  4. js-controller 3.0/3.1 jetzt im Latest!
js-controller
1.3k Beiträge 127 Kommentatoren 714.7k Aufrufe 89 Beobachtet
  • dslraserD dslraser
    @Thomas-Braun sagte in js-controller 3.0 jetzt im Latest!:
    npm rebuild canvas
    habe ich eben gemacht
    root@iobroker:/opt/iobroker# npm rebuild canvas
    > canvas@2.6.1 install /opt/iobroker/node_modules/canvas
    > node-pre-gyp install --fallback-to-build
    node-pre-gyp WARN Using request for node-pre-gyp https download
    [canvas] Success: "/opt/iobroker/node_modules/canvas/build/Release/canvas.node" already installed
    Pass --update-binary to reinstall or --build-from-source to recompile
    > canvas@2.6.1 install /opt/iobroker/node_modules/iobroker.iot/node_modules/canvas
    [canvas] Success: "/opt/iobroker/node_modules/iobroker.iot/node_modules/canvas/build/Release/canvas.node" already installed
    canvas@2.6.1 /opt/iobroker/node_modules/canvas
    canvas@2.6.1 /opt/iobroker/node_modules/iobroker.iot/node_modules/canvas
    Thomas BraunT
    Thomas BraunT
    Most Active Developer
    #680
    @dslraser Nicht als root!
    dslraserD apollon77A 2 Antworten Letzte Antwort
      dslraserD
      dslraserD
      dslraser
      #681
      @Thomas-Braun
      sondern ? (Portainer---Docker)
        @Thomas-Braun
        Thomas BraunT
        Thomas BraunT
        #682
        @dslraser Ach, der blöde Docker...
        npm rebuild canvas --build-from-source
          dslraserD
          dslraserD
          dslraser
          #683
          root@iobroker:/opt/iobroker# npm rebuild canvas --build-from-source
          Package pixman-1 was not found in the pkg-config search path.
          Perhaps you should add the directory containing `pixman-1.pc'
          to the PKG_CONFIG_PATH environment variable
          No package 'pixman-1' found
          gyp: Call to 'pkg-config pixman-1 --libs' returned exit status 1 while in binding.gyp. while trying to load binding.gyp
          gyp ERR! configure error
          gyp ERR! stack Error: `gyp` failed with exit code: 1
          gyp ERR! stack     at ChildProcess.onCpExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/configure.js:351:16)
          gyp ERR! stack     at ChildProcess.emit (events.js:310:20)
          gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:275:12)
          gyp ERR! System Linux 4.4.59+
          gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "configure" "--fallback-to-build" "--module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node" "--module_name=canvas" "--module_path=/opt/iobroker/node_modules/canvas/build/Release" "--napi_version=5" "--node_abi_napi=napi" "--napi_build_version=0" "--node_napi_label=node-v72"
          gyp ERR! cwd /opt/iobroker/node_modules/canvas
          gyp ERR! node -v v12.16.3
          gyp ERR! node-gyp -v v5.1.0
          gyp ERR! not ok
          node-pre-gyp ERR! build error
          node-pre-gyp ERR! stack Error: Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js configure --fallback-to-build --module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node --module_name=canvas --module_path=/opt/iobroker/node_modules/canvas/build/Release --napi_version=5 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v72' (1)
          node-pre-gyp ERR! stack     at ChildProcess.<anonymous> (/opt/iobroker/node_modules/canvas/node_modules/node-pre-gyp/lib/util/compile.js:83:29)
          node-pre-gyp ERR! stack     at ChildProcess.emit (events.js:310:20)
          node-pre-gyp ERR! stack     at maybeClose (internal/child_process.js:1021:16)
          node-pre-gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:286:5)
          node-pre-gyp ERR! System Linux 4.4.59+
          node-pre-gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/canvas/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"
          node-pre-gyp ERR! cwd /opt/iobroker/node_modules/canvas
          node-pre-gyp ERR! node -v v12.16.3
          node-pre-gyp ERR! node-pre-gyp -v v0.11.0
          node-pre-gyp ERR! not ok
          npm ERR! code ELIFECYCLE
          npm ERR! errno 1
          npm ERR! canvas@2.6.1 install: `node-pre-gyp install --fallback-to-build`
          npm ERR! Exit status 1
          npm ERR!
          npm ERR! Failed at the canvas@2.6.1 install script.
          npm ERR!     /opt/iobroker/.npm/_logs/2020-05-02T11_26_33_480Z-debug.log
            gyp ERR! not ok
            npm ERR! errno 1
            npm ERR!
            Thomas BraunT
            Thomas BraunT
            #684
            @dslraser Da fehlen jetzt die -dev-Pakete aus dem graphic stack. Ich weiß aber nicht wo man die bei deinem System her bekommt.
              dslraserD
              dslraserD
              dslraser
              #685
              @Thomas-Braun
              ich bin jetzt mal ne Stunde wech, nachher gets weiter.
              • liv-in-skyL
                liv-in-skyL
                #686
                was sind das für warnungen ? weiß jmd, wie man die die wegbekommen kann
                web.1	2020-05-02 13:43:02.580	warn	(22881) readFile will not read this file (uploads/files/1588419094081-xxxxxxxxxxxxxx6f-0378895cb788-grafik.png) in future versions: assets is not an object of type "meta"
                kommt so alle 20-30 sekunden - die
                  dslraserD
                  dslraserD
                  dslraser
                  #687
                  Was für Infos brauchst Du dafür ?
                    @dirk1962 sagte in js-controller 3.0 jetzt im Latest!:
                    @dslraser
                    Ich habe den Befehl nach "iobroker stop" im Verzeichnis "opt/iobroker" ausgeführt.
                    Mache ich da was falsch?
                    @apollon77
                    Beim heutigen Update (iot 1.4.14) ist es wieder da...
                    2020-05-02 13:05:48.477 - warn: iot.0 (1102) Cannot initialize getImage: Error: The module '/opt/iobroker/node_modules/canvas/build/Release/canvas.node'
                    was compiled against a different Node.js version using
                    NODE_MODULE_VERSION 64. This version of Node.js requires
                    NODE_MODULE_VERSION 72. Please try re-compiling or re-installing
                    the module (for instance, using `npm rebuild` or `npm install`).
                    apollon77A
                    apollon77A
                    #688
                    @dslraser Poste mal das install log von dem update
                      @dslraser
                      npm rebuild canvas
                      In /opt/iobroker
                      apollon77A
                      apollon77A
                      #689
                      @Thomas-Braun Das iobroker rebuild iot --install ist der preferred way mit controller 3.0!
                      dirk1962D 1 Antwort Letzte Antwort
                        apollon77A
                        apollon77A
                        #690
                        @Thomas-Braun Und genau aus dem grund haben wir das eigene Kommando! @Thomas-Braun Bitte empfehle das in Zukunft. Danke!
                        • apollon77A apollon77
                          dslraserD
                          dslraserD
                          dslraser
                          #691
                          @apollon77 sagte in js-controller 3.0 jetzt im Latest!:
                          vom iot Update, oder welches meinst Du ?
                          • liv-in-skyL liv-in-sky
                            apollon77A
                            apollon77A
                            #692
                            @liv-in-sky eigene Files die du irgendwie aus nem eigenen Folder lesen willst oder so? Der Name ist "assets" ... klingelt da was vllt?
                              apollon77A
                              apollon77A
                              #693
                              @dslraser Die sollte der Adapter an sich installieren ... mach mal ein apt installmit der Liste die da angegeben ist https://github.com/ioBroker/ioBroker.iot/blob/master/io-package.json#L243
                              Deswegen wäre ich mal über ein Install Log vom Adapter echt erfreut
                              Bzw bitte führe mal im container das hier aus
                              node -e 'console.log(process.platform);'
                              Was ist das Ergebnis?
                                dslraserD
                                dslraserD
                                dslraser
                                #694
                                root@iobroker:/opt/iobroker# node -e 'console.log(process.platform);'
                                linux
                                  dslraserD
                                  dslraserD
                                  dslraser
                                  #695
                                  das Log von heute habe ich vorhin gelöscht, da ich noch was anderes gemacht habe, da ist jetzt fast nichts drinn, jedenfalls nichts mehr von den Updates...😕
                                    apollon77A
                                    apollon77A
                                    #696
                                    @dslraser Dann versuch mal manuell die genannten Pakete zu installieren, an sich würde ich aber erwarten das er sagt das die alle da sind
                                      dslraserD
                                      dslraserD
                                      dslraser
                                      #697
                                      @apollon77
                                      meinst Du so ? (dann wäre das erste schon nicht da, oder ?)
                                      root@iobroker:/opt/iobroker# apt install libcairo2-dev
                                      E: Paket libcairo2-dev kann nicht gefunden werden.
                                        @apollon77
                                        apollon77A
                                        apollon77A
                                        #698
                                        @dslraser Was hast denn du für ein System in deinem Container? Also Debian hat das seit ewig (https://packages.debian.org/search?keywords=libcairo2-dev), Ubuntu an such auch ...
                                          dslraserD
                                          dslraserD
                                          dslraser
                                          #699
                                          @apollon77
                                          das ist das "Buanet Image 4.2=latest"
                                          33.2k
                                          84.4k
