  4. SyntaxError: Unexpected Tokken
syntaxerror
71 Beiträge 4 Kommentatoren 7.6k Aufrufe 2 Beobachtet
  • F Offline
    Finnimeister
    code_textpi@All-In-One_RasPi:~ $ iobroker start
    Starting iobroker controller daemon...
    iobroker controller daemon failed to start:  Failed to write pidfile (EACCES)
    An unknown error occurred: Error: Failed to write pidfile (EACCES)
    • F Finnimeister
      @Finnimeister Was passierte bei
      iobroker fix
      denn? Ich kann nicht hellsehen...
      • F Offline
        Finnimeister
        sorry...
        code_textCommands:
        iobroker setup [--objects <host>] [--states <host>] [custom]
        iobroker start - starts the js-controller
        iobroker stop - stops the js-controller
        iobroker start <adapter>[.instance] - starts a specified adapter instance
        iobroker stop <adapter>.[instance] - stops a specified adapter instance
        iobroker start all - starts js-controller and all adapters
        iobroker restart - restarts the js-controller
        iobroker restart <adapter>[.instance] - restarts a specified adapter
        iobroker debug <adapter> [--ip=<ip>] [--port=<port>] [--wait] - Starts a Node.js debugging session for the adapter
            --wait stops the execution until the debugger is attached.
            --ip and --port can be used to change the listen IP and port. Use IP 0.0.0.0 for remote debugging.
        iobroker info - shows the host info
        iobroker logs [adapter] [--watch] [--lines=1000]
        iobroker add <adapter> [desiredNumber] [--enabled] [--host <host>] [--port <port>]
        iobroker install <adapter> - installs a specified adapter
        iobroker rebuild <adapter>|self [--install]
        iobroker url <url> [<name>] - install adapter from specified url, e.g. GitHub
        iobroker del <adapter> - remove adapter from system
        iobroker del <adapter>.<instance> - remove adapter instance
        iobroker update [repository url] [--updatable/--u] [--installed/--i] [--force/--f] - update repository and optionally filter installed/updateable adapters, use --force to bypass hash check
        iobroker upgrade [repository url]
        iobroker upgrade self [repository url] - upgrade js-controller and all adapters, optionally you can specify the repository url
        iobroker upgrade <adapter> [repository url] - upgrade specified adapter, optionally you can specify the repository url
        iobroker upload <pathToLocalFile> <pathIniobroker>
        iobroker upload all - upload all adapter files to make them available for instances
        iobroker upload <adapter> - upload specified adapter files to make them available for instances
        iobroker object get <id> - get object specified by id
        iobroker object set <id> <json-value> - set object with the given id by providing a new json object
        iobroker object set <id> propertyname=<value or json-value> - update part of the object by providing a new value or partial object
        iobroker object extend <id> <json-value> - extend object with the given id by providing a new json object
        iobroker object del <id|pattern> [--yes]
        iobroker object chmod <object-mode> [state-mode] <id>
        iobroker object chown <user> <group> <id>
        iobroker object list <id>
        iobroker state get <id> - get state, specified by id
        iobroker state getplain <id> [--pretty]
        iobroker state getvalue <id>
        iobroker state set <id> <value> [ack]
        iobroker state del <id>
        iobroker message <adapter>[.instance] <command> [<message>]
        iobroker list <type> [filter]
        iobroker chmod <mode> <file>
        iobroker chown <user> <group> <file>
        iobroker touch <file>
        iobroker rm <file>
        iobroker file read <iobroker-path-to-read> [<filesystem-path-to-write>]
        iobroker file write <filesystem-path-to-read> <iobroker-path-to-write>
        iobroker file rm <iobroker-path-to-delete>
        iobroker file sync
        iobroker user add <user> [--ingroup group] [--password pass]
        iobroker user del <user>
        iobroker user passwd <user> [--password pass]
        iobroker user enable <user>
        iobroker user disable <user>
        iobroker user get <user>
        iobroker user check <user> [--password pass]
        iobroker group add <group>
        iobroker group del <group>
        iobroker group list <group>
        iobroker group enable <group>
        iobroker group disable <group>
        iobroker group get <group>
        iobroker group adduser <group> <user>
        iobroker group deluser <group> <user>
        iobroker host this
        iobroker host <hostname>
        iobroker host set <hostname>
        iobroker host remove <hostname>
        iobroker set <adapter>.<instance> [--port port] [--ip address] [--ssl true|false]
        iobroker license <license.file or license.text>
        iobroker cert create
        iobroker cert view [<certificate name>]
        iobroker clean
        iobroker backup
        iobroker restore <backup name or path> - restore a specified backup
        iobroker validate <backup name or path> - validate a specified backup
        iobroker <command> --timeout 5000
        iobroker status [all|<adapter>.<instance>]
        iobroker repo [name]
        iobroker repo add <name> <path or url>
        iobroker repo set <name>
        iobroker repo del <name>
        iobroker uuid
        iobroker unsetup
        iobroker fix - execute the installation fixer script, this updates your ioBroker installation
        iobroker multihost <enable|disable> [--secure true|false]
        iobroker multihost browse
        iobroker multihost connect
        iobroker compact status - show if compact mode is enabled in general
        iobroker compact <enable|on|disable|off> - enable or disable compact mode in general
        iobroker compact <adapter>.<instance> status - show if compact mode is enabled for a specific instance
        iobroker compact <adapter>.<instance> group <group-id> - define compact group of a specific adapter
        iobroker compact <adapter>.<instance> <disable|off> - enable or disable compact mode for specified adapter instance
        iobroker compact <adapter>.<instance> <enable|on> [group-id] - enable or disable compact mode for specified adapter instance and set comapct group optionally
        iobroker plugin enable <pluginname> [--host <hostname>] - enables a plugin for the specified host. If no host is specified, the current one is used
        iobroker plugin disable <pluginname> [--host <hostname>] - disables a plugin for the specified host. If no host is specified, the current one is used
        iobroker plugin status <pluginname> [--host <hostname>] - checks if a plugin is enabled for the specified host. If no host is specified, the current one is used
        iobroker plugin enable <pluginname> --instance <adapter>[.<nr>] - enables a plugin for the specified adapter instance (defaults to instance 0)
        iobroker plugin disable <pluginname> --instance <adapter>[.<nr>] - disables a plugin for the specified adapter instance (defaults to instance 0)
        iobroker plugin status <pluginname> --instance <adapter>[.<nr>] - checks if a plugin is enabled for the specified adapter instance (defaults to instance 0)
        iobroker version [adapter] - show version of js-controller or specified adapter
        iobroker [adapter] -v - show version of js-controller or specified adapter
        Options:
          --help     Hilfe anzeigen  [boolean]
          --version  Version anzeigen  [boolean]
        • F Finnimeister
          sorry...
          code_textCommands:
          iobroker rm <file>
          iobroker file sync
          iobroker host this
          iobroker clean
          iobroker backup
          iobroker uuid
          iobroker unsetup
          Options:
          @Finnimeister
          curl -sL https://iobroker.net/fix.sh | bash –
          Und bitte poste deine Eingabe mit. Dann kann man besser sehen, was du da so treibst.
          • F Offline
            Finnimeister
            Hallo hatte leider gestern kein netz mehr...
            es hat erst gelaufen und dan habe ich was aktualiesiert und dan gin wieder nix mehr...
            code_textpi@All-In-One_RasPi:/opt/iobroker $ iobroker start
            internal/modules/cjs/loader.js:969
              throw err;
            Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
                at Function.Module._resolveFilename (internal/modules/cjs/loader.js:966:15)
                at Function.Module._load (internal/modules/cjs/loader.js:842:27)
                at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:71:12)
                at internal/main/run_main_module.js:17:47 {
              code: 'MODULE_NOT_FOUND',
              requireStack: []
            • F Finnimeister
                throw err;
                requireStack: []
              @Finnimeister Was hast du denn wie aktualisiert?
              Fixer nochmal drüber jagen:
              F 1 Antwort Letzte Antwort
                Finnimeister
                @Thomas-Braun
                hab auf den kreis geklickt zu aktualiesieren
                • F Finnimeister
                  @Thomas-Braun
                  @Finnimeister
                  Fixer laufen lassen.
                  Dann
                  iobroker update
                  iobroker upgrade
                  • F Offline
                    Finnimeister
                    geht leider nicht....
                    code_textpi@All-In-One_RasPi:/opt/iobroker $ iobroker update
                      throw err;
                      requireStack: []
                    • F Finnimeister
                        throw err;
                        requireStack: []
                      @Finnimeister Und der Fixer?
                      • F Offline
                        Finnimeister
                        geht auch nicht...
                        code_textpi@All-In-One_RasPi:/opt/iobroker $ curl -sL https://iobroker.net/fix.sh | bash –
                        bash: –: Datei oder Verzeichnis nicht gefunden
                        • F Finnimeister
                          geht auch nicht...
                          @Finnimeister
                          cd /opt/iobroker
                          sudo -H -u iobroker npm install iobroker.js-controller
                          • F Offline
                            Finnimeister
                            code_textpi@All-In-One_RasPi:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.js-controller
                            sudo: Unbekannter Benutzer: iobroker
                            sudo: Regelwerks-Plugin konnte nicht initialisiert werden
                            • F Finnimeister
                              @Finnimeister
                              Warum hast du denn keinen user iobroker?
                              So eine alte Installation?
                              cd /opt/iobroker
                              • F Offline
                                Finnimeister
                                Danke !!! bist der beste....es läuft wieder....
                                • F Finnimeister
                                  @Finnimeister
                                  Dann jetzt den Fixer hinterher!
                                  • F Offline
                                    Finnimeister
                                    Meinst du das...
                                    code_textcurl -sL https://iobroker.net/fix.sh | bash –
                                    • F Finnimeister
                                      Meinst du das...
                                      @Finnimeister
                                      Ja. Oder
                                      iobroker stop
                                      iobroker fix
                                      • F Offline
                                        Finnimeister
                                        code_textpi@All-In-One_RasPi:/opt/iobroker $ iobroker fix
                                        Commands:
                                        iobroker rm <file>
                                        iobroker file sync
                                        iobroker host this
                                        iobroker clean
                                        iobroker backup
                                        iobroker uuid
                                        iobroker unsetup
                                        Options:
                                        • F Finnimeister
                                          Commands:
                                          iobroker rm <file>
                                          iobroker file sync
                                          iobroker host this
                                          iobroker clean
                                          iobroker backup
                                          iobroker uuid
                                          iobroker unsetup
                                          Options:
                                          @Finnimeister
