  4. Test Adapter fb-checkpresence v1.0.x
fritzboxsoapavmtr-064
248 Beiträge 23 Kommentatoren 53.4k Aufrufe 25 Beobachtet
    mameier1234
    mal wieder was neues...
    meine Tochter hat ein neues Handy, ich habe das Gerät ausgewählt und jetzt kommt im Log..:
    020-04-16 11:09:40.858	warn	(856) dublicate fritzbox device item. Please correct the hostname in the fritzbox settings for the device -> Vxxxxr 88:A4:79:DD:40:5B
    fb-checkpresence.0	2020-04-16 11:09:40.858	warn	(856) dublicate fritzbox device item. Please correct the hostname in the fritzbox settings for the device -> Vxxxxx 40:9C:28:03:F2:6C
    fb-checkpresence.0	2020-04-16 11:09:40.857	warn	(856) dublicate fritzbox device item. Please correct the hostname in the fritzbox settings for the device -> SonosZP 94:9F:3E:C2:67:CF
    fb-checkpresence.0	2020-04-16 11:09:40.857	warn	(856) dublicate fritzbox device item. Please correct the hostname in the fritzbox settings for the device -> SonosZP B8:E9:37:44:A6:B6
    fb-checkpresence.0	2020-04-16 11:09:40.856	warn	(856) dublicate fritzbox device item. Please correct the hostname in the fritzbox settings for the device -> SonosZP 94:9F:3E:77:D4:9A
    fb-checkpresence.0	2020-04-16 11:09:40.856	warn	(856) dublicate fritzbox device item. Please correct the hostname in the fritzbox settings for the device -> SonosZP 94:9F:3E:72:3B:B8
    fb-checkpresence.0	2020-04-16 11:09:40.856	warn	(856) dublicate fritzbox device item. Please correct the hostname in the fritzbox settings for the device -> SonosZP 94:9F:3E:70:5D:16
    fb-checkpresence.0	2020-04-16 11:09:40.855	warn	(856) dublicate fritzbox device item. Please correct the hostname in the fritzbox settings for the device -> SonosZP 94:9F:3E:90:51:46
    fb-checkpresence.0	2020-04-16 11:09:40.855	warn	(856) dublicate fritzbox device item. Please correct the hostname in the fritzbox settings for the device -> SonosZP 78:28:CA:BB:DC:56
    fb-checkpresence.0	2020-04-16 11:09:40.855	warn	(856) dublicate fritzbox device item. Please correct the hostname in the fritzbox settings for the device -> SonosZP 78:28:CA:91:26:06
    fb-checkpresence.0	2020-04-16 11:09:40.854	warn	(856) dublicate fritzbox device item. Please correct the hostname in the fritzbox settings for the device -> SonosZP 94:9F:3E:70:61:B4
    fb-checkpresence.0	2020-04-16 11:09:40.850	warn	(856) dublicate fritzbox device item. Please correct the hostname in the fritzbox settings for the device -> Galaxy-S8 44:91:60:7D:72:06
    fb-checkpresence.0	2020-04-16 11:09:40.850	warn	(856) dublicate fritzbox device item. Please correct the hostname in the fritzbox settings for the device -> Galaxy-S8 30:07:4D:94:24:97
    Grüße,
    Martin
    afuerhoffA 2 Antworten Letzte Antwort
    • M mameier1234
      afuerhoffA Offline
      afuerhoffA Offline
      afuerhoff
      #66
      @mameier1234
      Das ist eine Warnung, dass es in der Fritzbox doppelte Devicenamen für unterschiedliche Mac-Adressen gibt. Damit können die Fb-devices nicht korrekt als Objekt angelegt werden, da dafür der Name benutzt wird.
      • afuerhoffA Offline
        afuerhoffA Offline
        afuerhoff
        #67
        Hallo, die Version 1.0.1 ist jetzt im Latest Repository verfügbar.
        Homer.J.H 1 Antwort Letzte Antwort
        • afuerhoffA afuerhoff
          Homer.J.H Offline
          Homer.J.H Offline
          Homer.J.
          schrieb am zuletzt editiert von Homer.J.
          #68
          @afuerhoff Morgen seid dem Update kann ich keine Änderungen mehr Speichern, ich wollte die Familienliste neu anlegen ist nicht möglich.
          Eigentlich nur wegen dieser Warnung.
          Steht ja schon 2 post drüber.
          fb-checkpresence.0	2020-04-18 07:49:49.755	warn	(15244) dublicate fritzbox device item. Please correct the hostname in the fritzbox settings for the device -> iobroker
          • Homer.J.H Homer.J.
            afuerhoffA Offline
            afuerhoffA Offline
            afuerhoff
            schrieb am zuletzt editiert von afuerhoff
            #69
            @Homer-J
            Die Warnung sagt ja nur wie oben beschrieben, dass es doppelte Devicenamen in der Fritzbox gibt. Damit können die Fb-Devices nicht eindeutig adressiert werden. Kannst du den Fehler mit dem Speichern detaillierter beschreiben. Die Warnmeldung hat damit gar nichts zu tun.
            Homer.J.H ? 2 Antworten Letzte Antwort
              @Homer-J
              Homer.J.H Offline
              Homer.J.H Offline
              Homer.J.
              #70
              @afuerhoff wenn ich z.B jemanden Lösche und das Speichern möchte geht nicht. der Speicherbutton reagiert nicht, bei anderen Adaptern habe ich mal probehalber probiert dort geht es.
              Ist mir deshalb aufgefallen weil ich durch die warnmeldung die Benutzer neu anlegen wollte.
                @Homer-J
                #71
                @afuerhoff Hi, in der 1.0.1 geht das speichern nicht mehr, ich kann zwar Hinzufügen oder löschen, aber nicht mehr speichern.
                Adapter FB Presence 1.0.1 (gerade von Git geladen), iobroker js-controller 3.0.13, und Node 12.6.
                  afuerhoffA Offline
                  afuerhoffA Offline
                  afuerhoff
                  #72
                  @ilovegym
                  Kannst Du mal direkt über Admin installieren. Ist das Verhalten dann genauso? Bei mir funktioniert das Löschen und Speichern ohne Probleme.
                    mameier1234
                    #73
                    ich habe eine neue Person aus dem Gast-Netz hinzugefügt..
                    Klappt grundsätzlich, aber:
                    fb-checkpresence.0	2020-04-18 15:18:12.124	info	(856) History from Pxxxxx not enabled
                    Der Datenpunkt bleibt leer...
                    Grüße,
                    Martin
                    • M mameier1234
                      afuerhoffA Offline
                      afuerhoffA Offline
                      afuerhoff
                      #74
                      @mameier1234
                      Hallo, ich habe auch einen Gast hinzugefügt, der aber nicht online ist. Er ist auch nicht im normalen Netz angemeldet gewesen. Bei mir kommt ein Fehler von der Fritzbox,
                      hier mal ein Auszug:
                      <errorDescription>NoSuchEntryInArray</errorDescription>
                      Das liegt aber daran, dass in der Fritzbox der Eintrag mal angezeigt wird und mal nicht. Wahrscheinlich wurde die Abfrage genau in so einem Moment gestartet.
                      Jedenfalls ist das bei mir so. Kann das Verhalten vielleicht jemand bestätigen?
                      Die History wurde bei mir auch nicht eingeschaltet. Das kann aber mit dem oberen Verhalten zusammenhängen.
                      Edit: Im Datenpunkt wird auch kein Name, Typ und Rolle angezeigt. Unter presence des Familienmitglieds wird aber false angezeigt, was richtig ist.
                      • M mameier1234
                        afuerhoffA Offline
                        afuerhoffA Offline
                        afuerhoff
                        #75
                        @mameier1234 sagte in Test Adapter fb-checkpresence v1.0.x:
                        Hallo, hast du die doppelten Namen mal in der Fritzbox umbenannt?
                          afuerhoffA Offline
                          afuerhoffA Offline
                          afuerhoff
                          #76
                          @Homer-J sagte in Test Adapter fb-checkpresence v1.0.x:
                          Welche Versionen vom js-controller und Node.js hast du installiert?
                            afuerhoffA Offline
                            afuerhoffA Offline
                            afuerhoff
                            #77
                            @ilovegym sagte in Test Adapter fb-checkpresence v1.0.x:
                            Lief die Vorgänger Version auch schon mit js-controller 3.x und Node.js 12.x?
                              @ilovegym
                              #78
                              @afuerhoff sagte in Test Adapter fb-checkpresence v1.0.x:
                              @ilovegym
                              yes, das wars, jetzt gehts wieder! Admin 4.0.8 inzwischen, jetzt läuft das wieder ohne Probleme.
                              Hab auch duplicate Hostnames in der Fritzbox, ist wohl ein Bug im FritzOs, normalsollte das garnicht vorkommen...
                              aber das kann man ja ändern...
                                Homer.J.H Offline
                                Homer.J.H Offline
                                Homer.J.
                                #79
                                @afuerhoff lag bei mir auch an der Admin Version jetzt mit der 4.0.8 geht es wieder.
                                  mameier1234
                                  #80
                                  @afuerhoff ich habe den alten Namen gelöscht. Das Problem ist weg
                                  Grüße,
                                  Martin
                                  • JB_SullivanJ Offline
                                    JB_Sullivan
                                    #81
                                    Ich habe gerade die Update Orgie hier auf ioB hinter mir.
                                    fb-ckpresence meldet im LOG folgenden Fehler:
                                    fb-checkpresence.0	2020-04-19 13:17:48.274	error	(9040) Fb.getDeviceList Error: timeout of 2000ms exceeded
                                    Hatte ich vorher nie - gibt es dazu ggf. schon irgend welche Erkentnisse?
                                    • JB_SullivanJ JB_Sullivan
                                      afuerhoffA Offline
                                      afuerhoffA Offline
                                      afuerhoff
                                      #82
                                      @JB_Sullivan sagte in Test Adapter fb-checkpresence v1.0.x:
                                      Der Fehler kam bisher, wenn mehrere Instanzen und Adapter auf die Fritzbox zugegriffen haben. Ist das bei dir auch der Fall? Das timeout kommt aus der Fritzbox.
                                      Kommt der Fehler ständig oder einmalige Angelegenheit?
                                      GarfonsoG 1 Antwort Letzte Antwort
                                        GarfonsoG Offline
                                        GarfonsoG Offline
                                        Garfonso
                                        #83
                                        @afuerhoff
                                        Bei mir kommt der Fehler auch hin und wieder. Meine Fritzbox ist aber auch grundsätzlich sehr lahm (ist eine 6390 Cable). Warum machst du den Timeout da so kurz auf 2 Sekunden?
                                        Ultimativer Lovelace Leitfaden: https://forum.iobroker.net/topic/35937/der-ultimative-iobroker-lovelace-leitfaden-dokumentation
                                        Lovelace UI Beispiele: https://forum.iobroker.net/topic/35950/zeigt-her-eure-lovelace-visualisierung
                                        • GarfonsoG Garfonso
                                          @afuerhoff
                                          afuerhoffA Offline
                                          afuerhoffA Offline
                                          afuerhoff
                                          #84
                                          @Garfonso sagte in Test Adapter fb-checkpresence v1.0.x:
                                          Ich habe gerade nochmal nachgesehen. Es gibt noch eine Stelle im Code, wo 2s eingestellt sind.
                                          Asche auf mein Haupt. Hab ich übersehen. Wird im nächsten Release hochgesetzt.
