  4. Test Coronavirus Statistics for ioBroker
adapter installationadapterentwicklungtesten
1.2k Beiträge 120 Kommentatoren 627.6k Aufrufe 94 Beobachtet
  • DutchmanD Dutchman
    Aktuelle Test Version 0.6.9
    Veröffentlichungsdatum 22-03-2021
    Github Link https://github.com/iobroker-community-adapters/ioBroker.coronavirus-statistics/blob/master/README.md
    NPM npm i ioBroker.coronavirus-statistics@latest
    Adapter to show Global Corona Virus information and current reports
    Coronavirus Live Statistics adapter for ioBroker
    There is no configuration required, after installation it will :
    • Receive global information world-wide and write it to "global_totals"
    • Create a folder for each country with all relevant information regarding COVID-19
    • Update the information every 15 minutes
    The following information is available :
    Datapoint Details
    active Amount of current infected people
    cases Amount of totally known cases
    casesPerOneMillion Amount of totally known cases per million citizen
    critical Amount of critical situation (Hospitalized)
    deaths Amount of current registered deaths
    deathsPerOneMillion Amount of current registered deaths per million citizen
    recovered Amount of totally known recovered cases
    todayCases New Cases by Today
    todayDeaths Amount of totally known people died today
    test Total number of covid-19 tests taken globally
    tests per one million counties Total number of covid-19 tests taken globally per one million
    Please be aware this adapter uses as much as possible up-to-date information but there can be an delay of several hours depending on the country's report.
    German Federal States : https://npgeo-corona-npgeo-de.hub.arcgis.com/ s
    Generic Source : https://coronavirus-19-api.herokuapp.com
    Advanced settings
    Option Description
    All Countries Get data for all countries World-Wide (Default: false)
    Continents Group total amounts by continent in seperate state (Default: false)
    Delete unused States Delete data when countries are deselected (Default: false)
    German counties Get counties data for Germany (Selected only, Default false)
    German federal states Get federal state data for Germany (Selected only, Default false)
    Get all German federal states Get federal state data for Germany (Default false)
    Get all German counties Get all counties data for Germany (Default false)
    For Germany only
    It's possible to get data for federal states (Bundesländer) and counties (Landeskreise).
    You can choose to recieve all data or just select specific regions in advanced settings.
    Please note : After activation the the adapter must run 1 time to get all federal states and counties before table loads !
    Add missing countries
    It may happen that countries are not recognized correctly because the API delivers some country names not ISO conform. In such a case you will get a warning message in the log, which looks like this
    coronavirus-statistics.0	2020-03-21 09:05:31.328	warn	(22937) Timor-Leste not found in lib! Must be added to the country name translator.
    Using the datapoint coronavirus-statistics.0.countryTranslator you can assign a country yourself. Look for the name of the corresponding country here:
    List with country names
    With the selected country name you have to create a JSON string and enter it in the datapoint coronavirus-statistics.0.countryTranslator.
    The JSON string then looks like this, for example:
    	"Cabo_Verde": "Cape Verde",
    	"Timor-Leste": "East Timor"
    As first value the name from the warning message must be taken from the log. The name of the country from the List with country names is then assigned to this.
    Changelog
    sigi234S
    sigi234S
    @Dutchman
    coronavirus-statistics.0	2020-03-16 15:18:59.329	info	(13556) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    coronavirus-statistics.0	2020-03-16 15:18:55.508	warn	(13556) State attribute definition missing for + updated
    coronavirus-statistics.0	2020-03-16 15:18:50.119	info	(13556) starting. Version 0.2.0 in C:/Program Files/iobroker/Test/node_modules/iobroker.coronavirus-statistics, node: v10.16.3
    • sigi234S sigi234
      @Dutchman
      Hallo, wie kann ich das Widget anwenden?
      Erledigt, ein Neustart hat geholfen.
      LatziL
      LatziL
      Latzi
      @sigi234 sagte in Test Coronavirus Statistics for ioBroker:
      Die Frage stellt sich mir auch, dummerweise hat ein Neustart mir nicht die Augen geöffnet. Kannst du mir bitte weiterhelfen?
      • sigi234S sigi234
        @Dutchman
        @Dutchman
        Habe das WARN auch
        • LatziL Latzi
          sigi234S
          sigi234S
          @Latzi sagte in Test Coronavirus Statistics for ioBroker:
          • T
            T
            Tobias
            Habt ihr auch ein Problem mit der Darstellung?
            Unterste Zeile...
            • T Tobias
              Unterste Zeile...
              sigi234S
              sigi234S
              @Tobias
              CSS Font und Text
              T 1Topf1 2 Antworten Letzte Antwort
              • S
                S
                stimezo
                Forum Testing
                Kann man sich aber auch schnell selber basteln :-) :
                Christian
                sigi234S C P A 4 Antworten Letzte Antwort
                • S stimezo
                  Christian
                  sigi234S
                  sigi234S
                  @stimezo
                  Kannst du die Icons zur Verfügung stellen?
                  • sigi234S sigi234
                    @stimezo
                    S
                    S
                    stimezo
                    Forum Testing
                    @stimezo
                    Per mail?
                    Christian
                    • sigi234S sigi234
                      @Tobias
                      CSS Font und Text
                      T
                      T
                      Tobias
                      @sigi234
                      Danke. Da bin ich ja echt ein newbie...
                        @Dutchman
                        Habe das WARN auch
                        DutchmanD
                        DutchmanD
                        Dutchman
                        @Homoran sagte in Test Coronavirus Statistics for ioBroker:
                        Habe das WARN auch
                        fixed in 0.2.1
                        • M
                          M
                          MartyBr
                          Hallo, kann mir Jemand sagen, wo ich das Widget finde?
                          Danke.
                          Martin
                          Homematic und Homematic IP
                          • M MartyBr
                            Danke.
                            @MartyBr Da wo die anderen auch sind...
                              M
                              M
                              MartyBr
                              @Yetiberg Im VIS Editor? Ich habe den ioBroker schon neu gestartet, finde ihn aber nicht.
                              Wie heißt das Widget?
                              Martin
                              LatziL 1 Antwort Letzte Antwort
                              • M MartyBr
                                LatziL
                                LatziL
                                Latzi
                                @MartyBr sagte in Test Coronavirus Statistics for ioBroker:
                                benutzt du Firefox? Da hab ich auch das Problem gehabt (trotz cache leeren). Mit Chrome hat´s funktioniert.
                                • LatziL Latzi
                                  M
                                  M
                                  MartyBr
                                  @Latzi
                                  Nein Safari (Mac). Habe Safari neu gestartet und nun ist es da!
                                  Vielen Dank
                                  Martin
                                  • S stimezo
                                    Christian
                                    C
                                    C
                                    Coffeelover
                                    @stimezo Würdest du deine VIS teilen?
                                    • L
                                      L
                                      leif1
                                      Danke, läuft einwandfrei. Bei einem Land steht "Ich rannte". Auto Complete beim Iran? :)
                                      • L leif1
                                        sigi234S
                                        sigi234S
                                        @leif1 sagte in Test Coronavirus Statistics for ioBroker:
                                        Und Diamantprinzessin
                                        • harrymH
                                          harrymH
                                          harrym
                                          es erschreckende derzeit ist eher, dass in A und Co (wo echt harte Maßnahmen getroffen wurden) die Verbreitung stagniert.
                                          Bei uns in D sieht es derzeit anders aus :/
                                          ASRock FM2A88X-ITX+ mit 32GB RAM, 128GB SSD mit Proxmox, 3x1 TB SSD als RAID mit CT und VMs.
                                          84.2k
