  4. Beta Test js-controller 3.0.x auf GitHub
js-controller
416 Beiträge 39 Kommentatoren 107.6k Aufrufe 38 Beobachtet
  • wendy2702W Online
    wendy2702W Online
    #332
    Ich konnte nicht warten :-)
    Beim zweiten meiner Slaves diesmal den Fixer zuerst laufen lassen:
    pi@iobroker-garage-gross:/opt/iobroker $ iobroker stop
    pi@iobroker-garage-gross:/opt/iobroker $ sudo curl -sL https://iobroker.net/fix.sh | bash -
    library: loaded
    Library version=2020-04-12
        Welcome to the ioBroker installation fixer!
        Script version: 2020-04-12
        You might need to enter your password a couple of times.
        Installing prerequisites (1/3)
    OK   http://archive.raspberrypi.org jessie InRelease
    OK   http://mirrordirector.raspbian.org jessie InRelease
    OK   https://deb.nodesource.com jessie InRelease
    OK   http://archive.raspberrypi.org jessie/main armhf Packages
    OK   http://archive.raspberrypi.org jessie/ui armhf Packages
    OK   http://mirrordirector.raspbian.org jessie/main armhf Packages
    OK   http://mirrordirector.raspbian.org jessie/contrib armhf Packages
    OK   https://deb.nodesource.com jessie/main Sources
    OK   https://deb.nodesource.com jessie/main armhf Packages
    OK   http://mirrordirector.raspbian.org jessie/non-free armhf Packages
    OK   http://mirrordirector.raspbian.org jessie/rpi armhf Packages
    Holen: 1 https://deb.nodesource.com jessie/main Translation-de_DE [162 B]
    Ign http://archive.raspberrypi.org jessie/main Translation-de_DE
    Holen: 2 https://deb.nodesource.com jessie/main Translation-de [162 B]
    Ign http://archive.raspberrypi.org jessie/main Translation-en
    Holen: 3 https://deb.nodesource.com jessie/main Translation-en [162 B]
    Ign http://archive.raspberrypi.org jessie/ui Translation-de_DE
    Holen: 4 https://deb.nodesource.com jessie/main Translation-de_DE [162 B]
    Ign http://archive.raspberrypi.org jessie/ui Translation-en
    Holen: 5 https://deb.nodesource.com jessie/main Translation-de [162 B]
    Holen: 6 https://deb.nodesource.com jessie/main Translation-en [162 B]
    Holen: 7 https://deb.nodesource.com jessie/main Translation-de_DE [162 B]
    Holen: 8 https://deb.nodesource.com jessie/main Translation-de [162 B]
    Holen: 9 https://deb.nodesource.com jessie/main Translation-en [162 B]
    Holen: 10 https://deb.nodesource.com jessie/main Translation-de_DE [162 B]
    Holen: 11 https://deb.nodesource.com jessie/main Translation-de [162 B]
    Holen: 12 https://deb.nodesource.com jessie/main Translation-en [162 B]
    Holen: 13 https://deb.nodesource.com jessie/main Translation-de_DE [162 B]
    Ign https://deb.nodesource.com jessie/main Translation-de_DE
    Holen: 14 https://deb.nodesource.com jessie/main Translation-de [162 B]
    Holen: 15 https://deb.nodesource.com jessie/main Translation-en [162 B]
    Ign https://deb.nodesource.com jessie/main Translation-en
    Ign http://mirrordirector.raspbian.org jessie/contrib Translation-de_DE
    Ign http://mirrordirector.raspbian.org jessie/contrib Translation-en
    Ign http://mirrordirector.raspbian.org jessie/main Translation-de_DE
    Ign http://mirrordirector.raspbian.org jessie/main Translation-en
    Ign http://mirrordirector.raspbian.org jessie/non-free Translation-de_DE
    Ign http://mirrordirector.raspbian.org jessie/non-free Translation-en
    Ign http://mirrordirector.raspbian.org jessie/rpi Translation-de_DE
    Ign http://mirrordirector.raspbian.org jessie/rpi Translation-en
    Installed gcc-c++
    Installed python-dev
        Checking ioBroker user and directory permissions (2/3)
        Checking autostart (3/3)
    Enabling autostart...
    Autostart enabled!
        Your installation was fixed successfully
        Run iobroker start to start ioBroker again!
    pi@iobroker-garage-gross:/opt/iobroker $ iobroker start
    pi@iobroker-garage-gross:/opt/iobroker $ node -v
    v10.20.1
    pi@iobroker-garage-gross:/opt/iobroker $ npm -v
    6.14.4
    Dann versucht JS Controller zu installieren:
    pi@iobroker-garage-gross:/opt/iobroker $ sudo npm install ioBroker/ioBroker.js-controller
    npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
    > iobroker.js-controller@3.0.13 preinstall /opt/iobroker/node_modules/iobroker.js-controller
    > node lib/preinstallCheck.js
    NPM version: 6.14.4
    > iobroker.js-controller@3.0.13 install /opt/iobroker/node_modules/iobroker.js-controller
    > node iobroker.js setup first
    Cannot delete file. Not critical: Error: EACCES: permission denied, unlink '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/../../_service_iobroker.bat'
    Cannot delete file. Not critical: Error: EACCES: permission denied, unlink '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/../../iobroker.bat'
    Cannot delete file. Not critical: Error: EACCES: permission denied, unlink '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/../../iob.bat'
    fs.js:114
        throw err;
    Error: EACCES: permission denied, mkdir '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/../../tmp'
        at Object.mkdirSync (fs.js:757:3)
        at Setup.setup (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupSetup.js:692:16)
        at processCommand (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:258:23)
        at Object.module.exports.execute (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:2583:5)
        at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js:1:24)
        at Module._compile (internal/modules/cjs/loader.js:778:30)
        at Object.Module._extensions..js (internal/modules/cjs/loader.js:789:10)
        at Module.load (internal/modules/cjs/loader.js:653:32)
        at tryModuleLoad (internal/modules/cjs/loader.js:593:12)
        at Function.Module._load (internal/modules/cjs/loader.js:585:3)
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.1.2 (node_modules/chokidar/node_modules/fsevents):
    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
    npm ERR! code ELIFECYCLE
    npm ERR! errno 1
    npm ERR! iobroker.js-controller@3.0.13 install: `node iobroker.js setup first`
    npm ERR! Exit status 1
    npm ERR!
    npm ERR! Failed at the iobroker.js-controller@3.0.13 install script.
    npm ERR!     /root/.npm/_logs/2020-04-20T15_24_19_570Z-debug.log
    Erfolgreich installiert wieder mit festgelegtem User:
    pi@iobroker-garage-gross:/opt/iobroker $ sudo -H -u iobroker npm install ioBroker/ioBroker.js-controller
    NPM version: 6.14.4
    object system.certificates updated
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.1.2 (node_modules/fsevents):
    + iobroker.js-controller@3.0.13
    added 67 packages from 84 contributors in 152.394s
    7 packages are looking for funding
      run `npm fund` for details
    • G Offline
      guergen
      #333
      Ich kann machen was ich will, der tr064-Adapter spielt nicht mit:
      tr-064.0	2020-04-20 17:55:23.460	error	(2058) Password error: Please re-enter the password in Admin. Stopping
      tr-064.0	2020-04-20 17:55:23.425	info	(2058) starting. Version 4.0.0 in /opt/iobroker/node_modules/iobroker.tr-064, node: v10.20.1, js-controller: 3.0.13
      Ich habe 2 Adapter, wo ich das Fritzbox-Passwort eingeben muss, einmal den TR064 und FB-Presence.
      Beim Ersten kann ich machen was ich will, er nimmt das neue Passwort nicht.
      FB-Presence nimmt das selbe Passwort ohne Murren.
      JS 3.0.13
      Admin 4.0.9
      TR064 4.0.0
      Auch diverse Adapter geben mir folgendes im Log aus:
      2020-04-20 16:42:54.438 - warn: maxcul.0 (9240) adapter.objects.getObjectView is deprecated, and will be removed in the future. Please use adapter.getObjectView/Async. Report this to Developer!
      2020-04-20 16:42:54.464 - warn: maxcul.0 (9240) adapter.objects.getObjectView is deprecated, and will be removed in the future. Please use adapter.getObjectView/Async. Report this to Developer!
      2020-04-20 16:37:14.377 - warn: upnp.0 (11152) State value to set is invalid for upnp.0.FRITZ!Box_7590_(UI).fritzbox.Alive: The state property "expire" has the wrong type "string" (should be "number")!
      2020-04-20 16:37:14.377 - warn: upnp.0 (11152) This value will not be set in future versions. Please report this to the developer.
      2020-04-20 16:27:05.260 - warn: upnp.0 (11152) State value to set is invalid for upnp.0.Repeater310.fritzbox.Alive: The state property "expire" has the wrong type "string" (should be "number")!
      2020-04-20 16:27:05.261 - warn: upnp.0 (11152) This value will not be set in future versions. Please report this to the developer.
      wendy2702W Michael SauerM 2 Antworten Letzte Antwort
      • G guergen
        JS 3.0.13
        Admin 4.0.9
        TR064 4.0.0
        wendy2702W Online
        wendy2702W Online
        #334
        @guergen sagte in Beta Test js-controller 3.0.x auf GitHub:
        TR064 4.0.0
        Tipp mal was "falsches" ein, speichern und schließen und dann das richtige.
        G 1 Antwort Letzte Antwort
        • wendy2702W wendy2702
          TR064 4.0.0
          guergen
          #335
          @wendy2702 Ich habe mir schon die Finger wund getippt.
          Bin grade schon auf Admin 4.0.5 runter nix...
          • G Offline
            guergen
            #336
            Versuche grade ein Rollback auf die 2.2.9 oder 2.2.10....
            Wie heisst denn der korrekte Befehl?
            npm install iobroker.js-controller@version
            Was muss ich anstelle von "@Version" eingeben?
            2.2.9, 2.2.10, 2.2.x.... alles schon versucht
            • wendy2702W Online
              wendy2702W Online
              #337
              Logfile?
              So gemacht!?
              npm install iobroker.js-controller@2.2.9
                Logfile?
                So gemacht!?
                guergen
                #338
                @wendy2702
                Hier mit 2.2.9:
                 npm install ioBroker.js-controller@2.2.9                           npm ERR! code E404
                npm ERR! 404 Not Found - GET https://registry.npmjs.org/ioBroker.js-controller -                     Not found
                npm ERR! 404
                npm ERR! 404  'ioBroker.js-controller@2.2.9' is not in the npm registry.
                npm ERR! 404 Your package name is not valid, because
                npm ERR! 404  1. name can no longer contain capital letters
                npm ERR! 404
                npm ERR! 404 Note that you can also install from a
                npm ERR! 404 tarball, folder, http url, or git url.
                Das Selbe mit 2.2.10:
                iobroker@iobroker:/opt/iobroker$ npm install ioBroker.js-controller@2.2.10
                npm ERR! code E404
                npm ERR! 404
                npm ERR! 404  'ioBroker.js-controller@2.2.10' is not in the npm registry.
                npm ERR! 404
                Hier ein Log:
                0 info it worked if it ends with ok
                1 verbose cli [ '/usr/bin/node',
                1 verbose cli   '/usr/bin/npm',
                1 verbose cli   'install',
                1 verbose cli   'ioBroker.js-controller@2.2.9' ]
                2 info using npm@6.14.4
                3 info using node@v10.20.1
                4 verbose npm-session b1d2b8998bed8472
                5 silly install loadCurrentTree
                6 silly install readLocalPackageData
                7 http fetch GET 404 https://registry.npmjs.org/ioBroker.js-controller 1058ms
                8 http fetch GET 404 https://registry.npmjs.org/ioBroker.js-controller 778ms
                9 silly fetchPackageMetaData error for ioBroker.js-controller@2.2.9 404 Not Found - GET https://registry.npmjs.org/ioBroker.js-controller - Not found
                10 timing stage:rollbackFailedOptional Completed in 1ms
                11 timing stage:runTopLevelLifecycles Completed in 4482ms
                12 verbose stack Error: 404 Not Found - GET https://registry.npmjs.org/ioBroker.js-controller - Not found
                12 verbose stack     at res.buffer.catch.then.body (/usr/lib/node_modules/npm/node_modules/npm-registry-fetch/check-response.js:104:15)
                12 verbose stack     at process._tickCallback (internal/process/next_tick.js:68:7)
                13 verbose statusCode 404
                14 verbose pkgid ioBroker.js-controller@2.2.9
                15 verbose cwd /opt/iobroker
                16 verbose Linux 4.19.0-6-amd64
                17 verbose argv "/usr/bin/node" "/usr/bin/npm" "install" "ioBroker.js-controller@2.2.9"
                18 verbose node v10.20.1
                19 verbose npm  v6.14.4
                20 error code E404
                21 error 404 Not Found - GET https://registry.npmjs.org/ioBroker.js-controller - Not found
                22 error 404
                23 error 404 'ioBroker.js-controller@2.2.9' is not in the npm registry.
                24 error 404 Your package name is not valid, because
                25 error 404 1. name can no longer contain capital letters
                26 error 404 Note that you can also install from a
                27 error 404 tarball, folder, http url, or git url.
                28 verbose exit [ 1, true ]
                • wendy2702W Online
                  wendy2702W Online
                  #339
                  Ich schreibe das:
                  du machst das:
                  man beachte das "B" in iobroker :-)
                    Ich schreibe das:
                    du machst das:
                    guergen
                    #340
                    @wendy2702 Wo kommt das denn her.... ich habe copy/paste gemacht.... aber von der ersten Seite ganz oben...
                    egal....
                    Der Fehler sitzt je meistend VOR dem Bildschirm...
                    • afuerhoffA Offline
                      afuerhoffA Offline
                      afuerhoff
                      #341
                      Hallo, hab auf meinem Raspberry Pi 3 Testsystem die 3.0.13 unter Node.js 10.20.0 am Laufen. Installation lief reibungslos. Im Betrieb bis jetzt keine Auffälligkeiten. Bei der Adapter-Entwicklung hat das sofort einen Benefit gebracht, da sich ein Fehler bei der Objektbezeichnung sofort im Log angezeigt wurde.
                      Danke an die Entwickler für die Super Arbeit :-)
                      • G guergen
                        egal....
                        wendy2702W Online
                        wendy2702W Online
                        #342
                        Kenne ich.... hier auch ;-)
                          guergen
                          #343
                          @wendy2702 Bin jetzt komplett wieder zurück, läuft...
                          • G guergen
                            apollon77A Online
                            apollon77A Online
                            #344
                            @guergen und du hast nach einem Admin Update auch im Browser einen richtigen harten reload gemacht? Sonst Hast du nämlich noch
                            Den alten Admin JavaScript Code im Browser und das neue greift nicht!
                              @apollon77 In Anlehnung an deinen Eröffnungspost das Ihr informiert werden wolltet. Habe noch einen zweiten Slave und Master. Soll ich etwas besonderes testen?
                              Gerade einen meiner Slaves von 2.2.9 auf 3.0.13 upgedated.
                              Erster Versuch schlug fehlt wegen fehlender Zugriffsrechte:
                              pi@pi-iobroker:/opt/iobroker $ sudo npm install ioBroker/ioBroker.js-controller
                              NPM version: 6.14.4
                              fs.js:114
                                  throw err;
                              npm ERR! errno 1
                              npm ERR!
                              npm ERR!     /root/.npm/_logs/2020-04-20T14_39_28_903Z-debug.log
                              So sieht es allerdings im Ordner aus:
                              pi@pi-iobroker:/opt/iobroker $ ls -la
                              insgesamt 84
                              drwxrwxrwx+   7 iobroker iobroker  4096 Feb 25 09:42 .
                              drwxr-xr-x    4 root     root      4096 Feb  1  2018 ..
                              drwxrwxrwx+   2 iobroker iobroker  4096 Apr 20 16:16 backups
                              drwxrwxrwx+   2 iobroker iobroker  4096 Feb 15  2017 etc
                              -rwxrwxrwx+   1 iobroker iobroker   104 Mär  4  2019 INSTALLER_INFO.txt
                              -rwxrwxrwx+   1 iobroker iobroker   297 Feb 15  2017 install.sh
                              lrwxrwxrwx    1 iobroker iobroker    22 Mär  4  2019 iob -> /opt/iobroker/iobroker
                              -rwxrwxrwx+   1 iobroker iobroker   226 Mär  4  2019 iobroker
                              drwxrwxrwx+   4 iobroker iobroker  4096 Mai 14  2018 iobroker-data
                              -rwxrwxrwx+   1 iobroker iobroker    92 Mär  4  2019 killall.sh
                              drwxrwxrwx+   2 iobroker iobroker  4096 Apr 20 16:33 log
                              drwxrwxrwx+ 486 iobroker iobroker 20480 Apr 20 16:39 node_modules
                              -rwxrwxrwx+   1 iobroker iobroker    19 Mär  7  2019 .npmrc
                              -rwxrwxrwx+   1 iobroker iobroker   302 Feb 25 09:42 package.json
                              -rwxrwxrwx+   1 iobroker iobroker  5728 Apr 20 16:39 reinstall.js
                              -rwxrwxrwx+   1 iobroker iobroker   709 Mär  4  2019 reinstall.sh
                              Das sagt der Fixer:
                              pi@pi-iobroker:/opt/iobroker $ sudo curl -sL https://iobroker.net/fix.sh | bash -
                              library: loaded
                              ioBroker is not installed in /opt/iobroker! Cannot fix anything...
                              Das dann mit festgelegtem User:
                              pi@pi-iobroker:/opt/iobroker $ sudo -H -u iobroker npm install ioBroker/ioBroker.js-controller
                              NPM version: 6.14.4
                              added 69 packages from 61 contributors and audited 1552 packages in 150.66s
                              6 packages are looking for funding
                              found 61 vulnerabilities (23 low, 13 moderate, 25 high)
                                run `npm audit fix` to fix them, or `npm audit` for details
                                 │      New patch version of npm available! 6.13.4 → 6.13.7       │
                                 │   Changelog: https://github.com/npm/cli/releases/tag/v6.13.7   │
                                 │               Run npm install -g npm to update!                │
                              pi@pi-iobroker:/opt/iobroker $ ^V
                              Noch etwas, von woher bekommt Ihr die Info wegen NPM Patch?
                              Wenn ich das NPM Update mache habe ich danach die Version "6.14.4" installiert:
                              sudo npm install -g npm
                              /usr/bin/npm -> /usr/lib/node_modules/npm/bin/npm-cli.js
                              /usr/bin/npx -> /usr/lib/node_modules/npm/bin/npx-cli.js
                              + npm@6.14.4
                              updated 1 package in 40.604s
                              pi@pi-iobroker:/opt/iobroker $ node -v
                              v10.20.1
                              pi@pi-iobroker:/opt/iobroker $ npm -v
                              6.14.4
                              apollon77A Online
                              apollon77A Online
                              #345
                              @wendy2702 Also am Ende hast Du dir einiges davon scheinbar selbst eingebrockt ;-) Ganz oben steht das Du "sudo" genutzt hast für den install. Steht so aber nicht in der Anleitung!! Damit sind alle die Fehler und ggf andere Probleme die dich zu der Fixing-Arie geführt haben wohl darauf basierend! Tja, was so 4 blöde Buchstaben so ausmachen ;-)
                              ABer hast es ja dann über 5 Ecken hinbekommen.
                              Und die NPM patch-Info gibt NPM selbst aus, kommt nicht von uns
                                library: loaded
                                Installed gcc-c++
                                Autostart enabled!
                                v10.20.1
                                6.14.4
                                NPM version: 6.14.4
                                fs.js:114
                                    throw err;
                                npm ERR! errno 1
                                npm ERR!
                                NPM version: 6.14.4
                                apollon77A Online
                                apollon77A Online
                                #346
                                @wendy2702 AUch hier wieder ... wo hast Du das sudo her? ;-) Wenn Du mit einem System Arbeitest welches mit dem Installer bzw Fixer erstellt ist das Bitte FINGER WEG VON SUDO! ... BÖÖÖÖÖÖSE ;-)
                                Am besten jetzt den Fixer nochmal auf beiden Systemen hinterher um ggf komisches nochmal final geradezubiegen
                                harrymH wendy2702W 2 Antworten Letzte Antwort
                                • apollon77A apollon77
                                  harrymH Offline
                                  harrymH Offline
                                  harrym
                                  #347
                                  @apollon77 🤣 aber nicht immer is sudo böse
                                  ASRock FM2A88X-ITX+ mit 32GB RAM, 128GB SSD mit Proxmox, 3x1 TB SSD als RAID mit CT und VMs.
                                  • apollon77A Online
                                    apollon77A Online
                                    #348
                                    Ansonsten bedanke ich mich nochmals bei allen hier und wir verlagern die weiteren Themen jetzt in den Latest Thread --> https://forum.iobroker.net/topic/32481/js-controller-3-0-jetzt-im-latest
                                      guergen
                                      #349
                                      @apollon77 ja, hatte ich gemacht.
                                        wendy2702W Online
                                        wendy2702W Online
                                        #350
                                        @apollon77 sagte in Beta Test js-controller 3.0.x auf GitHub:
                                        Hm,
                                        so böse kann es nicht sein wenn es am Ende mit den 4 Buchstaben funktioniert hat aber festgelegtem User.
                                        Aber hast recht, das "sudo" beim ersten Versuch steht nicht in der Anleitung. ..... scheiß macht der Gewohnheit bevor der Fixer vor Ewigkeiten gelaufen ist.
                                        • wendy2702W Online
                                          wendy2702W Online
                                          #351
                                          Gerade noch das hier im Upgrade log gefunden:
                                          The following notifications happened during sync:
                                          • Ignoring Directory "_temp" because officially not created as meta object. Please remove directory!
                                          • Ignoring Directory "sayit.0" because officially not created as meta object. Please remove directory!
                                          • Ignoring Directory "sayit.1" because officially not created as meta object. Please remove directory!
                                          Das _temp ist von mir erzeugt aber die beiden sayit Ordner habe ich nicht selber erzeugt:
