  3. Entwicklung
  4. lgtv Adapter zur Steuerung von LG WebOS SmartTVs
lgtv
861 Beiträge 113 Kommentatoren 510.1k Aufrufe 69 Beobachtet
  • T
    T
    toschi
    #560
    Ich habe den Adapter auf Debug gestellt und dieses aus dem Log kopiert. Oder wie macht man das?
    host.IO-Broker 2020-07-08 22:07:15.181 info instance system.adapter.lgtv.0 started with pid 15621
    host.IO-Broker 2020-07-08 22:06:45.173 info Restart adapter system.adapter.lgtv.0 because enabled
    host.IO-Broker 2020-07-08 22:06:45.173 info instance system.adapter.lgtv.0 terminated with code 0 (NO_ERROR)
    lgtv.0 2020-07-08 22:06:44.671 debug (15576) Connection closed: 1000
    lgtv.0 2020-07-08 22:06:44.661 info (15576) Terminated (NO_ERROR): Without reason
    lgtv.0 2020-07-08 22:06:44.660 info (15576) terminating
    lgtv.0 2020-07-08 22:06:44.656 debug (15576) TV is off
    lgtv.0 2020-07-08 22:06:44.654 error at processTicksAndRejections (internal/process/task_queues.js:79:11)
    lgtv.0 2020-07-08 22:06:44.654 error at /opt/iobroker/node_modules/websocket/lib/WebSocketConnection.js:323:40
    lgtv.0 2020-07-08 22:06:44.654 error at WebSocketConnection.processFrame (/opt/iobroker/node_modules/websocket/lib/WebSocketConnection.js:554:26)
    lgtv.0 2020-07-08 22:06:44.654 error at WebSocketConnection.emit (events.js:315:20)
    lgtv.0 2020-07-08 22:06:44.654 error at WebSocketConnection.<anonymous> (/opt/iobroker/node_modules/lgtv2/index.js:146:48)
    lgtv.0 2020-07-08 22:06:44.654 error at Object.42c660520001 (/opt/iobroker/node_modules/iobroker.lgtv/lgtv.js:387:30)
    lgtv.0 2020-07-08 22:06:44.654 error (15576) TypeError: Cannot read property 'indexOf' of undefined
    lgtv.0 2020-07-08 22:06:44.654 error (15576) uncaught exception: Cannot read property 'indexOf' of undefined
    lgtv.0 2020-07-08 22:06:44.653 debug (15576) audio/getVolume: {"volumeStatus":{"activeStatus":true,"adjustVolume":true,"maxVolume":100,"muteStatus":false,"volume":12,"soundOutput":"tv_external_speaker"},"returnValue":true,"callerId":"se
    lgtv.0 2020-07-08 22:06:44.634 debug (15576) WebOS TV Connected
    lgtv.0 2020-07-08 22:06:44.582 debug (15576) Connecting to WebOS TV: ws://192.168.10.94:3000
    lgtv.0 2020-07-08 22:06:44.575 debug (15576) adapter.config = {"ip":"192.168.10.94","mac":"","timeout":"5000","reconnect":"5000","power":true,"healthIntervall":""}
    lgtv.0 2020-07-08 22:06:44.574 info (15576) Ready. Configured WebOS TV IP: 192.168.10.94
    lgtv.0 2020-07-08 22:06:44.564 info (15576) starting. Version 1.1.6 in /opt/iobroker/node_modules/iobroker.lgtv, node: v12.17.0, js-controller: 3.1.6
    lgtv.0 2020-07-08 22:06:41.633 debug (15576) statesDB connected
    lgtv.0 2020-07-08 22:06:41.633 debug (15576) States connected to redis: 127.0.0.1:9000
    lgtv.0 2020-07-08 22:06:41.628 debug (15576) States create System PubSub Client
    lgtv.0 2020-07-08 22:06:41.627 debug (15576) States create User PubSub Client
    lgtv.0 2020-07-08 22:06:41.624 debug (15576) Redis States: Use Redis connection: 127.0.0.1:9000
    lgtv.0 2020-07-08 22:06:41.623 debug (15576) objectDB connected
    lgtv.0 2020-07-08 22:06:41.621 debug (15576) Objects connected to redis: 127.0.0.1:9001
    lgtv.0 2020-07-08 22:06:41.612 debug (15576) Objects client initialize lua scripts
    lgtv.0 2020-07-08 22:06:41.611 debug (15576) Objects create User PubSub Client
    lgtv.0 2020-07-08 22:06:41.611 debug (15576) Objects create System PubSub Client
    lgtv.0 2020-07-08 22:06:41.610 debug (15576) Objects client ready ... initialize now
    lgtv.0 2020-07-08 22:06:41.591 debug (15576) Redis Objects: Use Redis connection: 127.0.0.1:9001
    host.IO-Broker 2020-07-08 22:06:41.314 info instance system.adapter.lgtv.0 started with pid 15576
    host.IO-Broker 2020-07-08 22:06:11.304 info Restart adapter system.adapter.lgtv.0 because enabled
    • D
      D
      dirkhe
      schrieb am zuletzt editiert von dirkhe
      #561
      Da ist definitiv ein Bug im Code. Ich meine, dass ich den schon mal gesehen habe und gedacht, dass ich den gefixt habe, vlt habe ich das aber auch nur lokal gemacht
      Schau mal hier https://forum.iobroker.net/post/449292
      @SchuetzeSchulz den fix könntest du eigentlich direkt übernehmen?
      • T toschi
        S
        S
        SchuetzeSchulz
        #562
        @toschi
        Bitte mal den Adapter deinstallieren und neu vom Github installieren.
        Der Fehler sollte jetzt - hoffentlich - dank @dirkhe weg sein :)
        • T
          T
          toschi
          #563
          Die Installation von GitHub bricht mit Fehler ab:
          Fertig mit Fehler: internal/modules/cjs/loader.js:1175 throw err; ^SyntaxError: /opt/iobroker/node_modules/iobroker.lgtv/io-package.json: Unexpected token } in JSON at position 520 at parse () at Object.Module._extensions..json (internal/modules/cjs/loader.js:1172:22) at Module.load (internal/modules/cjs/loader.js:986:32) at Function.Module._load (internal/modules/cjs/loader.js:879:14) at Module.require (internal/modules/cjs/loader.js:1026:19) at require (internal/modules/cjs/helpers.js:72:18) at Upload.uploadAdapter (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupUpload.js:481:19) at /opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupInstall.js:1781:24 at ChildProcess. (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupInstall.js:478:47) at ChildProcess.emit (events.js:315:20)
          • T toschi
            S
            S
            SchuetzeSchulz
            #564
            @toschi
            Da hat sich leider noch ein Fehler eingeschlichen gehabt.
            Bitte nochmal probieren.
            • S SchuetzeSchulz
              @toschi
              sigi234S
              sigi234S
              #565
              @SchuetzeSchulz sagte in lgtv Adapter zur Steuerung von LG WebOS SmartTVs:
              @toschi
              $ ./iobroker upgrade lgtv
              Update lgtv from @1.1.6 to @1.1.7
              NPM version: 6.14.4
              npm install iobroker.lgtv@1.1.7 --loglevel error (System call)
              gyp
               ERR! UNCAUGHT EXCEPTION gyp ERR! stack TypeError: tar.extract is not a functiongyp ERR! stack     at Request.<anonymous> (C:\Program Files\iobroker\Test\nodejs\node_modules\npm\node_modules\node-gyp\lib\install.js:199:22)gyp ERR! stack     at Request.emit (events.js:327:22)gyp ERR! stack     at Request.onRequestResponse (C:\Program Files\iobroker\Test\nodejs\node_modules\npm\node_modules\request\request.js:1066:10)gyp ERR! stack     at ClientRequest.emit (events.js:315:20)gyp ERR! stack     at HTTPParser.parserOnIncomingClient [as onIncoming] (_http_client.js:596:27)gyp ERR! stack     at HTTPParser.parserOnHeadersComplete (_http_common.js:119:17)gyp ERR! stack     at TLSSocket.socketOnData (_http_client.js:469:22)gyp ERR! stack     at TLSSocket.emit (events.js:315:20)gyp ERR! stack     at addChunk (_stream_readable.js:295:12)gyp ERR! stack     at readableAddChunk (_stream_readable.js:271:9)gyp ERR! System Windows_NT 10.0.19041gyp ERR! command "C:\\Program Files\\iobroker\\Test\\nodejs\\node.exe" "C:\\Program Files\\iobroker\\Test\\nodejs\\node_modules\\npm\\node_modules\\node-gyp\\bin\\node-gyp.js" "rebuild"gyp ERR! cwd C:\Program Files\iobroker\Test\node_modules\unix-dgramgyp ERR! node -v v12.18.0gyp ERR! node-gyp -v v5.1.0gyp ERR! This is a bug in `node-gyp`.gyp ERR! Try to update node-gyp and file an Issue if it does not help:gyp ERR!     <https://github.com/nodejs/node-gyp/issues>
              ERROR: Cannot find io-package.json in C:/Program Files/iobroker/Test/node_modules/iobroker.lgtv
              ERROR: Cannot parse C:/Program Files/iobroker/Test/node_modules/iobroker.lgtv/io-package.json:SyntaxError: Unexpected token } in JSON at position 520Cannot find io-package.json in C:/Program Files/iobroker/Test/node_modules/iobroker.lgtv
              Adapter "lgtv" updated
              upload [3] lgtv.admin C:/Program Files/iobroker/Test/node_modules/iobroker.lgtv/admin/words.js words.js application/javascript
               writeFile will not write this file (words.js) in future versions: undefined
               DB closed
              upload [2] lgtv.admin C:/Program Files/iobroker/Test/node_modules/iobroker.lgtv/admin/lgtv.png lgtv.png image/png
               writeFile will not write this file (lgtv.png) in future versions: undefined
              upload [1] lgtv.admin C:/Program Files/iobroker/Test/node_modules/iobroker.lgtv/admin/index_m.html index_m.html text/html
               writeFile will not write this file (index_m.html) in future versions: undefined
              upload [0] lgtv.admin C:/Program Files/iobroker/Test/node_modules/iobroker.lgtv/admin/index.html index.html text/html
               writeFile will not write this file (index.html) in future versions: undefined
              ERROR: process exited with code 29
              os: win32
              RAM: 7.9 GB
              Node.js: v12.18.0
              NPM: 6.14.4
              JS-Controller: 3.1.6
              Admin: 4.1.1
              Active instances: 46
              • kmxakK
                kmxakK
                kmxak
                #566
                Von Github direkt installieren funktioniert. Über Update Button geht es nicht.
                Gruß Alex
                • kmxakK kmxak
                  sigi234S
                  sigi234S
                  #567
                  @kmxak sagte in lgtv Adapter zur Steuerung von LG WebOS SmartTVs:
                  Kann ich bestätigen.
                  • T
                    T
                    toschi
                    #568
                    ich habe den adapter Version 1.1.7 gerade neu in iobroker normal installiert. Hat funktioniert kann aber erst nachmittags testen da TV aus ist.
                    • T toschi
                      S
                      S
                      SchuetzeSchulz
                      #569
                      Hab jetzt mal auf Hithub und NPM die Version 1.1.8 veröffentlicht.
                      Kann allerdings dauern, bis sie im Stable repository ist.
                      • T
                        T
                        toschi
                        #570
                        Die Version 1.1.7 hat sich verbunden. Laut,leise,Kanal+ und - funktioniert. Den Rest kann ich erst später probieren. Die 1.1.8 kann ich abends testen.
                        • T
                          T
                          toschi
                          #571
                          Die 1.1.8 läuft bei mir auch. Keine Probleme gefunden. Vielen Dank für die schnelle Hilfe.
                          • S SchuetzeSchulz
                            aufgrund mangelnden Angebots :lol: habe ich mich entschlossen einen Adapter für LG WebOS SmartTV's auf Basis von Hobbyquakers https://github.com/hobbyquaker/lgtv2 zu entwickeln.
                            Ich habe es - bin kein JavaScript-Profi - schon soweit geschafft, dass er in der Adapterliste korrekt auftaucht:
                            Und auch die Adapter-Konfiguration ist fertig:
                            Bisher habe ich nur die Popup-Funktion eingebaut. Wenn also z.b. "lgtv.0.popup" irgend ein Wert übergeben wird (hier sind teilweise auch HTML-Tags möglich), wird auf dem Fernseher ein Info-Popup angezeigt:
                            Nun mein großes Problem:
                            Ich habe das bisher extrem "quick & dirty" gelöst, indem ich Hobbyquakers LGTV2 mittels
                            var lgtvobj = require("lgtv2")({url: 'ws://' + adapter.config.IP + ':3000', timeout: adapter.config.timeout, reconnect: adapter.config.reconnect});
                            eingebunden, würde aber gern die Funktionen aus Hobbyquakers Script direkt implementieren wollen, um es übersichtlicher zu haben.
                            Einfaches "copy & paste" geht da natürlich nicht.
                            Daher nun meine Frage, ob mir da jemand helfen kann bzw. mir Tipps geben kann, wie ich am Besten vorgehe?
                            Ist so ein Adapter überhaupt gewünscht?
                            Was haltet Ihr bisher davon?
                            sigi234S
                            sigi234S
                            #572
                            @SchuetzeSchulz
                            Die 1.1.8 läuft bei mir auch. Keine Probleme gefunden. 👍
                            • sigi234S sigi234
                              @SchuetzeSchulz
                              S
                              S
                              SchuetzeSchulz
                              #573
                              Der Dank gilt @dirkhe . Er hat den "Fehler" ja gefunden :)
                              • S SchuetzeSchulz
                                sigi234S
                                sigi234S
                                #574
                                Dank an @dirkhe 😀
                                • S SchuetzeSchulz
                                  liv-in-skyL
                                  liv-in-skyL
                                  #575
                                  @SchuetzeSchulz
                                  hi
                                  bei der installation probleme - im info wird update auf 1.1.8 angezeigt - wenn fertig ist es aber immer noch 1.1.7
                                  wenn ich über "katze" installiere kommt code 25
                                  E 1 Antwort Letzte Antwort
                                  • liv-in-skyL liv-in-sky
                                    @SchuetzeSchulz
                                    hi
                                    E
                                    E
                                    erde-online
                                    #576
                                    ich habe das gleiche Problem.Nach Installation von 1.1.8 habe ich immer noch 1.1.7 und mir wird die Installation auf 1.1.8 vorgeschlagen.
                                    • E erde-online
                                      S
                                      S
                                      SchuetzeSchulz
                                      #577
                                      Bitte bei Problemen den Adapter mal komplett deinstallieren und dann neu installieren.
                                      • S SchuetzeSchulz
                                        liv-in-skyL
                                        liv-in-skyL
                                        #578
                                        @SchuetzeSchulz adapter gelöscht - neu installiert - selbes problem
                                        • S SchuetzeSchulz
                                          liv-in-skyL
                                          liv-in-skyL
                                          #579
                                          @SchuetzeSchulz
                                          noch eine weitere frage:
                                          der datenpunkt channel wird nicht upgedated - woran könnte das liegen
                                          84.2k
