  4. NPM-ERR beim Update jeglicher Adapter
nmp err adapter update
54 Beiträge 9 Kommentatoren 6.9k Aufrufe 6 Beobachtet
  • haselchenH haselchen
    @conectas
    Wie passt nun Dein Fehler zu @Joschi seinem?
    Mag ja etwas älter sein, aber in deinem Log sehe ich nix von "soef"?!
    conectasC Offline
    conectasC Offline
    conectas
    schrieb am zuletzt editiert von conectas
    @haselchen
    Das ganze LOG ist bei mir 2957 Zeilen lang
    2932 silly saveTree └── yargs@7.1.0
    2933 warn ajv-keywords@2.1.1 requires a peer of ajv@^5.0.0 but none is installed. You must install peer dependencies yourself.
    2934 warn optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.1.2 (node_modules/fsevents):
    2935 warn notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
    2936 verbose notsup SKIPPING OPTIONAL DEPENDENCY: Valid OS:    darwin
    2936 verbose notsup SKIPPING OPTIONAL DEPENDENCY: Valid Arch:  any
    2936 verbose notsup SKIPPING OPTIONAL DEPENDENCY: Actual OS:   linux
    2936 verbose notsup SKIPPING OPTIONAL DEPENDENCY: Actual Arch: arm
    2937 warn optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.4 (node_modules/osx-temperature-sensor):
    2938 warn notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
    2939 verbose notsup SKIPPING OPTIONAL DEPENDENCY: Valid OS:    darwin
    2939 verbose notsup SKIPPING OPTIONAL DEPENDENCY: Valid Arch:  any
    2939 verbose notsup SKIPPING OPTIONAL DEPENDENCY: Actual OS:   linux
    2939 verbose notsup SKIPPING OPTIONAL DEPENDENCY: Actual Arch: arm
    2940 warn optional SKIPPING OPTIONAL DEPENDENCY: fsevents@1.2.11 (node_modules/zigbee-herdsman/node_modules/fsevents):
    2941 warn notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.2.11: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
    2942 verbose notsup SKIPPING OPTIONAL DEPENDENCY: Valid OS:    darwin
    2942 verbose notsup SKIPPING OPTIONAL DEPENDENCY: Valid Arch:  any
    2942 verbose notsup SKIPPING OPTIONAL DEPENDENCY: Actual OS:   linux
    2942 verbose notsup SKIPPING OPTIONAL DEPENDENCY: Actual Arch: arm
    2943 warn optional SKIPPING OPTIONAL DEPENDENCY: fsevents@1.2.9 (node_modules/zigbee-herdsman-converters/node_modules/fsevents):
    2944 warn notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.2.9: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
    2945 verbose notsup SKIPPING OPTIONAL DEPENDENCY: Valid OS:    darwin
    2945 verbose notsup SKIPPING OPTIONAL DEPENDENCY: Valid Arch:  any
    2945 verbose notsup SKIPPING OPTIONAL DEPENDENCY: Actual OS:   linux
    2945 verbose notsup SKIPPING OPTIONAL DEPENDENCY: Actual Arch: arm
    2946 verbose stack Error: canvas@2.6.1 install: `node-pre-gyp install --fallback-to-build`
    2946 verbose stack Exit status 1
    2946 verbose stack     at EventEmitter.<anonymous> (/usr/lib/node_modules/npm/node_modules/npm-lifecycle/index.js:332:16)
    2946 verbose stack     at EventEmitter.emit (events.js:198:13)
    2946 verbose stack     at ChildProcess.<anonymous> (/usr/lib/node_modules/npm/node_modules/npm-lifecycle/lib/spawn.js:55:14)
    2946 verbose stack     at ChildProcess.emit (events.js:198:13)
    2946 verbose stack     at maybeClose (internal/child_process.js:982:16)
    2946 verbose stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:259:5)
    2947 verbose pkgid canvas@2.6.1
    2948 verbose cwd /opt/iobroker
    2949 verbose Linux 4.19.97-v7l+
    2950 verbose argv "/usr/bin/node" "/usr/bin/npm" "install" "iobroker.iot@1.4.0" "--loglevel" "error" "--prefix" "/opt/iobroker"
    2951 verbose node v10.19.0
    2952 verbose npm  v6.13.4
    2953 error code ELIFECYCLE
    2954 error errno 1
    2955 error canvas@2.6.1 install: `node-pre-gyp install --fallback-to-build`
    2955 error Exit status 1
    2956 error Failed at the canvas@2.6.1 install script.
    2956 error This is probably not a problem with npm. There is likely additional logging output above.
    2957 verbose exit [ 1, true ]
    • conectasC conectas
      @haselchen
      2954 error errno 1
      haselchenH Offline
      haselchenH Offline
      haselchen
      @conectas
      Und wo geht es in deinem Log um "soef"?
      Markiere mal die Stelle.
      Der IOT Adapter hat bereits ein Update bekommen.
      Version 1.4.1
      conectasC 1 Antwort Letzte Antwort
        @conectas
        Version 1.4.1
        conectasC Offline
        conectasC Offline
        conectas
        @haselchen
        Ich schrieb: gleiches Problem habe soef nie drauf gehabt
        Weil ich es so verstanden habe das es bei Ihm auch nicht am Ex. soef liegt...?
        Version 1.4.1
        wird mir nicht angeboten..
        • P Offline
          peterfido
          Bei mir betraf es alle möglichen Adapter.
          Peterfido
            @haselchen
            Version 1.4.1
            haselchenH Offline
            haselchenH Offline
            haselchen
            @conectas
            Eure Probleme haben nix miteinander zu tun.
            Was deinen IOT Adapter betrifft, habe ich eben schon geschrieben ,es gab ein Update.
            Probier mal die 1.4.1 ob die ohne Fehler durchgeht.
              @conectas
              conectasC Offline
              conectasC Offline
              conectas
              @haselchen sagte in NPM-ERR beim Update jeglicher Adapter:
              Kann natürlich sein .. sah nur nach dem gleichen Fehler aus...
              Bekomme ich nicht angezeigt.. ich reboote mal die Kiste.
                haselchenH Offline
                haselchenH Offline
                haselchen
                @conectas
                Verwahrungsort auf latest stellen, dann kommt die Version.
                Aber auf eigene Gefahr.
                Latest einstellen bedeutet "testen".
                  @conectas
                  conectasC Offline
                  conectasC Offline
                  conectas
                  bin bereits länger auf Latest .. kann man das neu einlesen der Liste erzwingen?
                  Wenn nicht auch okay .. IoT Assistants brauche ich eigentlich nicht.
                    haselchenH Offline
                    haselchenH Offline
                    haselchen
                    @conectas
                    Wenn du im Reiter Adapter bist , drückste auf aktualisieren (runder Pfeil)
                      @conectas
                      nützt noicht immer was - ich musste eben auch den Pfad zum Repo ändern in:
                      http://iobroker.live/repo/sources-dist-latest.json
                      haselchenH conectasC 2 Antworten Letzte Antwort
                        haselchenH Offline
                        haselchenH Offline
                        haselchen
                        @Homoran
                        Naaaanüchen... wie kann das sein?
                        2020-04-04 21:06:07.637 info Update repository "latest" under "http://download.iobroker.net/sources-dist-latest.json"
                        Funktioniert bisher immer bei mir.
                          @Homoran
                          @haselchen keine Ahnung. Geistert schon einige Zeit hier durchs Forum
                            conectasC Offline
                            conectasC Offline
                            conectas
                            @Homoran
                            kann ich bestätigen klappt NICHT ;-)
                            Kommt dann schon irgendwann.
                            Wie geschrieben iot.0 Adapter ist mir nicht wichtig.. Dachte (auf Grund des Fehlers) das bei mir auch ein generelles Problem besteht..
                            • P Offline
                              peterfido
                              Der Fehler besagt, das ein Link auf sich selbst verweist. Ich hatte beim Versuch, die Installation zu retten, den Link gelöscht und neu mit dem richtigen Ziel erstellt. Das wurde dann aber kurze Zeit später beim installieren / updaten von Adaptern wieder "versaut". Wieso, weshalb, warum kann ich nicht sagen. Es hatte definitiv mit dem Update von iobroker und einiger Komponenten wie dem js-Controller zu tun.
                              Peterfido
                                arnold
                                Hallo.
                                bei mir gleiche Problem ich kann keine Aktualisierung mache von Adaptern
                                IoT 1.3.4 auf 1.4.1
                                Telegram 1.5.4 auf 1.5.5
                                Mihome- vacuum 1.1.5 auf 2.0.7
                                haselchenH F 2 Antworten Letzte Antwort
                                • A arnold
                                  Hallo.
                                  IoT 1.3.4 auf 1.4.1
                                  haselchenH Offline
                                  haselchenH Offline
                                  haselchen
                                  @arnold
                                  Fehlerlog?
                                  • A arnold
                                    Hallo.
                                    IoT 1.3.4 auf 1.4.1
                                    frankyboy73
                                    @arnold und welche JS-Controller Version?
                                    Schöne Grüße Frank
                                      arnold
                                      • A arnold
                                        haselchenH Offline
                                        haselchenH Offline
                                        haselchen
                                        @arnold
                                        Normal sollte es kein Problem sein diese Version, trotzdem würde ich an Deiner Stelle downgraden auf 2.2.9
                                        Die 10er Version ist ausversehen online gestellt worden und ist glaube ich nur für Windows Nutzer.
                                          arnold
                                          Adapter tankerkoenig kann ich neu auch nicht instalieren
