  4. Update tr-064 Adapter
adapter
28 Beiträge 4 Kommentatoren 3.4k Aufrufe 4 Beobachtet
  • R Ralf
    seit einiger Zeit wird im iobroker ein Update angeboten, welches aber nicht installiert werden kann. Im Log steht Folgendes :
    tr-064.0 2020-06-01 09:18:46.824 info (4526) Terminated (NO_ERROR): Without reason
    tr-064.0 2020-06-01 09:18:46.822 info (4526) terminating
    tr-064.0 2020-06-01 09:18:46.785 error (4526) TypeError: Cannot read property 'getState' of undefined at checkIfUpdated (/opt/iobroker/node_modules/iobroker.tr-064/node_modules/soef/soef.js:1239:20) at Object.options.ready (/opt/io
    tr-064.0 2020-06-01 09:18:46.782 error (4526) unhandled promise rejection: Cannot read property 'getState' of undefined
    tr-064.0 2020-06-01 09:18:46.781 error Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    tr-064.0 2020-06-01 09:18:46.724 info (4526) starting. Version 0.4.18 in /opt/iobroker/node_modules/iobroker.tr-064, node: v10.20.1, js-controller: 3.1.4
    tr-064.0 2020-06-01 09:18:13.493 info (3556) Terminated (NO_ERROR): Without reason
    tr-064.0 2020-06-01 09:18:13.492 info (3556) terminating
    tr-064.0 2020-06-01 09:18:13.459 error (3556) TypeError: Cannot read property 'getState' of undefined at checkIfUpdated (/opt/iobroker/node_modules/iobroker.tr-064/node_modules/soef/soef.js:1239:20) at Object.options.ready (/opt/io
    tr-064.0 2020-06-01 09:18:13.455 error (3556) unhandled promise rejection: Cannot read property 'getState' of undefined
    tr-064.0 2020-06-01 09:18:13.454 error Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    tr-064.0 2020-06-01 09:18:13.394 info (3556) starting. Version 0.4.18 in /opt/iobroker/node_modules/iobroker.tr-064, node: v10.20.1, js-controller: 3.1.4
    tr-064.0 2020-06-01 09:17:40.102 info (2500) Terminated (NO_ERROR): Without reason
    tr-064.0 2020-06-01 09:17:40.101 info (2500) terminating
    tr-064.0 2020-06-01 09:17:40.067 error (2500) TypeError: Cannot read property 'getState' of undefined at checkIfUpdated (/opt/iobroker/node_modules/iobroker.tr-064/node_modules/soef/soef.js:1239:20) at Object.options.ready (/opt/io
    tr-064.0 2020-06-01 09:17:40.064 error (2500) unhandled promise rejection: Cannot read property 'getState' of undefined
    tr-064.0 2020-06-01 09:17:40.062 error Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    tr-064.0 2020-06-01 09:17:39.999 info (2500) starting. Version 0.4.18 in /opt/iobroker/node_modules/iobroker.tr-064, node: v10.20.1, js-controller: 3.1.4
    tr-064.0 2020-06-01 09:17:06.757 info (1576) Terminated (NO_ERROR): Without reason
    tr-064.0 2020-06-01 09:17:06.756 info (1576) terminating
    Der Adapter ist rot und lässt sich auch nicht mehr starten.
    Kann da vielleicht jemand helfen ?
    @Ralf EInmal den Adapter deinstallieren und dann neuinstallieren.
    BTW: Fehlermeldungen bitte in </> CodeTags setzen.
    R 1 Antwort Letzte Antwort
      Ralf
      @Thomas-Braun Nach der Deinstallation und Restart von iobroker wird immer noch das Update angeboten obwohl der Adapter in den Instanzen nicht mehr vorhanden ist. Blicke im Moment leider nicht durch.
      J Thomas BraunT 2 Antworten Letzte Antwort
      • R Ralf
        Jan1
        @Ralf
        Du hast wohl nur die Instanz deinstalliert und nicht den ganzen Adapter
        • R Ralf
          @Ralf
          iobroker list adapters
          iobroker update
          iobroker del tr-064
          iobroker add tr-064
            @Ralf
            iobroker update
            iobroker del tr-064
            iobroker add tr-064
            Ralf
            @Thomas-Braun sagte in Update tr-064 Adapter:
            iobroker del tr-064
            Adapter lässt sich nicht deinstallieren :
            <Delete adapter "tr-064"
            npm uninstall iobroker.tr-064 --error --prefix "/opt/iobroker" (System call)
            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.tr-064/node_modules/array-ext
            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.tr-064/node_modules/dgram
            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.tr-064/node_modules/ip
            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.tr-064/node_modules/safe-buffer
            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.tr-064/node_modules/dns-packet
            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.tr-064/node_modules/sprintf-js
            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.tr-064/node_modules/soef
            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@^1.0.5 (node_modules/iobroker.info/node_modules/osx-temperature-sensor):
            npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.7: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.1.2 (node_modules/chokidar/node_modules/fsevents):
            npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.3: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
            npm ERR! code EACCES
            npm ERR! syscall access
            npm ERR! path /opt/iobroker/node_modules/iobroker.tr-064/node_modules/array-ext
            npm ERR! errno -13
            npm ERR! Error: EACCES: permission denied, access '/opt/iobroker/node_modules/iobroker.tr-064/node_modules/array-ext'
            npm ERR! { [Error: EACCES: permission denied, access '/opt/iobroker/node_modules/iobroker.tr-064/node_modules/array-ext']
            npm ERR! stack:
            npm ERR! 'Error: EACCES: permission denied, access '/opt/iobroker/node_modules/iobroker.tr-064/node_modules/array-ext'',
            npm ERR! errno: -13,
            npm ERR! code: 'EACCES',
            npm ERR! syscall: 'access',
            npm ERR! path:
            npm ERR! '/opt/iobroker/node_modules/iobroker.tr-064/node_modules/array-ext' }
            npm ERR!
            npm ERR! The operation was rejected by your operating system.
            npm ERR! It is likely you do not have the permissions to access this file as the current user
            npm ERR!
            npm ERR! If you believe this might be a permissions issue, please double-check the
            npm ERR! permissions of the file and its containing directories, or try running
            npm ERR! the command again as root/Administrator.
            npm ERR! /home/iobroker/.npm/_logs/2020-06-01T08_05_12_110Z-debug.log
            Error deleting adapter tr-064 from disk: Error: host.debian-iobroker: Cannot uninstall iobroker.tr-064: 243
            You might have to delete it yourself!
            root@debian-iobroker:~#
            • R Ralf
              iobroker del tr-064
              npm ERR! errno -13
              npm ERR! stack:
              npm ERR! path:
              npm ERR!
              npm ERR!
              @Ralf
              Nicht als root rumhampeln und Konsolenausgaben in CodeTags setzen.
              • R Ralf
                sigi234S Online
                sigi234S Online
                @Ralf
                Bitte benutzt die Code Tags Funktion -> </>
                Hier gehts zur Hilfe.
                  @Ralf
                  Ralf
                  @Thomas-Braun Meldung in der Konsole :
                  Leider darf der Benutzer ralf »/usr/bin/iobroker update« als root auf debian-iobroker nicht ausführen.
                  • sigi234S sigi234
                    @Ralf
                    Ralf
                    @sigi234 sagte in Update tr-064 Adapter:
                    Finde leider nichts dazu wie man´s macht.
                    • R Ralf
                      Jan1
                      @Ralf
                      Wie man mit der Maus scrollt ist aber bekannt, oder? Also scroll mal im Link von sigi234 bis Editor runter.
                      • J Jan1
                        @Ralf
                        Ralf
                        @Jan1 ```
                        manchmal dauert´s halt etwas länger
                        • R Ralf
                          @Jan1 ```
                          Jan1
                          @Ralf
                          ist egal, wenn es dann doch irgendwann mal klappt ;-)
                          • J Jan1
                            @Ralf
                            Ralf
                            @Jan1 noch eine Idee wie ich den Adapter los werde und neu installieren kann ?
                            • R Ralf
                              @Ralf
                              adduser ralf sudo
                              Ggf. das nochmal als root und dann den root-login künftig vermeiden.
                                @Ralf
                                adduser ralf sudo
                                Ralf
                                @Ralf
                                adduser ralf sudo
                                ...und dann als "Ralf" einloggen ?
                                Ist das ein Problem, wenn ich mich als root einlogge ?
                                • R Ralf
                                  @Ralf
                                  adduser ralf sudo
                                  @Ralf
                                  Ja, dann als Ralf einloggen.
                                  root-login sollte tabu sein.
                                  Als ralf dann
                                  sudo whoami
                                    @Ralf
                                    Als ralf dann
                                    sudo whoami
                                    Ralf
                                    warum ??
                                    • R Ralf
                                      warum ??
                                      @Ralf
                                      Why sudo?
                                      Using sudo is better (safer) than opening a session as root for a number of reasons, including:
                                      Nobody needs to know the root password (sudo prompts for the current user's password). Extra privileges can be granted to individual users temporarily, and then taken away without the need for a password change.
                                      It's easy to run only the commands that require special privileges via sudo; the rest of the time, you work as an unprivileged user, which reduces the damage that mistakes can cause.
                                      Auditing/logging: when a sudo command is executed, the original username and the command are logged.
                                      For the reasons above, switching to root using sudo -i (or sudo su) is usually deprecated because it cancels the above features.
                                      Und das ganze System inkl. des Rechtemanagement ist darauf ausgelegt mit sudo zu agieren.
                                        @Ralf
                                        Why sudo?
                                        Ralf
                                        @Thomas-Braun Adapter lässt sich nach wie vor nicht deinstallieren :
                                        ralf@debian-iobroker:~$ sudo whoami
                                        root
                                        ralf@debian-iobroker:~$ iobroker del tr-064
                                        npm ERR! errno -13
                                        npm ERR!   stack:
                                        npm ERR!    'Error: EACCES: permission denied, access \'/opt/iobroker/node_modules/iobroker.tr-064/node_modules/array-ext\'',
                                        npm ERR!   path:
                                        npm ERR!
                                        npm ERR!
                                        npm ERR!     /home/iobroker/.npm/_logs/2020-06-01T09_12_12_551Z-debug.log
                                        • R Ralf
                                          root
                                          npm ERR! errno -13
                                          npm ERR!   stack:
                                          npm ERR!   path:
                                          npm ERR!
                                          npm ERR!
                                          @Ralf
                                          iobroker fix
