  4. Test Coronavirus Statistics for ioBroker
adapter installationadapterentwicklungtesten
1.2k Beiträge 120 Kommentatoren 599.8k Aufrufe 94 Beobachtet
  • sigi234S sigi234
    @Dutchman sagte in Test Coronavirus Statistics for ioBroker:
    @sigi234 sagte in Test Coronavirus Statistics for ioBroker:
    sie meinen ?
    Größe änderbar
    welche Größe ?
    DutchmanD
    DutchmanD
    Dutchman
    sie meinen ?
    Größe änderbar
    welche Größe ?
    da bin ich raus @Bluefox war so nett die zu machen front-end ist nicht meine stärke
    • DutchmanD Dutchman
      Aktuelle Test Version 0.6.9
      Veröffentlichungsdatum 22-03-2021
      Github Link https://github.com/iobroker-community-adapters/ioBroker.coronavirus-statistics/blob/master/README.md
      NPM npm i ioBroker.coronavirus-statistics@latest
      Adapter to show Global Corona Virus information and current reports
      Coronavirus Live Statistics adapter for ioBroker
      There is no configuration required, after installation it will :
      • Receive global information world-wide and write it to "global_totals"
      • Create a folder for each country with all relevant information regarding COVID-19
      • Update the information every 15 minutes
      The following information is available :
      Datapoint Details
      active Amount of current infected people
      cases Amount of totally known cases
      casesPerOneMillion Amount of totally known cases per million citizen
      critical Amount of critical situation (Hospitalized)
      deaths Amount of current registered deaths
      deathsPerOneMillion Amount of current registered deaths per million citizen
      recovered Amount of totally known recovered cases
      todayCases New Cases by Today
      todayDeaths Amount of totally known people died today
      test Total number of covid-19 tests taken globally
      tests per one million counties Total number of covid-19 tests taken globally per one million
      Please be aware this adapter uses as much as possible up-to-date information but there can be an delay of several hours depending on the country's report.
      German Federal States : https://npgeo-corona-npgeo-de.hub.arcgis.com/ s
      Generic Source : https://coronavirus-19-api.herokuapp.com
      Advanced settings
      Option Description
      All Countries Get data for all countries World-Wide (Default: false)
      Continents Group total amounts by continent in seperate state (Default: false)
      Delete unused States Delete data when countries are deselected (Default: false)
      German counties Get counties data for Germany (Selected only, Default false)
      German federal states Get federal state data for Germany (Selected only, Default false)
      Get all German federal states Get federal state data for Germany (Default false)
      Get all German counties Get all counties data for Germany (Default false)
      For Germany only
      It's possible to get data for federal states (Bundesländer) and counties (Landeskreise).
      You can choose to recieve all data or just select specific regions in advanced settings.
      Please note : After activation the the adapter must run 1 time to get all federal states and counties before table loads !
      Add missing countries
      It may happen that countries are not recognized correctly because the API delivers some country names not ISO conform. In such a case you will get a warning message in the log, which looks like this
      coronavirus-statistics.0	2020-03-21 09:05:31.328	warn	(22937) Timor-Leste not found in lib! Must be added to the country name translator.
      Using the datapoint coronavirus-statistics.0.countryTranslator you can assign a country yourself. Look for the name of the corresponding country here:
      List with country names
      With the selected country name you have to create a JSON string and enter it in the datapoint coronavirus-statistics.0.countryTranslator.
      The JSON string then looks like this, for example:
      	"Cabo_Verde": "Cape Verde",
      	"Timor-Leste": "East Timor"
      As first value the name from the warning message must be taken from the log. The name of the country from the List with country names is then assigned to this.
      Changelog
      sigi234S
      sigi234S
      @Dutchman
      coronavirus-statistics.0	2020-03-16 15:18:59.329	info	(13556) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      coronavirus-statistics.0	2020-03-16 15:18:55.508	warn	(13556) State attribute definition missing for + updated
      coronavirus-statistics.0	2020-03-16 15:18:50.119	info	(13556) starting. Version 0.2.0 in C:/Program Files/iobroker/Test/node_modules/iobroker.coronavirus-statistics, node: v10.16.3
      • sigi234S sigi234
        @Dutchman
        Hallo, wie kann ich das Widget anwenden?
        Erledigt, ein Neustart hat geholfen.
        LatziL
        LatziL
        Latzi
        Die Frage stellt sich mir auch, dummerweise hat ein Neustart mir nicht die Augen geöffnet. Kannst du mir bitte weiterhelfen?
        • sigi234S sigi234
          @Dutchman
          @Dutchman
          Habe das WARN auch
          • LatziL Latzi
            sigi234S
            sigi234S
            @Latzi sagte in Test Coronavirus Statistics for ioBroker:
            • T
              T
              Tobias
              Habt ihr auch ein Problem mit der Darstellung?
              Unterste Zeile...
              • T Tobias
                Unterste Zeile...
                sigi234S
                sigi234S
                @Tobias
                CSS Font und Text
                T 1Topf1 2 Antworten Letzte Antwort
                • S
                  S
                  stimezo
                  Forum Testing
                  Kann man sich aber auch schnell selber basteln :-) :
                  Christian
                  sigi234S C P A 4 Antworten Letzte Antwort
                  • S stimezo
                    Christian
                    sigi234S
                    sigi234S
                    @stimezo
                    Kannst du die Icons zur Verfügung stellen?
                    • sigi234S sigi234
                      @stimezo
                      S
                      S
                      stimezo
                      Forum Testing
                      @stimezo
                      Per mail?
                      Christian
                      • sigi234S sigi234
                        @Tobias
                        CSS Font und Text
                        T
                        T
                        Tobias
                        @sigi234
                        Danke. Da bin ich ja echt ein newbie...
                          @Dutchman
                          Habe das WARN auch
                          DutchmanD
                          DutchmanD
                          Dutchman
                          @Homoran sagte in Test Coronavirus Statistics for ioBroker:
                          Habe das WARN auch
                          fixed in 0.2.1
                          • M
                            M
                            MartyBr
                            Hallo, kann mir Jemand sagen, wo ich das Widget finde?
                            Danke.
                            Martin
                            Homematic und Homematic IP
                            • M MartyBr
                              Danke.
                              @MartyBr Da wo die anderen auch sind...
                                M
                                M
                                MartyBr
                                @Yetiberg Im VIS Editor? Ich habe den ioBroker schon neu gestartet, finde ihn aber nicht.
                                Wie heißt das Widget?
                                Martin
                                LatziL 1 Antwort Letzte Antwort
                                • M MartyBr
                                  LatziL
                                  LatziL
                                  Latzi
                                  @MartyBr sagte in Test Coronavirus Statistics for ioBroker:
                                  benutzt du Firefox? Da hab ich auch das Problem gehabt (trotz cache leeren). Mit Chrome hat´s funktioniert.
                                  • LatziL Latzi
                                    M
                                    M
                                    MartyBr
                                    @Latzi
                                    Nein Safari (Mac). Habe Safari neu gestartet und nun ist es da!
                                    Vielen Dank
                                    Martin
                                    • S stimezo
                                      Christian
                                      C
                                      C
                                      Coffeelover
                                      @stimezo Würdest du deine VIS teilen?
                                      • L
                                        L
                                        leif1
                                        Danke, läuft einwandfrei. Bei einem Land steht "Ich rannte". Auto Complete beim Iran? :)
                                        • L leif1
                                          sigi234S
                                          sigi234S
                                          @leif1 sagte in Test Coronavirus Statistics for ioBroker:
                                          Und Diamantprinzessin
                                          84.2k
