  4. FireTv 1.0.0 testen
FireTv 1.0.0 testen
firetvamazontest
82 Beiträge 21 Kommentatoren 13.6k Aufrufe 30 Beobachtet
  • sigi234S sigi234
    @foxriver76
    firetv.0	2020-04-09 16:48:50.917	info	(16056) 192.168.178.57: ADB version: 39, Android Version: , API Level:
    firetv.0	2020-04-09 16:48:50.915	error	Otherwise check for a confirmation dialog on your device.'
    firetv.0	2020-04-09 16:48:50.915	error	Try 'adb kill-server' if that seems wrong.
    firetv.0	2020-04-09 16:48:50.915	error	This adb server's $ADB_VENDOR_KEYS is not set
    firetv.0	2020-04-09 16:48:50.915	error	(16056) ID: 192.168.178.57 Error=Failure: 'device unauthorized.
    firetv.0	2020-04-09 16:48:50.913	error	Otherwise check for a confirmation dialog on your device.'
    firetv.0	2020-04-09 16:48:50.913	error	Try 'adb kill-server' if that seems wrong.
    firetv.0	2020-04-09 16:48:50.913	error	This adb server's $ADB_VENDOR_KEYS is not set
    firetv.0	2020-04-09 16:48:50.913	error	(16056) ID: 192.168.178.57 Error=Failure: 'device unauthorized.
    firetv.0	2020-04-09 16:48:50.911	error	Otherwise check for a confirmation dialog on your device.'
    firetv.0	2020-04-09 16:48:50.911	error	Try 'adb kill-server' if that seems wrong.
    firetv.0	2020-04-09 16:48:50.911	error	This adb server's $ADB_VENDOR_KEYS is not set
    firetv.0	2020-04-09 16:48:50.911	error	(16056) ID: 192.168.178.57 Error=Failure: 'device unauthorized.
    firetv.0	2020-04-09 16:48:50.910	debug	(16056) Connected to 192.168.178.57 id=192.168.178.57:5555
    firetv.0	2020-04-09 16:48:50.865	debug	(16056) Device 192.168.178.57:5555 + type=unauthorized was plugged in
    firetv.0	2020-04-09 16:48:50.796	debug	(16056) FireTV: 192.168.178.57
    foxriver76F Offline
    foxriver76F Offline
    foxriver76
    schrieb am zuletzt editiert von foxriver76
    @sigi234 hm und das ist mit alter Adapter Version nicht? Konfig Seite passt?
    An der ganzen Geschichte sollte sich nix geändert haben..
    Videotutorials & mehr
      darkiop
      schrieb am zuletzt editiert von darkiop
      Wollte dem 1.0.0 auch mal wieder ne Chance geben :)
      adb liegt unter /usr/bin - somit also auch in $PATH. Installiert über android-tools-adb (Debian).
      Der FireTV-Stick ist per ping erreichbar.
      In den Einstellungen des Adapters hatte ich trotzdem mal manuell den Pfad von ADB geändert - das wird beim speichern aber nicht übernommen.
      Mir ist es bisher nicht gelungen den Stick zu verbinden. Auch im mit Log = debug ist der Adapter nicht gerade gesprächig:
      error: firetv.0 (2364) adb executable not found. undefined
      Jemand ne Idee was ich noch versuchen könnte? Oder stelle ich mich gerade etwas blöd dran und verstehe die Logik des etwas angestaubten Admins nicht? :)
      Interessanterweise ist der Adapter die ganze Zeit 'grün' :)
      Proxmox-ioBroker-Redis-HA Doku: https://forum.iobroker.net/topic/47478/dokumentation-einer-proxmox-iobroker-redis-ha-umgebung
      • foxriver76F foxriver76
        sigi234S Online
        sigi234S Online
        @foxriver76 sagte in FireTv 1.0.0 testen:
        Alter hatte mal funktioniert, in letzter Zeit aber nicht mehr.
        • D darkiop
          sigi234S Online
          sigi234S Online
          @darkiop sagte in FireTv 1.0.0 testen:
          Bei mir auch.
          • foxriver76F Offline
            foxriver76F Offline
            foxriver76
            Puh für den ‘kreativen’ Code übernehme ich allgemein keine Verantwortung. Es gibt kein info.connection State, somit immer grün solange der Adapter nicht crashed oder aus ist.
            D ? 2 Antworten Letzte Antwort
              darkiop
              Passt schon ;)
              @sigi234 Läuft der Rest bei dir? Kannst du eine IP eintragen und über adb verbinden?
                @foxriver76 ich glaub der Adapter mag noch ausführlich getestet werden, die nächsten Tage-Wochen....
                hier zickt er auch gerade mal rum. von wegen device offline..
                Was er nicht macht:
                adb server starten
                adb connect device
                das mach ich vorher mit nem script, wenn ich iobroker starte...
                übrigens war in meiner prod. Installation da immer ein sudo adb notwendig!
                • D darkiop
                  Passt schon ;)
                  sigi234S Online
                  sigi234S Online
                  (9800) can not connect to 192.168.178.41 Error=unable to connect to 192.168.178.41:5555: cannot connect to 192.168.178.41:5555: Es konnte keine Verbindung hergestellt werden, da der Zielcomputer die
                  Hm, es hatte ja schon mal funktioniert. Ich weis noch das ich viel experimentiert habe, denke es liegt an der Abrage zum TV. Normalerweise solle da eine Verbindunsmeldung vom TV kommen ob ich den Zugriff erlaube.
                    Was er nicht macht:
                    adb server starten
                    adb connect device
                    foxriver76F Offline
                    foxriver76F Offline
                    foxriver76
                    @ilovegym hm ja insbesondere geht es mir darum, dass er mindestens so läuft wie vorher und js-c 3 kompatibel ist, alles was schon immer im Adapter schief lief, sollte sich mal einer annehmen der einen FireTV selbst hat.
                    Also wenn ich jetzt irgendwas kaputt gemacht habe was mit der vorherigen Version ging bitte hervorheben, sonst Issue damit sich möglichst bald mal jemand darum kümmert.
                      sigi234S Online
                      sigi234S Online
                      Nein, er ging schon einige Wochen bei mir nicht mehr.
                        darkiop
                        Alternativ könnte ja auch "alles" über ein Skript und exec adb machen ...
                        Mir geht es eigentlich nur um starten/beenden von Apps und ggf. reboot des Sticks.
                          darkiop
                          Ok, ich werde das ganze wirklich über ein Skript aufbauen.
                          Hier eine Liste mit den intents zum starten/stoppen diverser Apps:
                          https://gist.github.com/mcfrojd/9e6875e1db5c089b1e3ddeb7dba0f304
                          Das funktioniert von der Shell auch ohne Probleme.
                          Hier noch ein paar weitere Befehle aus meinen Notizen:
                          apt-get install android-tools-adb
                          adb start-server
                          adb kill-server
                          adb connect
                          adb disconnect
                          adb reboot
                          adb shell pm list packages -f
                          adb shell am start -a android.intent.action.VIEW -d -n com.spotify.tv.android/.SpotifyTVActivity
                          adb shell am start -a android.intent.action.VIEW -d -n org.xbmc.kodi/.Splash
                          adb am force-stop org.xbmc.kodi
                            darkiop
                            Erster Test erfolgreich - also als Alternative eine Option:
                            • harrymH Offline
                              harrymH Offline
                              harrym
                              hmmmm .seltsam .... ich kann apps direkt via Objekt vom Adapter starten, stoppen und auch alles andere auch. Ich habe den alten Adapter gelöscht und den neuen via Git installiert. ADB Pfad eingetragen, FireTV 4K hinzugefügt und alles war ok.
                              ASRock FM2A88X-ITX+ mit 32GB RAM, 128GB SSD mit Proxmox, 3x1 TB SSD als RAID mit CT und VMs.
                              • harrymH harrym
                                sigi234S Online
                                sigi234S Online
                                @harrym
                                Wie schaut der Pfad aus? Hast du Windows?
                                harrymH 2 Antworten Letzte Antwort
                                • sigi234S sigi234
                                  @harrym
                                  harrymH Offline
                                  harrymH Offline
                                  harrym
                                  @sigi234 ne. ich hab linux am laufen.
                                  /usr/lib/android-sdk/platform-tools/adb
                                  • sigi234S sigi234
                                    @harrym
                                    harrymH Offline
                                    harrymH Offline
                                    harrym
                                    @sigi234 eventuell den FireTV mal resetten/updaten und die Entwicklereinstellungen vom Stick checken ?
                                      foxriver76F Offline
                                      foxriver76
                                      Bitte auch mal nicht js-c 3 Tester testen ob es tut. ;-)
                                      • harrymH harrym
                                        sigi234S Online
                                        sigi234S Online
                                        @harrym sagte in FireTv 1.0.0 testen:
                                        firetv.0	2020-04-12 20:21:42.027	debug	(12848) system.adapter.admin.0: logging true
                                        firetv.0	2020-04-12 20:19:42.661	debug	(12848) system.adapter.admin.0: logging false
                                        firetv.0	2020-04-12 20:18:04.882	error	(12848) can not connect to 192.168.178.54 Error=unable to connect to 192.168.178.54:5555: cannot connect to 192.168.178.54:5555: Es konnte keine Verbindung hergestellt werden, da der Zielcomputer die
                                        firetv.0	2020-04-12 20:18:02.864	info	(12848) 192.168.178.57: ADB version: 39, Android Version: , API Level:
                                        firetv.0	2020-04-12 20:18:02.863	error	(12848) ID: 192.168.178.57 Error=Failure: 'device '192.168.178.57:5555' not found'
                                        firetv.0	2020-04-12 20:18:02.860	error	(12848) ID: 192.168.178.57 Error=Failure: 'device '192.168.178.57:5555' not found'
                                        firetv.0	2020-04-12 20:18:02.858	error	(12848) ID: 192.168.178.57 Error=Failure: 'device '192.168.178.57:5555' not found'
                                        firetv.0	2020-04-12 20:18:02.855	error	(12848) ID: 192.168.178.57 Error=Failure: 'device '192.168.178.57:5555' not found'
                                        firetv.0	2020-04-12 20:18:02.854	debug	(12848) Connected to 192.168.178.57 id=192.168.178.57:5555
                                        firetv.0	2020-04-12 20:18:02.848	debug	(12848) Device 192.168.178.57:5555 was unplugged
                                        firetv.0	2020-04-12 20:18:02.839	debug	(12848) Device 192.168.178.57:5555 + type=offline was plugged in
                                        firetv.0	2020-04-12 20:18:02.799	debug	(12848) FireTV: 192.168.178.57
                                        firetv.0	2020-04-12 20:18:02.798	debug	(12848) FireTV: 192.168.178.54
                                        firetv.0	2020-04-12 20:18:02.724	info	(12848) starting. Version 1.0.0 in C:/Program Files/iobroker/Test/node_modules/iobroker.firetv, node: v10.16.3, js-controller: 3.0.7
                                        firetv.0	2020-04-12 20:18:02.590	debug	(12848) statesDB connected
                                        firetv.0	2020-04-12 20:18:02.590	debug	(12848) States connected to redis: 127.0.0.1:9000
                                        firetv.0	2020-04-12 20:18:02.580	debug	(12848) States create System PubSub Client
                                        firetv.0	2020-04-12 20:18:02.579	debug	(12848) States create User PubSub Client
                                        firetv.0	2020-04-12 20:18:02.575	debug	(12848) Redis States: Use Redis connection: 127.0.0.1:9000
                                        firetv.0	2020-04-12 20:18:02.574	debug	(12848) objectDB connected
                                        firetv.0	2020-04-12 20:18:02.572	debug	(12848) Objects connected to redis: 127.0.0.1:9013
                                        firetv.0	2020-04-12 20:18:02.562	debug	(12848) Objects client initialize lua scripts
                                        firetv.0	2020-04-12 20:18:02.562	debug	(12848) Objects create User PubSub Client
                                        firetv.0	2020-04-12 20:18:02.562	debug	(12848) Objects create System PubSub Client
                                        firetv.0	2020-04-12 20:18:02.561	debug	(12848) Objects client ready ... initialize now
                                        firetv.0	2020-04-12 20:18:02.543	debug	(12848) Redis Objects: Use Redis connection: 127.0.0.1:9013
                                        firetv.0	2020-04-12 20:17:59.210	info	(2544) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                        firetv.0	2020-04-12 20:17:59.209	info	(2544) terminating
                                        firetv.0	2020-04-12 20:17:59.208	info	(2544) Got terminate signal TERMINATE_YOURSELF
                                          Tut auch unter 2.2.9 🙂
