  4. SyntaxError: Unexpected Tokken
syntaxerror
71 Beiträge 4 Kommentatoren 7.6k Aufrufe 2 Beobachtet
  • F Offline
    Finnimeister
    code_text/usr/bin/nodejs
    v12.18.1
    /usr/bin/node
    v12.18.1
    /usr/bin/npm
    6.14.5
    nodejs:
      Installiert:           12.18.1-1nodesource1
      Installationskandidat: 12.18.1-1nodesource1
      Versionstabelle:
     *** 12.18.1-1nodesource1 500
            500 https://deb.nodesource.com/node_12.x stretch/main armhf Packages
         8.11.1~dfsg-2~bpo9+1 500
            500 http://archive.raspberrypi.org/debian stretch/main armhf Packages
         4.8.2~dfsg-1 500
            500 http://raspbian.raspberrypi.org/raspbian stretch/main armhf Packages
    pi@All-In-One_RasPi:~ $
    • F Finnimeister
      v12.18.1
      /usr/bin/node
      v12.18.1
      /usr/bin/npm
      6.14.5
      nodejs:
        Versionstabelle:
           4.8.2~dfsg-1 500
      @Finnimeister
      iobroker stop
      iobroker fix
      iobroker start
      Und dann sollte das Ding wieder laufen.
      • F Offline
        Finnimeister
        code_textpi@All-In-One_RasPi:~ $ iobroker start
        Starting iobroker controller daemon...
        iobroker controller daemon failed to start:  Failed to write pidfile (EACCES)
        An unknown error occurred: Error: Failed to write pidfile (EACCES)
        • F Finnimeister
          @Finnimeister Was passierte bei
          iobroker fix
          denn? Ich kann nicht hellsehen...
          • F Offline
            Finnimeister
            sorry...
            code_textCommands:
            iobroker setup [--objects <host>] [--states <host>] [custom]
            iobroker start - starts the js-controller
            iobroker stop - stops the js-controller
            iobroker start <adapter>[.instance] - starts a specified adapter instance
            iobroker stop <adapter>.[instance] - stops a specified adapter instance
            iobroker start all - starts js-controller and all adapters
            iobroker restart - restarts the js-controller
            iobroker restart <adapter>[.instance] - restarts a specified adapter
            iobroker debug <adapter> [--ip=<ip>] [--port=<port>] [--wait] - Starts a Node.js debugging session for the adapter
                --wait stops the execution until the debugger is attached.
                --ip and --port can be used to change the listen IP and port. Use IP 0.0.0.0 for remote debugging.
            iobroker info - shows the host info
            iobroker logs [adapter] [--watch] [--lines=1000]
            iobroker add <adapter> [desiredNumber] [--enabled] [--host <host>] [--port <port>]
            iobroker install <adapter> - installs a specified adapter
            iobroker rebuild <adapter>|self [--install]
            iobroker url <url> [<name>] - install adapter from specified url, e.g. GitHub
            iobroker del <adapter> - remove adapter from system
            iobroker del <adapter>.<instance> - remove adapter instance
            iobroker update [repository url] [--updatable/--u] [--installed/--i] [--force/--f] - update repository and optionally filter installed/updateable adapters, use --force to bypass hash check
            iobroker upgrade [repository url]
            iobroker upgrade self [repository url] - upgrade js-controller and all adapters, optionally you can specify the repository url
            iobroker upgrade <adapter> [repository url] - upgrade specified adapter, optionally you can specify the repository url
            iobroker upload <pathToLocalFile> <pathIniobroker>
            iobroker upload all - upload all adapter files to make them available for instances
            iobroker upload <adapter> - upload specified adapter files to make them available for instances
            iobroker object get <id> - get object specified by id
            iobroker object set <id> <json-value> - set object with the given id by providing a new json object
            iobroker object set <id> propertyname=<value or json-value> - update part of the object by providing a new value or partial object
            iobroker object extend <id> <json-value> - extend object with the given id by providing a new json object
            iobroker object del <id|pattern> [--yes]
            iobroker object chmod <object-mode> [state-mode] <id>
            iobroker object chown <user> <group> <id>
            iobroker object list <id>
            iobroker state get <id> - get state, specified by id
            iobroker state getplain <id> [--pretty]
            iobroker state getvalue <id>
            iobroker state set <id> <value> [ack]
            iobroker state del <id>
            iobroker message <adapter>[.instance] <command> [<message>]
            iobroker list <type> [filter]
            iobroker chmod <mode> <file>
            iobroker chown <user> <group> <file>
            iobroker touch <file>
            iobroker rm <file>
            iobroker file read <iobroker-path-to-read> [<filesystem-path-to-write>]
            iobroker file write <filesystem-path-to-read> <iobroker-path-to-write>
            iobroker file rm <iobroker-path-to-delete>
            iobroker file sync
            iobroker user add <user> [--ingroup group] [--password pass]
            iobroker user del <user>
            iobroker user passwd <user> [--password pass]
            iobroker user enable <user>
            iobroker user disable <user>
            iobroker user get <user>
            iobroker user check <user> [--password pass]
            iobroker group add <group>
            iobroker group del <group>
            iobroker group list <group>
            iobroker group enable <group>
            iobroker group disable <group>
            iobroker group get <group>
            iobroker group adduser <group> <user>
            iobroker group deluser <group> <user>
            iobroker host this
            iobroker host <hostname>
            iobroker host set <hostname>
            iobroker host remove <hostname>
            iobroker set <adapter>.<instance> [--port port] [--ip address] [--ssl true|false]
            iobroker license <license.file or license.text>
            iobroker cert create
            iobroker cert view [<certificate name>]
            iobroker clean
            iobroker backup
            iobroker restore <backup name or path> - restore a specified backup
            iobroker validate <backup name or path> - validate a specified backup
            iobroker <command> --timeout 5000
            iobroker status [all|<adapter>.<instance>]
            iobroker repo [name]
            iobroker repo add <name> <path or url>
            iobroker repo set <name>
            iobroker repo del <name>
            iobroker uuid
            iobroker unsetup
            iobroker fix - execute the installation fixer script, this updates your ioBroker installation
            iobroker multihost <enable|disable> [--secure true|false]
            iobroker multihost browse
            iobroker multihost connect
            iobroker compact status - show if compact mode is enabled in general
            iobroker compact <enable|on|disable|off> - enable or disable compact mode in general
            iobroker compact <adapter>.<instance> status - show if compact mode is enabled for a specific instance
            iobroker compact <adapter>.<instance> group <group-id> - define compact group of a specific adapter
            iobroker compact <adapter>.<instance> <disable|off> - enable or disable compact mode for specified adapter instance
            iobroker compact <adapter>.<instance> <enable|on> [group-id] - enable or disable compact mode for specified adapter instance and set comapct group optionally
            iobroker plugin enable <pluginname> [--host <hostname>] - enables a plugin for the specified host. If no host is specified, the current one is used
            iobroker plugin disable <pluginname> [--host <hostname>] - disables a plugin for the specified host. If no host is specified, the current one is used
            iobroker plugin status <pluginname> [--host <hostname>] - checks if a plugin is enabled for the specified host. If no host is specified, the current one is used
            iobroker plugin enable <pluginname> --instance <adapter>[.<nr>] - enables a plugin for the specified adapter instance (defaults to instance 0)
            iobroker plugin disable <pluginname> --instance <adapter>[.<nr>] - disables a plugin for the specified adapter instance (defaults to instance 0)
            iobroker plugin status <pluginname> --instance <adapter>[.<nr>] - checks if a plugin is enabled for the specified adapter instance (defaults to instance 0)
            iobroker version [adapter] - show version of js-controller or specified adapter
            iobroker [adapter] -v - show version of js-controller or specified adapter
            Options:
              --help     Hilfe anzeigen  [boolean]
              --version  Version anzeigen  [boolean]
            • F Finnimeister
              sorry...
              code_textCommands:
              iobroker rm <file>
              iobroker file sync
              iobroker host this
              iobroker clean
              iobroker backup
              iobroker uuid
              iobroker unsetup
              Options:
              @Finnimeister
              curl -sL https://iobroker.net/fix.sh | bash –
              Und bitte poste deine Eingabe mit. Dann kann man besser sehen, was du da so treibst.
              • F Offline
                Finnimeister
                Hallo hatte leider gestern kein netz mehr...
                es hat erst gelaufen und dan habe ich was aktualiesiert und dan gin wieder nix mehr...
                code_textpi@All-In-One_RasPi:/opt/iobroker $ iobroker start
                internal/modules/cjs/loader.js:969
                  throw err;
                Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
                    at Function.Module._resolveFilename (internal/modules/cjs/loader.js:966:15)
                    at Function.Module._load (internal/modules/cjs/loader.js:842:27)
                    at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:71:12)
                    at internal/main/run_main_module.js:17:47 {
                  code: 'MODULE_NOT_FOUND',
                  requireStack: []
                • F Finnimeister
                    throw err;
                    requireStack: []
                  @Finnimeister Was hast du denn wie aktualisiert?
                  Fixer nochmal drüber jagen:
                  F 1 Antwort Letzte Antwort
                    Finnimeister
                    @Thomas-Braun
                    hab auf den kreis geklickt zu aktualiesieren
                    • F Finnimeister
                      @Thomas-Braun
                      @Finnimeister
                      Fixer laufen lassen.
                      Dann
                      iobroker update
                      iobroker upgrade
                      • F Offline
                        Finnimeister
                        geht leider nicht....
                        code_textpi@All-In-One_RasPi:/opt/iobroker $ iobroker update
                          throw err;
                          requireStack: []
                        • F Finnimeister
                            throw err;
                            requireStack: []
                          @Finnimeister Und der Fixer?
                          • F Offline
                            Finnimeister
                            geht auch nicht...
                            code_textpi@All-In-One_RasPi:/opt/iobroker $ curl -sL https://iobroker.net/fix.sh | bash –
                            bash: –: Datei oder Verzeichnis nicht gefunden
                            • F Finnimeister
                              geht auch nicht...
                              @Finnimeister
                              cd /opt/iobroker
                              sudo -H -u iobroker npm install iobroker.js-controller
                              • F Offline
                                Finnimeister
                                code_textpi@All-In-One_RasPi:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.js-controller
                                sudo: Unbekannter Benutzer: iobroker
                                sudo: Regelwerks-Plugin konnte nicht initialisiert werden
                                • F Finnimeister
                                  @Finnimeister
                                  Warum hast du denn keinen user iobroker?
                                  So eine alte Installation?
                                  cd /opt/iobroker
                                  • F Offline
                                    Finnimeister
                                    Danke !!! bist der beste....es läuft wieder....
                                    • F Finnimeister
                                      @Finnimeister
                                      Dann jetzt den Fixer hinterher!
                                      • F Offline
                                        Finnimeister
                                        Meinst du das...
                                        code_textcurl -sL https://iobroker.net/fix.sh | bash –
                                        • F Finnimeister
                                          Meinst du das...
                                          @Finnimeister
                                          Ja. Oder
                                          iobroker stop
                                          iobroker fix
