  4. [Major Update] SourceAnalytix v0.4.7-beta.0 released !
    6.5k
sourceanalytixtestenadapterupdate
1.1k Beiträge 103 Kommentatoren 440.5k Aufrufe 93 Beobachtet
  • SunshinemakerS Sunshinemaker
    @Dutchman
    Das sind die vom Xiaomi Mi power plug ZigBee EU, Model: ZNCZ04LM
      "type": "state",
      "common": {
        "name": "Steckdose Load power",
        "type": "number",
        "unit": "W",
        "read": true,
        "write": false,
        "role": "value.power",
        "custom": {
          "sourceanalytix.0": {
            "enabled": true,
            "alias": "",
            "state_type": "kWh_consumption",
            "state_unit": "w",
            "costs": false,
            "consumption": true,
            "meter_values": false,
            "start_day": 2.1522543344583314,
            "start_week": 0.010404209858333333,
            "start_month": 0,
            "start_quarter": 0,
            "start_year": 0,
            "previousReadingWatt": null,
            "previousReadingWattTs": null
      "from": "system.adapter.sourceanalytix.0",
      "user": "system.user.admin",
      "ts": 1587160800019,
      "_id": "zigbee.0.04cf8cdf3c75a1bf.load_power",
      "acl": {
        "object": 1636,
        "state": 1636,
        "owner": "system.user.admin",
      "native": {}
    Und das die Daten vom HMIP PSM
      "type": "state",
      "common": {
        "def": 0,
        "type": "number",
        "read": true,
        "write": false,
        "min": 0,
        "max": 838859.1,
        "unit": "Wh",
        "name": "Stckd_Fernseher:6.ENERGY_COUNTER",
        "custom": {
            "enabled": true,
            "alias": "",
            "state_unit": "wh",
            "costs": false,
            "start_day": 164.3275,
            "start_week": 164.3275,
            "start_month": 164.3275,
            "start_quarter": 164.3275,
            "start_year": 164.3275,
            "currentValuekWh": null
      "native": {
        "MIN": 0,
        "UNIT": "Wh",
        "OPERATIONS": 5,
        "MAX": 838859.1,
        "FLAGS": 1,
        "ID": "ENERGY_COUNTER",
        "TYPE": "FLOAT",
        "DEFAULT": 0,
        "CONTROL": "POWERMETER_PSM.ENERGY_COUNTER"
      "ts": 1587160800020,
      "_id": "hm-rpc.1.0001D3XXXXXXXX.6.ENERGY_COUNTER",
      "acl": {
        "object": 1636,
        "state": 1636,
      "type": "state",
      "common": {
        "def": 0,
        "type": "number",
        "read": true,
        "write": false,
        "min": 0,
        "max": 163830,
        "unit": "W",
        "name": "Stckd_Fernseher:6.POWER",
        "custom": {
            "enabled": true,
            "alias": "",
            "state_unit": "w",
            "costs": false,
            "start_day": 0,
            "start_week": 0,
            "start_month": 0,
            "start_quarter": 0,
            "start_year": 0,
            "previousReadingWattTs": null,
            "valueAtDeviceReset": 0.7450009218833333
      "native": {
        "MIN": 0,
        "UNIT": "W",
        "OPERATIONS": 5,
        "MAX": 163830,
        "FLAGS": 1,
        "ID": "POWER",
        "TYPE": "FLOAT",
        "DEFAULT": 0,
        "CONTROL": "POWERMETER_PSM.POWER"
      "ts": 1587160800018,
      "_id": "hm-rpc.1.0001D3XXXXXXXX.6.POWER",
      "acl": {
        "object": 1636,
        "state": 1636,
    DutchmanD Offline
    DutchmanD Offline
    Dutchman
    #151
    @Sören sagte in [Major Update] SourceAnalytix 0.4.0 complete code rebuild:
    Super ich danke dir, schaue mir das alles mal in ruhe an
    • DutchmanD Dutchman
      @AtomicIX sagte in [Major Update] SourceAnalytix 0.4.0 complete code rebuild:
      Dafür habe ich einen Wasserzähler mit integriertem Pulsgeber.
      Pulse habe ich noch nicht implementiert kommen aber demnaest, dan kannst einstellen wieviele Pulse ein m3 sind und errechnet SA das alles fuer dich
      AtomicIXA Offline
      AtomicIXA Offline
      AtomicIX
      #152
      @Dutchman Cool , klasse. Jetzt habe ich auch nach der neu Installation und dem Xten Neustart, die Einstellungen.
      Kannst du ungefähr absehen, wann du es schaffst, das Pulsen einzunbauen?
      • AtomicIXA AtomicIX
        DutchmanD Offline
        DutchmanD Offline
        Dutchman
        #153
        bin gerade am reset problem dran denke mal so 1-2 Wochen
        AtomicIXA 1 Antwort Letzte Antwort
          AtomicIXA Offline
          AtomicIXA Offline
          AtomicIX
          #154
          @Dutchman cool, danke
          • lobomauL lobomau
            @Dutchman Wow! Das ist noch mal merklich. Das ist jetzt im produktiv ioBroker. Geloggt ist in schwarz sourceanalytix.0.cpu.
            Zuerst Werte über Discovergy, 60s Aktualisierung, dann 120s und schließlich Umstellung auf smartmeter 60s.
            Normalerweise habe ich smartmeter auf 5s.
            Ich habe um 13:09 Uhr die smartmeter Aktualiserung auf 5s gestellt. Die Last geht NICHT hoch! :-)
            Mein ganzes System ist ruhiger, ioBroker kommt jetzt im Mittel mit 17% der CPU aus (vorher 27%)! 👏 👏 👏
            Also: Schuld war Kombination Discovergy mit Sourceanalytix
            DutchmanD Offline
            DutchmanD Offline
            Dutchman
            #155
            @lobomau sagte in [Major Update] SourceAnalytix 0.4.0 complete code rebuild:
            Hey, könntest du mal bitte die neuer Version von discovergy testen ob damit diese problem gelöst ist ?
              lobomauL Offline
              lobomauL Offline
              lobomau
              #156
              @Dutchman ich habe auf 0.5.2 geupdatet. Mehrbelastung ist weg 👍
              Hier ist der Verlauf. Erster Anstieg ist beim Update, dann habe ich Discovergy in SA dazugenommen mit 5s Aktualisierung, zweiter Anstieg ist Discovergy-Adapter Neustart. Ich hab noch was zum Thema Discovergy-Adapter, das ich im anderen thread antworte...
              Host: NUC8i3 mit Proxmox:
              • Slave: Pi4
              • lobomauL lobomau
                DutchmanD Offline
                DutchmanD Offline
                Dutchman
                #157
                Super ! Problem solved wie erwartet wegen den unnötigen object sets das andere klareren wir im discovergy thread
                • L Offline
                  lexiz52
                  #158
                  Erst mal vielen Dank für die Arbeit an diesem Adapter! Ich habe dieses Wochenende mein System neu aufgesetzt (Raspi4). In meiner alten vis nutze ich die Daten aus "this week (Montag-Sonntag)". Mir ist aufgefallen das in der neuen Version zwar ein neues Verzeichnis 2020 erstellt wird, was grundsätzlich gut ist um Daten aus den Jahren vergleichen zu können, aber natürlich in 2021 einiges an Arbeit in vis verursachen wird da ich meine Datenpunkte aktualisieren muss. In 2020 gibt es keinen Datenpunkt "this week" mehr und das alte wird nicht mehr aktualisiert. Ist das richtig oder habe etwas übersehen oder falsch angeklickt? Ist es geplant das der Datenpunkt "this week" wieder eingepflegt wird, ich halte diesen für sehr wichtig?
                  Danke !
                  Lexiz52
                  • L lexiz52
                    Danke !
                    Lexiz52
                    DutchmanD Offline
                    DutchmanD Offline
                    Dutchman
                    #159
                    @lexiz52 sagte in [Major Update] SourceAnalytix 0.4.0 complete code rebuild:
                    working on it : https://github.com/iobroker-community-adapters/ioBroker.sourceanalytix/issues/135
                      @Homer-J sagte in [Major Update] SourceAnalytix 0.4.0 complete code rebuild:
                      Morgen @Dutchman irgendetwas stimmt noch nicht ganz, jetzt wird der Tageswert zwar zurück gesetzt aber auch die restlichen Werte auf Null. Starte ich den Adapter einmal neu schreibt er die Werte wieder.
                      ich erwarte dafuer heute ein update das scheint zu passieren wen nach denn tagesreset sich der wert nicht aktualisiert.
                      Danke fürs melden
                      Berchemer
                      schrieb am zuletzt editiert von Berchemer
                      #160
                      @Dutchman sagte in [Major Update] SourceAnalytix 0.4.0 complete code rebuild:
                      Danke fürs melden
                      Da ich kein issue zum Thema auf github gefunden habe, möchte ich nur kurz mitteilen, dass auch ich das Problem habe und ggf. gerne Daten sende, um den Fehler besser zu lokalisieren :-)
                      O 1 Antwort Letzte Antwort
                      • B Berchemer
                        Danke fürs melden
                        O Offline
                        O Offline
                        osser
                        #161
                        @Berchemer sagte in [Major Update] SourceAnalytix 0.4.0 complete code rebuild:
                        Danke fürs melden
                        Dieses Verhalten kann ich auch bestätigen.
                        • O osser
                          Danke fürs melden
                          DutchmanD Offline
                          DutchmanD Offline
                          Dutchman
                          #162
                          @osser sagte in [Major Update] SourceAnalytix 0.4.0 complete code rebuild:
                          bin noch dran is diesmal n hartnäckiger :/
                            Berchemer
                            #163
                            Glück auf ;-)
                            • lobomauL Offline
                              lobomauL Offline
                              lobomau
                              #164
                              ich habe bei dem Adapter ein "Neu starten" kurz nach Tagesbeginn eingestellt und habe damit keine Einschränkungen. Oder übersehe ich etwas?
                              • Slave: Pi4
                              • lobomauL lobomau
                                DutchmanD Offline
                                DutchmanD Offline
                                Dutchman
                                #165
                                sollte so klappen, ist aber nicht wie ich es gerne hätte :(
                                Mit definieren bitte "kurz nach", ich wuerde es nicht innerhalb einer Sekunden mache den bei vielen werte ist er dan noch am rechnen :)
                                  crunchipC Abwesend
                                  crunchipC Abwesend
                                  #166
                                  @Dutchman ich lass nach 10min neustarten, sollte reichen
                                  • lobomauL Offline
                                    lobomauL Offline
                                    lobomau
                                    #167
                                    ich lasse sogar erst um 1:15h neustarten.
                                    • Slave: Pi4
                                    • lobomauL lobomau
                                      DutchmanD Offline
                                      DutchmanD Offline
                                      Dutchman
                                      #168
                                      ich bin dem Fehler auf der spur musste aber erst ne andere Baustelle lösen, sneak preview :
                                      Schermafbeelding 2020-04-22 om 12.25.56.png Schermafbeelding 2020-04-22 om 12.26.11.png
                                      coyoteC 1 Antwort Letzte Antwort
                                        coyoteC Offline
                                        coyoteC Offline
                                        coyote
                                        #169
                                        @Dutchman das sieht doch sehr gut aus 👍
                                        Leider kann ich nicht wirklich die neue Version testen, solange "Cannot read property .toLowerCase of undefined" der Fehler noch vorhanden ist. 😞
                                        • coyoteC coyote
                                          DutchmanD Offline
                                          DutchmanD Offline
                                          Dutchman
                                          #170
                                          @coyote sagte in [Major Update] SourceAnalytix 0.4.0 complete code rebuild:
                                          wie du da oben siehst, ist die Lösung unterwegs das problem hat naemlich mit der unit zu tun.
                                          Ich habe mich dazu entschieden die komplette unit Zuweisung neu auf zu bauen, das ermöglich es jetzt auch dynamisch units und Umrechnung factor selber ein zu tragen.
                                          Beipiele : Regenwasser messen in mm und solche spaesschen.
                                          In dem code teil ist auch dieser undefined error, erhoffe mir das morgen im griff zu haben muss aber noch mehr testen dafuer
