  4. Test Adapter Devices 0.3.x
devices
136 Beiträge 27 Kommentatoren 24.4k Aufrufe 24 Beobachtet
  • crunchipC
    crunchipC
    Developer Global Moderator Most Active Forum Testing
    wenn ich mir einen Alias anlegen möchte, erhalte ich folgende Warnungen, mache ich da etwas falsch, oder stimmt da etwas nicht?
    admin.0	2020-05-05 00:33:27.145	warn	(989) This object will not be created in future versions. Please report this to the developer.
    admin.0	2020-05-05 00:33:27.145	warn	(989) Object alias.0.Zaehler.Abwasser.ACTUAL is invalid: obj.common.type has an invalid value (state) but has to be one of number, string, boolean, array, object, mixed, file, json
    admin.0	2020-05-05 00:29:49.974	warn	(989) This object will not be created in future versions. Please report this to the developer.
    admin.0	2020-05-05 00:29:49.972	warn	(989) Object alias.0.Zaehler.Abwasser.ACTUAL is invalid: obj.common.type has an invalid value (state) but has to be one of number, string, boolean, array, object, mixed, file, json
    iogo.0	2020-05-05 00:28:54.361	info	(1282) database initialized with 104 state values
    iogo.0	2020-05-05 00:28:54.220	info	(1282) database initialized with 104 state values
    iogo.0	2020-05-05 00:28:47.719	info	(1282) uploading state
    iogo.0	2020-05-05 00:28:47.696	info	(1282) uploading state
    influxdb.0	2020-05-05 00:28:47.652	warn	(1233) Alias alias.0.Zaehler.Abwasser.ACTUAL has no target 12
    influxdb.2	2020-05-05 00:28:47.664	warn	(2240) Alias alias.0.Zaehler.Abwasser.ACTUAL has no target 12
    javascript.0	2020-05-05 00:28:47.654	warn	(1700) Alias alias.0.Zaehler.Abwasser.ACTUAL has no target 12
    iogo.0	2020-05-05 00:28:47.658	warn	(1282) Alias alias.0.Zaehler.Abwasser.ACTUAL has no target 12
    javascript.1	2020-05-05 00:28:47.655	warn	(1707) Alias alias.0.Zaehler.Abwasser.ACTUAL has no target 12
    admin.0	2020-05-05 00:28:47.628	warn	(989) This object will not be created in future versions. Please report this to the developer.
    admin.0	2020-05-05 00:28:47.624	warn	(989) Object alias.0.Zaehler.Abwasser.ACTUAL is invalid: obj.common.type has an invalid value (state) but has to be one of number, string, boolean, array, object, mixed, file, json
    influxdb.2	2020-05-05 00:28:47.346	warn	(2240) Alias alias.0.Zaehler.Abwasser has no target 12
    iogo.0	2020-05-05 00:28:47.355	warn	(1282) Alias alias.0.Zaehler.Abwasser has no target 12
    javascript.1	2020-05-05 00:28:47.348	warn	(1707) Alias alias.0.Zaehler.Abwasser has no target 12
    javascript.0	2020-05-05 00:28:47.349	warn	(1700) Alias alias.0.Zaehler.Abwasser has no target 12
    influxdb.0	2020-05-05 00:28:47.342	warn	(1233) Alias alias.0.Zaehler.Abwasser has no target 12
    59eec708-8438-4dbf-82e1-fd0bc1993187-image.png 52489ea1-30f2-4c00-85b3-d08a98b3f61b-image.png
    Unit habe ich nachträglich eingetragen, role hab ich geändert von "state" auf "value"
    die Raw vom Original
     "type": "state",
     "common": {
       "read": true,
       "write": false,
       "desc": "w_counter_3",
       "unit": "m3",
       "role": "value",
       "id": "w_counter_3",
       "name": "15",
       "type": "number",
       "custom": {
         "sourceanalytix.0": {
           "enabled": true,
           "alias": "Wasser",
           "state_type": "water_m3",
           "state_unit": "m3",
           "costs": true,
           "consumption": true,
           "meter_values": true,
           "start_day": 301.899,
           "start_week": 301.638,
           "start_month": 301.309,
           "start_quarter": 294.02,
           "start_year": 275.744
         "influxdb.0": {
           "enabled": true,
           "changesOnly": true,
           "debounce": "1000",
           "retention": "31536000",
           "changesRelogInterval": "3600",
           "changesMinDelta": 0,
           "storageType": "Number",
           "aliasId": ""
     "native": {},
     "from": "system.adapter.sourceanalytix.0",
     "user": "system.user.admin",
     "ts": 1588629600677,
     "_id": "wiffi-wz.0.root.10_1_30_10.w_counter_3",
     "acl": {
       "object": 1636,
       "state": 1636,
       "owner": "system.user.admin",
    nächste Frage, wenn ich diesen Alias wieder lösche
    kommen sämtliche Warnmeldungen im LOG
    iogo.0	2020-05-05 00:52:56.464	info	(1282) database initialized with 104 state values
    iogo.0	2020-05-05 00:52:55.815	info	(1282) database initialized with 104 state values
    iogo.0	2020-05-05 00:52:48.985	info	(1282) uploading state
    iogo.0	2020-05-05 00:52:48.968	info	(1282) uploading state
    javascript.1	2020-05-05 00:52:48.954	warn	at process.topLevelDomainCallback (domain.js:126:23)
    javascript.1	2020-05-05 00:52:48.954	warn	at processImmediate (timers.js:658:5)
    javascript.1	2020-05-05 00:52:48.954	warn	at tryOnImmediate (timers.js:676:5)
    javascript.1	2020-05-05 00:52:48.954	warn	at runCallback (timers.js:705:18)
    javascript.1	2020-05-05 00:52:48.954	warn	at Immediate.setImmediate (/opt/iobroker/node_modules/iobroker.objects-redis/index.js:1:30045)
    javascript.1	2020-05-05 00:52:48.954	warn	at change (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:1620:151)
    javascript.1	2020-05-05 00:52:48.954	warn	(1707) TypeError: Cannot read property '_id' of null
    influxdb.2	2020-05-05 00:52:48.952	warn	at process.topLevelDomainCallback (domain.js:126:23)
    influxdb.2	2020-05-05 00:52:48.952	warn	at processImmediate (timers.js:658:5)
    influxdb.2	2020-05-05 00:52:48.952	warn	at tryOnImmediate (timers.js:676:5)
    influxdb.2	2020-05-05 00:52:48.952	warn	at runCallback (timers.js:705:18)
    influxdb.2	2020-05-05 00:52:48.952	warn	at Immediate.setImmediate (/opt/iobroker/node_modules/iobroker.objects-redis/index.js:1:30045)
    influxdb.2	2020-05-05 00:52:48.952	warn	at change (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:1620:151)
    influxdb.2	2020-05-05 00:52:48.952	warn	(2240) TypeError: Cannot read property '_id' of null
    influxdb.0	2020-05-05 00:52:48.940	warn	at process.topLevelDomainCallback (domain.js:126:23)
    influxdb.0	2020-05-05 00:52:48.940	warn	at processImmediate (timers.js:658:5)
    influxdb.0	2020-05-05 00:52:48.940	warn	at tryOnImmediate (timers.js:676:5)
    influxdb.0	2020-05-05 00:52:48.940	warn	at runCallback (timers.js:705:18)
    influxdb.0	2020-05-05 00:52:48.940	warn	at Immediate.setImmediate (/opt/iobroker/node_modules/iobroker.objects-redis/index.js:1:30045)
    influxdb.0	2020-05-05 00:52:48.940	warn	at change (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:1620:151)
    influxdb.0	2020-05-05 00:52:48.940	warn	(1233) TypeError: Cannot read property '_id' of null
    javascript.0	2020-05-05 00:52:48.933	warn	at process.topLevelDomainCallback (domain.js:126:23)
    javascript.0	2020-05-05 00:52:48.933	warn	at processImmediate (timers.js:658:5)
    javascript.0	2020-05-05 00:52:48.933	warn	at tryOnImmediate (timers.js:676:5)
    javascript.0	2020-05-05 00:52:48.933	warn	at runCallback (timers.js:705:18)
    javascript.0	2020-05-05 00:52:48.933	warn	at Immediate.setImmediate (/opt/iobroker/node_modules/iobroker.objects-redis/index.js:1:30045)
    javascript.0	2020-05-05 00:52:48.933	warn	at change (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:1620:151)
    javascript.0	2020-05-05 00:52:48.933	warn	(1700) TypeError: Cannot read property '_id' of null
    iogo.0	2020-05-05 00:52:48.931	warn	at processImmediate (timers.js:658:5)
    iogo.0	2020-05-05 00:52:48.931	warn	at tryOnImmediate (timers.js:676:5)
    iogo.0	2020-05-05 00:52:48.931	warn	at runCallback (timers.js:705:18)
    iogo.0	2020-05-05 00:52:48.931	warn	at Immediate.setImmediate [as _onImmediate] (/opt/iobroker/node_modules/iobroker.objects-redis/index.js:1:30045)
    iogo.0	2020-05-05 00:52:48.931	warn	at change (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:1620:151)
    iogo.0	2020-05-05 00:52:48.931	warn	(1282) TypeError: Cannot read property '_id' of null
    javascript.1	2020-05-05 00:52:48.915	warn	(1707) Objects Cannot process system pmessage alias.0.Zaehler.Abwasser - null: Cannot read property '_id' of null
    iogo.0	2020-05-05 00:52:48.915	warn	(1282) Objects Cannot process system pmessage alias.0.Zaehler.Abwasser - null: Cannot read property '_id' of null
    influxdb.2	2020-05-05 00:52:48.927	warn	(2240) Objects Cannot process system pmessage alias.0.Zaehler.Abwasser - null: Cannot read property '_id' of null
    javascript.0	2020-05-05 00:52:48.922	warn	(1700) Objects Cannot process system pmessage alias.0.Zaehler.Abwasser - null: Cannot read property '_id' of null
    influxdb.0	2020-05-05 00:52:48.914	warn	(1233) Objects Cannot process system pmessage alias.0.Zaehler.Abwasser - null: Cannot read property '_id' of null
       "type": "state",
       "common": {
         "read": true,
         "write": false,
         "unit": "m3",
         "role": "value",
         "name": "15",
         "type": "number",
         "custom": {
             "enabled": true,
             "alias": "Wasser",
             "state_unit": "m3",
             "costs": true,
           "influxdb.0": {
             "enabled": true,
             "debounce": "1000",
             "aliasId": ""
       "native": {},
       "acl": {
         "object": 1636,
         "state": 1636,
      apollon77A
      apollon77A
      @crunchip Der eine Teil der meldungen kam wegen dem falschen typ (state anstelle einem datentyp). Der andere teil das auch "Stukturobjekte" Fehlermekdungen werden wird in der nächsten Controller Version gefixt sein. Der andere Fehler auch Danke!
      • apollon77A apollon77
        @martinschm SET/ACTUAL machen bei steuerbaren Geräten Sinn wenn eine Steueraktion ggf länger dauert o.ä. oder wie bei einem Thermostat wo eine gemessene temperatur hat etwas anderes ist als eine die man als Ziel einstellt. Alles wären so Dinge.
        Auch bei einer Jalousie könnte man (weil ja die aktion etwas dauert) das trennen. ACTUAL ist der aktuelle Wert. SET der Zielwert. ACTUAL wird dann erst nach der erfolgten Fahrt aktualisiert.
        LowBat ist eher als Boolean gedacht, ja einen Volt Wert würde ich dort nicht reinschreiben, aber mittelen read logik kannst Du ja eine grenze definieren und true setzen wenn dein Wert <3V oder so ist.
        Maintenance bedeutet das das Gerät irgendetwas braucht (Batteriewechsel, Störung o.ä.)
        M
        M
        martinschm
        @apollon77 said in Test Adapter Devices 0.3.x:
        Verzeih mir meine Unwissenheit, aber was ist den read logik ?
        GarfonsoG 1 Antwort Letzte Antwort
        • M martinschm
          GarfonsoG
          GarfonsoG
          Garfonso
          @martinschm
          Man kann dem alias sagen er soll die Daten noch manipulieren, bevor er sie in den Alias State schreibt (read logik) oder aus dem alias state in den original state (write logik). Soweit ich weiß geht das bisher nur über die RAW Ansicht des Objekts. Dort dann sowas eintragen:
            "common": {
              "name": "Buero batteryWarning",
              "role": "indicator.lowbat",
              "type": "boolean",
              "read": true,
              "write": false,
              "smartName": false,
              "alias": {
                "id": "zigbee.0.00158d0003f3cea3.battery",
                "read": "val < 20"
          Also wichtig die Zeile "read". Hier wird aus einer Batterie % Anzeige eine Batteriewarnung, wenn die Batterie unter 20% fällt. Damit kann man relativ lustige Sachen machen. "val" ist dabei in read der Wert des target state (also hier zigbee.0.00158d0003f3cea3.battery) und bei write der Wert des alias state.
          Ultimativer Lovelace Leitfaden: https://forum.iobroker.net/topic/35937/der-ultimative-iobroker-lovelace-leitfaden-dokumentation
          Lovelace UI Beispiele: https://forum.iobroker.net/topic/35950/zeigt-her-eure-lovelace-visualisierung
          M M 2 Antworten Letzte Antwort
          • M
            M
            muuulle
            mein Alias.0 Ordner ist verschwunden. Mögliches versehentliches löschen nicht auszuschließen 😲
            Was kann ich tun?
            BBTownB GarfonsoG 2 Antworten Letzte Antwort
            • M muuulle
              Was kann ich tun?
              BBTownB
              BBTownB
              BBTown
              @muuulle
              1. ein aktuelles Backup anlegen
              2. ein altes Backup zurückspielen
              3. die Objekte aus dem Knoten alias.0 sichern (exportieren)
              4. das zuvor angelegte Backup zurückspielen
              5. die alias.0 Objekte importieren
              ioBroker auf NUC (VM debian v13 (Trixie ), node v24.22.2 npm v11.19.0, js-controller v7.2.5 jsonl/jsonl / HomeMatic CCU-2 (Wired und Funk) / Philips HUE / echo.DOT / Broadlink RM pro / SONOS
              • BBTownB BBTown
                @muuulle
                M
                M
                muuulle
                @BBTown
                Danke für die Rückmeldung.
                Muss ich das große Rad auch drehen, wenn ich keinen Bedarf an den alten Alias habe? Ich könnte die paar Alias auch flott händisch anlegen...
                • M muuulle
                  @BBTown
                  paul53P
                  paul53P
                  @muuulle sagte:
                  Dann mache es.
                  const id = 'alias.0';
                  const obj = {
                      type: 'meta',
                      common: {
                      native: {}
                  if(!existsObject(id)) setObject(id, obj);
                  Produktiv: Asus PN42: N100 / 8 GB / 500 GB; Proxmox mit 2 VM (ioBroker / openCCU)
                  M apollon77A 2 Antworten Letzte Antwort
                    @muuulle sagte:
                    Dann mache es.
                    const obj = {
                        type: 'meta',
                        common: {
                        native: {}
                    M
                    M
                    muuulle
                    Moin Paul,
                    meine Programmierkenntnisse sind äußerst limitiert. Wo muss ich den Code einfügen? :male-construction-worker:
                    • M muuulle
                      Moin Paul,
                      paul53P
                      paul53P
                      @muuulle sagte:
                      als neues Javascript, starten und wieder beenden.
                      • M muuulle
                        Was kann ich tun?
                        GarfonsoG
                        GarfonsoG
                        Garfonso
                        @muuulle said in Test Adapter Devices 0.3.x:
                        Was kann ich tun?
                        Bist du sicher, dass er gelöscht wurde? Wenn keine Elemente darin sind, wird er nicht als "Ordner" angezeigt und landet im Admin in der Objekt-Ansicht ganz unten bei den States.
                          @muuulle sagte:
                          M
                          M
                          muuulle
                          Alles geklappt. Danke!
                            @muuulle sagte:
                            Dann mache es.
                            const obj = {
                                type: 'meta',
                                common: {
                                native: {}
                            apollon77A
                            apollon77A
                            @paul53 Ein "iobroker setup first" sollte auch reichen
                              paul53P
                              paul53P
                              @apollon77 sagte:
                              Danke. Das hatte ich zwar vermutet, war mir aber nicht sicher.
                              • GarfonsoG Garfonso
                                @martinschm
                                  "common": {
                                    "type": "boolean",
                                    "read": true,
                                    "write": false,
                                    "smartName": false,
                                    "alias": {
                                      "read": "val < 20"
                                M
                                M
                                muuulle
                                @Garfonso said in Test Adapter Devices 0.3.x:
                                @martinschm
                                  "common": {
                                    "type": "boolean",
                                    "read": true,
                                    "write": false,
                                    "smartName": false,
                                    "alias": {
                                      "read": "val < 20"
                                Moin @Garfonso
                                LOWBAT hat mit deiner Anleitung super funktioniert.
                                Meine aqara Sensoren kennen nur reachable. Kann man den Wert invertieren, dass ich UNREACH richtig füttern kann?
                                • M muuulle
                                  @martinschm
                                    "common": {
                                      "type": "boolean",
                                      "read": true,
                                      "write": false,
                                      "smartName": false,
                                      "alias": {
                                        "read": "val < 20"
                                  Moin @Garfonso
                                  paul53P
                                  paul53P
                                  @muuulle sagte:
                                        "read": "!val" // Alias read invertieren
                                    @muuulle sagte:
                                    M
                                    M
                                    muuulle
                                    Super.
                                    Ich habe jetzt alle meine unterschiedlichen Geräte vom Output vereinheitlicht.
                                    Könnte ich jetzt auch alle LOWBAT/UNREACH mit nur einer Abfrage (Blockly?) anfragen?
                                    Vielen Dank
                                    K paul53P GarfonsoG 3 Antworten Letzte Antwort
                                    • M muuulle
                                      Super.
                                      Vielen Dank
                                      K
                                      K
                                      Kueppert
                                      @muuulle schau mal hier rein:
                                      https://forum.iobroker.net/topic/23370/fenster-und-andere-geräte-zählen-opt-alexa-ansagen/627
                                      Für Hoematic wurde da schon was umgesetzt. Ich bin auch auf Xiaomi-Sensoren unterwegs und @dslraser baut dafür ggf. auch etwas. Wenn das nicht klappt, geh ich ggf auch über Alias.
                                      • M muuulle
                                        Super.
                                        Vielen Dank
                                        paul53P
                                        paul53P
                                        @muuulle sagte:
                                        Ja, jeweils für LOWBAT bzw. UNREACH mittels $Selector().
                                        • M muuulle
                                          Super.
                                          Vielen Dank
                                          GarfonsoG
                                          GarfonsoG
                                          Garfonso
                                          @muuulle
                                          Wenn sie alle gleich heißen, dann mit Javascript z.B. so:
                                          //wenn struktur alias.0.Gerät.Unreach. Wenn noch mehr "Ordner" noch öfter .* einfügen.
                                          $('[id=alias.0.*.UNREACH]').each(id => {
                                              //was mit id machen, z.B. getState();
                                          84.2k
