  4. SyntaxError: Unexpected Tokken
syntaxerror
71 Beiträge 4 Kommentatoren 7.6k Aufrufe 2 Beobachtet
  • F Offline
    Finnimeister
    Meinst du das...
    code_textcurl -sL https://iobroker.net/fix.sh | bash –
    • F Finnimeister
      Meinst du das...
      @Finnimeister
      Ja. Oder
      iobroker stop
      iobroker fix
      • F Offline
        Finnimeister
        code_textpi@All-In-One_RasPi:/opt/iobroker $ iobroker fix
        Commands:
        iobroker setup [--objects <host>] [--states <host>] [custom]
        iobroker start - starts the js-controller
        iobroker stop - stops the js-controller
        iobroker start <adapter>[.instance] - starts a specified adapter instance
        iobroker stop <adapter>.[instance] - stops a specified adapter instance
        iobroker start all - starts js-controller and all adapters
        iobroker restart - restarts the js-controller
        iobroker restart <adapter>[.instance] - restarts a specified adapter
        iobroker debug <adapter> [--ip=<ip>] [--port=<port>] [--wait] - Starts a Node.js debugging session for the adapter
            --wait stops the execution until the debugger is attached.
            --ip and --port can be used to change the listen IP and port. Use IP 0.0.0.0 for remote debugging.
        iobroker info - shows the host info
        iobroker logs [adapter] [--watch] [--lines=1000]
        iobroker add <adapter> [desiredNumber] [--enabled] [--host <host>] [--port <port>]
        iobroker install <adapter> - installs a specified adapter
        iobroker rebuild <adapter>|self [--install]
        iobroker url <url> [<name>] - install adapter from specified url, e.g. GitHub
        iobroker del <adapter> - remove adapter from system
        iobroker del <adapter>.<instance> - remove adapter instance
        iobroker update [repository url] [--updatable/--u] [--installed/--i] [--force/--f] - update repository and optionally filter installed/updateable adapters, use --force to bypass hash check
        iobroker upgrade [repository url]
        iobroker upgrade self [repository url] - upgrade js-controller and all adapters, optionally you can specify the repository url
        iobroker upgrade <adapter> [repository url] - upgrade specified adapter, optionally you can specify the repository url
        iobroker upload <pathToLocalFile> <pathIniobroker>
        iobroker upload all - upload all adapter files to make them available for instances
        iobroker upload <adapter> - upload specified adapter files to make them available for instances
        iobroker object get <id> - get object specified by id
        iobroker object set <id> <json-value> - set object with the given id by providing a new json object
        iobroker object set <id> propertyname=<value or json-value> - update part of the object by providing a new value or partial object
        iobroker object extend <id> <json-value> - extend object with the given id by providing a new json object
        iobroker object del <id|pattern> [--yes]
        iobroker object chmod <object-mode> [state-mode] <id>
        iobroker object chown <user> <group> <id>
        iobroker object list <id>
        iobroker state get <id> - get state, specified by id
        iobroker state getplain <id> [--pretty]
        iobroker state getvalue <id>
        iobroker state set <id> <value> [ack]
        iobroker state del <id>
        iobroker message <adapter>[.instance] <command> [<message>]
        iobroker list <type> [filter]
        iobroker chmod <mode> <file>
        iobroker chown <user> <group> <file>
        iobroker touch <file>
        iobroker rm <file>
        iobroker file read <iobroker-path-to-read> [<filesystem-path-to-write>]
        iobroker file write <filesystem-path-to-read> <iobroker-path-to-write>
        iobroker file rm <iobroker-path-to-delete>
        iobroker file sync
        iobroker user add <user> [--ingroup group] [--password pass]
        iobroker user del <user>
        iobroker user passwd <user> [--password pass]
        iobroker user enable <user>
        iobroker user disable <user>
        iobroker user get <user>
        iobroker user check <user> [--password pass]
        iobroker group add <group>
        iobroker group del <group>
        iobroker group list <group>
        iobroker group enable <group>
        iobroker group disable <group>
        iobroker group get <group>
        iobroker group adduser <group> <user>
        iobroker group deluser <group> <user>
        iobroker host this
        iobroker host <hostname>
        iobroker host set <hostname>
        iobroker host remove <hostname>
        iobroker set <adapter>.<instance> [--port port] [--ip address] [--ssl true|false]
        iobroker license <license.file or license.text>
        iobroker cert create
        iobroker cert view [<certificate name>]
        iobroker clean
        iobroker backup
        iobroker restore <backup name or path> - restore a specified backup
        iobroker validate <backup name or path> - validate a specified backup
        iobroker <command> --timeout 5000
        iobroker status [all|<adapter>.<instance>]
        iobroker repo [name]
        iobroker repo add <name> <path or url>
        iobroker repo set <name>
        iobroker repo del <name>
        iobroker uuid
        iobroker unsetup
        iobroker fix - execute the installation fixer script, this updates your ioBroker installation
        iobroker multihost <enable|disable> [--secure true|false]
        iobroker multihost browse
        iobroker multihost connect
        iobroker compact status - show if compact mode is enabled in general
        iobroker compact <enable|on|disable|off> - enable or disable compact mode in general
        iobroker compact <adapter>.<instance> status - show if compact mode is enabled for a specific instance
        iobroker compact <adapter>.<instance> group <group-id> - define compact group of a specific adapter
        iobroker compact <adapter>.<instance> <disable|off> - enable or disable compact mode for specified adapter instance
        iobroker compact <adapter>.<instance> <enable|on> [group-id] - enable or disable compact mode for specified adapter instance and set comapct group optionally
        iobroker plugin enable <pluginname> [--host <hostname>] - enables a plugin for the specified host. If no host is specified, the current one is used
        iobroker plugin disable <pluginname> [--host <hostname>] - disables a plugin for the specified host. If no host is specified, the current one is used
        iobroker plugin status <pluginname> [--host <hostname>] - checks if a plugin is enabled for the specified host. If no host is specified, the current one is used
        iobroker plugin enable <pluginname> --instance <adapter>[.<nr>] - enables a plugin for the specified adapter instance (defaults to instance 0)
        iobroker plugin disable <pluginname> --instance <adapter>[.<nr>] - disables a plugin for the specified adapter instance (defaults to instance 0)
        iobroker plugin status <pluginname> --instance <adapter>[.<nr>] - checks if a plugin is enabled for the specified adapter instance (defaults to instance 0)
        iobroker version [adapter] - show version of js-controller or specified adapter
        iobroker [adapter] -v - show version of js-controller or specified adapter
        Options:
          --help     Hilfe anzeigen  [boolean]
          --version  Version anzeigen  [boolean]
        pi@All-In-One_RasPi:/opt/iobroker $ iobroker start
        Starting iobroker controller daemon...
        iobroker controller daemon failed to start:  Failed to write pidfile (EACCES)
        An unknown error occurred: Error: Failed to write pidfile (EACCES)
        • F Finnimeister
          Commands:
          iobroker rm <file>
          iobroker file sync
          iobroker host this
          iobroker clean
          iobroker backup
          iobroker uuid
          iobroker unsetup
          Options:
          @Finnimeister
          • F Offline
            Finnimeister
            code_textpi@All-In-One_RasPi:/opt/iobroker $ curl -sL https://iobroker.net/fix.sh | bash –
            bash: –: Datei oder Verzeichnis nicht gefunden
            • F Finnimeister
              @Finnimeister
              Versuch mal ohne - am Ende:
              Ist die bash überhaupt installiert?
              apt policy bash
              • F Offline
                Finnimeister
                code_textpi@All-In-One_RasPi:~ $ curl -sL https://iobroker.net/fix.sh | bash
                library: loaded
                Library version=2020-06-12
                    Welcome to the ioBroker installation fixer!
                    Script version: 2020-04-12
                    You might need to enter your password a couple of times.
                    Installing prerequisites (1/3)
                OK:1 http://archive.raspberrypi.org/debian stretch InRelease
                OK:2 https://www.pivccu.de/piVCCU stable InRelease
                OK:3 https://deb.nodesource.com/node_12.x stretch InRelease
                OK:4 http://raspbian.raspberrypi.org/raspbian stretch InRelease
                Installed gcc-c++
                • F Offline
                  Finnimeister
                  ..aber es passiert nix,geht nicht weiter...
                  • F Finnimeister
                    @Finnimeister
                    Mit STRG-C abbrechen.
                    Dann mit
                    sudo adduser iobroker
                    einen user anlegen.
                    • F Offline
                      Finnimeister
                      code_textpi@All-In-One_RasPi:~ $ sudo adduser iobroker
                      Lege Benutzer »iobroker« an ...
                      Lege neue Gruppe »iobroker« (1001) an ...
                      Lege neuen Benutzer »iobroker« (1001) mit Gruppe »iobroker« an ...
                      Erstelle Home-Verzeichnis »/home/iobroker« ...
                      Kopiere Dateien aus »/etc/skel« ...
                      Geben Sie ein neues UNIX-Passwort ein:
                      Geben Sie das neue UNIX-Passwort erneut ein:
                      passwd: Passwort erfolgreich geändert
                      Benutzerinformationen für iobroker werden geändert.
                      Geben Sie einen neuen Wert an oder drücken Sie ENTER für den Standardwert
                              Vollständiger Name []: Heiko
                              Zimmernummer []:
                              Telefon geschäftlich []:
                              Telefon privat []:
                              Sonstiges []:
                      Sind die Informationen korrekt? [J/n] j
                      library: loaded
                      OK:1 http://raspbian.raspberrypi.org/raspbian stretch InRelease
                      OK:2 http://archive.raspberrypi.org/debian stretch InRelease
                      OK:3 https://www.pivccu.de/piVCCU stable InRelease
                      OK:4 https://deb.nodesource.com/node_12.x stretch InRelease
                      Installed gcc-c++
                      • F Finnimeister
                                Zimmernummer []:
                                Telefon privat []:
                                Sonstiges []:
                        library: loaded
                        Installed gcc-c++
                        @Finnimeister
                        sudo -u iobroker groups
                        F 1 Antwort Letzte Antwort
                          @Finnimeister
                          Finnimeister
                          @Thomas-Braun sagte in SyntaxError: Unexpected Tokken:
                          code_textpi@All-In-One_RasPi:~ $ sudo -u iobroker groups
                          iobroker
                          • F Finnimeister
                            iobroker
                            @Finnimeister
                            Keine Ahung, warum der Fixer abbricht.
                            Starte mal komplett per
                            sudo reboot
                            durch. Und dann nochmal:
                            curl -sL https://iobroker.net/fix.sh | bash -
                            mit - am Ende.
                            • F Offline
                              Finnimeister
                              code_textpi@All-In-One_RasPi:/opt/iobroker $ curl -sL https://iobroker.net/fix.sh | bash -
                              library: loaded
                              OK:4 https://www.pivccu.de/piVCCU stable InRelease
                              Installed gcc-c++
                              Installed python-dev
                                  Checking ioBroker user and directory permissions (2/3)
                                  Checking autostart (3/3)
                              Enabling autostart...
                              Created symlink /etc/systemd/system/multi-user.target.wants/iobroker.service → /lib/systemd/system/iobroker.service.
                              Autostart enabled!
                                  Your installation was fixed successfully
                                  Run iobroker start to start ioBroker again!
                              • F Finnimeister
                                library: loaded
                                Installed gcc-c++
                                Autostart enabled!
                                @Finnimeister
                                Okay, jetzt scheint alles zu passen.
                                • F Offline
                                  Finnimeister
                                  wie starte ich jetzt wieder???
                                  sudo iobroker start geht nicht...
                                  • F Finnimeister
                                    @Finnimeister
                                    Ohne sudo
                                    Einfach
                                    iobroker start
                                      @Finnimeister
                                      Ohne sudo
                                      Einfach
                                      iobroker start
                                      Finnimeister
                                      @Thomas-Braun
                                      code_textpi@All-In-One_RasPi:/opt/iobroker $ iobroker start
                                      * Startet so nicht !!!!
                                      • F Finnimeister
                                        @Thomas-Braun
                                        @Finnimeister
                                        iobroker status
                                          @Finnimeister
                                          iobroker status
                                          Finnimeister
                                          iobroker status
                                          code_textpi@All-In-One_RasPi:/opt/iobroker $ iobroker status
                                          iobroker is not running on this host.
                                          No iobroker host is running.
                                          Objects type: file
                                          States  type: redis
