  4. Viessmann-Adapter
Viessmann-Adapter
viesmann
523 Beiträge 50 Kommentatoren 213.2k Aufrufe 19 Beobachtet
    dtp
    schrieb am zuletzt editiert von dtp
    #486
    Lösung scheint gefunden. Im Pfad darf nur "/etc/vcontrold/" stehen. Sollte mal in den Standardeinstellungen des Adapters geändert werden.
    Nach dem Einlesen der vito.xml erhalte ich allerdings Warnmeldungen in der folgenden Art für alle Datenpunkte:
    viessmann.0	2020-07-11 15:20:18.939	warn	(8878) This object will not be created in future versions. Please report this to the developer.
    viessmann.0	2020-07-11 15:20:18.939	warn	(8878) Object viessmann.0.set.VitoBetriebsart is invalid: obj.common.type has an invalid value () but has to be one of number, string, boolean, array, object, mixed, file, json
    Normal oder ein Fehler in der vito.xml?
    • D dtp
      bahnuhrB Online
      bahnuhrB Online
      bahnuhr
      #487
      @dtp sagte in Viessmann-Adapter:
      Ja, die habe ich jetzt auch.
      Beim installieren der Instanz kam:
      viessmann.0	2020-09-05 09:14:04.281	warn	(5824) Object viessmann.0.set.TimerM1Fr is invalid: obj.common.type has an invalid value () but has to be one of number, string, boolean, array, object, mixed, file, json
      viessmann.0	2020-09-05 09:14:04.281	warn	(5824) This object will not be created in future versions. Please report this to the developer.
      viessmann.0	2020-09-05 09:14:04.281	warn	(5824) Object viessmann.0.set.TimerM1Do is invalid: obj.common.type has an invalid value () but has to be one of number, string, boolean, array, object, mixed, file, json
      viessmann.0	2020-09-05 09:14:04.280	warn	(5824) Object viessmann.0.set.TimerM1Mi is invalid: obj.common.type has an invalid value () but has to be one of number, string, boolean, array, object, mixed, file, json
      viessmann.0	2020-09-05 09:14:04.280	warn	(5824) This object will not be created in future versions. Please report this to the developer.
      viessmann.0	2020-09-05 09:14:04.280	warn	(5824) Object viessmann.0.set.TimerM1Di is invalid: obj.common.type has an invalid value () but has to be one of number, string, boolean, array, object, mixed, file, json
      viessmann.0	2020-09-05 09:14:04.280	warn	(5824) Object viessmann.0.set.TimerM1Mo is invalid: obj.common.type has an invalid value () but has to be one of number, string, boolean, array, object, mixed, file, json
      viessmann.0	2020-09-05 09:14:04.280	warn	(5824) Object viessmann.0.set.TempWWsoll is invalid: obj.common.type has an invalid value () but has to be one of number, string, boolean, array, object, mixed, file, json
      viessmann.0	2020-09-05 09:14:04.279	warn	(5824) Object viessmann.0.set.SystemTime is invalid: obj.common.type has an invalid value () but has to be one of number, string, boolean, array, object, mixed, file, json
      viessmann.0	2020-09-05 09:14:04.279	warn	(5824) This object will not be created in future versions. Please report this to the developer.
      Und !!!
      Die Objekte werden teilweise auch nicht angelegt.
      Wird der Adapter noch gepflegt ??
      mfg
      Dieter
      Danke.
      blauholstenB 2 Antworten Letzte Antwort
      • bahnuhrB bahnuhr
        Und !!!
        mfg
        Dieter
        blauholstenB Offline
        blauholsten
        #488
        @bahnuhr sagte in Viessmann-Adapter:
        mfg
        Dieter
        Ja natürlich
        - Alarm Adapter
        • blauholstenB blauholsten
          mfg
          Dieter
          Ja natürlich
          bahnuhrB Online
          bahnuhrB Online
          bahnuhr
          #489
          @blauholsten sagte in Viessmann-Adapter:
          Ja natürlich
          Das ist gut.
          Kannst du zu o.g. Problem etwas sagen?
          dtp hatte dies ja auch schon im Juli mitgeteilt.
          Danke.
          blauholstenB 1 Antwort Letzte Antwort
          • bahnuhrB bahnuhr
            Ja natürlich
            Das ist gut.
            blauholsten
            #490
            @bahnuhr oh, das habe ich überlesen. Muss ich mir anschauen
            - Alarm Adapter
            • bahnuhrB Online
              bahnuhrB Online
              bahnuhr
              #491
              @blauholsten
              Auch erscheinen bei den Werten jetzt 2x Grad Celsius
              War die ganze Zeit nicht so.
              Danke.
              • bahnuhrB Online
                bahnuhrB Online
                bahnuhr
                #492
                Und die Werte werden nicht mehr in sql gespeichert.
                sql.0	2020-09-06 11:28:14.197	info	(66860) Do not store value "48.000000 Grad Celsius" for viessmann.0.get.TempWWist because no number
                sql.0	2020-09-06 11:28:10.137	info	(66860) Do not store value "7.000000 Grad Celsius" for viessmann.0.get.TempKsoll because no number
                sql.0	2020-09-06 11:28:08.092	info	(66860) Do not store value "70.099998 Grad Celsius" for viessmann.0.get.TempKist because no number
                sql.0	2020-09-06 11:28:06.061	info	(66860) Do not store value "17.000000 Grad Celsius" for viessmann.0.get.TempA because no number
                War bisher auch nicht so.
                Danke.
                • bahnuhrB bahnuhr
                  @blauholsten
                  dtp
                  #493
                  Setze mal den Haken vor "Datenpunktwerte kürzen".
                  Du musst die entsprechenden Datenpunkte vermutlich einfach nur neu für SQL konfigurieren. Dann werden sie auch wieder aufgezeichnet.
                  bahnuhrB 2 Antworten Letzte Antwort
                  • D dtp
                    bahnuhrB Online
                    bahnuhrB Online
                    bahnuhr
                    #494
                    Danke Thorsten,
                    probier ich aus.
                    Danke.
                    • D dtp
                      bahnuhrB Online
                      bahnuhrB Online
                      bahnuhr
                      #495
                      Ja, das wars.
                      Und sie werden auch wieder geloggt.
                      Danke.
                      • bahnuhrB bahnuhr
                        Und !!!
                        mfg
                        Dieter
                        blauholsten
                        #496
                        @bahnuhr
                        Bitte Version 1.3.0 probieren, dort sollten keine Meldungen mehr kommen,
                        - Alarm Adapter
                          @bahnuhr
                          bahnuhrB Online
                          bahnuhrB Online
                          bahnuhr
                          #497
                          erledigt.
                          Bisher keine Fehlermeldung.
                          Danke.
                          • bahnuhrB bahnuhr
                            erledigt.
                            dtp
                            #498
                            @blauholsten
                            Wäre hilfreich, wenn du auch noch den angegebenen Standard-Link für die vito.xml
                            ändern könntest in den folgenden Pfad.
                            Könnte den einen oder anderen Frust beim Einrichten des Adapters vermeiden. ;)
                              Manuel_K
                              #499
                              Hallo versuche auch den Adapter zum laufen zu bringen. Habe aber noch Probleme mit vcontrold.
                              Habe mich an die Anleitung von github gehalten.
                              Bei dem Punkt 6 komme ich aber nicht weiter.
                              Wenn ich vcontrold -n eingebe kommt folgender Fehler:
                              [8520] Sat Nov 7 13:03:31 2020 : Device 2049 nicht definiert
                              Fehler beim Laden von /etc/vcontrold/vcontrold.xml, terminiere!
                              Was bedeutet das? Was habe ich falsch gemacht.
                              mfg Manuel
                              • M Manuel_K
                                mfg Manuel
                                squashball
                                #500
                                @Manuel_K
                                Dann ist in der vito.xml wohl die 2049 nicht definiert...
                                • S squashball
                                  @Manuel_K
                                  Manuel_K
                                  schrieb am zuletzt editiert von Manuel_K
                                  #501
                                  @squashball
                                  Wo muss ich denn was eintragen ? 2049 ist device und 300 ist das Protokoll.
                                  Laut Anleitung soll man doch nur device im vcontrold.xml ändern ??
                                  mfg Manuel
                                  • M Manuel_K
                                    @squashball
                                    mfg Manuel
                                    squashball
                                    #502
                                    @Manuel_K
                                    Schau mal in die Datei rein, ich meine, für die 2049 ist gar nichts definiert...
                                    • S squashball
                                      @Manuel_K
                                      Manuel_K
                                      #503
                                      @squashball
                                      Habe in der Vito.xml und in der vcontrold.xml überall die Adresse "2053" in die "2049" ausgetauscht. Auch das Protokoll 300 habe ich geändert.
                                      Nun kommt folgender Fehler:
                                      [9549] Sun Nov 8 16:04:55 2020 : Protokoll Kommando geteaddr (bei getHKPTyp) nicht definiert
                                      Hier der auszug aus der vito.xml
                                      <command name='getHKPTyp' protocmd='geteaddr'>
                                                      <description>Ermittle Typ der Heizkreispumpe</description>
                                                      <device ID="2049">
                                                          <addr>05</addr>
                                                          <len>1</len>
                                                          <bit>5</bit>
                                                          <unit>HKT</unit>
                                                      </device>
                                              </command>
                                      Was muss dort noch geändert werden?
                                      • M Manuel_K
                                        @squashball
                                                        <device ID="2049">
                                                            <addr>05</addr>
                                                            <len>1</len>
                                                            <bit>5</bit>
                                                            <unit>HKT</unit>
                                                        </device>
                                                </command>
                                        squashball
                                        schrieb am zuletzt editiert von squashball
                                        #504
                                        @Manuel_K
                                        Da muss nichts "geändert" werden, da muss das komplette Protokoll für diese Anlage geschrieben werden. Jede Anlage hat ihr eigenes Protokoll. Ich habe eine Vitocal 350 WO1B und daher auch die ID 2049 verwendet.
                                        Du kannst ja mal schauen, ob das hier bei dir die Außentemp ausgibt, falls du eine ähnliche WP hast:
                                        	<command name='getTempAussen' protocmd='getaddr'>
                                        		<addr>0101</addr>
                                        		<len>2</len>
                                        		<unit>UT</unit>
                                        		<description>Ermittle die Aussentemperatur in Grad C</description>
                                        	</command>
                                        • S squashball
                                          @Manuel_K
                                          		<addr>0101</addr>
                                          		<len>2</len>
                                          		<unit>UT</unit>
                                          	</command>
                                          Manuel_K
                                          #505
                                          @squashball
                                          Scheinbar habe ich die Vorgänger Wärmepumpe.
                                          Also ich bin nicht wirklich Fit mit dem Umschreiben.
                                          Vielleicht könntest du mir deine Vito.xml und vcontrold.xml zukommen lassen ? Dann bekomme ich es vielleicht hin.
                                          mfg Manuel
