755,"val":1010.91},{"ts":1594887400755,"val":1010.91},{"ts":1594887436755,"val":1010.9},{"ts":1594887472755,"val":1010.91},{"ts":1594887508755,"val":1010.91},{"ts":1594887544755,"val":1010.92},{"ts":1594887580755,"val":1010.9},{"ts":1594887616755,"val":1010.89},{"ts":1594887652755,"val":1010.9},{"ts":1594887688755,"val":1010.9},{"ts":1594887724755,"val":1010.88},{"ts":1594887760755,"val":1010.89},{"ts":1594887796755,"val":1010.9},{"ts":1594887832755,"val":1010.91},{"ts":1594887868755,"val":1010.93},{"ts":1594887904755,"val":1010.94},{"ts":1594887940755,"val":1010.94},{"ts":1594887976755,"val":1010.93},{"ts":1594888012755,"val":1010.94},{"ts":1594888048755,"val":1010.93},{"ts":1594888084755,"val":1010.93},{"ts":1594888120755,"val":1010.92},{"ts":1594888156755,"val":1010.93},{"ts":1594888192755,"val":1010.94},{"ts":1594888228755,"val":1010.96},{"ts":1594888264755,"val":1010.97},{"ts":1594888300755,"val":1010.97},{"ts":1594888336755,"val":1010.97},{"ts":1594888372755,"val":1010.96},{"ts":1594888408755,"val":1010.99},{"ts":1594888444755,"val":1010.98},{"ts":1594888480755,"val":1010.98},{"ts":1594888516755,"val":1010.99},{"ts":1594888552755,"val":1010.99},{"ts":1594888588755,"val":1011},{"ts":1594888624755,"val":1010.99},{"ts":1594888660755,"val":1010.99},{"ts":1594888696755,"val":1010.98},{"ts":1594888732755,"val":1010.98},{"ts":1594888768755,"val":1010.99},{"ts":1594888804755,"val":1010.99},{"ts":1594888840755,"val":1010.97},{"ts":1594888876755,"val":1010.99},{"ts":1594888912755,"val":1010.98},{"ts":1594888948755,"val":1010.97},{"ts":1594888984755,"val":1010.97},{"ts":1594889020755,"val":1010.96},{"ts":1594889056755,"val":1010.97},{"ts":1594889092755,"val":1010.98},{"ts":1594889128755,"val":1010.98},{"ts":1594889164755,"val":1010.99},{"ts":1594889200755,"val":1010.99},{"ts":1594889236755,"val":1010.98},{"ts":1594889272755,"val":1010.99},{"ts":1594889308755,"val":1010.98},{"ts":1594889344755,"val":1010.99},{"ts":1594889380755,"val":1010.95},{"ts":1594889416755,"val":1010.95},{"ts":1594889452755,"val":1010.97},{"ts":1594889488755,"val":1010.95},{"ts":1594889524755,"val":1010.94},{"ts":1594889560755,"val":1010.94},{"ts":1594889596755,"val":1010.94},{"ts":1594889632755,"val":1010.93},{"ts":1594889668755,"val":1010.94},{"ts":1594889704755,"val":1010.94},{"ts":1594889740755,"val":1010.94},{"ts":1594889776755,"val":1010.95},{"ts":1594889812755,"val":1010.94},{"ts":1594889848755,"val":1010.96},{"ts":1594889884755,"val":1010.98},{"ts":1594889920755,"val":1010.98},{"ts":1594889956755,"val":1010.99},{"ts":1594889992755,"val":1010.98},{"ts":1594890028755,"val":1010.99},{"ts":1594890064755,"val":1010.98},{"ts":1594890100755,"val":1010.98},{"ts":1594890136755,"val":1010.98},{"ts":1594890172755,"val":1010.99},{"ts":1594890208755,"val":1011.01},{"ts":1594890244755,"val":1011},{"ts":1594890280755,"val":1010.98},{"ts":1594890316755,"val":1011},{"ts":1594890352755,"val":1011},{"ts":1594890388755,"val":1010.98},{"ts":1594890424755,"val":1010.99},{"ts":1594890460755,"val":1011},{"ts":1594890496755,"val":1010.99},{"ts":1594890532755,"val":1011.01}] (bundle.min.js, line 2)
    [Log] [getTaskForHistoryData w00503] history data result 'mqtt.0.Wohnzimmer.TVOC': [{"ts":1594886950755,"val":142.66500000000002},{"ts":1594886968755,"val":142.33},{"ts":1594887004755,"val":142.4},{"ts":1594887040755,"val":149.83},{"ts":1594887076755,"val":148.8},{"ts":1594887112755,"val":151},{"ts":1594887148755,"val":163},{"ts":1594887184755,"val":167},{"ts":1594887220755,"val":158.33},{"ts":1594887256755,"val":156.8},{"ts":1594887292755,"val":155.5},{"ts":1594887328755,"val":155.6},{"ts":1594887364755,"val":152.83},{"ts":1594887400755,"val":153},{"ts":1594887436755,"val":153.4},{"ts":1594887472755,"val":155},{"ts":1594887508755,"val":151.8},{"ts":1594887544755,"val":154},{"ts":1594887580755,"val":152.2},{"ts":1594887616755,"val":152.33},{"ts":1594887652755,"val":153.83},{"ts":1594887688755,"val":155.2},{"ts":1594887724755,"val":155.33},{"ts":1594887760755,"val":151.2},{"ts":1594887796755,"val":149.83},{"ts":1594887832755,"val":149.4},{"ts":1594887868755,"val":148},{"ts":1594887904755,"val":150.67},{"ts":1594887940755,"val":148.8},{"ts":1594887976755,"val":152},{"ts":1594888012755,"val":150.6},{"ts":1594888048755,"val":149.67},{"ts":1594888084755,"val":147.4},{"ts":1594888120755,"val":149},{"ts":1594888156755,"val":148.67},{"ts":1594888192755,"val":148.4},{"ts":1594888228755,"val":151},{"ts":1594888264755,"val":149.8},{"ts":1594888300755,"val":150.17},{"ts":1594888336755,"val":146.5},{"ts":1594888372755,"val":149},{"ts":1594888408755,"val":149},{"ts":1594888444755,"val":148.4},{"ts":1594888480755,"val":150.67},{"ts":1594888516755,"val":148.4},{"ts":1594888552755,"val":146.67},{"ts":1594888588755,"val":147.67},{"ts":1594888624755,"val":149},{"ts":1594888660755,"val":148.17},{"ts":1594888696755,"val":149.2},{"ts":1594888732755,"val":148.67},{"ts":1594888768755,"val":150.6},{"ts":1594888804755,"val":146.17},{"ts":1594888840755,"val":147},{"ts":1594888876755,"val":145.6},{"ts":1594888912755,"val":145.17},{"ts":1594888948755,"val":144.8},{"ts":1594888984755,"val":146.33},{"ts":1594889020755,"val":150.6},{"ts":1594889056755,"val":149.17},{"ts":1594889092755,"val":148.33},{"ts":1594889128755,"val":149.4},{"ts":1594889164755,"val":152.5},{"ts":1594889200755,"val":149.6},{"ts":1594889236755,"val":148},{"ts":1594889272755,"val":146.8},{"ts":1594889308755,"val":147.67},{"ts":1594889344755,"val":146.67},{"ts":1594889380755,"val":144},{"ts":1594889416755,"val":143.83},{"ts":1594889452755,"val":146.2},{"ts":1594889488755,"val":145},{"ts":1594889524755,"val":142},{"ts":1594889560755,"val":140.17},{"ts":1594889596755,"val":143.83},{"ts":1594889632755,"val":144.4},{"ts":1594889668755,"val":144.83},{"ts":1594889704755,"val":143.8},{"ts":1594889740755,"val":142.67},{"ts":1594889776755,"val":141.2},{"ts":1594889812755,"val":139.33},{"ts":1594889848755,"val":143.33},{"ts":1594889884755,"val":140.2},{"ts":1594889920755,"val":140.67},{"ts":1594889956755,"val":140.4},{"ts":1594889992755,"val":141.67},{"ts":1594890028755,"val":139.8},{"ts":1594890064755,"val":142.17},{"ts":1594890100755,"val":140.17},{"ts":1594890136755,"val":140},{"ts":1594890172755,"val":139.5},{"ts":1594890208755,"val":140.4},{"ts":1594890244755,"val":142},{"ts":1594890280755,"val":143.2},{"ts":1594890316755,"val":141.83},{"ts":1594890352755,"val":142},{"ts":1594890388755,"val":140.8},{"ts":1594890424755,"val":141.5},{"ts":1594890460755,"val":140.4},{"ts":1594890496755,"val":140},{"ts":1594890532755,"val":140.6}] (bundle.min.js, line 2)
    [Log] [getTaskForHistoryData w00503] history data result 'mqtt.0.Wohnzimmer.Luftfeuchtigkeit': [{"ts":1594886950755,"val":41.29},{"ts":1594886968755,"val":41.28},{"ts":1594887004755,"val":41.18},{"ts":1594887040755,"val":41.24},{"ts":1594887076755,"val":41.14},{"ts":1594887112755,"val":41.22},{"ts":1594887148755,"val":40.46},{"ts":1594887184755,"val":41.05},{"ts":1594887220755,"val":40.79},{"ts":1594887256755,"val":41.13},{"ts":1594887292755,"val":41.23},{"ts":1594887328755,"val":40.99},{"ts":1594887364755,"val":40.75},{"ts":1594887400755,"val":41.01},{"ts":1594887436755,"val":41.1},{"ts":1594887472755,"val":41.18},{"ts":1594887508755,"val":41.15},{"ts":1594887544755,"val":41.35},{"ts":1594887580755,"val":41.29},{"ts":1594887616755,"val":41.58},{"ts":1594887652755,"val":41.22},{"ts":1594887688755,"val":41.26},{"ts":1594887724755,"val":41.3},{"ts":1594887760755,"val":41.29},{"ts":1594887796755,"val":41.24},{"ts":1594887832755,"val":41.2},{"ts":1594887868755,"val":41.19},{"ts":1594887904755,"val":41.14},{"ts":1594887940755,"val":41.08},{"ts":1594887976755,"val":40.99},{"ts":1594888012755,"val":41.04},{"ts":1594888048755,"val":41.06},{"ts":1594888084755,"val":41.01},{"ts":1594888120755,"val":40.95},{"ts":1594888156755,"val":40.96},{"ts":1594888192755,"val":40.95},{"ts":1594888228755,"val":40.92},{"ts":1594888264755,"val":40.92},{"ts":1594888300755,"val":40.93},{"ts":1594888336755,"val":40.97},{"ts":1594888372755,"val":40.95},{"ts":1594888408755,"val":40.98},{"ts":1594888444755,"val":40.93},{"ts":1594888480755,"val":40.96},{"ts":1594888516755,"val":40.99},{"ts":1594888552755,"val":40.97},{"ts":1594888588755,"val":40.97},{"ts":1594888624755,"val":40.95},{"ts":1594888660755,"val":40.96},{"ts":1594888696755,"val":40.93},{"ts":1594888732755,"val":40.97},{"ts":1594888768756,"val":40.98},{"ts":1594888804756,"val":41.01},{"ts":1594888840756,"val":40.99},{"ts":1594888876756,"val":41.02},{"ts":1594888912756,"val":41.05},{"ts":1594888948756,"val":41.01},{"ts":1594888984756,"val":40.94},{"ts":1594889020756,"val":40.99},{"ts":1594889056756,"val":40.98},{"ts":1594889092756,"val":40.96},{"ts":1594889128756,"val":40.85},{"ts":1594889164756,"val":40.88},{"ts":1594889200756,"val":40.93},{"ts":1594889236756,"val":40.93},{"ts":1594889272756,"val":40.67},{"ts":1594889308756,"val":40.92},{"ts":1594889344756,"val":41},{"ts":1594889380756,"val":41.01},{"ts":1594889416756,"val":41.03},{"ts":1594889452756,"val":41.05},{"ts":1594889488756,"val":41.05},{"ts":1594889524756,"val":41.07},{"ts":1594889560756,"val":41.06},{"ts":1594889596756,"val":41.01},{"ts":1594889632756,"val":41.05},{"ts":1594889668756,"val":41.05},{"ts":1594889704756,"val":41.05},{"ts":1594889740756,"val":41.05},{"ts":1594889776756,"val":41.08},{"ts":1594889812756,"val":41.05},{"ts":1594889848756,"val":41.08},{"ts":1594889884756,"val":41.09},{"ts":1594889920756,"val":41.08},{"ts":1594889956756,"val":41.08},{"ts":1594889992756,"val":41.09},{"ts":1594890028756,"val":40.99},{"ts":1594890064756,"val":41.03},{"ts":1594890100756,"val":41.07},{"ts":1594890136756,"val":41.06},{"ts":1594890172756,"val":41.05},{"ts":1594890208756,"val":41.05},{"ts":1594890244756,"val":40.92},{"ts":1594890280756,"val":40.97},{"ts":1594890316756,"val":40.92},{"ts":1594890352756,"val":40.95},{"ts":1594890388756,"val":40.94},{"ts":1594890424756,"val":40.9},{"ts":1594890460756,"val":40.91},{"ts":1594890496756,"val":40.82},{"ts":1594890532756,"val":40.84}] (bundle.min.js, line 2)
    Ich kann da halt nicht wirklich was anklicken. Das verhält sich, als wäre es nur ein Bild. Wenn ich allerdings aus dem Editor heraus nur die eine Card starte funktioniert das auch mit der Bedienung. Nur auf der Seite mit dem Masonry View, wo die Card drin eingebunden ist, kann ich das nicht bedienen. Als wäre das verdeckt.
    EDIT: Es wäre noch anzumerken, dass es scheinbar nur im Safari unter macOS Catalina so ist. Vielleicht macht es nicht wirklich sinn, da jetzt was zu suchen.
    macOS Catalina - Safari: nicht bedienbar
    macOS Catalina - Chrome: funktioniert einwandfrei
    iOS 13.5.1 - Safari (iPhone): funktioniert auch
    Nur zur Info, seit dem Update auf Safari 14.0 läuft das Chart wieder einwandfrei unter macOS.
      klaus88
      schrieb am zuletzt editiert von klaus88
      #120
      erstmal allerbesten Dank für dieses tolle Widget.
      Vielleicht hat wer einen Tipp für mich: Ich möchte gerne die aktuellen Corona Zahlen aufzeichnen - dank Corona Adapter und history Adapter und diesem Widget geht das relativ einfach.
      Leider sendet die Datenquelle aber zwischen 2 Tagen auch mal den Wert 0 - also als Bsp. :
      19.9. von 10 bis 24 Uhr Wert = 816
      20.9. von 0 bis 10 Uhr Wert = 0
      ab 10 Uhr Wert = 613.
      Dadurch schaut das Diagramm etwas komisch aus. Gibt es eine Möglichkeit, dass man "0" Werte ignorieren kann?
      Bild als Beispiel: !Corona.jpg
      Danke für eure Hilfe
      Klaus
      • K klaus88
        Klaus
        sigi234S Online
        sigi234S Online
        #121
        @klaus88 sagte in Material Design Widgets: Line History Chart Widget:
        history Adapter
        Genau hier
        • sigi234S sigi234
          history Adapter
          Genau hier
          klaus88
          #122
          @sigi234 Mist - ich hab's mir gedacht ! Hast einen Tipp wie?
          Derzeitige Einstellungen:
          Danke für deine Hilfe
          Klaus
          Update: Ich glaube jetzt haben wir gleichzeitig geschrieben :-) Ich habe diese Einstellung nicht !
          • K klaus88
            Klaus
            sigi234S Online
            sigi234S Online
            #123
            Welche Version?
            • sigi234S sigi234
              Welche Version?
              klaus88
              #124
              @sigi234 Sorry - bin auf der falschen Fährte gewesen - habs schon - ist natürlich in der Instanz und nicht im Objekt !!!
              DANKE DANKE für deine Hilfe - werde es mal checken ob es geht!
              Klaus
              • BostilB Offline
                BostilB Offline
                Bostil
                #125
                Hi @Scrounger - erhalte beim Erstellen eines simplen Liniendiagrams fast permanent im Editor und auch in der Runtime den Fehler "Error Timeout". Hast du eine Ahnung welche Einstellung hierfür verantwortlich sein könnte ? DANKE dir.
                Export:
                [{"tpl":"tplVis-materialdesign-Chart-Line-History","data":{"g_fixed":false,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","dataCount":"0","aggregate":"average","timeIntervalToShow":"1 day","refreshMethod":"timeInterval","refreshTimeInterval":"1 hour","chartTimeout":"2","pointStyle":"circle","showLegend":false,"legendPosition":"bottom","legendPointStyle":false,"showTooltip":true,"tooltipTimeFormats":"{\"millisecond\":\"lll:ss\",\"second\":\"lll:ss\",\"minute\":\"lll\",\"hour\":\"lll\",\"day\":\"lll\",\"week\":\"lll\",\"month\":\"lll\",\"quarter\":\"lll\",\"year\":\"lll\"}","tooltipShowColorBox":"true","lineSpanGaps0":"true","lineSpanGaps1":"true","xAxisPosition":"bottom","xAxisBounds":"axisTicks","xAxisTimeFormats":"{\"millisecond\":\"H:mm:ss.SSS\",\"second\":\"H:mm:ss\",\"minute\":\"H:mm\",\"hour\":\"H\",\"day\":\"ddd DD.\",\"week\":\"ll\",\"month\":\"MMM YYYY\",\"quarter\":\"[Q]Q - YYYY\",\"year\":\"YYYY\"}","xAxisValueDistanceToAxis":"6","xAxisShowAxis":"true","xAxisShowAxisLabels":"true","xAxisShowGridLines":"true","xAxisShowTicks":"true","xAxisMinRotation":"0","xAxisMaxRotation":"0","yAxisValueDistanceToAxis":"10","showYAxis0":"true","yAxisPosition0":"left","yAxisShowGridLines0":"true","yAxisShowTicks0":true,"yAxisShowAxisBorder0":"true","showYAxis1":"true","yAxisPosition1":"left","yAxisShowGridLines1":"true","yAxisShowTicks1":"true","yAxisShowAxisBorder1":"true","showValues0":"showValuesAuto","valuesPositionAnchor0":"end","valuesPositionAlign0":"top","valuesTextAlign0":"center","showValues1":"showValuesOn","valuesPositionAnchor1":"end","valuesPositionAlign1":"top","valuesTextAlign1":"center","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"oid0":"deconz.0.sensors.bc33acfffe4c92ba.temperature","historyAdapterInstance":"history.0","yAxisMinValue0":"","yAxisMaxValue0":"","multiply0":"","multiply1":"1","manualRefreshTrigger":"","mdwDebug":false,"minTimeInterval":"","maxDataPoints":"","useFillColor0":true,"yAxisStep0":"1","valuesSteps0":"1","backgroundColor":"rgba(61, 92, 101, 0.8)","chartAreaBackgroundColor":"rgba(61, 92, 101, 0.3)","animationDuration":"1200","chartPaddingTop":"10","chartPaddingLeft":"10","chartPaddingRight":"10","chartPaddingBottom":"4","colorScheme":"material.bluegrey","globalColor":"#dedede","pointSize":"7","pointSizeHover":"20","legendFontFamily":"Akrobat","legendFontColor":"#dedede","tooltipTitleFontFamily":"Akrobat","tooltipBodyFontFamily":"Akrobat","xAxisTitleFontFamily":"Akrobat","yAxisTitleFontFamily":"Akrobat","valuesFontFamily0":"Akrobat","tooltipBackgroundColor":"rgba(61, 92, 101, 0.8)","tooltipArrowSize":"5","tooltipDistanceToBar":"5","tooltipBoxRadius":"3","tooltipXpadding":"5","tooltipYpadding":"5","tooltipTitleFontColor":"#dedede","tooltipBodyFontColor":"#dedede","tooltipValueMaxDecimals":"1","tooltipValueMinDecimals":"1","lineTension0":"1","lineThikness0":"3","fillColor0":"rgba(84, 126, 138, 1)","pointHoverColor0":"rgba(61, 92, 101, 1)","xAxisValueFontFamily":"Akrobat","xAxisValueFontSize":"25","xAxisValueLabelColor":"#dedede","xAxisGridLinesColor":"#dedede","yAxisValueLabelColor":"#dedede","yAxisTitleFontSize":"25","yAxisValueFontFamily":"Akrobat","yAxisGridLinesColor0":"#dedede","yAxisValueFontSize":"25","yAxisTitleColor":"#dedede","yAxisValueColor0":"#dedede","yAxisValueMaxDigits0":"0","yAxisValueMinDigits0":"1","yAxisValueAppendText0":" °C","valuesMinDecimals0":"1","valuesMaxDecimals0":"1","valuesAppendText0":" °C","valuesFontColor0":"#dedede","valuesFontSize0":"25","disableHoverEffects":false,"dataColor0":"rgba(61, 92, 101, 1)","axisValueAppendText":"","xAxisTickLength":"3","yAxisTickLength0":"3","xAxisMaxLabel":"24","xAxisOffsetGridLines":false,"steppedLine0":false},"style":{"left":"30px","top":"415px","width":"794px","height":"419px","z-index":2},"widgetSet":"materialdesign"}]
                • BostilB Bostil
                  Export:
                  sigi234S Online
                  sigi234S Online
                  #126
                  @Bostil
                  Erhöhe das Diagramm Time Out unter Allgemein
                  Edit: geht bei mir auch nicht.
                  Welche Version hast du?
                  BostilB 1 Antwort Letzte Antwort
                  • sigi234S sigi234
                    @Bostil
                    BostilB Offline
                    BostilB Offline
                    Bostil
                    #127
                    @sigi234 Danke dir. Habe Version 0.3.19 der Material Design Widgets.
                    • ScroungerS Scrounger
                      Sämtliche Fragen zu Einstellungen (VIS Editor, Bedienung, JSON strings, etc.) des Widgets hier stellen
                      Das ist sicher besser für die Übersichtlichkeit und Dokumentation.
                      • Dokumentation
                      • Online Beispiel
                      Themen zu anderen Widgets findest du hier!
                      besterquesterB Offline
                      besterquester
                      #128
                      @Scrounger Hi, I am testin the lineHistory Chart. I would like to extend the chart to'bar' mode. I would like to support you in the development. I tried to fork and change the properties. Maybe you can give me a hint where to start.
                      With the json chart i developed a javascript class but would be better to have it as widget available
                      regards Chris
                      ScroungerS 1 Antwort Letzte Antwort
                      • besterquesterB besterquester
                        regards Chris
                        ScroungerS Offline
                        ScroungerS Offline
                        Scrounger
                        #129
                        @besterquester sagte in Material Design Widgets: Line History Chart Widget:
                        That would be great!
                        The code of the line chart history can be found here https://github.com/Scrounger/ioBroker.vis-materialdesign/blob/f72f81203c23cbb6e750d7033052d27605f9017e/widgets/materialdesign/js/widgets/materialdesign.chart.js#L334.
                        Think this is a good point to start. Please note that some functions are used by all charts, so you always have to test this too.
                        I use Minify to merge all widgets *.js files into one minifed file.
                        Im using VS Code as IDE and there it has a plugin Minify that will do this automatically.
                        If you have further questions, just contact me.
                        besterquesterB 2 Antworten Letzte Antwort
                        • SteffS Offline
                          SteffS Offline
                          Steff
                          #130
                          gibt es eine Möglichkeit in den Tooltips die Einheit des entsprechenden Datenpunkts anzuzeigen?
                          Ich kann im Tooltip Layout unter Text Anhang eine Einheit angeben, die gilt dann aber für alle Linien.
                          Gruß Steffen
                          ioBroker auf Intel NUC 7CJYH / Debian 13 "Trixie" / States & Objects in JSONL / Repo --> Beta / HM CCU2 V2.61.7 / Siemens LOGO! (0BA7 / 0BA8)
                          Admin V7.8.24 / Node V22.22.2 / NPM V10.9.7 / JSC V7.1.2 / JSE V9.2.2
                            besterquester
                            #131
                            @Scrounger Thanks i try to start to extend the history chart also used to visualize bar charts. I will get in contact when i have a ready version
                            regards Chris
                              besterquester
                              schrieb am zuletzt editiert von besterquester
                              #132
                              @Scrounger said in Material Design Widgets: Line History Chart Widget:
                              Just one question. I installed minify and what is to do in order to test the adapter. I am using visual code remote so i am directly on the adapter (RASPI PI). It seems the adapter do not accept changes I make in the code. The minify works but there is no change. Restarting adapter stop and start also is not working.
                              Maybe you can give a hint. :)
                              regards Chris
                                regards Chris
                                ScroungerS Offline
                                ScroungerS Offline
                                Scrounger
                                schrieb am zuletzt editiert von Scrounger
                                #133
                                regards Chris
                                To see the changes immideatly, change the files in iobroker\iobroker-data\files\vis\widgets\materialdesign and make a reload of the page. After you are finished with the changes dont forget to copy these into your project folder.
                                @Steff sagte in Material Design Widgets: Line History Chart Widget:
                                Gruß Steffen
                                Stimmt für tooltip geht das nur global. Schreib bitte nen issue auf github, dann bau ich das mit ein.
                                • C Coffeelover
                                  @Scrounger Funktioniert auf den ersten Test hin perfekt. Der nächste Kaffee geht auf mich.
                                  Vorher sah meine Heizungskurve so aus:
                                  Und jetzt so. Damit lässt sich sinnvoll etwas ablesen! (Ja - es sind unterschiedliche Heizkreise auf den Screenshots.)
                                  werner2000xW Offline
                                  werner2000x
                                  #134
                                  @Coffeelover Wie kann man die Zahlen der Datenpunkte entfernen?
                                  Mit "Linien zwischen Punkten ohne Daten" geht es nicht.
                                  Raspi4 8 GB mit Aqara Zigbee USB, iob
                                  Innogy Smarthome
                                  Bosch Bridge 2
                                  HUE Bridge
                                  OpenWB Wallbox mit EVU Kit
                                  Google Nest Pro Hub
                                  HA auf uGreen dxp4800
                                  • werner2000xW werner2000x
                                    sigi234S Online
                                    sigi234S Online
                                    #135
                                    @werner2000x
                                    werner2000xW 1 Antwort Letzte Antwort
                                    • sigi234S sigi234
                                      @werner2000x
                                      werner2000x
                                      #136
                                      @sigi234 Danke, hat geklappt :-)
                                      Innogy Smarthome
                                      Bosch Bridge 2
                                      HUE Bridge
                                      Google Nest Pro Hub
                                      • CKMartensC Offline
                                        CKMartensC Offline
                                        CKMartens
                                        #137
                                        ich versuche das Widget mit Daten von influx zu füttern.
                                        Leider kommt nur die Meldung Error: [0] [object Object], [1] [object Object]
                                        Eingestellt habe ich als Adapterinstanz influxdb.0
                                        Bei Datensätze habe ich die OIDs der Datenpunkte angegeben die in mittels influxdb gespeichert werden.
                                        Was muss ich wo einstellen damit es funktioniert? Danke für eure Hilfe.
                                        Carsten
                                          Snapergy
                                          schrieb am zuletzt editiert von Snapergy
                                          #138
                                          1. Gibt es eventuell ne Möglichkeit den Min- und den Max-Wert für den angezeigten Zeitraum hervorheben zu lassen?
                                          2. Gibt es ne Möglichkeit die History-Daten zeitlich zu shiften? Ich würde gerne pro Tag den Max- und Min-Wert loggen und dann am Ende des Tages in einen Datenpunkt eintragen, der history-mäßig dann gespeichert wird. Wenn ich mir dann aber eine gestufte Grafik ausgeben lasse, ist der Sprung ja immer erst am Ende des Tages, ich bräuchte ihn aber ja 24h eher
