  4. Beta Test js-controller 3.0.x auf GitHub
js-controller
416 Beiträge 39 Kommentatoren 107.6k Aufrufe 38 Beobachtet
  • wendy2702W wendy2702
    Logfile?
    So gemacht!?
    npm install iobroker.js-controller@2.2.9
    guergen
    #338
    @wendy2702
    Hier mit 2.2.9:
     npm install ioBroker.js-controller@2.2.9                           npm ERR! code E404
    npm ERR! 404 Not Found - GET https://registry.npmjs.org/ioBroker.js-controller -                     Not found
    npm ERR! 404
    npm ERR! 404  'ioBroker.js-controller@2.2.9' is not in the npm registry.
    npm ERR! 404 Your package name is not valid, because
    npm ERR! 404  1. name can no longer contain capital letters
    npm ERR! 404
    npm ERR! 404 Note that you can also install from a
    npm ERR! 404 tarball, folder, http url, or git url.
    Das Selbe mit 2.2.10:
    iobroker@iobroker:/opt/iobroker$ npm install ioBroker.js-controller@2.2.10
    npm ERR! code E404
    npm ERR! 404
    npm ERR! 404  'ioBroker.js-controller@2.2.10' is not in the npm registry.
    npm ERR! 404
    Hier ein Log:
    0 info it worked if it ends with ok
    1 verbose cli [ '/usr/bin/node',
    1 verbose cli   '/usr/bin/npm',
    1 verbose cli   'install',
    1 verbose cli   'ioBroker.js-controller@2.2.9' ]
    2 info using npm@6.14.4
    3 info using node@v10.20.1
    4 verbose npm-session b1d2b8998bed8472
    5 silly install loadCurrentTree
    6 silly install readLocalPackageData
    7 http fetch GET 404 https://registry.npmjs.org/ioBroker.js-controller 1058ms
    8 http fetch GET 404 https://registry.npmjs.org/ioBroker.js-controller 778ms
    9 silly fetchPackageMetaData error for ioBroker.js-controller@2.2.9 404 Not Found - GET https://registry.npmjs.org/ioBroker.js-controller - Not found
    10 timing stage:rollbackFailedOptional Completed in 1ms
    11 timing stage:runTopLevelLifecycles Completed in 4482ms
    12 verbose stack Error: 404 Not Found - GET https://registry.npmjs.org/ioBroker.js-controller - Not found
    12 verbose stack     at res.buffer.catch.then.body (/usr/lib/node_modules/npm/node_modules/npm-registry-fetch/check-response.js:104:15)
    12 verbose stack     at process._tickCallback (internal/process/next_tick.js:68:7)
    13 verbose statusCode 404
    14 verbose pkgid ioBroker.js-controller@2.2.9
    15 verbose cwd /opt/iobroker
    16 verbose Linux 4.19.0-6-amd64
    17 verbose argv "/usr/bin/node" "/usr/bin/npm" "install" "ioBroker.js-controller@2.2.9"
    18 verbose node v10.20.1
    19 verbose npm  v6.14.4
    20 error code E404
    21 error 404 Not Found - GET https://registry.npmjs.org/ioBroker.js-controller - Not found
    22 error 404
    23 error 404 'ioBroker.js-controller@2.2.9' is not in the npm registry.
    24 error 404 Your package name is not valid, because
    25 error 404 1. name can no longer contain capital letters
    26 error 404 Note that you can also install from a
    27 error 404 tarball, folder, http url, or git url.
    28 verbose exit [ 1, true ]
    • wendy2702W Offline
      wendy2702W Offline
      #339
      Ich schreibe das:
      du machst das:
      man beachte das "B" in iobroker :-)
      G 1 Antwort Letzte Antwort
        Ich schreibe das:
        du machst das:
        guergen
        #340
        @wendy2702 Wo kommt das denn her.... ich habe copy/paste gemacht.... aber von der ersten Seite ganz oben...
        egal....
        Der Fehler sitzt je meistend VOR dem Bildschirm...
        • afuerhoffA Offline
          afuerhoffA Offline
          afuerhoff
          #341
          Hallo, hab auf meinem Raspberry Pi 3 Testsystem die 3.0.13 unter Node.js 10.20.0 am Laufen. Installation lief reibungslos. Im Betrieb bis jetzt keine Auffälligkeiten. Bei der Adapter-Entwicklung hat das sofort einen Benefit gebracht, da sich ein Fehler bei der Objektbezeichnung sofort im Log angezeigt wurde.
          Danke an die Entwickler für die Super Arbeit :-)
          • G guergen
            egal....
            wendy2702W Offline
            wendy2702W Offline
            #342
            @guergen sagte in Beta Test js-controller 3.0.x auf GitHub:
            Kenne ich.... hier auch ;-)
              guergen
              #343
              @wendy2702 Bin jetzt komplett wieder zurück, läuft...
              • G guergen
                apollon77A Online
                apollon77A Online
                #344
                @guergen und du hast nach einem Admin Update auch im Browser einen richtigen harten reload gemacht? Sonst Hast du nämlich noch
                Den alten Admin JavaScript Code im Browser und das neue greift nicht!
                  @apollon77 In Anlehnung an deinen Eröffnungspost das Ihr informiert werden wolltet. Habe noch einen zweiten Slave und Master. Soll ich etwas besonderes testen?
                  Gerade einen meiner Slaves von 2.2.9 auf 3.0.13 upgedated.
                  Erster Versuch schlug fehlt wegen fehlender Zugriffsrechte:
                  pi@pi-iobroker:/opt/iobroker $ sudo npm install ioBroker/ioBroker.js-controller
                  npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
                  > iobroker.js-controller@3.0.13 preinstall /opt/iobroker/node_modules/iobroker.js-controller
                  > node lib/preinstallCheck.js
                  NPM version: 6.14.4
                  > iobroker.js-controller@3.0.13 install /opt/iobroker/node_modules/iobroker.js-controller
                  > node iobroker.js setup first
                  Cannot delete file. Not critical: Error: EACCES: permission denied, unlink '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/../../_service_iobroker.bat'
                  Cannot delete file. Not critical: Error: EACCES: permission denied, unlink '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/../../iobroker.bat'
                  Cannot delete file. Not critical: Error: EACCES: permission denied, unlink '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/../../iob.bat'
                  fs.js:114
                      throw err;
                  Error: EACCES: permission denied, mkdir '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/../../tmp'
                      at Object.mkdirSync (fs.js:757:3)
                      at Setup.setup (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupSetup.js:692:16)
                      at processCommand (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:258:23)
                      at Object.module.exports.execute (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:2583:5)
                      at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js:1:24)
                      at Module._compile (internal/modules/cjs/loader.js:778:30)
                      at Object.Module._extensions..js (internal/modules/cjs/loader.js:789:10)
                      at Module.load (internal/modules/cjs/loader.js:653:32)
                      at tryModuleLoad (internal/modules/cjs/loader.js:593:12)
                      at Function.Module._load (internal/modules/cjs/loader.js:585:3)
                  npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.1.2 (node_modules/chokidar/node_modules/fsevents):
                  npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
                  npm ERR! code ELIFECYCLE
                  npm ERR! errno 1
                  npm ERR! iobroker.js-controller@3.0.13 install: `node iobroker.js setup first`
                  npm ERR! Exit status 1
                  npm ERR!
                  npm ERR! Failed at the iobroker.js-controller@3.0.13 install script.
                  npm ERR!     /root/.npm/_logs/2020-04-20T14_39_28_903Z-debug.log
                  So sieht es allerdings im Ordner aus:
                  pi@pi-iobroker:/opt/iobroker $ ls -la
                  insgesamt 84
                  drwxrwxrwx+   7 iobroker iobroker  4096 Feb 25 09:42 .
                  drwxr-xr-x    4 root     root      4096 Feb  1  2018 ..
                  drwxrwxrwx+   2 iobroker iobroker  4096 Apr 20 16:16 backups
                  drwxrwxrwx+   2 iobroker iobroker  4096 Feb 15  2017 etc
                  -rwxrwxrwx+   1 iobroker iobroker   104 Mär  4  2019 INSTALLER_INFO.txt
                  -rwxrwxrwx+   1 iobroker iobroker   297 Feb 15  2017 install.sh
                  lrwxrwxrwx    1 iobroker iobroker    22 Mär  4  2019 iob -> /opt/iobroker/iobroker
                  -rwxrwxrwx+   1 iobroker iobroker   226 Mär  4  2019 iobroker
                  drwxrwxrwx+   4 iobroker iobroker  4096 Mai 14  2018 iobroker-data
                  -rwxrwxrwx+   1 iobroker iobroker    92 Mär  4  2019 killall.sh
                  drwxrwxrwx+   2 iobroker iobroker  4096 Apr 20 16:33 log
                  drwxrwxrwx+ 486 iobroker iobroker 20480 Apr 20 16:39 node_modules
                  -rwxrwxrwx+   1 iobroker iobroker    19 Mär  7  2019 .npmrc
                  -rwxrwxrwx+   1 iobroker iobroker   302 Feb 25 09:42 package.json
                  -rwxrwxrwx+   1 iobroker iobroker  5728 Apr 20 16:39 reinstall.js
                  -rwxrwxrwx+   1 iobroker iobroker   709 Mär  4  2019 reinstall.sh
                  Das sagt der Fixer:
                  pi@pi-iobroker:/opt/iobroker $ sudo curl -sL https://iobroker.net/fix.sh | bash -
                  library: loaded
                  Library version=2020-04-12
                  ioBroker is not installed in /opt/iobroker! Cannot fix anything...
                  Das dann mit festgelegtem User:
                  pi@pi-iobroker:/opt/iobroker $ sudo -H -u iobroker npm install ioBroker/ioBroker.js-controller
                  NPM version: 6.14.4
                  object system.certificates updated
                  npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.1.2 (node_modules/fsevents):
                  + iobroker.js-controller@3.0.13
                  added 69 packages from 61 contributors and audited 1552 packages in 150.66s
                  6 packages are looking for funding
                    run `npm fund` for details
                  found 61 vulnerabilities (23 low, 13 moderate, 25 high)
                    run `npm audit fix` to fix them, or `npm audit` for details
                     │      New patch version of npm available! 6.13.4 → 6.13.7       │
                     │   Changelog: https://github.com/npm/cli/releases/tag/v6.13.7   │
                     │               Run npm install -g npm to update!                │
                  pi@pi-iobroker:/opt/iobroker $ ^V
                  Noch etwas, von woher bekommt Ihr die Info wegen NPM Patch?
                  Wenn ich das NPM Update mache habe ich danach die Version "6.14.4" installiert:
                  sudo npm install -g npm
                  /usr/bin/npm -> /usr/lib/node_modules/npm/bin/npm-cli.js
                  /usr/bin/npx -> /usr/lib/node_modules/npm/bin/npx-cli.js
                  + npm@6.14.4
                  updated 1 package in 40.604s
                  pi@pi-iobroker:/opt/iobroker $ node -v
                  v10.20.1
                  pi@pi-iobroker:/opt/iobroker $ npm -v
                  6.14.4
                  apollon77A Online
                  apollon77A Online
                  #345
                  @wendy2702 Also am Ende hast Du dir einiges davon scheinbar selbst eingebrockt ;-) Ganz oben steht das Du "sudo" genutzt hast für den install. Steht so aber nicht in der Anleitung!! Damit sind alle die Fehler und ggf andere Probleme die dich zu der Fixing-Arie geführt haben wohl darauf basierend! Tja, was so 4 blöde Buchstaben so ausmachen ;-)
                  ABer hast es ja dann über 5 Ecken hinbekommen.
                  Und die NPM patch-Info gibt NPM selbst aus, kommt nicht von uns
                    Ich konnte nicht warten :-)
                    Beim zweiten meiner Slaves diesmal den Fixer zuerst laufen lassen:
                    pi@iobroker-garage-gross:/opt/iobroker $ iobroker stop
                    pi@iobroker-garage-gross:/opt/iobroker $ sudo curl -sL https://iobroker.net/fix.sh | bash -
                    library: loaded
                        Welcome to the ioBroker installation fixer!
                        Script version: 2020-04-12
                        You might need to enter your password a couple of times.
                        Installing prerequisites (1/3)
                    OK   http://archive.raspberrypi.org jessie InRelease
                    OK   http://mirrordirector.raspbian.org jessie InRelease
                    OK   https://deb.nodesource.com jessie InRelease
                    OK   http://archive.raspberrypi.org jessie/main armhf Packages
                    OK   http://archive.raspberrypi.org jessie/ui armhf Packages
                    OK   http://mirrordirector.raspbian.org jessie/main armhf Packages
                    OK   http://mirrordirector.raspbian.org jessie/contrib armhf Packages
                    OK   https://deb.nodesource.com jessie/main Sources
                    OK   https://deb.nodesource.com jessie/main armhf Packages
                    OK   http://mirrordirector.raspbian.org jessie/non-free armhf Packages
                    OK   http://mirrordirector.raspbian.org jessie/rpi armhf Packages
                    Holen: 1 https://deb.nodesource.com jessie/main Translation-de_DE [162 B]
                    Ign http://archive.raspberrypi.org jessie/main Translation-de_DE
                    Holen: 2 https://deb.nodesource.com jessie/main Translation-de [162 B]
                    Ign http://archive.raspberrypi.org jessie/main Translation-en
                    Holen: 3 https://deb.nodesource.com jessie/main Translation-en [162 B]
                    Ign http://archive.raspberrypi.org jessie/ui Translation-de_DE
                    Holen: 4 https://deb.nodesource.com jessie/main Translation-de_DE [162 B]
                    Ign http://archive.raspberrypi.org jessie/ui Translation-en
                    Holen: 5 https://deb.nodesource.com jessie/main Translation-de [162 B]
                    Holen: 6 https://deb.nodesource.com jessie/main Translation-en [162 B]
                    Holen: 7 https://deb.nodesource.com jessie/main Translation-de_DE [162 B]
                    Holen: 8 https://deb.nodesource.com jessie/main Translation-de [162 B]
                    Holen: 9 https://deb.nodesource.com jessie/main Translation-en [162 B]
                    Holen: 10 https://deb.nodesource.com jessie/main Translation-de_DE [162 B]
                    Holen: 11 https://deb.nodesource.com jessie/main Translation-de [162 B]
                    Holen: 12 https://deb.nodesource.com jessie/main Translation-en [162 B]
                    Holen: 13 https://deb.nodesource.com jessie/main Translation-de_DE [162 B]
                    Ign https://deb.nodesource.com jessie/main Translation-de_DE
                    Holen: 14 https://deb.nodesource.com jessie/main Translation-de [162 B]
                    Holen: 15 https://deb.nodesource.com jessie/main Translation-en [162 B]
                    Ign https://deb.nodesource.com jessie/main Translation-en
                    Ign http://mirrordirector.raspbian.org jessie/contrib Translation-de_DE
                    Ign http://mirrordirector.raspbian.org jessie/contrib Translation-en
                    Ign http://mirrordirector.raspbian.org jessie/main Translation-de_DE
                    Ign http://mirrordirector.raspbian.org jessie/main Translation-en
                    Ign http://mirrordirector.raspbian.org jessie/non-free Translation-de_DE
                    Ign http://mirrordirector.raspbian.org jessie/non-free Translation-en
                    Ign http://mirrordirector.raspbian.org jessie/rpi Translation-de_DE
                    Ign http://mirrordirector.raspbian.org jessie/rpi Translation-en
                    Installed gcc-c++
                    Installed python-dev
                        Checking ioBroker user and directory permissions (2/3)
                        Checking autostart (3/3)
                    Enabling autostart...
                    Autostart enabled!
                        Your installation was fixed successfully
                        Run iobroker start to start ioBroker again!
                    pi@iobroker-garage-gross:/opt/iobroker $ iobroker start
                    pi@iobroker-garage-gross:/opt/iobroker $ node -v
                    v10.20.1
                    pi@iobroker-garage-gross:/opt/iobroker $ npm -v
                    6.14.4
                    Dann versucht JS Controller zu installieren:
                    pi@iobroker-garage-gross:/opt/iobroker $ sudo npm install ioBroker/ioBroker.js-controller
                    NPM version: 6.14.4
                    fs.js:114
                        throw err;
                    npm ERR! errno 1
                    npm ERR!
                    npm ERR!     /root/.npm/_logs/2020-04-20T15_24_19_570Z-debug.log
                    Erfolgreich installiert wieder mit festgelegtem User:
                    pi@iobroker-garage-gross:/opt/iobroker $ sudo -H -u iobroker npm install ioBroker/ioBroker.js-controller
                    NPM version: 6.14.4
                    added 67 packages from 84 contributors in 152.394s
                    7 packages are looking for funding
                    apollon77A Online
                    apollon77A Online
                    #346
                    @wendy2702 AUch hier wieder ... wo hast Du das sudo her? ;-) Wenn Du mit einem System Arbeitest welches mit dem Installer bzw Fixer erstellt ist das Bitte FINGER WEG VON SUDO! ... BÖÖÖÖÖÖSE ;-)
                    Am besten jetzt den Fixer nochmal auf beiden Systemen hinterher um ggf komisches nochmal final geradezubiegen
                    harrymH wendy2702W 2 Antworten Letzte Antwort
                    • apollon77A apollon77
                      harrymH Offline
                      harrymH Offline
                      harrym
                      #347
                      @apollon77 🤣 aber nicht immer is sudo böse
                      ASRock FM2A88X-ITX+ mit 32GB RAM, 128GB SSD mit Proxmox, 3x1 TB SSD als RAID mit CT und VMs.
                      • apollon77A Online
                        apollon77A Online
                        #348
                        Ansonsten bedanke ich mich nochmals bei allen hier und wir verlagern die weiteren Themen jetzt in den Latest Thread --> https://forum.iobroker.net/topic/32481/js-controller-3-0-jetzt-im-latest
                          guergen
                          #349
                          @apollon77 ja, hatte ich gemacht.
                            wendy2702W Offline
                            wendy2702W Offline
                            #350
                            @apollon77 sagte in Beta Test js-controller 3.0.x auf GitHub:
                            Hm,
                            so böse kann es nicht sein wenn es am Ende mit den 4 Buchstaben funktioniert hat aber festgelegtem User.
                            Aber hast recht, das "sudo" beim ersten Versuch steht nicht in der Anleitung. ..... scheiß macht der Gewohnheit bevor der Fixer vor Ewigkeiten gelaufen ist.
                              wendy2702W Offline
                              #351
                              Gerade noch das hier im Upgrade log gefunden:
                              The following notifications happened during sync:
                              • Ignoring Directory "_temp" because officially not created as meta object. Please remove directory!
                              • Ignoring Directory "sayit.0" because officially not created as meta object. Please remove directory!
                              • Ignoring Directory "sayit.1" because officially not created as meta object. Please remove directory!
                              Das _temp ist von mir erzeugt aber die beiden sayit Ordner habe ich nicht selber erzeugt:
                                apollon77A Online
                                apollon77A Online
                                #352
                                @wendy2702 Falls Du sayit als Adapter noch installiert hast dann mach ein upload sayit, falls nicht kannste löschen.
                                  wendy2702W Offline
                                  #353
                                  Soll das nur ein Update sein mit dem Upload oder soll etwas mit den Ordnern passieren?
                                    apollon77A Online
                                    apollon77A Online
                                    #354
                                    @wendy2702 Es gab frühere controller Versionen die ggf nicht sauber bei "upload" der bei einer Installation passiert die Objekte angelegt haben. Damit fehlen die. Ein neues "upload" fixt das
                                    • G guergen
                                      Ich kann machen was ich will, der tr064-Adapter spielt nicht mit:
                                      tr-064.0	2020-04-20 17:55:23.460	error	(2058) Password error: Please re-enter the password in Admin. Stopping
                                      tr-064.0	2020-04-20 17:55:23.425	info	(2058) starting. Version 4.0.0 in /opt/iobroker/node_modules/iobroker.tr-064, node: v10.20.1, js-controller: 3.0.13
                                      Ich habe 2 Adapter, wo ich das Fritzbox-Passwort eingeben muss, einmal den TR064 und FB-Presence.
                                      Beim Ersten kann ich machen was ich will, er nimmt das neue Passwort nicht.
                                      FB-Presence nimmt das selbe Passwort ohne Murren.
                                      JS 3.0.13
                                      Admin 4.0.9
                                      TR064 4.0.0
                                      Auch diverse Adapter geben mir folgendes im Log aus:
                                      2020-04-20 16:42:54.438 - warn: maxcul.0 (9240) adapter.objects.getObjectView is deprecated, and will be removed in the future. Please use adapter.getObjectView/Async. Report this to Developer!
                                      2020-04-20 16:42:54.464 - warn: maxcul.0 (9240) adapter.objects.getObjectView is deprecated, and will be removed in the future. Please use adapter.getObjectView/Async. Report this to Developer!
                                      2020-04-20 16:37:14.377 - warn: upnp.0 (11152) State value to set is invalid for upnp.0.FRITZ!Box_7590_(UI).fritzbox.Alive: The state property "expire" has the wrong type "string" (should be "number")!
                                      2020-04-20 16:37:14.377 - warn: upnp.0 (11152) This value will not be set in future versions. Please report this to the developer.
                                      2020-04-20 16:27:05.260 - warn: upnp.0 (11152) State value to set is invalid for upnp.0.Repeater310.fritzbox.Alive: The state property "expire" has the wrong type "string" (should be "number")!
                                      2020-04-20 16:27:05.261 - warn: upnp.0 (11152) This value will not be set in future versions. Please report this to the developer.
                                      Michael SauerM Offline
                                      Michael Sauer
                                      schrieb am zuletzt editiert von Michael Sauer
                                      #355
                                      Habe die Fehler aus dem UPNP Adapter entfernt die Änderung der main.js findet Ihr hier:
                                      https://github.com/Michael-Sauer/ioBroker.upnp
                                      crunchipC apollon77A G 3 Antworten Letzte Antwort
                                      • Michael SauerM Michael Sauer
                                        crunchipC Offline
                                        crunchipC Offline
                                        #356
                                        @Michael-Sauer sagte in Beta Test js-controller 3.0.x auf GitHub:
                                        TR064
                                        zwecks Passwort beim TR064, mal ein upload machen, dann sollte das Problem gelöst sein
                                          apollon77A Online
                                          apollon77A Online
                                          #357
                                          @Michael-Sauer Installier vom tr-064 mal die 4.0.1
