  4. js-controller 3.0/3.1 jetzt im Latest!
js-controller
1.3k Beiträge 127 Kommentatoren 714.7k Aufrufe 89 Beobachtet
    Canvas rebuilden.
    dslraserD
    dslraserD
    dslraser
    #677
    @Thomas-Braun sagte in js-controller 3.0 jetzt im Latest!:
    Canvas rebuilden.
    ich habe das damit gemacht
    iobroker rebuild iot --install
    oder doch noch irgendwie anders ?
    • dslraserD dslraser
      Canvas rebuilden.
      Thomas BraunT
      Thomas BraunT
      Most Active Developer
      #678
      @dslraser
      npm rebuild canvas
      In /opt/iobroker
      dslraserD apollon77A 2 Antworten Letzte Antwort
        @dslraser
        npm rebuild canvas
        In /opt/iobroker
        dslraserD
        dslraserD
        dslraser
        #679
        npm rebuild canvas
        habe ich eben gemacht
        root@iobroker:/opt/iobroker# npm rebuild canvas
        > canvas@2.6.1 install /opt/iobroker/node_modules/canvas
        > node-pre-gyp install --fallback-to-build
        node-pre-gyp WARN Using request for node-pre-gyp https download
        [canvas] Success: "/opt/iobroker/node_modules/canvas/build/Release/canvas.node" already installed
        Pass --update-binary to reinstall or --build-from-source to recompile
        > canvas@2.6.1 install /opt/iobroker/node_modules/iobroker.iot/node_modules/canvas
        [canvas] Success: "/opt/iobroker/node_modules/iobroker.iot/node_modules/canvas/build/Release/canvas.node" already installed
        canvas@2.6.1 /opt/iobroker/node_modules/canvas
        canvas@2.6.1 /opt/iobroker/node_modules/iobroker.iot/node_modules/canvas
          npm rebuild canvas
          Thomas BraunT
          Thomas BraunT
          #680
          @dslraser Nicht als root!
            dslraserD
            dslraserD
            dslraser
            #681
            @Thomas-Braun
            sondern ? (Portainer---Docker)
              @Thomas-Braun
              Thomas BraunT
              Thomas BraunT
              #682
              @dslraser Ach, der blöde Docker...
              npm rebuild canvas --build-from-source
                dslraserD
                dslraserD
                dslraser
                #683
                root@iobroker:/opt/iobroker# npm rebuild canvas --build-from-source
                Package pixman-1 was not found in the pkg-config search path.
                Perhaps you should add the directory containing `pixman-1.pc'
                to the PKG_CONFIG_PATH environment variable
                No package 'pixman-1' found
                gyp: Call to 'pkg-config pixman-1 --libs' returned exit status 1 while in binding.gyp. while trying to load binding.gyp
                gyp ERR! configure error
                gyp ERR! stack Error: `gyp` failed with exit code: 1
                gyp ERR! stack     at ChildProcess.onCpExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/configure.js:351:16)
                gyp ERR! stack     at ChildProcess.emit (events.js:310:20)
                gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:275:12)
                gyp ERR! System Linux 4.4.59+
                gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "configure" "--fallback-to-build" "--module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node" "--module_name=canvas" "--module_path=/opt/iobroker/node_modules/canvas/build/Release" "--napi_version=5" "--node_abi_napi=napi" "--napi_build_version=0" "--node_napi_label=node-v72"
                gyp ERR! cwd /opt/iobroker/node_modules/canvas
                gyp ERR! node -v v12.16.3
                gyp ERR! node-gyp -v v5.1.0
                gyp ERR! not ok
                node-pre-gyp ERR! build error
                node-pre-gyp ERR! stack Error: Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js configure --fallback-to-build --module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node --module_name=canvas --module_path=/opt/iobroker/node_modules/canvas/build/Release --napi_version=5 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v72' (1)
                node-pre-gyp ERR! stack     at ChildProcess.<anonymous> (/opt/iobroker/node_modules/canvas/node_modules/node-pre-gyp/lib/util/compile.js:83:29)
                node-pre-gyp ERR! stack     at ChildProcess.emit (events.js:310:20)
                node-pre-gyp ERR! stack     at maybeClose (internal/child_process.js:1021:16)
                node-pre-gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:286:5)
                node-pre-gyp ERR! System Linux 4.4.59+
                node-pre-gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/canvas/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"
                node-pre-gyp ERR! cwd /opt/iobroker/node_modules/canvas
                node-pre-gyp ERR! node -v v12.16.3
                node-pre-gyp ERR! node-pre-gyp -v v0.11.0
                node-pre-gyp ERR! not ok
                npm ERR! code ELIFECYCLE
                npm ERR! errno 1
                npm ERR! canvas@2.6.1 install: `node-pre-gyp install --fallback-to-build`
                npm ERR! Exit status 1
                npm ERR!
                npm ERR! Failed at the canvas@2.6.1 install script.
                npm ERR!     /opt/iobroker/.npm/_logs/2020-05-02T11_26_33_480Z-debug.log
                  gyp ERR! not ok
                  npm ERR! errno 1
                  npm ERR!
                  Thomas BraunT
                  Thomas BraunT
                  #684
                  @dslraser Da fehlen jetzt die -dev-Pakete aus dem graphic stack. Ich weiß aber nicht wo man die bei deinem System her bekommt.
                    dslraserD
                    dslraserD
                    dslraser
                    #685
                    @Thomas-Braun
                    ich bin jetzt mal ne Stunde wech, nachher gets weiter.
                    • liv-in-skyL
                      liv-in-skyL
                      #686
                      was sind das für warnungen ? weiß jmd, wie man die die wegbekommen kann
                      web.1	2020-05-02 13:43:02.580	warn	(22881) readFile will not read this file (uploads/files/1588419094081-xxxxxxxxxxxxxx6f-0378895cb788-grafik.png) in future versions: assets is not an object of type "meta"
                      kommt so alle 20-30 sekunden - die
                        dslraserD
                        dslraserD
                        dslraser
                        #687
                        Was für Infos brauchst Du dafür ?
                          @dirk1962 sagte in js-controller 3.0 jetzt im Latest!:
                          @dslraser
                          Ich habe den Befehl nach "iobroker stop" im Verzeichnis "opt/iobroker" ausgeführt.
                          Mache ich da was falsch?
                          @apollon77
                          Beim heutigen Update (iot 1.4.14) ist es wieder da...
                          2020-05-02 13:05:48.477 - warn: iot.0 (1102) Cannot initialize getImage: Error: The module '/opt/iobroker/node_modules/canvas/build/Release/canvas.node'
                          was compiled against a different Node.js version using
                          NODE_MODULE_VERSION 64. This version of Node.js requires
                          NODE_MODULE_VERSION 72. Please try re-compiling or re-installing
                          the module (for instance, using `npm rebuild` or `npm install`).
                          apollon77A
                          apollon77A
                          #688
                          @dslraser Poste mal das install log von dem update
                            @dslraser
                            npm rebuild canvas
                            In /opt/iobroker
                            apollon77A
                            apollon77A
                            #689
                            @Thomas-Braun Das iobroker rebuild iot --install ist der preferred way mit controller 3.0!
                            dirk1962D 1 Antwort Letzte Antwort
                              apollon77A
                              apollon77A
                              #690
                              @Thomas-Braun Und genau aus dem grund haben wir das eigene Kommando! @Thomas-Braun Bitte empfehle das in Zukunft. Danke!
                              • apollon77A apollon77
                                dslraserD
                                dslraserD
                                dslraser
                                #691
                                @apollon77 sagte in js-controller 3.0 jetzt im Latest!:
                                vom iot Update, oder welches meinst Du ?
                                • liv-in-skyL liv-in-sky
                                  apollon77A
                                  apollon77A
                                  #692
                                  @liv-in-sky eigene Files die du irgendwie aus nem eigenen Folder lesen willst oder so? Der Name ist "assets" ... klingelt da was vllt?
                                    apollon77A
                                    apollon77A
                                    #693
                                    @dslraser Die sollte der Adapter an sich installieren ... mach mal ein apt installmit der Liste die da angegeben ist https://github.com/ioBroker/ioBroker.iot/blob/master/io-package.json#L243
                                    Deswegen wäre ich mal über ein Install Log vom Adapter echt erfreut
                                    Bzw bitte führe mal im container das hier aus
                                    node -e 'console.log(process.platform);'
                                    Was ist das Ergebnis?
                                      dslraserD
                                      dslraserD
                                      dslraser
                                      #694
                                      root@iobroker:/opt/iobroker# node -e 'console.log(process.platform);'
                                      linux
                                        dslraserD
                                        dslraserD
                                        dslraser
                                        #695
                                        das Log von heute habe ich vorhin gelöscht, da ich noch was anderes gemacht habe, da ist jetzt fast nichts drinn, jedenfalls nichts mehr von den Updates...😕
                                          apollon77A
                                          apollon77A
                                          #696
                                          @dslraser Dann versuch mal manuell die genannten Pakete zu installieren, an sich würde ich aber erwarten das er sagt das die alle da sind
                                          33.2k
                                          84.4k
