  4. FireTv 1.0.0 testen
FireTv 1.0.0 testen
firetvamazontest
82 Beiträge 21 Kommentatoren 13.6k Aufrufe 30 Beobachtet
  • harrymH harrym
    @sigi234 eventuell den FireTV mal resetten/updaten und die Entwicklereinstellungen vom Stick checken ?
    sigi234S Online
    sigi234S Online
    @harrym sagte in FireTv 1.0.0 testen:
    firetv.0	2020-04-12 20:21:42.027	debug	(12848) system.adapter.admin.0: logging true
    firetv.0	2020-04-12 20:19:42.661	debug	(12848) system.adapter.admin.0: logging false
    firetv.0	2020-04-12 20:18:04.882	error	(12848) can not connect to 192.168.178.54 Error=unable to connect to 192.168.178.54:5555: cannot connect to 192.168.178.54:5555: Es konnte keine Verbindung hergestellt werden, da der Zielcomputer die
    firetv.0	2020-04-12 20:18:02.864	info	(12848) 192.168.178.57: ADB version: 39, Android Version: , API Level:
    firetv.0	2020-04-12 20:18:02.863	error	(12848) ID: 192.168.178.57 Error=Failure: 'device '192.168.178.57:5555' not found'
    firetv.0	2020-04-12 20:18:02.860	error	(12848) ID: 192.168.178.57 Error=Failure: 'device '192.168.178.57:5555' not found'
    firetv.0	2020-04-12 20:18:02.858	error	(12848) ID: 192.168.178.57 Error=Failure: 'device '192.168.178.57:5555' not found'
    firetv.0	2020-04-12 20:18:02.855	error	(12848) ID: 192.168.178.57 Error=Failure: 'device '192.168.178.57:5555' not found'
    firetv.0	2020-04-12 20:18:02.854	debug	(12848) Connected to 192.168.178.57 id=192.168.178.57:5555
    firetv.0	2020-04-12 20:18:02.848	debug	(12848) Device 192.168.178.57:5555 was unplugged
    firetv.0	2020-04-12 20:18:02.839	debug	(12848) Device 192.168.178.57:5555 + type=offline was plugged in
    firetv.0	2020-04-12 20:18:02.799	debug	(12848) FireTV: 192.168.178.57
    firetv.0	2020-04-12 20:18:02.798	debug	(12848) FireTV: 192.168.178.54
    firetv.0	2020-04-12 20:18:02.724	info	(12848) starting. Version 1.0.0 in C:/Program Files/iobroker/Test/node_modules/iobroker.firetv, node: v10.16.3, js-controller: 3.0.7
    firetv.0	2020-04-12 20:18:02.590	debug	(12848) statesDB connected
    firetv.0	2020-04-12 20:18:02.590	debug	(12848) States connected to redis: 127.0.0.1:9000
    firetv.0	2020-04-12 20:18:02.580	debug	(12848) States create System PubSub Client
    firetv.0	2020-04-12 20:18:02.579	debug	(12848) States create User PubSub Client
    firetv.0	2020-04-12 20:18:02.575	debug	(12848) Redis States: Use Redis connection: 127.0.0.1:9000
    firetv.0	2020-04-12 20:18:02.574	debug	(12848) objectDB connected
    firetv.0	2020-04-12 20:18:02.572	debug	(12848) Objects connected to redis: 127.0.0.1:9013
    firetv.0	2020-04-12 20:18:02.562	debug	(12848) Objects client initialize lua scripts
    firetv.0	2020-04-12 20:18:02.562	debug	(12848) Objects create User PubSub Client
    firetv.0	2020-04-12 20:18:02.562	debug	(12848) Objects create System PubSub Client
    firetv.0	2020-04-12 20:18:02.561	debug	(12848) Objects client ready ... initialize now
    firetv.0	2020-04-12 20:18:02.543	debug	(12848) Redis Objects: Use Redis connection: 127.0.0.1:9013
    firetv.0	2020-04-12 20:17:59.210	info	(2544) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    firetv.0	2020-04-12 20:17:59.209	info	(2544) terminating
    firetv.0	2020-04-12 20:17:59.208	info	(2544) Got terminate signal TERMINATE_YOURSELF
    • foxriver76F foxriver76
      Bitte auch mal nicht js-c 3 Tester testen ob es tut. ;-)
      @foxriver76 sagte in FireTv 1.0.0 testen:
      Tut auch unter 2.2.9 🙂
      • capitaenzC Offline
        capitaenzC Offline
        capitaenz
        schrieb am zuletzt editiert von capitaenz
        Ich habe den Adapter auch zum laufen bekommen mit dem JS-Controller 2.2.9 (bekomme kein Update auf V3 angeboten).
        Was mich zum verzweifeln gebracht hat:
        • Folgendes ist falsch:
        Client = require('/opt/iobroker/node_modules/adbkit/lib/adb/client'),
        richtig:
        Client = require('/opt/iobroker/node_modules/adbkit/lib/adb/client');
        • Außderdem muss mit:
        sudo apt-get install -y android-tools-adb android-tools-fastboot
        Auf dem Tinkerboard (Raspberry) noch etwas nachinstalliert werden.
        • Zum Hinzufügen +-Button betätigen
          Das "+" ist gaaaaaaanz unten links versteckt!!!
        Jetzt kann ich zwar einen Reboot durchführen und links, rechts, usw bedienen, aber wie starte ich die Apps, z.B. You Tube?
        Hat da jemand einen Tipp für mich?
        Leif
        ioBroker auf Synology DS920+ (SSD Raid / 20GB RAM) im VMM
        harrymH 1 Antwort Letzte Antwort
        • capitaenzC capitaenz
          richtig:
          Leif
          harrymH Offline
          harrymH Offline
          harrym
          @capitaenz sagte in FireTv 1.0.0 testen:
          DP "startApp"
          richtig:
          Client = require('./node_modules/adbkit/lib/adb/client');
          Nö ;)  Client = require('/opt/iobroker/node_modules/adbkit/lib/adb/client');
          ASRock FM2A88X-ITX+ mit 32GB RAM, 128GB SSD mit Proxmox, 3x1 TB SSD als RAID mit CT und VMs.
          capitaenzC 1 Antwort Letzte Antwort
          • harrymH harrym
            DP "startApp"
            richtig:
            capitaenzC Offline
            capitaenzC Offline
            capitaenz
            @harrym
            Sorry, hab das falsche kopiert:
            falsch:
            richtig:
            Und dann unter startApp z.B. YouTube eingeben?
            Funktioniert aber leider bei mir nicht :-(
            • padrinoP Online
              padrinoP Online
              padrino
              So, im Moment läuft er - endlich =)
              Direkt mal eine Frage, die ganzen "Keys" Datenpunkte, wäre es da nicht sinnvoll, wenn die Rolle "button" statt "state" wäre? 🤔
                Sali84
                Gibt es irgendwo eine Übersicht über alle Funktionen die man machen kann?
                  SourKraut
                  Aloha zusammen
                  kennt zufällig jemand die Commands, die der Stick über ADB umsetzen kann.
                  Meines Wissens kann über die Bridge auch ein CEC-Signal vom Stick an den Fernseher gesendet werden.
                  Leider finde ich im Netz nichts was mir da weiterhilft.
                  Mir gehts darum meinen Samsung TV vom Stick wecken zu lassen. Per LAN geht`s ja bekannter Maßen nicht.
                  An sich funktioniert das ja, wenn ich den Stick per Adapter anspreche aber auch nur, wenn der TV schon länger aus ist.
                  Selbst wenn ich den AFTS per adb in den Ruhemodus schicke und wieder wecke, beeindruckt das den TV wenig.
                  Daher würde ich gern ein CEC-Signal vom Stick direkt mal triggern.
                  • S SourKraut
                    Aloha zusammen
                    Sali84
                    @SourKraut Sprich einfach die Taste Menu/home vom Stick an, dann wacht der TV auf.
                    • S Sali84
                      SourKraut
                      schrieb am zuletzt editiert von SourKraut
                      @Sali84
                      Um den Stick zu wecken nutze ich mittlerweile
                      adb shell input keyevent refresh
                      Allerdings reagiert der TV nicht, wenn der Stick dann läuft.
                      Ich kann den Stick auch nicht mehr in den Sleepmode schicken... Keine Ahnung warum.
                      Über den Adapter hat es einmal funktioniert, seid dem nicht mehr.
                      Direkt über die Bridge reagiert er auch nicht mehr auf
                      adb shell input keyevent 26
                      Das Ding treibt mich langsam aber sicher in den Wahnsinn. 😁
                      Der Adapter bekommt mittlerweile auch keine Verbindung mehr zum Stick.
                        Sali84
                        ich muss zugeben das der Adapter auch nicht so ganz funktioniert wie ich mir das vorstelle. Wird er noch grossartig weiterentwickelt?
                          SourKraut
                          Für mich sieht es tatsächlich so aus, als wäre nicht der Adapter allein das Problem.
                          Mein Stick z.B. zickt ja schon beim direkten ansprechen über die ADB.
                          kaerichiK 1 Antwort Letzte Antwort
                          • S SourKraut
                            kaerichiK Offline
                            kaerichiK Offline
                            kaerichi
                            schrieb am zuletzt editiert von kaerichi
                            Hallo zusammen, ich bekomme den Adapter gar nicht erst gestartet. Alles mögliche schon probiert,auch von hier https://forum.iobroker.net/topic/6804/fire-tv-adapter/105
                            Ich glaube bei mir läuft es wohl komplett schief ;-) Bin aber auch Neuling bei iobroker und mit Linux habe ich schon Jahre nicht mehr rumhantiert :-) MFG
                            EDIT: Hat sich erledigt. iobroker.firetv@1.0.0 manuell von der Konsole installiert, dann über Konsole die Instanz zu iobroker hinzugefügt. Wurde sofort grün, der Adapter findet ADB von alleine.
                            • Z Offline
                              Z Offline
                              zombiee77
                              Wahrscheinlich steht es hier irgendwo, aber ich habe es nicht gefunden.
                              In /usr/bin/ liegt der link zum adb:
                              trotzdem erhalte ich folgende Meldung:
                              firetv.0	2020-07-01 21:11:32.545	error	(3012264) adb executable not found. undefined
                              firetv.0	2020-07-01 21:11:32.423	info	(3012264) starting. Version 1.0.0 in /opt/iobroker/node_modules/iobroker.firetv, node: v10.21.0, js-controller: 3.1.6
                              host.ZBOX-NANO-Linux	2020-07-01 21:11:30.598	info	instance system.adapter.firetv.0 started with pid 3012264
                              Was mache ich falsch?
                              • Z zombiee77
                                @zombiee77 Folge dem Link und gib im Adapter den direkten Pfad zur adb ein. Muss ich bei mir auch machen
                                • Z Offline
                                  Z Offline
                                  zombiee77
                                  @Thomas-Braun Danke!!
                                  Jetzt spuckt er die Fehlermeldung nicht mehr aus.
                                  Aber finden tut er auch kein Device, obwohl ich USB-Debugging am Fire-Stick eingeschaltet habe.
                                  • Z zombiee77
                                    crunchipC Offline
                                    crunchipC Offline
                                    @zombiee77 manuell eintragen
                                    Z 1 Antwort Letzte Antwort
                                      Z Offline
                                      Z Offline
                                      zombiee77
                                      @crunchip Danke! Hat geklappt!
                                      • Z Offline
                                        Z Offline
                                        zombiee77
                                        Gibt es eine Erklärung für die Objekte?
                                        Welche kann ich schreiben und welche kann ich nur lesen?
                                        • Christoph1337C Offline
                                          Christoph1337
                                          @foxriver76 Ich habe den adapter eine ganze weile getestet. was mir wirklich hier noch fehlt ist eine Möglichkeit zu prüfen ob gerade etwas abgespielt wird. Egal ob Netflix oder Amazon video.
                                          Das wäre mega!
