  4. SyntaxError: Unexpected Tokken
syntaxerror
71 Beiträge 4 Kommentatoren 7.6k Aufrufe 2 Beobachtet
  • F Offline
    Finnimeister
    code_textpi@All-In-One_RasPi:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.js-controller
    sudo: Unbekannter Benutzer: iobroker
    sudo: Regelwerks-Plugin konnte nicht initialisiert werden
    • F Finnimeister
      @Finnimeister
      Warum hast du denn keinen user iobroker?
      So eine alte Installation?
      cd /opt/iobroker
      • F Offline
        Finnimeister
        Danke !!! bist der beste....es läuft wieder....
        • F Finnimeister
          @Finnimeister
          Dann jetzt den Fixer hinterher!
          • F Offline
            Finnimeister
            Meinst du das...
            code_textcurl -sL https://iobroker.net/fix.sh | bash –
            • F Finnimeister
              Meinst du das...
              @Finnimeister
              Ja. Oder
              iobroker stop
              iobroker fix
              • F Offline
                Finnimeister
                code_textpi@All-In-One_RasPi:/opt/iobroker $ iobroker fix
                Commands:
                iobroker setup [--objects <host>] [--states <host>] [custom]
                iobroker start - starts the js-controller
                iobroker stop - stops the js-controller
                iobroker start <adapter>[.instance] - starts a specified adapter instance
                iobroker stop <adapter>.[instance] - stops a specified adapter instance
                iobroker start all - starts js-controller and all adapters
                iobroker restart - restarts the js-controller
                iobroker restart <adapter>[.instance] - restarts a specified adapter
                iobroker debug <adapter> [--ip=<ip>] [--port=<port>] [--wait] - Starts a Node.js debugging session for the adapter
                    --wait stops the execution until the debugger is attached.
                    --ip and --port can be used to change the listen IP and port. Use IP 0.0.0.0 for remote debugging.
                iobroker info - shows the host info
                iobroker logs [adapter] [--watch] [--lines=1000]
                iobroker add <adapter> [desiredNumber] [--enabled] [--host <host>] [--port <port>]
                iobroker install <adapter> - installs a specified adapter
                iobroker rebuild <adapter>|self [--install]
                iobroker url <url> [<name>] - install adapter from specified url, e.g. GitHub
                iobroker del <adapter> - remove adapter from system
                iobroker del <adapter>.<instance> - remove adapter instance
                iobroker update [repository url] [--updatable/--u] [--installed/--i] [--force/--f] - update repository and optionally filter installed/updateable adapters, use --force to bypass hash check
                iobroker upgrade [repository url]
                iobroker upgrade self [repository url] - upgrade js-controller and all adapters, optionally you can specify the repository url
                iobroker upgrade <adapter> [repository url] - upgrade specified adapter, optionally you can specify the repository url
                iobroker upload <pathToLocalFile> <pathIniobroker>
                iobroker upload all - upload all adapter files to make them available for instances
                iobroker upload <adapter> - upload specified adapter files to make them available for instances
                iobroker object get <id> - get object specified by id
                iobroker object set <id> <json-value> - set object with the given id by providing a new json object
                iobroker object set <id> propertyname=<value or json-value> - update part of the object by providing a new value or partial object
                iobroker object extend <id> <json-value> - extend object with the given id by providing a new json object
                iobroker object del <id|pattern> [--yes]
                iobroker object chmod <object-mode> [state-mode] <id>
                iobroker object chown <user> <group> <id>
                iobroker object list <id>
                iobroker state get <id> - get state, specified by id
                iobroker state getplain <id> [--pretty]
                iobroker state getvalue <id>
                iobroker state set <id> <value> [ack]
                iobroker state del <id>
                iobroker message <adapter>[.instance] <command> [<message>]
                iobroker list <type> [filter]
                iobroker chmod <mode> <file>
                iobroker chown <user> <group> <file>
                iobroker touch <file>
                iobroker rm <file>
                iobroker file read <iobroker-path-to-read> [<filesystem-path-to-write>]
                iobroker file write <filesystem-path-to-read> <iobroker-path-to-write>
                iobroker file rm <iobroker-path-to-delete>
                iobroker file sync
                iobroker user add <user> [--ingroup group] [--password pass]
                iobroker user del <user>
                iobroker user passwd <user> [--password pass]
                iobroker user enable <user>
                iobroker user disable <user>
                iobroker user get <user>
                iobroker user check <user> [--password pass]
                iobroker group add <group>
                iobroker group del <group>
                iobroker group list <group>
                iobroker group enable <group>
                iobroker group disable <group>
                iobroker group get <group>
                iobroker group adduser <group> <user>
                iobroker group deluser <group> <user>
                iobroker host this
                iobroker host <hostname>
                iobroker host set <hostname>
                iobroker host remove <hostname>
                iobroker set <adapter>.<instance> [--port port] [--ip address] [--ssl true|false]
                iobroker license <license.file or license.text>
                iobroker cert create
                iobroker cert view [<certificate name>]
                iobroker clean
                iobroker backup
                iobroker restore <backup name or path> - restore a specified backup
                iobroker validate <backup name or path> - validate a specified backup
                iobroker <command> --timeout 5000
                iobroker status [all|<adapter>.<instance>]
                iobroker repo [name]
                iobroker repo add <name> <path or url>
                iobroker repo set <name>
                iobroker repo del <name>
                iobroker uuid
                iobroker unsetup
                iobroker fix - execute the installation fixer script, this updates your ioBroker installation
                iobroker multihost <enable|disable> [--secure true|false]
                iobroker multihost browse
                iobroker multihost connect
                iobroker compact status - show if compact mode is enabled in general
                iobroker compact <enable|on|disable|off> - enable or disable compact mode in general
                iobroker compact <adapter>.<instance> status - show if compact mode is enabled for a specific instance
                iobroker compact <adapter>.<instance> group <group-id> - define compact group of a specific adapter
                iobroker compact <adapter>.<instance> <disable|off> - enable or disable compact mode for specified adapter instance
                iobroker compact <adapter>.<instance> <enable|on> [group-id] - enable or disable compact mode for specified adapter instance and set comapct group optionally
                iobroker plugin enable <pluginname> [--host <hostname>] - enables a plugin for the specified host. If no host is specified, the current one is used
                iobroker plugin disable <pluginname> [--host <hostname>] - disables a plugin for the specified host. If no host is specified, the current one is used
                iobroker plugin status <pluginname> [--host <hostname>] - checks if a plugin is enabled for the specified host. If no host is specified, the current one is used
                iobroker plugin enable <pluginname> --instance <adapter>[.<nr>] - enables a plugin for the specified adapter instance (defaults to instance 0)
                iobroker plugin disable <pluginname> --instance <adapter>[.<nr>] - disables a plugin for the specified adapter instance (defaults to instance 0)
                iobroker plugin status <pluginname> --instance <adapter>[.<nr>] - checks if a plugin is enabled for the specified adapter instance (defaults to instance 0)
                iobroker version [adapter] - show version of js-controller or specified adapter
                iobroker [adapter] -v - show version of js-controller or specified adapter
                Options:
                  --help     Hilfe anzeigen  [boolean]
                  --version  Version anzeigen  [boolean]
                pi@All-In-One_RasPi:/opt/iobroker $ iobroker start
                Starting iobroker controller daemon...
                iobroker controller daemon failed to start:  Failed to write pidfile (EACCES)
                An unknown error occurred: Error: Failed to write pidfile (EACCES)
                • F Finnimeister
                  Commands:
                  iobroker rm <file>
                  iobroker file sync
                  iobroker host this
                  iobroker clean
                  iobroker backup
                  iobroker uuid
                  iobroker unsetup
                  Options:
                  @Finnimeister
                  • F Offline
                    Finnimeister
                    code_textpi@All-In-One_RasPi:/opt/iobroker $ curl -sL https://iobroker.net/fix.sh | bash –
                    bash: –: Datei oder Verzeichnis nicht gefunden
                    • F Finnimeister
                      @Finnimeister
                      Versuch mal ohne - am Ende:
                      Ist die bash überhaupt installiert?
                      apt policy bash
                      • F Offline
                        Finnimeister
                        code_textpi@All-In-One_RasPi:~ $ curl -sL https://iobroker.net/fix.sh | bash
                        library: loaded
                        Library version=2020-06-12
                            Welcome to the ioBroker installation fixer!
                            Script version: 2020-04-12
                            You might need to enter your password a couple of times.
                            Installing prerequisites (1/3)
                        OK:1 http://archive.raspberrypi.org/debian stretch InRelease
                        OK:2 https://www.pivccu.de/piVCCU stable InRelease
                        OK:3 https://deb.nodesource.com/node_12.x stretch InRelease
                        OK:4 http://raspbian.raspberrypi.org/raspbian stretch InRelease
                        Installed gcc-c++
                        • F Offline
                          Finnimeister
                          ..aber es passiert nix,geht nicht weiter...
                          • F Finnimeister
                            @Finnimeister
                            Mit STRG-C abbrechen.
                            Dann mit
                            sudo adduser iobroker
                            einen user anlegen.
                            • F Offline
                              Finnimeister
                              code_textpi@All-In-One_RasPi:~ $ sudo adduser iobroker
                              Lege Benutzer »iobroker« an ...
                              Lege neue Gruppe »iobroker« (1001) an ...
                              Lege neuen Benutzer »iobroker« (1001) mit Gruppe »iobroker« an ...
                              Erstelle Home-Verzeichnis »/home/iobroker« ...
                              Kopiere Dateien aus »/etc/skel« ...
                              Geben Sie ein neues UNIX-Passwort ein:
                              Geben Sie das neue UNIX-Passwort erneut ein:
                              passwd: Passwort erfolgreich geändert
                              Benutzerinformationen für iobroker werden geändert.
                              Geben Sie einen neuen Wert an oder drücken Sie ENTER für den Standardwert
                                      Vollständiger Name []: Heiko
                                      Zimmernummer []:
                                      Telefon geschäftlich []:
                                      Telefon privat []:
                                      Sonstiges []:
                              Sind die Informationen korrekt? [J/n] j
                              library: loaded
                              OK:1 http://raspbian.raspberrypi.org/raspbian stretch InRelease
                              OK:2 http://archive.raspberrypi.org/debian stretch InRelease
                              OK:3 https://www.pivccu.de/piVCCU stable InRelease
                              OK:4 https://deb.nodesource.com/node_12.x stretch InRelease
                              Installed gcc-c++
                              • F Finnimeister
                                        Zimmernummer []:
                                        Telefon privat []:
                                        Sonstiges []:
                                library: loaded
                                Installed gcc-c++
                                @Finnimeister
                                sudo -u iobroker groups
                                F 1 Antwort Letzte Antwort
                                  @Finnimeister
                                  Finnimeister
                                  @Thomas-Braun sagte in SyntaxError: Unexpected Tokken:
                                  code_textpi@All-In-One_RasPi:~ $ sudo -u iobroker groups
                                  iobroker
                                  • F Finnimeister
                                    iobroker
                                    @Finnimeister
                                    Keine Ahung, warum der Fixer abbricht.
                                    Starte mal komplett per
                                    sudo reboot
                                    durch. Und dann nochmal:
                                    curl -sL https://iobroker.net/fix.sh | bash -
                                    mit - am Ende.
                                    • F Offline
                                      Finnimeister
                                      code_textpi@All-In-One_RasPi:/opt/iobroker $ curl -sL https://iobroker.net/fix.sh | bash -
                                      library: loaded
                                      OK:4 https://www.pivccu.de/piVCCU stable InRelease
                                      Installed gcc-c++
                                      Installed python-dev
                                          Checking ioBroker user and directory permissions (2/3)
                                          Checking autostart (3/3)
                                      Enabling autostart...
                                      Created symlink /etc/systemd/system/multi-user.target.wants/iobroker.service → /lib/systemd/system/iobroker.service.
                                      Autostart enabled!
                                          Your installation was fixed successfully
                                          Run iobroker start to start ioBroker again!
                                      • F Finnimeister
                                        library: loaded
                                        Installed gcc-c++
                                        Autostart enabled!
                                        @Finnimeister
                                        Okay, jetzt scheint alles zu passen.
                                        • F Offline
                                          Finnimeister
                                          wie starte ich jetzt wieder???
                                          sudo iobroker start geht nicht...
