  4. Test Coronavirus Statistics for ioBroker
adapter installationadapterentwicklungtesten
1.2k Beiträge 120 Kommentatoren 624.2k Aufrufe 94 Beobachtet
  • DutchmanD Dutchman
    Aktuelle Test Version 0.6.9
    Veröffentlichungsdatum 22-03-2021
    Github Link https://github.com/iobroker-community-adapters/ioBroker.coronavirus-statistics/blob/master/README.md
    NPM npm i ioBroker.coronavirus-statistics@latest
    Adapter to show Global Corona Virus information and current reports
    Coronavirus Live Statistics adapter for ioBroker
    There is no configuration required, after installation it will :
    • Receive global information world-wide and write it to "global_totals"
    • Create a folder for each country with all relevant information regarding COVID-19
    • Update the information every 15 minutes
    The following information is available :
    Datapoint Details
    active Amount of current infected people
    cases Amount of totally known cases
    casesPerOneMillion Amount of totally known cases per million citizen
    critical Amount of critical situation (Hospitalized)
    deaths Amount of current registered deaths
    deathsPerOneMillion Amount of current registered deaths per million citizen
    recovered Amount of totally known recovered cases
    todayCases New Cases by Today
    todayDeaths Amount of totally known people died today
    test Total number of covid-19 tests taken globally
    tests per one million counties Total number of covid-19 tests taken globally per one million
    Please be aware this adapter uses as much as possible up-to-date information but there can be an delay of several hours depending on the country's report.
    German Federal States : https://npgeo-corona-npgeo-de.hub.arcgis.com/ s
    Generic Source : https://coronavirus-19-api.herokuapp.com
    Advanced settings
    Option Description
    All Countries Get data for all countries World-Wide (Default: false)
    Continents Group total amounts by continent in seperate state (Default: false)
    Delete unused States Delete data when countries are deselected (Default: false)
    German counties Get counties data for Germany (Selected only, Default false)
    German federal states Get federal state data for Germany (Selected only, Default false)
    Get all German federal states Get federal state data for Germany (Default false)
    Get all German counties Get all counties data for Germany (Default false)
    For Germany only
    It's possible to get data for federal states (Bundesländer) and counties (Landeskreise).
    You can choose to recieve all data or just select specific regions in advanced settings.
    Please note : After activation the the adapter must run 1 time to get all federal states and counties before table loads !
    Add missing countries
    It may happen that countries are not recognized correctly because the API delivers some country names not ISO conform. In such a case you will get a warning message in the log, which looks like this
    coronavirus-statistics.0	2020-03-21 09:05:31.328	warn	(22937) Timor-Leste not found in lib! Must be added to the country name translator.
    Using the datapoint coronavirus-statistics.0.countryTranslator you can assign a country yourself. Look for the name of the corresponding country here:
    List with country names
    With the selected country name you have to create a JSON string and enter it in the datapoint coronavirus-statistics.0.countryTranslator.
    The JSON string then looks like this, for example:
    	"Cabo_Verde": "Cape Verde",
    	"Timor-Leste": "East Timor"
    As first value the name from the warning message must be taken from the log. The name of the country from the List with country names is then assigned to this.
    Changelog
    ChaotC
    ChaotC
    Chaot
    #94
    @Dutchman
    Seit heute morgen diese Warnung:
    coronavirus-statistics.0	2020-03-19 07:30:47.800	warn	(31245) State attribute definition missing for + casesPerOneMillion
    coronavirus-statistics.0	2020-03-19 07:30:47.677	warn	(31245) State attribute definition missing for + casesPerOneMillion
    coronavirus-statistics.0	2020-03-19 07:30:47.543	warn	(31245) State attribute definition missing for + casesPerOneMillion
    coronavirus-statistics.0	2020-03-19 07:30:47.362	warn	(31245) State attribute definition missing for + casesPerOneMillion
    coronavirus-statistics.0	2020-03-19 07:30:47.102	warn	(31245) State attribute definition missing for + casesPerOneMillion
    coronavirus-statistics.0	2020-03-19 07:30:46.955	warn	(31245) State attribute definition missing for + casesPerOneMillion
    cvidalC KnallochseK DutchmanD 3 Antworten Letzte Antwort
    • D
      D
      dos1973
      #95
      Wie formatiere ich denn denn DP, wann das letzte mal die Daten aktualisiert wurden. Da kommt bei mir ein Linux Zahlenwert. Also der unter „Global“
      • ScroungerS Scrounger
        @norman1991
        Das geht leider nicht ganz so einfach, weil das eine Schriftart ist, die im Material Design Widgets Adapter implementiert ist. Am einfachsten ist es die Widgets von meinem Adapter zu nutzen.
        Alterntiv könnt ihr Euch die icons auf https://materialdesignicons.com/ heraussuchen und herunterladen.
        Namen der verwendeten icons von links nach rechts:
        • biohazard
        • heart-pulse
        • seat-flat
        • grave-stone
        • hospital-box
        • skull-crossbones
        Uli977U
        Uli977U
        Uli977
        #96
        @Scrounger Danke!
        @sigi234 Danke!
        • D dos1973
          sigi234S
          sigi234S
          #97
          @dos1973 sagte in Test Coronavirus Statistics for ioBroker:
          Nimm das Widget Timestamp
          • sigi234S sigi234
            D
            D
            dos1973
            #98
            @sigi234 Danke, funktioniert!
            • ChaotC Chaot
              @Dutchman
              cvidalC
              cvidalC
              cvidal
              Forum Testing
              #99
              @Chaot sagte in Test Coronavirus Statistics for ioBroker:
              @Dutchman
              Kann ich bestätigen, ist bei mir seit heute auch so.
              • ChaotC Chaot
                @Dutchman
                KnallochseK
                KnallochseK
                Knallochse
                #100
                @Dutchman
                Bei mir auch
                • ChaotC Chaot
                  @Dutchman
                  DutchmanD
                  DutchmanD
                  Dutchman
                  schrieb am zuletzt editiert von Dutchman
                  #101
                  @cvidal sagte in Test Coronavirus Statistics for ioBroker:
                  Cool neue daten, kleine sorgen ich mach mal n update :)
                  • L
                    L
                    locito09
                    schrieb am zuletzt editiert von locito09
                    #102
                    Hier noch paar Länder flagen:
                    Welt.png Spanien.png Schweiz.png Portugal1.png Österreich.png Italien.png Deutschland.png
                    • DutchmanD
                      DutchmanD
                      Dutchman
                      #103
                      Ich finde es sehr cool was ihr alles auf die beine stellt mit den icons und views, ich bin aber kein front-end man. :/.
                      Wuerde mich ueber PR mit widget setzen freuen (open MIT license !)
                      • MyzerATM
                        MyzerATM
                        MyzerAT
                        #104
                        ich nutze auch diesen Adapter, erst mal an danke an @Dutchman für die Bereitstellung!
                        was mich aber verwirrt, die Todes Zahlen für Österreich sind nicht aktuell mit deren aus unseren Nachrichten, laut Medien sind in Österreich bereits 7 Menschen verstorben, der Adapter zeigt mir aber nur 5 an?
                        lg Rudi
                        Node 22.23.0
                        Nodejs 22.23.0
                        npm 10.9.8
                        js-controller 7.2.2
                        • C
                          C
                          Coffeelover
                          schrieb am zuletzt editiert von Coffeelover
                          #105
                          Das liegt daran, dass der Adapter gerade keine Daten zieht (Siehe Statement vor 20 Minuten).
                          Davon abgesehen hast du derzeit einfach unterschiedliche Quelle für die Zahlen, die nicht durchgängig synchronisiert sind.
                          • MyzerATM MyzerAT
                            sigi234S
                            sigi234S
                            #106
                            @MyzerAT sagte in Test Coronavirus Statistics for ioBroker:
                            Bitte beachten Sie, dass dieser Adapter so viele aktuelle Informationen wie möglich verwendet. Je nach Bericht des Landes kann es jedoch zu einer Verzögerung von mehreren Stunden kommen
                            ScroungerS 1 Antwort Letzte Antwort
                              DutchmanD
                              DutchmanD
                              Dutchman
                              #107
                              @Dutchman sagte in Test Coronavirus Statistics for ioBroker:
                              solved in 0.2.3
                              • sigi234S sigi234
                                ScroungerS
                                ScroungerS
                                Scrounger
                                schrieb am zuletzt editiert von Scrounger
                                #108
                                Als Anregung hier meine View(s) mit Material Design Widgets:
                                View mit Grid Widget mit Selects für Zeitintervall & Filter:
                                  "settings": {
                                    "style": {},
                                    "theme": "redmond",
                                    "sizex": "",
                                    "sizey": "",
                                    "gridSize": "",
                                    "snapType": null
                                  "widgets": {
                                    "e00001": {
                                      "tpl": "tplVis-materialdesign-Select",
                                      "data": {
                                        "oid": "0_userdata.0.vis.Corona.timeInterval",
                                        "g_fixed": false,
                                        "g_visibility": false,
                                        "g_css_font_text": false,
                                        "g_css_background": false,
                                        "g_css_shadow_padding": false,
                                        "g_css_border": false,
                                        "g_gestures": false,
                                        "g_signals": false,
                                        "g_last_change": false,
                                        "visibility-cond": "==",
                                        "visibility-val": 1,
                                        "visibility-groups-action": "hide",
                                        "inputType": "text",
                                        "inputLayout": "regular",
                                        "showInputMessageAlways": "true",
                                        "showInputCounter": false,
                                        "clearIconShow": false,
                                        "listDataMethod": "jsonStringObject",
                                        "countSelectItems": "1",
                                        "listPosition": "bottom",
                                        "showSelectedIcon": "prepend-inner",
                                        "showValue": false,
                                        "signals-cond-0": "==",
                                        "signals-val-0": true,
                                        "signals-icon-0": "/vis/signals/lowbattery.png",
                                        "signals-icon-size-0": 0,
                                        "signals-blink-0": false,
                                        "signals-horz-0": 0,
                                        "signals-vert-0": 0,
                                        "signals-hide-edit-0": false,
                                        "signals-cond-1": "==",
                                        "signals-val-1": true,
                                        "signals-icon-1": "/vis/signals/lowbattery.png",
                                        "signals-icon-size-1": 0,
                                        "signals-blink-1": false,
                                        "signals-horz-1": 0,
                                        "signals-vert-1": 0,
                                        "signals-hide-edit-1": false,
                                        "signals-cond-2": "==",
                                        "signals-val-2": true,
                                        "signals-icon-2": "/vis/signals/lowbattery.png",
                                        "signals-icon-size-2": 0,
                                        "signals-blink-2": false,
                                        "signals-horz-2": 0,
                                        "signals-vert-2": 0,
                                        "signals-hide-edit-2": false,
                                        "lc-type": "last-change",
                                        "lc-is-interval": true,
                                        "lc-is-moment": false,
                                        "lc-format": "",
                                        "lc-position-vert": "top",
                                        "lc-position-horz": "right",
                                        "lc-offset-vert": 0,
                                        "lc-offset-horz": 0,
                                        "lc-font-size": "12px",
                                        "lc-font-family": "",
                                        "lc-font-style": "",
                                        "lc-bkg-color": "",
                                        "lc-color": "",
                                        "lc-border-width": "0",
                                        "lc-border-style": "",
                                        "lc-border-color": "",
                                        "lc-border-radius": 10,
                                        "lc-zindex": 0,
                                        "inputLabelText": "Zeitintervall",
                                        "inputLabelColor": "#ffffff",
                                        "inputLabelFontFamily": "RobotoCondensed-LightItalic",
                                        "collapseIconColor": "#ffffff",
                                        "collapseIconSize": "",
                                        "jsonStringObject": "[   {\n\t\t\"text\": \"1 Tag\",\n\t\t\"value\": \"1 day\"\n\t}, \n\t{\n\t\t\"text\": \"3 Tage\",\n\t\t\"value\": \"3 days\"\n\t}, \n\t{\n\t\t\"text\": \"1 Woche\",\n\t\t\"value\": \"7 days\"\n\t}, \n\t{\n\t\t\"text\": \"2 Wochen\",\n\t\t\"value\": \"14 days\"\n\t}, \n\t{\n\t\t\"text\": \"1 Monat\",\n\t\t\"value\": \"1 month\"\n\t}, \n\t{\n\t\t\"text\": \"2 Monate\",\n\t\t\"value\": \"2 months\"\n\t}, \n\t{\n\t\t\"text\": \"3 Monate\",\n\t\t\"value\": \"3 months\"\n\t}, \n\t{\n\t\t\"text\": \"6 Monate\",\n\t\t\"value\": \"6 months\"\n\t}, \n\t{\n\t\t\"text\": \"1 Jahr\",\n\t\t\"value\": \"1 year\"\n\t}\n]",
                                        "listPositionOffset": true,
                                        "inputLayoutBackgroundColor": "transparent",
                                        "inputLabelColorSelected": "#ffffff",
                                        "inputTranslateX": "-15",
                                        "clearIcon": "",
                                        "inputLayoutBorderColorHover": "#ffffff",
                                        "inputLayoutBorderColorSelected": "#ffffff",
                                        "inputLayoutBorderColor": "#a1a1a1",
                                        "listItemFontColor": "",
                                        "inputTextColor": "#ffffff",
                                        "inputTextFontFamily": "RobotoCondensed-LightItalic",
                                        "prepandIcon": "",
                                        "prepandIconColor": "",
                                        "prepandIconSize": "",
                                        "prepandInnerIcon": "",
                                        "prepandInnerIconColor": "#ffffff",
                                        "prepandInnerIconSize": "18",
                                        "collapseIcon": "",
                                        "inputTranslateY": "-12",
                                        "listIconSelectedColor": "#44739e",
                                        "listIconColor": "",
                                        "appendOuterIcon": "",
                                        "appendOuterIconSize": "2",
                                        "listItemFont": "RobotoCondensed-Regular",
                                        "listItemRippleEffectColor": "",
                                        "inputLayoutBackgroundColorSelected": "",
                                        "inputLayoutBackgroundColorHover": "",
                                        "listIcon0": ""
                                      "style": {
                                        "left": "10px",
                                        "top": "0px",
                                        "z-index": "1",
                                        "width": "calc(50% - 50px)",
                                        "height": "40px"
                                      "widgetSet": "materialdesign"
                                    "e00002": {
                                      "tpl": "tplHtml",
                                      "data": {
                                        "g_fixed": false,
                                        "g_css_background": true,
                                        "g_signals": false,
                                        "refreshInterval": "0",
                                        "lc-format": "",
                                        "lc-bkg-color": "",
                                        "lc-color": "",
                                        "lc-zindex": 0
                                      "style": {
                                        "left": "0",
                                        "top": "0",
                                        "width": "100%",
                                        "height": "50px",
                                        "background-color": "#44739e"
                                      "widgetSet": "basic"
                                    "e00003": {
                                      "tpl": "tplTimeValue",
                                      "data": {
                                        "oid": "coronavirus-statistics.0.global_totals.updated",
                                        "g_fixed": false,
                                        "g_css_font_text": true,
                                        "g_signals": false,
                                        "lc-format": "",
                                        "lc-bkg-color": "",
                                        "lc-color": "",
                                        "lc-zindex": 0,
                                        "format_date": "DD.MM.YYYY<br>hh:mm"
                                      "style": {
                                        "left": "calc(100% - 70px)",
                                        "top": "12px",
                                        "width": "60px",
                                        "height": "26px",
                                        "color": "#ffffff",
                                        "text-align": "right",
                                        "z-index": "1",
                                        "font-family": "RobotoCondensed-Light",
                                        "font-size": "12px"
                                    "e00004": {
                                      "tpl": "tplVis-materialdesign-Grid-Views",
                                      "data": {
                                        "g_fixed": false,
                                        "g_signals": false,
                                        "countViews": "15",
                                        "viewVertAlignment": "center",
                                        "viewHorAlignment": "center",
                                        "showResolutionAssistant": false,
                                        "visibilityCondition0": "==",
                                        "visibilityCondition1": "==",
                                        "lc-format": "",
                                        "lc-bkg-color": "",
                                        "lc-color": "",
                                        "lc-zindex": 0,
                                        "visibilityCondition2": "==",
                                        "visibilityCondition3": "==",
                                        "View0": "CoronaVirus_World",
                                        "viewsHeight0": "400",
                                        "viewColSpan0": "4",
                                        "View1": "CoronaVirus_Europa",
                                        "viewsHeight1": "400",
                                        "desktopGaps": "4",
                                        "View2": "CoronaVirus_America",
                                        "viewsHeight2": "400",
                                        "View3": "CoronaVirus_North_America",
                                        "viewsHeight3": "400",
                                        "visibilityCondition4": "==",
                                        "visibilityCondition5": "==",
                                        "visibilityCondition6": "==",
                                        "visibilityCondition7": "==",
                                        "View4": "CoronaVirus_South_America",
                                        "viewsHeight4": "400",
                                        "View5": "CoronaVirus_Asia",
                                        "viewsHeight5": "400",
                                        "View6": "CoronaVirus_Africa",
                                        "viewsHeight6": "400",
                                        "viewColSpan1": "4",
                                        "viewColSpan2": "4",
                                        "viewColSpan3": "4",
                                        "viewColSpan4": "4",
                                        "viewColSpan5": "4",
                                        "viewColSpan6": "4",
                                        "handyGridPortraitColSpan0": "12",
                                        "handyGridLandscapeColSpan0": "12",
                                        "tabletGridPortraitColSpan0": "6",
                                        "tabletGridLandscapeColSpan0": "6",
                                        "handyGridPortraitColSpan1": "12",
                                        "handyGridLandscapeColSpan1": "12",
                                        "tabletGridPortraitColSpan1": "6",
                                        "tabletGridLandscapeColSpan1": "6",
                                        "handyGridPortraitColSpan2": "12",
                                        "handyGridLandscapeColSpan2": "12",
                                        "tabletGridPortraitColSpan2": "6",
                                        "tabletGridLandscapeColSpan2": "6",
                                        "handyGridPortraitColSpan4": "12",
                                        "handyGridLandscapeColSpan4": "12",
                                        "tabletGridPortraitColSpan4": "6",
                                        "tabletGridLandscapeColSpan4": "6",
                                        "handyGridPortraitColSpan5": "12",
                                        "handyGridLandscapeColSpan5": "12",
                                        "tabletGridPortraitColSpan5": "6",
                                        "tabletGridLandscapeColSpan5": "6",
                                        "handyGridPortraitColSpan6": "12",
                                        "handyGridLandscapeColSpan6": "12",
                                        "tabletGridPortraitColSpan6": "6",
                                        "tabletGridLandscapeColSpan6": "6",
                                        "handyGridPortraitColSpan3": "12",
                                        "handyGridLandscapeColSpan3": "12",
                                        "tabletGridPortraitColSpan3": "6",
                                        "tabletGridLandscapeColSpan3": "6",
                                        "viewsHeight7": "400",
                                        "viewColSpan7": "4",
                                        "handyGridPortraitColSpan7": "12",
                                        "handyGridLandscapeColSpan7": "12",
                                        "tabletGridPortraitColSpan7": "6",
                                        "tabletGridLandscapeColSpan7": "6",
                                        "View7": "CoronaVirus_Oceania",
                                        "visibleResolutionLessThan1": "",
                                        "visibilityOid0": "0_userdata.0.vis.Corona.visibileContinent",
                                        "visibilityConditionValue0": "true",
                                        "visibilityOid1": "0_userdata.0.vis.Corona.visibileContinent",
                                        "visibilityConditionValue1": "true",
                                        "visibilityOid2": "0_userdata.0.vis.Corona.visibileContinent",
                                        "visibilityConditionValue2": "true",
                                        "visibilityOid3": "0_userdata.0.vis.Corona.visibileContinent",
                                        "visibilityConditionValue3": "true",
                                        "visibilityOid4": "0_userdata.0.vis.Corona.visibileContinent",
                                        "visibilityConditionValue4": "true",
                                        "visibilityOid5": "0_userdata.0.vis.Corona.visibileContinent",
                                        "visibilityConditionValue5": "true",
                                        "visibilityOid6": "0_userdata.0.vis.Corona.visibileContinent",
                                        "visibilityConditionValue6": "true",
                                        "visibilityOid7": "0_userdata.0.vis.Corona.visibileContinent",
                                        "visibilityConditionValue7": "true",
                                        "visibilityCondition8": "==",
                                        "visibilityCondition9": "==",
                                        "visibilityCondition10": "==",
                                        "visibilityCondition11": "==",
                                        "visibilityCondition12": "==",
                                        "visibilityCondition13": "==",
                                        "visibilityCondition14": "==",
                                        "View8": "CoronaVirus_Deutschland",
                                        "viewsHeight8": "400",
                                        "viewColSpan8": "4",
                                        "handyGridPortraitColSpan8": "12",
                                        "handyGridLandscapeColSpan8": "12",
                                        "tabletGridPortraitColSpan8": "6",
                                        "tabletGridLandscapeColSpan8": "6",
                                        "visibilityOid8": "0_userdata.0.vis.Corona.visibileCountries",
                                        "visibilityConditionValue8": "true",
                                        "viewsHeight9": "400",
                                        "viewColSpan9": "4",
                                        "handyGridPortraitColSpan9": "12",
                                        "handyGridLandscapeColSpan9": "12",
                                        "tabletGridPortraitColSpan9": "6",
                                        "tabletGridLandscapeColSpan9": "6",
                                        "visibilityOid9": "0_userdata.0.vis.Corona.visibileCountries",
                                        "visibilityConditionValue9": "true",
                                        "View9": "CoronaVirus_USA",
                                        "viewsHeight10": "400",
                                        "viewColSpan10": "4",
                                        "handyGridPortraitColSpan10": "12",
                                        "handyGridLandscapeColSpan10": "12",
                                        "tabletGridPortraitColSpan10": "6",
                                        "tabletGridLandscapeColSpan10": "6",
                                        "visibilityOid10": "0_userdata.0.vis.Corona.visibileCountries",
                                        "visibilityConditionValue10": "true",
                                        "View10": "CoronaVirus_Italien",
                                        "viewsHeight11": "400",
                                        "viewColSpan11": "4",
                                        "handyGridPortraitColSpan11": "12",
                                        "handyGridLandscapeColSpan11": "12",
                                        "tabletGridPortraitColSpan11": "6",
                                        "tabletGridLandscapeColSpan11": "6",
                                        "visibilityOid11": "0_userdata.0.vis.Corona.visibileCountries",
                                        "visibilityConditionValue11": "true",
                                        "View11": "CoronaVirus_Spain",
                                        "viewsHeight12": "400",
                                        "viewColSpan12": "4",
                                        "handyGridPortraitColSpan12": "12",
                                        "handyGridLandscapeColSpan12": "12",
                                        "tabletGridPortraitColSpan12": "6",
                                        "tabletGridLandscapeColSpan12": "6",
                                        "visibilityOid12": "0_userdata.0.vis.Corona.visibileCountries",
                                        "visibilityConditionValue12": "true",
                                        "View12": "CoronaVirus_France",
                                        "tabletGridPortraitColSpan13": "6",
                                        "viewsHeight13": "400",
                                        "viewColSpan13": "4",
                                        "handyGridPortraitColSpan13": "12",
                                        "handyGridLandscapeColSpan13": "12",
                                        "tabletGridLandscapeColSpan13": "6",
                                        "visibilityOid13": "0_userdata.0.vis.Corona.visibileCountries",
                                        "visibilityConditionValue13": "true",
                                        "View13": "CoronaVirus_Austria",
                                        "viewsHeight14": "400",
                                        "viewColSpan14": "4",
                                        "handyGridPortraitColSpan14": "12",
                                        "handyGridLandscapeColSpan14": "12",
                                        "tabletGridPortraitColSpan14": "6",
                                        "tabletGridLandscapeColSpan14": "6",
                                        "visibilityOid14": "0_userdata.0.vis.Corona.visibileCountries",
                                        "visibilityConditionValue14": "true",
                                        "View14": "CoronaVirus_Schweiz",
                                        "visibilityCondition15": "==",
                                        "viewsHeight15": "400",
                                        "viewColSpan15": "4",
                                        "handyGridPortraitColSpan15": "12",
                                        "handyGridLandscapeColSpan15": "12",
                                        "tabletGridPortraitColSpan15": "6",
                                        "tabletGridLandscapeColSpan15": "6",
                                        "visibilityOid15": "0_userdata.0.vis.Corona.visibileCountries",
                                        "visibilityConditionValue15": "true",
                                        "View15": "CoronaVirus_China"
                                      "style": {
                                        "left": "0px",
                                        "top": "50px",
                                        "width": "100%",
                                        "height": "calc(100% - 50px)",
                                        "overflow-y": "auto"
                                    "e00005": {
                                      "data": {
                                        "oid": "0_userdata.0.vis.Corona.filter",
                                        "g_fixed": false,
                                        "g_signals": false,
                                        "clearIconShow": true,
                                        "showValue": false,
                                        "lc-format": "",
                                        "lc-bkg-color": "",
                                        "lc-color": "",
                                        "lc-zindex": 0,
                                        "inputLabelText": "Filter",
                                        "jsonStringObject": "[   {\n\t\t\"text\": \"Kontinente\",\n\t\t\"value\": \"continents\"\n\t}, \n\t{\n\t\t\"text\": \"Länder\",\n\t\t\"value\": \"countries\"\n\t}\n]",
                                        "clearIcon": "",
                                        "prepandIcon": "",
                                        "collapseIcon": "",
                                        "listIcon0": "",
                                        "clearIconColor": "#ffffff"
                                      "style": {
                                        "left": "calc(50% - 30px)",
                                        "top": "0px",
                                        "z-index": "1",
                                        "height": "40px"
                                  "name": "CoronaVirus",
                                  "filterList": []
                                View mit Statistik und Line History Graph - am Beispiel Welt:
                                  "settings": {
                                    "style": {
                                      "background_class": ""
                                    "theme": "redmond",
                                    "sizex": "",
                                    "sizey": "",
                                    "gridSize": "",
                                    "snapType": null
                                  "widgets": {
                                    "e00001": {
                                      "tpl": "tplVis-materialdesign-Card",
                                      "data": {
                                        "g_fixed": true,
                                        "g_signals": false,
                                        "titleLayout": "headline6",
                                        "subtitleLayout": "headline6",
                                        "cardLayout": "Basic",
                                        "cardStyle": "default",
                                        "lc-format": "",
                                        "lc-bkg-color": "",
                                        "lc-color": "",
                                        "lc-zindex": 0,
                                        "html": "",
                                        "labelSubTextHeight": "",
                                        "labelTextHeight": "",
                                        "subtitle": "",
                                        "title": "      Welt",
                                        "name": "Card",
                                        "colorTitle": "#44739e",
                                        "class": "my-card-container"
                                      "style": {
                                        "left": "",
                                        "top": "",
                                        "width": "",
                                        "height": "400px",
                                        "z-index": ""
                                    "e00002": {
                                      "tpl": "tplVis-materialdesign-Chart-Line-History",
                                      "data": {
                                        "g_fixed": false,
                                        "g_signals": false,
                                        "dataCount": "3",
                                        "aggregate": "max",
                                        "timeIntervalToShow": "1 day",
                                        "refreshMethod": "timeInterval",
                                        "refreshTimeInterval": "5 minutes",
                                        "pointStyle": "circle",
                                        "showLegend": "true",
                                        "legendPosition": "top",
                                        "legendPointStyle": "true",
                                        "showTooltip": "true",
                                        "tooltipTimeFormats": "{\"millisecond\":\"lll:ss\",\"second\":\"lll:ss\",\"minute\":\"lll\",\"hour\":\"lll\",\"day\":\"lll\",\"week\":\"lll\",\"month\":\"lll\",\"quarter\":\"lll\",\"year\":\"lll\"}",
                                        "tooltipShowColorBox": "true",
                                        "lineSpanGaps0": true,
                                        "lineSpanGaps1": "true",
                                        "xAxisPosition": "bottom",
                                        "xAxisBounds": "dataSet",
                                        "xAxisTimeFormats": "{\"millisecond\":\"H:mm:ss.SSS\",\"second\":\"H:mm:ss\",\"minute\":\"H:mm\",\"hour\":\"dd. H:mm\",\"day\":\"dd DD.MM\",\"week\":\"dd DD.MM\",\"month\":\"MMM YYYY\",\"quarter\":\"[Q]Q - YYYY\",\"year\":\"YYYY\"}",
                                        "xAxisValueDistanceToAxis": "0",
                                        "xAxisShowAxis": "true",
                                        "xAxisShowAxisLabels": "true",
                                        "xAxisShowGridLines": "true",
                                        "xAxisShowTicks": "true",
                                        "yAxisValueDistanceToAxis": "10",
                                        "showYAxis0": "true",
                                        "yAxisPosition0": "left",
                                        "yAxisShowGridLines0": true,
                                        "yAxisShowTicks0": "true",
                                        "yAxisShowAxisBorder0": "true",
                                        "showYAxis1": "true",
                                        "yAxisPosition1": "left",
                                        "yAxisShowGridLines1": false,
                                        "yAxisShowTicks1": "true",
                                        "yAxisShowAxisBorder1": "true",
                                        "showValues0": false,
                                        "valuesPositionAnchor0": "end",
                                        "valuesPositionAlign0": "top",
                                        "valuesTextAlign0": "center",
                                        "showValues1": false,
                                        "valuesPositionAnchor1": "end",
                                        "valuesPositionAlign1": "top",
                                        "valuesTextAlign1": "center",
                                        "lc-format": "",
                                        "lc-bkg-color": "",
                                        "lc-color": "",
                                        "lc-zindex": 0,
                                        "historyAdapterInstance": "sql.0",
                                        "oid0": "coronavirus-statistics.0.global_totals.cases",
                                        "dataColor0": "red",
                                        "legendText0": "Infiziert",
                                        "pointSizeHover": "",
                                        "pointSize": "0",
                                        "oid1": "coronavirus-statistics.0.global_totals.deaths",
                                        "dataColor1": "",
                                        "legendText1": "Todesfälle",
                                        "commonYAxis1": "0",
                                        "yAxisMinValue1": "0",
                                        "yAxisMinValue0": "0",
                                        "useFillColor1": false,
                                        "lineSpanGaps2": "true",
                                        "showYAxis2": "true",
                                        "yAxisPosition2": "left",
                                        "yAxisShowGridLines2": "true",
                                        "yAxisShowTicks2": "true",
                                        "yAxisShowAxisBorder2": "true",
                                        "showValues2": false,
                                        "valuesPositionAnchor2": "end",
                                        "valuesPositionAlign2": "top",
                                        "valuesTextAlign2": "center",
                                        "oid2": "coronavirus-statistics.0.global_totals.recovered",
                                        "commonYAxis2": "0",
                                        "legendText2": "Genesen",
                                        "dataColor2": "green",
                                        "useFillColor0": false,
                                        "useFillColor2": false,
                                        "legendFontFamily": "",
                                        "legendFontSize": "12",
                                        "legendBoxWidth": "4",
                                        "legendPadding": "",
                                        "xAxisValueFontSize": "10",
                                        "xAxisValueFontFamily": "RobotoCondensed-Light",
                                        "yAxisValueFontSize": "10",
                                        "yAxisValueFontFamily": "RobotoCondensed-Light",
                                        "lineTension2": "",
                                        "lineThikness2": "2",
                                        "lineThikness1": "2",
                                        "lineThikness0": "2",
                                        "time_interval_oid": "0_userdata.0.vis.Corona.timeInterval",
                                        "xAxisMaxLabel": "7",
                                        "maxDataPoints": "50",
                                        "lineTension0": "",
                                        "lineSpanGaps3": "true",
                                        "showYAxis3": "true",
                                        "yAxisPosition3": "right",
                                        "yAxisShowGridLines3": false,
                                        "yAxisShowTicks3": true,
                                        "yAxisShowAxisBorder3": true,
                                        "showValues3": false,
                                        "valuesPositionAnchor3": "end",
                                        "valuesPositionAlign3": "top",
                                        "valuesTextAlign3": "center",
                                        "oid3": "javascript.0.corona.continents.World.todayCases",
                                        "yAxisMinValue3": "0",
                                        "dataColor3": "darkorange",
                                        "legendText3": "Infiziert pro Tag",
                                        "useFillColor3": false,
                                        "lineThikness3": "2",
                                        "chartPaddingLeft": "5"
                                      "style": {
                                        "left": "10px",
                                        "top": "150px",
                                        "width": "calc(100% - 20px)",
                                        "height": "250px",
                                        "z-index": "1"
                                    "e00003": {
                                      "tpl": "tplImage",
                                      "data": {
                                        "g_fixed": false,
                                        "g_signals": false,
                                        "lc-format": "",
                                        "lc-bkg-color": "",
                                        "lc-color": "",
                                        "lc-zindex": 0,
                                        "src": "/vis.0/myImages/flags/world_2.png"
                                      "style": {
                                        "left": "10px",
                                        "top": "18px",
                                        "width": "30px",
                                        "height": "30px"
                                    "e00004": {
                                      "tpl": "tplVis-materialdesign-Icon-List",
                                      "data": {
                                        "g_fixed": false,
                                        "g_signals": false,
                                        "wrapItems": false,
                                        "listItemDataMethod": "inputPerEditor",
                                        "countListItems": "5",
                                        "vibrateOnMobilDevices": "50",
                                        "listLayout": "standard",
                                        "itemLayout": "vertical",
                                        "buttonLayout": "round",
                                        "autoLockAfter": "10",
                                        "lockIconTop": "5",
                                        "lockIconLeft": "5",
                                        "lockFilterGrayscale": "30",
                                        "lockApplyOnlyOnImage": "true",
                                        "listType0": "text",
                                        "showValueLabel0": true,
                                        "listType1": "text",
                                        "showValueLabel1": "true",
                                        "lc-format": "",
                                        "lc-bkg-color": "",
                                        "lc-color": "",
                                        "lc-zindex": 0,
                                        "listType2": "text",
                                        "showValueLabel2": "true",
                                        "listType3": "text",
                                        "showValueLabel3": "true",
                                        "listType4": "text",
                                        "showValueLabel4": "true",
                                        "listType5": "text",
                                        "showValueLabel5": "true",
                                        "listType6": "text",
                                        "showValueLabel6": "true",
                                        "listImage0": "biohazard",
                                        "label0": "<div class=\"my-corona-title\">Infiziert</div>",
                                        "subLabel0": "<div class=\"my-corona-value\">{coronavirus-statistics.0.global_totals.cases}</div>",
                                        "listImage1": "heart-pulse",
                                        "label1": "<div class=\"my-corona-title\">Genesen</div>",
                                        "subLabel1": "<div class=\"my-corona-value\">{coronavirus-statistics.0.global_totals.recovered}</div>",
                                        "listImage2": "seat-flat",
                                        "label2": "<div class=\"my-corona-title\">Kritisch</div>",
                                        "valueAppendix2": "",
                                        "subLabel2": "<div class=\"my-corona-value\">{javascript.0.corona.continents.World.critical}</div>",
                                        "label3": "<div class=\"my-corona-title\">Todesfälle</div>",
                                        "listImage3": "grave-stone",
                                        "subLabel3": "<div class=\"my-corona-value\">{coronavirus-statistics.0.global_totals.deaths}</div>",
                                        "listImage4": "hospital-box",
                                        "valueAppendix4": "",
                                        "label4": "<div class=\"my-corona-title\">Heute<br>Infiziert</div>",
                                        "subLabel4": "<div class=\"my-corona-value\">{javascript.0.corona.continents.World.todayCases}</div>",
                                        "listImage5": "skull-crossbones",
                                        "label5": "<div class=\"my-corona-title\">Heute<br>Todesfälle</div>",
                                        "subLabel5": "<div class=\"my-corona-value\">{javascript.0.corona.continents.World.todayDeaths}</div>",
                                        "iconHeight": "35",
                                        "verticalIconContainerHeight": "",
                                        "labelFontSize": "10",
                                        "labelFontFamily": "RobotoCondensed-Regular",
                                        "subLabelFontSize": "12",
                                        "subLabelFontFamily": "RobotoCondensed-LightItalic",
                                        "oid0": "",
                                        "itemGaps": "0",
                                        "valueFontSize": "",
                                        "listImageColor0": "red",
                                        "listImageColor1": "green",
                                        "listImageColor2": "gold",
                                        "listImageColor3": "",
                                        "listImageColor4": "darkorange",
                                        "listImageColor5": "black",
                                        "lockEnabled0": false,
                                        "itemBackgroundColor0": "",
                                        "horizontalIconContainerWidth": ""
                                      "style": {
                                        "left": "0px",
                                        "top": "60px",
                                        "width": "100%",
                                        "height": "96px"
                                  "name": "CoronaVirus_World",
                                  "filterList": []
                                Für Filter und Zeitinterval Funktion werden noch folgende Datenpunkte benötigt:
                                Und folgendes Skript damit man filtern kann:
                                // Filter für Corona Statistik
                                on({ id: '0_userdata.0.vis.Corona.filter', change: 'any' }, function (obj) {
                                    if (obj.state.val === 'continents') {
                                        setState('0_userdata.0.vis.Corona.visibileContinent', true, true);
                                        setState('0_userdata.0.vis.Corona.visibileCountries', false, true);
                                    } else if (obj.state.val === 'countries') {
                                        setState('0_userdata.0.vis.Corona.visibileContinent', false, true);
                                        setState('0_userdata.0.vis.Corona.visibileCountries', true, true);
                                    } else {
                                sigi234S Uli977U H M KusselinK 9 Antworten Letzte Antwort
                                    "settings": {
                                      "style": {},
                                      "theme": "redmond",
                                      "sizex": "",
                                      "sizey": "",
                                      "gridSize": "",
                                      "snapType": null
                                    "widgets": {
                                      "e00001": {
                                        "data": {
                                          "g_fixed": false,
                                          "g_signals": false,
                                          "showValue": false,
                                          "lc-format": "",
                                          "lc-bkg-color": "",
                                          "lc-color": "",
                                          "lc-zindex": 0,
                                          "clearIcon": "",
                                          "prepandIcon": "",
                                          "collapseIcon": "",
                                          "listIcon0": ""
                                        "style": {
                                          "left": "10px",
                                          "top": "0px",
                                          "z-index": "1",
                                          "height": "40px"
                                      "e00002": {
                                        "tpl": "tplHtml",
                                        "data": {
                                          "g_fixed": false,
                                          "g_signals": false,
                                          "lc-format": "",
                                          "lc-bkg-color": "",
                                          "lc-color": "",
                                          "lc-zindex": 0
                                        "style": {
                                          "left": "0",
                                          "top": "0",
                                          "width": "100%",
                                          "height": "50px",
                                      "e00003": {
                                        "data": {
                                          "g_fixed": false,
                                          "g_signals": false,
                                          "lc-format": "",
                                          "lc-bkg-color": "",
                                          "lc-color": "",
                                          "lc-zindex": 0,
                                        "style": {
                                          "top": "12px",
                                          "width": "60px",
                                          "height": "26px",
                                          "color": "#ffffff",
                                          "z-index": "1",
                                          "font-size": "12px"
                                      "e00004": {
                                        "data": {
                                          "g_fixed": false,
                                          "g_signals": false,
                                          "countViews": "15",
                                          "lc-format": "",
                                          "lc-bkg-color": "",
                                          "lc-color": "",
                                          "lc-zindex": 0,
                                          "desktopGaps": "4",
                                        "style": {
                                          "left": "0px",
                                          "top": "50px",
                                          "width": "100%",
                                      "e00005": {
                                        "data": {
                                          "g_fixed": false,
                                          "g_signals": false,
                                          "showValue": false,
                                          "lc-format": "",
                                          "lc-bkg-color": "",
                                          "lc-color": "",
                                          "lc-zindex": 0,
                                          "clearIcon": "",
                                          "prepandIcon": "",
                                          "collapseIcon": "",
                                          "listIcon0": "",
                                        "style": {
                                          "top": "0px",
                                          "z-index": "1",
                                          "height": "40px"
                                    "filterList": []
                                    "settings": {
                                      "style": {
                                      "theme": "redmond",
                                      "sizex": "",
                                      "sizey": "",
                                      "gridSize": "",
                                      "snapType": null
                                    "widgets": {
                                      "e00001": {
                                        "data": {
                                          "g_fixed": true,
                                          "g_signals": false,
                                          "lc-format": "",
                                          "lc-bkg-color": "",
                                          "lc-color": "",
                                          "lc-zindex": 0,
                                          "html": "",
                                          "subtitle": "",
                                          "title": "      Welt",
                                          "name": "Card",
                                        "style": {
                                          "left": "",
                                          "top": "",
                                          "width": "",
                                          "height": "400px",
                                          "z-index": ""
                                      "e00002": {
                                        "data": {
                                          "g_fixed": false,
                                          "g_signals": false,
                                          "dataCount": "3",
                                          "aggregate": "max",
                                          "lc-format": "",
                                          "lc-bkg-color": "",
                                          "lc-color": "",
                                          "lc-zindex": 0,
                                          "pointSize": "0",
                                          "dataColor1": "",
                                          "lineTension2": "",
                                          "lineTension0": "",
                                        "style": {
                                          "left": "10px",
                                          "top": "150px",
                                          "height": "250px",
                                          "z-index": "1"
                                      "e00003": {
                                        "tpl": "tplImage",
                                        "data": {
                                          "g_fixed": false,
                                          "g_signals": false,
                                          "lc-format": "",
                                          "lc-bkg-color": "",
                                          "lc-color": "",
                                          "lc-zindex": 0,
                                        "style": {
                                          "left": "10px",
                                          "top": "18px",
                                          "width": "30px",
                                          "height": "30px"
                                      "e00004": {
                                        "data": {
                                          "g_fixed": false,
                                          "g_signals": false,
                                          "wrapItems": false,
                                          "lockIconTop": "5",
                                          "lc-format": "",
                                          "lc-bkg-color": "",
                                          "lc-color": "",
                                          "lc-zindex": 0,
                                          "iconHeight": "35",
                                          "oid0": "",
                                          "itemGaps": "0",
                                        "style": {
                                          "left": "0px",
                                          "top": "60px",
                                          "width": "100%",
                                          "height": "96px"
                                    "filterList": []
                                      } else {
                                  sigi234S
                                  sigi234S
                                  #109
                                  @Scrounger sagte in Test Coronavirus Statistics for ioBroker:
                                  Welche Werte als Zeichenkette?
                                  • sigi234S sigi234
                                    ScroungerS
                                    ScroungerS
                                    Scrounger
                                    #110
                                    @sigi234 sagte in Test Coronavirus Statistics for ioBroker:
                                    Stimmt wichtig info :-)
                                    Die beiden müssen vom Typ Zeichenkette (String):
                                    • DutchmanD
                                      DutchmanD
                                      Dutchman
                                      #111
                                      Leute wen ihr noch Funktionen in den adapter integriert haben möchtet, macht n issue auf bitte diesen thread hier kan ich nicht vervolgen.
                                          "settings": {
                                            "style": {},
                                            "theme": "redmond",
                                            "sizex": "",
                                            "sizey": "",
                                            "gridSize": "",
                                            "snapType": null
                                          "widgets": {
                                            "e00001": {
                                              "data": {
                                                "g_fixed": false,
                                                "g_signals": false,
                                                "showValue": false,
                                                "lc-format": "",
                                                "lc-bkg-color": "",
                                                "lc-color": "",
                                                "lc-zindex": 0,
                                                "clearIcon": "",
                                                "prepandIcon": "",
                                                "collapseIcon": "",
                                                "listIcon0": ""
                                              "style": {
                                                "left": "10px",
                                                "top": "0px",
                                                "z-index": "1",
                                                "height": "40px"
                                            "e00002": {
                                              "tpl": "tplHtml",
                                              "data": {
                                                "g_fixed": false,
                                                "g_signals": false,
                                                "lc-format": "",
                                                "lc-bkg-color": "",
                                                "lc-color": "",
                                                "lc-zindex": 0
                                              "style": {
                                                "left": "0",
                                                "top": "0",
                                                "width": "100%",
                                                "height": "50px",
                                            "e00003": {
                                              "data": {
                                                "g_fixed": false,
                                                "g_signals": false,
                                                "lc-format": "",
                                                "lc-bkg-color": "",
                                                "lc-color": "",
                                                "lc-zindex": 0,
                                              "style": {
                                                "top": "12px",
                                                "width": "60px",
                                                "height": "26px",
                                                "color": "#ffffff",
                                                "z-index": "1",
                                                "font-size": "12px"
                                            "e00004": {
                                              "data": {
                                                "g_fixed": false,
                                                "g_signals": false,
                                                "countViews": "15",
                                                "lc-format": "",
                                                "lc-bkg-color": "",
                                                "lc-color": "",
                                                "lc-zindex": 0,
                                                "desktopGaps": "4",
                                              "style": {
                                                "left": "0px",
                                                "top": "50px",
                                                "width": "100%",
                                            "e00005": {
                                              "data": {
                                                "g_fixed": false,
                                                "g_signals": false,
                                                "showValue": false,
                                                "lc-format": "",
                                                "lc-bkg-color": "",
                                                "lc-color": "",
                                                "lc-zindex": 0,
                                                "clearIcon": "",
                                                "prepandIcon": "",
                                                "collapseIcon": "",
                                                "listIcon0": "",
                                              "style": {
                                                "top": "0px",
                                                "z-index": "1",
                                                "height": "40px"
                                          "filterList": []
                                          "settings": {
                                            "style": {
                                            "theme": "redmond",
                                            "sizex": "",
                                            "sizey": "",
                                            "gridSize": "",
                                            "snapType": null
                                          "widgets": {
                                            "e00001": {
                                              "data": {
                                                "g_fixed": true,
                                                "g_signals": false,
                                                "lc-format": "",
                                                "lc-bkg-color": "",
                                                "lc-color": "",
                                                "lc-zindex": 0,
                                                "html": "",
                                                "subtitle": "",
                                                "title": "      Welt",
                                                "name": "Card",
                                              "style": {
                                                "left": "",
                                                "top": "",
                                                "width": "",
                                                "height": "400px",
                                                "z-index": ""
                                            "e00002": {
                                              "data": {
                                                "g_fixed": false,
                                                "g_signals": false,
                                                "dataCount": "3",
                                                "aggregate": "max",
                                                "lc-format": "",
                                                "lc-bkg-color": "",
                                                "lc-color": "",
                                                "lc-zindex": 0,
                                                "pointSize": "0",
                                                "dataColor1": "",
                                                "lineTension2": "",
                                                "lineTension0": "",
                                              "style": {
                                                "left": "10px",
                                                "top": "150px",
                                                "height": "250px",
                                                "z-index": "1"
                                            "e00003": {
                                              "tpl": "tplImage",
                                              "data": {
                                                "g_fixed": false,
                                                "g_signals": false,
                                                "lc-format": "",
                                                "lc-bkg-color": "",
                                                "lc-color": "",
                                                "lc-zindex": 0,
                                              "style": {
                                                "left": "10px",
                                                "top": "18px",
                                                "width": "30px",
                                                "height": "30px"
                                            "e00004": {
                                              "data": {
                                                "g_fixed": false,
                                                "g_signals": false,
                                                "wrapItems": false,
                                                "lockIconTop": "5",
                                                "lc-format": "",
                                                "lc-bkg-color": "",
                                                "lc-color": "",
                                                "lc-zindex": 0,
                                                "iconHeight": "35",
                                                "oid0": "",
                                                "itemGaps": "0",
                                              "style": {
                                                "left": "0px",
                                                "top": "60px",
                                                "width": "100%",
                                                "height": "96px"
                                          "filterList": []
                                            } else {
                                        Uli977U
                                        Uli977U
                                        Uli977
                                        #112
                                        @Scrounger Bei mir kommen keine Linien?! Wo ist der Fehler?
                                        C 1 Antwort Letzte Antwort
                                        • MyzerATM
                                          MyzerATM
                                          MyzerAT
                                          #113
                                          wie komme ich jetzt zu version 0.2.3 ??
                                          lg Rudi
                                          Node 22.23.0
                                          Nodejs 22.23.0
                                          npm 10.9.8
                                          js-controller 7.2.2
                                          84.2k
