  4. js-controller 3.0/3.1 jetzt im Latest!
js-controller
1.3k Beiträge 127 Kommentatoren 605.7k Aufrufe 89 Beobachtet
  • dslraserD dslraser
    @Thomas-Braun sagte in js-controller 3.0 jetzt im Latest!:
    npm rebuild canvas --build-from-source
    root@iobroker:/opt/iobroker# npm rebuild canvas --build-from-source
    > canvas@2.6.1 install /opt/iobroker/node_modules/canvas
    > node-pre-gyp install --fallback-to-build
    node-pre-gyp WARN Using request for node-pre-gyp https download
    Package pixman-1 was not found in the pkg-config search path.
    Perhaps you should add the directory containing `pixman-1.pc'
    to the PKG_CONFIG_PATH environment variable
    No package 'pixman-1' found
    gyp: Call to 'pkg-config pixman-1 --libs' returned exit status 1 while in binding.gyp. while trying to load binding.gyp
    gyp ERR! configure error
    gyp ERR! stack Error: `gyp` failed with exit code: 1
    gyp ERR! stack     at ChildProcess.onCpExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/configure.js:351:16)
    gyp ERR! stack     at ChildProcess.emit (events.js:310:20)
    gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:275:12)
    gyp ERR! System Linux 4.4.59+
    gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "configure" "--fallback-to-build" "--module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node" "--module_name=canvas" "--module_path=/opt/iobroker/node_modules/canvas/build/Release" "--napi_version=5" "--node_abi_napi=napi" "--napi_build_version=0" "--node_napi_label=node-v72"
    gyp ERR! cwd /opt/iobroker/node_modules/canvas
    gyp ERR! node -v v12.16.3
    gyp ERR! node-gyp -v v5.1.0
    gyp ERR! not ok
    node-pre-gyp ERR! build error
    node-pre-gyp ERR! stack Error: Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js configure --fallback-to-build --module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node --module_name=canvas --module_path=/opt/iobroker/node_modules/canvas/build/Release --napi_version=5 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v72' (1)
    node-pre-gyp ERR! stack     at ChildProcess.<anonymous> (/opt/iobroker/node_modules/canvas/node_modules/node-pre-gyp/lib/util/compile.js:83:29)
    node-pre-gyp ERR! stack     at ChildProcess.emit (events.js:310:20)
    node-pre-gyp ERR! stack     at maybeClose (internal/child_process.js:1021:16)
    node-pre-gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:286:5)
    node-pre-gyp ERR! System Linux 4.4.59+
    node-pre-gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/canvas/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"
    node-pre-gyp ERR! cwd /opt/iobroker/node_modules/canvas
    node-pre-gyp ERR! node -v v12.16.3
    node-pre-gyp ERR! node-pre-gyp -v v0.11.0
    node-pre-gyp ERR! not ok
    npm ERR! code ELIFECYCLE
    npm ERR! errno 1
    npm ERR! canvas@2.6.1 install: `node-pre-gyp install --fallback-to-build`
    npm ERR! Exit status 1
    npm ERR!
    npm ERR! Failed at the canvas@2.6.1 install script.
    npm ERR!     /opt/iobroker/.npm/_logs/2020-05-02T11_26_33_480Z-debug.log
    #684
    @dslraser Da fehlen jetzt die -dev-Pakete aus dem graphic stack. Ich weiß aber nicht wo man die bei deinem System her bekommt.
      @dslraser Ach, der blöde Docker...
      dslraserD Offline
      dslraserD Offline
      dslraser
      #685
      @Thomas-Braun
      ich bin jetzt mal ne Stunde wech, nachher gets weiter.
      • liv-in-skyL Offline
        liv-in-skyL Offline
        #686
        was sind das für warnungen ? weiß jmd, wie man die die wegbekommen kann
        web.1	2020-05-02 13:43:02.580	warn	(22881) readFile will not read this file (uploads/files/1588419094081-xxxxxxxxxxxxxx6f-0378895cb788-grafik.png) in future versions: assets is not an object of type "meta"
        kommt so alle 20-30 sekunden - die
          dslraserD Offline
          dslraserD Offline
          dslraser
          #687
          Was für Infos brauchst Du dafür ?
            @dirk1962 sagte in js-controller 3.0 jetzt im Latest!:
            @dslraser
            Ich habe den Befehl nach "iobroker stop" im Verzeichnis "opt/iobroker" ausgeführt.
            Mache ich da was falsch?
            @apollon77
            Beim heutigen Update (iot 1.4.14) ist es wieder da...
            2020-05-02 13:05:48.477 - warn: iot.0 (1102) Cannot initialize getImage: Error: The module '/opt/iobroker/node_modules/canvas/build/Release/canvas.node'
            was compiled against a different Node.js version using
            NODE_MODULE_VERSION 64. This version of Node.js requires
            NODE_MODULE_VERSION 72. Please try re-compiling or re-installing
            the module (for instance, using `npm rebuild` or `npm install`).
            #688
            @dslraser Poste mal das install log von dem update
              @dslraser
              npm rebuild canvas
              In /opt/iobroker
              #689
              @Thomas-Braun Das iobroker rebuild iot --install ist der preferred way mit controller 3.0!
              dirk1962D 1 Antwort Letzte Antwort
                @dslraser Nicht als root!
                #690
                @Thomas-Braun Und genau aus dem grund haben wir das eigene Kommando! @Thomas-Braun Bitte empfehle das in Zukunft. Danke!
                • apollon77A apollon77
                  dslraserD Offline
                  dslraserD Offline
                  dslraser
                  #691
                  @apollon77 sagte in js-controller 3.0 jetzt im Latest!:
                  vom iot Update, oder welches meinst Du ?
                  • liv-in-skyL liv-in-sky
                    #692
                    @liv-in-sky eigene Files die du irgendwie aus nem eigenen Folder lesen willst oder so? Der Name ist "assets" ... klingelt da was vllt?
                      #693
                      @dslraser Die sollte der Adapter an sich installieren ... mach mal ein apt installmit der Liste die da angegeben ist https://github.com/ioBroker/ioBroker.iot/blob/master/io-package.json#L243
                      Deswegen wäre ich mal über ein Install Log vom Adapter echt erfreut
                      Bzw bitte führe mal im container das hier aus
                      node -e 'console.log(process.platform);'
                      Was ist das Ergebnis?
                        dslraserD Offline
                        dslraserD Offline
                        dslraser
                        #694
                        root@iobroker:/opt/iobroker# node -e 'console.log(process.platform);'
                        linux
                          dslraserD Offline
                          dslraserD Offline
                          dslraser
                          #695
                          das Log von heute habe ich vorhin gelöscht, da ich noch was anderes gemacht habe, da ist jetzt fast nichts drinn, jedenfalls nichts mehr von den Updates...😕
                            #696
                            @dslraser Dann versuch mal manuell die genannten Pakete zu installieren, an sich würde ich aber erwarten das er sagt das die alle da sind
                              dslraserD Offline
                              dslraserD Offline
                              dslraser
                              #697
                              @apollon77
                              meinst Du so ? (dann wäre das erste schon nicht da, oder ?)
                              root@iobroker:/opt/iobroker# apt install libcairo2-dev
                              E: Paket libcairo2-dev kann nicht gefunden werden.
                                @apollon77
                                #698
                                @dslraser Was hast denn du für ein System in deinem Container? Also Debian hat das seit ewig (https://packages.debian.org/search?keywords=libcairo2-dev), Ubuntu an such auch ...
                                  dslraserD Offline
                                  dslraserD Offline
                                  dslraser
                                  #699
                                  @apollon77
                                  das ist das "Buanet Image 4.2=latest"
                                    dslraserD Offline
                                    dslraserD Offline
                                    dslraser
                                    #700
                                    Das hier: Buanet
                                      dirk1962D Offline
                                      dirk1962D Offline
                                      dirk1962
                                      schrieb am zuletzt editiert von dirk1962
                                      #701
                                      @apollon77
                                      Habe ich genauso gemacht und musste es nach jedem Update des iot Adapters wieder machen.
                                      iobroker läuft unter PROXMOX in VM.
                                      JS-controller 3.0.20
                                      Node.js v12.16.3
                                      alle Adapter aus dem latest.
                                      NUC8i5 mit Proxmox; Raspberrymatic in VM, iobroker, Motioneye, infuxDB und Grafana in CT.
                                      • F Offline
                                        fabib
                                        #702
                                        Hallo Leute,
                                        hab den Update geschafft. Jetzt habe ich nur noch das Problem mit dem Zigbee Adapter Version 1.1.1 ... ich weiß leider nicht weiter. Hab schon npm rebuild gemacht und iobroker fix
                                        Das Log aus ioBroker wenn der Adapter starten möchte:
                                        2020-05-02 14:35:19.196 - info: host.raspberrypi "system.adapter.zigbee.0" enabled
                                        2020-05-02 14:35:19.250 - info: host.raspberrypi instance system.adapter.zigbee.0 started with pid 10268
                                        2020-05-02 14:35:21.564 - info: zigbee.0 (10268) starting. Version 1.1.1 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.16.3, js-controller: 3.0.20
                                        2020-05-02 14:35:21.603 - info: zigbee.0 (10268) Starting Zigbee...
                                        2020-05-02 14:35:28.883 - error: zigbee.0 (10268) Failed to start Zigbee
                                        2020-05-02 14:35:28.884 - error: zigbee.0 (10268) Error: Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)
                                        at ZStackAdapter. (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/adapter/z-stack/adapter/zStackAdapter.js:71:23)
                                        at Generator.throw ()
                                        at rejected (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/adapter/z-stack/adapter/zStackAdapter.js:6:65)
                                        2020-05-02 14:35:38.886 - info: zigbee.0 (10268) Try to reconnect. 1 attempts left
                                        2020-05-02 14:35:38.888 - info: zigbee.0 (10268) Starting Zigbee...
                                        2020-05-02 14:35:39.112 - error: zigbee.0 (10268) Failed to start Zigbee
                                        2020-05-02 14:35:39.113 - error: zigbee.0 (10268) Error: Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'
                                        at Znp. (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:113:32)
                                        at Generator.next ()
                                        at /opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:8:71
                                        at new Promise ()
                                        at __awaiter (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:4:12)
                                        at SerialPort. (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:111:49)
                                        at SerialPort._error (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/node_modules/@serialport/stream/lib/index.js:198:14)
                                        at /opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/node_modules/@serialport/stream/lib/index.js:242:12
                                        Und die Versionen:
                                        pi@raspberrypi:~ $ npm -v
                                        6.14.4
                                        pi@raspberrypi:~ $ node -v
                                        v12.16.3
                                        pi@raspberrypi:~ $ nodejs -v
                                        v12.16.3
                                        pi@raspberrypi:~ $ iobroker version
                                        3.0.20
                                        Übersehe ich etwas? Mache ich was falsch? Hab ich was nicht richtig gemacht? Bin ich hier überhaupt richtig mit meinem Anliegen.
                                        Ich danke schonmal im Voraus ;-)
                                        Liebe Grüße
                                        ? apollon77A 2 Antworten Letzte Antwort
                                          liv-in-skyL Offline
                                          liv-in-skyL Offline
                                          #703
                                          @apollon77 hi
                                          leider klingelt da nichts - ich nutze das eigentlich nicht - nur dateien, die mit writeFile geschrieben worden sind - html-dateien, die auch funktionieren
                                          ich habe alles durchsucht im iobroker-container (linux-ebene) nach assets, *grafik.png oder den ganzen angezeigten namen - auch unter scripte-tab - ich habe keine idee mehr nach was oder wo ich noch suchen soll - es kommt auch nicht immer - momentan sind keine meldungen - hast du einen tipp, wie ich die suche angehen kann
                                          das hier ist auch noch gekommen:
                                          web.1	2020-05-02 14:17:40.166	warn	(22881) readFile will not read this file () in future versions: favicon.ico is not an object of type "meta"
                                          was genau bedeutet die meldung - sind da files, die ich irgenwann einfach in das iobroker verzeichnis kopiert habe oder sind das meldungen, die bei abrufen dieser files erscheinen - und wer kann das abrufen? scripte habe ich auch durchsucht.
                                          crunchipC apollon77A M 3 Antworten Letzte Antwort
