- ioBroker Community Home
- Deutsch
- Tester
- Test Adapter Linux Control v1.x.x
Version 0.2.5 bei github verügbar, bitte darauf updaten.
@Homoran
Adapter auf debug stellen und dann bitte das log posten.@Scrounger sagte in Test Adapter Linux Control v0.x.x:
@Homoran
Adapter auf debug stellen und dann bitte das log posten.erledigt: aber noch mit der alten Version:
2020-08-15 16:04:21.514 - info: host.raspberrypi Do not restart adapter system.adapter.linux-control.0 because desired by instance 2020-08-15 16:04:22.317 - debug: linux-control.0 (19029) Redis Objects: Use Redis connection: 127.0.0.1:9001 2020-08-15 16:04:22.356 - debug: linux-control.0 (19029) Objects client ready ... initialize now 2020-08-15 16:04:22.370 - debug: linux-control.0 (19029) Objects create System PubSub Client 2020-08-15 16:04:22.371 - debug: linux-control.0 (19029) Objects create User PubSub Client 2020-08-15 16:04:22.372 - debug: linux-control.0 (19029) Objects client initialize lua scripts 2020-08-15 16:04:22.393 - debug: linux-control.0 (19029) Objects connected to redis: 127.0.0.1:9001 2020-08-15 16:04:22.402 - debug: linux-control.0 (19029) objectDB connected 2020-08-15 16:04:22.404 - debug: linux-control.0 (19029) Redis States: Use Redis connection: 127.0.0.1:9000 2020-08-15 16:04:22.416 - debug: linux-control.0 (19029) States create User PubSub Client 2020-08-15 16:04:22.419 - debug: linux-control.0 (19029) States create System PubSub Client 2020-08-15 16:04:22.438 - debug: linux-control.0 (19029) States connected to redis: 127.0.0.1:9000 2020-08-15 16:04:22.439 - debug: linux-control.0 (19029) statesDB connected 2020-08-15 16:04:24.577 - debug: linux-control.0 (19029) Plugin sentry Initialize Plugin (enabled=true) 2020-08-15 16:04:24.740 - info: linux-control.0 (19029) starting. Version 0.2.4 in /opt/iobroker/node_modules/iobroker.linux-control, node: v10.21.0, js-controller: 3.1.4 2020-08-15 16:04:24.814 - info: linux-control.0 (19029) getting data from RasPi4 (192.168.138.139:22) 2020-08-15 16:04:24.857 - debug: linux-control.0 (19029) [getConnection] Host 'RasPi4' (192.168.138.139:22): using sudo for authentification 2020-08-15 16:04:25.048 - debug: linux-control.0 (19029) [distributionInfo] RasPi4 (192.168.138.139:22): send command: 'cat /etc/os-release' 2020-08-15 16:04:25.389 - debug: linux-control.0 (19029) [distributionInfo] RasPi4 (192.168.138.139:22): response stdout: PRETTY_NAME="Raspbian GNU/Linux 10 (buster)" NAME="Raspbian GNU/Linux" VERSION_ID="10" VERSION="10 (buster)" VERSION_CODENAME=buster ID=raspbian ID_LIKE=debian HOME_URL="http://www.raspbian.org/" SUPPORT_URL="http://www.raspbian.org/RaspbianForums" BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs" 2020-08-15 16:04:25.413 - debug: linux-control.0 (19029) [distributionInfo] RasPi4 (192.168.138.139:22): csvToJson result: [{"prop":"PRETTY_NAME","val":"Raspbian GNU/Linux 10 (buster)"},{"prop":"NAME","val":"Raspbian GNU/Linux"},{"prop":"VERSION_ID","val":"10"},{"prop":"VERSION","val":"10 (buster)"},{"prop":"VERSION_CODENAME","val":"buster"},{"prop":"ID","val":"raspbian"},{"prop":"ID_LIKE","val":"debian"},{"prop":"HOME_URL","val":"http://www.raspbian.org/"},{"prop":"SUPPORT_URL","val":"http://www.raspbian.org/RaspbianForums"},{"prop":"BUG_REPORT_URL","val":"http://www.raspbian.org/RaspbianBugs"}] 2020-08-15 16:04:25.526 - debug: linux-control.0 (19029) [cmdAptUpdate] RasPi4 (192.168.138.139:22): no datapoints selected -> removing existing datapoints 2020-08-15 16:04:25.637 - debug: linux-control.0 (19029) [servicesInfo] RasPi4 (192.168.138.139:22): send command: 'systemctl list-units --type service --all --no-legend | awk '{out=""; for(i=5;i<=NF;i++){out=out" "$i}; print $1","$2","$3","$4","out}'' 2020-08-15 16:04:25.662 - debug: linux-control.0 (19029) [servicesInfo] RasPi4 (192.168.138.139:22): response stdout: alsa-restore.service,loaded,active,exited, Save/Restore Sound Card State alsa-state.service,loaded,active,running, Manage Sound Card State (restore and store) apparmor.service,not-found,inactive,dead, apparmor.service apt-daily-upgrade.service,loaded,inactive,dead, Daily apt upgrade and clean activities apt-daily.service,loaded,inactive,dead, Daily apt download activities auditd.service,not-found,inactive,dead, auditd.service auth-rpcgss-module.service,loaded,inactive,dead, Kernel Module supporting RPCSEC_GSS avahi-daemon.service,loaded,active,running, Avahi mDNS/DNS-SD Stack bluetooth.service,loaded,active,running, Bluetooth service bthelper@hci0.service,loaded,inactive,dead, Raspberry Pi bluetooth helper connman.service,not-found,inactive,dead, connman.service console-screen.service,not-found,inactive,dead, console-screen.service console-setup.service,loaded,active,exited, Set console font and keymap cron.service,loaded,active,running, Regular background program processing daemon dbus.service,loaded,active,running, D-Bus System Message Bus dhcpcd.service,loaded,active,running, dhcpcd on all interfaces display-manager.service,not-found,inactive,dead, display-manager.service dphys-swapfile.service,loaded,active,exited, dphys-swapfile - set up, mount/unmount, and delete a swap file emergency.service,loaded,inactive,dead, Emergency Shell fake-hwclock.service,loaded,active,exited, Restore / save the current clock getty-static.service,loaded,inactive,dead, getty on tty2-tty6 if dbus and logind are not available getty@tty1.service,loaded,active,running, Getty on tty1 gssproxy.service,not-found,inactive,dead, gssproxy.service hciuart.service,loaded,active,running, Configure Bluetooth Modems connected by UART ifupdown-pre.service,loaded,active,exited, Helper to synchronize boot up for ifupdown influxdb.service,not-found,inactive,dead, influxdb.service iobroker.service,loaded,active,running, ioBroker Server kbd.service,not-found,inactive,dead, kbd.service keyboard-setup.service,loaded,active,exited, Set the console keyboard layout kmod-static-nodes.service,loaded,active,exited, Create list of required static device nodes for the current kernel logrotate.service,loaded,inactive,dead, Rotate log files man-db.service,loaded,inactive,dead, Daily man-db regeneration mariadb-server.service,not-found,inactive,dead, mariadb-server.service mountkernfs.service,masked,inactive,dead, mountkernfs.service mysql-server.service,not-found,inactive,dead, mysql-server.service networking.service,loaded,active,exited, Raise network interfaces NetworkManager.service,not-found,inactive,dead, NetworkManager.service nfs-blkmap.service,not-found,inactive,dead, nfs-blkmap.service nfs-config.service,loaded,inactive,dead, Preprocess NFS configuration nfs-server.service,not-found,inactive,dead, nfs-server.service nfs-utils.service,loaded,inactive,dead, NFS server and client services plymouth-quit-wait.service,not-found,inactive,dead, plymouth-quit-wait.service plymouth-start.service,not-found,inactive,dead, plymouth-start.service raspberrypi-net-mods.service,loaded,inactive,dead, Copy user wpa_supplicant.conf raspi-config.service,loaded,active,exited, LSB: Switch to ondemand cpu governor (unless shift key is pressed) rc-local.service,loaded,active,exited, /etc/rc.local Compatibility redis.service,not-found,inactive,dead, redis.service regenerate_ssh_host_keys.service,loaded,inactive,dead, Regenerate SSH host keys rescue.service,loaded,inactive,dead, Rescue Shell rng-tools.service,loaded,active,running, rng-tools.service rpc-gssd.service,loaded,inactive,dead, RPC security service for NFS client and server rpc-svcgssd.service,loaded,inactive,dead, RPC security service for NFS server rpi-eeprom-update.service,loaded,active,exited, Check for Raspberry Pi EEPROM updates rsync.service,loaded,inactive,dead, fast remote file copy program daemon rsyslog.service,loaded,active,running, System Logging Service ssh.service,loaded,active,running, OpenBSD Secure Shell server sshswitch.service,loaded,inactive,dead, Turn on SSH if /boot/ssh is present systemd-ask-password-console.service,loaded,inactive,dead, Dispatch Password Requests to Console systemd-ask-password-wall.service,loaded,inactive,dead, Forward Password Requests to Wall systemd-binfmt.service,loaded,inactive,dead, Set Up Additional Binary Formats systemd-fsck-root.service,loaded,active,exited, File System Check on Root Device systemd-fsck@dev-disk-by\x2dpartuuid-50fbae26\x2d01.service,loaded,active,exited, File System Check on /dev/disk/by-partuuid/50fbae26-01 systemd-fsckd.service,loaded,inactive,dead, File System Check Daemon to report status systemd-hwdb-update.service,loaded,inactive,dead, Rebuild Hardware Database systemd-initctl.service,loaded,inactive,dead, initctl Compatibility Daemon systemd-journal-flush.service,loaded,active,exited, Flush Journal to Persistent Storage systemd-journald.service,loaded,active,running, Journal Service systemd-logind.service,loaded,active,running, Login Service systemd-machine-id-commit.service,loaded,inactive,dead, Commit a transient machine-id on disk systemd-modules-load.service,loaded,active,exited, Load Kernel Modules systemd-networkd.service,loaded,inactive,dead, Network Service systemd-quotacheck.service,loaded,inactive,dead, File System Quota Check systemd-random-seed.service,loaded,active,exited, Load/Save Random Seed systemd-remount-fs.service,loaded,active,exited, Remount Root and Kernel File Systems systemd-rfkill.service,loaded,inactive,dead, Load/Save RF Kill Switch Status systemd-sysctl.service,loaded,active,exited, Apply Kernel Variables systemd-sysusers.service,loaded,active,exited, Create System Users systemd-timesyncd.service,loaded,active,running, Network Time Synchronization systemd-tmpfiles-clean.service,loaded,inactive,dead, Cleanup of Temporary Directories systemd-tmpfiles-setup-dev.service,loaded,active,exited, Create Static Device Nodes in /dev systemd-tmpfiles-setup.service,loaded,active,exited, Create Volatile Files and Directories systemd-udev-trigger.service,loaded,active,exited, udev Coldplug all Devices systemd-udevd.service,loaded,active,running, udev Kernel Device Manager systemd-update-done.service,not-found,inactive,dead, systemd-update-done.service systemd-update-utmp-runlevel.service,loaded,inactive,dead, Update UTMP about System Runlevel Changes systemd-update-utmp.service,loaded,active,exited, Update UTMP about System Boot/Shutdown systemd-user-sessions.service,loaded,active,exited, Permit User Sessions systemd-vconsole-setup.service,not-found,inactive,dead, systemd-vconsole-setup.service triggerhappy.service,loaded,active,running, triggerhappy global hotkey daemon user-runtime-dir@1000.service,loaded,active,exited, User Runtime Directory /run/user/1000 user@1000.service,loaded,active,running, User Manager for UID 1000 wpa_supplicant.service,loaded,active,running, WPA supplicant 2020-08-15 16:04:25.669 - debug: linux-control.0 (19029) [servicesInfo] RasPi4 (192.168.138.139:22): csvToJson result: [{"id":"alsa-restore.service","load":"loaded","active":"active","running":"exited","description":"Save/Restore Sound Card State"},{"id":"alsa-state.service","load":"loaded","active":"active","running":"running","description":"Manage Sound Card State (restore and store)"},{"id":"apparmor.service","load":"not-found","active":"inactive","running":"dead","description":"apparmor.service"},{"id":"apt-daily-upgrade.service","load":"loaded","active":"inactive","running":"dead","description":"Daily apt upgrade and clean activities"},{"id":"apt-daily.service","load":"loaded","active":"inactive","running":"dead","description":"Daily apt download activities"},{"id":"auditd.service","load":"not-found","active":"inactive","running":"dead","description":"auditd.service"},{"id":"auth-rpcgss-module.service","load":"loaded","active":"inactive","running":"dead","description":"Kernel Module supporting RPCSEC_GSS"},{"id":"avahi-daemon.service","load":"loaded","active":"active","running":"running","description":"Avahi mDNS/DNS-SD Stack"},{"id":"bluetooth.service","load":"loaded","active":"active","running":"running","description":"Bluetooth service"},{"id":"bthelper@hci0.service","load":"loaded","active":"inactive","running":"dead","description":"Raspberry Pi bluetooth helper"},{"id":"connman.service","load":"not-found","active":"inactive","running":"dead","description":"connman.service"},{"id":"console-screen.service","load":"not-found","active":"inactive","running":"dead","description":"console-screen.service"},{"id":"console-setup.service","load":"loaded","active":"active","running":"exited","description":"Set console font and keymap"},{"id":"cron.service","load":"loaded","active":"active","running":"running","description":"Regular background program processing daemon"},{"id":"dbus.service","load":"loaded","active":"active","running":"running","description":"D-Bus System Message Bus"},{"id":"dhcpcd.service","load":"loaded","active":"active","running":"running","description":"dhcpcd on all interfaces"},{"id":"display-manager.service","load":"not-found","active":"inactive","running":"dead","description":"display-manager.service"},{"id":"dphys-swapfile.service","load":"loaded","active":"active","running":"exited","description":"dphys-swapfile - set up","field6":"mount/unmount","field7":"and delete a swap file"},{"id":"emergency.service","load":"loaded","active":"inactive","running":"dead","description":"Emergency Shell"},{"id":"fake-hwclock.service","load":"loaded","active":"active","running":"exited","description":"Restore / save the current clock"},{"id":"getty-static.service","load":"loaded","active":"inactive","running":"dead","description":"getty on tty2-tty6 if dbus and logind are not available"},{"id":"getty@tty1.service","load":"loaded","active":"active","running":"running","description":"Getty on tty1"},{"id":"gssproxy.service","load":"not-found","active":"inactive","running":"dead","description":"gssproxy.service"},{"id":"hciuart.service","load":"loaded","active":"active","running":"running","description":"Configure Bluetooth Modems connected by UART"},{"id":"ifupdown-pre.service","load":"loaded","active":"active","running":"exited","description":"Helper to synchronize boot up for ifupdown"},{"id":"influxdb.service","load":"not-found","active":"inactive","running":"dead","description":"influxdb.service"},{"id":"iobroker.service","load":"loaded","active":"active","running":"running","description":"ioBroker Server"},{"id":"kbd.service","load":"not-found","active":"inactive","running":"dead","description":"kbd.service"},{"id":"keyboard-setup.service","load":"loaded","active":"active","running":"exited","description":"Set the console keyboard layout"},{"id":"kmod-static-nodes.service","load":"loaded","active":"active","running":"exited","description":"Create list of required static device nodes for the current kernel"},{"id":"logrotate.service","load":"loaded","active":"inactive","running":"dead","description":"Rotate log files"},{"id":"man-db.service","load":"loaded","active":"inactive","running":"dead","description":"Daily man-db regeneration"},{"id":"mariadb-server.service","load":"not-found","active":"inactive","running":"dead","description":"mariadb-server.service"},{"id":"mountkernfs.service","load":"masked","active":"inactive","running":"dead","description":"mountkernfs.service"},{"id":"mysql-server.service","load":"not-found","active":"inactive","running":"dead","description":"mysql-server.service"},{"id":"networking.service","load":"loaded","active":"active","running":"exited","description":"Raise network interfaces"},{"id":"NetworkManager.service","load":"not-found","active":"inactive","running":"dead","description":"NetworkManager.service"},{"id":"nfs-blkmap.service","load":"not-found","active":"inactive","running":"dead","description":"nfs-blkmap.service"},{"id":"nfs-config.service","load":"loaded","active":"inactive","running":"dead","description":"Preprocess NFS configuration"},{"id":"nfs-server.service","load":"not-found","active":"inactive","running":"dead","description":"nfs-server.service"},{"id":"nfs-utils.service","load":"loaded","active":"inactive","running":"dead","description":"NFS server and client services"},{"id":"plymouth-quit-wait.service","load":"not-found","active":"inactive","running":"dead","description":"plymouth-quit-wait.service"},{"id":"plymouth-start.service","load":"not-found","active":"inactive","running":"dead","description":"plymouth-start.service"},{"id":"raspberrypi-net-mods.service","load":"loaded","active":"inactive","running":"dead","description":"Copy user wpa_supplicant.conf"},{"id":"raspi-config.service","load":"loaded","active":"active","running":"exited","description":"LSB: Switch to ondemand cpu governor (unless shift key is pressed)"},{"id":"rc-local.service","load":"loaded","active":"active","running":"exited","description":"/etc/rc.local Compatibility"},{"id":"redis.service","load":"not-found","active":"inactive","running":"dead","description":"redis.service"},{"id":"regenerate_ssh_host_keys.service","load":"loaded","active":"inactive","running":"dead","description":"Regenerate SSH host keys"},{"id":"rescue.service","load":"loaded","active":"inactive","running":"dead","description":"Rescue Shell"},{"id":"rng-tools.service","load":"loaded","active":"active","running":"running","description":"rng-tools.service"},{"id":"rpc-gssd.service","load":"loaded","active":"inactive","running":"dead","description":"RPC security service for NFS client and server"},{"id":"rpc-svcgssd.service","load":"loaded","active":"inactive","running":"dead","description":"RPC security service for NFS server"},{"id":"rpi-eeprom-update.service","load":"loaded","active":"active","running":"exited","description":"Check for Raspberry Pi EEPROM updates"},{"id":"rsync.service","load":"loaded","active":"inactive","running":"dead","description":"fast remote file copy program daemon"},{"id":"rsyslog.service","load":"loaded","active":"active","running":"running","description":"System Logging Service"},{"id":"ssh.service","load":"loaded","active":"active","running":"running","description":"OpenBSD Secure Shell server"},{"id":"sshswitch.service","load":"loaded","active":"inactive","running":"dead","description":"Turn on SSH if /boot/ssh is present"},{"id":"systemd-ask-password-console.service","load":"loaded","active":"inactive","running":"dead","description":"Dispatch Password Requests to Console"},{"id":"systemd-ask-password-wall.service","load":"loaded","active":"inactive","running":"dead","description":"Forward Password Requests to Wall"},{"id":"systemd-binfmt.service","load":"loaded","active":"inactive","running":"dead","description":"Set Up Additional Binary Formats"},{"id":"systemd-fsck-root.service","load":"loaded","active":"active","running":"exited","description":"File System Check on Root Device"},{"id":"systemd-fsck@dev-disk-by\\x2dpartuuid-50fbae26\\x2d01.service","load":"loaded","active":"active","running":"exited","description":"File System Check on /dev/disk/by-partuuid/50fbae26-01"},{"id":"systemd-fsckd.service","load":"loaded","active":"inactive","running":"dead","description":"File System Check Daemon to report status"},{"id":"systemd-hwdb-update.service","load":"loaded","active":"inactive","running":"dead","description":"Rebuild Hardware Database"},{"id":"systemd-initctl.service","load":"loaded","active":"inactive","running":"dead","description":"initctl Compatibility Daemon"},{"id":"systemd-journal-flush.service","load":"loaded","active":"active","running":"exited","description":"Flush Journal to Persistent Storage"},{"id":"systemd-journald.service","load":"loaded","active":"active","running":"running","description":"Journal Service"},{"id":"systemd-logind.service","load":"loaded","active":"active","running":"running","description":"Login Service"},{"id":"systemd-machine-id-commit.service","load":"loaded","active":"inactive","running":"dead","description":"Commit a transient machine-id on disk"},{"id":"systemd-modules-load.service","load":"loaded","active":"active","running":"exited","description":"Load Kernel Modules"},{"id":"systemd-networkd.service","load":"loaded","active":"inactive","running":"dead","description":"Network Service"},{"id":"systemd-quotacheck.service","load":"loaded","active":"inactive","running":"dead","description":"File System Quota Check"},{"id":"systemd-random-seed.service","load":"loaded","active":"active","running":"exited","description":"Load/Save Random Seed"},{"id":"systemd-remount-fs.service","load":"loaded","active":"active","running":"exited","description":"Remount Root and Kernel File Systems"},{"id":"systemd-rfkill.service","load":"loaded","active":"inactive","running":"dead","description":"Load/Save RF Kill Switch Status"},{"id":"systemd-sysctl.service","load":"loaded","active":"active","running":"exited","description":"Apply Kernel Variables"},{"id":"systemd-sysusers.service","load":"loaded","active":"active","running":"exited","description":"Create System Users"},{"id":"systemd-timesyncd.service","load":"loaded","active":"active","running":"running","description":"Network Time Synchronization"},{"id":"systemd-tmpfiles-clean.service","load":"loaded","active":"inactive","running":"dead","description":"Cleanup of Temporary Directories"},{"id":"systemd-tmpfiles-setup-dev.service","load":"loaded","active":"active","running":"exited","description":"Create Static Device Nodes in /dev"},{"id":"systemd-tmpfiles-setup.service","load":"loaded","active":"active","running":"exited","description":"Create Volatile Files and Directories"},{"id":"systemd-udev-trigger.service","load":"loaded","active":"active","running":"exited","description":"udev Coldplug all Devices"},{"id":"systemd-udevd.service","load":"loaded","active":"active","running":"running","description":"udev Kernel Device Manager"},{"id":"systemd-update-done.service","load":"not-found","active":"inactive","running":"dead","description":"systemd-update-done.service"},{"id":"systemd-update-utmp-runlevel.service","load":"loaded","active":"inactive","running":"dead","description":"Update UTMP about System Runlevel Changes"},{"id":"systemd-update-utmp.service","load":"loaded","active":"active","running":"exited","description":"Update UTMP about System Boot/Shutdown"},{"id":"systemd-user-sessions.service","load":"loaded","active":"active","running":"exited","description":"Permit User Sessions"},{"id":"systemd-vconsole-setup.service","load":"not-found","active":"inactive","running":"dead","description":"systemd-vconsole-setup.service"},{"id":"triggerhappy.service","load":"loaded","active":"active","running":"running","description":"triggerhappy global hotkey daemon"},{"id":"user-runtime-dir@1000.service","load":"loaded","active":"active","running":"exited","description":"User Runtime Directory /run/user/1000"},{"id":"user@1000.service","load":"loaded","active":"active","running":"running","description":"User Manager for UID 1000"},{"id":"wpa_supplicant.service","load":"loaded","active":"active","running":"running","description":"WPA supplicant"}] 2020-08-15 16:04:28.974 - debug: linux-control.0 (19029) [needrestart] RasPi4 (192.168.138.139:22): no datapoints selected -> removing existing datapoints 2020-08-15 16:04:29.018 - debug: linux-control.0 (19029) [folderSizes] RasPi4 (192.168.138.139:22): send command: 'sudo du -sk /opt/iobroker/iobroker-data/history | awk '{ print $1 /1024 }'' 2020-08-15 16:04:29.265 - debug: linux-control.0 (19029) [folderSizes] RasPi4 (192.168.138.139:22): response stdout: 194.051 2020-08-15 16:04:29.281 - debug: linux-control.0 (19029) [folderSizes] RasPi4 (192.168.138.139:22): RasPi4.folders.history.size: 194.05 MB 2020-08-15 16:04:29.328 - debug: linux-control.0 (19029) [folderSizes] RasPi4 (192.168.138.139:22): send command: 'sudo find /opt/iobroker/iobroker-data/history -name "*" | wc -l' 2020-08-15 16:04:29.513 - debug: linux-control.0 (19029) [folderSizes] RasPi4 (192.168.138.139:22): response stdout: 22104 2020-08-15 16:04:29.515 - debug: linux-control.0 (19029) [folderSizes] RasPi4 (192.168.138.139:22): RasPi4.folders.history.files: 22104 Dateien 2020-08-15 16:04:29.558 - debug: linux-control.0 (19029) [folderSizes] RasPi4 (192.168.138.139:22): send command: 'tmp=$(sudo find /opt/iobroker/iobroker-data/history -name "*" -type f -exec stat -c "%Y %n" -- {} \; | sort -nr | head -n1 | awk '{print $2}') && date +%s -r $tmp' 2020-08-15 16:05:00.034 - info: host.raspberrypi instance system.adapter.dwd.0 started with pid 25920 2020-08-15 16:05:04.414 - info: dwd.0 (25920) starting. Version 2.5.0 in /opt/iobroker/node_modules/iobroker.dwd, node: v10.21.0, js-controller: 3.1.4 2020-08-15 16:05:08.655 - info: dwd.0 (25920) Terminated (NO_ERROR): Without reason 2020-08-15 16:05:09.175 - info: host.raspberrypi instance system.adapter.dwd.0 terminated with code 0 (NO_ERROR) 2020-08-15 16:06:06.140 - debug: linux-control.0 (19029) [folderSizes] RasPi4 (192.168.138.139:22): response stdout: 1597500265 2020-08-15 16:06:06.153 - debug: linux-control.0 (19029) [folderSizes] RasPi4 (192.168.138.139:22): RasPi4.folders.history.lastChange: 1597500265000 -> 15.08.2020 16:04 2020-08-15 16:06:06.199 - debug: linux-control.0 (19029) [userCommand] RasPi4 (192.168.138.139:22, id: root, description: ): send command: 'df / | grep / | awk '{ print $5}' | sed 's/%//g'' 2020-08-15 16:06:06.217 - debug: linux-control.0 (19029) [userCommand] RasPi4 (192.168.138.139:22, id: root, description: ): response stdout: 19 2020-08-15 16:06:06.270 - debug: linux-control.0 (19029) [userCommand] RasPi4 (192.168.138.139:22, id: ip, description: ): send command: 'hostname -I | cut -d' ' -f1' 2020-08-15 16:06:06.297 - debug: linux-control.0 (19029) [userCommand] RasPi4 (192.168.138.139:22, id: ip, description: ): response stdout: 192.168.138.139 2020-08-15 16:06:06.302 - debug: linux-control.0 (19029) [userCommand] RasPi4 (192.168.138.139:22, id: cpu-temp, description: ): send command: 'vcgencmd measure_temp | awk '{print substr($1, length($0)-5,4)}'' 2020-08-15 16:06:06.318 - debug: linux-control.0 (19029) [userCommand] RasPi4 (192.168.138.139:22, id: cpu-temp, description: ): response stdout: 51.0 2020-08-15 16:06:06.371 - info: linux-control.0 (19029) successful received data from RasPi4 (192.168.138.139:22) 2020-08-15 16:06:06.372 - info: linux-control.0 (19029) getting data from NUC_VM (192.168.138.123:22) 2020-08-15 16:06:06.457 - debug: linux-control.0 (19029) [getConnection] Host 'NUC_VM' (192.168.138.123:22): using sudo for authentification 2020-08-15 16:06:06.510 - debug: linux-control.0 (19029) [distributionInfo] NUC_VM (192.168.138.123:22): send command: 'cat /etc/os-release' 2020-08-15 16:06:06.574 - debug: linux-control.0 (19029) [distributionInfo] NUC_VM (192.168.138.123:22): response stdout: PRETTY_NAME="Debian GNU/Linux 10 (buster)" NAME="Debian GNU/Linux" VERSION_ID="10" VERSION="10 (buster)" VERSION_CODENAME=buster ID=debian HOME_URL="https://www.debian.org/" SUPPORT_URL="https://www.debian.org/support" BUG_REPORT_URL="https://bugs.debian.org/" 2020-08-15 16:06:06.578 - debug: linux-control.0 (19029) [distributionInfo] NUC_VM (192.168.138.123:22): csvToJson result: [{"prop":"PRETTY_NAME","val":"Debian GNU/Linux 10 (buster)"},{"prop":"NAME","val":"Debian GNU/Linux"},{"prop":"VERSION_ID","val":"10"},{"prop":"VERSION","val":"10 (buster)"},{"prop":"VERSION_CODENAME","val":"buster"},{"prop":"ID","val":"debian"},{"prop":"HOME_URL","val":"https://www.debian.org/"},{"prop":"SUPPORT_URL","val":"https://www.debian.org/support"},{"prop":"BUG_REPORT_URL","val":"https://bugs.debian.org/"}] 2020-08-15 16:06:06.594 - debug: linux-control.0 (19029) [cmdAptUpdate] NUC_VM (192.168.138.123:22): no datapoints selected -> removing existing datapoints 2020-08-15 16:06:06.598 - debug: linux-control.0 (19029) [servicesInfo] NUC_VM (192.168.138.123:22): send command: 'systemctl list-units --type service --all --no-legend | awk '{out=""; for(i=5;i<=NF;i++){out=out" "$i}; print $1","$2","$3","$4","out}'' 2020-08-15 16:06:06.610 - debug: linux-control.0 (19029) [servicesInfo] NUC_VM (192.168.138.123:22): response stdout: apache2.service,loaded,active,running, The Apache HTTP Server apparmor.service,loaded,active,exited, Load AppArmor profiles apt-daily-upgrade.service,loaded,inactive,dead, Daily apt upgrade and clean activities apt-daily.service,loaded,inactive,dead, Daily apt download activities auditd.service,not-found,inactive,dead, auditd.service auth-rpcgss-module.service,loaded,inactive,dead, Kernel Module supporting RPCSEC_GSS avahi-daemon.service,loaded,active,running, Avahi mDNS/DNS-SD Stack clamav-daemon.service,not-found,inactive,dead, clamav-daemon.service connman.service,not-found,inactive,dead, connman.service console-screen.service,not-found,inactive,dead, console-screen.service console-setup.service,loaded,active,exited, Set console font and keymap cron.service,loaded,active,running, Regular background program processing daemon cups-browsed.service,loaded,failed,failed, Make remote CUPS printers available locally cups.service,loaded,active,running, CUPS Scheduler dbus.service,loaded,active,running, D-Bus System Message Bus display-manager.service,not-found,inactive,dead, display-manager.service emergency.service,loaded,inactive,dead, Emergency Shell exim4.service,loaded,active,running, LSB: exim Mail Transport Agent getty-static.service,loaded,inactive,dead, getty on tty2-tty6 if dbus and logind are not available getty@tty1.service,loaded,active,running, Getty on tty1 greylist.service,not-found,inactive,dead, greylist.service gssproxy.service,not-found,inactive,dead, gssproxy.service ifup@ens18.service,loaded,active,exited, ifup for ens18 ifupdown-pre.service,loaded,active,exited, Helper to synchronize boot up for ifupdown influxdb.service,not-found,inactive,dead, influxdb.service iobroker.service,loaded,active,running, ioBroker Server irqbalance.service,loaded,active,running, irqbalance daemon kbd.service,not-found,inactive,dead, kbd.service keyboard-setup.service,loaded,active,exited, Set the console keyboard layout kmod-static-nodes.service,loaded,active,exited, Create list of required static device nodes for the current kernel logrotate.service,loaded,inactive,dead, Rotate log files man-db.service,loaded,inactive,dead, Daily man-db regeneration mariadb-server.service,not-found,inactive,dead, mariadb-server.service mysql-server.service,not-found,inactive,dead, mysql-server.service mysql.service,not-found,inactive,dead, mysql.service networking.service,loaded,active,exited, Raise network interfaces NetworkManager.service,not-found,inactive,dead, NetworkManager.service nfs-blkmap.service,not-found,inactive,dead, nfs-blkmap.service nfs-config.service,loaded,inactive,dead, Preprocess NFS configuration nfs-server.service,not-found,inactive,dead, nfs-server.service nfs-utils.service,loaded,inactive,dead, NFS server and client services ntp.service,loaded,active,running, Network Time Service plymouth-quit-wait.service,not-found,inactive,dead, plymouth-quit-wait.service plymouth-start.service,not-found,inactive,dead, plymouth-start.service postgresql.service,not-found,inactive,dead, postgresql.service rc-local.service,loaded,inactive,dead, /etc/rc.local Compatibility redis.service,not-found,inactive,dead, redis.service rescue.service,loaded,inactive,dead, Rescue Shell rpc-gssd.service,loaded,inactive,dead, RPC security service for NFS client and server rpc-svcgssd.service,loaded,inactive,dead, RPC security service for NFS server rpcbind.service,loaded,active,running, RPC bind portmap service rsync.service,loaded,inactive,dead, fast remote file copy program daemon rsyslog.service,loaded,active,running, System Logging Service spamassassin.service,not-found,inactive,dead, spamassassin.service ssh.service,loaded,active,running, OpenBSD Secure Shell server systemd-ask-password-console.service,loaded,inactive,dead, Dispatch Password Requests to Console systemd-ask-password-wall.service,loaded,inactive,dead, Forward Password Requests to Wall systemd-binfmt.service,loaded,inactive,dead, Set Up Additional Binary Formats systemd-fsck-root.service,loaded,inactive,dead, File System Check on Root Device systemd-fsckd.service,loaded,inactive,dead, File System Check Daemon to report status systemd-hwdb-update.service,loaded,inactive,dead, Rebuild Hardware Database systemd-initctl.service,loaded,inactive,dead, initctl Compatibility Daemon systemd-journal-flush.service,loaded,active,exited, Flush Journal to Persistent Storage systemd-journald.service,loaded,active,running, Journal Service systemd-logind.service,loaded,active,running, Login Service systemd-machine-id-commit.service,loaded,inactive,dead, Commit a transient machine-id on disk systemd-modules-load.service,loaded,active,exited, Load Kernel Modules systemd-networkd.service,loaded,inactive,dead, Network Service systemd-random-seed.service,loaded,active,exited, Load/Save Random Seed systemd-remount-fs.service,loaded,active,exited, Remount Root and Kernel File Systems systemd-sysctl.service,loaded,active,exited, Apply Kernel Variables systemd-sysusers.service,loaded,active,exited, Create System Users systemd-timesyncd.service,loaded,inactive,dead, Network Time Synchronization systemd-tmpfiles-clean.service,loaded,inactive,dead, Cleanup of Temporary Directories systemd-tmpfiles-setup-dev.service,loaded,active,exited, Create Static Device Nodes in /dev systemd-tmpfiles-setup.service,loaded,active,exited, Create Volatile Files and Directories systemd-udev-trigger.service,loaded,active,exited, udev Coldplug all Devices systemd-udevd.service,loaded,active,running, udev Kernel Device Manager systemd-update-done.service,not-found,inactive,dead, systemd-update-done.service systemd-update-utmp-runlevel.service,loaded,inactive,dead, Update UTMP about System Runlevel Changes systemd-update-utmp.service,loaded,active,exited, Update UTMP about System Boot/Shutdown systemd-user-sessions.service,loaded,active,exited, Permit User Sessions systemd-vconsole-setup.service,not-found,inactive,dead, systemd-vconsole-setup.service user-runtime-dir@1000.service,loaded,active,exited, User Runtime Directory /run/user/1000 user@1000.service,loaded,active,running, User Manager for UID 1000 2020-08-15 16:06:06.615 - debug: linux-control.0 (19029) [servicesInfo] NUC_VM (192.168.138.123:22): csvToJson result: [{"id":"apache2.service","load":"loaded","active":"active","running":"running","description":"The Apache HTTP Server"},{"id":"apparmor.service","load":"loaded","active":"active","running":"exited","description":"Load AppArmor profiles"},{"id":"apt-daily-upgrade.service","load":"loaded","active":"inactive","running":"dead","description":"Daily apt upgrade and clean activities"},{"id":"apt-daily.service","load":"loaded","active":"inactive","running":"dead","description":"Daily apt download activities"},{"id":"auditd.service","load":"not-found","active":"inactive","running":"dead","description":"auditd.service"},{"id":"auth-rpcgss-module.service","load":"loaded","active":"inactive","running":"dead","description":"Kernel Module supporting RPCSEC_GSS"},{"id":"avahi-daemon.service","load":"loaded","active":"active","running":"running","description":"Avahi mDNS/DNS-SD Stack"},{"id":"clamav-daemon.service","load":"not-found","active":"inactive","running":"dead","description":"clamav-daemon.service"},{"id":"connman.service","load":"not-found","active":"inactive","running":"dead","description":"connman.service"},{"id":"console-screen.service","load":"not-found","active":"inactive","running":"dead","description":"console-screen.service"},{"id":"console-setup.service","load":"loaded","active":"active","running":"exited","description":"Set console font and keymap"},{"id":"cron.service","load":"loaded","active":"active","running":"running","description":"Regular background program processing daemon"},{"id":"cups-browsed.service","load":"loaded","active":"failed","running":"failed","description":"Make remote CUPS printers available locally"},{"id":"cups.service","load":"loaded","active":"active","running":"running","description":"CUPS Scheduler"},{"id":"dbus.service","load":"loaded","active":"active","running":"running","description":"D-Bus System Message Bus"},{"id":"display-manager.service","load":"not-found","active":"inactive","running":"dead","description":"display-manager.service"},{"id":"emergency.service","load":"loaded","active":"inactive","running":"dead","description":"Emergency Shell"},{"id":"exim4.service","load":"loaded","active":"active","running":"running","description":"LSB: exim Mail Transport Agent"},{"id":"getty-static.service","load":"loaded","active":"inactive","running":"dead","description":"getty on tty2-tty6 if dbus and logind are not available"},{"id":"getty@tty1.service","load":"loaded","active":"active","running":"running","description":"Getty on tty1"},{"id":"greylist.service","load":"not-found","active":"inactive","running":"dead","description":"greylist.service"},{"id":"gssproxy.service","load":"not-found","active":"inactive","running":"dead","description":"gssproxy.service"},{"id":"ifup@ens18.service","load":"loaded","active":"active","running":"exited","description":"ifup for ens18"},{"id":"ifupdown-pre.service","load":"loaded","active":"active","running":"exited","description":"Helper to synchronize boot up for ifupdown"},{"id":"influxdb.service","load":"not-found","active":"inactive","running":"dead","description":"influxdb.service"},{"id":"iobroker.service","load":"loaded","active":"active","running":"running","description":"ioBroker Server"},{"id":"irqbalance.service","load":"loaded","active":"active","running":"running","description":"irqbalance daemon"},{"id":"kbd.service","load":"not-found","active":"inactive","running":"dead","description":"kbd.service"},{"id":"keyboard-setup.service","load":"loaded","active":"active","running":"exited","description":"Set the console keyboard layout"},{"id":"kmod-static-nodes.service","load":"loaded","active":"active","running":"exited","description":"Create list of required static device nodes for the current kernel"},{"id":"logrotate.service","load":"loaded","active":"inactive","running":"dead","description":"Rotate log files"},{"id":"man-db.service","load":"loaded","active":"inactive","running":"dead","description":"Daily man-db regeneration"},{"id":"mariadb-server.service","load":"not-found","active":"inactive","running":"dead","description":"mariadb-server.service"},{"id":"mysql-server.service","load":"not-found","active":"inactive","running":"dead","description":"mysql-server.service"},{"id":"mysql.service","load":"not-found","active":"inactive","running":"dead","description":"mysql.service"},{"id":"networking.service","load":"loaded","active":"active","running":"exited","description":"Raise network interfaces"},{"id":"NetworkManager.service","load":"not-found","active":"inactive","running":"dead","description":"NetworkManager.service"},{"id":"nfs-blkmap.service","load":"not-found","active":"inactive","running":"dead","description":"nfs-blkmap.service"},{"id":"nfs-config.service","load":"loaded","active":"inactive","running":"dead","description":"Preprocess NFS configuration"},{"id":"nfs-server.service","load":"not-found","active":"inactive","running":"dead","description":"nfs-server.service"},{"id":"nfs-utils.service","load":"loaded","active":"inactive","running":"dead","description":"NFS server and client services"},{"id":"ntp.service","load":"loaded","active":"active","running":"running","description":"Network Time Service"},{"id":"plymouth-quit-wait.service","load":"not-found","active":"inactive","running":"dead","description":"plymouth-quit-wait.service"},{"id":"plymouth-start.service","load":"not-found","active":"inactive","running":"dead","description":"plymouth-start.service"},{"id":"postgresql.service","load":"not-found","active":"inactive","running":"dead","description":"postgresql.service"},{"id":"rc-local.service","load":"loaded","active":"inactive","running":"dead","description":"/etc/rc.local Compatibility"},{"id":"redis.service","load":"not-found","active":"inactive","running":"dead","description":"redis.service"},{"id":"rescue.service","load":"loaded","active":"inactive","running":"dead","description":"Rescue Shell"},{"id":"rpc-gssd.service","load":"loaded","active":"inactive","running":"dead","description":"RPC security service for NFS client and server"},{"id":"rpc-svcgssd.service","load":"loaded","active":"inactive","running":"dead","description":"RPC security service for NFS server"},{"id":"rpcbind.service","load":"loaded","active":"active","running":"running","description":"RPC bind portmap service"},{"id":"rsync.service","load":"loaded","active":"inactive","running":"dead","description":"fast remote file copy program daemon"},{"id":"rsyslog.service","load":"loaded","active":"active","running":"running","description":"System Logging Service"},{"id":"spamassassin.service","load":"not-found","active":"inactive","running":"dead","description":"spamassassin.service"},{"id":"ssh.service","load":"loaded","active":"active","running":"running","description":"OpenBSD Secure Shell server"},{"id":"systemd-ask-password-console.service","load":"loaded","active":"inactive","running":"dead","description":"Dispatch Password Requests to Console"},{"id":"systemd-ask-password-wall.service","load":"loaded","active":"inactive","running":"dead","description":"Forward Password Requests to Wall"},{"id":"systemd-binfmt.service","load":"loaded","active":"inactive","running":"dead","description":"Set Up Additional Binary Formats"},{"id":"systemd-fsck-root.service","load":"loaded","active":"inactive","running":"dead","description":"File System Check on Root Device"},{"id":"systemd-fsckd.service","load":"loaded","active":"inactive","running":"dead","description":"File System Check Daemon to report status"},{"id":"systemd-hwdb-update.service","load":"loaded","active":"inactive","running":"dead","description":"Rebuild Hardware Database"},{"id":"systemd-initctl.service","load":"loaded","active":"inactive","running":"dead","description":"initctl Compatibility Daemon"},{"id":"systemd-journal-flush.service","load":"loaded","active":"active","running":"exited","description":"Flush Journal to Persistent Storage"},{"id":"systemd-journald.service","load":"loaded","active":"active","running":"running","description":"Journal Service"},{"id":"systemd-logind.service","load":"loaded","active":"active","running":"running","description":"Login Service"},{"id":"systemd-machine-id-commit.service","load":"loaded","active":"inactive","running":"dead","description":"Commit a transient machine-id on disk"},{"id":"systemd-modules-load.service","load":"loaded","active":"active","running":"exited","description":"Load Kernel Modules"},{"id":"systemd-networkd.service","load":"loaded","active":"inactive","running":"dead","description":"Network Service"},{"id":"systemd-random-seed.service","load":"loaded","active":"active","running":"exited","description":"Load/Save Random Seed"},{"id":"systemd-remount-fs.service","load":"loaded","active":"active","running":"exited","description":"Remount Root and Kernel File Systems"},{"id":"systemd-sysctl.service","load":"loaded","active":"active","running":"exited","description":"Apply Kernel Variables"},{"id":"systemd-sysusers.service","load":"loaded","active":"active","running":"exited","description":"Create System Users"},{"id":"systemd-timesyncd.service","load":"loaded","active":"inactive","running":"dead","description":"Network Time Synchronization"},{"id":"systemd-tmpfiles-clean.service","load":"loaded","active":"inactive","running":"dead","description":"Cleanup of Temporary Directories"},{"id":"systemd-tmpfiles-setup-dev.service","load":"loaded","active":"active","running":"exited","description":"Create Static Device Nodes in /dev"},{"id":"systemd-tmpfiles-setup.service","load":"loaded","active":"active","running":"exited","description":"Create Volatile Files and Directories"},{"id":"systemd-udev-trigger.service","load":"loaded","active":"active","running":"exited","description":"udev Coldplug all Devices"},{"id":"systemd-udevd.service","load":"loaded","active":"active","running":"running","description":"udev Kernel Device Manager"},{"id":"systemd-update-done.service","load":"not-found","active":"inactive","running":"dead","description":"systemd-update-done.service"},{"id":"systemd-update-utmp-runlevel.service","load":"loaded","active":"inactive","running":"dead","description":"Update UTMP about System Runlevel Changes"},{"id":"systemd-update-utmp.service","load":"loaded","active":"active","running":"exited","description":"Update UTMP about System Boot/Shutdown"},{"id":"systemd-user-sessions.service","load":"loaded","active":"active","running":"exited","description":"Permit User Sessions"},{"id":"systemd-vconsole-setup.service","load":"not-found","active":"inactive","running":"dead","description":"systemd-vconsole-setup.service"},{"id":"user-runtime-dir@1000.service","load":"loaded","active":"active","running":"exited","description":"User Runtime Directory /run/user/1000"},{"id":"user@1000.service","load":"loaded","active":"active","running":"running","description":"User Manager for UID 1000"}] 2020-08-15 16:06:06.984 - debug: linux-control.0 (19029) [needrestart] NUC_VM (192.168.138.123:22): no datapoints selected -> removing existing datapoints 2020-08-15 16:06:07.002 - debug: linux-control.0 (19029) [folderSizes] NUC_VM (192.168.138.123:22): send command: 'sudo du -sk /opt/iobroker/iobroker-data/history | awk '{ print $1 /1024 }'' 2020-08-15 16:06:07.316 - debug: linux-control.0 (19029) [folderSizes] NUC_VM (192.168.138.123:22): response stdout: [sudo] Passwort für pi: 13499.5 2020-08-15 16:06:07.319 - debug: linux-control.0 (19029) [folderSizes] NUC_VM (192.168.138.123:22): NUC_VM.folders.history.size: NaN MB 2020-08-15 16:06:07.369 - debug: linux-control.0 (19029) [folderSizes] NUC_VM (192.168.138.123:22): send command: 'sudo find /opt/iobroker/iobroker-data/history -name "*" | wc -l' 2020-08-15 16:06:07.578 - debug: linux-control.0 (19029) [folderSizes] NUC_VM (192.168.138.123:22): response stdout: [sudo] Passwort für pi: 112349 2020-08-15 16:06:07.581 - debug: linux-control.0 (19029) [folderSizes] NUC_VM (192.168.138.123:22): NUC_VM.folders.history.files: NaN Dateien 2020-08-15 16:06:07.629 - debug: linux-control.0 (19029) [folderSizes] NUC_VM (192.168.138.123:22): send command: 'tmp=$(sudo find /opt/iobroker/iobroker-data/history -name "*" -type f -exec stat -c "%Y %n" -- {} \; | sort -nr | head -n1 | awk '{print $2}') && date +%s -r $tmp' 2020-08-15 16:06:17.713 - info: web.0 (22824) ==>Connected system.user.admin from ::ffff:192.168.138.145 2020-08-15 16:06:19.906 - info: web.0 (22824) <==Disconnect system.user.admin from ::ffff:192.168.138.145 2020-08-15 16:08:25.229 - debug: linux-control.0 (19029) [folderSizes] NUC_VM (192.168.138.123:22): response stdout: [sudo] Passwort für pi: 1597500492 2020-08-15 16:08:25.232 - debug: linux-control.0 (19029) [folderSizes] NUC_VM (192.168.138.123:22): NUC_VM.folders.history.lastChange: NaN -> 2020-08-15 16:08:25.279 - debug: linux-control.0 (19029) [userCommand] NUC_VM (192.168.138.123:22, id: root, description: ): send command: 'df / | grep / | awk '{ print $5}' | sed 's/%//g'' 2020-08-15 16:08:25.291 - debug: linux-control.0 (19029) [userCommand] NUC_VM (192.168.138.123:22, id: root, description: ): response stdout: 55 2020-08-15 16:08:25.314 - debug: linux-control.0 (19029) [userCommand] NUC_VM (192.168.138.123:22, id: ip, description: ): send command: 'hostname -I | cut -d' ' -f1' 2020-08-15 16:08:25.323 - debug: linux-control.0 (19029) [userCommand] NUC_VM (192.168.138.123:22, id: ip, description: ): response stdout: 192.168.138.123 2020-08-15 16:08:25.371 - debug: linux-control.0 (19029) [userCommand] NUC_VM (192.168.138.123:22): datapoint-id: 'cpu-temp', description: '' -> is not enabled! 2020-08-15 16:08:25.371 - debug: linux-control.0 (19029) [userCommand] NUC_VM (192.168.138.123:22, id: Ordner, description: ): send command: 'du -c /opt/iobroker/iobroker-data/history | tail -1 | awk '{printf $1MB}'' 2020-08-15 16:08:25.671 - debug: linux-control.0 (19029) [userCommand] NUC_VM (192.168.138.123:22, id: Ordner, description: ): response stdout: 13823576 2020-08-15 16:08:25.676 - info: linux-control.0 (19029) successful received data from NUC_VM (192.168.138.123:22) 2020-08-15 16:08:25.676 - info: linux-control.0 (19029) getting data from Tinker (192.168.138.74:22) 2020-08-15 16:08:25.742 - debug: linux-control.0 (19029) [getConnection] Host 'Tinker' (192.168.138.74:22): using sudo for authentification 2020-08-15 16:08:25.970 - debug: linux-control.0 (19029) [distributionInfo] Tinker (192.168.138.74:22): send command: 'cat /etc/os-release' 2020-08-15 16:08:26.280 - debug: linux-control.0 (19029) [distributionInfo] Tinker (192.168.138.74:22): response stdout: NAME="Ubuntu" VERSION="18.04.4 LTS (Bionic Beaver)" ID=ubuntu ID_LIKE=debian PRETTY_NAME="Ubuntu 18.04.4 LTS" VERSION_ID="18.04" HOME_URL="https://www.ubuntu.com/" SUPPORT_URL="https://help.ubuntu.com/" BUG_REPORT_URL="https://bugs.launchpad.net/ubuntu/" PRIVACY_POLICY_URL="https://www.ubuntu.com/legal/terms-and-policies/privacy-policy" VERSION_CODENAME=bionic UBUNTU_CODENAME=bionic 2020-08-15 16:08:26.285 - debug: linux-control.0 (19029) [distributionInfo] Tinker (192.168.138.74:22): csvToJson result: [{"prop":"NAME","val":"Ubuntu"},{"prop":"VERSION","val":"18.04.4 LTS (Bionic Beaver)"},{"prop":"ID","val":"ubuntu"},{"prop":"ID_LIKE","val":"debian"},{"prop":"PRETTY_NAME","val":"Ubuntu 18.04.4 LTS"},{"prop":"VERSION_ID","val":"18.04"},{"prop":"HOME_URL","val":"https://www.ubuntu.com/"},{"prop":"SUPPORT_URL","val":"https://help.ubuntu.com/"},{"prop":"BUG_REPORT_URL","val":"https://bugs.launchpad.net/ubuntu/"},{"prop":"PRIVACY_POLICY_URL","val":"https://www.ubuntu.com/legal/terms-and-policies/privacy-policy"},{"prop":"VERSION_CODENAME","val":"bionic"},{"prop":"UBUNTU_CODENAME","val":"bionic"}] 2020-08-15 16:08:26.362 - debug: linux-control.0 (19029) [cmdAptUpdate] Tinker (192.168.138.74:22): no datapoints selected -> removing existing datapoints 2020-08-15 16:08:26.369 - debug: linux-control.0 (19029) [servicesInfo] Tinker (192.168.138.74:22): send command: 'systemctl list-units --type service --all --no-legend | awk '{out=""; for(i=5;i<=NF;i++){out=out" "$i}; print $1","$2","$3","$4","out}'' 2020-08-15 16:08:26.391 - debug: linux-control.0 (19029) [servicesInfo] Tinker (192.168.138.74:22): response stdout: alsa-restore.service,loaded,active,exited, Save/Restore Sound Card State alsa-state.service,loaded,inactive,dead, Manage Sound Card State (restore and store) apparmor.service,not-found,inactive,dead, apparmor.service apt-daily-upgrade.service,loaded,inactive,dead, Daily apt upgrade and clean activities apt-daily.service,loaded,inactive,dead, Daily apt download activities armbian-firstrun-config.service,loaded,inactive,dead, Armbian first run optional user configuration armbian-hardware-monitor.service,loaded,active,exited, Armbian hardware monitoring armbian-hardware-optimize.service,loaded,active,exited, Armbian hardware optimization armbian-ramlog.service,loaded,active,exited, Armbian memory supported logging armbian-zram-config.service,loaded,active,exited, Armbian ZRAM config armian-ramlog.service,not-found,inactive,dead, armian-ramlog.service auditd.service,not-found,inactive,dead, auditd.service bluetooth.service,loaded,active,running, Bluetooth service chrony.service,loaded,active,running, chrony, an NTP client/server connman.service,not-found,inactive,dead, connman.service console-screen.service,not-found,inactive,dead, console-screen.service console-setup.service,loaded,active,exited, Set console font and keymap cpufrequtils.service,loaded,active,exited, LSB: set CPUFreq kernel parameters cron.service,loaded,active,running, Regular background program processing daemon dbus.service,loaded,active,running, D-Bus System Message Bus display-manager.service,not-found,inactive,dead, display-manager.service emergency.service,loaded,inactive,dead, Emergency Shell fake-hwclock.service,loaded,active,exited, Restore / save the current clock fstrim.service,loaded,inactive,dead, Discard unused blocks getty-static.service,loaded,inactive,dead, getty on tty2-tty6 if dbus and logind are not available getty@tty1.service,loaded,active,running, Getty on tty1 haveged.service,loaded,active,running, Entropy daemon using the HAVEGE algorithm hostapd.service,loaded,active,exited, LSB: Advanced IEEE 802.11 management daemon influxdb.service,not-found,inactive,dead, influxdb.service iobroker.service,loaded,active,running, ioBroker Server kbd.service,not-found,inactive,dead, kbd.service keyboard-setup.service,loaded,active,exited, Set the console keyboard layout kmod-static-nodes.service,loaded,active,exited, Create list of required static device nodes for the current kernel loadcpufreq.service,loaded,active,exited, LSB: Load kernel modules needed to enable cpufreq scaling mariadb-server.service,not-found,inactive,dead, mariadb-server.service motd-news.service,loaded,inactive,dead, Message of the Day mountkernfs.service,masked,inactive,dead, mountkernfs.service mysql-server.service,not-found,inactive,dead, mysql-server.service networkd-dispatcher.service,loaded,active,running, Dispatcher daemon for systemd-networkd networking.service,loaded,active,exited, Raise network interfaces NetworkManager-wait-online.service,loaded,active,exited, Network Manager Wait Online NetworkManager.service,loaded,active,running, Network Manager ondemand.service,masked,inactive,dead, ondemand.service openntpd.service,not-found,inactive,dead, openntpd.service plymouth-quit-wait.service,not-found,inactive,dead, plymouth-quit-wait.service plymouth-start.service,not-found,inactive,dead, plymouth-start.service polkit.service,loaded,active,running, Authorization Manager rc-local.service,loaded,active,exited, /etc/rc.local Compatibility redis.service,not-found,inactive,dead, redis.service rescue.service,loaded,inactive,dead, Rescue Shell resolvconf-pull-resolved.service,loaded,inactive,dead, resolvconf-pull-resolved.service resolvconf.service,loaded,active,exited, Nameserver information manager rng-tools.service,loaded,active,running, rng-tools.service rsync.service,loaded,inactive,dead, fast remote file copy program daemon rsyslog.service,loaded,active,running, System Logging Service serial-getty@ttyS2.service,loaded,active,running, Serial Getty on ttyS2 setvtrgb.service,loaded,active,exited, Set console scheme ssh.service,loaded,active,running, OpenBSD Secure Shell server sysfsutils.service,loaded,active,exited, LSB: Set sysfs variables from /etc/sysfs.conf sysstat.service,loaded,active,exited, Resets System Activity Data Collector systemd-ask-password-console.service,loaded,inactive,dead, Dispatch Password Requests to Console systemd-ask-password-wall.service,loaded,inactive,dead, Forward Password Requests to Wall systemd-binfmt.service,loaded,inactive,dead, Set Up Additional Binary Formats systemd-fsck-root.service,loaded,inactive,dead, File System Check on Root Device systemd-fsckd.service,loaded,inactive,dead, File System Check Daemon to report status systemd-hwdb-update.service,loaded,inactive,dead, Rebuild Hardware Database systemd-initctl.service,loaded,inactive,dead, /dev/initctl Compatibility Daemon systemd-journal-flush.service,loaded,active,exited, Flush Journal to Persistent Storage systemd-journald.service,loaded,active,running, Journal Service systemd-logind.service,loaded,active,running, Login Service systemd-machine-id-commit.service,loaded,inactive,dead, Commit a transient machine-id on disk systemd-modules-load.service,loaded,active,exited, Load Kernel Modules systemd-networkd.service,loaded,inactive,dead, Network Service systemd-random-seed.service,loaded,active,exited, Load/Save Random Seed systemd-remount-fs.service,loaded,active,exited, Remount Root and Kernel File Systems systemd-resolved.service,loaded,active,running, Network Name Resolution systemd-rfkill.service,loaded,inactive,dead, Load/Save RF Kill Switch Status systemd-sysctl.service,loaded,active,exited, Apply Kernel Variables systemd-sysusers.service,not-found,inactive,dead, systemd-sysusers.service systemd-timesyncd.service,loaded,inactive,dead, Network Time Synchronization systemd-tmpfiles-clean.service,loaded,inactive,dead, Cleanup of Temporary Directories systemd-tmpfiles-setup-dev.service,loaded,active,exited, Create Static Device Nodes in /dev systemd-tmpfiles-setup.service,loaded,active,exited, Create Volatile Files and Directories systemd-udev-trigger.service,loaded,active,exited, udev Coldplug all Devices systemd-udevd.service,loaded,active,running, udev Kernel Device Manager systemd-update-done.service,not-found,inactive,dead, systemd-update-done.service systemd-update-utmp-runlevel.service,loaded,inactive,dead, Update UTMP about System Runlevel Changes systemd-update-utmp.service,loaded,active,exited, Update UTMP about System Boot/Shutdown systemd-user-sessions.service,loaded,active,exited, Permit User Sessions systemd-vconsole-setup.service,not-found,inactive,dead, systemd-vconsole-setup.service tinker-bluetooth.service,loaded,active,running, Realtek H5 bluetooth support unattended-upgrades.service,loaded,active,running, Unattended Upgrades Shutdown user@1002.service,loaded,active,running, User Manager for UID 1002 wpa_supplicant.service,loaded,active,running, WPA supplicant 2020-08-15 16:08:26.403 - debug: linux-control.0 (19029) [servicesInfo] Tinker (192.168.138.74:22): csvToJson result: [{"id":"alsa-restore.service","load":"loaded","active":"active","running":"exited","description":"Save/Restore Sound Card State"},{"id":"alsa-state.service","load":"loaded","active":"inactive","running":"dead","description":"Manage Sound Card State (restore and store)"},{"id":"apparmor.service","load":"not-found","active":"inactive","running":"dead","description":"apparmor.service"},{"id":"apt-daily-upgrade.service","load":"loaded","active":"inactive","running":"dead","description":"Daily apt upgrade and clean activities"},{"id":"apt-daily.service","load":"loaded","active":"inactive","running":"dead","description":"Daily apt download activities"},{"id":"armbian-firstrun-config.service","load":"loaded","active":"inactive","running":"dead","description":"Armbian first run optional user configuration"},{"id":"armbian-hardware-monitor.service","load":"loaded","active":"active","running":"exited","description":"Armbian hardware monitoring"},{"id":"armbian-hardware-optimize.service","load":"loaded","active":"active","running":"exited","description":"Armbian hardware optimization"},{"id":"armbian-ramlog.service","load":"loaded","active":"active","running":"exited","description":"Armbian memory supported logging"},{"id":"armbian-zram-config.service","load":"loaded","active":"active","running":"exited","description":"Armbian ZRAM config"},{"id":"armian-ramlog.service","load":"not-found","active":"inactive","running":"dead","description":"armian-ramlog.service"},{"id":"auditd.service","load":"not-found","active":"inactive","running":"dead","description":"auditd.service"},{"id":"bluetooth.service","load":"loaded","active":"active","running":"running","description":"Bluetooth service"},{"id":"chrony.service","load":"loaded","active":"active","running":"running","description":"chrony","field6":"an NTP client/server"},{"id":"connman.service","load":"not-found","active":"inactive","running":"dead","description":"connman.service"},{"id":"console-screen.service","load":"not-found","active":"inactive","running":"dead","description":"console-screen.service"},{"id":"console-setup.service","load":"loaded","active":"active","running":"exited","description":"Set console font and keymap"},{"id":"cpufrequtils.service","load":"loaded","active":"active","running":"exited","description":"LSB: set CPUFreq kernel parameters"},{"id":"cron.service","load":"loaded","active":"active","running":"running","description":"Regular background program processing daemon"},{"id":"dbus.service","load":"loaded","active":"active","running":"running","description":"D-Bus System Message Bus"},{"id":"display-manager.service","load":"not-found","active":"inactive","running":"dead","description":"display-manager.service"},{"id":"emergency.service","load":"loaded","active":"inactive","running":"dead","description":"Emergency Shell"},{"id":"fake-hwclock.service","load":"loaded","active":"active","running":"exited","description":"Restore / save the current clock"},{"id":"fstrim.service","load":"loaded","active":"inactive","running":"dead","description":"Discard unused blocks"},{"id":"getty-static.service","load":"loaded","active":"inactive","running":"dead","description":"getty on tty2-tty6 if dbus and logind are not available"},{"id":"getty@tty1.service","load":"loaded","active":"active","running":"running","description":"Getty on tty1"},{"id":"haveged.service","load":"loaded","active":"active","running":"running","description":"Entropy daemon using the HAVEGE algorithm"},{"id":"hostapd.service","load":"loaded","active":"active","running":"exited","description":"LSB: Advanced IEEE 802.11 management daemon"},{"id":"influxdb.service","load":"not-found","active":"inactive","running":"dead","description":"influxdb.service"},{"id":"iobroker.service","load":"loaded","active":"active","running":"running","description":"ioBroker Server"},{"id":"kbd.service","load":"not-found","active":"inactive","running":"dead","description":"kbd.service"},{"id":"keyboard-setup.service","load":"loaded","active":"active","running":"exited","description":"Set the console keyboard layout"},{"id":"kmod-static-nodes.service","load":"loaded","active":"active","running":"exited","description":"Create list of required static device nodes for the current kernel"},{"id":"loadcpufreq.service","load":"loaded","active":"active","running":"exited","description":"LSB: Load kernel modules needed to enable cpufreq scaling"},{"id":"mariadb-server.service","load":"not-found","active":"inactive","running":"dead","description":"mariadb-server.service"},{"id":"motd-news.service","load":"loaded","active":"inactive","running":"dead","description":"Message of the Day"},{"id":"mountkernfs.service","load":"masked","active":"inactive","running":"dead","description":"mountkernfs.service"},{"id":"mysql-server.service","load":"not-found","active":"inactive","running":"dead","description":"mysql-server.service"},{"id":"networkd-dispatcher.service","load":"loaded","active":"active","running":"running","description":"Dispatcher daemon for systemd-networkd"},{"id":"networking.service","load":"loaded","active":"active","running":"exited","description":"Raise network interfaces"},{"id":"NetworkManager-wait-online.service","load":"loaded","active":"active","running":"exited","description":"Network Manager Wait Online"},{"id":"NetworkManager.service","load":"loaded","active":"active","running":"running","description":"Network Manager"},{"id":"ondemand.service","load":"masked","active":"inactive","running":"dead","description":"ondemand.service"},{"id":"openntpd.service","load":"not-found","active":"inactive","running":"dead","description":"openntpd.service"},{"id":"plymouth-quit-wait.service","load":"not-found","active":"inactive","running":"dead","description":"plymouth-quit-wait.service"},{"id":"plymouth-start.service","load":"not-found","active":"inactive","running":"dead","description":"plymouth-start.service"},{"id":"polkit.service","load":"loaded","active":"active","running":"running","description":"Authorization Manager"},{"id":"rc-local.service","load":"loaded","active":"active","running":"exited","description":"/etc/rc.local Compatibility"},{"id":"redis.service","load":"not-found","active":"inactive","running":"dead","description":"redis.service"},{"id":"rescue.service","load":"loaded","active":"inactive","running":"dead","description":"Rescue Shell"},{"id":"resolvconf-pull-resolved.service","load":"loaded","active":"inactive","running":"dead","description":"resolvconf-pull-resolved.service"},{"id":"resolvconf.service","load":"loaded","active":"active","running":"exited","description":"Nameserver information manager"},{"id":"rng-tools.service","load":"loaded","active":"active","running":"running","description":"rng-tools.service"},{"id":"rsync.service","load":"loaded","active":"inactive","running":"dead","description":"fast remote file copy program daemon"},{"id":"rsyslog.service","load":"loaded","active":"active","running":"running","description":"System Logging Service"},{"id":"serial-getty@ttyS2.service","load":"loaded","active":"active","running":"running","description":"Serial Getty on ttyS2"},{"id":"setvtrgb.service","load":"loaded","active":"active","running":"exited","description":"Set console scheme"},{"id":"ssh.service","load":"loaded","active":"active","running":"running","description":"OpenBSD Secure Shell server"},{"id":"sysfsutils.service","load":"loaded","active":"active","running":"exited","description":"LSB: Set sysfs variables from /etc/sysfs.conf"},{"id":"sysstat.service","load":"loaded","active":"active","running":"exited","description":"Resets System Activity Data Collector"},{"id":"systemd-ask-password-console.service","load":"loaded","active":"inactive","running":"dead","description":"Dispatch Password Requests to Console"},{"id":"systemd-ask-password-wall.service","load":"loaded","active":"inactive","running":"dead","description":"Forward Password Requests to Wall"},{"id":"systemd-binfmt.service","load":"loaded","active":"inactive","running":"dead","description":"Set Up Additional Binary Formats"},{"id":"systemd-fsck-root.service","load":"loaded","active":"inactive","running":"dead","description":"File System Check on Root Device"},{"id":"systemd-fsckd.service","load":"loaded","active":"inactive","running":"dead","description":"File System Check Daemon to report status"},{"id":"systemd-hwdb-update.service","load":"loaded","active":"inactive","running":"dead","description":"Rebuild Hardware Database"},{"id":"systemd-initctl.service","load":"loaded","active":"inactive","running":"dead","description":"/dev/initctl Compatibility Daemon"},{"id":"systemd-journal-flush.service","load":"loaded","active":"active","running":"exited","description":"Flush Journal to Persistent Storage"},{"id":"systemd-journald.service","load":"loaded","active":"active","running":"running","description":"Journal Service"},{"id":"systemd-logind.service","load":"loaded","active":"active","running":"running","description":"Login Service"},{"id":"systemd-machine-id-commit.service","load":"loaded","active":"inactive","running":"dead","description":"Commit a transient machine-id on disk"},{"id":"systemd-modules-load.service","load":"loaded","active":"active","running":"exited","description":"Load Kernel Modules"},{"id":"systemd-networkd.service","load":"loaded","active":"inactive","running":"dead","description":"Network Service"},{"id":"systemd-random-seed.service","load":"loaded","active":"active","running":"exited","description":"Load/Save Random Seed"},{"id":"systemd-remount-fs.service","load":"loaded","active":"active","running":"exited","description":"Remount Root and Kernel File Systems"},{"id":"systemd-resolved.service","load":"loaded","active":"active","running":"running","description":"Network Name Resolution"},{"id":"systemd-rfkill.service","load":"loaded","active":"inactive","running":"dead","description":"Load/Save RF Kill Switch Status"},{"id":"systemd-sysctl.service","load":"loaded","active":"active","running":"exited","description":"Apply Kernel Variables"},{"id":"systemd-sysusers.service","load":"not-found","active":"inactive","running":"dead","description":"systemd-sysusers.service"},{"id":"systemd-timesyncd.service","load":"loaded","active":"inactive","running":"dead","description":"Network Time Synchronization"},{"id":"systemd-tmpfiles-clean.service","load":"loaded","active":"inactive","running":"dead","description":"Cleanup of Temporary Directories"},{"id":"systemd-tmpfiles-setup-dev.service","load":"loaded","active":"active","running":"exited","description":"Create Static Device Nodes in /dev"},{"id":"systemd-tmpfiles-setup.service","load":"loaded","active":"active","running":"exited","description":"Create Volatile Files and Directories"},{"id":"systemd-udev-trigger.service","load":"loaded","active":"active","running":"exited","description":"udev Coldplug all Devices"},{"id":"systemd-udevd.service","load":"loaded","active":"active","running":"running","description":"udev Kernel Device Manager"},{"id":"systemd-update-done.service","load":"not-found","active":"inactive","running":"dead","description":"systemd-update-done.service"},{"id":"systemd-update-utmp-runlevel.service","load":"loaded","active":"inactive","running":"dead","description":"Update UTMP about System Runlevel Changes"},{"id":"systemd-update-utmp.service","load":"loaded","active":"active","running":"exited","description":"Update UTMP about System Boot/Shutdown"},{"id":"systemd-user-sessions.service","load":"loaded","active":"active","running":"exited","description":"Permit User Sessions"},{"id":"systemd-vconsole-setup.service","load":"not-found","active":"inactive","running":"dead","description":"systemd-vconsole-setup.service"},{"id":"tinker-bluetooth.service","load":"loaded","active":"active","running":"running","description":"Realtek H5 bluetooth support"},{"id":"unattended-upgrades.service","load":"loaded","active":"active","running":"running","description":"Unattended Upgrades Shutdown"},{"id":"user@1002.service","load":"loaded","active":"active","running":"running","description":"User Manager for UID 1002"},{"id":"wpa_supplicant.service","load":"loaded","active":"active","running":"running","description":"WPA supplicant"}] 2020-08-15 16:08:26.816 - debug: linux-control.0 (19029) [needrestart] Tinker (192.168.138.74:22): no datapoints selected -> removing existing datapoints 2020-08-15 16:08:26.837 - debug: linux-control.0 (19029) [folderSizes] Tinker (192.168.138.74:22): send command: 'sudo du -sk /opt/iobroker/iobroker-data | awk '{ print $1 /1024 }'' 2020-08-15 16:08:26.904 - debug: linux-control.0 (19029) [folderSizes] Tinker (192.168.138.74:22): response stdout: Sorry, user pi is not allowed to execute '/usr/bin/du -sk /opt/iobroker/iobroker-data' as root on localhost. 2020-08-15 16:08:26.906 - debug: linux-control.0 (19029) [folderSizes] Tinker (192.168.138.74:22): Tinker.folders.iobroker.size: NaN MB 2020-08-15 16:08:26.948 - debug: linux-control.0 (19029) [folderSizes] Tinker (192.168.138.74:22): send command: 'sudo find /opt/iobroker/iobroker-data -name "*" | wc -l' 2020-08-15 16:08:27.154 - debug: linux-control.0 (19029) [folderSizes] Tinker (192.168.138.74:22): response stdout: Sorry, user pi is not allowed to execute '/usr/bin/find /opt/iobroker/iobroker-data -name *' as root on localhost. 0 2020-08-15 16:08:27.157 - debug: linux-control.0 (19029) [folderSizes] Tinker (192.168.138.74:22): Tinker.folders.iobroker.files: NaN Dateien 2020-08-15 16:08:27.208 - debug: linux-control.0 (19029) [folderSizes] Tinker (192.168.138.74:22): send command: 'tmp=$(sudo find /opt/iobroker/iobroker-data -name "*" -type f -exec stat -c "%Y %n" -- {} \; | sort -nr | head -n1 | awk '{print $2}') && date +%s -r $tmp' 2020-08-15 16:08:27.315 - debug: linux-control.0 (19029) [folderSizes] Tinker (192.168.138.74:22): response stdout: Sorry, user pi is not allowed to execute '/usr/bin/find /opt/iobroker/iobroker-data -name * -type f -exec stat -c %Y %n -- {} ;' as root on localhost. date: option requires an argument -- 'r' Try 'date --help' for more information. 2020-08-15 16:08:27.318 - debug: linux-control.0 (19029) [folderSizes] Tinker (192.168.138.74:22): Tinker.folders.iobroker.lastChange: NaN -> 2020-08-15 16:08:27.369 - debug: linux-control.0 (19029) [userCommand] Tinker (192.168.138.74:22, id: root, description: ): send command: 'df / | grep / | awk '{ print $5}' | sed 's/%//g'' 2020-08-15 16:08:27.415 - debug: linux-control.0 (19029) [userCommand] Tinker (192.168.138.74:22, id: root, description: ): response stdout: 5 2020-08-15 16:08:27.423 - debug: linux-control.0 (19029) [userCommand] Tinker (192.168.138.74:22, id: ip, description: ): send command: 'hostname -I | cut -d' ' -f1' 2020-08-15 16:08:27.467 - debug: linux-control.0 (19029) [userCommand] Tinker (192.168.138.74:22, id: ip, description: ): response stdout: 192.168.138.74 2020-08-15 16:08:27.476 - debug: linux-control.0 (19029) [userCommand] Tinker (192.168.138.74:22, id: cpu-temp, description: ): send command: 'cat /sys/devices/virtual/thermal/thermal_zone0/temp | awk '{print substr($1, length($0)-5,3)}'' 2020-08-15 16:08:27.519 - debug: linux-control.0 (19029) [userCommand] Tinker (192.168.138.74:22, id: cpu-temp, description: ): response stdout: 46 2020-08-15 16:08:27.527 - info: linux-control.0 (19029) successful received data from Tinker (192.168.138.74:22)scheint ein seltsames Problem mit dem Passwort bei sudo zu sein.
Beim Raspi kann man auch auf der Konsole Befehle mit sudo ohne weitere Passworteingabe durchführen. das geht weder beim Tinker (Armbian) noch beim der VM (Debian)seltsamerweise funktioniert es aber bei "meine Befehle".
bei der NUC_VM habe ich den gleichen Befehl (du -c /opt/iobroker/iobroker-data/history | tail -1 | awk '{printf $1MB}') nochmals unter "eigene Befehle" ausgeführt:
da klappt es:
der Installationsfixer: curl -fsL https://iobroker.net/fix.sh | bash - -
@Scrounger sagte in Test Adapter Linux Control v0.x.x:
Version 0.2.5 bei github verügbar, bitte darauf updaten.
@Homoran
Adapter auf debug stellen und dann bitte das log posten.erledigt: aber noch mit der alten Version:
2020-08-15 16:04:21.514 - info: host.raspberrypi Do not restart adapter system.adapter.linux-control.0 because desired by instance 2020-08-15 16:04:22.317 - debug: linux-control.0 (19029) Redis Objects: Use Redis connection: 127.0.0.1:9001 2020-08-15 16:04:22.356 - debug: linux-control.0 (19029) Objects client ready ... initialize now 2020-08-15 16:04:22.370 - debug: linux-control.0 (19029) Objects create System PubSub Client 2020-08-15 16:04:22.371 - debug: linux-control.0 (19029) Objects create User PubSub Client 2020-08-15 16:04:22.372 - debug: linux-control.0 (19029) Objects client initialize lua scripts 2020-08-15 16:04:22.393 - debug: linux-control.0 (19029) Objects connected to redis: 127.0.0.1:9001 2020-08-15 16:04:22.402 - debug: linux-control.0 (19029) objectDB connected 2020-08-15 16:04:22.404 - debug: linux-control.0 (19029) Redis States: Use Redis connection: 127.0.0.1:9000 2020-08-15 16:04:22.416 - debug: linux-control.0 (19029) States create User PubSub Client 2020-08-15 16:04:22.419 - debug: linux-control.0 (19029) States create System PubSub Client 2020-08-15 16:04:22.438 - debug: linux-control.0 (19029) States connected to redis: 127.0.0.1:9000 2020-08-15 16:04:22.439 - debug: linux-control.0 (19029) statesDB connected 2020-08-15 16:04:24.577 - debug: linux-control.0 (19029) Plugin sentry Initialize Plugin (enabled=true) 2020-08-15 16:04:24.740 - info: linux-control.0 (19029) starting. Version 0.2.4 in /opt/iobroker/node_modules/iobroker.linux-control, node: v10.21.0, js-controller: 3.1.4 2020-08-15 16:04:24.814 - info: linux-control.0 (19029) getting data from RasPi4 (192.168.138.139:22) 2020-08-15 16:04:24.857 - debug: linux-control.0 (19029) [getConnection] Host 'RasPi4' (192.168.138.139:22): using sudo for authentification 2020-08-15 16:04:25.048 - debug: linux-control.0 (19029) [distributionInfo] RasPi4 (192.168.138.139:22): send command: 'cat /etc/os-release' 2020-08-15 16:04:25.389 - debug: linux-control.0 (19029) [distributionInfo] RasPi4 (192.168.138.139:22): response stdout: PRETTY_NAME="Raspbian GNU/Linux 10 (buster)" NAME="Raspbian GNU/Linux" VERSION_ID="10" VERSION="10 (buster)" VERSION_CODENAME=buster ID=raspbian ID_LIKE=debian HOME_URL="http://www.raspbian.org/" SUPPORT_URL="http://www.raspbian.org/RaspbianForums" BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs" 2020-08-15 16:04:25.413 - debug: linux-control.0 (19029) [distributionInfo] RasPi4 (192.168.138.139:22): csvToJson result: [{"prop":"PRETTY_NAME","val":"Raspbian GNU/Linux 10 (buster)"},{"prop":"NAME","val":"Raspbian GNU/Linux"},{"prop":"VERSION_ID","val":"10"},{"prop":"VERSION","val":"10 (buster)"},{"prop":"VERSION_CODENAME","val":"buster"},{"prop":"ID","val":"raspbian"},{"prop":"ID_LIKE","val":"debian"},{"prop":"HOME_URL","val":"http://www.raspbian.org/"},{"prop":"SUPPORT_URL","val":"http://www.raspbian.org/RaspbianForums"},{"prop":"BUG_REPORT_URL","val":"http://www.raspbian.org/RaspbianBugs"}] 2020-08-15 16:04:25.526 - debug: linux-control.0 (19029) [cmdAptUpdate] RasPi4 (192.168.138.139:22): no datapoints selected -> removing existing datapoints 2020-08-15 16:04:25.637 - debug: linux-control.0 (19029) [servicesInfo] RasPi4 (192.168.138.139:22): send command: 'systemctl list-units --type service --all --no-legend | awk '{out=""; for(i=5;i<=NF;i++){out=out" "$i}; print $1","$2","$3","$4","out}'' 2020-08-15 16:04:25.662 - debug: linux-control.0 (19029) [servicesInfo] RasPi4 (192.168.138.139:22): response stdout: alsa-restore.service,loaded,active,exited, Save/Restore Sound Card State alsa-state.service,loaded,active,running, Manage Sound Card State (restore and store) apparmor.service,not-found,inactive,dead, apparmor.service apt-daily-upgrade.service,loaded,inactive,dead, Daily apt upgrade and clean activities apt-daily.service,loaded,inactive,dead, Daily apt download activities auditd.service,not-found,inactive,dead, auditd.service auth-rpcgss-module.service,loaded,inactive,dead, Kernel Module supporting RPCSEC_GSS avahi-daemon.service,loaded,active,running, Avahi mDNS/DNS-SD Stack bluetooth.service,loaded,active,running, Bluetooth service bthelper@hci0.service,loaded,inactive,dead, Raspberry Pi bluetooth helper connman.service,not-found,inactive,dead, connman.service console-screen.service,not-found,inactive,dead, console-screen.service console-setup.service,loaded,active,exited, Set console font and keymap cron.service,loaded,active,running, Regular background program processing daemon dbus.service,loaded,active,running, D-Bus System Message Bus dhcpcd.service,loaded,active,running, dhcpcd on all interfaces display-manager.service,not-found,inactive,dead, display-manager.service dphys-swapfile.service,loaded,active,exited, dphys-swapfile - set up, mount/unmount, and delete a swap file emergency.service,loaded,inactive,dead, Emergency Shell fake-hwclock.service,loaded,active,exited, Restore / save the current clock getty-static.service,loaded,inactive,dead, getty on tty2-tty6 if dbus and logind are not available getty@tty1.service,loaded,active,running, Getty on tty1 gssproxy.service,not-found,inactive,dead, gssproxy.service hciuart.service,loaded,active,running, Configure Bluetooth Modems connected by UART ifupdown-pre.service,loaded,active,exited, Helper to synchronize boot up for ifupdown influxdb.service,not-found,inactive,dead, influxdb.service iobroker.service,loaded,active,running, ioBroker Server kbd.service,not-found,inactive,dead, kbd.service keyboard-setup.service,loaded,active,exited, Set the console keyboard layout kmod-static-nodes.service,loaded,active,exited, Create list of required static device nodes for the current kernel logrotate.service,loaded,inactive,dead, Rotate log files man-db.service,loaded,inactive,dead, Daily man-db regeneration mariadb-server.service,not-found,inactive,dead, mariadb-server.service mountkernfs.service,masked,inactive,dead, mountkernfs.service mysql-server.service,not-found,inactive,dead, mysql-server.service networking.service,loaded,active,exited, Raise network interfaces NetworkManager.service,not-found,inactive,dead, NetworkManager.service nfs-blkmap.service,not-found,inactive,dead, nfs-blkmap.service nfs-config.service,loaded,inactive,dead, Preprocess NFS configuration nfs-server.service,not-found,inactive,dead, nfs-server.service nfs-utils.service,loaded,inactive,dead, NFS server and client services plymouth-quit-wait.service,not-found,inactive,dead, plymouth-quit-wait.service plymouth-start.service,not-found,inactive,dead, plymouth-start.service raspberrypi-net-mods.service,loaded,inactive,dead, Copy user wpa_supplicant.conf raspi-config.service,loaded,active,exited, LSB: Switch to ondemand cpu governor (unless shift key is pressed) rc-local.service,loaded,active,exited, /etc/rc.local Compatibility redis.service,not-found,inactive,dead, redis.service regenerate_ssh_host_keys.service,loaded,inactive,dead, Regenerate SSH host keys rescue.service,loaded,inactive,dead, Rescue Shell rng-tools.service,loaded,active,running, rng-tools.service rpc-gssd.service,loaded,inactive,dead, RPC security service for NFS client and server rpc-svcgssd.service,loaded,inactive,dead, RPC security service for NFS server rpi-eeprom-update.service,loaded,active,exited, Check for Raspberry Pi EEPROM updates rsync.service,loaded,inactive,dead, fast remote file copy program daemon rsyslog.service,loaded,active,running, System Logging Service ssh.service,loaded,active,running, OpenBSD Secure Shell server sshswitch.service,loaded,inactive,dead, Turn on SSH if /boot/ssh is present systemd-ask-password-console.service,loaded,inactive,dead, Dispatch Password Requests to Console systemd-ask-password-wall.service,loaded,inactive,dead, Forward Password Requests to Wall systemd-binfmt.service,loaded,inactive,dead, Set Up Additional Binary Formats systemd-fsck-root.service,loaded,active,exited, File System Check on Root Device systemd-fsck@dev-disk-by\x2dpartuuid-50fbae26\x2d01.service,loaded,active,exited, File System Check on /dev/disk/by-partuuid/50fbae26-01 systemd-fsckd.service,loaded,inactive,dead, File System Check Daemon to report status systemd-hwdb-update.service,loaded,inactive,dead, Rebuild Hardware Database systemd-initctl.service,loaded,inactive,dead, initctl Compatibility Daemon systemd-journal-flush.service,loaded,active,exited, Flush Journal to Persistent Storage systemd-journald.service,loaded,active,running, Journal Service systemd-logind.service,loaded,active,running, Login Service systemd-machine-id-commit.service,loaded,inactive,dead, Commit a transient machine-id on disk systemd-modules-load.service,loaded,active,exited, Load Kernel Modules systemd-networkd.service,loaded,inactive,dead, Network Service systemd-quotacheck.service,loaded,inactive,dead, File System Quota Check systemd-random-seed.service,loaded,active,exited, Load/Save Random Seed systemd-remount-fs.service,loaded,active,exited, Remount Root and Kernel File Systems systemd-rfkill.service,loaded,inactive,dead, Load/Save RF Kill Switch Status systemd-sysctl.service,loaded,active,exited, Apply Kernel Variables systemd-sysusers.service,loaded,active,exited, Create System Users systemd-timesyncd.service,loaded,active,running, Network Time Synchronization systemd-tmpfiles-clean.service,loaded,inactive,dead, Cleanup of Temporary Directories systemd-tmpfiles-setup-dev.service,loaded,active,exited, Create Static Device Nodes in /dev systemd-tmpfiles-setup.service,loaded,active,exited, Create Volatile Files and Directories systemd-udev-trigger.service,loaded,active,exited, udev Coldplug all Devices systemd-udevd.service,loaded,active,running, udev Kernel Device Manager systemd-update-done.service,not-found,inactive,dead, systemd-update-done.service systemd-update-utmp-runlevel.service,loaded,inactive,dead, Update UTMP about System Runlevel Changes systemd-update-utmp.service,loaded,active,exited, Update UTMP about System Boot/Shutdown systemd-user-sessions.service,loaded,active,exited, Permit User Sessions systemd-vconsole-setup.service,not-found,inactive,dead, systemd-vconsole-setup.service triggerhappy.service,loaded,active,running, triggerhappy global hotkey daemon user-runtime-dir@1000.service,loaded,active,exited, User Runtime Directory /run/user/1000 user@1000.service,loaded,active,running, User Manager for UID 1000 wpa_supplicant.service,loaded,active,running, WPA supplicant 2020-08-15 16:04:25.669 - debug: linux-control.0 (19029) [servicesInfo] RasPi4 (192.168.138.139:22): csvToJson result: [{"id":"alsa-restore.service","load":"loaded","active":"active","running":"exited","description":"Save/Restore Sound Card State"},{"id":"alsa-state.service","load":"loaded","active":"active","running":"running","description":"Manage Sound Card State (restore and store)"},{"id":"apparmor.service","load":"not-found","active":"inactive","running":"dead","description":"apparmor.service"},{"id":"apt-daily-upgrade.service","load":"loaded","active":"inactive","running":"dead","description":"Daily apt upgrade and clean activities"},{"id":"apt-daily.service","load":"loaded","active":"inactive","running":"dead","description":"Daily apt download activities"},{"id":"auditd.service","load":"not-found","active":"inactive","running":"dead","description":"auditd.service"},{"id":"auth-rpcgss-module.service","load":"loaded","active":"inactive","running":"dead","description":"Kernel Module supporting RPCSEC_GSS"},{"id":"avahi-daemon.service","load":"loaded","active":"active","running":"running","description":"Avahi mDNS/DNS-SD Stack"},{"id":"bluetooth.service","load":"loaded","active":"active","running":"running","description":"Bluetooth service"},{"id":"bthelper@hci0.service","load":"loaded","active":"inactive","running":"dead","description":"Raspberry Pi bluetooth helper"},{"id":"connman.service","load":"not-found","active":"inactive","running":"dead","description":"connman.service"},{"id":"console-screen.service","load":"not-found","active":"inactive","running":"dead","description":"console-screen.service"},{"id":"console-setup.service","load":"loaded","active":"active","running":"exited","description":"Set console font and keymap"},{"id":"cron.service","load":"loaded","active":"active","running":"running","description":"Regular background program processing daemon"},{"id":"dbus.service","load":"loaded","active":"active","running":"running","description":"D-Bus System Message Bus"},{"id":"dhcpcd.service","load":"loaded","active":"active","running":"running","description":"dhcpcd on all interfaces"},{"id":"display-manager.service","load":"not-found","active":"inactive","running":"dead","description":"display-manager.service"},{"id":"dphys-swapfile.service","load":"loaded","active":"active","running":"exited","description":"dphys-swapfile - set up","field6":"mount/unmount","field7":"and delete a swap file"},{"id":"emergency.service","load":"loaded","active":"inactive","running":"dead","description":"Emergency Shell"},{"id":"fake-hwclock.service","load":"loaded","active":"active","running":"exited","description":"Restore / save the current clock"},{"id":"getty-static.service","load":"loaded","active":"inactive","running":"dead","description":"getty on tty2-tty6 if dbus and logind are not available"},{"id":"getty@tty1.service","load":"loaded","active":"active","running":"running","description":"Getty on tty1"},{"id":"gssproxy.service","load":"not-found","active":"inactive","running":"dead","description":"gssproxy.service"},{"id":"hciuart.service","load":"loaded","active":"active","running":"running","description":"Configure Bluetooth Modems connected by UART"},{"id":"ifupdown-pre.service","load":"loaded","active":"active","running":"exited","description":"Helper to synchronize boot up for ifupdown"},{"id":"influxdb.service","load":"not-found","active":"inactive","running":"dead","description":"influxdb.service"},{"id":"iobroker.service","load":"loaded","active":"active","running":"running","description":"ioBroker Server"},{"id":"kbd.service","load":"not-found","active":"inactive","running":"dead","description":"kbd.service"},{"id":"keyboard-setup.service","load":"loaded","active":"active","running":"exited","description":"Set the console keyboard layout"},{"id":"kmod-static-nodes.service","load":"loaded","active":"active","running":"exited","description":"Create list of required static device nodes for the current kernel"},{"id":"logrotate.service","load":"loaded","active":"inactive","running":"dead","description":"Rotate log files"},{"id":"man-db.service","load":"loaded","active":"inactive","running":"dead","description":"Daily man-db regeneration"},{"id":"mariadb-server.service","load":"not-found","active":"inactive","running":"dead","description":"mariadb-server.service"},{"id":"mountkernfs.service","load":"masked","active":"inactive","running":"dead","description":"mountkernfs.service"},{"id":"mysql-server.service","load":"not-found","active":"inactive","running":"dead","description":"mysql-server.service"},{"id":"networking.service","load":"loaded","active":"active","running":"exited","description":"Raise network interfaces"},{"id":"NetworkManager.service","load":"not-found","active":"inactive","running":"dead","description":"NetworkManager.service"},{"id":"nfs-blkmap.service","load":"not-found","active":"inactive","running":"dead","description":"nfs-blkmap.service"},{"id":"nfs-config.service","load":"loaded","active":"inactive","running":"dead","description":"Preprocess NFS configuration"},{"id":"nfs-server.service","load":"not-found","active":"inactive","running":"dead","description":"nfs-server.service"},{"id":"nfs-utils.service","load":"loaded","active":"inactive","running":"dead","description":"NFS server and client services"},{"id":"plymouth-quit-wait.service","load":"not-found","active":"inactive","running":"dead","description":"plymouth-quit-wait.service"},{"id":"plymouth-start.service","load":"not-found","active":"inactive","running":"dead","description":"plymouth-start.service"},{"id":"raspberrypi-net-mods.service","load":"loaded","active":"inactive","running":"dead","description":"Copy user wpa_supplicant.conf"},{"id":"raspi-config.service","load":"loaded","active":"active","running":"exited","description":"LSB: Switch to ondemand cpu governor (unless shift key is pressed)"},{"id":"rc-local.service","load":"loaded","active":"active","running":"exited","description":"/etc/rc.local Compatibility"},{"id":"redis.service","load":"not-found","active":"inactive","running":"dead","description":"redis.service"},{"id":"regenerate_ssh_host_keys.service","load":"loaded","active":"inactive","running":"dead","description":"Regenerate SSH host keys"},{"id":"rescue.service","load":"loaded","active":"inactive","running":"dead","description":"Rescue Shell"},{"id":"rng-tools.service","load":"loaded","active":"active","running":"running","description":"rng-tools.service"},{"id":"rpc-gssd.service","load":"loaded","active":"inactive","running":"dead","description":"RPC security service for NFS client and server"},{"id":"rpc-svcgssd.service","load":"loaded","active":"inactive","running":"dead","description":"RPC security service for NFS server"},{"id":"rpi-eeprom-update.service","load":"loaded","active":"active","running":"exited","description":"Check for Raspberry Pi EEPROM updates"},{"id":"rsync.service","load":"loaded","active":"inactive","running":"dead","description":"fast remote file copy program daemon"},{"id":"rsyslog.service","load":"loaded","active":"active","running":"running","description":"System Logging Service"},{"id":"ssh.service","load":"loaded","active":"active","running":"running","description":"OpenBSD Secure Shell server"},{"id":"sshswitch.service","load":"loaded","active":"inactive","running":"dead","description":"Turn on SSH if /boot/ssh is present"},{"id":"systemd-ask-password-console.service","load":"loaded","active":"inactive","running":"dead","description":"Dispatch Password Requests to Console"},{"id":"systemd-ask-password-wall.service","load":"loaded","active":"inactive","running":"dead","description":"Forward Password Requests to Wall"},{"id":"systemd-binfmt.service","load":"loaded","active":"inactive","running":"dead","description":"Set Up Additional Binary Formats"},{"id":"systemd-fsck-root.service","load":"loaded","active":"active","running":"exited","description":"File System Check on Root Device"},{"id":"systemd-fsck@dev-disk-by\\x2dpartuuid-50fbae26\\x2d01.service","load":"loaded","active":"active","running":"exited","description":"File System Check on /dev/disk/by-partuuid/50fbae26-01"},{"id":"systemd-fsckd.service","load":"loaded","active":"inactive","running":"dead","description":"File System Check Daemon to report status"},{"id":"systemd-hwdb-update.service","load":"loaded","active":"inactive","running":"dead","description":"Rebuild Hardware Database"},{"id":"systemd-initctl.service","load":"loaded","active":"inactive","running":"dead","description":"initctl Compatibility Daemon"},{"id":"systemd-journal-flush.service","load":"loaded","active":"active","running":"exited","description":"Flush Journal to Persistent Storage"},{"id":"systemd-journald.service","load":"loaded","active":"active","running":"running","description":"Journal Service"},{"id":"systemd-logind.service","load":"loaded","active":"active","running":"running","description":"Login Service"},{"id":"systemd-machine-id-commit.service","load":"loaded","active":"inactive","running":"dead","description":"Commit a transient machine-id on disk"},{"id":"systemd-modules-load.service","load":"loaded","active":"active","running":"exited","description":"Load Kernel Modules"},{"id":"systemd-networkd.service","load":"loaded","active":"inactive","running":"dead","description":"Network Service"},{"id":"systemd-quotacheck.service","load":"loaded","active":"inactive","running":"dead","description":"File System Quota Check"},{"id":"systemd-random-seed.service","load":"loaded","active":"active","running":"exited","description":"Load/Save Random Seed"},{"id":"systemd-remount-fs.service","load":"loaded","active":"active","running":"exited","description":"Remount Root and Kernel File Systems"},{"id":"systemd-rfkill.service","load":"loaded","active":"inactive","running":"dead","description":"Load/Save RF Kill Switch Status"},{"id":"systemd-sysctl.service","load":"loaded","active":"active","running":"exited","description":"Apply Kernel Variables"},{"id":"systemd-sysusers.service","load":"loaded","active":"active","running":"exited","description":"Create System Users"},{"id":"systemd-timesyncd.service","load":"loaded","active":"active","running":"running","description":"Network Time Synchronization"},{"id":"systemd-tmpfiles-clean.service","load":"loaded","active":"inactive","running":"dead","description":"Cleanup of Temporary Directories"},{"id":"systemd-tmpfiles-setup-dev.service","load":"loaded","active":"active","running":"exited","description":"Create Static Device Nodes in /dev"},{"id":"systemd-tmpfiles-setup.service","load":"loaded","active":"active","running":"exited","description":"Create Volatile Files and Directories"},{"id":"systemd-udev-trigger.service","load":"loaded","active":"active","running":"exited","description":"udev Coldplug all Devices"},{"id":"systemd-udevd.service","load":"loaded","active":"active","running":"running","description":"udev Kernel Device Manager"},{"id":"systemd-update-done.service","load":"not-found","active":"inactive","running":"dead","description":"systemd-update-done.service"},{"id":"systemd-update-utmp-runlevel.service","load":"loaded","active":"inactive","running":"dead","description":"Update UTMP about System Runlevel Changes"},{"id":"systemd-update-utmp.service","load":"loaded","active":"active","running":"exited","description":"Update UTMP about System Boot/Shutdown"},{"id":"systemd-user-sessions.service","load":"loaded","active":"active","running":"exited","description":"Permit User Sessions"},{"id":"systemd-vconsole-setup.service","load":"not-found","active":"inactive","running":"dead","description":"systemd-vconsole-setup.service"},{"id":"triggerhappy.service","load":"loaded","active":"active","running":"running","description":"triggerhappy global hotkey daemon"},{"id":"user-runtime-dir@1000.service","load":"loaded","active":"active","running":"exited","description":"User Runtime Directory /run/user/1000"},{"id":"user@1000.service","load":"loaded","active":"active","running":"running","description":"User Manager for UID 1000"},{"id":"wpa_supplicant.service","load":"loaded","active":"active","running":"running","description":"WPA supplicant"}] 2020-08-15 16:04:28.974 - debug: linux-control.0 (19029) [needrestart] RasPi4 (192.168.138.139:22): no datapoints selected -> removing existing datapoints 2020-08-15 16:04:29.018 - debug: linux-control.0 (19029) [folderSizes] RasPi4 (192.168.138.139:22): send command: 'sudo du -sk /opt/iobroker/iobroker-data/history | awk '{ print $1 /1024 }'' 2020-08-15 16:04:29.265 - debug: linux-control.0 (19029) [folderSizes] RasPi4 (192.168.138.139:22): response stdout: 194.051 2020-08-15 16:04:29.281 - debug: linux-control.0 (19029) [folderSizes] RasPi4 (192.168.138.139:22): RasPi4.folders.history.size: 194.05 MB 2020-08-15 16:04:29.328 - debug: linux-control.0 (19029) [folderSizes] RasPi4 (192.168.138.139:22): send command: 'sudo find /opt/iobroker/iobroker-data/history -name "*" | wc -l' 2020-08-15 16:04:29.513 - debug: linux-control.0 (19029) [folderSizes] RasPi4 (192.168.138.139:22): response stdout: 22104 2020-08-15 16:04:29.515 - debug: linux-control.0 (19029) [folderSizes] RasPi4 (192.168.138.139:22): RasPi4.folders.history.files: 22104 Dateien 2020-08-15 16:04:29.558 - debug: linux-control.0 (19029) [folderSizes] RasPi4 (192.168.138.139:22): send command: 'tmp=$(sudo find /opt/iobroker/iobroker-data/history -name "*" -type f -exec stat -c "%Y %n" -- {} \; | sort -nr | head -n1 | awk '{print $2}') && date +%s -r $tmp' 2020-08-15 16:05:00.034 - info: host.raspberrypi instance system.adapter.dwd.0 started with pid 25920 2020-08-15 16:05:04.414 - info: dwd.0 (25920) starting. Version 2.5.0 in /opt/iobroker/node_modules/iobroker.dwd, node: v10.21.0, js-controller: 3.1.4 2020-08-15 16:05:08.655 - info: dwd.0 (25920) Terminated (NO_ERROR): Without reason 2020-08-15 16:05:09.175 - info: host.raspberrypi instance system.adapter.dwd.0 terminated with code 0 (NO_ERROR) 2020-08-15 16:06:06.140 - debug: linux-control.0 (19029) [folderSizes] RasPi4 (192.168.138.139:22): response stdout: 1597500265 2020-08-15 16:06:06.153 - debug: linux-control.0 (19029) [folderSizes] RasPi4 (192.168.138.139:22): RasPi4.folders.history.lastChange: 1597500265000 -> 15.08.2020 16:04 2020-08-15 16:06:06.199 - debug: linux-control.0 (19029) [userCommand] RasPi4 (192.168.138.139:22, id: root, description: ): send command: 'df / | grep / | awk '{ print $5}' | sed 's/%//g'' 2020-08-15 16:06:06.217 - debug: linux-control.0 (19029) [userCommand] RasPi4 (192.168.138.139:22, id: root, description: ): response stdout: 19 2020-08-15 16:06:06.270 - debug: linux-control.0 (19029) [userCommand] RasPi4 (192.168.138.139:22, id: ip, description: ): send command: 'hostname -I | cut -d' ' -f1' 2020-08-15 16:06:06.297 - debug: linux-control.0 (19029) [userCommand] RasPi4 (192.168.138.139:22, id: ip, description: ): response stdout: 192.168.138.139 2020-08-15 16:06:06.302 - debug: linux-control.0 (19029) [userCommand] RasPi4 (192.168.138.139:22, id: cpu-temp, description: ): send command: 'vcgencmd measure_temp | awk '{print substr($1, length($0)-5,4)}'' 2020-08-15 16:06:06.318 - debug: linux-control.0 (19029) [userCommand] RasPi4 (192.168.138.139:22, id: cpu-temp, description: ): response stdout: 51.0 2020-08-15 16:06:06.371 - info: linux-control.0 (19029) successful received data from RasPi4 (192.168.138.139:22) 2020-08-15 16:06:06.372 - info: linux-control.0 (19029) getting data from NUC_VM (192.168.138.123:22) 2020-08-15 16:06:06.457 - debug: linux-control.0 (19029) [getConnection] Host 'NUC_VM' (192.168.138.123:22): using sudo for authentification 2020-08-15 16:06:06.510 - debug: linux-control.0 (19029) [distributionInfo] NUC_VM (192.168.138.123:22): send command: 'cat /etc/os-release' 2020-08-15 16:06:06.574 - debug: linux-control.0 (19029) [distributionInfo] NUC_VM (192.168.138.123:22): response stdout: PRETTY_NAME="Debian GNU/Linux 10 (buster)" NAME="Debian GNU/Linux" VERSION_ID="10" VERSION="10 (buster)" VERSION_CODENAME=buster ID=debian HOME_URL="https://www.debian.org/" SUPPORT_URL="https://www.debian.org/support" BUG_REPORT_URL="https://bugs.debian.org/" 2020-08-15 16:06:06.578 - debug: linux-control.0 (19029) [distributionInfo] NUC_VM (192.168.138.123:22): csvToJson result: [{"prop":"PRETTY_NAME","val":"Debian GNU/Linux 10 (buster)"},{"prop":"NAME","val":"Debian GNU/Linux"},{"prop":"VERSION_ID","val":"10"},{"prop":"VERSION","val":"10 (buster)"},{"prop":"VERSION_CODENAME","val":"buster"},{"prop":"ID","val":"debian"},{"prop":"HOME_URL","val":"https://www.debian.org/"},{"prop":"SUPPORT_URL","val":"https://www.debian.org/support"},{"prop":"BUG_REPORT_URL","val":"https://bugs.debian.org/"}] 2020-08-15 16:06:06.594 - debug: linux-control.0 (19029) [cmdAptUpdate] NUC_VM (192.168.138.123:22): no datapoints selected -> removing existing datapoints 2020-08-15 16:06:06.598 - debug: linux-control.0 (19029) [servicesInfo] NUC_VM (192.168.138.123:22): send command: 'systemctl list-units --type service --all --no-legend | awk '{out=""; for(i=5;i<=NF;i++){out=out" "$i}; print $1","$2","$3","$4","out}'' 2020-08-15 16:06:06.610 - debug: linux-control.0 (19029) [servicesInfo] NUC_VM (192.168.138.123:22): response stdout: apache2.service,loaded,active,running, The Apache HTTP Server apparmor.service,loaded,active,exited, Load AppArmor profiles apt-daily-upgrade.service,loaded,inactive,dead, Daily apt upgrade and clean activities apt-daily.service,loaded,inactive,dead, Daily apt download activities auditd.service,not-found,inactive,dead, auditd.service auth-rpcgss-module.service,loaded,inactive,dead, Kernel Module supporting RPCSEC_GSS avahi-daemon.service,loaded,active,running, Avahi mDNS/DNS-SD Stack clamav-daemon.service,not-found,inactive,dead, clamav-daemon.service connman.service,not-found,inactive,dead, connman.service console-screen.service,not-found,inactive,dead, console-screen.service console-setup.service,loaded,active,exited, Set console font and keymap cron.service,loaded,active,running, Regular background program processing daemon cups-browsed.service,loaded,failed,failed, Make remote CUPS printers available locally cups.service,loaded,active,running, CUPS Scheduler dbus.service,loaded,active,running, D-Bus System Message Bus display-manager.service,not-found,inactive,dead, display-manager.service emergency.service,loaded,inactive,dead, Emergency Shell exim4.service,loaded,active,running, LSB: exim Mail Transport Agent getty-static.service,loaded,inactive,dead, getty on tty2-tty6 if dbus and logind are not available getty@tty1.service,loaded,active,running, Getty on tty1 greylist.service,not-found,inactive,dead, greylist.service gssproxy.service,not-found,inactive,dead, gssproxy.service ifup@ens18.service,loaded,active,exited, ifup for ens18 ifupdown-pre.service,loaded,active,exited, Helper to synchronize boot up for ifupdown influxdb.service,not-found,inactive,dead, influxdb.service iobroker.service,loaded,active,running, ioBroker Server irqbalance.service,loaded,active,running, irqbalance daemon kbd.service,not-found,inactive,dead, kbd.service keyboard-setup.service,loaded,active,exited, Set the console keyboard layout kmod-static-nodes.service,loaded,active,exited, Create list of required static device nodes for the current kernel logrotate.service,loaded,inactive,dead, Rotate log files man-db.service,loaded,inactive,dead, Daily man-db regeneration mariadb-server.service,not-found,inactive,dead, mariadb-server.service mysql-server.service,not-found,inactive,dead, mysql-server.service mysql.service,not-found,inactive,dead, mysql.service networking.service,loaded,active,exited, Raise network interfaces NetworkManager.service,not-found,inactive,dead, NetworkManager.service nfs-blkmap.service,not-found,inactive,dead, nfs-blkmap.service nfs-config.service,loaded,inactive,dead, Preprocess NFS configuration nfs-server.service,not-found,inactive,dead, nfs-server.service nfs-utils.service,loaded,inactive,dead, NFS server and client services ntp.service,loaded,active,running, Network Time Service plymouth-quit-wait.service,not-found,inactive,dead, plymouth-quit-wait.service plymouth-start.service,not-found,inactive,dead, plymouth-start.service postgresql.service,not-found,inactive,dead, postgresql.service rc-local.service,loaded,inactive,dead, /etc/rc.local Compatibility redis.service,not-found,inactive,dead, redis.service rescue.service,loaded,inactive,dead, Rescue Shell rpc-gssd.service,loaded,inactive,dead, RPC security service for NFS client and server rpc-svcgssd.service,loaded,inactive,dead, RPC security service for NFS server rpcbind.service,loaded,active,running, RPC bind portmap service rsync.service,loaded,inactive,dead, fast remote file copy program daemon rsyslog.service,loaded,active,running, System Logging Service spamassassin.service,not-found,inactive,dead, spamassassin.service ssh.service,loaded,active,running, OpenBSD Secure Shell server systemd-ask-password-console.service,loaded,inactive,dead, Dispatch Password Requests to Console systemd-ask-password-wall.service,loaded,inactive,dead, Forward Password Requests to Wall systemd-binfmt.service,loaded,inactive,dead, Set Up Additional Binary Formats systemd-fsck-root.service,loaded,inactive,dead, File System Check on Root Device systemd-fsckd.service,loaded,inactive,dead, File System Check Daemon to report status systemd-hwdb-update.service,loaded,inactive,dead, Rebuild Hardware Database systemd-initctl.service,loaded,inactive,dead, initctl Compatibility Daemon systemd-journal-flush.service,loaded,active,exited, Flush Journal to Persistent Storage systemd-journald.service,loaded,active,running, Journal Service systemd-logind.service,loaded,active,running, Login Service systemd-machine-id-commit.service,loaded,inactive,dead, Commit a transient machine-id on disk systemd-modules-load.service,loaded,active,exited, Load Kernel Modules systemd-networkd.service,loaded,inactive,dead, Network Service systemd-random-seed.service,loaded,active,exited, Load/Save Random Seed systemd-remount-fs.service,loaded,active,exited, Remount Root and Kernel File Systems systemd-sysctl.service,loaded,active,exited, Apply Kernel Variables systemd-sysusers.service,loaded,active,exited, Create System Users systemd-timesyncd.service,loaded,inactive,dead, Network Time Synchronization systemd-tmpfiles-clean.service,loaded,inactive,dead, Cleanup of Temporary Directories systemd-tmpfiles-setup-dev.service,loaded,active,exited, Create Static Device Nodes in /dev systemd-tmpfiles-setup.service,loaded,active,exited, Create Volatile Files and Directories systemd-udev-trigger.service,loaded,active,exited, udev Coldplug all Devices systemd-udevd.service,loaded,active,running, udev Kernel Device Manager systemd-update-done.service,not-found,inactive,dead, systemd-update-done.service systemd-update-utmp-runlevel.service,loaded,inactive,dead, Update UTMP about System Runlevel Changes systemd-update-utmp.service,loaded,active,exited, Update UTMP about System Boot/Shutdown systemd-user-sessions.service,loaded,active,exited, Permit User Sessions systemd-vconsole-setup.service,not-found,inactive,dead, systemd-vconsole-setup.service user-runtime-dir@1000.service,loaded,active,exited, User Runtime Directory /run/user/1000 user@1000.service,loaded,active,running, User Manager for UID 1000 2020-08-15 16:06:06.615 - debug: linux-control.0 (19029) [servicesInfo] NUC_VM (192.168.138.123:22): csvToJson result: [{"id":"apache2.service","load":"loaded","active":"active","running":"running","description":"The Apache HTTP Server"},{"id":"apparmor.service","load":"loaded","active":"active","running":"exited","description":"Load AppArmor profiles"},{"id":"apt-daily-upgrade.service","load":"loaded","active":"inactive","running":"dead","description":"Daily apt upgrade and clean activities"},{"id":"apt-daily.service","load":"loaded","active":"inactive","running":"dead","description":"Daily apt download activities"},{"id":"auditd.service","load":"not-found","active":"inactive","running":"dead","description":"auditd.service"},{"id":"auth-rpcgss-module.service","load":"loaded","active":"inactive","running":"dead","description":"Kernel Module supporting RPCSEC_GSS"},{"id":"avahi-daemon.service","load":"loaded","active":"active","running":"running","description":"Avahi mDNS/DNS-SD Stack"},{"id":"clamav-daemon.service","load":"not-found","active":"inactive","running":"dead","description":"clamav-daemon.service"},{"id":"connman.service","load":"not-found","active":"inactive","running":"dead","description":"connman.service"},{"id":"console-screen.service","load":"not-found","active":"inactive","running":"dead","description":"console-screen.service"},{"id":"console-setup.service","load":"loaded","active":"active","running":"exited","description":"Set console font and keymap"},{"id":"cron.service","load":"loaded","active":"active","running":"running","description":"Regular background program processing daemon"},{"id":"cups-browsed.service","load":"loaded","active":"failed","running":"failed","description":"Make remote CUPS printers available locally"},{"id":"cups.service","load":"loaded","active":"active","running":"running","description":"CUPS Scheduler"},{"id":"dbus.service","load":"loaded","active":"active","running":"running","description":"D-Bus System Message Bus"},{"id":"display-manager.service","load":"not-found","active":"inactive","running":"dead","description":"display-manager.service"},{"id":"emergency.service","load":"loaded","active":"inactive","running":"dead","description":"Emergency Shell"},{"id":"exim4.service","load":"loaded","active":"active","running":"running","description":"LSB: exim Mail Transport Agent"},{"id":"getty-static.service","load":"loaded","active":"inactive","running":"dead","description":"getty on tty2-tty6 if dbus and logind are not available"},{"id":"getty@tty1.service","load":"loaded","active":"active","running":"running","description":"Getty on tty1"},{"id":"greylist.service","load":"not-found","active":"inactive","running":"dead","description":"greylist.service"},{"id":"gssproxy.service","load":"not-found","active":"inactive","running":"dead","description":"gssproxy.service"},{"id":"ifup@ens18.service","load":"loaded","active":"active","running":"exited","description":"ifup for ens18"},{"id":"ifupdown-pre.service","load":"loaded","active":"active","running":"exited","description":"Helper to synchronize boot up for ifupdown"},{"id":"influxdb.service","load":"not-found","active":"inactive","running":"dead","description":"influxdb.service"},{"id":"iobroker.service","load":"loaded","active":"active","running":"running","description":"ioBroker Server"},{"id":"irqbalance.service","load":"loaded","active":"active","running":"running","description":"irqbalance daemon"},{"id":"kbd.service","load":"not-found","active":"inactive","running":"dead","description":"kbd.service"},{"id":"keyboard-setup.service","load":"loaded","active":"active","running":"exited","description":"Set the console keyboard layout"},{"id":"kmod-static-nodes.service","load":"loaded","active":"active","running":"exited","description":"Create list of required static device nodes for the current kernel"},{"id":"logrotate.service","load":"loaded","active":"inactive","running":"dead","description":"Rotate log files"},{"id":"man-db.service","load":"loaded","active":"inactive","running":"dead","description":"Daily man-db regeneration"},{"id":"mariadb-server.service","load":"not-found","active":"inactive","running":"dead","description":"mariadb-server.service"},{"id":"mysql-server.service","load":"not-found","active":"inactive","running":"dead","description":"mysql-server.service"},{"id":"mysql.service","load":"not-found","active":"inactive","running":"dead","description":"mysql.service"},{"id":"networking.service","load":"loaded","active":"active","running":"exited","description":"Raise network interfaces"},{"id":"NetworkManager.service","load":"not-found","active":"inactive","running":"dead","description":"NetworkManager.service"},{"id":"nfs-blkmap.service","load":"not-found","active":"inactive","running":"dead","description":"nfs-blkmap.service"},{"id":"nfs-config.service","load":"loaded","active":"inactive","running":"dead","description":"Preprocess NFS configuration"},{"id":"nfs-server.service","load":"not-found","active":"inactive","running":"dead","description":"nfs-server.service"},{"id":"nfs-utils.service","load":"loaded","active":"inactive","running":"dead","description":"NFS server and client services"},{"id":"ntp.service","load":"loaded","active":"active","running":"running","description":"Network Time Service"},{"id":"plymouth-quit-wait.service","load":"not-found","active":"inactive","running":"dead","description":"plymouth-quit-wait.service"},{"id":"plymouth-start.service","load":"not-found","active":"inactive","running":"dead","description":"plymouth-start.service"},{"id":"postgresql.service","load":"not-found","active":"inactive","running":"dead","description":"postgresql.service"},{"id":"rc-local.service","load":"loaded","active":"inactive","running":"dead","description":"/etc/rc.local Compatibility"},{"id":"redis.service","load":"not-found","active":"inactive","running":"dead","description":"redis.service"},{"id":"rescue.service","load":"loaded","active":"inactive","running":"dead","description":"Rescue Shell"},{"id":"rpc-gssd.service","load":"loaded","active":"inactive","running":"dead","description":"RPC security service for NFS client and server"},{"id":"rpc-svcgssd.service","load":"loaded","active":"inactive","running":"dead","description":"RPC security service for NFS server"},{"id":"rpcbind.service","load":"loaded","active":"active","running":"running","description":"RPC bind portmap service"},{"id":"rsync.service","load":"loaded","active":"inactive","running":"dead","description":"fast remote file copy program daemon"},{"id":"rsyslog.service","load":"loaded","active":"active","running":"running","description":"System Logging Service"},{"id":"spamassassin.service","load":"not-found","active":"inactive","running":"dead","description":"spamassassin.service"},{"id":"ssh.service","load":"loaded","active":"active","running":"running","description":"OpenBSD Secure Shell server"},{"id":"systemd-ask-password-console.service","load":"loaded","active":"inactive","running":"dead","description":"Dispatch Password Requests to Console"},{"id":"systemd-ask-password-wall.service","load":"loaded","active":"inactive","running":"dead","description":"Forward Password Requests to Wall"},{"id":"systemd-binfmt.service","load":"loaded","active":"inactive","running":"dead","description":"Set Up Additional Binary Formats"},{"id":"systemd-fsck-root.service","load":"loaded","active":"inactive","running":"dead","description":"File System Check on Root Device"},{"id":"systemd-fsckd.service","load":"loaded","active":"inactive","running":"dead","description":"File System Check Daemon to report status"},{"id":"systemd-hwdb-update.service","load":"loaded","active":"inactive","running":"dead","description":"Rebuild Hardware Database"},{"id":"systemd-initctl.service","load":"loaded","active":"inactive","running":"dead","description":"initctl Compatibility Daemon"},{"id":"systemd-journal-flush.service","load":"loaded","active":"active","running":"exited","description":"Flush Journal to Persistent Storage"},{"id":"systemd-journald.service","load":"loaded","active":"active","running":"running","description":"Journal Service"},{"id":"systemd-logind.service","load":"loaded","active":"active","running":"running","description":"Login Service"},{"id":"systemd-machine-id-commit.service","load":"loaded","active":"inactive","running":"dead","description":"Commit a transient machine-id on disk"},{"id":"systemd-modules-load.service","load":"loaded","active":"active","running":"exited","description":"Load Kernel Modules"},{"id":"systemd-networkd.service","load":"loaded","active":"inactive","running":"dead","description":"Network Service"},{"id":"systemd-random-seed.service","load":"loaded","active":"active","running":"exited","description":"Load/Save Random Seed"},{"id":"systemd-remount-fs.service","load":"loaded","active":"active","running":"exited","description":"Remount Root and Kernel File Systems"},{"id":"systemd-sysctl.service","load":"loaded","active":"active","running":"exited","description":"Apply Kernel Variables"},{"id":"systemd-sysusers.service","load":"loaded","active":"active","running":"exited","description":"Create System Users"},{"id":"systemd-timesyncd.service","load":"loaded","active":"inactive","running":"dead","description":"Network Time Synchronization"},{"id":"systemd-tmpfiles-clean.service","load":"loaded","active":"inactive","running":"dead","description":"Cleanup of Temporary Directories"},{"id":"systemd-tmpfiles-setup-dev.service","load":"loaded","active":"active","running":"exited","description":"Create Static Device Nodes in /dev"},{"id":"systemd-tmpfiles-setup.service","load":"loaded","active":"active","running":"exited","description":"Create Volatile Files and Directories"},{"id":"systemd-udev-trigger.service","load":"loaded","active":"active","running":"exited","description":"udev Coldplug all Devices"},{"id":"systemd-udevd.service","load":"loaded","active":"active","running":"running","description":"udev Kernel Device Manager"},{"id":"systemd-update-done.service","load":"not-found","active":"inactive","running":"dead","description":"systemd-update-done.service"},{"id":"systemd-update-utmp-runlevel.service","load":"loaded","active":"inactive","running":"dead","description":"Update UTMP about System Runlevel Changes"},{"id":"systemd-update-utmp.service","load":"loaded","active":"active","running":"exited","description":"Update UTMP about System Boot/Shutdown"},{"id":"systemd-user-sessions.service","load":"loaded","active":"active","running":"exited","description":"Permit User Sessions"},{"id":"systemd-vconsole-setup.service","load":"not-found","active":"inactive","running":"dead","description":"systemd-vconsole-setup.service"},{"id":"user-runtime-dir@1000.service","load":"loaded","active":"active","running":"exited","description":"User Runtime Directory /run/user/1000"},{"id":"user@1000.service","load":"loaded","active":"active","running":"running","description":"User Manager for UID 1000"}] 2020-08-15 16:06:06.984 - debug: linux-control.0 (19029) [needrestart] NUC_VM (192.168.138.123:22): no datapoints selected -> removing existing datapoints 2020-08-15 16:06:07.002 - debug: linux-control.0 (19029) [folderSizes] NUC_VM (192.168.138.123:22): send command: 'sudo du -sk /opt/iobroker/iobroker-data/history | awk '{ print $1 /1024 }'' 2020-08-15 16:06:07.316 - debug: linux-control.0 (19029) [folderSizes] NUC_VM (192.168.138.123:22): response stdout: [sudo] Passwort für pi: 13499.5 2020-08-15 16:06:07.319 - debug: linux-control.0 (19029) [folderSizes] NUC_VM (192.168.138.123:22): NUC_VM.folders.history.size: NaN MB 2020-08-15 16:06:07.369 - debug: linux-control.0 (19029) [folderSizes] NUC_VM (192.168.138.123:22): send command: 'sudo find /opt/iobroker/iobroker-data/history -name "*" | wc -l' 2020-08-15 16:06:07.578 - debug: linux-control.0 (19029) [folderSizes] NUC_VM (192.168.138.123:22): response stdout: [sudo] Passwort für pi: 112349 2020-08-15 16:06:07.581 - debug: linux-control.0 (19029) [folderSizes] NUC_VM (192.168.138.123:22): NUC_VM.folders.history.files: NaN Dateien 2020-08-15 16:06:07.629 - debug: linux-control.0 (19029) [folderSizes] NUC_VM (192.168.138.123:22): send command: 'tmp=$(sudo find /opt/iobroker/iobroker-data/history -name "*" -type f -exec stat -c "%Y %n" -- {} \; | sort -nr | head -n1 | awk '{print $2}') && date +%s -r $tmp' 2020-08-15 16:06:17.713 - info: web.0 (22824) ==>Connected system.user.admin from ::ffff:192.168.138.145 2020-08-15 16:06:19.906 - info: web.0 (22824) <==Disconnect system.user.admin from ::ffff:192.168.138.145 2020-08-15 16:08:25.229 - debug: linux-control.0 (19029) [folderSizes] NUC_VM (192.168.138.123:22): response stdout: [sudo] Passwort für pi: 1597500492 2020-08-15 16:08:25.232 - debug: linux-control.0 (19029) [folderSizes] NUC_VM (192.168.138.123:22): NUC_VM.folders.history.lastChange: NaN -> 2020-08-15 16:08:25.279 - debug: linux-control.0 (19029) [userCommand] NUC_VM (192.168.138.123:22, id: root, description: ): send command: 'df / | grep / | awk '{ print $5}' | sed 's/%//g'' 2020-08-15 16:08:25.291 - debug: linux-control.0 (19029) [userCommand] NUC_VM (192.168.138.123:22, id: root, description: ): response stdout: 55 2020-08-15 16:08:25.314 - debug: linux-control.0 (19029) [userCommand] NUC_VM (192.168.138.123:22, id: ip, description: ): send command: 'hostname -I | cut -d' ' -f1' 2020-08-15 16:08:25.323 - debug: linux-control.0 (19029) [userCommand] NUC_VM (192.168.138.123:22, id: ip, description: ): response stdout: 192.168.138.123 2020-08-15 16:08:25.371 - debug: linux-control.0 (19029) [userCommand] NUC_VM (192.168.138.123:22): datapoint-id: 'cpu-temp', description: '' -> is not enabled! 2020-08-15 16:08:25.371 - debug: linux-control.0 (19029) [userCommand] NUC_VM (192.168.138.123:22, id: Ordner, description: ): send command: 'du -c /opt/iobroker/iobroker-data/history | tail -1 | awk '{printf $1MB}'' 2020-08-15 16:08:25.671 - debug: linux-control.0 (19029) [userCommand] NUC_VM (192.168.138.123:22, id: Ordner, description: ): response stdout: 13823576 2020-08-15 16:08:25.676 - info: linux-control.0 (19029) successful received data from NUC_VM (192.168.138.123:22) 2020-08-15 16:08:25.676 - info: linux-control.0 (19029) getting data from Tinker (192.168.138.74:22) 2020-08-15 16:08:25.742 - debug: linux-control.0 (19029) [getConnection] Host 'Tinker' (192.168.138.74:22): using sudo for authentification 2020-08-15 16:08:25.970 - debug: linux-control.0 (19029) [distributionInfo] Tinker (192.168.138.74:22): send command: 'cat /etc/os-release' 2020-08-15 16:08:26.280 - debug: linux-control.0 (19029) [distributionInfo] Tinker (192.168.138.74:22): response stdout: NAME="Ubuntu" VERSION="18.04.4 LTS (Bionic Beaver)" ID=ubuntu ID_LIKE=debian PRETTY_NAME="Ubuntu 18.04.4 LTS" VERSION_ID="18.04" HOME_URL="https://www.ubuntu.com/" SUPPORT_URL="https://help.ubuntu.com/" BUG_REPORT_URL="https://bugs.launchpad.net/ubuntu/" PRIVACY_POLICY_URL="https://www.ubuntu.com/legal/terms-and-policies/privacy-policy" VERSION_CODENAME=bionic UBUNTU_CODENAME=bionic 2020-08-15 16:08:26.285 - debug: linux-control.0 (19029) [distributionInfo] Tinker (192.168.138.74:22): csvToJson result: [{"prop":"NAME","val":"Ubuntu"},{"prop":"VERSION","val":"18.04.4 LTS (Bionic Beaver)"},{"prop":"ID","val":"ubuntu"},{"prop":"ID_LIKE","val":"debian"},{"prop":"PRETTY_NAME","val":"Ubuntu 18.04.4 LTS"},{"prop":"VERSION_ID","val":"18.04"},{"prop":"HOME_URL","val":"https://www.ubuntu.com/"},{"prop":"SUPPORT_URL","val":"https://help.ubuntu.com/"},{"prop":"BUG_REPORT_URL","val":"https://bugs.launchpad.net/ubuntu/"},{"prop":"PRIVACY_POLICY_URL","val":"https://www.ubuntu.com/legal/terms-and-policies/privacy-policy"},{"prop":"VERSION_CODENAME","val":"bionic"},{"prop":"UBUNTU_CODENAME","val":"bionic"}] 2020-08-15 16:08:26.362 - debug: linux-control.0 (19029) [cmdAptUpdate] Tinker (192.168.138.74:22): no datapoints selected -> removing existing datapoints 2020-08-15 16:08:26.369 - debug: linux-control.0 (19029) [servicesInfo] Tinker (192.168.138.74:22): send command: 'systemctl list-units --type service --all --no-legend | awk '{out=""; for(i=5;i<=NF;i++){out=out" "$i}; print $1","$2","$3","$4","out}'' 2020-08-15 16:08:26.391 - debug: linux-control.0 (19029) [servicesInfo] Tinker (192.168.138.74:22): response stdout: alsa-restore.service,loaded,active,exited, Save/Restore Sound Card State alsa-state.service,loaded,inactive,dead, Manage Sound Card State (restore and store) apparmor.service,not-found,inactive,dead, apparmor.service apt-daily-upgrade.service,loaded,inactive,dead, Daily apt upgrade and clean activities apt-daily.service,loaded,inactive,dead, Daily apt download activities armbian-firstrun-config.service,loaded,inactive,dead, Armbian first run optional user configuration armbian-hardware-monitor.service,loaded,active,exited, Armbian hardware monitoring armbian-hardware-optimize.service,loaded,active,exited, Armbian hardware optimization armbian-ramlog.service,loaded,active,exited, Armbian memory supported logging armbian-zram-config.service,loaded,active,exited, Armbian ZRAM config armian-ramlog.service,not-found,inactive,dead, armian-ramlog.service auditd.service,not-found,inactive,dead, auditd.service bluetooth.service,loaded,active,running, Bluetooth service chrony.service,loaded,active,running, chrony, an NTP client/server connman.service,not-found,inactive,dead, connman.service console-screen.service,not-found,inactive,dead, console-screen.service console-setup.service,loaded,active,exited, Set console font and keymap cpufrequtils.service,loaded,active,exited, LSB: set CPUFreq kernel parameters cron.service,loaded,active,running, Regular background program processing daemon dbus.service,loaded,active,running, D-Bus System Message Bus display-manager.service,not-found,inactive,dead, display-manager.service emergency.service,loaded,inactive,dead, Emergency Shell fake-hwclock.service,loaded,active,exited, Restore / save the current clock fstrim.service,loaded,inactive,dead, Discard unused blocks getty-static.service,loaded,inactive,dead, getty on tty2-tty6 if dbus and logind are not available getty@tty1.service,loaded,active,running, Getty on tty1 haveged.service,loaded,active,running, Entropy daemon using the HAVEGE algorithm hostapd.service,loaded,active,exited, LSB: Advanced IEEE 802.11 management daemon influxdb.service,not-found,inactive,dead, influxdb.service iobroker.service,loaded,active,running, ioBroker Server kbd.service,not-found,inactive,dead, kbd.service keyboard-setup.service,loaded,active,exited, Set the console keyboard layout kmod-static-nodes.service,loaded,active,exited, Create list of required static device nodes for the current kernel loadcpufreq.service,loaded,active,exited, LSB: Load kernel modules needed to enable cpufreq scaling mariadb-server.service,not-found,inactive,dead, mariadb-server.service motd-news.service,loaded,inactive,dead, Message of the Day mountkernfs.service,masked,inactive,dead, mountkernfs.service mysql-server.service,not-found,inactive,dead, mysql-server.service networkd-dispatcher.service,loaded,active,running, Dispatcher daemon for systemd-networkd networking.service,loaded,active,exited, Raise network interfaces NetworkManager-wait-online.service,loaded,active,exited, Network Manager Wait Online NetworkManager.service,loaded,active,running, Network Manager ondemand.service,masked,inactive,dead, ondemand.service openntpd.service,not-found,inactive,dead, openntpd.service plymouth-quit-wait.service,not-found,inactive,dead, plymouth-quit-wait.service plymouth-start.service,not-found,inactive,dead, plymouth-start.service polkit.service,loaded,active,running, Authorization Manager rc-local.service,loaded,active,exited, /etc/rc.local Compatibility redis.service,not-found,inactive,dead, redis.service rescue.service,loaded,inactive,dead, Rescue Shell resolvconf-pull-resolved.service,loaded,inactive,dead, resolvconf-pull-resolved.service resolvconf.service,loaded,active,exited, Nameserver information manager rng-tools.service,loaded,active,running, rng-tools.service rsync.service,loaded,inactive,dead, fast remote file copy program daemon rsyslog.service,loaded,active,running, System Logging Service serial-getty@ttyS2.service,loaded,active,running, Serial Getty on ttyS2 setvtrgb.service,loaded,active,exited, Set console scheme ssh.service,loaded,active,running, OpenBSD Secure Shell server sysfsutils.service,loaded,active,exited, LSB: Set sysfs variables from /etc/sysfs.conf sysstat.service,loaded,active,exited, Resets System Activity Data Collector systemd-ask-password-console.service,loaded,inactive,dead, Dispatch Password Requests to Console systemd-ask-password-wall.service,loaded,inactive,dead, Forward Password Requests to Wall systemd-binfmt.service,loaded,inactive,dead, Set Up Additional Binary Formats systemd-fsck-root.service,loaded,inactive,dead, File System Check on Root Device systemd-fsckd.service,loaded,inactive,dead, File System Check Daemon to report status systemd-hwdb-update.service,loaded,inactive,dead, Rebuild Hardware Database systemd-initctl.service,loaded,inactive,dead, /dev/initctl Compatibility Daemon systemd-journal-flush.service,loaded,active,exited, Flush Journal to Persistent Storage systemd-journald.service,loaded,active,running, Journal Service systemd-logind.service,loaded,active,running, Login Service systemd-machine-id-commit.service,loaded,inactive,dead, Commit a transient machine-id on disk systemd-modules-load.service,loaded,active,exited, Load Kernel Modules systemd-networkd.service,loaded,inactive,dead, Network Service systemd-random-seed.service,loaded,active,exited, Load/Save Random Seed systemd-remount-fs.service,loaded,active,exited, Remount Root and Kernel File Systems systemd-resolved.service,loaded,active,running, Network Name Resolution systemd-rfkill.service,loaded,inactive,dead, Load/Save RF Kill Switch Status systemd-sysctl.service,loaded,active,exited, Apply Kernel Variables systemd-sysusers.service,not-found,inactive,dead, systemd-sysusers.service systemd-timesyncd.service,loaded,inactive,dead, Network Time Synchronization systemd-tmpfiles-clean.service,loaded,inactive,dead, Cleanup of Temporary Directories systemd-tmpfiles-setup-dev.service,loaded,active,exited, Create Static Device Nodes in /dev systemd-tmpfiles-setup.service,loaded,active,exited, Create Volatile Files and Directories systemd-udev-trigger.service,loaded,active,exited, udev Coldplug all Devices systemd-udevd.service,loaded,active,running, udev Kernel Device Manager systemd-update-done.service,not-found,inactive,dead, systemd-update-done.service systemd-update-utmp-runlevel.service,loaded,inactive,dead, Update UTMP about System Runlevel Changes systemd-update-utmp.service,loaded,active,exited, Update UTMP about System Boot/Shutdown systemd-user-sessions.service,loaded,active,exited, Permit User Sessions systemd-vconsole-setup.service,not-found,inactive,dead, systemd-vconsole-setup.service tinker-bluetooth.service,loaded,active,running, Realtek H5 bluetooth support unattended-upgrades.service,loaded,active,running, Unattended Upgrades Shutdown user@1002.service,loaded,active,running, User Manager for UID 1002 wpa_supplicant.service,loaded,active,running, WPA supplicant 2020-08-15 16:08:26.403 - debug: linux-control.0 (19029) [servicesInfo] Tinker (192.168.138.74:22): csvToJson result: [{"id":"alsa-restore.service","load":"loaded","active":"active","running":"exited","description":"Save/Restore Sound Card State"},{"id":"alsa-state.service","load":"loaded","active":"inactive","running":"dead","description":"Manage Sound Card State (restore and store)"},{"id":"apparmor.service","load":"not-found","active":"inactive","running":"dead","description":"apparmor.service"},{"id":"apt-daily-upgrade.service","load":"loaded","active":"inactive","running":"dead","description":"Daily apt upgrade and clean activities"},{"id":"apt-daily.service","load":"loaded","active":"inactive","running":"dead","description":"Daily apt download activities"},{"id":"armbian-firstrun-config.service","load":"loaded","active":"inactive","running":"dead","description":"Armbian first run optional user configuration"},{"id":"armbian-hardware-monitor.service","load":"loaded","active":"active","running":"exited","description":"Armbian hardware monitoring"},{"id":"armbian-hardware-optimize.service","load":"loaded","active":"active","running":"exited","description":"Armbian hardware optimization"},{"id":"armbian-ramlog.service","load":"loaded","active":"active","running":"exited","description":"Armbian memory supported logging"},{"id":"armbian-zram-config.service","load":"loaded","active":"active","running":"exited","description":"Armbian ZRAM config"},{"id":"armian-ramlog.service","load":"not-found","active":"inactive","running":"dead","description":"armian-ramlog.service"},{"id":"auditd.service","load":"not-found","active":"inactive","running":"dead","description":"auditd.service"},{"id":"bluetooth.service","load":"loaded","active":"active","running":"running","description":"Bluetooth service"},{"id":"chrony.service","load":"loaded","active":"active","running":"running","description":"chrony","field6":"an NTP client/server"},{"id":"connman.service","load":"not-found","active":"inactive","running":"dead","description":"connman.service"},{"id":"console-screen.service","load":"not-found","active":"inactive","running":"dead","description":"console-screen.service"},{"id":"console-setup.service","load":"loaded","active":"active","running":"exited","description":"Set console font and keymap"},{"id":"cpufrequtils.service","load":"loaded","active":"active","running":"exited","description":"LSB: set CPUFreq kernel parameters"},{"id":"cron.service","load":"loaded","active":"active","running":"running","description":"Regular background program processing daemon"},{"id":"dbus.service","load":"loaded","active":"active","running":"running","description":"D-Bus System Message Bus"},{"id":"display-manager.service","load":"not-found","active":"inactive","running":"dead","description":"display-manager.service"},{"id":"emergency.service","load":"loaded","active":"inactive","running":"dead","description":"Emergency Shell"},{"id":"fake-hwclock.service","load":"loaded","active":"active","running":"exited","description":"Restore / save the current clock"},{"id":"fstrim.service","load":"loaded","active":"inactive","running":"dead","description":"Discard unused blocks"},{"id":"getty-static.service","load":"loaded","active":"inactive","running":"dead","description":"getty on tty2-tty6 if dbus and logind are not available"},{"id":"getty@tty1.service","load":"loaded","active":"active","running":"running","description":"Getty on tty1"},{"id":"haveged.service","load":"loaded","active":"active","running":"running","description":"Entropy daemon using the HAVEGE algorithm"},{"id":"hostapd.service","load":"loaded","active":"active","running":"exited","description":"LSB: Advanced IEEE 802.11 management daemon"},{"id":"influxdb.service","load":"not-found","active":"inactive","running":"dead","description":"influxdb.service"},{"id":"iobroker.service","load":"loaded","active":"active","running":"running","description":"ioBroker Server"},{"id":"kbd.service","load":"not-found","active":"inactive","running":"dead","description":"kbd.service"},{"id":"keyboard-setup.service","load":"loaded","active":"active","running":"exited","description":"Set the console keyboard layout"},{"id":"kmod-static-nodes.service","load":"loaded","active":"active","running":"exited","description":"Create list of required static device nodes for the current kernel"},{"id":"loadcpufreq.service","load":"loaded","active":"active","running":"exited","description":"LSB: Load kernel modules needed to enable cpufreq scaling"},{"id":"mariadb-server.service","load":"not-found","active":"inactive","running":"dead","description":"mariadb-server.service"},{"id":"motd-news.service","load":"loaded","active":"inactive","running":"dead","description":"Message of the Day"},{"id":"mountkernfs.service","load":"masked","active":"inactive","running":"dead","description":"mountkernfs.service"},{"id":"mysql-server.service","load":"not-found","active":"inactive","running":"dead","description":"mysql-server.service"},{"id":"networkd-dispatcher.service","load":"loaded","active":"active","running":"running","description":"Dispatcher daemon for systemd-networkd"},{"id":"networking.service","load":"loaded","active":"active","running":"exited","description":"Raise network interfaces"},{"id":"NetworkManager-wait-online.service","load":"loaded","active":"active","running":"exited","description":"Network Manager Wait Online"},{"id":"NetworkManager.service","load":"loaded","active":"active","running":"running","description":"Network Manager"},{"id":"ondemand.service","load":"masked","active":"inactive","running":"dead","description":"ondemand.service"},{"id":"openntpd.service","load":"not-found","active":"inactive","running":"dead","description":"openntpd.service"},{"id":"plymouth-quit-wait.service","load":"not-found","active":"inactive","running":"dead","description":"plymouth-quit-wait.service"},{"id":"plymouth-start.service","load":"not-found","active":"inactive","running":"dead","description":"plymouth-start.service"},{"id":"polkit.service","load":"loaded","active":"active","running":"running","description":"Authorization Manager"},{"id":"rc-local.service","load":"loaded","active":"active","running":"exited","description":"/etc/rc.local Compatibility"},{"id":"redis.service","load":"not-found","active":"inactive","running":"dead","description":"redis.service"},{"id":"rescue.service","load":"loaded","active":"inactive","running":"dead","description":"Rescue Shell"},{"id":"resolvconf-pull-resolved.service","load":"loaded","active":"inactive","running":"dead","description":"resolvconf-pull-resolved.service"},{"id":"resolvconf.service","load":"loaded","active":"active","running":"exited","description":"Nameserver information manager"},{"id":"rng-tools.service","load":"loaded","active":"active","running":"running","description":"rng-tools.service"},{"id":"rsync.service","load":"loaded","active":"inactive","running":"dead","description":"fast remote file copy program daemon"},{"id":"rsyslog.service","load":"loaded","active":"active","running":"running","description":"System Logging Service"},{"id":"serial-getty@ttyS2.service","load":"loaded","active":"active","running":"running","description":"Serial Getty on ttyS2"},{"id":"setvtrgb.service","load":"loaded","active":"active","running":"exited","description":"Set console scheme"},{"id":"ssh.service","load":"loaded","active":"active","running":"running","description":"OpenBSD Secure Shell server"},{"id":"sysfsutils.service","load":"loaded","active":"active","running":"exited","description":"LSB: Set sysfs variables from /etc/sysfs.conf"},{"id":"sysstat.service","load":"loaded","active":"active","running":"exited","description":"Resets System Activity Data Collector"},{"id":"systemd-ask-password-console.service","load":"loaded","active":"inactive","running":"dead","description":"Dispatch Password Requests to Console"},{"id":"systemd-ask-password-wall.service","load":"loaded","active":"inactive","running":"dead","description":"Forward Password Requests to Wall"},{"id":"systemd-binfmt.service","load":"loaded","active":"inactive","running":"dead","description":"Set Up Additional Binary Formats"},{"id":"systemd-fsck-root.service","load":"loaded","active":"inactive","running":"dead","description":"File System Check on Root Device"},{"id":"systemd-fsckd.service","load":"loaded","active":"inactive","running":"dead","description":"File System Check Daemon to report status"},{"id":"systemd-hwdb-update.service","load":"loaded","active":"inactive","running":"dead","description":"Rebuild Hardware Database"},{"id":"systemd-initctl.service","load":"loaded","active":"inactive","running":"dead","description":"/dev/initctl Compatibility Daemon"},{"id":"systemd-journal-flush.service","load":"loaded","active":"active","running":"exited","description":"Flush Journal to Persistent Storage"},{"id":"systemd-journald.service","load":"loaded","active":"active","running":"running","description":"Journal Service"},{"id":"systemd-logind.service","load":"loaded","active":"active","running":"running","description":"Login Service"},{"id":"systemd-machine-id-commit.service","load":"loaded","active":"inactive","running":"dead","description":"Commit a transient machine-id on disk"},{"id":"systemd-modules-load.service","load":"loaded","active":"active","running":"exited","description":"Load Kernel Modules"},{"id":"systemd-networkd.service","load":"loaded","active":"inactive","running":"dead","description":"Network Service"},{"id":"systemd-random-seed.service","load":"loaded","active":"active","running":"exited","description":"Load/Save Random Seed"},{"id":"systemd-remount-fs.service","load":"loaded","active":"active","running":"exited","description":"Remount Root and Kernel File Systems"},{"id":"systemd-resolved.service","load":"loaded","active":"active","running":"running","description":"Network Name Resolution"},{"id":"systemd-rfkill.service","load":"loaded","active":"inactive","running":"dead","description":"Load/Save RF Kill Switch Status"},{"id":"systemd-sysctl.service","load":"loaded","active":"active","running":"exited","description":"Apply Kernel Variables"},{"id":"systemd-sysusers.service","load":"not-found","active":"inactive","running":"dead","description":"systemd-sysusers.service"},{"id":"systemd-timesyncd.service","load":"loaded","active":"inactive","running":"dead","description":"Network Time Synchronization"},{"id":"systemd-tmpfiles-clean.service","load":"loaded","active":"inactive","running":"dead","description":"Cleanup of Temporary Directories"},{"id":"systemd-tmpfiles-setup-dev.service","load":"loaded","active":"active","running":"exited","description":"Create Static Device Nodes in /dev"},{"id":"systemd-tmpfiles-setup.service","load":"loaded","active":"active","running":"exited","description":"Create Volatile Files and Directories"},{"id":"systemd-udev-trigger.service","load":"loaded","active":"active","running":"exited","description":"udev Coldplug all Devices"},{"id":"systemd-udevd.service","load":"loaded","active":"active","running":"running","description":"udev Kernel Device Manager"},{"id":"systemd-update-done.service","load":"not-found","active":"inactive","running":"dead","description":"systemd-update-done.service"},{"id":"systemd-update-utmp-runlevel.service","load":"loaded","active":"inactive","running":"dead","description":"Update UTMP about System Runlevel Changes"},{"id":"systemd-update-utmp.service","load":"loaded","active":"active","running":"exited","description":"Update UTMP about System Boot/Shutdown"},{"id":"systemd-user-sessions.service","load":"loaded","active":"active","running":"exited","description":"Permit User Sessions"},{"id":"systemd-vconsole-setup.service","load":"not-found","active":"inactive","running":"dead","description":"systemd-vconsole-setup.service"},{"id":"tinker-bluetooth.service","load":"loaded","active":"active","running":"running","description":"Realtek H5 bluetooth support"},{"id":"unattended-upgrades.service","load":"loaded","active":"active","running":"running","description":"Unattended Upgrades Shutdown"},{"id":"user@1002.service","load":"loaded","active":"active","running":"running","description":"User Manager for UID 1002"},{"id":"wpa_supplicant.service","load":"loaded","active":"active","running":"running","description":"WPA supplicant"}] 2020-08-15 16:08:26.816 - debug: linux-control.0 (19029) [needrestart] Tinker (192.168.138.74:22): no datapoints selected -> removing existing datapoints 2020-08-15 16:08:26.837 - debug: linux-control.0 (19029) [folderSizes] Tinker (192.168.138.74:22): send command: 'sudo du -sk /opt/iobroker/iobroker-data | awk '{ print $1 /1024 }'' 2020-08-15 16:08:26.904 - debug: linux-control.0 (19029) [folderSizes] Tinker (192.168.138.74:22): response stdout: Sorry, user pi is not allowed to execute '/usr/bin/du -sk /opt/iobroker/iobroker-data' as root on localhost. 2020-08-15 16:08:26.906 - debug: linux-control.0 (19029) [folderSizes] Tinker (192.168.138.74:22): Tinker.folders.iobroker.size: NaN MB 2020-08-15 16:08:26.948 - debug: linux-control.0 (19029) [folderSizes] Tinker (192.168.138.74:22): send command: 'sudo find /opt/iobroker/iobroker-data -name "*" | wc -l' 2020-08-15 16:08:27.154 - debug: linux-control.0 (19029) [folderSizes] Tinker (192.168.138.74:22): response stdout: Sorry, user pi is not allowed to execute '/usr/bin/find /opt/iobroker/iobroker-data -name *' as root on localhost. 0 2020-08-15 16:08:27.157 - debug: linux-control.0 (19029) [folderSizes] Tinker (192.168.138.74:22): Tinker.folders.iobroker.files: NaN Dateien 2020-08-15 16:08:27.208 - debug: linux-control.0 (19029) [folderSizes] Tinker (192.168.138.74:22): send command: 'tmp=$(sudo find /opt/iobroker/iobroker-data -name "*" -type f -exec stat -c "%Y %n" -- {} \; | sort -nr | head -n1 | awk '{print $2}') && date +%s -r $tmp' 2020-08-15 16:08:27.315 - debug: linux-control.0 (19029) [folderSizes] Tinker (192.168.138.74:22): response stdout: Sorry, user pi is not allowed to execute '/usr/bin/find /opt/iobroker/iobroker-data -name * -type f -exec stat -c %Y %n -- {} ;' as root on localhost. date: option requires an argument -- 'r' Try 'date --help' for more information. 2020-08-15 16:08:27.318 - debug: linux-control.0 (19029) [folderSizes] Tinker (192.168.138.74:22): Tinker.folders.iobroker.lastChange: NaN -> 2020-08-15 16:08:27.369 - debug: linux-control.0 (19029) [userCommand] Tinker (192.168.138.74:22, id: root, description: ): send command: 'df / | grep / | awk '{ print $5}' | sed 's/%//g'' 2020-08-15 16:08:27.415 - debug: linux-control.0 (19029) [userCommand] Tinker (192.168.138.74:22, id: root, description: ): response stdout: 5 2020-08-15 16:08:27.423 - debug: linux-control.0 (19029) [userCommand] Tinker (192.168.138.74:22, id: ip, description: ): send command: 'hostname -I | cut -d' ' -f1' 2020-08-15 16:08:27.467 - debug: linux-control.0 (19029) [userCommand] Tinker (192.168.138.74:22, id: ip, description: ): response stdout: 192.168.138.74 2020-08-15 16:08:27.476 - debug: linux-control.0 (19029) [userCommand] Tinker (192.168.138.74:22, id: cpu-temp, description: ): send command: 'cat /sys/devices/virtual/thermal/thermal_zone0/temp | awk '{print substr($1, length($0)-5,3)}'' 2020-08-15 16:08:27.519 - debug: linux-control.0 (19029) [userCommand] Tinker (192.168.138.74:22, id: cpu-temp, description: ): response stdout: 46 2020-08-15 16:08:27.527 - info: linux-control.0 (19029) successful received data from Tinker (192.168.138.74:22)scheint ein seltsames Problem mit dem Passwort bei sudo zu sein.
Beim Raspi kann man auch auf der Konsole Befehle mit sudo ohne weitere Passworteingabe durchführen. das geht weder beim Tinker (Armbian) noch beim der VM (Debian)seltsamerweise funktioniert es aber bei "meine Befehle".
bei der NUC_VM habe ich den gleichen Befehl (du -c /opt/iobroker/iobroker-data/history | tail -1 | awk '{printf $1MB}') nochmals unter "eigene Befehle" ausgeführt:
da klappt es:
@Scrounger sagte in Test Adapter Linux Control v0.x.x:
@Homoran
Hab noch was eingebaut, bitte teste mal die aktuelle github versionHabe neu installiert - upload gemacht und Instanz sicherheitshalber nochmal gestartet.
steht immer noch
nulldrinHier das leider sehr umfangreiche debug log:
2020-08-16 10:37:56.204 - [32minfo[39m: linux-control.0 (24751) getting data from RasPi4 (192.168.138.139:22) 2020-08-16 10:37:56.257 - [34mdebug[39m: linux-control.0 (24751) [getConnection] Host 'RasPi4' (192.168.138.139:22): using sudo for authentification 2020-08-16 10:37:56.428 - [34mdebug[39m: linux-control.0 (24751) [distributionInfo] RasPi4 (192.168.138.139:22): send command: 'cat /etc/os-release' 2020-08-16 10:37:56.732 - [34mdebug[39m: linux-control.0 (24751) [distributionInfo] RasPi4 (192.168.138.139:22): response stdout: PRETTY_NAME="Raspbian GNU/Linux 10 (buster)" NAME="Raspbian GNU/Linux" VERSION_ID="10" VERSION="10 (buster)" VERSION_CODENAME=buster ID=raspbian ID_LIKE=debian HOME_URL="http://www.raspbian.org/" SUPPORT_URL="http://www.raspbian.org/RaspbianForums" BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs" 2020-08-16 10:37:56.735 - [34mdebug[39m: linux-control.0 (24751) [distributionInfo] RasPi4 (192.168.138.139:22): csvToJson result: [{"prop":"PRETTY_NAME","val":"Raspbian GNU/Linux 10 (buster)"},{"prop":"NAME","val":"Raspbian GNU/Linux"},{"prop":"VERSION_ID","val":"10"},{"prop":"VERSION","val":"10 (buster)"},{"prop":"VERSION_CODENAME","val":"buster"},{"prop":"ID","val":"raspbian"},{"prop":"ID_LIKE","val":"debian"},{"prop":"HOME_URL","val":"http://www.raspbian.org/"},{"prop":"SUPPORT_URL","val":"http://www.raspbian.org/RaspbianForums"},{"prop":"BUG_REPORT_URL","val":"http://www.raspbian.org/RaspbianBugs"}] 2020-08-16 10:37:56.752 - [34mdebug[39m: linux-control.0 (24751) [cmdAptUpdate] RasPi4 (192.168.138.139:22): no datapoints selected -> removing existing datapoints 2020-08-16 10:37:56.755 - [34mdebug[39m: linux-control.0 (24751) [servicesInfo] RasPi4 (192.168.138.139:22): send command: 'systemctl list-units --type service --all --no-legend | awk '{out=""; for(i=5;i<=NF;i++){out=out" "$i}; print $1","$2","$3","$4","out}'' 2020-08-16 10:37:56.780 - [34mdebug[39m: linux-control.0 (24751) [servicesInfo] RasPi4 (192.168.138.139:22): response stdout: alsa-restore.service,loaded,active,exited, Save/Restore Sound Card State alsa-state.service,loaded,active,running, Manage Sound Card State (restore and store) apparmor.service,not-found,inactive,dead, apparmor.service apt-daily-upgrade.service,loaded,inactive,dead, Daily apt upgrade and clean activities apt-daily.service,loaded,inactive,dead, Daily apt download activities auditd.service,not-found,inactive,dead, auditd.service auth-rpcgss-module.service,loaded,inactive,dead, Kernel Module supporting RPCSEC_GSS avahi-daemon.service,loaded,active,running, Avahi mDNS/DNS-SD Stack bluetooth.service,loaded,active,running, Bluetooth service bthelper@hci0.service,loaded,inactive,dead, Raspberry Pi bluetooth helper connman.service,not-found,inactive,dead, connman.service console-screen.service,not-found,inactive,dead, console-screen.service console-setup.service,loaded,active,exited, Set console font and keymap cron.service,loaded,active,running, Regular background program processing daemon dbus.service,loaded,active,running, D-Bus System Message Bus dhcpcd.service,loaded,active,running, dhcpcd on all interfaces display-manager.service,not-found,inactive,dead, display-manager.service dphys-swapfile.service,loaded,active,exited, dphys-swapfile - set up, mount/unmount, and delete a swap file emergency.service,loaded,inactive,dead, Emergency Shell fake-hwclock.service,loaded,active,exited, Restore / save the current clock getty-static.service,loaded,inactive,dead, getty on tty2-tty6 if dbus and logind are not available getty@tty1.service,loaded,active,running, Getty on tty1 gssproxy.service,not-found,inactive,dead, gssproxy.service hciuart.service,loaded,active,running, Configure Bluetooth Modems connected by UART ifupdown-pre.service,loaded,active,exited, Helper to synchronize boot up for ifupdown influxdb.service,not-found,inactive,dead, influxdb.service iobroker.service,loaded,active,running, ioBroker Server kbd.service,not-found,inactive,dead, kbd.service keyboard-setup.service,loaded,active,exited, Set the console keyboard layout kmod-static-nodes.service,loaded,active,exited, Create list of required static device nodes for the current kernel logrotate.service,loaded,inactive,dead, Rotate log files man-db.service,loaded,inactive,dead, Daily man-db regeneration mariadb-server.service,not-found,inactive,dead, mariadb-server.service mountkernfs.service,masked,inactive,dead, mountkernfs.service mysql-server.service,not-found,inactive,dead, mysql-server.service networking.service,loaded,active,exited, Raise network interfaces NetworkManager.service,not-found,inactive,dead, NetworkManager.service nfs-blkmap.service,not-found,inactive,dead, nfs-blkmap.service nfs-config.service,loaded,inactive,dead, Preprocess NFS configuration nfs-server.service,not-found,inactive,dead, nfs-server.service nfs-utils.service,loaded,inactive,dead, NFS server and client services plymouth-quit-wait.service,not-found,inactive,dead, plymouth-quit-wait.service plymouth-start.service,not-found,inactive,dead, plymouth-start.service raspberrypi-net-mods.service,loaded,inactive,dead, Copy user wpa_supplicant.conf raspi-config.service,loaded,active,exited, LSB: Switch to ondemand cpu governor (unless shift key is pressed) rc-local.service,loaded,active,exited, /etc/rc.local Compatibility redis.service,not-found,inactive,dead, redis.service regenerate_ssh_host_keys.service,loaded,inactive,dead, Regenerate SSH host keys rescue.service,loaded,inactive,dead, Rescue Shell rng-tools.service,loaded,active,running, rng-tools.service rpc-gssd.service,loaded,inactive,dead, RPC security service for NFS client and server rpc-svcgssd.service,loaded,inactive,dead, RPC security service for NFS server rpi-eeprom-update.service,loaded,active,exited, Check for Raspberry Pi EEPROM updates rsync.service,loaded,inactive,dead, fast remote file copy program daemon rsyslog.service,loaded,active,running, System Logging Service ssh.service,loaded,active,running, OpenBSD Secure Shell server sshswitch.service,loaded,inactive,dead, Turn on SSH if /boot/ssh is present systemd-ask-password-console.service,loaded,inactive,dead, Dispatch Password Requests to Console systemd-ask-password-wall.service,loaded,inactive,dead, Forward Password Requests to Wall systemd-binfmt.service,loaded,inactive,dead, Set Up Additional Binary Formats systemd-fsck-root.service,loaded,active,exited, File System Check on Root Device systemd-fsck@dev-disk-by\x2dpartuuid-50fbae26\x2d01.service,loaded,active,exited, File System Check on /dev/disk/by-partuuid/50fbae26-01 systemd-fsckd.service,loaded,inactive,dead, File System Check Daemon to report status systemd-hwdb-update.service,loaded,inactive,dead, Rebuild Hardware Database systemd-initctl.service,loaded,inactive,dead, initctl Compatibility Daemon systemd-journal-flush.service,loaded,active,exited, Flush Journal to Persistent Storage systemd-journald.service,loaded,active,running, Journal Service systemd-logind.service,loaded,active,running, Login Service systemd-machine-id-commit.service,loaded,inactive,dead, Commit a transient machine-id on disk systemd-modules-load.service,loaded,active,exited, Load Kernel Modules systemd-networkd.service,loaded,inactive,dead, Network Service systemd-quotacheck.service,loaded,inactive,dead, File System Quota Check systemd-random-seed.service,loaded,active,exited, Load/Save Random Seed systemd-remount-fs.service,loaded,active,exited, Remount Root and Kernel File Systems systemd-rfkill.service,loaded,inactive,dead, Load/Save RF Kill Switch Status systemd-sysctl.service,loaded,active,exited, Apply Kernel Variables systemd-sysusers.service,loaded,active,exited, Create System Users systemd-timesyncd.service,loaded,active,running, Network Time Synchronization systemd-tmpfiles-clean.service,loaded,inactive,dead, Cleanup of Temporary Directories systemd-tmpfiles-setup-dev.service,loaded,active,exited, Create Static Device Nodes in /dev systemd-tmpfiles-setup.service,loaded,active,exited, Create Volatile Files and Directories systemd-udev-trigger.service,loaded,active,exited, udev Coldplug all Devices systemd-udevd.service,loaded,active,running, udev Kernel Device Manager systemd-update-done.service,not-found,inactive,dead, systemd-update-done.service systemd-update-utmp-runlevel.service,loaded,inactive,dead, Update UTMP about System Runlevel Changes systemd-update-utmp.service,loaded,active,exited, Update UTMP about System Boot/Shutdown systemd-user-sessions.service,loaded,active,exited, Permit User Sessions systemd-vconsole-setup.service,not-found,inactive,dead, systemd-vconsole-setup.service triggerhappy.service,loaded,active,running, triggerhappy global hotkey daemon user-runtime-dir@1000.service,loaded,active,exited, User Runtime Directory /run/user/1000 user@1000.service,loaded,active,running, User Manager for UID 1000 wpa_supplicant.service,loaded,active,running, WPA supplicant 2020-08-16 10:37:56.785 - [34mdebug[39m: linux-control.0 (24751) [servicesInfo] RasPi4 (192.168.138.139:22): csvToJson result: [{"id":"alsa-restore.service","load":"loaded","active":"active","running":"exited","description":"Save/Restore Sound Card State"},{"id":"alsa-state.service","load":"loaded","active":"active","running":"running","description":"Manage Sound Card State (restore and store)"},{"id":"apparmor.service","load":"not-found","active":"inactive","running":"dead","description":"apparmor.service"},{"id":"apt-daily-upgrade.service","load":"loaded","active":"inactive","running":"dead","description":"Daily apt upgrade and clean activities"},{"id":"apt-daily.service","load":"loaded","active":"inactive","running":"dead","description":"Daily apt download activities"},{"id":"auditd.service","load":"not-found","active":"inactive","running":"dead","description":"auditd.service"},{"id":"auth-rpcgss-module.service","load":"loaded","active":"inactive","running":"dead","description":"Kernel Module supporting RPCSEC_GSS"},{"id":"avahi-daemon.service","load":"loaded","active":"active","running":"running","description":"Avahi mDNS/DNS-SD Stack"},{"id":"bluetooth.service","load":"loaded","active":"active","running":"running","description":"Bluetooth service"},{"id":"bthelper@hci0.service","load":"loaded","active":"inactive","running":"dead","description":"Raspberry Pi bluetooth helper"},{"id":"connman.service","load":"not-found","active":"inactive","running":"dead","description":"connman.service"},{"id":"console-screen.service","load":"not-found","active":"inactive","running":"dead","description":"console-screen.service"},{"id":"console-setup.service","load":"loaded","active":"active","running":"exited","description":"Set console font and keymap"},{"id":"cron.service","load":"loaded","active":"active","running":"running","description":"Regular background program processing daemon"},{"id":"dbus.service","load":"loaded","active":"active","running":"running","description":"D-Bus System Message Bus"},{"id":"dhcpcd.service","load":"loaded","active":"active","running":"running","description":"dhcpcd on all interfaces"},{"id":"display-manager.service","load":"not-found","active":"inactive","running":"dead","description":"display-manager.service"},{"id":"dphys-swapfile.service","load":"loaded","active":"active","running":"exited","description":"dphys-swapfile - set up","field6":"mount/unmount","field7":"and delete a swap file"},{"id":"emergency.service","load":"loaded","active":"inactive","running":"dead","description":"Emergency Shell"},{"id":"fake-hwclock.service","load":"loaded","active":"active","running":"exited","description":"Restore / save the current clock"},{"id":"getty-static.service","load":"loaded","active":"inactive","running":"dead","description":"getty on tty2-tty6 if dbus and logind are not available"},{"id":"getty@tty1.service","load":"loaded","active":"active","running":"running","description":"Getty on tty1"},{"id":"gssproxy.service","load":"not-found","active":"inactive","running":"dead","description":"gssproxy.service"},{"id":"hciuart.service","load":"loaded","active":"active","running":"running","description":"Configure Bluetooth Modems connected by UART"},{"id":"ifupdown-pre.service","load":"loaded","active":"active","running":"exited","description":"Helper to synchronize boot up for ifupdown"},{"id":"influxdb.service","load":"not-found","active":"inactive","running":"dead","description":"influxdb.service"},{"id":"iobroker.service","load":"loaded","active":"active","running":"running","description":"ioBroker Server"},{"id":"kbd.service","load":"not-found","active":"inactive","running":"dead","description":"kbd.service"},{"id":"keyboard-setup.service","load":"loaded","active":"active","running":"exited","description":"Set the console keyboard layout"},{"id":"kmod-static-nodes.service","load":"loaded","active":"active","running":"exited","description":"Create list of required static device nodes for the current kernel"},{"id":"logrotate.service","load":"loaded","active":"inactive","running":"dead","description":"Rotate log files"},{"id":"man-db.service","load":"loaded","active":"inactive","running":"dead","description":"Daily man-db regeneration"},{"id":"mariadb-server.service","load":"not-found","active":"inactive","running":"dead","description":"mariadb-server.service"},{"id":"mountkernfs.service","load":"masked","active":"inactive","running":"dead","description":"mountkernfs.service"},{"id":"mysql-server.service","load":"not-found","active":"inactive","running":"dead","description":"mysql-server.service"},{"id":"networking.service","load":"loaded","active":"active","running":"exited","description":"Raise network interfaces"},{"id":"NetworkManager.service","load":"not-found","active":"inactive","running":"dead","description":"NetworkManager.service"},{"id":"nfs-blkmap.service","load":"not-found","active":"inactive","running":"dead","description":"nfs-blkmap.service"},{"id":"nfs-config.service","load":"loaded","active":"inactive","running":"dead","description":"Preprocess NFS configuration"},{"id":"nfs-server.service","load":"not-found","active":"inactive","running":"dead","description":"nfs-server.service"},{"id":"nfs-utils.service","load":"loaded","active":"inactive","running":"dead","description":"NFS server and client services"},{"id":"plymouth-quit-wait.service","load":"not-found","active":"inactive","running":"dead","description":"plymouth-quit-wait.service"},{"id":"plymouth-start.service","load":"not-found","active":"inactive","running":"dead","description":"plymouth-start.service"},{"id":"raspberrypi-net-mods.service","load":"loaded","active":"inactive","running":"dead","description":"Copy user wpa_supplicant.conf"},{"id":"raspi-config.service","load":"loaded","active":"active","running":"exited","description":"LSB: Switch to ondemand cpu governor (unless shift key is pressed)"},{"id":"rc-local.service","load":"loaded","active":"active","running":"exited","description":"/etc/rc.local Compatibility"},{"id":"redis.service","load":"not-found","active":"inactive","running":"dead","description":"redis.service"},{"id":"regenerate_ssh_host_keys.service","load":"loaded","active":"inactive","running":"dead","description":"Regenerate SSH host keys"},{"id":"rescue.service","load":"loaded","active":"inactive","running":"dead","description":"Rescue Shell"},{"id":"rng-tools.service","load":"loaded","active":"active","running":"running","description":"rng-tools.service"},{"id":"rpc-gssd.service","load":"loaded","active":"inactive","running":"dead","description":"RPC security service for NFS client and server"},{"id":"rpc-svcgssd.service","load":"loaded","active":"inactive","running":"dead","description":"RPC security service for NFS server"},{"id":"rpi-eeprom-update.service","load":"loaded","active":"active","running":"exited","description":"Check for Raspberry Pi EEPROM updates"},{"id":"rsync.service","load":"loaded","active":"inactive","running":"dead","description":"fast remote file copy program daemon"},{"id":"rsyslog.service","load":"loaded","active":"active","running":"running","description":"System Logging Service"},{"id":"ssh.service","load":"loaded","active":"active","running":"running","description":"OpenBSD Secure Shell server"},{"id":"sshswitch.service","load":"loaded","active":"inactive","running":"dead","description":"Turn on SSH if /boot/ssh is present"},{"id":"systemd-ask-password-console.service","load":"loaded","active":"inactive","running":"dead","description":"Dispatch Password Requests to Console"},{"id":"systemd-ask-password-wall.service","load":"loaded","active":"inactive","running":"dead","description":"Forward Password Requests to Wall"},{"id":"systemd-binfmt.service","load":"loaded","active":"inactive","running":"dead","description":"Set Up Additional Binary Formats"},{"id":"systemd-fsck-root.service","load":"loaded","active":"active","running":"exited","description":"File System Check on Root Device"},{"id":"systemd-fsck@dev-disk-by\\x2dpartuuid-50fbae26\\x2d01.service","load":"loaded","active":"active","running":"exited","description":"File System Check on /dev/disk/by-partuuid/50fbae26-01"},{"id":"systemd-fsckd.service","load":"loaded","active":"inactive","running":"dead","description":"File System Check Daemon to report status"},{"id":"systemd-hwdb-update.service","load":"loaded","active":"inactive","running":"dead","description":"Rebuild Hardware Database"},{"id":"systemd-initctl.service","load":"loaded","active":"inactive","running":"dead","description":"initctl Compatibility Daemon"},{"id":"systemd-journal-flush.service","load":"loaded","active":"active","running":"exited","description":"Flush Journal to Persistent Storage"},{"id":"systemd-journald.service","load":"loaded","active":"active","running":"running","description":"Journal Service"},{"id":"systemd-logind.service","load":"loaded","active":"active","running":"running","description":"Login Service"},{"id":"systemd-machine-id-commit.service","load":"loaded","active":"inactive","running":"dead","description":"Commit a transient machine-id on disk"},{"id":"systemd-modules-load.service","load":"loaded","active":"active","running":"exited","description":"Load Kernel Modules"},{"id":"systemd-networkd.service","load":"loaded","active":"inactive","running":"dead","description":"Network Service"},{"id":"systemd-quotacheck.service","load":"loaded","active":"inactive","running":"dead","description":"File System Quota Check"},{"id":"systemd-random-seed.service","load":"loaded","active":"active","running":"exited","description":"Load/Save Random Seed"},{"id":"systemd-remount-fs.service","load":"loaded","active":"active","running":"exited","description":"Remount Root and Kernel File Systems"},{"id":"systemd-rfkill.service","load":"loaded","active":"inactive","running":"dead","description":"Load/Save RF Kill Switch Status"},{"id":"systemd-sysctl.service","load":"loaded","active":"active","running":"exited","description":"Apply Kernel Variables"},{"id":"systemd-sysusers.service","load":"loaded","active":"active","running":"exited","description":"Create System Users"},{"id":"systemd-timesyncd.service","load":"loaded","active":"active","running":"running","description":"Network Time Synchronization"},{"id":"systemd-tmpfiles-clean.service","load":"loaded","active":"inactive","running":"dead","description":"Cleanup of Temporary Directories"},{"id":"systemd-tmpfiles-setup-dev.service","load":"loaded","active":"active","running":"exited","description":"Create Static Device Nodes in /dev"},{"id":"systemd-tmpfiles-setup.service","load":"loaded","active":"active","running":"exited","description":"Create Volatile Files and Directories"},{"id":"systemd-udev-trigger.service","load":"loaded","active":"active","running":"exited","description":"udev Coldplug all Devices"},{"id":"systemd-udevd.service","load":"loaded","active":"active","running":"running","description":"udev Kernel Device Manager"},{"id":"systemd-update-done.service","load":"not-found","active":"inactive","running":"dead","description":"systemd-update-done.service"},{"id":"systemd-update-utmp-runlevel.service","load":"loaded","active":"inactive","running":"dead","description":"Update UTMP about System Runlevel Changes"},{"id":"systemd-update-utmp.service","load":"loaded","active":"active","running":"exited","description":"Update UTMP about System Boot/Shutdown"},{"id":"systemd-user-sessions.service","load":"loaded","active":"active","running":"exited","description":"Permit User Sessions"},{"id":"systemd-vconsole-setup.service","load":"not-found","active":"inactive","running":"dead","description":"systemd-vconsole-setup.service"},{"id":"triggerhappy.service","load":"loaded","active":"active","running":"running","description":"triggerhappy global hotkey daemon"},{"id":"user-runtime-dir@1000.service","load":"loaded","active":"active","running":"exited","description":"User Runtime Directory /run/user/1000"},{"id":"user@1000.service","load":"loaded","active":"active","running":"running","description":"User Manager for UID 1000"},{"id":"wpa_supplicant.service","load":"loaded","active":"active","running":"running","description":"WPA supplicant"}] 2020-08-16 10:37:57.213 - [34mdebug[39m: linux-control.0 (24751) [needrestart] RasPi4 (192.168.138.139:22): no datapoints selected -> removing existing datapoints 2020-08-16 10:37:57.231 - [34mdebug[39m: linux-control.0 (24751) [folderSizes] RasPi4 (192.168.138.139:22): send command: 'sudo du -sk /opt/iobroker/iobroker-data/history | awk '{ print $1 /1024 }' | tail -1' 2020-08-16 10:37:57.464 - [34mdebug[39m: linux-control.0 (24751) [folderSizes] RasPi4 (192.168.138.139:22): response stdout: 195.422 2020-08-16 10:37:57.466 - [34mdebug[39m: linux-control.0 (24751) [folderSizes] RasPi4 (192.168.138.139:22): RasPi4.folders.history.size: 195.42 MB 2020-08-16 10:37:57.469 - [34mdebug[39m: linux-control.0 (24751) [folderSizes] RasPi4 (192.168.138.139:22): send command: 'sudo find /opt/iobroker/iobroker-data/history -name "*" | wc -l | tail -1' 2020-08-16 10:37:57.674 - [34mdebug[39m: linux-control.0 (24751) [folderSizes] RasPi4 (192.168.138.139:22): response stdout: 22286 2020-08-16 10:37:57.675 - [34mdebug[39m: linux-control.0 (24751) [folderSizes] RasPi4 (192.168.138.139:22): RasPi4.folders.history.files: 22286 Dateien 2020-08-16 10:37:57.679 - [34mdebug[39m: linux-control.0 (24751) [folderSizes] RasPi4 (192.168.138.139:22): send command: 'tmp=$(sudo find /opt/iobroker/iobroker-data/history -name "*" -type f -exec stat -c "%Y %n" -- {} \; | sort -nr | head -n1 | awk '{print $2}' | tail -1) && date +%s -r $tmp' 2020-08-16 10:39:35.043 - [34mdebug[39m: linux-control.0 (24751) [folderSizes] RasPi4 (192.168.138.139:22): response stdout: 1597567063 2020-08-16 10:39:35.044 - [34mdebug[39m: linux-control.0 (24751) [folderSizes] RasPi4 (192.168.138.139:22): RasPi4.folders.history.lastChange: 1597567063000 -> 16.08.2020 10:37 2020-08-16 10:39:35.048 - [34mdebug[39m: linux-control.0 (24751) [userCommand] RasPi4 (192.168.138.139:22, id: root, description: ): send command: 'df / | grep / | awk '{ print $5}' | sed 's/%//g'' 2020-08-16 10:39:35.066 - [34mdebug[39m: linux-control.0 (24751) [userCommand] RasPi4 (192.168.138.139:22, id: root, description: ): response stdout: 19 2020-08-16 10:39:35.070 - [34mdebug[39m: linux-control.0 (24751) [userCommand] RasPi4 (192.168.138.139:22, id: ip, description: ): send command: 'hostname -I | cut -d' ' -f1' 2020-08-16 10:39:35.091 - [34mdebug[39m: linux-control.0 (24751) [userCommand] RasPi4 (192.168.138.139:22, id: ip, description: ): response stdout: 192.168.138.139 2020-08-16 10:39:35.096 - [34mdebug[39m: linux-control.0 (24751) [userCommand] RasPi4 (192.168.138.139:22, id: cpu-temp, description: ): send command: 'vcgencmd measure_temp | awk '{print substr($1, length($0)-5,4)}'' 2020-08-16 10:39:35.112 - [34mdebug[39m: linux-control.0 (24751) [userCommand] RasPi4 (192.168.138.139:22, id: cpu-temp, description: ): response stdout: 55.0 2020-08-16 10:39:35.117 - [32minfo[39m: linux-control.0 (24751) successful received data from RasPi4 (192.168.138.139:22) 2020-08-16 10:40:00.035 - [32minfo[39m: host.raspberrypi instance system.adapter.dwd.0 started with pid 5509 2020-08-16 10:40:03.867 - [32minfo[39m: dwd.0 (5509) starting. Version 2.5.0 in /opt/iobroker/node_modules/iobroker.dwd, node: v10.21.0, js-controller: 3.1.4 2020-08-16 10:40:05.425 - [32minfo[39m: dwd.0 (5509) Terminated (NO_ERROR): Without reason 2020-08-16 10:40:05.952 - [32minfo[39m: host.raspberrypi instance system.adapter.dwd.0 terminated with code 0 (NO_ERROR) 2020-08-16 10:40:20.852 - [32minfo[39m: linux-control.0 (24751) getting data from NUC_VM (192.168.138.123:22) 2020-08-16 10:40:20.886 - [34mdebug[39m: linux-control.0 (24751) [getConnection] Host 'NUC_VM' (192.168.138.123:22): using sudo for authentification 2020-08-16 10:40:20.969 - [34mdebug[39m: linux-control.0 (24751) [distributionInfo] NUC_VM (192.168.138.123:22): send command: 'cat /etc/os-release' 2020-08-16 10:40:21.025 - [34mdebug[39m: linux-control.0 (24751) [distributionInfo] NUC_VM (192.168.138.123:22): response stdout: PRETTY_NAME="Debian GNU/Linux 10 (buster)" NAME="Debian GNU/Linux" VERSION_ID="10" VERSION="10 (buster)" VERSION_CODENAME=buster ID=debian HOME_URL="https://www.debian.org/" SUPPORT_URL="https://www.debian.org/support" BUG_REPORT_URL="https://bugs.debian.org/" 2020-08-16 10:40:21.028 - [34mdebug[39m: linux-control.0 (24751) [distributionInfo] NUC_VM (192.168.138.123:22): csvToJson result: [{"prop":"PRETTY_NAME","val":"Debian GNU/Linux 10 (buster)"},{"prop":"NAME","val":"Debian GNU/Linux"},{"prop":"VERSION_ID","val":"10"},{"prop":"VERSION","val":"10 (buster)"},{"prop":"VERSION_CODENAME","val":"buster"},{"prop":"ID","val":"debian"},{"prop":"HOME_URL","val":"https://www.debian.org/"},{"prop":"SUPPORT_URL","val":"https://www.debian.org/support"},{"prop":"BUG_REPORT_URL","val":"https://bugs.debian.org/"}] 2020-08-16 10:40:21.045 - [34mdebug[39m: linux-control.0 (24751) [cmdAptUpdate] NUC_VM (192.168.138.123:22): no datapoints selected -> removing existing datapoints 2020-08-16 10:40:21.049 - [34mdebug[39m: linux-control.0 (24751) [servicesInfo] NUC_VM (192.168.138.123:22): send command: 'systemctl list-units --type service --all --no-legend | awk '{out=""; for(i=5;i<=NF;i++){out=out" "$i}; print $1","$2","$3","$4","out}'' 2020-08-16 10:40:21.060 - [34mdebug[39m: linux-control.0 (24751) [servicesInfo] NUC_VM (192.168.138.123:22): response stdout: apache2.service,loaded,active,running, The Apache HTTP Server apparmor.service,loaded,active,exited, Load AppArmor profiles apt-daily-upgrade.service,loaded,inactive,dead, Daily apt upgrade and clean activities apt-daily.service,loaded,inactive,dead, Daily apt download activities auditd.service,not-found,inactive,dead, auditd.service auth-rpcgss-module.service,loaded,inactive,dead, Kernel Module supporting RPCSEC_GSS avahi-daemon.service,loaded,active,running, Avahi mDNS/DNS-SD Stack clamav-daemon.service,not-found,inactive,dead, clamav-daemon.service connman.service,not-found,inactive,dead, connman.service console-screen.service,not-found,inactive,dead, console-screen.service console-setup.service,loaded,active,exited, Set console font and keymap cron.service,loaded,active,running, Regular background program processing daemon cups-browsed.service,loaded,failed,failed, Make remote CUPS printers available locally cups.service,loaded,active,running, CUPS Scheduler dbus.service,loaded,active,running, D-Bus System Message Bus display-manager.service,not-found,inactive,dead, display-manager.service emergency.service,loaded,inactive,dead, Emergency Shell exim4.service,loaded,active,running, LSB: exim Mail Transport Agent getty-static.service,loaded,inactive,dead, getty on tty2-tty6 if dbus and logind are not available getty@tty1.service,loaded,active,running, Getty on tty1 greylist.service,not-found,inactive,dead, greylist.service gssproxy.service,not-found,inactive,dead, gssproxy.service ifup@ens18.service,loaded,active,exited, ifup for ens18 ifupdown-pre.service,loaded,active,exited, Helper to synchronize boot up for ifupdown influxdb.service,not-found,inactive,dead, influxdb.service iobroker.service,loaded,active,running, ioBroker Server irqbalance.service,loaded,active,running, irqbalance daemon kbd.service,not-found,inactive,dead, kbd.service keyboard-setup.service,loaded,active,exited, Set the console keyboard layout kmod-static-nodes.service,loaded,active,exited, Create list of required static device nodes for the current kernel logrotate.service,loaded,inactive,dead, Rotate log files man-db.service,loaded,inactive,dead, Daily man-db regeneration mariadb-server.service,not-found,inactive,dead, mariadb-server.service mysql-server.service,not-found,inactive,dead, mysql-server.service mysql.service,not-found,inactive,dead, mysql.service networking.service,loaded,active,exited, Raise network interfaces NetworkManager.service,not-found,inactive,dead, NetworkManager.service nfs-blkmap.service,not-found,inactive,dead, nfs-blkmap.service nfs-config.service,loaded,inactive,dead, Preprocess NFS configuration nfs-server.service,not-found,inactive,dead, nfs-server.service nfs-utils.service,loaded,inactive,dead, NFS server and client services ntp.service,loaded,active,running, Network Time Service plymouth-quit-wait.service,not-found,inactive,dead, plymouth-quit-wait.service plymouth-start.service,not-found,inactive,dead, plymouth-start.service postgresql.service,not-found,inactive,dead, postgresql.service rc-local.service,loaded,inactive,dead, /etc/rc.local Compatibility redis.service,not-found,inactive,dead, redis.service rescue.service,loaded,inactive,dead, Rescue Shell rpc-gssd.service,loaded,inactive,dead, RPC security service for NFS client and server rpc-svcgssd.service,loaded,inactive,dead, RPC security service for NFS server rpcbind.service,loaded,active,running, RPC bind portmap service rsync.service,loaded,inactive,dead, fast remote file copy program daemon rsyslog.service,loaded,active,running, System Logging Service spamassassin.service,not-found,inactive,dead, spamassassin.service ssh.service,loaded,active,running, OpenBSD Secure Shell server systemd-ask-password-console.service,loaded,inactive,dead, Dispatch Password Requests to Console systemd-ask-password-wall.service,loaded,inactive,dead, Forward Password Requests to Wall systemd-binfmt.service,loaded,inactive,dead, Set Up Additional Binary Formats systemd-fsck-root.service,loaded,inactive,dead, File System Check on Root Device systemd-fsckd.service,loaded,inactive,dead, File System Check Daemon to report status systemd-hwdb-update.service,loaded,inactive,dead, Rebuild Hardware Database systemd-initctl.service,loaded,inactive,dead, initctl Compatibility Daemon systemd-journal-flush.service,loaded,active,exited, Flush Journal to Persistent Storage systemd-journald.service,loaded,active,running, Journal Service systemd-logind.service,loaded,active,running, Login Service systemd-machine-id-commit.service,loaded,inactive,dead, Commit a transient machine-id on disk systemd-modules-load.service,loaded,active,exited, Load Kernel Modules systemd-networkd.service,loaded,inactive,dead, Network Service systemd-random-seed.service,loaded,active,exited, Load/Save Random Seed systemd-remount-fs.service,loaded,active,exited, Remount Root and Kernel File Systems systemd-sysctl.service,loaded,active,exited, Apply Kernel Variables systemd-sysusers.service,loaded,active,exited, Create System Users systemd-timesyncd.service,loaded,inactive,dead, Network Time Synchronization systemd-tmpfiles-clean.service,loaded,inactive,dead, Cleanup of Temporary Directories systemd-tmpfiles-setup-dev.service,loaded,active,exited, Create Static Device Nodes in /dev systemd-tmpfiles-setup.service,loaded,active,exited, Create Volatile Files and Directories systemd-udev-trigger.service,loaded,active,exited, udev Coldplug all Devices systemd-udevd.service,loaded,active,running, udev Kernel Device Manager systemd-update-done.service,not-found,inactive,dead, systemd-update-done.service systemd-update-utmp-runlevel.service,loaded,inactive,dead, Update UTMP about System Runlevel Changes systemd-update-utmp.service,loaded,active,exited, Update UTMP about System Boot/Shutdown systemd-user-sessions.service,loaded,active,exited, Permit User Sessions systemd-vconsole-setup.service,not-found,inactive,dead, systemd-vconsole-setup.service user-runtime-dir@1000.service,loaded,active,exited, User Runtime Directory /run/user/1000 user@1000.service,loaded,active,running, User Manager for UID 1000 2020-08-16 10:40:21.065 - [34mdebug[39m: linux-control.0 (24751) [servicesInfo] NUC_VM (192.168.138.123:22): csvToJson result: [{"id":"apache2.service","load":"loaded","active":"active","running":"running","description":"The Apache HTTP Server"},{"id":"apparmor.service","load":"loaded","active":"active","running":"exited","description":"Load AppArmor profiles"},{"id":"apt-daily-upgrade.service","load":"loaded","active":"inactive","running":"dead","description":"Daily apt upgrade and clean activities"},{"id":"apt-daily.service","load":"loaded","active":"inactive","running":"dead","description":"Daily apt download activities"},{"id":"auditd.service","load":"not-found","active":"inactive","running":"dead","description":"auditd.service"},{"id":"auth-rpcgss-module.service","load":"loaded","active":"inactive","running":"dead","description":"Kernel Module supporting RPCSEC_GSS"},{"id":"avahi-daemon.service","load":"loaded","active":"active","running":"running","description":"Avahi mDNS/DNS-SD Stack"},{"id":"clamav-daemon.service","load":"not-found","active":"inactive","running":"dead","description":"clamav-daemon.service"},{"id":"connman.service","load":"not-found","active":"inactive","running":"dead","description":"connman.service"},{"id":"console-screen.service","load":"not-found","active":"inactive","running":"dead","description":"console-screen.service"},{"id":"console-setup.service","load":"loaded","active":"active","running":"exited","description":"Set console font and keymap"},{"id":"cron.service","load":"loaded","active":"active","running":"running","description":"Regular background program processing daemon"},{"id":"cups-browsed.service","load":"loaded","active":"failed","running":"failed","description":"Make remote CUPS printers available locally"},{"id":"cups.service","load":"loaded","active":"active","running":"running","description":"CUPS Scheduler"},{"id":"dbus.service","load":"loaded","active":"active","running":"running","description":"D-Bus System Message Bus"},{"id":"display-manager.service","load":"not-found","active":"inactive","running":"dead","description":"display-manager.service"},{"id":"emergency.service","load":"loaded","active":"inactive","running":"dead","description":"Emergency Shell"},{"id":"exim4.service","load":"loaded","active":"active","running":"running","description":"LSB: exim Mail Transport Agent"},{"id":"getty-static.service","load":"loaded","active":"inactive","running":"dead","description":"getty on tty2-tty6 if dbus and logind are not available"},{"id":"getty@tty1.service","load":"loaded","active":"active","running":"running","description":"Getty on tty1"},{"id":"greylist.service","load":"not-found","active":"inactive","running":"dead","description":"greylist.service"},{"id":"gssproxy.service","load":"not-found","active":"inactive","running":"dead","description":"gssproxy.service"},{"id":"ifup@ens18.service","load":"loaded","active":"active","running":"exited","description":"ifup for ens18"},{"id":"ifupdown-pre.service","load":"loaded","active":"active","running":"exited","description":"Helper to synchronize boot up for ifupdown"},{"id":"influxdb.service","load":"not-found","active":"inactive","running":"dead","description":"influxdb.service"},{"id":"iobroker.service","load":"loaded","active":"active","running":"running","description":"ioBroker Server"},{"id":"irqbalance.service","load":"loaded","active":"active","running":"running","description":"irqbalance daemon"},{"id":"kbd.service","load":"not-found","active":"inactive","running":"dead","description":"kbd.service"},{"id":"keyboard-setup.service","load":"loaded","active":"active","running":"exited","description":"Set the console keyboard layout"},{"id":"kmod-static-nodes.service","load":"loaded","active":"active","running":"exited","description":"Create list of required static device nodes for the current kernel"},{"id":"logrotate.service","load":"loaded","active":"inactive","running":"dead","description":"Rotate log files"},{"id":"man-db.service","load":"loaded","active":"inactive","running":"dead","description":"Daily man-db regeneration"},{"id":"mariadb-server.service","load":"not-found","active":"inactive","running":"dead","description":"mariadb-server.service"},{"id":"mysql-server.service","load":"not-found","active":"inactive","running":"dead","description":"mysql-server.service"},{"id":"mysql.service","load":"not-found","active":"inactive","running":"dead","description":"mysql.service"},{"id":"networking.service","load":"loaded","active":"active","running":"exited","description":"Raise network interfaces"},{"id":"NetworkManager.service","load":"not-found","active":"inactive","running":"dead","description":"NetworkManager.service"},{"id":"nfs-blkmap.service","load":"not-found","active":"inactive","running":"dead","description":"nfs-blkmap.service"},{"id":"nfs-config.service","load":"loaded","active":"inactive","running":"dead","description":"Preprocess NFS configuration"},{"id":"nfs-server.service","load":"not-found","active":"inactive","running":"dead","description":"nfs-server.service"},{"id":"nfs-utils.service","load":"loaded","active":"inactive","running":"dead","description":"NFS server and client services"},{"id":"ntp.service","load":"loaded","active":"active","running":"running","description":"Network Time Service"},{"id":"plymouth-quit-wait.service","load":"not-found","active":"inactive","running":"dead","description":"plymouth-quit-wait.service"},{"id":"plymouth-start.service","load":"not-found","active":"inactive","running":"dead","description":"plymouth-start.service"},{"id":"postgresql.service","load":"not-found","active":"inactive","running":"dead","description":"postgresql.service"},{"id":"rc-local.service","load":"loaded","active":"inactive","running":"dead","description":"/etc/rc.local Compatibility"},{"id":"redis.service","load":"not-found","active":"inactive","running":"dead","description":"redis.service"},{"id":"rescue.service","load":"loaded","active":"inactive","running":"dead","description":"Rescue Shell"},{"id":"rpc-gssd.service","load":"loaded","active":"inactive","running":"dead","description":"RPC security service for NFS client and server"},{"id":"rpc-svcgssd.service","load":"loaded","active":"inactive","running":"dead","description":"RPC security service for NFS server"},{"id":"rpcbind.service","load":"loaded","active":"active","running":"running","description":"RPC bind portmap service"},{"id":"rsync.service","load":"loaded","active":"inactive","running":"dead","description":"fast remote file copy program daemon"},{"id":"rsyslog.service","load":"loaded","active":"active","running":"running","description":"System Logging Service"},{"id":"spamassassin.service","load":"not-found","active":"inactive","running":"dead","description":"spamassassin.service"},{"id":"ssh.service","load":"loaded","active":"active","running":"running","description":"OpenBSD Secure Shell server"},{"id":"systemd-ask-password-console.service","load":"loaded","active":"inactive","running":"dead","description":"Dispatch Password Requests to Console"},{"id":"systemd-ask-password-wall.service","load":"loaded","active":"inactive","running":"dead","description":"Forward Password Requests to Wall"},{"id":"systemd-binfmt.service","load":"loaded","active":"inactive","running":"dead","description":"Set Up Additional Binary Formats"},{"id":"systemd-fsck-root.service","load":"loaded","active":"inactive","running":"dead","description":"File System Check on Root Device"},{"id":"systemd-fsckd.service","load":"loaded","active":"inactive","running":"dead","description":"File System Check Daemon to report status"},{"id":"systemd-hwdb-update.service","load":"loaded","active":"inactive","running":"dead","description":"Rebuild Hardware Database"},{"id":"systemd-initctl.service","load":"loaded","active":"inactive","running":"dead","description":"initctl Compatibility Daemon"},{"id":"systemd-journal-flush.service","load":"loaded","active":"active","running":"exited","description":"Flush Journal to Persistent Storage"},{"id":"systemd-journald.service","load":"loaded","active":"active","running":"running","description":"Journal Service"},{"id":"systemd-logind.service","load":"loaded","active":"active","running":"running","description":"Login Service"},{"id":"systemd-machine-id-commit.service","load":"loaded","active":"inactive","running":"dead","description":"Commit a transient machine-id on disk"},{"id":"systemd-modules-load.service","load":"loaded","active":"active","running":"exited","description":"Load Kernel Modules"},{"id":"systemd-networkd.service","load":"loaded","active":"inactive","running":"dead","description":"Network Service"},{"id":"systemd-random-seed.service","load":"loaded","active":"active","running":"exited","description":"Load/Save Random Seed"},{"id":"systemd-remount-fs.service","load":"loaded","active":"active","running":"exited","description":"Remount Root and Kernel File Systems"},{"id":"systemd-sysctl.service","load":"loaded","active":"active","running":"exited","description":"Apply Kernel Variables"},{"id":"systemd-sysusers.service","load":"loaded","active":"active","running":"exited","description":"Create System Users"},{"id":"systemd-timesyncd.service","load":"loaded","active":"inactive","running":"dead","description":"Network Time Synchronization"},{"id":"systemd-tmpfiles-clean.service","load":"loaded","active":"inactive","running":"dead","description":"Cleanup of Temporary Directories"},{"id":"systemd-tmpfiles-setup-dev.service","load":"loaded","active":"active","running":"exited","description":"Create Static Device Nodes in /dev"},{"id":"systemd-tmpfiles-setup.service","load":"loaded","active":"active","running":"exited","description":"Create Volatile Files and Directories"},{"id":"systemd-udev-trigger.service","load":"loaded","active":"active","running":"exited","description":"udev Coldplug all Devices"},{"id":"systemd-udevd.service","load":"loaded","active":"active","running":"running","description":"udev Kernel Device Manager"},{"id":"systemd-update-done.service","load":"not-found","active":"inactive","running":"dead","description":"systemd-update-done.service"},{"id":"systemd-update-utmp-runlevel.service","load":"loaded","active":"inactive","running":"dead","description":"Update UTMP about System Runlevel Changes"},{"id":"systemd-update-utmp.service","load":"loaded","active":"active","running":"exited","description":"Update UTMP about System Boot/Shutdown"},{"id":"systemd-user-sessions.service","load":"loaded","active":"active","running":"exited","description":"Permit User Sessions"},{"id":"systemd-vconsole-setup.service","load":"not-found","active":"inactive","running":"dead","description":"systemd-vconsole-setup.service"},{"id":"user-runtime-dir@1000.service","load":"loaded","active":"active","running":"exited","description":"User Runtime Directory /run/user/1000"},{"id":"user@1000.service","load":"loaded","active":"active","running":"running","description":"User Manager for UID 1000"}] 2020-08-16 10:40:21.427 - [34mdebug[39m: linux-control.0 (24751) [needrestart] NUC_VM (192.168.138.123:22): no datapoints selected -> removing existing datapoints 2020-08-16 10:40:21.440 - [34mdebug[39m: linux-control.0 (24751) [folderSizes] NUC_VM (192.168.138.123:22): send command: 'sudo du -sk /opt/iobroker/iobroker-data/history | awk '{ print $1 /1024 }' | tail -1' 2020-08-16 10:40:21.766 - [34mdebug[39m: linux-control.0 (24751) [folderSizes] NUC_VM (192.168.138.123:22): response stdout: [sudo] Passwort für pi: 13533.4 2020-08-16 10:40:21.768 - [34mdebug[39m: linux-control.0 (24751) [folderSizes] NUC_VM (192.168.138.123:22): NUC_VM.folders.history.size: NaN MB 2020-08-16 10:40:21.772 - [34mdebug[39m: linux-control.0 (24751) [folderSizes] NUC_VM (192.168.138.123:22): send command: 'sudo find /opt/iobroker/iobroker-data/history -name "*" | wc -l | tail -1' 2020-08-16 10:40:22.085 - [34mdebug[39m: linux-control.0 (24751) [folderSizes] NUC_VM (192.168.138.123:22): response stdout: [sudo] Passwort für pi: 112764 2020-08-16 10:40:22.086 - [34mdebug[39m: linux-control.0 (24751) [folderSizes] NUC_VM (192.168.138.123:22): NUC_VM.folders.history.files: NaN Dateien 2020-08-16 10:40:22.089 - [34mdebug[39m: linux-control.0 (24751) [folderSizes] NUC_VM (192.168.138.123:22): send command: 'tmp=$(sudo find /opt/iobroker/iobroker-data/history -name "*" -type f -exec stat -c "%Y %n" -- {} \; | sort -nr | head -n1 | awk '{print $2}' | tail -1) && date +%s -r $tmp' 2020-08-16 10:40:22.686 - [32minfo[39m: linux-control.0 (24751) getting data from Tinker (192.168.138.74:22) 2020-08-16 10:40:22.719 - [34mdebug[39m: linux-control.0 (24751) [getConnection] Host 'Tinker' (192.168.138.74:22): using sudo for authentification 2020-08-16 10:40:22.825 - [34mdebug[39m: linux-control.0 (24751) [distributionInfo] Tinker (192.168.138.74:22): send command: 'cat /etc/os-release' 2020-08-16 10:40:23.123 - [34mdebug[39m: linux-control.0 (24751) [distributionInfo] Tinker (192.168.138.74:22): response stdout: NAME="Ubuntu" VERSION="18.04.4 LTS (Bionic Beaver)" ID=ubuntu ID_LIKE=debian PRETTY_NAME="Ubuntu 18.04.4 LTS" VERSION_ID="18.04" HOME_URL="https://www.ubuntu.com/" SUPPORT_URL="https://help.ubuntu.com/" BUG_REPORT_URL="https://bugs.launchpad.net/ubuntu/" PRIVACY_POLICY_URL="https://www.ubuntu.com/legal/terms-and-policies/privacy-policy" VERSION_CODENAME=bionic UBUNTU_CODENAME=bionic 2020-08-16 10:40:23.127 - [34mdebug[39m: linux-control.0 (24751) [distributionInfo] Tinker (192.168.138.74:22): csvToJson result: [{"prop":"NAME","val":"Ubuntu"},{"prop":"VERSION","val":"18.04.4 LTS (Bionic Beaver)"},{"prop":"ID","val":"ubuntu"},{"prop":"ID_LIKE","val":"debian"},{"prop":"PRETTY_NAME","val":"Ubuntu 18.04.4 LTS"},{"prop":"VERSION_ID","val":"18.04"},{"prop":"HOME_URL","val":"https://www.ubuntu.com/"},{"prop":"SUPPORT_URL","val":"https://help.ubuntu.com/"},{"prop":"BUG_REPORT_URL","val":"https://bugs.launchpad.net/ubuntu/"},{"prop":"PRIVACY_POLICY_URL","val":"https://www.ubuntu.com/legal/terms-and-policies/privacy-policy"},{"prop":"VERSION_CODENAME","val":"bionic"},{"prop":"UBUNTU_CODENAME","val":"bionic"}] 2020-08-16 10:40:23.152 - [34mdebug[39m: linux-control.0 (24751) [cmdAptUpdate] Tinker (192.168.138.74:22): no datapoints selected -> removing existing datapoints 2020-08-16 10:40:23.155 - [34mdebug[39m: linux-control.0 (24751) [servicesInfo] Tinker (192.168.138.74:22): send command: 'systemctl list-units --type service --all --no-legend | awk '{out=""; for(i=5;i<=NF;i++){out=out" "$i}; print $1","$2","$3","$4","out}'' 2020-08-16 10:40:23.178 - [34mdebug[39m: linux-control.0 (24751) [servicesInfo] Tinker (192.168.138.74:22): response stdout: alsa-restore.service,loaded,active,exited, Save/Restore Sound Card State alsa-state.service,loaded,inactive,dead, Manage Sound Card State (restore and store) apparmor.service,not-found,inactive,dead, apparmor.service apt-daily-upgrade.service,loaded,inactive,dead, Daily apt upgrade and clean activities apt-daily.service,loaded,inactive,dead, Daily apt download activities armbian-firstrun-config.service,loaded,inactive,dead, Armbian first run optional user configuration armbian-hardware-monitor.service,loaded,active,exited, Armbian hardware monitoring armbian-hardware-optimize.service,loaded,active,exited, Armbian hardware optimization armbian-ramlog.service,loaded,active,exited, Armbian memory supported logging armbian-zram-config.service,loaded,active,exited, Armbian ZRAM config armian-ramlog.service,not-found,inactive,dead, armian-ramlog.service auditd.service,not-found,inactive,dead, auditd.service bluetooth.service,loaded,active,running, Bluetooth service chrony.service,loaded,active,running, chrony, an NTP client/server connman.service,not-found,inactive,dead, connman.service console-screen.service,not-found,inactive,dead, console-screen.service console-setup.service,loaded,active,exited, Set console font and keymap cpufrequtils.service,loaded,active,exited, LSB: set CPUFreq kernel parameters cron.service,loaded,active,running, Regular background program processing daemon dbus.service,loaded,active,running, D-Bus System Message Bus display-manager.service,not-found,inactive,dead, display-manager.service emergency.service,loaded,inactive,dead, Emergency Shell fake-hwclock.service,loaded,active,exited, Restore / save the current clock fstrim.service,loaded,inactive,dead, Discard unused blocks getty-static.service,loaded,inactive,dead, getty on tty2-tty6 if dbus and logind are not available getty@tty1.service,loaded,active,running, Getty on tty1 haveged.service,loaded,active,running, Entropy daemon using the HAVEGE algorithm hostapd.service,loaded,active,exited, LSB: Advanced IEEE 802.11 management daemon influxdb.service,not-found,inactive,dead, influxdb.service iobroker.service,loaded,active,running, ioBroker Server kbd.service,not-found,inactive,dead, kbd.service keyboard-setup.service,loaded,active,exited, Set the console keyboard layout kmod-static-nodes.service,loaded,active,exited, Create list of required static device nodes for the current kernel loadcpufreq.service,loaded,active,exited, LSB: Load kernel modules needed to enable cpufreq scaling mariadb-server.service,not-found,inactive,dead, mariadb-server.service motd-news.service,loaded,inactive,dead, Message of the Day mountkernfs.service,masked,inactive,dead, mountkernfs.service mysql-server.service,not-found,inactive,dead, mysql-server.service networkd-dispatcher.service,loaded,active,running, Dispatcher daemon for systemd-networkd networking.service,loaded,active,exited, Raise network interfaces NetworkManager-wait-online.service,loaded,active,exited, Network Manager Wait Online NetworkManager.service,loaded,active,running, Network Manager ondemand.service,masked,inactive,dead, ondemand.service openntpd.service,not-found,inactive,dead, openntpd.service plymouth-quit-wait.service,not-found,inactive,dead, plymouth-quit-wait.service plymouth-start.service,not-found,inactive,dead, plymouth-start.service polkit.service,loaded,active,running, Authorization Manager rc-local.service,loaded,active,exited, /etc/rc.local Compatibility redis.service,not-found,inactive,dead, redis.service rescue.service,loaded,inactive,dead, Rescue Shell resolvconf-pull-resolved.service,loaded,inactive,dead, resolvconf-pull-resolved.service resolvconf.service,loaded,active,exited, Nameserver information manager rng-tools.service,loaded,active,running, rng-tools.service rsync.service,loaded,inactive,dead, fast remote file copy program daemon rsyslog.service,loaded,active,running, System Logging Service serial-getty@ttyS2.service,loaded,active,running, Serial Getty on ttyS2 setvtrgb.service,loaded,active,exited, Set console scheme ssh.service,loaded,active,running, OpenBSD Secure Shell server sysfsutils.service,loaded,active,exited, LSB: Set sysfs variables from /etc/sysfs.conf sysstat.service,loaded,active,exited, Resets System Activity Data Collector systemd-ask-password-console.service,loaded,inactive,dead, Dispatch Password Requests to Console systemd-ask-password-wall.service,loaded,inactive,dead, Forward Password Requests to Wall systemd-binfmt.service,loaded,inactive,dead, Set Up Additional Binary Formats systemd-fsck-root.service,loaded,inactive,dead, File System Check on Root Device systemd-fsckd.service,loaded,inactive,dead, File System Check Daemon to report status systemd-hwdb-update.service,loaded,inactive,dead, Rebuild Hardware Database systemd-initctl.service,loaded,inactive,dead, /dev/initctl Compatibility Daemon systemd-journal-flush.service,loaded,active,exited, Flush Journal to Persistent Storage systemd-journald.service,loaded,active,running, Journal Service systemd-logind.service,loaded,active,running, Login Service systemd-machine-id-commit.service,loaded,inactive,dead, Commit a transient machine-id on disk systemd-modules-load.service,loaded,active,exited, Load Kernel Modules systemd-networkd.service,loaded,inactive,dead, Network Service systemd-random-seed.service,loaded,active,exited, Load/Save Random Seed systemd-remount-fs.service,loaded,active,exited, Remount Root and Kernel File Systems systemd-resolved.service,loaded,active,running, Network Name Resolution systemd-rfkill.service,loaded,inactive,dead, Load/Save RF Kill Switch Status systemd-sysctl.service,loaded,active,exited, Apply Kernel Variables systemd-sysusers.service,not-found,inactive,dead, systemd-sysusers.service systemd-timesyncd.service,loaded,inactive,dead, Network Time Synchronization systemd-tmpfiles-clean.service,loaded,inactive,dead, Cleanup of Temporary Directories systemd-tmpfiles-setup-dev.service,loaded,active,exited, Create Static Device Nodes in /dev systemd-tmpfiles-setup.service,loaded,active,exited, Create Volatile Files and Directories systemd-udev-trigger.service,loaded,active,exited, udev Coldplug all Devices systemd-udevd.service,loaded,active,running, udev Kernel Device Manager systemd-update-done.service,not-found,inactive,dead, systemd-update-done.service systemd-update-utmp-runlevel.service,loaded,inactive,dead, Update UTMP about System Runlevel Changes systemd-update-utmp.service,loaded,active,exited, Update UTMP about System Boot/Shutdown systemd-user-sessions.service,loaded,active,exited, Permit User Sessions systemd-vconsole-setup.service,not-found,inactive,dead, systemd-vconsole-setup.service tinker-bluetooth.service,loaded,active,running, Realtek H5 bluetooth support unattended-upgrades.service,loaded,active,running, Unattended Upgrades Shutdown user@1002.service,loaded,active,running, User Manager for UID 1002 wpa_supplicant.service,loaded,active,running, WPA supplicant 2020-08-16 10:40:23.186 - [34mdebug[39m: linux-control.0 (24751) [servicesInfo] Tinker (192.168.138.74:22): csvToJson result: [{"id":"alsa-restore.service","load":"loaded","active":"active","running":"exited","description":"Save/Restore Sound Card State"},{"id":"alsa-state.service","load":"loaded","active":"inactive","running":"dead","description":"Manage Sound Card State (restore and store)"},{"id":"apparmor.service","load":"not-found","active":"inactive","running":"dead","description":"apparmor.service"},{"id":"apt-daily-upgrade.service","load":"loaded","active":"inactive","running":"dead","description":"Daily apt upgrade and clean activities"},{"id":"apt-daily.service","load":"loaded","active":"inactive","running":"dead","description":"Daily apt download activities"},{"id":"armbian-firstrun-config.service","load":"loaded","active":"inactive","running":"dead","description":"Armbian first run optional user configuration"},{"id":"armbian-hardware-monitor.service","load":"loaded","active":"active","running":"exited","description":"Armbian hardware monitoring"},{"id":"armbian-hardware-optimize.service","load":"loaded","active":"active","running":"exited","description":"Armbian hardware optimization"},{"id":"armbian-ramlog.service","load":"loaded","active":"active","running":"exited","description":"Armbian memory supported logging"},{"id":"armbian-zram-config.service","load":"loaded","active":"active","running":"exited","description":"Armbian ZRAM config"},{"id":"armian-ramlog.service","load":"not-found","active":"inactive","running":"dead","description":"armian-ramlog.service"},{"id":"auditd.service","load":"not-found","active":"inactive","running":"dead","description":"auditd.service"},{"id":"bluetooth.service","load":"loaded","active":"active","running":"running","description":"Bluetooth service"},{"id":"chrony.service","load":"loaded","active":"active","running":"running","description":"chrony","field6":"an NTP client/server"},{"id":"connman.service","load":"not-found","active":"inactive","running":"dead","description":"connman.service"},{"id":"console-screen.service","load":"not-found","active":"inactive","running":"dead","description":"console-screen.service"},{"id":"console-setup.service","load":"loaded","active":"active","running":"exited","description":"Set console font and keymap"},{"id":"cpufrequtils.service","load":"loaded","active":"active","running":"exited","description":"LSB: set CPUFreq kernel parameters"},{"id":"cron.service","load":"loaded","active":"active","running":"running","description":"Regular background program processing daemon"},{"id":"dbus.service","load":"loaded","active":"active","running":"running","description":"D-Bus System Message Bus"},{"id":"display-manager.service","load":"not-found","active":"inactive","running":"dead","description":"display-manager.service"},{"id":"emergency.service","load":"loaded","active":"inactive","running":"dead","description":"Emergency Shell"},{"id":"fake-hwclock.service","load":"loaded","active":"active","running":"exited","description":"Restore / save the current clock"},{"id":"fstrim.service","load":"loaded","active":"inactive","running":"dead","description":"Discard unused blocks"},{"id":"getty-static.service","load":"loaded","active":"inactive","running":"dead","description":"getty on tty2-tty6 if dbus and logind are not available"},{"id":"getty@tty1.service","load":"loaded","active":"active","running":"running","description":"Getty on tty1"},{"id":"haveged.service","load":"loaded","active":"active","running":"running","description":"Entropy daemon using the HAVEGE algorithm"},{"id":"hostapd.service","load":"loaded","active":"active","running":"exited","description":"LSB: Advanced IEEE 802.11 management daemon"},{"id":"influxdb.service","load":"not-found","active":"inactive","running":"dead","description":"influxdb.service"},{"id":"iobroker.service","load":"loaded","active":"active","running":"running","description":"ioBroker Server"},{"id":"kbd.service","load":"not-found","active":"inactive","running":"dead","description":"kbd.service"},{"id":"keyboard-setup.service","load":"loaded","active":"active","running":"exited","description":"Set the console keyboard layout"},{"id":"kmod-static-nodes.service","load":"loaded","active":"active","running":"exited","description":"Create list of required static device nodes for the current kernel"},{"id":"loadcpufreq.service","load":"loaded","active":"active","running":"exited","description":"LSB: Load kernel modules needed to enable cpufreq scaling"},{"id":"mariadb-server.service","load":"not-found","active":"inactive","running":"dead","description":"mariadb-server.service"},{"id":"motd-news.service","load":"loaded","active":"inactive","running":"dead","description":"Message of the Day"},{"id":"mountkernfs.service","load":"masked","active":"inactive","running":"dead","description":"mountkernfs.service"},{"id":"mysql-server.service","load":"not-found","active":"inactive","running":"dead","description":"mysql-server.service"},{"id":"networkd-dispatcher.service","load":"loaded","active":"active","running":"running","description":"Dispatcher daemon for systemd-networkd"},{"id":"networking.service","load":"loaded","active":"active","running":"exited","description":"Raise network interfaces"},{"id":"NetworkManager-wait-online.service","load":"loaded","active":"active","running":"exited","description":"Network Manager Wait Online"},{"id":"NetworkManager.service","load":"loaded","active":"active","running":"running","description":"Network Manager"},{"id":"ondemand.service","load":"masked","active":"inactive","running":"dead","description":"ondemand.service"},{"id":"openntpd.service","load":"not-found","active":"inactive","running":"dead","description":"openntpd.service"},{"id":"plymouth-quit-wait.service","load":"not-found","active":"inactive","running":"dead","description":"plymouth-quit-wait.service"},{"id":"plymouth-start.service","load":"not-found","active":"inactive","running":"dead","description":"plymouth-start.service"},{"id":"polkit.service","load":"loaded","active":"active","running":"running","description":"Authorization Manager"},{"id":"rc-local.service","load":"loaded","active":"active","running":"exited","description":"/etc/rc.local Compatibility"},{"id":"redis.service","load":"not-found","active":"inactive","running":"dead","description":"redis.service"},{"id":"rescue.service","load":"loaded","active":"inactive","running":"dead","description":"Rescue Shell"},{"id":"resolvconf-pull-resolved.service","load":"loaded","active":"inactive","running":"dead","description":"resolvconf-pull-resolved.service"},{"id":"resolvconf.service","load":"loaded","active":"active","running":"exited","description":"Nameserver information manager"},{"id":"rng-tools.service","load":"loaded","active":"active","running":"running","description":"rng-tools.service"},{"id":"rsync.service","load":"loaded","active":"inactive","running":"dead","description":"fast remote file copy program daemon"},{"id":"rsyslog.service","load":"loaded","active":"active","running":"running","description":"System Logging Service"},{"id":"serial-getty@ttyS2.service","load":"loaded","active":"active","running":"running","description":"Serial Getty on ttyS2"},{"id":"setvtrgb.service","load":"loaded","active":"active","running":"exited","description":"Set console scheme"},{"id":"ssh.service","load":"loaded","active":"active","running":"running","description":"OpenBSD Secure Shell server"},{"id":"sysfsutils.service","load":"loaded","active":"active","running":"exited","description":"LSB: Set sysfs variables from /etc/sysfs.conf"},{"id":"sysstat.service","load":"loaded","active":"active","running":"exited","description":"Resets System Activity Data Collector"},{"id":"systemd-ask-password-console.service","load":"loaded","active":"inactive","running":"dead","description":"Dispatch Password Requests to Console"},{"id":"systemd-ask-password-wall.service","load":"loaded","active":"inactive","running":"dead","description":"Forward Password Requests to Wall"},{"id":"systemd-binfmt.service","load":"loaded","active":"inactive","running":"dead","description":"Set Up Additional Binary Formats"},{"id":"systemd-fsck-root.service","load":"loaded","active":"inactive","running":"dead","description":"File System Check on Root Device"},{"id":"systemd-fsckd.service","load":"loaded","active":"inactive","running":"dead","description":"File System Check Daemon to report status"},{"id":"systemd-hwdb-update.service","load":"loaded","active":"inactive","running":"dead","description":"Rebuild Hardware Database"},{"id":"systemd-initctl.service","load":"loaded","active":"inactive","running":"dead","description":"/dev/initctl Compatibility Daemon"},{"id":"systemd-journal-flush.service","load":"loaded","active":"active","running":"exited","description":"Flush Journal to Persistent Storage"},{"id":"systemd-journald.service","load":"loaded","active":"active","running":"running","description":"Journal Service"},{"id":"systemd-logind.service","load":"loaded","active":"active","running":"running","description":"Login Service"},{"id":"systemd-machine-id-commit.service","load":"loaded","active":"inactive","running":"dead","description":"Commit a transient machine-id on disk"},{"id":"systemd-modules-load.service","load":"loaded","active":"active","running":"exited","description":"Load Kernel Modules"},{"id":"systemd-networkd.service","load":"loaded","active":"inactive","running":"dead","description":"Network Service"},{"id":"systemd-random-seed.service","load":"loaded","active":"active","running":"exited","description":"Load/Save Random Seed"},{"id":"systemd-remount-fs.service","load":"loaded","active":"active","running":"exited","description":"Remount Root and Kernel File Systems"},{"id":"systemd-resolved.service","load":"loaded","active":"active","running":"running","description":"Network Name Resolution"},{"id":"systemd-rfkill.service","load":"loaded","active":"inactive","running":"dead","description":"Load/Save RF Kill Switch Status"},{"id":"systemd-sysctl.service","load":"loaded","active":"active","running":"exited","description":"Apply Kernel Variables"},{"id":"systemd-sysusers.service","load":"not-found","active":"inactive","running":"dead","description":"systemd-sysusers.service"},{"id":"systemd-timesyncd.service","load":"loaded","active":"inactive","running":"dead","description":"Network Time Synchronization"},{"id":"systemd-tmpfiles-clean.service","load":"loaded","active":"inactive","running":"dead","description":"Cleanup of Temporary Directories"},{"id":"systemd-tmpfiles-setup-dev.service","load":"loaded","active":"active","running":"exited","description":"Create Static Device Nodes in /dev"},{"id":"systemd-tmpfiles-setup.service","load":"loaded","active":"active","running":"exited","description":"Create Volatile Files and Directories"},{"id":"systemd-udev-trigger.service","load":"loaded","active":"active","running":"exited","description":"udev Coldplug all Devices"},{"id":"systemd-udevd.service","load":"loaded","active":"active","running":"running","description":"udev Kernel Device Manager"},{"id":"systemd-update-done.service","load":"not-found","active":"inactive","running":"dead","description":"systemd-update-done.service"},{"id":"systemd-update-utmp-runlevel.service","load":"loaded","active":"inactive","running":"dead","description":"Update UTMP about System Runlevel Changes"},{"id":"systemd-update-utmp.service","load":"loaded","active":"active","running":"exited","description":"Update UTMP about System Boot/Shutdown"},{"id":"systemd-user-sessions.service","load":"loaded","active":"active","running":"exited","description":"Permit User Sessions"},{"id":"systemd-vconsole-setup.service","load":"not-found","active":"inactive","running":"dead","description":"systemd-vconsole-setup.service"},{"id":"tinker-bluetooth.service","load":"loaded","active":"active","running":"running","description":"Realtek H5 bluetooth support"},{"id":"unattended-upgrades.service","load":"loaded","active":"active","running":"running","description":"Unattended Upgrades Shutdown"},{"id":"user@1002.service","load":"loaded","active":"active","running":"running","description":"User Manager for UID 1002"},{"id":"wpa_supplicant.service","load":"loaded","active":"active","running":"running","description":"WPA supplicant"}] 2020-08-16 10:40:23.874 - [34mdebug[39m: linux-control.0 (24751) [needrestart] Tinker (192.168.138.74:22): no datapoints selected -> removing existing datapoints 2020-08-16 10:40:23.886 - [34mdebug[39m: linux-control.0 (24751) [folderSizes] Tinker (192.168.138.74:22): send command: 'sudo du -sk /opt/iobroker/iobroker-data | awk '{ print $1 /1024 }' | tail -1' 2020-08-16 10:40:23.987 - [34mdebug[39m: linux-control.0 (24751) [folderSizes] Tinker (192.168.138.74:22): response stdout: Sorry, user pi is not allowed to execute '/usr/bin/du -sk /opt/iobroker/iobroker-data' as root on localhost. 2020-08-16 10:40:23.988 - [34mdebug[39m: linux-control.0 (24751) [folderSizes] Tinker (192.168.138.74:22): Tinker.folders.iobroker.size: NaN MB 2020-08-16 10:40:23.991 - [34mdebug[39m: linux-control.0 (24751) [folderSizes] Tinker (192.168.138.74:22): send command: 'sudo find /opt/iobroker/iobroker-data -name "*" | wc -l | tail -1' 2020-08-16 10:40:24.095 - [34mdebug[39m: linux-control.0 (24751) [folderSizes] Tinker (192.168.138.74:22): response stdout: Sorry, user pi is not allowed to execute '/usr/bin/find /opt/iobroker/iobroker-data -name *' as root on localhost. 0 2020-08-16 10:40:24.097 - [34mdebug[39m: linux-control.0 (24751) [folderSizes] Tinker (192.168.138.74:22): Tinker.folders.iobroker.files: NaN Dateien 2020-08-16 10:40:24.099 - [34mdebug[39m: linux-control.0 (24751) [folderSizes] Tinker (192.168.138.74:22): send command: 'tmp=$(sudo find /opt/iobroker/iobroker-data -name "*" -type f -exec stat -c "%Y %n" -- {} \; | sort -nr | head -n1 | awk '{print $2}' | tail -1) && date +%s -r $tmp' 2020-08-16 10:40:24.203 - [34mdebug[39m: linux-control.0 (24751) [folderSizes] Tinker (192.168.138.74:22): response stdout: Sorry, user pi is not allowed to execute '/usr/bin/find /opt/iobroker/iobroker-data -name * -type f -exec stat -c %Y %n -- {} ;' as root on localhost. date: option requires an argument -- 'r' Try 'date --help' for more information. 2020-08-16 10:40:24.204 - [34mdebug[39m: linux-control.0 (24751) [folderSizes] Tinker (192.168.138.74:22): Tinker.folders.iobroker.lastChange: NaN -> 2020-08-16 10:40:24.207 - [34mdebug[39m: linux-control.0 (24751) [userCommand] Tinker (192.168.138.74:22, id: root, description: ): send command: 'df / | grep / | awk '{ print $5}' | sed 's/%//g'' 2020-08-16 10:40:24.235 - [34mdebug[39m: linux-control.0 (24751) [userCommand] Tinker (192.168.138.74:22, id: root, description: ): response stdout: 5 2020-08-16 10:40:24.239 - [34mdebug[39m: linux-control.0 (24751) [userCommand] Tinker (192.168.138.74:22, id: ip, description: ): send command: 'hostname -I | cut -d' ' -f1' 2020-08-16 10:40:24.250 - [34mdebug[39m: linux-control.0 (24751) [userCommand] Tinker (192.168.138.74:22, id: ip, description: ): response stdout: 192.168.138.74 2020-08-16 10:40:24.253 - [34mdebug[39m: linux-control.0 (24751) [userCommand] Tinker (192.168.138.74:22, id: cpu-temp, description: ): send command: 'cat /sys/devices/virtual/thermal/thermal_zone0/temp | awk '{print substr($1, length($0)-5,3)}'' 2020-08-16 10:40:24.263 - [34mdebug[39m: linux-control.0 (24751) [userCommand] Tinker (192.168.138.74:22, id: cpu-temp, description: ): response stdout: 47 2020-08-16 10:40:24.267 - [32minfo[39m: linux-control.0 (24751) successful received data from Tinker (192.168.138.74:22)ich hoffe es ist alles notwendige drin.
Ich bilde mir ein gestern wäre das log noch formatiert gewesen :-(kein Support per PN! - Fragen im Forum stellen - Benutzt das Voting rechts unten im Beitrag wenn er euch geholfen hat.
der Installationsfixer: curl -fsL https://iobroker.net/fix.sh | bash - -
@Scrounger,
wäre es möglich, das du deinen Adapter mit der Funktion von meinem Adapter erweiterst ? Mein Adapter führt die Befehle aus, wenn das Objekt dazu auf true gesetzt wird. Warum sollte Zeit in 2 fast gleiche Adapter investiert werden.
Hier der Github-Link und der Forums-Link. -
@Scrounger,
Hier der Github-Link und der Forums-Link.nach einem gelösten Thread wäre es sinnvoll dies in der Überschrift des ersten Posts einzutragen [gelöst]-... Bitte benutzt das Voting rechts unten im Beitrag wenn er euch geholfen hat. Forum-Tools: PicPick https://picpick.app/en/download/ und ScreenToGif https://www.screentogif.com/downloads.html
@liv-in-sky sagte in Test Adapter Linux Control v0.x.x:
@Wal ich denke das geht schon
Da muß ich mal testen :-)
@Wal und ich werd mir deinen mal ansehen - ist total an mir vorbei gegangen
@Wal wichtig ist, dass der befehl als button definiert wird
@liv-in-sky
hmm, was gebe ich als Abrufintervall ein, ich will ja nicht pollen ? -
@liv-in-sky
hmm, was gebe ich als Abrufintervall ein, ich will ja nicht pollen ?@Wal verstehe ich nicht ganz
das interval wird gebraucht für z.b folder abfragen oder service abfragen
wenn du nur einen button für einen server einrichten willst - also ohne folder oder service - wird das im moment nicht funktioneren
wenn du die datenpunkte (tab DATENPUNKTE) alle deaktivierst, weiß ich nicht ob noch gepollt wird und ob noch die befehle ausgeführt werden - mußt du ausprobieren
im log siehst du, ob gepollt wirdnach einem gelösten Thread wäre es sinnvoll dies in der Überschrift des ersten Posts einzutragen [gelöst]-... Bitte benutzt das Voting rechts unten im Beitrag wenn er euch geholfen hat. Forum-Tools: PicPick https://picpick.app/en/download/ und ScreenToGif https://www.screentogif.com/downloads.html
im log siehst du, ob gepollt wird@liv-in-sky sagte in Test Adapter Linux Control v0.x.x:
im log siehst du, ob gepollt wirdHab alles deaktiviert und den Intervall auf 9999 gestellt, funktioniert, danke.
@Wal sagte in Test Adapter Linux Control v0.x.x:
Ich bau noch ein, das bei Intervall = 0 das polling deaktiviert wird.
Alternativ kann man auch den Adapter einmal nach der Konfirguration eines eigenen Button laufen lassen und dann den host deaktiviert setzen (bei aktiviert den haken raus)@Homoran sagte in Test Adapter Linux Control v0.x.x:
@Scrounger sagte in Test Adapter Linux Control v0.x.x:
@Homoran
Hab noch was eingebaut, bitte teste mal die aktuelle github versionHabe neu installiert - upload gemacht und Instanz sicherheitshalber nochmal gestartet.
steht immer noch
nulldrinHab nochmal was eingebaut, bitte teste die aktuelle version von github.
Dein Tinker hat keine berechtigung:2020-08-15 16:08:27.315 - debug: linux-control.0 (19029) [folderSizes] Tinker (192.168.138.74:22): response stdout: Sorry, user pi is not allowed to execute '/usr/bin/find /opt/iobroker/iobroker-data -name * -type f -exec stat -c %Y %n -- {} ;' as root on localhost. -
@Homoran
steht immer noch
Dein Tinker hat keine berechtigung:2020-08-15 16:08:27.315 - debug: linux-control.0 (19029) [folderSizes] Tinker (192.168.138.74:22): response stdout: Sorry, user pi is not allowed to execute '/usr/bin/find /opt/iobroker/iobroker-data -name * -type f -exec stat -c %Y %n -- {} ;' as root on localhost.kein Support per PN! - Fragen im Forum stellen - Benutzt das Voting rechts unten im Beitrag wenn er euch geholfen hat.
@Homoran
steht immer noch
Dein Tinker hat keine berechtigung:2020-08-15 16:08:27.315 - debug: linux-control.0 (19029) [folderSizes] Tinker (192.168.138.74:22): response stdout: Sorry, user pi is not allowed to execute '/usr/bin/find /opt/iobroker/iobroker-data -name * -type f -exec stat -c %Y %n -- {} ;' as root on localhost.ist mir gerade in den sinn gekommen
könnte man da was über das sudoers file auf dem tinker machen ?
@liv-in-sky müsste mich mal schlau machen wo es steht, aber irgendwo konnte man einstellen ob bei sudo das Passwort abgefragt werden soll.
Das wollte ich aber eigentlich nicht ändern, im Gegenteil beim RaspiOS stört mich die fehlende Abfrage.kein Support per PN! - Fragen im Forum stellen - Benutzt das Voting rechts unten im Beitrag wenn er euch geholfen hat.
Das wollte ich aber eigentlich nicht ändern, im Gegenteil beim RaspiOS stört mich die fehlende Abfrage.@Homoran oder du gehst ohne passwort über rsa key file
@liv-in-sky Vielleicht geht auch was mit dem
sticky bit.
[Edit:] Ich meinte natürlich setuid, nicht sticky bit.Linux-Werkzeugkasten:
iob_diag: curl -sLf -o diag.sh https://iobroker.net/diag.sh && bash diag.sh -
@Homoran
steht immer noch
Dein Tinker hat keine berechtigung:2020-08-15 16:08:27.315 - debug: linux-control.0 (19029) [folderSizes] Tinker (192.168.138.74:22): response stdout: Sorry, user pi is not allowed to execute '/usr/bin/find /opt/iobroker/iobroker-data -name * -type f -exec stat -c %Y %n -- {} ;' as root on localhost.@Scrounger
habe gestern abend mal versucht, eine verbindung über rsa key file zu erstellen. anschliessend habe ich den pfad wieder aus dem setting im adapter genommen um wieder mit passwort zu verbinden - seitdem habe ich fehler und die verbindung wird nicht wieder hergestellt - iobroker restart heute morgen brachte keine verbesserunglinux-control.0 2020-08-17 08:29:10.256 error (2065) [getConnection] error: config.privateKey does not exist at given fs path, stack: AssertionError [ERR_ASSERTION]: config.privateKey does not exist at given fs path at new AssertionError (int linux-control.0 2020-08-17 08:29:10.255 error (2065) [getConnection] Could not establish a connection to 'Proxmox' (192.168.178.10:22)! linux-control.0 2020-08-17 08:28:10.247 error (2065) [getConnection] error: config.privateKey does not exist at given fs path, stack: AssertionError [ERR_ASSERTION]: config.privateKey does not exist at given fs path at new AssertionError (int linux-control.0 2020-08-17 08:28:10.246 error (2065) [getConnection] Could not establish a connection to 'Proxmox' (192.168.178.10:22)! linux-control.0 2020-08-17 08:27:10.236 error (2065) [getConnection] error: config.privateKey does not exist at given fs path, stack: AssertionError [ERR_ASSERTION]: config.privateKey does not exist at given fs path at new AssertionError (int linux-control.0 2020-08-17 08:27:10.236 error (2065) [getConnection] Could not establish a connection to 'Proxmox' (192.168.178.10:22)!hast du eine idee dazu ?
@Scrounger
Ja da muss ich noch was abfangen. Werd im Laufe des Tages noch eine neue Version bauen.
@Scrounger danke und gruß
