  4. Update tr-064 Adapter
adapter
28 Beiträge 4 Kommentatoren 3.4k Aufrufe 4 Beobachtet
  • R Ralf
    @Thomas-Braun Nach der Deinstallation und Restart von iobroker wird immer noch das Update angeboten obwohl der Adapter in den Instanzen nicht mehr vorhanden ist. Blicke im Moment leider nicht durch.
    @Ralf
    iobroker list adapters
    iobroker update
    iobroker del tr-064
    iobroker add tr-064
    R 1 Antwort Letzte Antwort
      @Ralf
      iobroker update
      iobroker del tr-064
      iobroker add tr-064
      Ralf
      @Thomas-Braun sagte in Update tr-064 Adapter:
      iobroker del tr-064
      Adapter lässt sich nicht deinstallieren :
      <Delete adapter "tr-064"
      npm uninstall iobroker.tr-064 --error --prefix "/opt/iobroker" (System call)
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.tr-064/node_modules/array-ext
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.tr-064/node_modules/dgram
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.tr-064/node_modules/ip
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.tr-064/node_modules/safe-buffer
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.tr-064/node_modules/dns-packet
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.tr-064/node_modules/sprintf-js
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.tr-064/node_modules/soef
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@^1.0.5 (node_modules/iobroker.info/node_modules/osx-temperature-sensor):
      npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.7: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.1.2 (node_modules/chokidar/node_modules/fsevents):
      npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.3: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
      npm ERR! code EACCES
      npm ERR! syscall access
      npm ERR! path /opt/iobroker/node_modules/iobroker.tr-064/node_modules/array-ext
      npm ERR! errno -13
      npm ERR! Error: EACCES: permission denied, access '/opt/iobroker/node_modules/iobroker.tr-064/node_modules/array-ext'
      npm ERR! { [Error: EACCES: permission denied, access '/opt/iobroker/node_modules/iobroker.tr-064/node_modules/array-ext']
      npm ERR! stack:
      npm ERR! 'Error: EACCES: permission denied, access '/opt/iobroker/node_modules/iobroker.tr-064/node_modules/array-ext'',
      npm ERR! errno: -13,
      npm ERR! code: 'EACCES',
      npm ERR! syscall: 'access',
      npm ERR! path:
      npm ERR! '/opt/iobroker/node_modules/iobroker.tr-064/node_modules/array-ext' }
      npm ERR!
      npm ERR! The operation was rejected by your operating system.
      npm ERR! It is likely you do not have the permissions to access this file as the current user
      npm ERR!
      npm ERR! If you believe this might be a permissions issue, please double-check the
      npm ERR! permissions of the file and its containing directories, or try running
      npm ERR! the command again as root/Administrator.
      npm ERR! /home/iobroker/.npm/_logs/2020-06-01T08_05_12_110Z-debug.log
      Error deleting adapter tr-064 from disk: Error: host.debian-iobroker: Cannot uninstall iobroker.tr-064: 243
      You might have to delete it yourself!
      root@debian-iobroker:~#
      • R Ralf
        iobroker del tr-064
        npm ERR! errno -13
        npm ERR! stack:
        npm ERR! path:
        npm ERR!
        npm ERR!
        @Ralf
        Nicht als root rumhampeln und Konsolenausgaben in CodeTags setzen.
        • R Ralf
          seit einiger Zeit wird im iobroker ein Update angeboten, welches aber nicht installiert werden kann. Im Log steht Folgendes :
          tr-064.0 2020-06-01 09:18:46.824 info (4526) Terminated (NO_ERROR): Without reason
          tr-064.0 2020-06-01 09:18:46.822 info (4526) terminating
          tr-064.0 2020-06-01 09:18:46.785 error (4526) TypeError: Cannot read property 'getState' of undefined at checkIfUpdated (/opt/iobroker/node_modules/iobroker.tr-064/node_modules/soef/soef.js:1239:20) at Object.options.ready (/opt/io
          tr-064.0 2020-06-01 09:18:46.782 error (4526) unhandled promise rejection: Cannot read property 'getState' of undefined
          tr-064.0 2020-06-01 09:18:46.781 error Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
          tr-064.0 2020-06-01 09:18:46.724 info (4526) starting. Version 0.4.18 in /opt/iobroker/node_modules/iobroker.tr-064, node: v10.20.1, js-controller: 3.1.4
          tr-064.0 2020-06-01 09:18:13.493 info (3556) Terminated (NO_ERROR): Without reason
          tr-064.0 2020-06-01 09:18:13.492 info (3556) terminating
          tr-064.0 2020-06-01 09:18:13.459 error (3556) TypeError: Cannot read property 'getState' of undefined at checkIfUpdated (/opt/iobroker/node_modules/iobroker.tr-064/node_modules/soef/soef.js:1239:20) at Object.options.ready (/opt/io
          tr-064.0 2020-06-01 09:18:13.455 error (3556) unhandled promise rejection: Cannot read property 'getState' of undefined
          tr-064.0 2020-06-01 09:18:13.454 error Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
          tr-064.0 2020-06-01 09:18:13.394 info (3556) starting. Version 0.4.18 in /opt/iobroker/node_modules/iobroker.tr-064, node: v10.20.1, js-controller: 3.1.4
          tr-064.0 2020-06-01 09:17:40.102 info (2500) Terminated (NO_ERROR): Without reason
          tr-064.0 2020-06-01 09:17:40.101 info (2500) terminating
          tr-064.0 2020-06-01 09:17:40.067 error (2500) TypeError: Cannot read property 'getState' of undefined at checkIfUpdated (/opt/iobroker/node_modules/iobroker.tr-064/node_modules/soef/soef.js:1239:20) at Object.options.ready (/opt/io
          tr-064.0 2020-06-01 09:17:40.064 error (2500) unhandled promise rejection: Cannot read property 'getState' of undefined
          tr-064.0 2020-06-01 09:17:40.062 error Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
          tr-064.0 2020-06-01 09:17:39.999 info (2500) starting. Version 0.4.18 in /opt/iobroker/node_modules/iobroker.tr-064, node: v10.20.1, js-controller: 3.1.4
          tr-064.0 2020-06-01 09:17:06.757 info (1576) Terminated (NO_ERROR): Without reason
          tr-064.0 2020-06-01 09:17:06.756 info (1576) terminating
          Der Adapter ist rot und lässt sich auch nicht mehr starten.
          Kann da vielleicht jemand helfen ?
          sigi234S Online
          sigi234S Online
          @Ralf
          Bitte benutzt die Code Tags Funktion -> </>
          Hier gehts zur Hilfe.
            @Ralf
            Ralf
            @Thomas-Braun Meldung in der Konsole :
            Leider darf der Benutzer ralf »/usr/bin/iobroker update« als root auf debian-iobroker nicht ausführen.
            • sigi234S sigi234
              @Ralf
              Ralf
              @sigi234 sagte in Update tr-064 Adapter:
              Finde leider nichts dazu wie man´s macht.
              • R Ralf
                Jan1
                @Ralf
                Wie man mit der Maus scrollt ist aber bekannt, oder? Also scroll mal im Link von sigi234 bis Editor runter.
                • J Jan1
                  @Ralf
                  Ralf
                  @Jan1 ```
                  manchmal dauert´s halt etwas länger
                  • R Ralf
                    @Jan1 ```
                    Jan1
                    @Ralf
                    ist egal, wenn es dann doch irgendwann mal klappt ;-)
                    • J Jan1
                      @Ralf
                      Ralf
                      @Jan1 noch eine Idee wie ich den Adapter los werde und neu installieren kann ?
                      • R Ralf
                        @Ralf
                        adduser ralf sudo
                        Ggf. das nochmal als root und dann den root-login künftig vermeiden.
                          @Ralf
                          adduser ralf sudo
                          Ralf
                          @Ralf
                          adduser ralf sudo
                          ...und dann als "Ralf" einloggen ?
                          Ist das ein Problem, wenn ich mich als root einlogge ?
                          • R Ralf
                            @Ralf
                            adduser ralf sudo
                            @Ralf
                            Ja, dann als Ralf einloggen.
                            root-login sollte tabu sein.
                            Als ralf dann
                            sudo whoami
                              @Ralf
                              Als ralf dann
                              sudo whoami
                              Ralf
                              warum ??
                              • R Ralf
                                warum ??
                                @Ralf
                                Why sudo?
                                Using sudo is better (safer) than opening a session as root for a number of reasons, including:
                                Nobody needs to know the root password (sudo prompts for the current user's password). Extra privileges can be granted to individual users temporarily, and then taken away without the need for a password change.
                                It's easy to run only the commands that require special privileges via sudo; the rest of the time, you work as an unprivileged user, which reduces the damage that mistakes can cause.
                                Auditing/logging: when a sudo command is executed, the original username and the command are logged.
                                For the reasons above, switching to root using sudo -i (or sudo su) is usually deprecated because it cancels the above features.
                                Und das ganze System inkl. des Rechtemanagement ist darauf ausgelegt mit sudo zu agieren.
                                  @Ralf
                                  Why sudo?
                                  Ralf
                                  @Thomas-Braun Adapter lässt sich nach wie vor nicht deinstallieren :
                                  ralf@debian-iobroker:~$ sudo whoami
                                  root
                                  ralf@debian-iobroker:~$ iobroker del tr-064
                                  npm ERR! errno -13
                                  npm ERR!   stack:
                                  npm ERR!    'Error: EACCES: permission denied, access \'/opt/iobroker/node_modules/iobroker.tr-064/node_modules/array-ext\'',
                                  npm ERR!   path:
                                  npm ERR!
                                  npm ERR!
                                  npm ERR!     /home/iobroker/.npm/_logs/2020-06-01T09_12_12_551Z-debug.log
                                  • R Ralf
                                    root
                                    npm ERR! errno -13
                                    npm ERR!   stack:
                                    npm ERR!   path:
                                    npm ERR!
                                    npm ERR!
                                    @Ralf
                                    iobroker fix
                                      @Ralf
                                      iobroker fix
                                      Ralf
                                      iobroker fix
                                      und dann ?
                                      ralf@debian-iobroker:~$ iobroker fix
                                      library: loaded
                                      Library version=2020-04-12
                                      ioBroker or some processes are still running:
                                       io.admin.0
                                       io.discovery.0
                                       io.info.0
                                       io.hue.0
                                       io.ping.0
                                       io.harmony.0
                                       io.fakeroku.0
                                       io.web.0
                                       io.history.0
                                       io.javascript.0
                                       io.alexa2.0
                                       io.sonoff.0
                                       io.milight.0
                                       io.iot.0
                                       io.worx.0
                                       io.tuya.0
                                       io.shelly.0
                                      Please stop them first and try again!
                                      • R Ralf
                                        iobroker fix
                                        und dann ?
                                        library: loaded
                                         io.admin.0
                                         io.discovery.0
                                         io.info.0
                                         io.hue.0
                                         io.ping.0
                                         io.harmony.0
                                         io.fakeroku.0
                                         io.web.0
                                         io.history.0
                                         io.javascript.0
                                         io.alexa2.0
                                         io.sonoff.0
                                         io.milight.0
                                         io.iot.0
                                         io.worx.0
                                         io.tuya.0
                                         io.shelly.0
                                        @Ralf
                                        iobroker stop
                                        iobroker fix
                                          @Ralf
                                          iobroker stop
                                          iobroker fix
                                          Ralf
                                          @Thomas-Braun ok. sieht jetzt so aus :
                                              Welcome to the ioBroker installation fixer!
                                              Script version: 2020-04-12
                                              You might need to enter your password a couple of times.
                                              Installing prerequisites (1/3)
                                          OK:1 http://deb.debian.org/debian buster InRelease
                                          Holen:2 http://deb.debian.org/debian buster-updates InRelease [49,3 kB]
                                          Holen:3 http://security.debian.org/debian-security buster/updates InRelease [65,4 kB]
                                          OK:4 https://deb.nodesource.com/node_10.x buster InRelease
                                          Es wurden 115 kB in 2 s geholt (48,7 kB/s).
                                          Installed gcc-c++
                                          Installed python-dev
                                              Checking ioBroker user and directory permissions (2/3)
                                              Checking autostart (3/3)
                                          Enabling autostart...
                                          Autostart enabled!
                                              Your installation was fixed successfully
                                              Run iobroker start to start ioBroker again!
                                          ralf@debian-iobroker:~$ iobroker start
